[U-Boot] [PATCH 0/2] api: export LCD and video to external apps
This patch set exports LCD and video clearing and bitmap-rendering on screen functions to external apps, and provides a unified interface of accessing them.
Che-Liang Chiou (2): lcd: video: add clear and draw bitmap declaration api: export LCD and video to external apps
api/Makefile | 3 +- api/api.c | 51 ++++++++++++++++++++++++++++++ api/api_display.c | 85 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 ++ common/lcd.c | 15 +++++--- examples/api/demo.c | 28 ++++++++++++++++ examples/api/glue.c | 31 ++++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 +++++++++ include/lcd.h | 2 + include/video.h | 2 + include/video_font.h | 6 +++ 12 files changed, 241 insertions(+), 7 deletions(-) create mode 100644 api/api_display.c
The functions for clearing and drawing bitmaps on the screen were not exposed publicly and are made public in this patch in preparation for implementing the display interface of api_public.h.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org --- common/lcd.c | 15 +++++++++------ include/lcd.h | 2 ++ include/video.h | 2 ++ 3 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index d9cb8ca..d6e3188 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -78,7 +78,6 @@ static inline void lcd_putc_xy (ushort x, ushort y, uchar c);
static int lcd_init (void *lcdbase);
-static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]); static void *lcd_logo (void);
static int lcd_getbgcolor (void); @@ -353,7 +352,13 @@ int drv_lcd_init (void) }
/*----------------------------------------------------------------------*/ -static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) +static int do_lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) +{ + lcd_clear(); + return 0; +} + +void lcd_clear (void) { #if LCD_BPP == LCD_MONOCHROME /* Setting the palette */ @@ -394,12 +399,10 @@ static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]
console_col = 0; console_row = 0; - - return (0); }
U_BOOT_CMD( - cls, 1, 1, lcd_clear, + cls, 1, 1, do_lcd_clear, "clear screen", "" ); @@ -413,7 +416,7 @@ static int lcd_init (void *lcdbase)
lcd_ctrl_init (lcdbase); lcd_is_enabled = 1; - lcd_clear (NULL, 1, 1, NULL); /* dummy args */ + lcd_clear (); lcd_enable ();
/* Initialize the console */ diff --git a/include/lcd.h b/include/lcd.h index 0e098d9..fba4ec2 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -210,6 +210,8 @@ void lcd_disable (void); void lcd_putc (const char c); void lcd_puts (const char *s); void lcd_printf (const char *fmt, ...); +void lcd_clear (void); +int lcd_display_bitmap(ulong bmp_image, int x, int y);
/* Allow boards to customize the information displayed */ void lcd_show_board_info(void); diff --git a/include/video.h b/include/video.h index efcc682..6cd6f72 100644 --- a/include/video.h +++ b/include/video.h @@ -15,5 +15,7 @@ int video_init (void *videobase); void video_putc (const char c); void video_puts (const char *s); void video_printf (const char *fmt, ...); +void video_clear (void); +int video_display_bitmap(ulong bmp_image, int x, int y);
#endif
Dear Che-Liang Chiou,
In message 11c2761c2883cf217a6efae98dccb83d19606927.1317715598.git.clchiou@chromium.org you wrote:
Please run through checkpatch and fix the errors and warnings.
This patch exports LCD and video information and bitmap-rendering functions to external apps.
This patch is tested on a Seaboard, which does not have a video output. So I only tested LCD code paths.
NOTE: The Seaboard LCD driver is not yet upstreamed; the test was done in a local downstream repo.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org --- api/Makefile | 3 +- api/api.c | 51 ++++++++++++++++++++++++++++++ api/api_display.c | 85 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 ++ examples/api/demo.c | 28 ++++++++++++++++ examples/api/glue.c | 31 ++++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 +++++++++ include/video_font.h | 6 +++ 9 files changed, 228 insertions(+), 1 deletions(-) create mode 100644 api/api_display.c
diff --git a/api/Makefile b/api/Makefile index 2a64c4d..0e99f74 100644 --- a/api/Makefile +++ b/api/Makefile @@ -24,7 +24,8 @@ include $(TOPDIR)/config.mk
LIB = $(obj)libapi.o
-COBJS-$(CONFIG_API) += api.o api_net.o api_storage.o api_platform-$(ARCH).o +COBJS-$(CONFIG_API) += api.o api_display.o api_net.o api_storage.o \ + api_platform-$(ARCH).o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/api/api.c b/api/api.c index 853f010..ddf2edd 100644 --- a/api/api.c +++ b/api/api.c @@ -553,6 +553,54 @@ static int API_env_enum(va_list ap) return 0; }
+/* + * pseudo signature: + * + * int API_display_get_info(int type, struct display_info *di) + */ +static int API_display_get_info(va_list ap) +{ + int type; + struct display_info *di; + + type = (int)va_arg(ap, u_int32_t); + di = (struct display_info *)va_arg(ap, u_int32_t); + if (!di) + return API_EINVAL; + + return display_get_info(type, di); +} + +/* + * pseudo signature: + * + * int API_display_draw_bitmap(void *bitmap, int x, int y) + */ +static int API_display_draw_bitmap(va_list ap) +{ + ulong bitmap; + int x, y; + + bitmap = (ulong)va_arg(ap, ulong); + if (!bitmap) + return API_EINVAL; + x = (int)va_arg(ap, u_int32_t); + y = (int)va_arg(ap, u_int32_t); + + return display_draw_bitmap(bitmap, x, y); +} + +/* + * pseudo signature: + * + * void API_display_clear(void) + */ +static int API_display_clear(va_list ap) +{ + display_clear(); + return 0; +} + static cfp_t calls_table[API_MAXCALL] = { NULL, };
/* @@ -616,6 +664,9 @@ void api_init(void) calls_table[API_ENV_GET] = &API_env_get; calls_table[API_ENV_SET] = &API_env_set; calls_table[API_ENV_ENUM] = &API_env_enum; + calls_table[API_DISPLAY_GET_INFO] = &API_display_get_info; + calls_table[API_DISPLAY_DRAW_BITMAP] = &API_display_draw_bitmap; + calls_table[API_DISPLAY_CLEAR] = &API_display_clear; calls_no = API_MAXCALL;
debugf("API initialized with %d calls\n", calls_no); diff --git a/api/api_display.c b/api/api_display.c new file mode 100644 index 0000000..6255848 --- /dev/null +++ b/api/api_display.c @@ -0,0 +1,85 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <lcd.h> +#include <video.h> +#include <video_font.h> /* Get font width and height */ +#include <api_public.h> + +int display_get_info(int type, struct display_info *di) +{ + switch (type) { + default: + debug("%s: unsupport display device type: %d\n", __FILE__, type); + return API_ENODEV; + +#ifdef CONFIG_LCD + case DISPLAY_TYPE_LCD: + di->pixel_width = panel_info.vl_col; + di->pixel_height = panel_info.vl_row; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + case DISPLAY_TYPE_VIDEO: + di->pixel_width = VIDEO_VISIBLE_COLS; + di->pixel_height = VIDEO_VISIBLE_ROWS; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + } + + di->type = type; + return 0; +} + +int display_draw_bitmap(ulong bitmap, int x, int y) +{ + int err = 0; + + /* + * Although CONFIG_LCD and CONFIG_VIDEO or CONFIG_CFB_CONSOLE + * generally should not be both set, if this does happen, I think + * drawing on both of them makes more sense. + */ +#ifdef CONFIG_LCD + err |= lcd_display_bitmap(bitmap, x, y); +#endif +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + err |= video_display_bitmap(bitmap, x, y); +#endif + + return err; +} + +void display_clear(void) +{ +#ifdef CONFIG_LCD + lcd_clear(); +#endif +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + video_clear(); +#endif +} diff --git a/api/api_private.h b/api/api_private.h index 94a7fc5..988f702 100644 --- a/api/api_private.h +++ b/api/api_private.h @@ -45,4 +45,8 @@ int dev_write_net(void *, void *, int);
void dev_stor_init(void);
+int display_get_info(int type, struct display_info *di); +int display_draw_bitmap(ulong bitmap, int x, int y); +void display_clear(void); + #endif /* _API_PRIVATE_H_ */ diff --git a/examples/api/demo.c b/examples/api/demo.c index 65e7491..191bd79 100644 --- a/examples/api/demo.c +++ b/examples/api/demo.c @@ -176,6 +176,34 @@ int main(int argc, char * const argv[]) while ((env = ub_env_enum(env)) != NULL) printf("%s = %s\n", env, ub_env_get(env));
+ printf("\n*** Display ***\n"); + + struct display_info disinfo; + if (ub_display_get_info(DISPLAY_TYPE_LCD, &disinfo)) + printf("LCD info: failed\n"); + else { + printf("LCD info:\n"); + printf(" pixel width: %d\n", disinfo.pixel_width); + printf(" pixel height: %d\n", disinfo.pixel_height); + printf(" screen rows: %d\n", disinfo.screen_rows); + printf(" screen cols: %d\n", disinfo.screen_cols); + } + if (ub_display_get_info(DISPLAY_TYPE_VIDEO, &disinfo)) + printf("video info: failed\n"); + else { + printf("video info:\n"); + printf(" pixel width: %d\n", disinfo.pixel_width); + printf(" pixel height: %d\n", disinfo.pixel_height); + printf(" screen rows: %d\n", disinfo.screen_rows); + printf(" screen cols: %d\n", disinfo.screen_cols); + } + + printf("*** Press any key to continue ***\n"); + printf("got char 0x%x\n", ub_getc()); + + /* this only clears messages on screen, not on serial port */ + ub_display_clear(); + /* reset */ printf("\n*** Resetting board ***\n"); ub_reset(); diff --git a/examples/api/glue.c b/examples/api/glue.c index eff6a7e..d907e3f 100644 --- a/examples/api/glue.c +++ b/examples/api/glue.c @@ -402,3 +402,34 @@ const char * ub_env_enum(const char *last)
return env_name; } + +/**************************************** + * + * display + * + ****************************************/ + +int ub_display_get_info(int type, struct display_info *di) +{ + int err = 0; + + if (!syscall(API_DISPLAY_GET_INFO, &err, (uint32_t)type, (uint32_t)di)) + return API_ESYSC; + + return err; +} + +int ub_display_draw_bitmap(ulong bitmap, int x, int y) +{ + int err = 0; + + if (!syscall(API_DISPLAY_DRAW_BITMAP, &err, bitmap, x, y)) + return API_ESYSC; + + return err; +} + +void ub_display_clear(void) +{ + syscall(API_DISPLAY_CLEAR, NULL); +} diff --git a/examples/api/glue.h b/examples/api/glue.h index 6bf47d0..e43f7d9 100644 --- a/examples/api/glue.h +++ b/examples/api/glue.h @@ -77,4 +77,9 @@ int ub_dev_send(int handle, void *buf, int len); int ub_dev_recv(int handle, void *buf, int len, int *rlen); struct device_info * ub_dev_get(int);
+/* display */ +int ub_display_get_info(int type, struct display_info *di); +int ub_display_draw_bitmap(ulong bitmap, int x, int y); +void ub_display_clear(void); + #endif /* _API_GLUE_H_ */ diff --git a/include/api_public.h b/include/api_public.h index 5940d81..4420c99 100644 --- a/include/api_public.h +++ b/include/api_public.h @@ -90,6 +90,9 @@ enum { API_ENV_ENUM, API_ENV_GET, API_ENV_SET, + API_DISPLAY_GET_INFO, + API_DISPLAY_DRAW_BITMAP, + API_DISPLAY_CLEAR, API_MAXCALL };
@@ -152,4 +155,17 @@ struct device_info { int state; };
+#define DISPLAY_TYPE_LCD 0x0001 +#define DISPLAY_TYPE_VIDEO 0x0002 + +struct display_info { + int type; + /* screen size in pixels */ + int pixel_width; + int pixel_height; + /* screen size in rows and columns of text */ + int screen_rows; + int screen_cols; +}; + #endif /* _API_PUBLIC_H_ */ diff --git a/include/video_font.h b/include/video_font.h index 706e185..5571a87 100644 --- a/include/video_font.h +++ b/include/video_font.h @@ -29,6 +29,12 @@ #define VIDEO_FONT_HEIGHT 16 #define VIDEO_FONT_SIZE (VIDEO_FONT_CHARS * VIDEO_FONT_HEIGHT)
+/* + * Adding unused attribute here so that compiler will not complain + * video_fontdata is not used in source files that only use + * VIDEO_FONT_* (e.g., api/api_display.c). + */ +__attribute__ ((unused)) static unsigned char video_fontdata[VIDEO_FONT_SIZE] = {
/* 0 0x00 '^@' */
In message ce61e361e4b8456b9e0584a72f37d2e278ff2ab1.1317715598.git.clchiou@chromium.org you wrote:
- switch (type) {
- default:
Line too long.
+#ifdef CONFIG_LCD
- case DISPLAY_TYPE_LCD:
break;
- case DISPLAY_TYPE_VIDEO:
break;
- di->type = type;
- int err = 0;
+#ifdef CONFIG_LCD
- err |= lcd_display_bitmap(bitmap, x, y);
- err |= video_display_bitmap(bitmap, x, y);
- return err;
- lcd_clear();
- video_clear();
- printf("\n*** Display ***\n");
- struct display_info disinfo;
Please don't mix declarations and code.
- if (ub_display_get_info(DISPLAY_TYPE_LCD, &disinfo))
- else {
Use braces in both branches. Please fix globally.
- /* this only clears messages on screen, not on serial port */
- ub_display_clear();
What happens here if no display is available?
Dear Wolfgang Denk, On Fri, Oct 7, 2011 at 2:33 AM, Wolfgang Denk wd@denx.de wrote:
- switch (type) {
- default:
- debug("%s: unsupport display device type: %d\n", __FILE__, type);
Line too long.
+#ifdef CONFIG_LCD
- di->pixel_width = panel_info.vl_col;
- di->pixel_height = panel_info.vl_row;
- di->screen_rows = CONSOLE_ROWS;
- di->screen_cols = CONSOLE_COLS;
- break;
- di->pixel_width = VIDEO_VISIBLE_COLS;
- di->pixel_height = VIDEO_VISIBLE_ROWS;
- break;
- di->type = type;
- int err = 0;
- * Although CONFIG_LCD and CONFIG_VIDEO or CONFIG_CFB_CONSOLE
- * generally should not be both set, if this does happen, I think
- * drawing on both of them makes more sense.
+#ifdef CONFIG_LCD
- return err;
- lcd_clear();
- video_clear();
- printf("LCD info: failed\n");
- else {
It is equivalent to a no-op. Or do you think we should print a warning message if no display is available?
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Randal said it would be tough to do in sed. He didn't say he didn't understand sed. Randal understands sed quite well. Which is why he uses Perl. :-) - Larry Wall in 7874@jpl-devvax.JPL.NASA.GOV
Regards, Che-Liang
Dear Che-liang Chiou,
In message CANJuy2KuhG+4kueEupj0PBeFKJdhAJJnt_8-vULXYUXh9oCWKQ@mail.gmail.com you wrote:
ub_display_clear();
Please either add an if() and don;t run the function at all, or add a comment that explains that this callis harmless if no display is present.
Hi Wolfgang Denk,
I have added following comments to this call in patch V2. + /*+ * This only clears messages on screen, not on serial port. It is+ * equivalent to a no-op if no display is available.+ */Do you think it is sufficient?
Regards, Che-Liang
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "He was so narrow minded he could see through a keyhole with both eyes ..."
In message CANJuy2LVSzvodiim096iqj2kJ3gGD4dR=9-bctO=HJm4nhfNxg@mail.gmail.com you wrote:
Hi Wolfgang Denk,
/*+ * This only clears me=
ssages on screen, not on serial port. It is+ * equivalent to a no-op if n= o display is available.+ */Do you think it is sufficient?
