[U-Boot] [PATCH v2 0/8] dm: pci: tegra: Convert Tegra PCI to driver model
This series converts all Tegra boards to use driver model for PCI. The net effect should be no change in functionality.
A few additional features are added to make this possible: - Helper functions to support accessing 8- and 16-bit values within a 32-bit word - Fixing a build error for CONFIG_CMD_PCI_ENUM - Decoding the PCI ranges property such that configuration ranges are ignored - Supporting bus-master devices on boards where RAM does not start at 0
This series is tested on beaver. It is available at u-boot-dm/tegra-working.
Changes in v2: - Update commit message to explain that the feature is not important - Drop the feature from tegra boards - Rename 'addr' to 'size' - Correct logic for use of gd->pci_ram_top - Update commit message to mention future work - Use the device_is_on_pci_bus() API - Leave pci_skip_dev() at the bottom of the file to reduce the diff size
Simon Glass (8): dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig dm: pci: Avoid a driver model build error with CONFIG_CMD_PCI_ENUM dm: pci: Set up the SDRAM mapping correctly dm: pci: Support decoding ranges with duplicate entries dm: pci: Add functions to emulate 8- and 16-bit access dm: pci: Add a function to get the controller for a bus dm: pci: Add a function to find the regions for a PCI bus dm: tegra: pci: Convert tegra boards to driver model for PCI
arch/arm/mach-tegra/Kconfig | 1 + common/cmd_pci.c | 4 + configs/apalis_t30_defconfig | 1 + configs/beaver_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/trimslice_defconfig | 1 + drivers/pci/Kconfig | 10 ++ drivers/pci/pci-uclass.c | 105 +++++++++++- drivers/pci/pci_tegra.c | 394 +++++++++++++++---------------------------- include/configs/apalis_t30.h | 2 - include/configs/beaver.h | 2 - include/configs/cardhu.h | 2 - include/configs/jetson-tk1.h | 2 - include/configs/trimslice.h | 2 - include/fdtdec.h | 3 - include/pci.h | 51 ++++++ lib/fdtdec.c | 3 - 18 files changed, 304 insertions(+), 282 deletions(-)
Move this option to Kconig and fix up all users.
Changes in v2: None
configs/apalis_t30_defconfig | 1 + configs/beaver_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/trimslice_defconfig | 1 + drivers/pci/Kconfig | 10 ++++++++++ include/configs/apalis_t30.h | 1 - include/configs/beaver.h | 1 - include/configs/cardhu.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/trimslice.h | 1 - 11 files changed, 15 insertions(+), 5 deletions(-)
diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 8971d29..871dc43 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="Apalis T30 # " # CONFIG_CMD_NFS is not set CONFIG_NETDEVICES=y CONFIG_E1000=y +CONFIG_PCI_TEGRA=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 4a6f6e4..dfc9adf 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y +CONFIG_PCI_TEGRA=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 722bbeb..9e4a123 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y +CONFIG_PCI_TEGRA=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 6df5c7e..7b1992b 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y +CONFIG_PCI_TEGRA=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 18292e2..08e1b62 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y +CONFIG_PCI_TEGRA=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 167d405..c219c19 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -19,4 +19,14 @@ config PCI_SANDBOX the device tree but the normal PCI scan technique is used to find then.
+config PCI_TEGRA + bool "Tegra PCI support" + depends on TEGRA + help + Enable support for the PCIe controller found on some generations of + Tegra. Tegra20 has 2 root ports with a total of 4 lanes, Tegra30 has + 3 root ports with a total of 6 lanes and Tegra124 has 2 root ports + with a total of 5 lanes. Some boards require this for Ethernet + support to work (e.g. beaver, jetson-tk1). + endmenu diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index fe1ef9d..7552a80 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -49,7 +49,6 @@
/* PCI host support */ #define CONFIG_PCI -#define CONFIG_PCI_TEGRA #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/include/configs/beaver.h b/include/configs/beaver.h index 1790f60..9e8dcf3f7 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -73,7 +73,6 @@
/* PCI host support */ #define CONFIG_PCI -#define CONFIG_PCI_TEGRA #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index ce6b158..174bb48 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -75,7 +75,6 @@
/* PCI host support */ #define CONFIG_PCI -#define CONFIG_PCI_TEGRA #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index e87a010..618ffa6 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -59,7 +59,6 @@
/* PCI host support */ #define CONFIG_PCI -#define CONFIG_PCI_TEGRA #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index 2ab5511..bdf1bd4 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -58,7 +58,6 @@
This is not supported with driver model, so print a message instead of generating a build error. Rescanning PCI is not yet implemented.
This function will be implemented later once some additional PCI driver model improvements are merged. It was confirmed on the mailing list that no one on the tegra side will miss this feature, so it is disabled for tegra.
common/cmd_pci.c | 4 ++++ include/configs/apalis_t30.h | 1 - include/configs/beaver.h | 1 - include/configs/cardhu.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/trimslice.h | 1 - 6 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index dcecef8..69c5332 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -457,7 +457,11 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return pci_cfg_display(bdf, addr, size, value); #ifdef CONFIG_CMD_PCI_ENUM case 'e': +# ifdef CONFIG_DM_PCI + printf("This command is not yet supported with driver model\n"); +# else pci_init(); +# endif return 0; #endif case 'n': /* next */ diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index 7552a80..e1eb700 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -51,7 +51,6 @@ #define CONFIG_PCI #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI -#define CONFIG_CMD_PCI_ENUM
/* PCI networking support */ #define CONFIG_E1000_NO_NVM diff --git a/include/configs/beaver.h b/include/configs/beaver.h index 9e8dcf3f7..a2c9622 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -75,7 +75,6 @@ #define CONFIG_PCI #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI -#define CONFIG_CMD_PCI_ENUM
/* PCI networking support */ #define CONFIG_RTL8169 diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index 174bb48..0d857bb 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -77,7 +77,6 @@ #define CONFIG_PCI #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI -#define CONFIG_CMD_PCI_ENUM
/* PCI networking support */ #define CONFIG_RTL8169 diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 618ffa6..7e0cc5e 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -61,7 +61,6 @@ #define CONFIG_PCI #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI -#define CONFIG_CMD_PCI_ENUM
/* PCI networking support */ #define CONFIG_RTL8169 diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index bdf1bd4..add5d40 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -60,7 +60,6 @@ #define CONFIG_PCI #define CONFIG_PCI_PNP #define CONFIG_CMD_PCI -#define CONFIG_CMD_PCI_ENUM
SDRAM doesn't always start at 0. Adjust the region mapping so that it works on platforms where SDRAM is somewhere else.
