[PATCH] mkimage: Improve documentation of algo-name parameter
Addresses the feedback provided on 5902a397d029 which raced with the merge.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- doc/mkimage.1 | 2 +- tools/imagetool.h | 3 ++- 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/doc/mkimage.1 b/doc/mkimage.1 index 0734bd36a11..fc84cca066b 100644 --- a/doc/mkimage.1 +++ b/doc/mkimage.1 @@ -158,7 +158,7 @@ CONFIG_OF_CONTROL in U-Boot. .TP .BI "-o [" "signing algorithm" "]" Specifies the algorithm to be used for signing a FIT image. The default is -taken from the target signature nodes 'algo' properties. +taken from the signature node's 'algo' property.
.TP .BI "-p [" "external position" "]" diff --git a/tools/imagetool.h b/tools/imagetool.h index a4105515d81..12f911600f9 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -71,7 +71,8 @@ struct image_tool_params { const char *keydest; /* Destination .dtb for public key */ const char *keyfile; /* Filename of private or public key */ const char *comment; /* Comment to add to signature node */ - const char *algo_name; /* Algorithm name to use hashing/signing */ + const char *algo_name; /* Algorithm name to use for hashing/signing or + NULL to use the one specified in the its */ int require_keys; /* 1 to mark signing keys as 'required' */ int file_size; /* Total size of output file */ int orig_file_size; /* Original size for file before padding */
nit below
Best to move this to before the code line, since we try to avoid splitting one-line comments like this.
-- 2.34.1
Jan Kiszka