Yes, this is OK with me. Thanks.
api/Makefile | 3 +- api/api.c | 51 +++++++++++++++++++++++++++++ api/api_display.c | 86 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 ++ common/lcd.c | 16 ++++++--- examples/api/demo.c | 31 ++++++++++++++++++ examples/api/glue.c | 31 ++++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 +++++++++ include/lcd.h | 2 + include/video.h | 2 + include/video_font.h | 6 +++ 12 files changed, 246 insertions(+), 7 deletions(-) create mode 100644 api/api_display.c
Changes since V1 Fix style errors
common/lcd.c | 16 ++++++++++------ include/lcd.h | 2 ++ include/video.h | 2 ++ 3 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index d9cb8ca..20e97b9 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -78,7 +78,6 @@ static inline void lcd_putc_xy (ushort x, ushort y, uchar c);
static int lcd_getbgcolor (void); @@ -353,7 +352,14 @@ int drv_lcd_init (void) }
/*----------------------------------------------------------------------*/ -static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) +static +int do_lcd_clear(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + lcd_clear(); + return 0; +} + +void lcd_clear(void) { #if LCD_BPP == LCD_MONOCHROME /* Setting the palette */ @@ -394,12 +400,10 @@ static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]
U_BOOT_CMD( - cls, 1, 1, lcd_clear, + cls, 1, 1, do_lcd_clear, "clear screen", "" ); @@ -413,7 +417,7 @@ static int lcd_init (void *lcdbase)
lcd_ctrl_init (lcdbase); lcd_is_enabled = 1; - lcd_clear (NULL, 1, 1, NULL); /* dummy args */ + lcd_clear(); lcd_enable ();
/* Initialize the console */ diff --git a/include/lcd.h b/include/lcd.h index 0e098d9..39af14a 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -210,6 +210,8 @@ void lcd_disable (void); void lcd_putc (const char c); void lcd_puts (const char *s); void lcd_printf (const char *fmt, ...); +void lcd_clear(void); +int lcd_display_bitmap(ulong bmp_image, int x, int y);
/* Allow boards to customize the information displayed */ void lcd_show_board_info(void); diff --git a/include/video.h b/include/video.h index efcc682..280bb76 100644 --- a/include/video.h +++ b/include/video.h @@ -15,5 +15,7 @@ int video_init (void *videobase); void video_putc (const char c); void video_puts (const char *s); void video_printf (const char *fmt, ...); +void video_clear(void); +int video_display_bitmap(ulong bmp_image, int x, int y);
#endif
api/Makefile | 3 +- api/api.c | 51 +++++++++++++++++++++++++++++ api/api_display.c | 86 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 ++ examples/api/demo.c | 31 ++++++++++++++++++ examples/api/glue.c | 31 ++++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 +++++++++ include/video_font.h | 6 +++ 9 files changed, 232 insertions(+), 1 deletions(-) create mode 100644 api/api_display.c
debugf("API initialized with %d calls\n", calls_no); diff --git a/api/api_display.c b/api/api_display.c new file mode 100644 index 0000000..4746d20 --- /dev/null +++ b/api/api_display.c @@ -0,0 +1,86 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <lcd.h> +#include <video.h> +#include <video_font.h> /* Get font width and height */ +#include <api_public.h> + +int display_get_info(int type, struct display_info *di) +{ + switch (type) { + default: + debug("%s: unsupport display device type: %d\n", + __FILE__, type); + return API_ENODEV; + +#ifdef CONFIG_LCD + case DISPLAY_TYPE_LCD: + di->pixel_width = panel_info.vl_col; + di->pixel_height = panel_info.vl_row; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + case DISPLAY_TYPE_VIDEO: + di->pixel_width = VIDEO_VISIBLE_COLS; + di->pixel_height = VIDEO_VISIBLE_ROWS; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + } + + di->type = type; + return 0; +} + +int display_draw_bitmap(ulong bitmap, int x, int y) +{ + int err = 0; + + /* + * Although CONFIG_LCD and CONFIG_VIDEO or CONFIG_CFB_CONSOLE + * generally should not be both set, if this does happen, I think + * drawing on both of them makes more sense. + */ +#ifdef CONFIG_LCD + err |= lcd_display_bitmap(bitmap, x, y); +#endif +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + err |= video_display_bitmap(bitmap, x, y); +#endif + + return err; +} + +void display_clear(void) +{ +#ifdef CONFIG_LCD + lcd_clear(); +#endif +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + video_clear(); +#endif +} diff --git a/api/api_private.h b/api/api_private.h index 94a7fc5..988f702 100644 --- a/api/api_private.h +++ b/api/api_private.h @@ -45,4 +45,8 @@ int dev_write_net(void *, void *, int);
+int display_get_info(int type, struct display_info *di); +int display_draw_bitmap(ulong bitmap, int x, int y); +void display_clear(void); + #endif /* _API_PRIVATE_H_ */ diff --git a/examples/api/demo.c b/examples/api/demo.c index 65e7491..19d38f6 100644 --- a/examples/api/demo.c +++ b/examples/api/demo.c @@ -48,6 +48,7 @@ int main(int argc, char * const argv[]) ulong start, now; struct device_info *di; lbasize_t rlen; + struct display_info disinfo;
if (!api_search_sig(&sig)) return -1; @@ -176,6 +177,36 @@ int main(int argc, char * const argv[]) while ((env = ub_env_enum(env)) != NULL) printf("%s = %s\n", env, ub_env_get(env));
+ printf("\n*** Display ***\n"); + + if (ub_display_get_info(DISPLAY_TYPE_LCD, &disinfo)) { + printf("LCD info: failed\n"); + } else { + printf("LCD info:\n"); + printf(" pixel width: %d\n", disinfo.pixel_width); + printf(" pixel height: %d\n", disinfo.pixel_height); + printf(" screen rows: %d\n", disinfo.screen_rows); + printf(" screen cols: %d\n", disinfo.screen_cols); + } + if (ub_display_get_info(DISPLAY_TYPE_VIDEO, &disinfo)) { + printf("video info: failed\n"); + } else { + printf("video info:\n"); + printf(" pixel width: %d\n", disinfo.pixel_width); + printf(" pixel height: %d\n", disinfo.pixel_height); + printf(" screen rows: %d\n", disinfo.screen_rows); + printf(" screen cols: %d\n", disinfo.screen_cols); + } + + printf("*** Press any key to continue ***\n"); + printf("got char 0x%x\n", ub_getc()); + + /* + * This only clears messages on screen, not on serial port. It is + * equivalent to a no-op if no display is available. + */ + ub_display_clear(); + /* reset */ printf("\n*** Resetting board ***\n"); ub_reset(); diff --git a/examples/api/glue.c b/examples/api/glue.c index eff6a7e..d907e3f 100644 --- a/examples/api/glue.c +++ b/examples/api/glue.c @@ -402,3 +402,34 @@ const char * ub_env_enum(const char *last)
/* 0 0x00 '^@' */
thanks for the patch and style fixes! I've some comments on it. Please see below.
On Fri, 7 Oct 2011 16:28:12 +0800 Che-Liang Chiou clchiou@chromium.org wrote:
Many boards defining CONFIG_LCD also define CONFIG_LCD_LOGO. Enabling CONFIG_API for such board configurations will break compiling, e.g.:
$ ./MAKEALL TQM823L_LCD Configuring for TQM823L_LCD - Board: TQM823L, Options: LCD,NEC_NL6448BC20 api_display.c: In function 'display_get_info': api_display.c:40: error: 'BMP_LOGO_HEIGHT' undeclared (first use in this function) api_display.c:40: error: (Each undeclared identifier is reported only once api_display.c:40: error: for each function it appears in.) make[1]: *** [api_display.o] Error 1 make: *** [api/libapi.o] Error 2
Any idea how to fix this issue?
Similar problem exists for boards using cfb_console driver, e.g. enabling CONFIG_API breaks compiling for tqm5200 board:
$ ./MAKEALL TQM5200 Configuring for TQM5200 board... api_display.c: In function 'display_get_info': api_display.c:47: error: 'VIDEO_VISIBLE_COLS' undeclared (first use in this function) api_display.c:47: error: (Each undeclared identifier is reported only once api_display.c:47: error: for each function it appears in.) api_display.c:48: error: 'VIDEO_VISIBLE_ROWS' undeclared (first use in this function) make[1]: *** [api_display.o] Error 1 make: *** [api/libapi.o] Error 2
We need to resolve these issues before committing this patch, i think.
Thanks, Anatolij
Hi Anatolij,
Thanks for testing this patch. Please see below.
BMP_LOGO_HEIGHT is defined bmp_logo.h, which is automatically generated by tools/bmp_logo.c when CONFIG_LCD_LOGO or CONFIG_VIDEO_LOGO is set. So I guess this is quite easy to fix. We could include bmp_logo.h in api_display.c.
VIDEO_VISIBLE_{COLS,ROLS} are just macros defined in cfb_console.c, this is my mistake. I should use GraphicDevice->{winSizeX,winSizeY} that are VIDEO_VISIBLE_{COLS,ROLS} defined upon.
Thanks, Anatolij
Regards, Che-Liang
On Tue, 18 Oct 2011 14:12:59 +0800 Che-liang Chiou clchiou@chromium.org wrote: ...
This won't work I'm afraid. bmp_logo.h is included elsewhere an including it in libapi will cause multiple definition of `bmp_logo_bitmap' and `bmp_logo_palette' compile errors.
Thanks, Anatolij
Hi Anatolij,
Thanks, Anatolij
I was planning to add a 'static __attribute__((unused))' to it to avoid this problem. What do you think?
Regards, Che-Liang
Che-Liang Chiou (4): lcd: video: add clear and draw bitmap declaration tools: logo: add static and unused to bmp arrays video: add access to GraphicDevice struct api: export LCD and video to external apps
api/Makefile | 3 +- api/api.c | 51 +++++++++++++++++++++ api/api_display.c | 97 +++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 ++ board/eltec/mhpc/mhpc.c | 7 +++ common/lcd.c | 16 ++++--- drivers/video/ati_radeon_fb.c | 5 ++ drivers/video/ct69000.c | 5 ++ drivers/video/fsl_diu_fb.c | 8 +++- drivers/video/mb862xx.c | 5 ++ drivers/video/mb86r0xgdc.c | 5 ++ drivers/video/mx3fb.c | 5 ++ drivers/video/mxc_ipuv3_fb.c | 5 ++ drivers/video/sed13806.c | 6 +++ drivers/video/sm501.c | 5 ++ drivers/video/smiLynxEM.c | 5 ++ examples/api/demo.c | 31 +++++++++++++ examples/api/glue.c | 31 +++++++++++++ examples/api/glue.h | 5 ++ include/api_public.h | 16 +++++++ include/lcd.h | 2 + include/video.h | 2 + include/video_fb.h | 6 ++- include/video_font.h | 6 +++ tools/bmp_logo.c | 6 ++- 25 files changed, 326 insertions(+), 11 deletions(-) create mode 100644 api/api_display.c
Changes in V3 Rebase to ToT
Changes in V2 Fix style errors
#endif
The generated header bmp_logo.h is useful even outside common/lcd.c for the logo dimension. However, the problem is, the generated bmp_logo.h cannot be included multiple times because bmp_logo_palette[] and bmp_logo_bitmap[] are defined in the bmp_logo.h.
We may remedy this by adding static __attribute__((unused)) to the array definitions so that bmp_logo.h can be included multiple times, and these arrays is used in only one inclusion (lcd.c).
Changes in V3 Add to the patch set
tools/bmp_logo.c | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/tools/bmp_logo.c b/tools/bmp_logo.c index 47228d2..3d11284 100644 --- a/tools/bmp_logo.c +++ b/tools/bmp_logo.c @@ -113,7 +113,8 @@ int main (int argc, char *argv[]) error ("Error allocating memory for file", fp);
/* read and print the palette information */ - printf ("unsigned short bmp_logo_palette[] = {\n"); + printf("static __attribute__((unused)) " + "unsigned short bmp_logo_palette[] = {\n");
for (i=0; i<n_colors; ++i) { b->palette[(int)(i*3+2)] = fgetc(fp); @@ -137,7 +138,8 @@ int main (int argc, char *argv[]) printf ("\n"); printf ("};\n"); printf ("\n"); - printf ("unsigned char bmp_logo_bitmap[] = {\n"); + printf("static __attribute__((unused)) " + "unsigned char bmp_logo_bitmap[] = {\n"); for (i=(b->height-1)*b->width; i>=0; i-=b->width) { for (x = 0; x < b->width; x++) { b->data[(uint16_t) i + x] = (uint8_t) fgetc (fp) \
video_hw_init() returns this struct, which is quite useful, but it is probably not okay to call this function multiple times. So this patch adds video_devinfo() that does nothing but return this struct.
video_devinfo() does not guarantee that this struct is initialized. It is user's responsibility to make sure that the video device is properly initialized.
board/eltec/mhpc/mhpc.c | 7 +++++++ drivers/video/ati_radeon_fb.c | 5 +++++ drivers/video/ct69000.c | 5 +++++ drivers/video/fsl_diu_fb.c | 8 +++++++- drivers/video/mb862xx.c | 5 +++++ drivers/video/mb86r0xgdc.c | 5 +++++ drivers/video/mx3fb.c | 5 +++++ drivers/video/mxc_ipuv3_fb.c | 5 +++++ drivers/video/sed13806.c | 6 ++++++ drivers/video/sm501.c | 5 +++++ drivers/video/smiLynxEM.c | 5 +++++ include/video_fb.h | 6 +++++- 12 files changed, 65 insertions(+), 2 deletions(-)
diff --git a/board/eltec/mhpc/mhpc.c b/board/eltec/mhpc/mhpc.c index 7cca6b2..0d2c8c9 100644 --- a/board/eltec/mhpc/mhpc.c +++ b/board/eltec/mhpc/mhpc.c @@ -466,6 +466,13 @@ void *video_hw_init (void)
+void *video_devinfo(void) +{ + return (void *)&gdev; +} + +/* ------------------------------------------------------------------------- */ + void video_set_lut (unsigned int index, unsigned char r, unsigned char g, unsigned char b) { diff --git a/drivers/video/ati_radeon_fb.c b/drivers/video/ati_radeon_fb.c index 4a9bd07..77509e1 100644 --- a/drivers/video/ati_radeon_fb.c +++ b/drivers/video/ati_radeon_fb.c @@ -770,6 +770,11 @@ void *video_hw_init(void) return ((void *) pGD); }
+void *video_devinfo(void) +{ + return (void *)&ctfb; +} + void video_set_lut (unsigned int index, /* color number */ unsigned char r, /* red */ unsigned char g, /* green */ diff --git a/drivers/video/ct69000.c b/drivers/video/ct69000.c index 3db614d..660a64c 100644 --- a/drivers/video/ct69000.c +++ b/drivers/video/ct69000.c @@ -1176,6 +1176,11 @@ video_hw_init (void) return ((void *) &ctfb); }
+void *video_devinfo(void) +{ + return (void *)&ctfb; +} + /******************************************************************************* * * Set a RGB color in the LUT (8 bit index) diff --git a/drivers/video/fsl_diu_fb.c b/drivers/video/fsl_diu_fb.c index cb43904..6ed6c32 100644 --- a/drivers/video/fsl_diu_fb.c +++ b/drivers/video/fsl_diu_fb.c @@ -367,9 +367,10 @@ int fsl_diu_init(u16 xres, u16 yres, u32 pixel_format, int gamma_fix) return 0; }
+static GraphicDevice ctfb; + void *video_hw_init(void) { - static GraphicDevice ctfb; const char *options; unsigned int depth = 0, freq = 0;
@@ -408,3 +409,8 @@ void *video_hw_init(void)
return &ctfb; } + +void *video_devinfo(void) +{ + return (void *)&ctfb; +} diff --git a/drivers/video/mb862xx.c b/drivers/video/mb862xx.c index 1a4ba82..36dbdc1 100644 --- a/drivers/video/mb862xx.c +++ b/drivers/video/mb862xx.c @@ -444,6 +444,11 @@ void *video_hw_init (void) return dev; }
+void *video_devinfo(void) +{ + return (void *)&mb862xx; +} + /* * Set a RGB color in the LUT */ diff --git a/drivers/video/mb86r0xgdc.c b/drivers/video/mb86r0xgdc.c index 345a73b..455aea3 100644 --- a/drivers/video/mb86r0xgdc.c +++ b/drivers/video/mb86r0xgdc.c @@ -182,3 +182,8 @@ void *video_hw_init(void)
return pGD; } + +void *video_devinfo(void) +{ + return (void *)&mb86r0x; +} diff --git a/drivers/video/mx3fb.c b/drivers/video/mx3fb.c index f30deb3..4ff84c8 100644 --- a/drivers/video/mx3fb.c +++ b/drivers/video/mx3fb.c @@ -922,6 +922,11 @@ void *video_hw_init(void) return (void *) &panel; }
+void *video_devinfo(void) +{ + return (void *)&panel; +} + void video_set_lut(unsigned int index, /* color number */ unsigned char r, /* red */ unsigned char g, /* green */ diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c index 1bee54c..fd27828 100644 --- a/drivers/video/mxc_ipuv3_fb.c +++ b/drivers/video/mxc_ipuv3_fb.c @@ -590,6 +590,11 @@ void *video_hw_init(void) return (void *)&panel; }
+void *video_devinfo(void) +{ + return (void *)&panel; +} + void video_set_lut(unsigned int index, /* color number */ unsigned char r, /* red */ unsigned char g, /* green */ diff --git a/drivers/video/sed13806.c b/drivers/video/sed13806.c index 0bf9ba6..ee7b9b9 100644 --- a/drivers/video/sed13806.c +++ b/drivers/video/sed13806.c @@ -108,6 +108,12 @@ void *video_hw_init (void)
return (&sed13806); } + +void *video_devinfo(void) +{ + return (void *)&sed13806; +} + /*----------------------------------------------------------------------------- * Epson_wait_idle -- Wait for hardware to become idle *----------------------------------------------------------------------------- diff --git a/drivers/video/sm501.c b/drivers/video/sm501.c index 42ac680..dd2a438 100644 --- a/drivers/video/sm501.c +++ b/drivers/video/sm501.c @@ -238,3 +238,8 @@ not_pci:
return (&sm501); } + +void *video_devinfo(void) +{ + return (void *)&sm501; +} diff --git a/drivers/video/smiLynxEM.c b/drivers/video/smiLynxEM.c index 2001e9c..87855eb 100644 --- a/drivers/video/smiLynxEM.c +++ b/drivers/video/smiLynxEM.c @@ -752,6 +752,11 @@ void *video_hw_init (void) return ((void*)&smi); }
+void *video_devinfo(void) +{ + return (void *)&smi; +} + /******************************************************************************* * * Drawing engine fill on screen region diff --git a/include/video_fb.h b/include/video_fb.h index f649c54..239bf37 100644 --- a/include/video_fb.h +++ b/include/video_fb.h @@ -76,7 +76,11 @@ typedef struct { /* Export Graphic Functions */ /******************************************************************************/
-void *video_hw_init (void); /* returns GraphicDevice struct or NULL */ +void *video_hw_init(void); /* initializes the device and + returns GraphicDevice struct or NULL */ + +void *video_devinfo(void); /* returns GraphicDevice struct; + _no_ guarantee it is initialized! */
#ifdef VIDEO_HW_BITBLT void video_hw_bitblt (
On Tue, 18 Oct 2011 17:15:37 +0800 Che-Liang Chiou clchiou@chromium.org wrote:
NAK. Better would be to add video_devinfo() only to drivers/video/cfb_console.c since the graphic device structure pointer is stored there. We do not need to add this function to each video driver.