This needs testing on other platforms.
Changes in v2: - Rename 'addr' to 'size' - Correct logic for use of gd->pci_ram_top
drivers/pci/pci-uclass.c | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 1d93194..6d860c4 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -680,8 +680,8 @@ static int decode_regions(struct pci_controller *hose, const void *blob, int parent_node, int node) { int pci_addr_cells, addr_cells, size_cells; + phys_addr_t base = 0, size; int cells_per_record; - phys_addr_t addr; const u32 *prop; int len; int i; @@ -732,11 +732,14 @@ static int decode_regions(struct pci_controller *hose, const void *blob, }
/* Add a region for our local memory */ - addr = gd->ram_size; - if (gd->pci_ram_top && gd->pci_ram_top < addr) - addr = gd->pci_ram_top; - pci_set_region(hose->regions + hose->region_count++, 0, 0, addr, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + size = gd->ram_size; +#ifdef CONFIG_SYS_SDRAM_BASE + base = CONFIG_SYS_SDRAM_BASE; +#endif + if (gd->pci_ram_top && gd->pci_ram_top < base + size) + size = gd->pci_ram_top - base; + pci_set_region(hose->regions + hose->region_count++, base, base, + size, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY);
return 0; }
At present we add a new resource entry for every range entry. But some range entries refer to configuration regions. To make this work, avoid adding two regions of the same type. The later ranges will overwrite the earlier (configuration) ones.
There does not seem to be a way to distinguish the configuration ranges other than by ordering (as per the device tree binding).
We could perhaps instead just store one region of each type in a simple array. Once we are sure that we don't need to support multiple regions, we could change this. It would be easier to do it when all drivers are converted to use driver model for PCI.
Changes in v2: - Update commit message to mention future work
drivers/pci/pci-uclass.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 6d860c4..7b48879 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -704,6 +704,7 @@ static int decode_regions(struct pci_controller *hose, const void *blob, int space_code; u32 flags; int type; + int pos;
if (len < cells_per_record) break; @@ -726,9 +727,15 @@ static int decode_regions(struct pci_controller *hose, const void *blob, } else { continue; } - debug(" - type=%d\n", type); - pci_set_region(hose->regions + hose->region_count++, pci_addr, - addr, size, type); + pos = -1; + for (i = 0; i < hose->region_count; i++) { + if (hose->regions[i].flags == type) + pos = i; + } + if (pos == -1) + pos = hose->region_count++; + debug(" - type=%d, pos=%d\n", type, pos); + pci_set_region(hose->regions + pos, pci_addr, addr, size, type); }
Provide a few functions to support using 32-bit access to emulate 8- and 16-bit access.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Stephen Warren swarren@nvidia.com ---
Changes in v2: None
drivers/pci/pci-uclass.c | 39 +++++++++++++++++++++++++++++++++++++++ include/pci.h | 31 +++++++++++++++++++++++++++++++ 2 files changed, 70 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 7b48879..e38e0b2 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -927,6 +927,45 @@ int pci_find_first_device(struct udevice **devp) return skip_to_next_device(bus, devp); }
+ulong pci_conv_32_to_size(ulong value, uint offset, enum pci_size_t size) +{ + switch (size) { + case PCI_SIZE_8: + return (value >> ((offset & 3) * 8)) & 0xff; + case PCI_SIZE_16: + return (value >> ((offset & 2) * 8)) & 0xffff; + default: + return value; + } +} + +ulong pci_conv_size_to_32(ulong old, ulong value, uint offset, + enum pci_size_t size) +{ + uint off_mask; + uint val_mask, shift; + ulong ldata, mask; + + switch (size) { + case PCI_SIZE_8: + off_mask = 3; + val_mask = 0xff; + break; + case PCI_SIZE_16: + off_mask = 2; + val_mask = 0xffff; + break; + default: + return value; + } + shift = (offset & off_mask) * 8; + ldata = (value & val_mask) << shift; + mask = val_mask << shift; + value = (old & ~mask) | ldata; + + return value; +} + UCLASS_DRIVER(pci) = { .id = UCLASS_PCI, .name = "pci", diff --git a/include/pci.h b/include/pci.h index ed135a5..ec2d104 100644 --- a/include/pci.h +++ b/include/pci.h @@ -1092,6 +1092,37 @@ static inline int pci_read_config_byte(pci_dev_t pcidev, int offset, }
/** + * pci_conv_32_to_size() - convert a 32-bit read value to the given size + * + * Some PCI buses must always perform 32-bit reads. The data must then be + * shifted and masked to reflect the required access size and offset. This + * function performs this transformation. + * + * @value: Value to transform (32-bit value read from @offset & ~3) + * @offset: Register offset that was read + * @size: Required size of the result + * @return the value that would have been obtained if the read had been + * performed at the given offset with the correct size + */ +ulong pci_conv_32_to_size(ulong value, uint offset, enum pci_size_t size); + +/** + * pci_conv_size_to_32() - update a 32-bit value to prepare for a write + * + * Some PCI buses must always perform 32-bit writes. To emulate a smaller + * write the old 32-bit data must be read, updated with the required new data + * and written back as a 32-bit value. This function performs the + * transformation from the old value to the new value. + * + * @value: Value to transform (32-bit value read from @offset & ~3) + * @offset: Register offset that should be written + * @size: Required size of the write + * @return the value that should be written as a 32-bit access to @offset & ~3. + */ +ulong pci_conv_size_to_32(ulong old, ulong value, uint offset, + enum pci_size_t size); + +/** * struct dm_pci_emul_ops - PCI device emulator operations */ struct dm_pci_emul_ops {
A PCI bus may be a bridge device where the controller is the bridge's parent. Add a function to return the controller device, given a PCI device.
