[U-Boot] [PATCH] armv8/ls1043a: Add MTD partition scheme
Add and share the the MTD partition scheme with kernel by defualt bootargs. And add the "mtdparts" env.
Signed-off-by: Wenbin Song wenbin.song@nxp.com --- include/configs/ls1043a_common.h | 22 ++++++++++++++++++++-- 1 file changed, 20 insertions(+), 2 deletions(-)
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index fd243b1..6964873 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -236,6 +236,21 @@ #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
+#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define MTDPARTS_DEFAULT "mtdparts=spi0.0:1m(uboot)," \ + "5m(kernel),1m(dtb),9m(file_system)" +#else +#define MTDPARTS_DEFAULT "mtdparts=60000000.nor:1m(nor_bank0_rcw)," \ + "1m(nor_bank0_uboot),1m(nor_bank0_uboot_env)," \ + "1m(nor_bank0_fman_uconde),40m(nor_bank0_fit)," \ + "1m(nor_bank4_rcw),1m(nor_bank4_uboot)," \ + "1m(nor_bank4_uboot_env),1m(nor_bank4_fman_ucode)," \ + "40m(nor_bank4_fit);7e800000.flash:" \ + "1m(nand_uboot),1m(nand_uboot_env)," \ + "20m(nand_fit);spi0.0:1m(uboot)," \ + "5m(kernel),1m(dtb),9m(file_system)" +#endif + /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ @@ -248,10 +263,13 @@ "kernel_start=0x61100000\0" \ "kernel_load=0xa0000000\0" \ "kernel_size=0x2800000\0" \ - "console=ttyAMA0,38400n8\0" + "console=ttyAMA0,38400n8\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0"
#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ - "earlycon=uart8250,mmio,0x21c0500" + "earlycon=uart8250,mmio,0x21c0500 " \ + MTDPARTS_DEFAULT + #define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ "$kernel_size && bootm $kernel_load" #define CONFIG_BOOTDELAY 10
- "console=ttyAMA0,38400n8\0" \
- "mtdparts=" MTDPARTS_DEFAULT "\0"
MTDPARTS_DEFAULT
You could use $mtdparts here so your bootcmd doesn't get too long.
York
MTDPARTS_DEFAULT
Wenbin,
A related question regarding MTD, how do you make NOR MTD device working on these boards (ls1043aqds and ls1043ardb)? This is a common file for both RDB and QDS. I presume you have verified on both. I have nand working on both, spi-nor working on rdb only. I don't have NOR working on either of them. It may be not a U-Boot issue though.
York
Hi: York
1, There is an issue for sdk2.0 kernel that the nor-flash can't be probed . we can fix it as follow:
$make menuconfig
x -> Device Drivers x -> Memory Technology Device (MTD) support x -> RAM/ROM/Flash chip drivers x -> Flash chip driver advanced configuration options x -> Flash cmd/query data swapping x x ( ) NO x x (X) BIG_ENDIAN_BYTE x x ( ) LITTLE_ENDIAN_BYTE
Enable BIG_ENDIAN_BYTE .
2, The spi-nor flash can working on ls1043aqds , and I use the sdk2.0 kernel (ce5a3841f3). [ 1.598954] m25p80 spi0.0: n25q128a11 (16384 Kbytes) [ 1.603923] 4 cmdlinepart partitions found on MTD device spi0.0 [ 1.609842] Creating 4 MTD partitions on "spi0.0": [ 1.614624] 0x000000000000-0x000000100000 : "uboot" [ 1.624205] ftl_cs: FTL header not found. [ 1.628421] 0x000000100000-0x000000600000 : "kernel" [ 1.638086] ftl_cs: FTL header not found. [ 1.642316] 0x000000600000-0x000000700000 : "dtb" [ 1.651702] ftl_cs: FTL header not found. [ 1.655932] 0x000000700000-0x000001000000 : "file_system" [ 1.666028] ftl_cs: FTL header not found.
Best Regards Wenbin Song
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Wednesday, April 06, 2016 5:02 AM To: Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com; u-boot@lists.denx.de Cc: Qianyu Gong qianyu.gong@nxp.com; Shaohui Xie shaohui.xie@nxp.com; Zhiqiang Hou zhiqiang.hou@nxp.com Subject: Re: [PATCH] armv8/ls1043a: Add MTD partition scheme
bootargs.
root=/dev/ram0 " \
MTDPARTS_DEFAULT
Wenbin,
York
Hi: York
Do you mean that I should use $mtdpart to instead of "MTDPARTS_DEFAULT" ?
As follows: #define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ "earlycon=uart8250,mmio,0x21c0500 " \ "$mtdparts"
If so, the variable $mtdparts can't be extend ,like that:
root@ls1043aqds:~# cat /proc/cmdline console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ${mtdparts}
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Wednesday, April 06, 2016 4:33 AM To: Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com; u-boot@lists.denx.de Cc: Qianyu Gong qianyu.gong@nxp.com; Shaohui Xie shaohui.xie@nxp.com; Zhiqiang Hou zhiqiang.hou@nxp.com Subject: Re: [PATCH] armv8/ls1043a: Add MTD partition scheme
#define
+MTDPARTS_DEFAULT "mtdparts=spi0.0:1m(uboot)," \
root=/dev/ram0 " \
MTDPARTS_DEFAULT
York
On 04/05/2016 09:20 PM, Wenbin Song wrote:
Hi: York
What do you see "print bootargs" under U-Boot? I thought the variable can be extended when U-Boot runs the command. Like we used to have $consoledev, $othbootargs, etc.