Anatolij
api/Makefile | 3 +- api/api.c | 51 ++++++++++++++++++++++++++ api/api_display.c | 97 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 ++ examples/api/demo.c | 31 ++++++++++++++++ examples/api/glue.c | 31 ++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 ++++++++ include/video_font.h | 6 +++ 9 files changed, 243 insertions(+), 1 deletions(-) create mode 100644 api/api_display.c
debugf("API initialized with %d calls\n", calls_no); diff --git a/api/api_display.c b/api/api_display.c new file mode 100644 index 0000000..b162f7f --- /dev/null +++ b/api/api_display.c @@ -0,0 +1,97 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <lcd.h> +#include <video.h> +#include <video_fb.h> +#include <video_font.h> /* Get font width and height */ +#include <api_public.h> + +/* lcd.h needs BMP_LOGO_HEIGHT to calculate CONSOLE_ROWS */ +#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) +#include <bmp_logo.h> +#endif + +int display_get_info(int type, struct display_info *di) +{ +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + GraphicDevice *gdev; +#endif + + switch (type) { + default: + debug("%s: unsupport display device type: %d\n", + __FILE__, type); + return API_ENODEV; + +#ifdef CONFIG_LCD + case DISPLAY_TYPE_LCD: + di->pixel_width = panel_info.vl_col; + di->pixel_height = panel_info.vl_row; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + case DISPLAY_TYPE_VIDEO: + gdev = video_devinfo(); + di->pixel_width = gdev->winSizeX; + di->pixel_height = gdev->winSizeY; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + } + + di->type = type; + return 0; +} + +int display_draw_bitmap(ulong bitmap, int x, int y) +{ + int err = 0; + + /* + * Although CONFIG_LCD and CONFIG_VIDEO or CONFIG_CFB_CONSOLE + * generally should not be both set, if this does happen, I think + * drawing on both of them makes more sense. + */ +#ifdef CONFIG_LCD + err |= lcd_display_bitmap(bitmap, x, y); +#endif +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + err |= video_display_bitmap(bitmap, x, y); +#endif + + return err; +} + +void display_clear(void) +{ +#ifdef CONFIG_LCD + lcd_clear(); +#endif +#if defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE) + video_clear(); +#endif +} diff --git a/api/api_private.h b/api/api_private.h index 94a7fc5..988f702 100644 --- a/api/api_private.h +++ b/api/api_private.h @@ -45,4 +45,8 @@ int dev_write_net(void *, void *, int);
/* 0 0x00 '^@' */
On Tue, 18 Oct 2011 17:15:38 +0800 Che-Liang Chiou clchiou@chromium.org wrote: ...
- GraphicDevice *gdev;
- switch (type) {
- default:
__FILE__, type);
return API_ENODEV;
+#ifdef CONFIG_LCD
break;
the return value of video_devinfo() should be checked before dereferencing gdev pointer (it could be NULL).
Another issue is that CONSOLE_ROWS and CONSOLE_COLS macros expand to 'panel_info' structure usage here which is only okay for CONFIG_LCD case. For CONFIG_VIDEO case these macros are defined in cfb_console.c file and thus can not be used here as you currently do (compile breakage again).
- lcd_clear();
- video_clear();
video_clear() is used here but it is not defined. Below is a small patch included. It shows how video_clear() could look like (but this was not tested yet).
Anatolij
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 4e653b8..5336937 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1753,6 +1753,23 @@ static int video_init(void) return 0; }
+void video_clear(void) +{ +#ifdef VIDEO_HW_RECTFILL + video_hw_rectfill(VIDEO_PIXEL_SIZE, /* bytes per pixel */ + 0, /* dest pos x */ + 0, /* dest pos y */ + VIDEO_VISIBLE_COLS, /* frame width */ + VIDEO_VISIBLE_ROWS, /* frame height */ + CONSOLE_BG_COL /* fill color */ + ); +#else + memsetl(CONSOLE_ROW_FIRST, CONSOLE_SIZE >> 2, CONSOLE_BG_COL); +#endif + console_col = 0; + console_row = 0; +} + /* * Implement a weak default function for boards that optionally * need to skip the video initialization.
Hi Anatolij,
I remove the support of video device from the patch set since I don't have a board with video output at hand for now. I will leave this to future work.
Regards, Che-Liang
- switch (type) {
- default:
- __FILE__, type);
- return API_ENODEV;
+#ifdef CONFIG_LCD
- break;
- gdev = video_devinfo();
- di->pixel_width = gdev->winSizeX;
- di->pixel_height = gdev->winSizeY;
- lcd_clear();
- video_clear();
Anatolij
- video_hw_rectfill(VIDEO_PIXEL_SIZE, /* bytes per pixel */
- 0, /* dest pos x */
- 0, /* dest pos y */
- VIDEO_VISIBLE_COLS, /* frame width */
- VIDEO_VISIBLE_ROWS, /* frame height */
- CONSOLE_BG_COL /* fill color */
+#else
- memsetl(CONSOLE_ROW_FIRST, CONSOLE_SIZE >> 2, CONSOLE_BG_COL);
- console_col = 0;
- console_row = 0;
This patch set exports LCD clearing and bitmap-rendering on screen functions to external apps, and provides a unified interface of accessing them.
Che-Liang Chiou (3): lcd: add clear and draw bitmap declaration tools: logo: add static and unused to bmp arrays api: export LCD device to external apps
api/Makefile | 3 +- api/api.c | 51 +++++++++++++++++++++++++++++++++++++ api/api_display.c | 69 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 +++ common/lcd.c | 16 +++++++---- examples/api/demo.c | 31 ++++++++++++++++++++++ examples/api/glue.c | 31 ++++++++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 +++++++++++ include/lcd.h | 2 + include/video_font.h | 6 ++++ tools/bmp_logo.c | 6 +++- 12 files changed, 231 insertions(+), 9 deletions(-) create mode 100644 api/api_display.c
Changes in V4 Remove support of video device, which is untested and will leave to future work
common/lcd.c | 16 ++++++++++------ include/lcd.h | 2 ++ 2 files changed, 12 insertions(+), 6 deletions(-)
nice. can you fix common/cmd_bmp.c while you're at it and delete the inline extern decl for this func ? -mike
Changes in V4 None
i'm not sure this is the right way to go. what if we split bmp_logo.h instead into bmp_logo_data.h (which has the array contents) and bmp_log.h (which has the defines and externs for the data arrays) ? -mike
I support that suggestion.
This patch exports LCD info-query and bitmap-rendering functions to external apps.
This patch is tested on a Seaboard. Because the LCD driver is not yet upstreamed, the test was done in a local downstream repo.
api/Makefile | 3 +- api/api.c | 51 +++++++++++++++++++++++++++++++++++++ api/api_display.c | 69 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 +++ examples/api/demo.c | 31 ++++++++++++++++++++++ examples/api/glue.c | 31 ++++++++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 +++++++++++ include/video_font.h | 6 ++++ 9 files changed, 215 insertions(+), 1 deletions(-) create mode 100644 api/api_display.c
debugf("API initialized with %d calls\n", calls_no); diff --git a/api/api_display.c b/api/api_display.c new file mode 100644 index 0000000..b18a4a5 --- /dev/null +++ b/api/api_display.c @@ -0,0 +1,69 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <api_public.h> +#include <lcd.h> +#include <video_font.h> /* Get font width and height */ + +/* lcd.h needs BMP_LOGO_HEIGHT to calculate CONSOLE_ROWS */ +#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) +#include <bmp_logo.h> +#endif + +/* TODO(clchiou): add support of video device */ + +int display_get_info(int type, struct display_info *di) +{ + switch (type) { + default: + debug("%s: unsupport display device type: %d\n", + __FILE__, type); + return API_ENODEV; +#ifdef CONFIG_LCD + case DISPLAY_TYPE_LCD: + di->pixel_width = panel_info.vl_col; + di->pixel_height = panel_info.vl_row; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + } + + di->type = type; + return 0; +} + +int display_draw_bitmap(ulong bitmap, int x, int y) +{ + int err = 0; +#ifdef CONFIG_LCD + err |= lcd_display_bitmap(bitmap, x, y); +#endif + return err; +} + +void display_clear(void) +{ +#ifdef CONFIG_LCD + lcd_clear(); +#endif +} diff --git a/api/api_private.h b/api/api_private.h index 94a7fc5..988f702 100644 --- a/api/api_private.h +++ b/api/api_private.h @@ -45,4 +45,8 @@ int dev_write_net(void *, void *, int);
/* 0 0x00 '^@' */
- pseudo signature:
- int API_display_get_info(int type, struct display_info *di)
- int type;
- struct display_info *di;
- type = (int)va_arg(ap, u_int32_t);
- di = (struct display_info *)va_arg(ap, u_int32_t);
i know you simply copied these warts from the rest of the code, but this va_arg() usage looks wrong to me. why is u_int32_t always used as the argument to va_arg() and then the return value is cast ? seems to me this code should actually read: type = va_arg(ap, int); di = va_arg(ap, struct display_info *);
could you see if that change still works for you ?
- ulong bitmap;
- int x, y;
- bitmap = (ulong)va_arg(ap, ulong);
- if (!bitmap)
return API_EINVAL;
seems to me that this NULL pointer check belongs in the lcd core
- int err = 0;
+#ifdef CONFIG_LCD
- return err;
i think this should read: int display_draw_bitmap(ulong bitmap, int x, int y) { #ifdef CONFIG_LCD return lcd_display_bitmap(bitmap, x, y); #else return API_ENODEV; #endif }
- Adding unused attribute here so that compiler will not complain
- video_fontdata is not used in source files that only use
- VIDEO_FONT_* (e.g., api/api_display.c).
i don't think this is right. we should split the data from the rest of the defines/structs. -mike
Che-Liang Chiou (4): lcd: add clear and draw bitmap declaration tools: logo: split bmp arrays from bmp_logo.h font: split font data from video_font.h api: export LCD device to external apps
Makefile | 1 + api/Makefile | 3 +- api/api.c | 47 + api/api_display.c | 74 + api/api_private.h | 4 + arch/powerpc/cpu/mpc8xx/video.c | 1 + board/mcc200/lcd.c | 4 +- common/cmd_bmp.c | 4 +- common/lcd.c | 16 +- drivers/video/cfb_console.c | 2 + drivers/video/sed156x.c | 1 + examples/api/demo.c | 31 + examples/api/glue.c | 31 + examples/api/glue.h | 5 + include/api_public.h | 16 + include/lcd.h | 2 + include/video_font.h | 4614 +-------------------------------------- include/video_font_data.h | 4639 +++++++++++++++++++++++++++++++++++++++ tools/Makefile | 8 +- tools/bmp_logo.c | 80 +- 20 files changed, 4940 insertions(+), 4643 deletions(-) create mode 100644 api/api_display.c create mode 100644 include/video_font_data.h
Changes in V5 Remove inline extern declaration from cmd_bmp.c
common/cmd_bmp.c | 4 +--- common/lcd.c | 14 ++++++++++---- include/lcd.h | 2 ++ 3 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/common/cmd_bmp.c b/common/cmd_bmp.c index 23fc82f..682f395 100644 --- a/common/cmd_bmp.c +++ b/common/cmd_bmp.c @@ -237,9 +237,7 @@ static int bmp_display(ulong addr, int x, int y) }
#if defined(CONFIG_LCD) - extern int lcd_display_bitmap (ulong, int, int); - - ret = lcd_display_bitmap ((unsigned long)bmp, x, y); + ret = lcd_display_bitmap((ulong)bmp, x, y); #elif defined(CONFIG_VIDEO) extern int video_display_bitmap (ulong, int, int);
diff --git a/common/lcd.c b/common/lcd.c index d9cb8ca..6d91310 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -353,7 +353,14 @@ int drv_lcd_init (void) }
/*----------------------------------------------------------------------*/ -static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) +static +int do_lcd_clear(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + lcd_clear(); + return 0; +} + +void lcd_clear(void) { #if LCD_BPP == LCD_MONOCHROME /* Setting the palette */ @@ -394,8 +401,7 @@ static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]
console_col = 0; console_row = 0; - - return (0); + lcd_sync(); }
U_BOOT_CMD( @@ -413,7 +419,7 @@ static int lcd_init (void *lcdbase)
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Signed-off-by: Che-Liang Chiou clchiou@chromium.org Acked-by: Mike Frysinger vapier@gentoo.org Signed-off-by: Anatolij Gustschin agust@denx.de --- Changes since V5: - fix compile issues: lcd.c:81: error: conflicting types for 'lcd_clear' /home/ag/u-boot/u-boot-video/include/lcd.h:213: error: previous declaration of 'lcd_clear' was here lcd.c: In function 'do_lcd_clear': lcd.c:359: error: too few arguments to function 'lcd_clear' lcd.c: At top level: lcd.c:364: error: conflicting types for 'lcd_clear' lcd.c:81: error: previous declaration of 'lcd_clear' was here lcd.c: In function 'lcd_clear': lcd.c:405: warning: 'return' with a value, in function returning void lcd.c: At top level: lcd.c:408: warning: initialization from incompatible pointer type make[1]: *** [lcd.o] Error 1 make: *** [common/libcommon.o] Error 2
common/cmd_bmp.c | 4 +--- common/lcd.c | 16 ++++++++++------ include/lcd.h | 2 ++ 3 files changed, 13 insertions(+), 9 deletions(-)
/* Initialize the console */ diff --git a/include/lcd.h b/include/lcd.h index 89cc90c..83b50f4 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -210,6 +210,8 @@ void lcd_disable (void); void lcd_putc (const char c); void lcd_puts (const char *s); void lcd_printf (const char *fmt, ...); +void lcd_clear(void); +int lcd_display_bitmap(ulong bmp_image, int x, int y);
Changes since V5:
Applied to u-boot-video/master, thanks.