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Stephen Warren swarren@nvidia.com ---
Changes in v2: - Use the device_is_on_pci_bus() API
drivers/pci/pci-uclass.c | 8 ++++++++ include/pci.h | 8 ++++++++ 2 files changed, 16 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index e38e0b2..f3f5f00 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -53,6 +53,14 @@ struct pci_controller *pci_bus_to_hose(int busnum) return dev_get_uclass_priv(bus); }
+struct udevice *pci_get_controller(struct udevice *dev) +{ + while (device_is_on_pci_bus(dev)) + dev = dev->parent; + + return dev; +} + pci_dev_t pci_get_bdf(struct udevice *dev) { struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); diff --git a/include/pci.h b/include/pci.h index ec2d104..f3dda70 100644 --- a/include/pci.h +++ b/include/pci.h @@ -1123,6 +1123,14 @@ ulong pci_conv_size_to_32(ulong old, ulong value, uint offset, enum pci_size_t size);
/** + * pci_get_controller() - obtain the controller to use for a bus + * + * @dev: Device to check + * @return pointer to the controller device for this bus + */ +struct udevice *pci_get_controller(struct udevice *dev); + +/** * struct dm_pci_emul_ops - PCI device emulator operations */ struct dm_pci_emul_ops {
This function looks up the controller and returns a pointer to each region type.
Changes in v2: None
drivers/pci/pci-uclass.c | 30 ++++++++++++++++++++++++++++++ include/pci.h | 12 ++++++++++++ 2 files changed, 42 insertions(+)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index f3f5f00..5fe3072 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -974,6 +974,36 @@ ulong pci_conv_size_to_32(ulong old, ulong value, uint offset, return value; }
+int pci_get_regions(struct udevice *dev, struct pci_region **iop, + struct pci_region **memp, struct pci_region **prefp) +{ + struct udevice *bus = pci_get_controller(dev); + struct pci_controller *hose = dev_get_uclass_priv(bus); + int i; + + *iop = NULL; + *memp = NULL; + *prefp = NULL; + for (i = 0; i < hose->region_count; i++) { + switch (hose->regions[i].flags) { + case PCI_REGION_IO: + if (!*iop || (*iop)->size < hose->regions[i].size) + *iop = hose->regions + i; + break; + case PCI_REGION_MEM: + if (!*memp || (*memp)->size < hose->regions[i].size) + *memp = hose->regions + i; + break; + case (PCI_REGION_MEM | PCI_REGION_PREFETCH): + if (!*prefp || (*prefp)->size < hose->regions[i].size) + *prefp = hose->regions + i; + break; + } + } + + return (*iop != NULL) + (*memp != NULL) + (*prefp != NULL); +} + UCLASS_DRIVER(pci) = { .id = UCLASS_PCI, .name = "pci", diff --git a/include/pci.h b/include/pci.h index f3dda70..9c19482 100644 --- a/include/pci.h +++ b/include/pci.h @@ -1131,6 +1131,18 @@ ulong pci_conv_size_to_32(ulong old, ulong value, uint offset, struct udevice *pci_get_controller(struct udevice *dev);
/** + * pci_get_regions() - obtain pointers to all the region types + * + * @dev: Device to check + * @iop: Returns a pointer to the I/O region, or NULL if none + * @memp: Returns a pointer to the memory region, or NULL if none + * @prefp: Returns a pointer to the pre-fetch region, or NULL if none + * @return the number of non-NULL regions returned, normally 3 + */ +int pci_get_regions(struct udevice *dev, struct pci_region **iop, + struct pci_region **memp, struct pci_region **prefp); + +/** * struct dm_pci_emul_ops - PCI device emulator operations */ struct dm_pci_emul_ops {
Adjust the Tegra PCI driver to support driver model and move all boards over at the same time. This can make use of some generic driver model code, such as the range-decoding logic.
