[U-Boot-Users] MIPS (purple) compilation problems.
Hi
I'm trying to port the U-Boot to Marvell board with MIPS (rm7000) I am using a cross compiler mips64-elf. I'm trying to compile the purpule_config and I have some compilation problems, when I'm using the cpu/mips/config flag -mabicalls I get a lot of warnings: c1: warning: -G is incompatible with PIC code which is the default ......... and an LD error: mips64-elf-ld: common/main.o: linking PIC files with non-PIC files Bad value: failed to merge target specific data of file common/main.o
When I remove the -mabicalls flag, the compilation pass, and the LD fail again on different error: mips64-elf-ld: target elf32-tradbigmips not found
The LD is looking for elf32-tradbigmips because in the LD script we define the output file to be: elf32-tradbigmips
why do we use this definition and not elf32-bigmips?? and what is the difference between these two?? and why when I install my cross compiler I don't have support for this output format??
so I changed it the output format to elf32-bigmips then I'm getting this LD error: : undefined reference to `_GLOBAL_OFFSET_TABLE_'
I know it is because I don't have this define in the linker script, and I guess the elf32-tradbigmips has this definition. What should I do??
Thanks
Hi
I'm trying to port the U-Boot to Marvell board with MIPS (rm7000) I see that after relocating to the DRAM the disassembly of the u-boot shows me that we jump back to the flash: start.S: dis: la t9,board_init_r lui t9,0xbfc1 addiu t9,20140 j t9 jr t9
I see that I get the same problem when I jump to printf etc. maybe it is because I don't compile the code as PIC? Is there any special compilation flag I should use? Can someone please send me a disassembly of the U-Boot for any of the MIPS board (purple, incaip or dbaux100).
Is there any special handle for relocating of the MIPS that is different from the PPC, that I should take under consideration???
Thanks Ronen
Ronen Shitrit wrote:
Hi
Thanks
In your Subject: you write: MIPS (purple) compilation problems. I cannot see any relation to the Infineon Purple board here??
What did you disassemble? The code in RAM?
This cannot work. This is what I see for the "purple" board:
... move a0, a1 564: 00a02021 move a0,a1 la t9, board_init_r 568: 8f990000 lw t9,0(gp) j t9 56c: 03200008 jr t9 move a1, a2 /* delay slot */ 570: 00c02821 move a1,a2
If you meddle with the compiler options you better know EXACTLY what you are doing.
Use the flags as they are defined in U-Boot. This is what works for me.
See above.
There are differences, but your problem is not caused by any of these. You use bad compiler options and/or misconfigured tools.
I don't understand why you don't follow the clear hints the compiler is giving: "incompatible with PIC code which is the default". If your compiler is configured such that PIC is the default, and this default is causing incompatibilities, I would try to find out which compiler option can be used NOT to generate PIC. ["-fno-pic" comes to mind.]
Hi
Thanks for your help.
The code I disassemble below is the u-boot image. Believe me I tried all the flags that you can think about - but non of it gave me a "clean" u-boot image.
As I understand the code must be PIC, other wise when we will relocate to the DRAM in the next function call we will jump back to the Flash, cause the compiler might use absolute jump and not a relative branch/jump. any way I found how to overcome the below problem and now the compiler generate the same code as you have, I use gcc -membedded-pic and ld --relocatable , but this option doesn't work well with my elf compiler(as it is mentioned in the man), and it cause some other problems. Can you please send me a short description how did you built your cross compiler.
Thanks Ronen
See above.
Yes, that much was clear. My question was: is this the image on the disk of your development host, or in flash on your target system before relocation, or in RAM on your target system after relocation?
No. The code must be relocatable, but not PIC.
It will not, because we relocate it.
Please note that to relocate code means more than just copying it to a different address.
This is why we relocate the code.
See http://www.denx.de/twiki/bin/view/DULG/ELDKRebuildingComponents#Section_3.7.....
Ronen Shitrit