Anatolij
This patch fixes this by defining these arrays in another header bmp_logo_data.h and in bmp_logo.h only declaring these arrays.
Changes in V5 Split bmp arrays from bmp_logo.h to bmp_logo_data.h
Changes in V4 None
Makefile | 1 + common/lcd.c | 1 + drivers/video/cfb_console.c | 1 + tools/Makefile | 8 ++++- tools/bmp_logo.c | 80 ++++++++++++++++++++++++++++++++----------- 5 files changed, 70 insertions(+), 21 deletions(-)
diff --git a/Makefile b/Makefile index e9a153c..d35f2b5 100644 --- a/Makefile +++ b/Makefile @@ -947,6 +947,7 @@ clean: $(obj)arch/blackfin/cpu/bootrom-asm-offsets.[chs] \ $(obj)arch/blackfin/cpu/init.{lds,elf} @rm -f $(obj)include/bmp_logo.h + @rm -f $(obj)include/bmp_logo_data.h @rm -f $(obj)lib/asm-offsets.s @rm -f $(obj)include/generated/asm-offsets.h @rm -f $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s diff --git a/common/lcd.c b/common/lcd.c index 6d91310..dd4d37b 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -63,6 +63,7 @@ /************************************************************************/ #ifdef CONFIG_LCD_LOGO # include <bmp_logo.h> /* Get logo data, width and height */ +# include <bmp_logo_data.h> # if (CONSOLE_COLOR_WHITE >= BMP_LOGO_OFFSET) && (LCD_BPP != LCD_COLOR16) # error Default Color Map overlaps with Logo Color Map # endif diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 4e653b8..8d0c496 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -285,6 +285,7 @@ void console_cursor(int state); #ifdef CONFIG_VIDEO_LOGO #ifdef CONFIG_VIDEO_BMP_LOGO #include <bmp_logo.h> +#include <bmp_logo_data.h> #define VIDEO_LOGO_WIDTH BMP_LOGO_WIDTH #define VIDEO_LOGO_HEIGHT BMP_LOGO_HEIGHT #define VIDEO_LOGO_LUT_OFFSET BMP_LOGO_OFFSET diff --git a/tools/Makefile b/tools/Makefile index fc741d3..f750ad2 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -110,8 +110,11 @@ LIBFDT_OBJ_FILES-y += fdt_wip.o
# Generated LCD/video logo LOGO_H = $(OBJTREE)/include/bmp_logo.h +LOGO_DATA_H = $(OBJTREE)/include/bmp_logo_data.h LOGO-$(CONFIG_LCD_LOGO) += $(LOGO_H) +LOGO-$(CONFIG_LCD_LOGO) += $(LOGO_DATA_H) LOGO-$(CONFIG_VIDEO_LOGO) += $(LOGO_H) +LOGO-$(CONFIG_VIDEO_LOGO) += $(LOGO_DATA_H)
ifeq ($(LOGO_BMP),) LOGO_BMP= logos/denx.bmp @@ -234,7 +237,10 @@ else endif
$(LOGO_H): $(obj)bmp_logo $(LOGO_BMP) - $(obj)./bmp_logo $(LOGO_BMP) >$@ + $(obj)./bmp_logo --gen-info $(LOGO_BMP) > $@ + +$(LOGO_DATA_H): $(obj)bmp_logo $(LOGO_BMP) + $(obj)./bmp_logo --gen-data $(LOGO_BMP) > $@
diff --git a/tools/bmp_logo.c b/tools/bmp_logo.c index 47228d2..b2ad3d5 100644 --- a/tools/bmp_logo.c +++ b/tools/bmp_logo.c @@ -1,5 +1,10 @@ #include "compiler.h"
+enum { + MODE_GEN_INFO, + MODE_GEN_DATA +}; + typedef struct bitmap_s { /* bitmap description */ uint16_t width; uint16_t height; @@ -9,6 +14,11 @@ typedef struct bitmap_s { /* bitmap description */
#define DEFAULT_CMAP_SIZE 16 /* size of default color map */
+void usage(const char *prog) +{ + fprintf(stderr, "Usage: %s [--gen-info|--gen-data] file\n", prog); +} + /* * Neutralize little endians. */ @@ -39,21 +49,52 @@ int error (char * msg, FILE *fp) exit (EXIT_FAILURE); }
+void gen_info(bitmap_t *b, uint16_t n_colors) +{ + printf("/*\n" + " * Automatically generated by "tools/bmp_logo"\n" + " *\n" + " * DO NOT EDIT\n" + " *\n" + " */\n\n\n" + "#ifndef __BMP_LOGO_H__\n" + "#define __BMP_LOGO_H__\n\n" + "#define BMP_LOGO_WIDTH\t\t%d\n" + "#define BMP_LOGO_HEIGHT\t\t%d\n" + "#define BMP_LOGO_COLORS\t\t%d\n" + "#define BMP_LOGO_OFFSET\t\t%d\n\n" + "extern unsigned short bmp_logo_palette[];\n" + "extern unsigned char bmp_logo_bitmap[];\n\n" + "#endif /* __BMP_LOGO_H__ */\n", + b->width, b->height, n_colors, + DEFAULT_CMAP_SIZE); +} + int main (int argc, char *argv[]) { - int i, x; + int mode, i, x; FILE *fp; bitmap_t bmp; bitmap_t *b = &bmp; uint16_t data_offset, n_colors;
- if (argc < 2) { - fprintf (stderr, "Usage: %s file\n", argv[0]); + if (argc < 3) { + usage(argv[0]); exit (EXIT_FAILURE); }
- if ((fp = fopen (argv[1], "rb")) == NULL) { - perror (argv[1]); + if (!strcmp(argv[1], "--gen-info")) + mode = MODE_GEN_INFO; + else if (!strcmp(argv[1], "--gen-data")) + mode = MODE_GEN_DATA; + else { + usage(argv[0]); + exit(EXIT_FAILURE); + } + + fp = fopen(argv[2], "rb"); + if (!fp) { + perror(argv[2]); exit (EXIT_FAILURE); }
@@ -92,28 +133,26 @@ int main (int argc, char *argv[]) n_colors = 256 - DEFAULT_CMAP_SIZE; }
- printf ("/*\n" + if (mode == MODE_GEN_INFO) { + gen_info(b, n_colors); + goto out; + } + + printf("/*\n" " * Automatically generated by "tools/bmp_logo"\n" " *\n" " * DO NOT EDIT\n" " *\n" " */\n\n\n" - "#ifndef __BMP_LOGO_H__\n" - "#define __BMP_LOGO_H__\n\n" - "#define BMP_LOGO_WIDTH\t\t%d\n" - "#define BMP_LOGO_HEIGHT\t\t%d\n" - "#define BMP_LOGO_COLORS\t\t%d\n" - "#define BMP_LOGO_OFFSET\t\t%d\n" - "\n", - b->width, b->height, n_colors, - DEFAULT_CMAP_SIZE); + "#ifndef __BMP_LOGO_DATA_H__\n" + "#define __BMP_LOGO_DATA_H__\n\n");
/* allocate memory */ if ((b->data = (uint8_t *)malloc(b->width * b->height)) == NULL) error ("Error allocating memory for file", fp);
/* read and print the palette information */ - printf ("unsigned short bmp_logo_palette[] = {\n"); + printf("unsigned short bmp_logo_palette[] = {\n");
for (i=0; i<n_colors; ++i) { b->palette[(int)(i*3+2)] = fgetc(fp); @@ -137,14 +176,13 @@ int main (int argc, char *argv[]) printf ("\n"); printf ("};\n"); printf ("\n"); - printf ("unsigned char bmp_logo_bitmap[] = {\n"); + printf("unsigned char bmp_logo_bitmap[] = {\n"); for (i=(b->height-1)*b->width; i>=0; i-=b->width) { for (x = 0; x < b->width; x++) { b->data[(uint16_t) i + x] = (uint8_t) fgetc (fp) \ + DEFAULT_CMAP_SIZE; } } - fclose (fp);
for (i=0; i<(b->height*b->width); ++i) { if ((i%8) == 0) @@ -156,8 +194,10 @@ int main (int argc, char *argv[]) } printf ("\n" "};\n\n" - "#endif /* __BMP_LOGO_H__ */\n" + "#endif /* __BMP_LOGO_DATA_H__ */\n" );
- return (0); +out: + fclose(fp); + return 0; }
Signed-off-by: Che-Liang Chiou clchiou@chromium.org Acked-by: Mike Frysinger vapier@gentoo.org Signed-off-by: Anatolij Gustschin agust@denx.de --- Changes since V5: - add bmp_logo_data.h to .gitignore
Makefile | 1 + common/lcd.c | 1 + drivers/video/cfb_console.c | 1 + include/.gitignore | 1 + tools/Makefile | 8 ++++- tools/bmp_logo.c | 80 ++++++++++++++++++++++++++++++++----------- 6 files changed, 71 insertions(+), 21 deletions(-)
diff --git a/Makefile b/Makefile index 9ef33f9..b620e75 100644 --- a/Makefile +++ b/Makefile @@ -866,6 +866,7 @@ clean: $(obj)arch/blackfin/cpu/bootrom-asm-offsets.[chs] \ $(obj)arch/blackfin/cpu/init.{lds,elf} @rm -f $(obj)include/bmp_logo.h + @rm -f $(obj)include/bmp_logo_data.h @rm -f $(obj)lib/asm-offsets.s @rm -f $(obj)include/generated/asm-offsets.h @rm -f $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s diff --git a/common/lcd.c b/common/lcd.c index 20e97b9..504b8f6 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -63,6 +63,7 @@ /************************************************************************/ #ifdef CONFIG_LCD_LOGO # include <bmp_logo.h> /* Get logo data, width and height */ +# include <bmp_logo_data.h> # if (CONSOLE_COLOR_WHITE >= BMP_LOGO_OFFSET) && (LCD_BPP != LCD_COLOR16) # error Default Color Map overlaps with Logo Color Map # endif diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 1863563..24e5761 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -285,6 +285,7 @@ void console_cursor(int state); #ifdef CONFIG_VIDEO_LOGO #ifdef CONFIG_VIDEO_BMP_LOGO #include <bmp_logo.h> +#include <bmp_logo_data.h> #define VIDEO_LOGO_WIDTH BMP_LOGO_WIDTH #define VIDEO_LOGO_HEIGHT BMP_LOGO_HEIGHT #define VIDEO_LOGO_LUT_OFFSET BMP_LOGO_OFFSET diff --git a/include/.gitignore b/include/.gitignore index ec224c5..7cd3e90 100644 --- a/include/.gitignore +++ b/include/.gitignore @@ -1,5 +1,6 @@ /autoconf.mk* /asm /bmp_logo.h +/bmp_logo_data.h /config.h /config.mk diff --git a/tools/Makefile b/tools/Makefile index df56a25..948ec19 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -111,8 +111,11 @@ LIBFDT_OBJ_FILES-y += fdt_wip.o
ifeq ($(LOGO_BMP),) LOGO_BMP= logos/denx.bmp @@ -236,7 +239,10 @@ else endif
Changes since V5:
Anatolij
While video_font.h is useful even without referencing the font data, it is not possible to be included multiple times because it defines font data array right in the header.
This patch splits the font data array into video_font_data.h and so now video_font.h can be included multiple times. This at least solves the code duplication in board/mcc200/lcd.c.