Changes in v2: - Leave pci_skip_dev() at the bottom of the file to reduce the diff size
arch/arm/mach-tegra/Kconfig | 1 + drivers/pci/pci_tegra.c | 394 +++++++++++++++----------------------------- include/fdtdec.h | 3 - lib/fdtdec.c | 3 - 4 files changed, 138 insertions(+), 263 deletions(-)
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index de2454e..e5c135f 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -13,6 +13,7 @@ config TEGRA_ARMV7_COMMON select DM_SPI select DM_GPIO select DM_KEYBOARD + select DM_PCI
choice prompt "Tegra SoC select" diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index ebb959f..6bc91ec 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -10,10 +10,10 @@ * SPDX-License-Identifier: GPL-2.0 */
-#define DEBUG #define pr_fmt(fmt) "tegra-pcie: " fmt
#include <common.h> +#include <dm.h> #include <errno.h> #include <fdtdec.h> #include <malloc.h> @@ -174,7 +174,11 @@ DECLARE_GLOBAL_DATA_PTR; #define RP_LINK_CONTROL_STATUS_DL_LINK_ACTIVE 0x20000000 #define RP_LINK_CONTROL_STATUS_LINKSTAT_MASK 0x3fff0000
-struct tegra_pcie; +enum tegra_pci_id { + TEGRA20_PCIE, + TEGRA30_PCIE, + TEGRA124_PCIE, +};
struct tegra_pcie_port { struct tegra_pcie *pcie; @@ -203,10 +207,6 @@ struct tegra_pcie { struct fdt_resource afi; struct fdt_resource cs;
- struct fdt_resource prefetch; - struct fdt_resource mem; - struct fdt_resource io; - struct list_head ports; unsigned long xbar;
@@ -214,11 +214,6 @@ struct tegra_pcie { struct tegra_xusb_phy *phy; };
-static inline struct tegra_pcie *to_tegra_pcie(struct pci_controller *hose) -{ - return container_of(hose, struct tegra_pcie, hose); -} - static void afi_writel(struct tegra_pcie *pcie, unsigned long value, unsigned long offset) { @@ -280,46 +275,54 @@ static int tegra_pcie_conf_address(struct tegra_pcie *pcie, pci_dev_t bdf, return 0; }
- return -1; + return -EFAULT; }
-static int tegra_pcie_read_conf(struct pci_controller *hose, pci_dev_t bdf, - int where, u32 *value) +static int pci_tegra_read_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) { - struct tegra_pcie *pcie = to_tegra_pcie(hose); - unsigned long address; + struct tegra_pcie *pcie = dev_get_priv(bus); + unsigned long address, value; int err;
- err = tegra_pcie_conf_address(pcie, bdf, where, &address); + err = tegra_pcie_conf_address(pcie, bdf, offset, &address); if (err < 0) { - *value = 0xffffffff; - return 1; + value = 0xffffffff; + goto done; }
- *value = readl(address); + value = readl(address);
/* fixup root port class */ if (PCI_BUS(bdf) == 0) { - if (where == PCI_CLASS_REVISION) { - *value &= ~0x00ff0000; - *value |= PCI_CLASS_BRIDGE_PCI << 16; + if (offset == PCI_CLASS_REVISION) { + value &= ~0x00ff0000; + value |= PCI_CLASS_BRIDGE_PCI << 16; } }
+done: + *valuep = pci_conv_32_to_size(value, offset, size); + return 0; }
-static int tegra_pcie_write_conf(struct pci_controller *hose, pci_dev_t bdf, - int where, u32 value) +static int pci_tegra_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) { - struct tegra_pcie *pcie = to_tegra_pcie(hose); + struct tegra_pcie *pcie = dev_get_priv(bus); unsigned long address; + ulong old; int err;
- err = tegra_pcie_conf_address(pcie, bdf, where, &address); + err = tegra_pcie_conf_address(pcie, bdf, offset, &address); if (err < 0) - return 1; + return 0;
+ old = readl(address); + value = pci_conv_size_to_32(old, value, offset, size); writel(value, address);
return 0; @@ -344,12 +347,10 @@ static int tegra_pcie_port_parse_dt(const void *fdt, int node, }
static int tegra_pcie_get_xbar_config(const void *fdt, int node, u32 lanes, - unsigned long *xbar) + enum tegra_pci_id id, unsigned long *xbar) { - enum fdt_compat_id id = fdtdec_lookup(fdt, node); - switch (id) { - case COMPAT_NVIDIA_TEGRA20_PCIE: + case TEGRA20_PCIE: switch (lanes) { case 0x00000004: debug("single-mode configuration\n"); @@ -362,8 +363,7 @@ static int tegra_pcie_get_xbar_config(const void *fdt, int node, u32 lanes, return 0; } break; - - case COMPAT_NVIDIA_TEGRA30_PCIE: + case TEGRA30_PCIE: switch (lanes) { case 0x00000204: debug("4x1, 2x1 configuration\n"); @@ -381,8 +381,7 @@ static int tegra_pcie_get_xbar_config(const void *fdt, int node, u32 lanes, return 0; } break; - - case COMPAT_NVIDIA_TEGRA124_PCIE: + case TEGRA124_PCIE: switch (lanes) { case 0x0000104: debug("4x1, 1x1 configuration\n"); @@ -395,7 +394,6 @@ static int tegra_pcie_get_xbar_config(const void *fdt, int node, u32 lanes, return 0; } break; - default: break; } @@ -403,57 +401,6 @@ static int tegra_pcie_get_xbar_config(const void *fdt, int node, u32 lanes, return -FDT_ERR_NOTFOUND; }
