[PATCH 1/1] lib: rsa: fix data abort in br_i32_decode()
After removing leading zeros the RSA modulus may be unaligned. On architectures like ARM 32bit unaligned access may lead to a data abort, e.g. when executing 'ut lib lib_asn1_pkcs7'.
Use memcpy() to transfer from unaligned to aligned memory.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/rsa/rsa-keyprop.c | 22 ++++++++++++++-------- 1 file changed, 14 insertions(+), 8 deletions(-)
diff --git a/lib/rsa/rsa-keyprop.c b/lib/rsa/rsa-keyprop.c index 1e83eedc82..6153cb00b3 100644 --- a/lib/rsa/rsa-keyprop.c +++ b/lib/rsa/rsa-keyprop.c @@ -17,23 +17,29 @@ #include <u-boot/rsa-mod-exp.h>
/** - * br_dec16be() - Convert 16-bit big-endian integer to native - * @src: Pointer to data - * Return: Native-endian integer + * br_dec16be() - convert unaligned 16-bit big-endian integer to native + * @src: unaligned pointer to data + * Return: native-endian 16-bit integer */ static unsigned br_dec16be(const void *src) { - return be16_to_cpup(src); + u16 buf; + + memcpy(&buf, src, sizeof(buf)); + return be16_to_cpu(buf); }
/** - * br_dec32be() - Convert 32-bit big-endian integer to native - * @src: Pointer to data - * Return: Native-endian integer + * br_dec32be() - convert unaligned 32-bit big-endian integer to native + * @src: unaligned pointer to data + * Return: native-endian 32-bit integer */ static uint32_t br_dec32be(const void *src) { - return be32_to_cpup(src); + u32 buf; + + memcpy(&buf, src, sizeof(buf)); + return be32_to_cpu(buf); }
/** -- 2.20.1
HI Heinrich,
- br_dec16be() - Convert 16-bit big-endian integer to native
- @src: Pointer to data
- Return: Native-endian integer
- br_dec16be() - convert unaligned 16-bit big-endian integer to native
- @src: unaligned pointer to data
- Return: native-endian 16-bit integer
u16 buf;
Is it possible to use __get_unaligned_be() ?
On Tue, Sep 08, 2020 at 05:56:06PM -0600, Simon Glass wrote:
HI Heinrich,
u16 buf;
Robert has sent the fix here: https://lists.denx.de/pipermail/u-boot/2020-September/425949.html
I think it's better.
-Takahiro Akashi
AKASHI Takahiro