Changes in V5 Split font arrays from video_font.h to video_font_data.h
arch/powerpc/cpu/mpc8xx/video.c | 1 + board/mcc200/lcd.c | 4 +- common/lcd.c | 1 + drivers/video/cfb_console.c | 1 + drivers/video/sed156x.c | 1 + include/video_font.h | 4614 +-------------------------------------- include/video_font_data.h | 4639 +++++++++++++++++++++++++++++++++++++++ 7 files changed, 4647 insertions(+), 4614 deletions(-) create mode 100644 include/video_font_data.h
diff --git a/arch/powerpc/cpu/mpc8xx/video.c b/arch/powerpc/cpu/mpc8xx/video.c index 7725c67..1bbf4cc 100644 --- a/arch/powerpc/cpu/mpc8xx/video.c +++ b/arch/powerpc/cpu/mpc8xx/video.c @@ -125,6 +125,7 @@ DECLARE_GLOBAL_DATA_PTR; /************************************************************************/
#include <video_font.h> /* Get font data, width and height */ +#include <video_font_data.h>
#ifdef CONFIG_VIDEO_LOGO #include <video_logo.h> /* Get logo data, width and height */ diff --git a/board/mcc200/lcd.c b/board/mcc200/lcd.c index 726366d..d8f754c 100644 --- a/board/mcc200/lcd.c +++ b/board/mcc200/lcd.c @@ -55,6 +55,9 @@ #define PSOC_RETRIES 10 /* each of PSOC_WAIT_TIME */ #define PSOC_WAIT_TIME 10 /* usec */
+#include <video_font.h> +#define FONT_WIDTH VIDEO_FONT_WIDTH + DECLARE_GLOBAL_DATA_PTR;
/* @@ -185,7 +188,6 @@ void lcd_enable (void) } #ifdef CONFIG_PROGRESSBAR
-#define FONT_WIDTH 8 /* the same as VIDEO_FONT_WIDTH in video_font.h */ void show_progress (int size, int tot) { int cnt; diff --git a/common/lcd.c b/common/lcd.c index dd4d37b..0edeb89 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -57,6 +57,7 @@ /* ** FONT DATA */ /************************************************************************/ #include <video_font.h> /* Get font data, width and height */ +#include <video_font_data.h>
/************************************************************************/ /* ** LOGO DATA */ diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 8d0c496..9c6d89e 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -202,6 +202,7 @@ #include <linux/types.h> #include <stdio_dev.h> #include <video_font.h> +#include <video_font_data.h>
#if defined(CONFIG_CMD_DATE) #include <rtc.h> diff --git a/drivers/video/sed156x.c b/drivers/video/sed156x.c index 707250d..a610b74 100644 --- a/drivers/video/sed156x.c +++ b/drivers/video/sed156x.c @@ -41,6 +41,7 @@
/* include the font data */ #include <video_font.h> +#include <video_font_data.h>
#if VIDEO_FONT_WIDTH != 8 || VIDEO_FONT_HEIGHT != 16 #error Expecting VIDEO_FONT_WIDTH == 8 && VIDEO_FONT_HEIGHT == 16 diff --git a/include/video_font.h b/include/video_font.h index 706e185..47957c4 100644 --- a/include/video_font.h +++ b/include/video_font.h @@ -29,4616 +29,4 @@ #define VIDEO_FONT_HEIGHT 16 #define VIDEO_FONT_SIZE (VIDEO_FONT_CHARS * VIDEO_FONT_HEIGHT)
-static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { - - /* 0 0x00 '^@' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 1 0x01 '^A' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x81, /* 10000001 */ - 0xa5, /* 10100101 */ - 0x81, /* 10000001 */ - 0x81, /* 10000001 */ - 0xbd, /* 10111101 */ - 0x99, /* 10011001 */ - 0x81, /* 10000001 */ - 0x81, /* 10000001 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 2 0x02 '^B' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0xff, /* 11111111 */ - 0xdb, /* 11011011 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xc3, /* 11000011 */ - 0xe7, /* 11100111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 3 0x03 '^C' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x6c, /* 01101100 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0x7c, /* 01111100 */ - 0x38, /* 00111000 */ - 0x10, /* 00010000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 4 0x04 '^D' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x7c, /* 01111100 */ - 0xfe, /* 11111110 */ - 0x7c, /* 01111100 */ - 0x38, /* 00111000 */ - 0x10, /* 00010000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 5 0x05 '^E' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x3c, /* 00111100 */ - 0xe7, /* 11100111 */ - 0xe7, /* 11100111 */ - 0xe7, /* 11100111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 6 0x06 '^F' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x7e, /* 01111110 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 7 0x07 '^G' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 8 0x08 '^H' */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xe7, /* 11100111 */ - 0xc3, /* 11000011 */ - 0xc3, /* 11000011 */ - 0xe7, /* 11100111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - - /* 9 0x09 '^I' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0x42, /* 01000010 */ - 0x42, /* 01000010 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 10 0x0a '^J' */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xc3, /* 11000011 */ - 0x99, /* 10011001 */ - 0xbd, /* 10111101 */ - 0xbd, /* 10111101 */ - 0x99, /* 10011001 */ - 0xc3, /* 11000011 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - - /* 11 0x0b '^K' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1e, /* 00011110 */ - 0x0e, /* 00001110 */ - 0x1a, /* 00011010 */ - 0x32, /* 00110010 */ - 0x78, /* 01111000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x78, /* 01111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 12 0x0c '^L' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 13 0x0d '^M' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3f, /* 00111111 */ - 0x33, /* 00110011 */ - 0x3f, /* 00111111 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x70, /* 01110000 */ - 0xf0, /* 11110000 */ - 0xe0, /* 11100000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 14 0x0e '^N' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7f, /* 01111111 */ - 0x63, /* 01100011 */ - 0x7f, /* 01111111 */ - 0x63, /* 01100011 */ - 0x63, /* 01100011 */ - 0x63, /* 01100011 */ - 0x63, /* 01100011 */ - 0x67, /* 01100111 */ - 0xe7, /* 11100111 */ - 0xe6, /* 11100110 */ - 0xc0, /* 11000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 15 0x0f '^O' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xdb, /* 11011011 */ - 0x3c, /* 00111100 */ - 0xe7, /* 11100111 */ - 0x3c, /* 00111100 */ - 0xdb, /* 11011011 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 16 0x10 '^P' */ - 0x00, /* 00000000 */ - 0x80, /* 10000000 */ - 0xc0, /* 11000000 */ - 0xe0, /* 11100000 */ - 0xf0, /* 11110000 */ - 0xf8, /* 11111000 */ - 0xfe, /* 11111110 */ - 0xf8, /* 11111000 */ - 0xf0, /* 11110000 */ - 0xe0, /* 11100000 */ - 0xc0, /* 11000000 */ - 0x80, /* 10000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 17 0x11 '^Q' */ - 0x00, /* 00000000 */ - 0x02, /* 00000010 */ - 0x06, /* 00000110 */ - 0x0e, /* 00001110 */ - 0x1e, /* 00011110 */ - 0x3e, /* 00111110 */ - 0xfe, /* 11111110 */ - 0x3e, /* 00111110 */ - 0x1e, /* 00011110 */ - 0x0e, /* 00001110 */ - 0x06, /* 00000110 */ - 0x02, /* 00000010 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 18 0x12 '^R' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 19 0x13 '^S' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 20 0x14 '^T' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7f, /* 01111111 */ - 0xdb, /* 11011011 */ - 0xdb, /* 11011011 */ - 0xdb, /* 11011011 */ - 0x7b, /* 01111011 */ - 0x1b, /* 00011011 */ - 0x1b, /* 00011011 */ - 0x1b, /* 00011011 */ - 0x1b, /* 00011011 */ - 0x1b, /* 00011011 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 21 0x15 '^U' */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0x60, /* 01100000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x0c, /* 00001100 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 22 0x16 '^V' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 23 0x17 '^W' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 24 0x18 '^X' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 25 0x19 '^Y' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 26 0x1a '^Z' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0xfe, /* 11111110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 27 0x1b '^[' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xfe, /* 11111110 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 28 0x1c '^' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 29 0x1d '^]' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x28, /* 00101000 */ - 0x6c, /* 01101100 */ - 0xfe, /* 11111110 */ - 0x6c, /* 01101100 */ - 0x28, /* 00101000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 30 0x1e '^^' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x38, /* 00111000 */ - 0x7c, /* 01111100 */ - 0x7c, /* 01111100 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 31 0x1f '^_' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0x7c, /* 01111100 */ - 0x7c, /* 01111100 */ - 0x38, /* 00111000 */ - 0x38, /* 00111000 */ - 0x10, /* 00010000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 32 0x20 ' ' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 33 0x21 '!' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x3c, /* 00111100 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 34 0x22 '"' */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x24, /* 00100100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 35 0x23 '#' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0xfe, /* 11111110 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0xfe, /* 11111110 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 36 0x24 '$' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc2, /* 11000010 */ - 0xc0, /* 11000000 */ - 0x7c, /* 01111100 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x86, /* 10000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 37 0x25 '%' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc2, /* 11000010 */ - 0xc6, /* 11000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xc6, /* 11000110 */ - 0x86, /* 10000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 38 0x26 '&' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 39 0x27 ''' */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 40 0x28 '(' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 41 0x29 ')' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 42 0x2a '*' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0xff, /* 11111111 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 43 0x2b '+' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 44 0x2c ',' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 45 0x2d '-' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 46 0x2e '.' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 47 0x2f '/' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x02, /* 00000010 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xc0, /* 11000000 */ - 0x80, /* 10000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 48 0x30 '0' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 49 0x31 '1' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x38, /* 00111000 */ - 0x78, /* 01111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 50 0x32 '2' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 51 0x33 '3' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x3c, /* 00111100 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 52 0x34 '4' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x0c, /* 00001100 */ - 0x1c, /* 00011100 */ - 0x3c, /* 00111100 */ - 0x6c, /* 01101100 */ - 0xcc, /* 11001100 */ - 0xfe, /* 11111110 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x1e, /* 00011110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 53 0x35 '5' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xfc, /* 11111100 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 54 0x36 '6' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x60, /* 01100000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xfc, /* 11111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 55 0x37 '7' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 56 0x38 '8' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 57 0x39 '9' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7e, /* 01111110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x78, /* 01111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 58 0x3a ':' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 59 0x3b ';' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 60 0x3c '<' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x06, /* 00000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 61 0x3d '=' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 62 0x3e '>' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 63 0x3f '?' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 64 0x40 '@' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xde, /* 11011110 */ - 0xde, /* 11011110 */ - 0xde, /* 11011110 */ - 0xdc, /* 11011100 */ - 0xc0, /* 11000000 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 65 0x41 'A' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 66 0x42 'B' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfc, /* 11111100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x7c, /* 01111100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0xfc, /* 11111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 67 0x43 'C' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0xc2, /* 11000010 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc2, /* 11000010 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 68 0x44 'D' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xf8, /* 11111000 */ - 0x6c, /* 01101100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x6c, /* 01101100 */ - 0xf8, /* 11111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 69 0x45 'E' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x66, /* 01100110 */ - 0x62, /* 01100010 */ - 0x68, /* 01101000 */ - 0x78, /* 01111000 */ - 0x68, /* 01101000 */ - 0x60, /* 01100000 */ - 0x62, /* 01100010 */ - 0x66, /* 01100110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 70 0x46 'F' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x66, /* 01100110 */ - 0x62, /* 01100010 */ - 0x68, /* 01101000 */ - 0x78, /* 01111000 */ - 0x68, /* 01101000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0xf0, /* 11110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 71 0x47 'G' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0xc2, /* 11000010 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xde, /* 11011110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x66, /* 01100110 */ - 0x3a, /* 00111010 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 72 0x48 'H' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 73 0x49 'I' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 74 0x4a 'J' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1e, /* 00011110 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x78, /* 01111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 75 0x4b 'K' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xe6, /* 11100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x6c, /* 01101100 */ - 0x78, /* 01111000 */ - 0x78, /* 01111000 */ - 0x6c, /* 01101100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0xe6, /* 11100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 76 0x4c 'L' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xf0, /* 11110000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x62, /* 01100010 */ - 0x66, /* 01100110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 77 0x4d 'M' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xee, /* 11101110 */ - 0xfe, /* 11111110 */ - 0xfe, /* 11111110 */ - 0xd6, /* 11010110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 78 0x4e 'N' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xe6, /* 11100110 */ - 0xf6, /* 11110110 */ - 0xfe, /* 11111110 */ - 0xde, /* 11011110 */ - 0xce, /* 11001110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 79 0x4f 'O' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 80 0x50 'P' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfc, /* 11111100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x7c, /* 01111100 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0xf0, /* 11110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 81 0x51 'Q' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xd6, /* 11010110 */ - 0xde, /* 11011110 */ - 0x7c, /* 01111100 */ - 0x0c, /* 00001100 */ - 0x0e, /* 00001110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 82 0x52 'R' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfc, /* 11111100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x7c, /* 01111100 */ - 0x6c, /* 01101100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0xe6, /* 11100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 83 0x53 'S' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x60, /* 01100000 */ - 0x38, /* 00111000 */ - 0x0c, /* 00001100 */ - 0x06, /* 00000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 84 0x54 'T' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x7e, /* 01111110 */ - 0x5a, /* 01011010 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 85 0x55 'U' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 86 0x56 'V' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x10, /* 00010000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 87 0x57 'W' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xfe, /* 11111110 */ - 0xee, /* 11101110 */ - 0x6c, /* 01101100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 88 0x58 'X' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x7c, /* 01111100 */ - 0x38, /* 00111000 */ - 0x38, /* 00111000 */ - 0x7c, /* 01111100 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 89 0x59 'Y' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 90 0x5a 'Z' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0x86, /* 10000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xc2, /* 11000010 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 91 0x5b '[' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 92 0x5c '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x80, /* 10000000 */ - 0xc0, /* 11000000 */ - 0xe0, /* 11100000 */ - 0x70, /* 01110000 */ - 0x38, /* 00111000 */ - 0x1c, /* 00011100 */ - 0x0e, /* 00001110 */ - 0x06, /* 00000110 */ - 0x02, /* 00000010 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 93 0x5d ']' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 94 0x5e '^' */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 95 0x5f '_' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 96 0x60 '`' */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 97 0x61 'a' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x78, /* 01111000 */ - 0x0c, /* 00001100 */ - 0x7c, /* 01111100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 98 0x62 'b' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xe0, /* 11100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x78, /* 01111000 */ - 0x6c, /* 01101100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 99 0x63 'c' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 100 0x64 'd' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1c, /* 00011100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x3c, /* 00111100 */ - 0x6c, /* 01101100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 101 0x65 'e' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 102 0x66 'f' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1c, /* 00011100 */ - 0x36, /* 00110110 */ - 0x32, /* 00110010 */ - 0x30, /* 00110000 */ - 0x78, /* 01111000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x78, /* 01111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 103 0x67 'g' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x7c, /* 01111100 */ - 0x0c, /* 00001100 */ - 0xcc, /* 11001100 */ - 0x78, /* 01111000 */ - 0x00, /* 00000000 */ - - /* 104 0x68 'h' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xe0, /* 11100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x6c, /* 01101100 */ - 0x76, /* 01110110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0xe6, /* 11100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 105 0x69 'i' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 106 0x6a 'j' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x00, /* 00000000 */ - 0x0e, /* 00001110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - - /* 107 0x6b 'k' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xe0, /* 11100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x66, /* 01100110 */ - 0x6c, /* 01101100 */ - 0x78, /* 01111000 */ - 0x78, /* 01111000 */ - 0x6c, /* 01101100 */ - 0x66, /* 01100110 */ - 0xe6, /* 11100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 108 0x6c 'l' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 109 0x6d 'm' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xec, /* 11101100 */ - 0xfe, /* 11111110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 110 0x6e 'n' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xdc, /* 11011100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 111 0x6f 'o' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 112 0x70 'p' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xdc, /* 11011100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x7c, /* 01111100 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0xf0, /* 11110000 */ - 0x00, /* 00000000 */ - - /* 113 0x71 'q' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x7c, /* 01111100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x1e, /* 00011110 */ - 0x00, /* 00000000 */ - - /* 114 0x72 'r' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xdc, /* 11011100 */ - 0x76, /* 01110110 */ - 0x66, /* 01100110 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0xf0, /* 11110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 115 0x73 's' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0x60, /* 01100000 */ - 0x38, /* 00111000 */ - 0x0c, /* 00001100 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 116 0x74 't' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0xfc, /* 11111100 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x36, /* 00110110 */ - 0x1c, /* 00011100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 117 0x75 'u' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 118 0x76 'v' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 119 0x77 'w' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xd6, /* 11010110 */ - 0xfe, /* 11111110 */ - 0x6c, /* 01101100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 120 0x78 'x' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x38, /* 00111000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 121 0x79 'y' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7e, /* 01111110 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0xf8, /* 11111000 */ - 0x00, /* 00000000 */ - - /* 122 0x7a 'z' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xcc, /* 11001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 123 0x7b '{' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x0e, /* 00001110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x70, /* 01110000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x0e, /* 00001110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 124 0x7c '|' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 125 0x7d '}' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x70, /* 01110000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x0e, /* 00001110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x70, /* 01110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 126 0x7e '~' */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 127 0x7f '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 128 0x80 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0xc2, /* 11000010 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc2, /* 11000010 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x70, /* 01110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 129 0x81 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xcc, /* 11001100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 130 0x82 '' */ - 0x00, /* 00000000 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 131 0x83 '' */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x00, /* 00000000 */ - 0x78, /* 01111000 */ - 0x0c, /* 00001100 */ - 0x7c, /* 01111100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 132 0x84 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xcc, /* 11001100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x78, /* 01111000 */ - 0x0c, /* 00001100 */ - 0x7c, /* 01111100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 133 0x85 ' ' */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x78, /* 01111000 */ - 0x0c, /* 00001100 */ - 0x7c, /* 01111100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 134 0x86 '' */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x00, /* 00000000 */ - 0x78, /* 01111000 */ - 0x0c, /* 00001100 */ - 0x7c, /* 01111100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 135 0x87 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x18, /* 00011000 */ - 0x70, /* 01110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 136 0x88 '' */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 137 0x89 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 138 0x8a '' */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 139 0x8b '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 140 0x8c '' */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 141 0x8d '' */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 142 0x8e '' */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 143 0x8f '' */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 144 0x90 '' */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x66, /* 01100110 */ - 0x62, /* 01100010 */ - 0x68, /* 01101000 */ - 0x78, /* 01111000 */ - 0x68, /* 01101000 */ - 0x62, /* 01100010 */ - 0x66, /* 01100110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 145 0x91 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xec, /* 11101100 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x7e, /* 01111110 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0x6e, /* 01101110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 146 0x92 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3e, /* 00111110 */ - 0x6c, /* 01101100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xfe, /* 11111110 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xce, /* 11001110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 147 0x93 '' */ - 0x00, /* 00000000 */ - 0x10, /* 00010000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 148 0x94 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 149 0x95 '' */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 150 0x96 '' */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x78, /* 01111000 */ - 0xcc, /* 11001100 */ - 0x00, /* 00000000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 151 0x97 '' */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 152 0x98 '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7e, /* 01111110 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x78, /* 01111000 */ - 0x00, /* 00000000 */ - - /* 153 0x99 '' */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 154 0x9a '' */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 155 0x9b '' */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 156 0x9c '' */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x64, /* 01100100 */ - 0x60, /* 01100000 */ - 