-static int tegra_pcie_parse_dt_ranges(const void *fdt, int node, - struct tegra_pcie *pcie) -{ - const u32 *ptr, *end; - int len; - - ptr = fdt_getprop(fdt, node, "ranges", &len); - if (!ptr) { - error("missing "ranges" property"); - return -FDT_ERR_NOTFOUND; - } - - end = ptr + len / 4; - - while (ptr < end) { - struct fdt_resource *res = NULL; - u32 space = fdt32_to_cpu(*ptr); - - switch ((space >> 24) & 0x3) { - case 0x01: - res = &pcie->io; - break; - - case 0x02: /* 32 bit */ - case 0x03: /* 64 bit */ - if (space & (1 << 30)) - res = &pcie->prefetch; - else - res = &pcie->mem; - - break; - } - - if (res) { - res->start = fdt32_to_cpu(ptr[3]); - res->end = res->start + fdt32_to_cpu(ptr[5]); - } - - ptr += 3 + 1 + 2; - } - - debug("PCI regions:\n"); - debug(" I/O: %pa-%pa\n", &pcie->io.start, &pcie->io.end); - debug(" non-prefetchable memory: %pa-%pa\n", &pcie->mem.start, - &pcie->mem.end); - debug(" prefetchable memory: %pa-%pa\n", &pcie->prefetch.start, - &pcie->prefetch.end); - - return 0; -} - static int tegra_pcie_parse_port_info(const void *fdt, int node, unsigned int *index, unsigned int *lanes) @@ -480,7 +427,7 @@ static int tegra_pcie_parse_port_info(const void *fdt, int node, return 0; }
-static int tegra_pcie_parse_dt(const void *fdt, int node, +static int tegra_pcie_parse_dt(const void *fdt, int node, enum tegra_pci_id id, struct tegra_pcie *pcie) { int err, subnode; @@ -516,12 +463,6 @@ static int tegra_pcie_parse_dt(const void *fdt, int node, } }
- err = tegra_pcie_parse_dt_ranges(fdt, node, pcie); - if (err < 0) { - error("failed to parse "ranges" property"); - return err; - } - fdt_for_each_subnode(fdt, subnode, node) { unsigned int index = 0, num_lanes = 0; struct tegra_pcie_port *port; @@ -556,7 +497,7 @@ static int tegra_pcie_parse_dt(const void *fdt, int node, port->pcie = pcie; }
- err = tegra_pcie_get_xbar_config(fdt, node, lanes, &pcie->xbar); + err = tegra_pcie_get_xbar_config(fdt, node, lanes, id, &pcie->xbar); if (err < 0) { error("invalid lane configuration"); return err; @@ -758,9 +699,12 @@ static int tegra_pcie_enable_controller(struct tegra_pcie *pcie) return 0; }
-static void tegra_pcie_setup_translations(struct tegra_pcie *pcie) +static int tegra_pcie_setup_translations(struct udevice *bus) { + struct tegra_pcie *pcie = dev_get_priv(bus); unsigned long fpci, axi, size; + struct pci_region *io, *mem, *pref; + int count;
/* BAR 0: type 1 extended configuration space */ fpci = 0xfe100000; @@ -771,28 +715,32 @@ static void tegra_pcie_setup_translations(struct tegra_pcie *pcie) afi_writel(pcie, size >> 12, AFI_AXI_BAR0_SZ); afi_writel(pcie, fpci, AFI_FPCI_BAR0);
+ count = pci_get_regions(bus, &io, &mem, &pref); + if (count != 3) + return -EINVAL; + /* BAR 1: downstream I/O */ fpci = 0xfdfc0000; - size = fdt_resource_size(&pcie->io); - axi = pcie->io.start; + size = io->size; + axi = io->phys_start;
afi_writel(pcie, axi, AFI_AXI_BAR1_START); afi_writel(pcie, size >> 12, AFI_AXI_BAR1_SZ); afi_writel(pcie, fpci, AFI_FPCI_BAR1);
/* BAR 2: prefetchable memory */ - fpci = (((pcie->prefetch.start >> 12) & 0x0fffffff) << 4) | 0x1; - size = fdt_resource_size(&pcie->prefetch); - axi = pcie->prefetch.start; + fpci = (((pref->phys_start >> 12) & 0x0fffffff) << 4) | 0x1; + size = pref->size; + axi = pref->phys_start;
afi_writel(pcie, axi, AFI_AXI_BAR2_START); afi_writel(pcie, size >> 12, AFI_AXI_BAR2_SZ); afi_writel(pcie, fpci, AFI_FPCI_BAR2);
/* BAR 3: non-prefetchable memory */ - fpci = (((pcie->mem.start >> 12) & 0x0fffffff) << 4) | 0x1; - size = fdt_resource_size(&pcie->mem); - axi = pcie->mem.start; + fpci = (((mem->phys_start >> 12) & 0x0fffffff) << 4) | 0x1; + size = mem->size; + axi = mem->phys_start;
afi_writel(pcie, axi, AFI_AXI_BAR3_START); afi_writel(pcie, size >> 12, AFI_AXI_BAR3_SZ); @@ -818,6 +766,8 @@ static void tegra_pcie_setup_translations(struct tegra_pcie *pcie) afi_writel(pcie, 0, AFI_MSI_BAR_SZ); afi_writel(pcie, 0, AFI_MSI_AXI_BAR_ST); afi_writel(pcie, 0, AFI_MSI_BAR_SZ); + + return 0; }