York
Hi: York
I set bootargs as the following steps:
=> env default mtdparts => printenv mtdparts mtdparts=mtdparts=60000000.nor:1m(nor_bank0_rcw),1m(nor_bank0_uboot),1m(nor_bank0_uboot_env),1m(nor_bank0_fman_uconde),40m(nor_bank0_fit),1m(nor_bank4_rcw),1m(nor_bank4_uboot),1m(nor_bank4_uboot_env),1m(nor_bank4_fman_ucode),40m(nor_bank4_fit);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system) => env default bootargs => printenv bootargs bootargs=console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ${mtdparts}
The macro CONFIG_BOOTARGS only be extern as an char-string, and it will be spliced into default_environment array .
const uchar default_environment[] = { #ifdef CONFIG_BOOTARGS "bootargs=" CONFIG_BOOTARGS "\0" #endif
The variable we use to have $consoledev, $othbootargs was used in the following cases:
858 #define CONFIG_BOOTCOMMAND \ 859 "setenv bootargs root=/dev/ram rw " \ 860 "console=$consoledev,$baudrate $othbootargs;" \ 861 "setenv ramdiskaddr 0x02000000;" \ 862 "setenv fdtaddr 0x00c00000;" \ 863 "setenv loadaddr 0x1000000;" \ 864 "bootm $loadaddr $ramdiskaddr $fdtaddr"
Because the "setenv" will be executed , So the variable could be extended.
What do you suggest?
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Wednesday, April 06, 2016 12:39 PM To: Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com; u-boot@lists.denx.de Cc: Qianyu Gong qianyu.gong@nxp.com; Shaohui Xie shaohui.xie@nxp.com; Zhiqiang Hou zhiqiang.hou@nxp.com Subject: Re: [PATCH] armv8/ls1043a: Add MTD partition scheme
Hi: York
root=/dev/ram0 " \
York
On 04/06/2016 12:11 AM, Wenbin Song wrote:
Hi: York
I see what you mean. I am trying to reduce the environmental variables. Do you need the variable "mtdparts"? Would it be a better idea to set bootargs using the bootcmd?
While you are on it, I suggest you take a look at other variables. "console=ttyAMA0,38400n8" is wrong here.
We don't have to copy kernel image from NOR flash to DDR if the ramdisk load address is set properly in its file. So you can remove the copying from bootcmd.
York
Hi: York
Please see my inline comments.
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Thursday, April 07, 2016 1:18 AM To: Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com; u-boot@lists.denx.de Cc: Qianyu Gong qianyu.gong@nxp.com; Shaohui Xie shaohui.xie@nxp.com; Zhiqiang Hou zhiqiang.hou@nxp.com Subject: Re: [PATCH] armv8/ls1043a: Add MTD partition scheme
Hi: York
mtdparts=mtdparts=60000000.nor:1m(nor_bank0_rcw),1m(nor_bank0_uboot) ,1
m(nor_bank0_uboot_env),1m(nor_bank0_fman_uconde),40m(nor_bank0_fit ),1m
(nor_bank4_rcw),1m(nor_bank4_uboot),1m(nor_bank4_uboot_env),1m(nor_ ban
k4_fman_ucode),40m(nor_bank4_fit);7e800000.flash:1m(nand_uboot),1m(na n
d_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file _system) => env default bootargs => printenv bootargs bootargs=console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ${mtdparts}
following cases:
[wenbin]
I export this variable in order to make easier to modify the bootargs under uboot command-line.
For example: =>setenv bootargs "console=ttyS0,115200 root=/dev/ram0 $mtdparts" =>setenv bootargs "console=ttyLP0,115200 root=/dev/ram0 $mtdparts"
Use the $mtdparts to instead of a long string.
[wenbin]
yes, It is a good idea. But we need all kinds of ways to boot kernel with this "bootargs". The bootcmd only can specify one boot-way. IOW, only the way specified by this "bootcmd" can execute " setenv bootargs". So I want to supply the default bootargs by the CONFIG_BOOTARGS .
[wenbin]
Ok, thanks for your advices, I will modify them on the later patch.
York
On 04/06/2016 10:46 PM, Wenbin Song wrote:
Hi: York
Hi: York
following cases:
[wenbin]
[wenbin]
[wenbin]
Wenbin,
Do you have an update?
York
Hi: York
I'm sorry to have misunderstood you mean. I think it is a good idea that modify/remove the wrong/useless variables in a new patch. And I will make it later. Do you have any suggestion?
-----Original Message----- From: york sun Sent: Wednesday, July 20, 2016 6:02 AM To: Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com; u-boot@lists.denx.de Cc: Qianyu Gong qianyu.gong@nxp.com; Shaohui Xie shaohui.xie@nxp.com; Zhiqiang Hou zhiqiang.hou@nxp.com Subject: Re: [PATCH] armv8/ls1043a: Add MTD partition scheme
Hi: York
Hi: York
d_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(fi le _system) => env default bootargs => printenv bootargs bootargs=console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ${mtdparts}
following cases:
[wenbin]
uboot command-line.
[wenbin]
from bootcmd.
[wenbin]
Wenbin,
York
On 07/19/2016 08:02 PM, Wenbin Song wrote:
Hi: York
Yes, please make a cleanup patch first, then your change of MTD partition.
York
Wenbin Song
York Sun
york sun