0xf0, /* 11110000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0xe6, /* 11100110 */ - 0xfc, /* 11111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 157 0x9d '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 158 0x9e '' */ - 0x00, /* 00000000 */ - 0xf8, /* 11111000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xf8, /* 11111000 */ - 0xc4, /* 11000100 */ - 0xcc, /* 11001100 */ - 0xde, /* 11011110 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 159 0x9f '' */ - 0x00, /* 00000000 */ - 0x0e, /* 00001110 */ - 0x1b, /* 00011011 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xd8, /* 11011000 */ - 0x70, /* 01110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 160 0xa0 ' ' */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x00, /* 00000000 */ - 0x78, /* 01111000 */ - 0x0c, /* 00001100 */ - 0x7c, /* 01111100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 161 0xa1 '¡' */ - 0x00, /* 00000000 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 162 0xa2 '¢' */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 163 0xa3 '£' */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x00, /* 00000000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 164 0xa4 '€' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0x00, /* 00000000 */ - 0xdc, /* 11011100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 165 0xa5 '¥' */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0x00, /* 00000000 */ - 0xc6, /* 11000110 */ - 0xe6, /* 11100110 */ - 0xf6, /* 11110110 */ - 0xfe, /* 11111110 */ - 0xde, /* 11011110 */ - 0xce, /* 11001110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 166 0xa6 'Š' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x3e, /* 00111110 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 167 0xa7 '§' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 168 0xa8 'š' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xc0, /* 11000000 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x7c, /* 01111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 169 0xa9 '©' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 170 0xaa 'ª' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 171 0xab '«' */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0xe0, /* 11100000 */ - 0x62, /* 01100010 */ - 0x66, /* 01100110 */ - 0x6c, /* 01101100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xdc, /* 11011100 */ - 0x86, /* 10000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x3e, /* 00111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 172 0xac '¬' */ - 0x00, /* 00000000 */ - 0x60, /* 01100000 */ - 0xe0, /* 11100000 */ - 0x62, /* 01100010 */ - 0x66, /* 01100110 */ - 0x6c, /* 01101100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x66, /* 01100110 */ - 0xce, /* 11001110 */ - 0x9a, /* 10011010 */ - 0x3f, /* 00111111 */ - 0x06, /* 00000110 */ - 0x06, /* 00000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 173 0xad '' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x3c, /* 00111100 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 174 0xae '®' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x36, /* 00110110 */ - 0x6c, /* 01101100 */ - 0xd8, /* 11011000 */ - 0x6c, /* 01101100 */ - 0x36, /* 00110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 175 0xaf '¯' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xd8, /* 11011000 */ - 0x6c, /* 01101100 */ - 0x36, /* 00110110 */ - 0x6c, /* 01101100 */ - 0xd8, /* 11011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 176 0xb0 '°' */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - 0x11, /* 00010001 */ - 0x44, /* 01000100 */ - - /* 177 0xb1 '±' */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - 0x55, /* 01010101 */ - 0xaa, /* 10101010 */ - - /* 178 0xb2 '²' */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - 0xdd, /* 11011101 */ - 0x77, /* 01110111 */ - - /* 179 0xb3 '³' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 180 0xb4 'Ž' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xf8, /* 11111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 181 0xb5 'µ' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xf8, /* 11111000 */ - 0x18, /* 00011000 */ - 0xf8, /* 11111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 182 0xb6 '¶' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xf6, /* 11110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 183 0xb7 '·' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 184 0xb8 'ž' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xf8, /* 11111000 */ - 0x18, /* 00011000 */ - 0xf8, /* 11111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 185 0xb9 '¹' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xf6, /* 11110110 */ - 0x06, /* 00000110 */ - 0xf6, /* 11110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 186 0xba 'º' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 187 0xbb '»' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x06, /* 00000110 */ - 0xf6, /* 11110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 188 0xbc 'Œ' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xf6, /* 11110110 */ - 0x06, /* 00000110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 189 0xbd 'œ' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 190 0xbe 'Ÿ' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xf8, /* 11111000 */ - 0x18, /* 00011000 */ - 0xf8, /* 11111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 191 0xbf '¿' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xf8, /* 11111000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 192 0xc0 'À' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x1f, /* 00011111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 193 0xc1 'Á' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 194 0xc2 'Â' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 195 0xc3 'Ã' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x1f, /* 00011111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 196 0xc4 'Ä' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 197 0xc5 'Å' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xff, /* 11111111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 198 0xc6 'Æ' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x1f, /* 00011111 */ - 0x18, /* 00011000 */ - 0x1f, /* 00011111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 199 0xc7 'Ç' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x37, /* 00110111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 200 0xc8 'È' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x37, /* 00110111 */ - 0x30, /* 00110000 */ - 0x3f, /* 00111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 201 0xc9 'É' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3f, /* 00111111 */ - 0x30, /* 00110000 */ - 0x37, /* 00110111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 202 0xca 'Ê' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xf7, /* 11110111 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 203 0xcb 'Ë' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0xf7, /* 11110111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 204 0xcc 'Ì' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x37, /* 00110111 */ - 0x30, /* 00110000 */ - 0x37, /* 00110111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 205 0xcd 'Í' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 206 0xce 'Î' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xf7, /* 11110111 */ - 0x00, /* 00000000 */ - 0xf7, /* 11110111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 207 0xcf 'Ï' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 208 0xd0 'Ð' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 209 0xd1 'Ñ' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 210 0xd2 'Ò' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 211 0xd3 'Ó' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x3f, /* 00111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 212 0xd4 'Ô' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x1f, /* 00011111 */ - 0x18, /* 00011000 */ - 0x1f, /* 00011111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 213 0xd5 'Õ' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1f, /* 00011111 */ - 0x18, /* 00011000 */ - 0x1f, /* 00011111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 214 0xd6 'Ö' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x3f, /* 00111111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 215 0xd7 '×' */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0xff, /* 11111111 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - - /* 216 0xd8 'Ø' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xff, /* 11111111 */ - 0x18, /* 00011000 */ - 0xff, /* 11111111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 217 0xd9 'Ù' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xf8, /* 11111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 218 0xda 'Ú' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1f, /* 00011111 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 219 0xdb 'Û' */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - - /* 220 0xdc 'Ü' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - - /* 221 0xdd 'Ý' */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - 0xf0, /* 11110000 */ - - /* 222 0xde 'Þ' */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - 0x0f, /* 00001111 */ - - /* 223 0xdf 'ß' */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0xff, /* 11111111 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 224 0xe0 'à' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0xdc, /* 11011100 */ - 0x76, /* 01110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 225 0xe1 'á' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x78, /* 01111000 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xcc, /* 11001100 */ - 0xd8, /* 11011000 */ - 0xcc, /* 11001100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xcc, /* 11001100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 226 0xe2 'â' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0xc0, /* 11000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 227 0xe3 'ã' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 228 0xe4 'ä' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 229 0xe5 'å' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0x70, /* 01110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 230 0xe6 'æ' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x7c, /* 01111100 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0xc0, /* 11000000 */ - 0x00, /* 00000000 */ - - /* 231 0xe7 'ç' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 232 0xe8 'è' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 233 0xe9 'é' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xfe, /* 11111110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 234 0xea 'ê' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0xee, /* 11101110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 235 0xeb 'ë' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1e, /* 00011110 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x3e, /* 00111110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x66, /* 01100110 */ - 0x3c, /* 00111100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 236 0xec 'ì' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0xdb, /* 11011011 */ - 0xdb, /* 11011011 */ - 0xdb, /* 11011011 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 237 0xed 'í' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x03, /* 00000011 */ - 0x06, /* 00000110 */ - 0x7e, /* 01111110 */ - 0xdb, /* 11011011 */ - 0xdb, /* 11011011 */ - 0xf3, /* 11110011 */ - 0x7e, /* 01111110 */ - 0x60, /* 01100000 */ - 0xc0, /* 11000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 238 0xee 'î' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x1c, /* 00011100 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x7c, /* 01111100 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x1c, /* 00011100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 239 0xef 'ï' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7c, /* 01111100 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0xc6, /* 11000110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 240 0xf0 'ð' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0xfe, /* 11111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 241 0xf1 'ñ' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x7e, /* 01111110 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 242 0xf2 'ò' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x06, /* 00000110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 243 0xf3 'ó' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x30, /* 00110000 */ - 0x60, /* 01100000 */ - 0x30, /* 00110000 */ - 0x18, /* 00011000 */ - 0x0c, /* 00001100 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 244 0xf4 'ô' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x0e, /* 00001110 */ - 0x1b, /* 00011011 */ - 0x1b, /* 00011011 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - - /* 245 0xf5 'õ' */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0xd8, /* 11011000 */ - 0x70, /* 01110000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 246 0xf6 'ö' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 247 0xf7 '÷' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0x00, /* 00000000 */ - 0x76, /* 01110110 */ - 0xdc, /* 11011100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 248 0xf8 'ø' */ - 0x00, /* 00000000 */ - 0x38, /* 00111000 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x38, /* 00111000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 249 0xf9 'ù' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 250 0xfa 'ú' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x18, /* 00011000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 251 0xfb 'û' */ - 0x00, /* 00000000 */ - 0x0f, /* 00001111 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0x0c, /* 00001100 */ - 0xec, /* 11101100 */ - 0x6c, /* 01101100 */ - 0x6c, /* 01101100 */ - 0x3c, /* 00111100 */ - 0x1c, /* 00011100 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 252 0xfc 'ü' */ - 0x00, /* 00000000 */ - 0x6c, /* 01101100 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x36, /* 00110110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 253 0xfd 'ý' */ - 0x00, /* 00000000 */ - 0x3c, /* 00111100 */ - 0x66, /* 01100110 */ - 0x0c, /* 00001100 */ - 0x18, /* 00011000 */ - 0x32, /* 00110010 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 254 0xfe 'þ' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x7e, /* 01111110 */ - 0x7e, /* 01111110 */ - 0x7e, /* 01111110 */ - 0x7e, /* 01111110 */ - 0x7e, /* 01111110 */ - 0x7e, /* 01111110 */ - 0x7e, /* 01111110 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - - /* 255 0xff 'ÿ' */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - 0x00, /* 00000000 */ - -}; - -#endif +#endif /* _VIDEO_FONT_ */ diff --git a/include/video_font_data.h b/include/video_font_data.h new file mode 100644 index 0000000..c7a8b9b --- /dev/null +++ b/include/video_font_data.h @@ -0,0 +1,4639 @@ +/* + * (C) Copyright 2000 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _VIDEO_FONT_DATA_ +#define _VIDEO_FONT_DATA_ + +static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { + + /* 0 0x00 '^@' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 1 0x01 '^A' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x81, /* 10000001 */ + 0xa5, /* 10100101 */ + 0x81, /* 10000001 */ + 0x81, /* 10000001 */ + 0xbd, /* 10111101 */ + 0x99, /* 10011001 */ + 0x81, /* 10000001 */ + 0x81, /* 10000001 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 2 0x02 '^B' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0xff, /* 11111111 */ + 0xdb, /* 11011011 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xc3, /* 11000011 */ + 0xe7, /* 11100111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 3 0x03 '^C' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x6c, /* 01101100 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0x7c, /* 01111100 */ + 0x38, /* 00111000 */ + 0x10, /* 00010000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 4 0x04 '^D' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x7c, /* 01111100 */ + 0xfe, /* 11111110 */ + 0x7c, /* 01111100 */ + 0x38, /* 00111000 */ + 0x10, /* 00010000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 5 0x05 '^E' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x3c, /* 00111100 */ + 0xe7, /* 11100111 */ + 0xe7, /* 11100111 */ + 0xe7, /* 11100111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 6 0x06 '^F' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x7e, /* 01111110 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 7 0x07 '^G' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 8 0x08 '^H' */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xe7, /* 11100111 */ + 0xc3, /* 11000011 */ + 0xc3, /* 11000011 */ + 0xe7, /* 11100111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + + /* 9 0x09 '^I' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0x42, /* 01000010 */ + 0x42, /* 01000010 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 10 0x0a '^J' */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xc3, /* 11000011 */ + 0x99, /* 10011001 */ + 0xbd, /* 10111101 */ + 0xbd, /* 10111101 */ + 0x99, /* 10011001 */ + 0xc3, /* 11000011 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + + /* 11 0x0b '^K' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1e, /* 00011110 */ + 0x0e, /* 00001110 */ + 0x1a, /* 00011010 */ + 0x32, /* 00110010 */ + 0x78, /* 01111000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x78, /* 01111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 12 0x0c '^L' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 13 0x0d '^M' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3f, /* 00111111 */ + 0x33, /* 00110011 */ + 0x3f, /* 00111111 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x70, /* 01110000 */ + 0xf0, /* 11110000 */ + 0xe0, /* 11100000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 14 0x0e '^N' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7f, /* 01111111 */ + 0x63, /* 01100011 */ + 0x7f, /* 01111111 */ + 0x63, /* 01100011 */ + 0x63, /* 01100011 */ + 0x63, /* 01100011 */ + 0x63, /* 01100011 */ + 0x67, /* 01100111 */ + 0xe7, /* 11100111 */ + 0xe6, /* 11100110 */ + 0xc0, /* 11000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 15 0x0f '^O' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xdb, /* 11011011 */ + 0x3c, /* 00111100 */ + 0xe7, /* 11100111 */ + 0x3c, /* 00111100 */ + 0xdb, /* 11011011 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 16 0x10 '^P' */ + 0x00, /* 00000000 */ + 0x80, /* 10000000 */ + 0xc0, /* 11000000 */ + 0xe0, /* 11100000 */ + 0xf0, /* 11110000 */ + 0xf8, /* 11111000 */ + 0xfe, /* 11111110 */ + 0xf8, /* 11111000 */ + 0xf0, /* 11110000 */ + 0xe0, /* 11100000 */ + 0xc0, /* 11000000 */ + 0x80, /* 10000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 17 0x11 '^Q' */ + 0x00, /* 00000000 */ + 0x02, /* 00000010 */ + 0x06, /* 00000110 */ + 0x0e, /* 00001110 */ + 0x1e, /* 00011110 */ + 0x3e, /* 00111110 */ + 0xfe, /* 11111110 */ + 0x3e, /* 00111110 */ + 0x1e, /* 00011110 */ + 0x0e, /* 00001110 */ + 0x06, /* 00000110 */ + 0x02, /* 00000010 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 18 0x12 '^R' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 19 0x13 '^S' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 20 0x14 '^T' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7f, /* 01111111 */ + 0xdb, /* 11011011 */ + 0xdb, /* 11011011 */ + 0xdb, /* 11011011 */ + 0x7b, /* 01111011 */ + 0x1b, /* 00011011 */ + 0x1b, /* 00011011 */ + 0x1b, /* 00011011 */ + 0x1b, /* 00011011 */ + 0x1b, /* 00011011 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 21 0x15 '^U' */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0x60, /* 01100000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x0c, /* 00001100 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 22 0x16 '^V' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 23 0x17 '^W' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 24 0x18 '^X' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 25 0x19 '^Y' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 26 0x1a '^Z' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0xfe, /* 11111110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 27 0x1b '^[' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xfe, /* 11111110 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 28 0x1c '^' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 29 0x1d '^]' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x28, /* 00101000 */ + 0x6c, /* 01101100 */ + 0xfe, /* 11111110 */ + 0x6c, /* 01101100 */ + 0x28, /* 00101000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 30 0x1e '^^' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x38, /* 00111000 */ + 0x7c, /* 01111100 */ + 0x7c, /* 01111100 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 31 0x1f '^_' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0x7c, /* 01111100 */ + 0x7c, /* 01111100 */ + 0x38, /* 00111000 */ + 0x38, /* 00111000 */ + 0x10, /* 00010000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 32 0x20 ' ' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 33 0x21 '!' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x3c, /* 00111100 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 34 0x22 '"' */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x24, /* 00100100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 35 0x23 '#' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0xfe, /* 11111110 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0xfe, /* 11111110 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 36 0x24 '$' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc2, /* 11000010 */ + 0xc0, /* 11000000 */ + 0x7c, /* 01111100 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x86, /* 10000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 37 0x25 '%' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc2, /* 11000010 */ + 0xc6, /* 11000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xc6, /* 11000110 */ + 0x86, /* 10000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 38 0x26 '&' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 39 0x27 ''' */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 40 0x28 '(' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 41 0x29 ')' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 42 0x2a '*' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0xff, /* 11111111 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 43 0x2b '+' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 44 0x2c ',' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 45 0x2d '-' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 46 0x2e '.' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 47 0x2f '/' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x02, /* 00000010 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xc0, /* 11000000 */ + 0x80, /* 10000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 48 0x30 '0' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 49 0x31 '1' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x38, /* 00111000 */ + 0x78, /* 01111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 50 0x32 '2' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 51 0x33 '3' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x3c, /* 00111100 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 52 0x34 '4' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x0c, /* 00001100 */ + 0x1c, /* 00011100 */ + 0x3c, /* 00111100 */ + 0x6c, /* 01101100 */ + 0xcc, /* 11001100 */ + 0xfe, /* 11111110 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x1e, /* 00011110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 53 0x35 '5' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xfc, /* 11111100 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 54 0x36 '6' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x60, /* 01100000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xfc, /* 11111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 55 0x37 '7' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 56 0x38 '8' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 57 0x39 '9' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7e, /* 01111110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x78, /* 01111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 58 0x3a ':' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 59 0x3b ';' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 60 0x3c '<' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x06, /* 00000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 61 0x3d '=' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 62 0x3e '>' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 63 0x3f '?' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 64 0x40 '@' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xde, /* 11011110 */ + 0xde, /* 11011110 */ + 0xde, /* 11011110 */ + 0xdc, /* 11011100 */ + 0xc0, /* 11000000 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 65 0x41 'A' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 66 0x42 'B' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfc, /* 11111100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x7c, /* 01111100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0xfc, /* 11111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 67 0x43 'C' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0xc2, /* 11000010 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc2, /* 11000010 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 68 0x44 'D' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xf8, /* 11111000 */ + 0x6c, /* 01101100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x6c, /* 01101100 */ + 0xf8, /* 11111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 69 0x45 'E' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x66, /* 01100110 */ + 0x62, /* 01100010 */ + 0x68, /* 01101000 */ + 0x78, /* 01111000 */ + 0x68, /* 01101000 */ + 0x60, /* 01100000 */ + 0x62, /* 01100010 */ + 0x66, /* 01100110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 70 0x46 'F' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x66, /* 01100110 */ + 0x62, /* 01100010 */ + 0x68, /* 01101000 */ + 0x78, /* 01111000 */ + 0x68, /* 01101000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0xf0, /* 11110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 71 0x47 'G' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0xc2, /* 11000010 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xde, /* 11011110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x66, /* 01100110 */ + 0x3a, /* 00111010 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 72 0x48 'H' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 73 0x49 'I' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 74 0x4a 'J' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1e, /* 00011110 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x78, /* 01111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 75 0x4b 'K' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xe6, /* 11100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x6c, /* 01101100 */ + 0x78, /* 01111000 */ + 0x78, /* 01111000 */ + 0x6c, /* 01101100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0xe6, /* 11100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 76 0x4c 'L' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xf0, /* 11110000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x62, /* 01100010 */ + 0x66, /* 01100110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 77 0x4d 'M' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xee, /* 11101110 */ + 0xfe, /* 11111110 */ + 0xfe, /* 11111110 */ + 0xd6, /* 11010110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 78 0x4e 'N' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xe6, /* 11100110 */ + 0xf6, /* 11110110 */ + 0xfe, /* 11111110 */ + 0xde, /* 11011110 */ + 0xce, /* 11001110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 79 0x4f 'O' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 80 0x50 'P' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfc, /* 11111100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x7c, /* 01111100 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0xf0, /* 11110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 81 0x51 'Q' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xd6, /* 11010110 */ + 0xde, /* 11011110 */ + 0x7c, /* 01111100 */ + 0x0c, /* 00001100 */ + 0x0e, /* 00001110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 82 0x52 'R' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfc, /* 11111100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x7c, /* 01111100 */ + 0x6c, /* 01101100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0xe6, /* 11100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 83 0x53 'S' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x60, /* 01100000 */ + 0x38, /* 00111000 */ + 0x0c, /* 00001100 */ + 0x06, /* 00000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 84 0x54 'T' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x7e, /* 01111110 */ + 0x5a, /* 01011010 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 85 0x55 'U' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 86 0x56 'V' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x10, /* 00010000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 87 0x57 'W' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xfe, /* 11111110 */ + 0xee, /* 11101110 */ + 0x6c, /* 01101100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 88 0x58 'X' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x7c, /* 01111100 */ + 0x38, /* 00111000 */ + 0x38, /* 00111000 */ + 0x7c, /* 01111100 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 89 0x59 'Y' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 90 0x5a 'Z' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0x86, /* 10000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xc2, /* 11000010 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 91 0x5b '[' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 92 0x5c '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x80, /* 10000000 */ + 0xc0, /* 11000000 */ + 0xe0, /* 11100000 */ + 0x70, /* 01110000 */ + 0x38, /* 00111000 */ + 0x1c, /* 00011100 */ + 0x0e, /* 00001110 */ + 0x06, /* 00000110 */ + 0x02, /* 00000010 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 93 0x5d ']' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 94 0x5e '^' */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 95 0x5f '_' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 96 0x60 '`' */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 97 0x61 'a' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x78, /* 01111000 */ + 0x0c, /* 00001100 */ + 0x7c, /* 01111100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 98 0x62 'b' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xe0, /* 11100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x78, /* 01111000 */ + 0x6c, /* 01101100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 99 0x63 'c' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 100 0x64 'd' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1c, /* 00011100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x3c, /* 00111100 */ + 0x6c, /* 01101100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 101 0x65 'e' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 102 0x66 'f' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1c, /* 00011100 */ + 0x36, /* 00110110 */ + 0x32, /* 00110010 */ + 0x30, /* 00110000 */ + 0x78, /* 01111000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x78, /* 01111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 103 0x67 'g' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x7c, /* 01111100 */ + 0x0c, /* 00001100 */ + 0xcc, /* 11001100 */ + 0x78, /* 01111000 */ + 0x00, /* 00000000 */ + + /* 104 0x68 'h' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xe0, /* 11100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x6c, /* 01101100 */ + 0x76, /* 01110110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0xe6, /* 11100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 105 0x69 'i' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 106 0x6a 'j' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x00, /* 00000000 */ + 0x0e, /* 00001110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + + /* 107 0x6b 'k' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xe0, /* 11100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x66, /* 01100110 */ + 0x6c, /* 01101100 */ + 0x78, /* 01111000 */ + 0x78, /* 01111000 */ + 0x6c, /* 01101100 */ + 0x66, /* 01100110 */ + 0xe6, /* 11100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 108 0x6c 'l' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 109 0x6d 'm' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xec, /* 11101100 */ + 0xfe, /* 11111110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 110 0x6e 'n' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xdc, /* 11011100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 111 0x6f 'o' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 112 0x70 'p' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xdc, /* 11011100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x7c, /* 01111100 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0xf0, /* 11110000 */ + 0x00, /* 00000000 */ + + /* 113 0x71 'q' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x7c, /* 01111100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x1e, /* 00011110 */ + 0x00, /* 00000000 */ + + /* 114 0x72 'r' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xdc, /* 11011100 */ + 0x76, /* 01110110 */ + 0x66, /* 01100110 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0xf0, /* 11110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 115 0x73 's' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0x60, /* 01100000 */ + 0x38, /* 00111000 */ + 0x0c, /* 00001100 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 116 0x74 't' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0xfc, /* 11111100 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x36, /* 00110110 */ + 0x1c, /* 00011100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 117 0x75 'u' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 118 0x76 'v' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 119 0x77 'w' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xd6, /* 11010110 */ + 0xfe, /* 11111110 */ + 0x6c, /* 01101100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 120 0x78 'x' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x38, /* 00111000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 121 0x79 'y' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7e, /* 01111110 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0xf8, /* 11111000 */ + 0x00, /* 00000000 */ + + /* 122 0x7a 'z' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xcc, /* 11001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 123 0x7b '{' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x0e, /* 00001110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x70, /* 01110000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x0e, /* 00001110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 124 0x7c '|' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 125 0x7d '}' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x70, /* 01110000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x0e, /* 00001110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x70, /* 01110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 126 0x7e '~' */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 127 0x7f '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 128 0x80 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0xc2, /* 11000010 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc2, /* 11000010 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x70, /* 01110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 129 0x81 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xcc, /* 11001100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 130 0x82 '' */ + 0x00, /* 00000000 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 131 0x83 '' */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x00, /* 00000000 */ + 0x78, /* 01111000 */ + 0x0c, /* 00001100 */ + 0x7c, /* 01111100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 132 0x84 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xcc, /* 11001100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x78, /* 01111000 */ + 0x0c, /* 00001100 */ + 0x7c, /* 01111100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 133 0x85 ' ' */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x78, /* 01111000 */ + 0x0c, /* 00001100 */ + 0x7c, /* 01111100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 134 0x86 '' */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x00, /* 00000000 */ + 0x78, /* 01111000 */ + 0x0c, /* 00001100 */ + 0x7c, /* 01111100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 135 0x87 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x18, /* 00011000 */ + 0x70, /* 01110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 136 0x88 '' */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 137 0x89 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 138 0x8a '' */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 139 0x8b '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 140 0x8c '' */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 141 0x8d '' */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 142 0x8e '' */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 143 0x8f '' */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 144 0x90 '' */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x66, /* 01100110 */ + 0x62, /* 01100010 */ + 0x68, /* 01101000 */ + 0x78, /* 01111000 */ + 0x68, /* 01101000 */ + 0x62, /* 01100010 */ + 0x66, /* 01100110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 145 0x91 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xec, /* 11101100 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x7e, /* 01111110 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0x6e, /* 01101110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 146 0x92 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3e, /* 00111110 */ + 0x6c, /* 01101100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xfe, /* 11111110 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xce, /* 11001110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 147 0x93 '' */ + 0x00, /* 00000000 */ + 0x10, /* 00010000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 148 0x94 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 149 0x95 '' */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 150 0x96 '' */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x78, /* 01111000 */ + 0xcc, /* 11001100 */ + 0x00, /* 00000000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 151 0x97 '' */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 152 0x98 '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7e, /* 01111110 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x78, /* 01111000 */ + 0x00, /* 00000000 */ + + /* 153 0x99 '' */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 154 0x9a '' */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 155 0x9b '' */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 156 0x9c '' */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x64, /* 01100100 */ + 0x60, /* 01100000 */ + 0xf0, /* 11110000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0xe6, /* 11100110 */ + 0xfc, /* 11111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 157 0x9d '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 158 0x9e '' */ + 0x00, /* 00000000 */ + 0xf8, /* 11111000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xf8, /* 11111000 */ + 0xc4, /* 11000100 */ + 0xcc, /* 11001100 */ + 0xde, /* 11011110 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 159 0x9f '' */ + 0x00, /* 00000000 */ + 0x0e, /* 00001110 */ + 0x1b, /* 00011011 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xd8, /* 11011000 */ + 0x70, /* 01110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 160 0xa0 ' ' */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x00, /* 00000000 */ + 0x78, /* 01111000 */ + 0x0c, /* 00001100 */ + 0x7c, /* 01111100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 161 0xa1 '¡' */ + 0x00, /* 00000000 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 162 0xa2 '¢' */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 163 0xa3 '£' */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x00, /* 00000000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 164 0xa4 '€' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0x00, /* 00000000 */ + 0xdc, /* 11011100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 165 0xa5 '¥' */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0x00, /* 00000000 */ + 0xc6, /* 11000110 */ + 0xe6, /* 11100110 */ + 0xf6, /* 11110110 */ + 0xfe, /* 11111110 */ + 0xde, /* 11011110 */ + 0xce, /* 11001110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 166 0xa6 'Š' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x3e, /* 00111110 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 167 0xa7 '§' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 168 0xa8 'š' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xc0, /* 11000000 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x7c, /* 01111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 169 0xa9 '©' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 170 0xaa 'ª' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 171 0xab '«' */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0xe0, /* 11100000 */ + 0x62, /* 01100010 */ + 0x66, /* 01100110 */ + 0x6c, /* 01101100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xdc, /* 11011100 */ + 0x86, /* 10000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x3e, /* 00111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 172 0xac '¬' */ + 0x00, /* 00000000 */ + 0x60, /* 01100000 */ + 0xe0, /* 11100000 */ + 0x62, /* 01100010 */ + 0x66, /* 01100110 */ + 0x6c, /* 01101100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x66, /* 01100110 */ + 0xce, /* 11001110 */ + 0x9a, /* 10011010 */ + 0x3f, /* 00111111 */ + 0x06, /* 00000110 */ + 0x06, /* 00000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 173 0xad '' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x3c, /* 00111100 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 174 0xae '®' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x36, /* 00110110 */ + 0x6c, /* 01101100 */ + 0xd8, /* 11011000 */ + 0x6c, /* 01101100 */ + 0x36, /* 00110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 175 0xaf '¯' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xd8, /* 11011000 */ + 0x6c, /* 01101100 */ + 0x36, /* 00110110 */ + 0x6c, /* 01101100 */ + 0xd8, /* 11011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 176 0xb0 '°' */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + 0x11, /* 00010001 */ + 0x44, /* 01000100 */ + + /* 177 0xb1 '±' */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + 0x55, /* 01010101 */ + 0xaa, /* 10101010 */ + + /* 178 0xb2 '²' */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + 0xdd, /* 11011101 */ + 0x77, /* 01110111 */ + + /* 179 0xb3 '³' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 180 0xb4 'Ž' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xf8, /* 11111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 181 0xb5 'µ' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xf8, /* 11111000 */ + 0x18, /* 00011000 */ + 0xf8, /* 11111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 182 0xb6 '¶' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xf6, /* 11110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 183 0xb7 '·' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 184 0xb8 'ž' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xf8, /* 11111000 */ + 0x18, /* 00011000 */ + 0xf8, /* 11111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 185 0xb9 '¹' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xf6, /* 11110110 */ + 0x06, /* 00000110 */ + 0xf6, /* 11110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 186 0xba 'º' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 187 0xbb '»' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x06, /* 00000110 */ + 0xf6, /* 11110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 188 0xbc 'Œ' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xf6, /* 11110110 */ + 0x06, /* 00000110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 189 0xbd 'œ' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 190 0xbe 'Ÿ' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xf8, /* 11111000 */ + 0x18, /* 00011000 */ + 0xf8, /* 11111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 191 0xbf '¿' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xf8, /* 11111000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 192 0xc0 'À' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x1f, /* 00011111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 193 0xc1 'Á' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 194 0xc2 'Â' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 195 0xc3 'Ã' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x1f, /* 00011111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 196 0xc4 'Ä' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 197 0xc5 'Å' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xff, /* 11111111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 198 0xc6 'Æ' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x1f, /* 00011111 */ + 0x18, /* 00011000 */ + 0x1f, /* 00011111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 199 0xc7 'Ç' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x37, /* 00110111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 200 0xc8 'È' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x37, /* 00110111 */ + 0x30, /* 00110000 */ + 0x3f, /* 00111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 201 0xc9 'É' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3f, /* 00111111 */ + 0x30, /* 00110000 */ + 0x37, /* 00110111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 202 0xca 'Ê' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xf7, /* 11110111 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 203 0xcb 'Ë' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0xf7, /* 11110111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 204 0xcc 'Ì' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x37, /* 00110111 */ + 0x30, /* 00110000 */ + 0x37, /* 00110111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 205 0xcd 'Í' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 206 0xce 'Î' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xf7, /* 11110111 */ + 0x00, /* 00000000 */ + 0xf7, /* 11110111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 207 0xcf 'Ï' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 208 0xd0 'Ð' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 209 0xd1 'Ñ' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 210 0xd2 'Ò' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 211 0xd3 'Ó' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x3f, /* 00111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 212 0xd4 'Ô' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x1f, /* 00011111 */ + 0x18, /* 00011000 */ + 0x1f, /* 00011111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 213 0xd5 'Õ' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1f, /* 00011111 */ + 0x18, /* 00011000 */ + 0x1f, /* 00011111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 214 0xd6 'Ö' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x3f, /* 00111111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 215 0xd7 '×' */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0xff, /* 11111111 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + + /* 216 0xd8 'Ø' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xff, /* 11111111 */ + 0x18, /* 00011000 */ + 0xff, /* 11111111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 217 0xd9 'Ù' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xf8, /* 11111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 218 0xda 'Ú' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1f, /* 00011111 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 219 0xdb 'Û' */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + + /* 220 0xdc 'Ü' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + + /* 221 0xdd 'Ý' */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + 0xf0, /* 11110000 */ + + /* 222 0xde 'Þ' */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + 0x0f, /* 00001111 */ + + /* 223 0xdf 'ß' */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0xff, /* 11111111 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 224 0xe0 'à' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0xdc, /* 11011100 */ + 0x76, /* 01110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 225 0xe1 'á' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x78, /* 01111000 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xcc, /* 11001100 */ + 0xd8, /* 11011000 */ + 0xcc, /* 11001100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xcc, /* 11001100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 226 0xe2 'â' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0xc0, /* 11000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 227 0xe3 'ã' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 228 0xe4 'ä' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 229 0xe5 'å' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0x70, /* 01110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 230 0xe6 'æ' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x7c, /* 01111100 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0xc0, /* 11000000 */ + 0x00, /* 00000000 */ + + /* 231 0xe7 'ç' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 232 0xe8 'è' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 233 0xe9 'é' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xfe, /* 11111110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 234 0xea 'ê' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0xee, /* 11101110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 235 0xeb 'ë' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1e, /* 00011110 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x3e, /* 00111110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x66, /* 01100110 */ + 0x3c, /* 00111100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 236 0xec 'ì' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0xdb, /* 11011011 */ + 0xdb, /* 11011011 */ + 0xdb, /* 11011011 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 237 0xed 'í' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x03, /* 00000011 */ + 0x06, /* 00000110 */ + 0x7e, /* 01111110 */ + 0xdb, /* 11011011 */ + 0xdb, /* 11011011 */ + 0xf3, /* 11110011 */ + 0x7e, /* 01111110 */ + 0x60, /* 01100000 */ + 0xc0, /* 11000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 238 0xee 'î' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x1c, /* 00011100 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x7c, /* 01111100 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x1c, /* 00011100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 239 0xef 'ï' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7c, /* 01111100 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0xc6, /* 11000110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 240 0xf0 'ð' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0xfe, /* 11111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 241 0xf1 'ñ' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x7e, /* 01111110 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 242 0xf2 'ò' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x06, /* 00000110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 243 0xf3 'ó' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x30, /* 00110000 */ + 0x60, /* 01100000 */ + 0x30, /* 00110000 */ + 0x18, /* 00011000 */ + 0x0c, /* 00001100 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 244 0xf4 'ô' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x0e, /* 00001110 */ + 0x1b, /* 00011011 */ + 0x1b, /* 00011011 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + + /* 245 0xf5 'õ' */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0xd8, /* 11011000 */ + 0x70, /* 01110000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 246 0xf6 'ö' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 247 0xf7 '÷' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0x00, /* 00000000 */ + 0x76, /* 01110110 */ + 0xdc, /* 11011100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 248 0xf8 'ø' */ + 0x00, /* 00000000 */ + 0x38, /* 00111000 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x38, /* 00111000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 249 0xf9 'ù' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 250 0xfa 'ú' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x18, /* 00011000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 251 0xfb 'û' */ + 0x00, /* 00000000 */ + 0x0f, /* 00001111 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0x0c, /* 00001100 */ + 0xec, /* 11101100 */ + 0x6c, /* 01101100 */ + 0x6c, /* 01101100 */ + 0x3c, /* 00111100 */ + 0x1c, /* 00011100 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 252 0xfc 'ü' */ + 0x00, /* 00000000 */ + 0x6c, /* 01101100 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x36, /* 00110110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 253 0xfd 'ý' */ + 0x00, /* 00000000 */ + 0x3c, /* 00111100 */ + 0x66, /* 01100110 */ + 0x0c, /* 00001100 */ + 0x18, /* 00011000 */ + 0x32, /* 00110010 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 254 0xfe 'þ' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x7e, /* 01111110 */ + 0x7e, /* 01111110 */ + 0x7e, /* 01111110 */ + 0x7e, /* 01111110 */ + 0x7e, /* 01111110 */ + 0x7e, /* 01111110 */ + 0x7e, /* 01111110 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + + /* 255 0xff 'ÿ' */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + 0x00, /* 00000000 */ + +}; + +#endif
Acked-by: Mike Frysinger vapier@gentoo.org -mike
On Fri, 21 Oct 2011 17:04:21 +0800 Che-Liang Chiou clchiou@chromium.org wrote: ...