static unsigned long tegra_pcie_port_get_pex_ctrl(struct tegra_pcie_port *port) @@ -964,175 +914,105 @@ static int tegra_pcie_enable(struct tegra_pcie *pcie) return 0; }
-static const struct tegra_pcie_soc tegra20_pcie_soc = { - .num_ports = 2, - .pads_pll_ctl = PADS_PLL_CTL_TEGRA20, - .tx_ref_sel = PADS_PLL_CTL_TXCLKREF_DIV10, - .has_pex_clkreq_en = false, - .has_pex_bias_ctrl = false, - .has_cml_clk = false, - .has_gen2 = false, -}; - -static const struct tegra_pcie_soc tegra30_pcie_soc = { - .num_ports = 3, - .pads_pll_ctl = PADS_PLL_CTL_TEGRA30, - .tx_ref_sel = PADS_PLL_CTL_TXCLKREF_BUF_EN, - .has_pex_clkreq_en = true, - .has_pex_bias_ctrl = true, - .has_cml_clk = true, - .has_gen2 = false, -}; - -static const struct tegra_pcie_soc tegra124_pcie_soc = { - .num_ports = 2, - .pads_pll_ctl = PADS_PLL_CTL_TEGRA30, - .tx_ref_sel = PADS_PLL_CTL_TXCLKREF_BUF_EN, - .has_pex_clkreq_en = true, - .has_pex_bias_ctrl = true, - .has_cml_clk = true, - .has_gen2 = true, +static const struct tegra_pcie_soc pci_tegra_soc[] = { + [TEGRA20_PCIE] = { + .num_ports = 2, + .pads_pll_ctl = PADS_PLL_CTL_TEGRA20, + .tx_ref_sel = PADS_PLL_CTL_TXCLKREF_DIV10, + .has_pex_clkreq_en = false, + .has_pex_bias_ctrl = false, + .has_cml_clk = false, + .has_gen2 = false, + }, + [TEGRA30_PCIE] = { + .num_ports = 3, + .pads_pll_ctl = PADS_PLL_CTL_TEGRA30, + .tx_ref_sel = PADS_PLL_CTL_TXCLKREF_BUF_EN, + .has_pex_clkreq_en = true, + .has_pex_bias_ctrl = true, + .has_cml_clk = true, + .has_gen2 = false, + }, + [TEGRA124_PCIE] = { + .num_ports = 2, + .pads_pll_ctl = PADS_PLL_CTL_TEGRA30, + .tx_ref_sel = PADS_PLL_CTL_TXCLKREF_BUF_EN, + .has_pex_clkreq_en = true, + .has_pex_bias_ctrl = true, + .has_cml_clk = true, + .has_gen2 = true, + } };
-static int process_nodes(const void *fdt, int nodes[], unsigned int count) +static int pci_tegra_ofdata_to_platdata(struct udevice *dev) { - unsigned int i; - - for (i = 0; i < count; i++) { - const struct tegra_pcie_soc *soc; - struct tegra_pcie *pcie; - enum fdt_compat_id id; - int err; - - if (!fdtdec_get_is_enabled(fdt, nodes[i])) - continue; - - id = fdtdec_lookup(fdt, nodes[i]); - switch (id) { - case COMPAT_NVIDIA_TEGRA20_PCIE: - soc = &tegra20_pcie_soc; - break; + struct tegra_pcie *pcie = dev_get_priv(dev); + enum tegra_pci_id id;
- case COMPAT_NVIDIA_TEGRA30_PCIE: - soc = &tegra30_pcie_soc; - break; + id = dev_get_driver_data(dev); + pcie->soc = &pci_tegra_soc[id];
- case COMPAT_NVIDIA_TEGRA124_PCIE: - soc = &tegra124_pcie_soc; - break; + INIT_LIST_HEAD(&pcie->ports);
- default: - error("unsupported compatible: %s", - fdtdec_get_compatible(id)); - continue; - } - - pcie = malloc(sizeof(*pcie)); - if (!pcie) { - error("failed to allocate controller"); - continue; - } - - memset(pcie, 0, sizeof(*pcie)); - pcie->soc = soc; - - INIT_LIST_HEAD(&pcie->ports); - - err = tegra_pcie_parse_dt(fdt, nodes[i], pcie); - if (err < 0) { - free(pcie); - continue; - } - - err = tegra_pcie_power_on(pcie); - if (err < 0) { - error("failed to power on"); - continue; - } - - err = tegra_pcie_enable_controller(pcie); - if (err < 0) { - error("failed to enable controller"); - continue; - } - - tegra_pcie_setup_translations(pcie); - - err = tegra_pcie_enable(pcie); - if (err < 0) { - error("failed to enable PCIe"); - continue; - } - - pcie->hose.first_busno = 0; - pcie->hose.current_busno = 0; - pcie->hose.last_busno = 0; + if (tegra_pcie_parse_dt(gd->fdt_blob, dev->of_offset, id, pcie)) + return -EINVAL;
- pci_set_region(&pcie->hose.regions[0], NV_PA_SDRAM_BASE, - NV_PA_SDRAM_BASE, gd->ram_size, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - pci_set_region(&pcie->hose.regions[1], pcie->io.start, - pcie->io.start, fdt_resource_size(&pcie->io), - PCI_REGION_IO); - - pci_set_region(&pcie->hose.regions[2], pcie->mem.start, - pcie->mem.start, fdt_resource_size(&pcie->mem), - PCI_REGION_MEM); - - pci_set_region(&pcie->hose.regions[3], pcie->prefetch.start, - pcie->prefetch.start, - fdt_resource_size(&pcie->prefetch), - PCI_REGION_MEM | PCI_REGION_PREFETCH); + return 0; +}
- pcie->hose.region_count = 4; +static int pci_tegra_probe(struct udevice *dev) +{ + struct tegra_pcie *pcie = dev_get_priv(dev); + int err;