include/video_font.h | 4614 +-------------------------------------- include/video_font_data.h | 4639 +++++++++++++++++++++++++++++++++++++++ 7 files changed, 4647 insertions(+), 4614 deletions(-) create mode 100644 include/video_font_data.h
Please next time additionally use '-C' Option for 'git format-patch ...' when generating patches with code movement. It will produce smaller patches, e.g.: ... include/video_font.h | 4614 +-------------------------- include/{video_font.h => video_font_data.h} | 9 +- 7 files changed, 10 insertions(+), 4621 deletions(-) copy include/{video_font.h => video_font_data.h} (99%)
But you do not have to resubmit this patch, I think.
Thanks, Anatolij
Thanks for the advice. I will add -C option.
Regards, Che-Liang
While video_font.h is useful even without referencing the font data, it is not possible to be included multiple times because it defines font data array right in the header.
This patch splits the font data array into video_font_data.h and so now video_font.h can be included multiple times. This at least solves the code duplication in board/mcc200/lcd.c.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org
Changes in V5 Split font arrays from video_font.h to video_font_data.h
arch/powerpc/cpu/mpc8xx/video.c | 1 + board/mcc200/lcd.c | 4 +- common/lcd.c | 1 + drivers/video/cfb_console.c | 1 + drivers/video/sed156x.c | 1 + include/video_font.h | 4614 +-------------------------------------- include/video_font_data.h | 4639 +++++++++++++++++++++++++++++++++++++++ 7 files changed, 4647 insertions(+), 4614 deletions(-) create mode 100644 include/video_font_data.h
Applied to u-boot-video/master, thanks.
Anatolij
This patch exports LCD info-query and bitmap-rendering functions to external apps.
This patch is tested on a Seaboard. Because the LCD driver is not yet upstreamed, the test was done in a local downstream repo.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org ---
Changes in V5 Clean up logic
Changes in V4 Remove support of video device, which is untested and will leave to future work
Changes in V3 Rebase to ToT
Changes in V2 Fix style errors
api/Makefile | 3 +- api/api.c | 47 +++++++++++++++++++++++++++++++ api/api_display.c | 74 ++++++++++++++++++++++++++++++++++++++++++++++++++ api/api_private.h | 4 +++ examples/api/demo.c | 31 +++++++++++++++++++++ examples/api/glue.c | 31 +++++++++++++++++++++ examples/api/glue.h | 5 +++ include/api_public.h | 16 +++++++++++ 8 files changed, 210 insertions(+), 1 deletions(-) create mode 100644 api/api_display.c
diff --git a/api/Makefile b/api/Makefile index 2a64c4d..0e99f74 100644 --- a/api/Makefile +++ b/api/Makefile @@ -24,7 +24,8 @@ include $(TOPDIR)/config.mk
LIB = $(obj)libapi.o
-COBJS-$(CONFIG_API) += api.o api_net.o api_storage.o api_platform-$(ARCH).o +COBJS-$(CONFIG_API) += api.o api_display.o api_net.o api_storage.o \ + api_platform-$(ARCH).o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/api/api.c b/api/api.c index 853f010..a3bf60a 100644 --- a/api/api.c +++ b/api/api.c @@ -553,6 +553,50 @@ static int API_env_enum(va_list ap) return 0; }
+/* + * pseudo signature: + * + * int API_display_get_info(int type, struct display_info *di) + */ +static int API_display_get_info(va_list ap) +{ + int type; + struct display_info *di; + + type = va_arg(ap, int); + di = va_arg(ap, struct display_info *); + + return display_get_info(type, di); +} + +/* + * pseudo signature: + * + * int API_display_draw_bitmap(ulong bitmap, int x, int y) + */ +static int API_display_draw_bitmap(va_list ap) +{ + ulong bitmap; + int x, y; + + bitmap = va_arg(ap, ulong); + x = va_arg(ap, int); + y = va_arg(ap, int); + + return display_draw_bitmap(bitmap, x, y); +} + +/* + * pseudo signature: + * + * void API_display_clear(void) + */ +static int API_display_clear(va_list ap) +{ + display_clear(); + return 0; +} + static cfp_t calls_table[API_MAXCALL] = { NULL, };
/* @@ -616,6 +660,9 @@ void api_init(void) calls_table[API_ENV_GET] = &API_env_get; calls_table[API_ENV_SET] = &API_env_set; calls_table[API_ENV_ENUM] = &API_env_enum; + calls_table[API_DISPLAY_GET_INFO] = &API_display_get_info; + calls_table[API_DISPLAY_DRAW_BITMAP] = &API_display_draw_bitmap; + calls_table[API_DISPLAY_CLEAR] = &API_display_clear; calls_no = API_MAXCALL;
debugf("API initialized with %d calls\n", calls_no); diff --git a/api/api_display.c b/api/api_display.c new file mode 100644 index 0000000..6439170 --- /dev/null +++ b/api/api_display.c @@ -0,0 +1,74 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <api_public.h> +#include <lcd.h> +#include <video_font.h> /* Get font width and height */ + +/* lcd.h needs BMP_LOGO_HEIGHT to calculate CONSOLE_ROWS */ +#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) +#include <bmp_logo.h> +#endif + +/* TODO(clchiou): add support of video device */ + +int display_get_info(int type, struct display_info *di) +{ + if (!di) + return API_EINVAL; + + switch (type) { + default: + debug("%s: unsupport display device type: %d\n", + __FILE__, type); + return API_ENODEV; +#ifdef CONFIG_LCD + case DISPLAY_TYPE_LCD: + di->pixel_width = panel_info.vl_col; + di->pixel_height = panel_info.vl_row; + di->screen_rows = CONSOLE_ROWS; + di->screen_cols = CONSOLE_COLS; + break; +#endif + } + + di->type = type; + return 0; +} + +int display_draw_bitmap(ulong bitmap, int x, int y) +{ + if (!bitmap) + return API_EINVAL; +#ifdef CONFIG_LCD + return lcd_display_bitmap(bitmap, x, y); +#else + return API_ENODEV; +#endif +} + +void display_clear(void) +{ +#ifdef CONFIG_LCD + lcd_clear(); +#endif +} diff --git a/api/api_private.h b/api/api_private.h index 94a7fc5..988f702 100644 --- a/api/api_private.h +++ b/api/api_private.h @@ -45,4 +45,8 @@ int dev_write_net(void *, void *, int);
void dev_stor_init(void);
+int display_get_info(int type, struct display_info *di); +int display_draw_bitmap(ulong bitmap, int x, int y); +void display_clear(void); + #endif /* _API_PRIVATE_H_ */ diff --git a/examples/api/demo.c b/examples/api/demo.c index 65e7491..19d38f6 100644 --- a/examples/api/demo.c +++ b/examples/api/demo.c @@ -48,6 +48,7 @@ int main(int argc, char * const argv[]) ulong start, now; struct device_info *di; lbasize_t rlen; + struct display_info disinfo;
if (!api_search_sig(&sig)) return -1; @@ -176,6 +177,36 @@ int main(int argc, char * const argv[]) while ((env = ub_env_enum(env)) != NULL) printf("%s = %s\n", env, ub_env_get(env));
+ printf("\n*** Display ***\n"); + + if (ub_display_get_info(DISPLAY_TYPE_LCD, &disinfo)) { + printf("LCD info: failed\n"); + } else { + printf("LCD info:\n"); + printf(" pixel width: %d\n", disinfo.pixel_width); + printf(" pixel height: %d\n", disinfo.pixel_height); + printf(" screen rows: %d\n", disinfo.screen_rows); + printf(" screen cols: %d\n", disinfo.screen_cols); + } + if (ub_display_get_info(DISPLAY_TYPE_VIDEO, &disinfo)) { + printf("video info: failed\n"); + } else { + printf("video info:\n"); + printf(" pixel width: %d\n", disinfo.pixel_width); + printf(" pixel height: %d\n", disinfo.pixel_height); + printf(" screen rows: %d\n", disinfo.screen_rows); + printf(" screen cols: %d\n", disinfo.screen_cols); + } + + printf("*** Press any key to continue ***\n"); + printf("got char 0x%x\n", ub_getc()); + + /* + * This only clears messages on screen, not on serial port. It is + * equivalent to a no-op if no display is available. + */ + ub_display_clear(); + /* reset */ printf("\n*** Resetting board ***\n"); ub_reset(); diff --git a/examples/api/glue.c b/examples/api/glue.c index eff6a7e..d907e3f 100644 --- a/examples/api/glue.c +++ b/examples/api/glue.c @@ -402,3 +402,34 @@ const char * ub_env_enum(const char *last)
return env_name; } + +/**************************************** + * + * display + * + ****************************************/ + +int ub_display_get_info(int type, struct display_info *di) +{ + int err = 0; + + if (!syscall(API_DISPLAY_GET_INFO, &err, (uint32_t)type, (uint32_t)di)) + return API_ESYSC; + + return err; +} + +int ub_display_draw_bitmap(ulong bitmap, int x, int y) +{ + int err = 0; + + if (!syscall(API_DISPLAY_DRAW_BITMAP, &err, bitmap, x, y)) + return API_ESYSC; + + return err; +} + +void ub_display_clear(void) +{ + syscall(API_DISPLAY_CLEAR, NULL); +} diff --git a/examples/api/glue.h b/examples/api/glue.h index 6bf47d0..e43f7d9 100644 --- a/examples/api/glue.h +++ b/examples/api/glue.h @@ -77,4 +77,9 @@ int ub_dev_send(int handle, void *buf, int len); int ub_dev_recv(int handle, void *buf, int len, int *rlen); struct device_info * ub_dev_get(int);
+/* display */ +int ub_display_get_info(int type, struct display_info *di); +int ub_display_draw_bitmap(ulong bitmap, int x, int y); +void ub_display_clear(void); + #endif /* _API_GLUE_H_ */ diff --git a/include/api_public.h b/include/api_public.h index 5940d81..4420c99 100644 --- a/include/api_public.h +++ b/include/api_public.h @@ -90,6 +90,9 @@ enum { API_ENV_ENUM, API_ENV_GET, API_ENV_SET, + API_DISPLAY_GET_INFO, + API_DISPLAY_DRAW_BITMAP, + API_DISPLAY_CLEAR, API_MAXCALL };
@@ -152,4 +155,17 @@ struct device_info { int state; };
+#define DISPLAY_TYPE_LCD 0x0001 +#define DISPLAY_TYPE_VIDEO 0x0002 + +struct display_info { + int type; + /* screen size in pixels */ + int pixel_width; + int pixel_height; + /* screen size in rows and columns of text */ + int screen_rows; + int screen_cols; +}; + #endif /* _API_PUBLIC_H_ */
On Fri, 21 Oct 2011 17:04:22 +0800 Che-Liang Chiou clchiou@chromium.org wrote:
Anatolij
The functions for clearing and drawing bitmaps on the screen were not exposed publicly and are made public in this patch in preparation for implementing the display interface of api_public.h.
Changes in V5 Remove inline extern declaration from cmd_bmp.c
common/cmd_bmp.c | 4 +--- common/lcd.c | 14 ++++++++++---- include/lcd.h | 2 ++ 3 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/common/cmd_bmp.c b/common/cmd_bmp.c index 23fc82f..682f395 100644 --- a/common/cmd_bmp.c +++ b/common/cmd_bmp.c @@ -237,9 +237,7 @@ static int bmp_display(ulong addr, int x, int y) }
#if defined(CONFIG_LCD) - extern int lcd_display_bitmap (ulong, int, int); - - ret = lcd_display_bitmap ((unsigned long)bmp, x, y); + ret = lcd_display_bitmap((ulong)bmp, x, y); #elif defined(CONFIG_VIDEO) extern int video_display_bitmap (ulong, int, int);
diff --git a/common/lcd.c b/common/lcd.c index d9cb8ca..6d91310 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -353,7 +353,14 @@ int drv_lcd_init (void) }
/*----------------------------------------------------------------------*/ -static int lcd_clear (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) +static +int do_lcd_clear(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + lcd_clear(); + return 0; +} + +void lcd_clear(void) { #if LCD_BPP == LCD_MONOCHROME /* Setting the palette */ @@ -413,7 +419,7 @@ static int lcd_init (void *lcdbase)
lcd_ctrl_init (lcdbase); lcd_is_enabled = 1; - lcd_clear (NULL, 1, 1, NULL); /* dummy args */ + lcd_clear(); lcd_enable ();
/* Initialize the console */ diff --git a/include/lcd.h b/include/lcd.h index 0e098d9..39af14a 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -210,6 +210,8 @@ void lcd_disable (void); void lcd_putc (const char c); void lcd_puts (const char *s); void lcd_printf (const char *fmt, ...); +void lcd_clear(void); +int lcd_display_bitmap(ulong bmp_image, int x, int y);
/* Allow boards to customize the information displayed */ void lcd_show_board_info(void);
seems like you sent out the same patch a few min before this. was this posting an accident ? -mike
participants (5)
Anatolij Gustschin
Che-Liang Chiou
Che-liang Chiou
Mike Frysinger