- pci_set_ops(&pcie->hose, - pci_hose_read_config_byte_via_dword, - pci_hose_read_config_word_via_dword, - tegra_pcie_read_conf, - pci_hose_write_config_byte_via_dword, - pci_hose_write_config_word_via_dword, - tegra_pcie_write_conf); + err = tegra_pcie_power_on(pcie); + if (err < 0) { + error("failed to power on"); + return err; + }
- pci_register_hose(&pcie->hose); + err = tegra_pcie_enable_controller(pcie); + if (err < 0) { + error("failed to enable controller"); + return err; + }
-#ifdef CONFIG_PCI_SCAN_SHOW - printf("PCI: Enumerating devices...\n"); - printf("---------------------------------------\n"); - printf(" Device ID Description\n"); - printf(" ------ -- -----------\n"); -#endif + err = tegra_pcie_setup_translations(dev); + if (err < 0) { + error("failed to decode ranges"); + return err; + }
- pcie->hose.last_busno = pci_hose_scan(&pcie->hose); + err = tegra_pcie_enable(pcie); + if (err < 0) { + error("failed to enable PCIe"); + return err; }
return 0; }
-void pci_init_board(void) -{ - const void *fdt = gd->fdt_blob; - int count, nodes[1]; - - count = fdtdec_find_aliases_for_id(fdt, "pcie-controller", - COMPAT_NVIDIA_TEGRA124_PCIE, - nodes, ARRAY_SIZE(nodes)); - if (process_nodes(fdt, nodes, count)) - return; - - count = fdtdec_find_aliases_for_id(fdt, "pcie-controller", - COMPAT_NVIDIA_TEGRA30_PCIE, - nodes, ARRAY_SIZE(nodes)); - if (process_nodes(fdt, nodes, count)) - return; - - count = fdtdec_find_aliases_for_id(fdt, "pcie-controller", - COMPAT_NVIDIA_TEGRA20_PCIE, - nodes, ARRAY_SIZE(nodes)); - if (process_nodes(fdt, nodes, count)) - return; -} +static const struct dm_pci_ops pci_tegra_ops = { + .read_config = pci_tegra_read_config, + .write_config = pci_tegra_write_config, +}; + +static const struct udevice_id pci_tegra_ids[] = { + { .compatible = "nvidia,tegra20-pcie", .data = TEGRA20_PCIE }, + { .compatible = "nvidia,tegra30-pcie", .data = TEGRA30_PCIE }, + { .compatible = "nvidia,tegra124-pcie", .data = TEGRA124_PCIE }, + { } +}; + +U_BOOT_DRIVER(pci_tegra) = { + .name = "pci_tegra", + .id = UCLASS_PCI, + .of_match = pci_tegra_ids, + .ops = &pci_tegra_ops, + .ofdata_to_platdata = pci_tegra_ofdata_to_platdata, + .probe = pci_tegra_probe, + .priv_auto_alloc_size = sizeof(struct tegra_pcie), +};
int pci_skip_dev(struct pci_controller *hose, pci_dev_t dev) { diff --git a/include/fdtdec.h b/include/fdtdec.h index a6a1ffc..7fe657d 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -128,9 +128,6 @@ enum fdt_compat_id { COMPAT_NVIDIA_TEGRA124_SDMMC, /* Tegra124 SDMMC controller */ COMPAT_NVIDIA_TEGRA30_SDMMC, /* Tegra30 SDMMC controller */ COMPAT_NVIDIA_TEGRA20_SDMMC, /* Tegra20 SDMMC controller */ - COMPAT_NVIDIA_TEGRA124_PCIE, /* Tegra 124 PCIe controller */ - COMPAT_NVIDIA_TEGRA30_PCIE, /* Tegra 30 PCIe controller */ - COMPAT_NVIDIA_TEGRA20_PCIE, /* Tegra 20 PCIe controller */ COMPAT_NVIDIA_TEGRA124_XUSB_PADCTL, /* Tegra124 XUSB pad controller */ COMPAT_NVIDIA_TEGRA210_XUSB_PADCTL, diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 6f08edf..82d0090 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -34,9 +34,6 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(NVIDIA_TEGRA124_SDMMC, "nvidia,tegra124-sdhci"), COMPAT(NVIDIA_TEGRA30_SDMMC, "nvidia,tegra30-sdhci"), COMPAT(NVIDIA_TEGRA20_SDMMC, "nvidia,tegra20-sdhci"), - COMPAT(NVIDIA_TEGRA124_PCIE, "nvidia,tegra124-pcie"), - COMPAT(NVIDIA_TEGRA30_PCIE, "nvidia,tegra30-pcie"), - COMPAT(NVIDIA_TEGRA20_PCIE, "nvidia,tegra20-pcie"), COMPAT(NVIDIA_TEGRA124_XUSB_PADCTL, "nvidia,tegra124-xusb-padctl"), COMPAT(NVIDIA_TEGRA210_XUSB_PADCTL, "nvidia,tegra210-xusb-padctl"), COMPAT(SMSC_LAN9215, "smsc,lan9215"),
Simon,
-----Original Message----- From: Simon Glass [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Thursday, November 12, 2015 9:07 AM To: U-Boot Mailing List u-boot@lists.denx.de Cc: Tom Warren TWarren@nvidia.com; Stephen Warren swarren@wwwdotorg.org; Stephen Warren swarren@nvidia.com; Simon Glass sjg@chromium.org; Marek Vasut marek.vasut@gmail.com; Pavel Herrmann morpheus.ibis@gmail.com Subject: [PATCH v2 8/8] dm: tegra: pci: Convert tegra boards to driver model for PCI
This one doesn't apply to current u-boot-tegra/master (with Stephen's recent PCI patches). IIRC, I was going to take Stephen's PCI patches in to Tegra and you'd adjust yours to work with that. PTAL as I'm getting ready to send a PR to TomR today for u-boot-tegra/master.
Thanks,
Tom -- nvpublic
Changes in v2:
- select DM_PCI
- SPDX-License-Identifier: GPL-2.0
- TEGRA20_PCIE,
- TEGRA30_PCIE,
- TEGRA124_PCIE,
- return -1;
- return -EFAULT;
- struct tegra_pcie *pcie = dev_get_priv(bus);
- unsigned long address, value; int err;
- err = tegra_pcie_conf_address(pcie, bdf, offset, &address); if (err < 0) {
return 1;
value = 0xffffffff;
}goto done;
} }value |= PCI_CLASS_BRIDGE_PCI << 16;
+done:
- *valuep = pci_conv_32_to_size(value, offset, size);
- struct tegra_pcie *pcie = dev_get_priv(bus); unsigned long address;
- ulong old; int err;
return 1;
- switch (id) {
- case TEGRA20_PCIE: switch (lanes) { case 0x00000004: debug("single-mode configuration\n"); @@ -362,8
- case TEGRA30_PCIE: switch (lanes) { case 0x00000204: debug("4x1, 2x1 configuration\n");
- case TEGRA124_PCIE: switch (lanes) { case 0x0000104: debug("4x1, 1x1 configuration\n");
- default: break; }
- int len;
- if (!ptr) {
error("missing \"ranges\" property");
case 0x01:
res = &pcie->io;
break;
else
res = &pcie->mem;
break;
if (res) {
ptr += 3 + 1 + 2;
&pcie->mem.end);
-static int tegra_pcie_parse_dt(const void *fdt, int node, +static int tegra_pcie_parse_dt(const void *fdt, int node, enum +tegra_pci_id id, struct tegra_pcie *pcie) { int err, subnode; @@ -516,12 +463,6 @@ static int tegra_pcie_parse_dt(const void *fdt, int node, } }
- if (err < 0) {
error("failed to parse \"ranges\" property");
return err;
- err = tegra_pcie_get_xbar_config(fdt, node, lanes, id, &pcie->xbar); if (err < 0) { error("invalid lane configuration"); return err;
int count;
- count = pci_get_regions(bus, &io, &mem, &pref);
- if (count != 3)
return -EINVAL;
- /* BAR 1: downstream I/O */ fpci = 0xfdfc0000;
size = io->size;
size = pref->size;
size = mem->size;
- .num_ports = 2,
- .num_ports = 3,
- .num_ports = 2,
- .has_gen2 = true,
- [TEGRA20_PCIE] = {
.num_ports = 2,
.has_gen2 = false,
- [TEGRA30_PCIE] = {
.num_ports = 3,
.has_gen2 = false,
- [TEGRA124_PCIE] = {
.num_ports = 2,
.has_gen2 = true,
- unsigned int i;
int err;
continue;
switch (id) {
break;
- struct tegra_pcie *pcie = dev_get_priv(dev);
- enum tegra_pci_id id;
break;
- id = dev_get_driver_data(dev);
- pcie->soc = &pci_tegra_soc[id];
break;
default:
continue;
if (!pcie) {
continue;
pcie->soc = soc;
if (err < 0) {
free(pcie);
continue;
if (err < 0) {
continue;
if (err < 0) {
continue;
if (err < 0) {
continue;
- if (tegra_pcie_parse_dt(gd->fdt_blob, dev->of_offset, id, pcie))
return -EINVAL;
PCI_REGION_IO);
PCI_REGION_MEM);
+static int pci_tegra_probe(struct udevice *dev) {
- int err;
- if (err < 0) {
return err;
- if (err < 0) {
return err;
-#endif
- err = tegra_pcie_setup_translations(dev);
- if (err < 0) {
return err;
if (err < 0) {
return err;
return;
return;
return;
- .read_config = pci_tegra_read_config,
- .write_config = pci_tegra_write_config,
- { .compatible = "nvidia,tegra20-pcie", .data = TEGRA20_PCIE },
- { .compatible = "nvidia,tegra30-pcie", .data = TEGRA30_PCIE },
- { .compatible = "nvidia,tegra124-pcie", .data = TEGRA124_PCIE },
- .name = "pci_tegra",
- .id = UCLASS_PCI,
- .of_match = pci_tegra_ids,
- .ops = &pci_tegra_ops,
- .ofdata_to_platdata = pci_tegra_ofdata_to_platdata,
- .probe = pci_tegra_probe,
- .priv_auto_alloc_size = sizeof(struct tegra_pcie), };
padctl"), COMPAT(NVIDIA_TEGRA210_XUSB_PADCTL, "nvidia,tegra210-xusb- padctl"), COMPAT(SMSC_LAN9215, "smsc,lan9215"), -- 2.6.0.rc2.230.g3dd15c0
On 11/12/2015 09:16 AM, Tom Warren wrote:
Simon,
I think you can go ahead with the PR and apply this series later and send another PR right?
Stephen,
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Thursday, November 12, 2015 9:42 AM To: Tom Warren TWarren@nvidia.com Cc: Simon Glass sjg@chromium.org; U-Boot Mailing List <u- boot@lists.denx.de>; Stephen Warren swarren@nvidia.com; Marek Vasut marek.vasut@gmail.com; Pavel Herrmann morpheus.ibis@gmail.com Subject: Re: [PATCH v2 8/8] dm: tegra: pci: Convert tegra boards to driver model for PCI
Simon,
Simon
tegra/master.
I'm not worried about my PR so much as Simon having not used the latest tegra/master (which just went up yesterday, to be fair) to base his changes on. ----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
On 12 November 2015 at 09:58, Tom Warren TWarren@nvidia.com wrote:
Stephen,
Simon,
Simon
tegra/master.
I've sent v3 - need to wait for Stephen to review/test.
It's taken a long time to get these Tegra changes up - were they waiting on an ARM patch? I have another PCI series which I may just send now, and worry about the conflicts later.
Hi Tom,
On 12 November 2015 at 09:16, Tom Warren TWarren@nvidia.com wrote:
Simon,
I've rebased and pushed it to u-boot-dm/tegra-working. Please note that this is not suitable for pulling as it has patman tags. But Stephen might want to test it.
I'll send a new series a bit later.
Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Thursday, November 12, 2015 9:52 AM To: Tom Warren TWarren@nvidia.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Stephen Warren swarren@wwwdotorg.org; Stephen Warren swarren@nvidia.com; Marek Vasut marek.vasut@gmail.com; Pavel Herrmann morpheus.ibis@gmail.com Subject: Re: [PATCH v2 8/8] dm: tegra: pci: Convert tegra boards to driver model for PCI
Hi Tom,
Simon,
Simon
tegra/master.
No worries - just wanted you to be aware of the new code in tegra/master. Thanks.
Tom -- nvpublic
Stephen Warren
Tom Warren
