[U-Boot] [PATCH 1/2] imx: imx6sx-sdb: Enable DM QSPI driver
To support DM QSPI driver - Add spi0 and spi1 alias for qspi1 and qspi2. - Modify n25q256a@0 and n25q256a@1 compatible string to "spi-flash" - Enable DM SPI/QSPI relavent configurations - Remove iomux settings of qspi2 in board codes which is not needed for DM driver. - Add sf default settings. So running "sf probe" can detect the flash
Signed-off-by: Ye Li ye.li@nxp.com --- arch/arm/dts/imx6sx-sdb.dts | 4 ++-- arch/arm/dts/imx6sx.dtsi | 12 +++++++----- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 25 ------------------------- configs/mx6sxsabresd_defconfig | 7 +++++++ include/configs/mx6sxsabresd.h | 4 ++++ 5 files changed, 20 insertions(+), 32 deletions(-)
diff --git a/arch/arm/dts/imx6sx-sdb.dts b/arch/arm/dts/imx6sx-sdb.dts index 6dd9beb..a04b00d 100644 --- a/arch/arm/dts/imx6sx-sdb.dts +++ b/arch/arm/dts/imx6sx-sdb.dts @@ -115,7 +115,7 @@ flash0: n25q256a@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "micron,n25q256a", "jedec,spi-nor"; + compatible = "spi-flash"; spi-max-frequency = <29000000>; reg = <0>; }; @@ -123,7 +123,7 @@ flash1: n25q256a@1 { #address-cells = <1>; #size-cells = <1>; - compatible = "micron,n25q256a", "jedec,spi-nor"; + compatible = "spi-flash"; spi-max-frequency = <29000000>; reg = <1>; }; diff --git a/arch/arm/dts/imx6sx.dtsi b/arch/arm/dts/imx6sx.dtsi index 1a473e8..8ccf264 100644 --- a/arch/arm/dts/imx6sx.dtsi +++ b/arch/arm/dts/imx6sx.dtsi @@ -40,11 +40,13 @@ serial3 = &uart4; serial4 = &uart5; serial5 = &uart6; - spi0 = &ecspi1; - spi1 = &ecspi2; - spi2 = &ecspi3; - spi3 = &ecspi4; - spi4 = &ecspi5; + spi0 = &qspi1; + spi1 = &qspi2; + spi2 = &ecspi1; + spi3 = &ecspi2; + spi4 = &ecspi3; + spi5 = &ecspi4; + spi6 = &ecspi5; usbphy0 = &usbphy1; usbphy1 = &usbphy2; }; diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index d56e235..3e10c7f 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -205,33 +205,8 @@ int board_mmc_get_env_dev(int devno)
#ifdef CONFIG_FSL_QSPI
-#define QSPI_PAD_CTRL1 \ - (PAD_CTL_SRE_FAST | PAD_CTL_SPEED_HIGH | \ - PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_40ohm) - -static iomux_v3_cfg_t const quadspi_pads[] = { - MX6_PAD_NAND_WP_B__QSPI2_A_DATA_0 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_READY_B__QSPI2_A_DATA_1 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_CE0_B__QSPI2_A_DATA_2 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_CE1_B__QSPI2_A_DATA_3 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_ALE__QSPI2_A_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_CLE__QSPI2_A_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_DATA07__QSPI2_A_DQS | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_DATA01__QSPI2_B_DATA_0 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_DATA00__QSPI2_B_DATA_1 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_WE_B__QSPI2_B_DATA_2 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_RE_B__QSPI2_B_DATA_3 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_DATA03__QSPI2_B_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_DATA02__QSPI2_B_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_NAND_DATA05__QSPI2_B_DQS | MUX_PAD_CTRL(QSPI_PAD_CTRL1), -}; - int board_qspi_init(void) { - /* Set the iomux */ - imx_iomux_v3_setup_multiple_pads(quadspi_pads, - ARRAY_SIZE(quadspi_pads)); - /* Set the clock */ enable_qspi_clk(1);
diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 6ea92bb..9e4b13b 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y CONFIG_CMD_PCI=y @@ -36,8 +37,14 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_FSL_QSPI=y CONFIG_PHYLIB=y CONFIG_PCI=y CONFIG_PINCTRL=y diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index f5ca2fc..4506acb 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -186,6 +186,10 @@ #define FSL_QSPI_FLASH_SIZE SZ_32M #endif #define FSL_QSPI_FLASH_NUM 2 +#define CONFIG_SF_DEFAULT_BUS 1 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 40000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #endif
#ifndef CONFIG_SPL_BUILD
To support DM QSPI driver: - Modify n25q256a@0 and n25q256a@1 compatible string to "spi-flash" - Enable DM SPI and DM SPI FLASH configurations - Remove iomux settings of qspi1 in board codes which is not needed for DM driver.
Signed-off-by: Ye Li ye.li@nxp.com --- arch/arm/dts/imx6sx-sabreauto.dts | 40 +++++++++++++++++++++++++ board/freescale/mx6sxsabreauto/mx6sxsabreauto.c | 24 --------------- configs/mx6sxsabreauto_defconfig | 2 ++ 3 files changed, 42 insertions(+), 24 deletions(-)
diff --git a/arch/arm/dts/imx6sx-sabreauto.dts b/arch/arm/dts/imx6sx-sabreauto.dts index a4c2627..ee5c349 100644 --- a/arch/arm/dts/imx6sx-sabreauto.dts +++ b/arch/arm/dts/imx6sx-sabreauto.dts @@ -96,6 +96,29 @@ }; };
+&qspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi1_1>; + status = "okay"; + ddrsmp=<2>; + + flash0: n25q256a@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <29000000>; + reg = <0>; + }; + + flash1: n25q256a@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <29000000>; + reg = <1>; + }; +}; + &iomuxc { imx6x-sabreauto { pinctrl_i2c2_1: i2c2grp-1 { @@ -112,6 +135,23 @@ >; };
+ pinctrl_qspi1_1: qspi1grp_1 { + fsl,pins = < + MX6SX_PAD_QSPI1A_DATA0__QSPI1_A_DATA_0 0x70a1 + MX6SX_PAD_QSPI1A_DATA1__QSPI1_A_DATA_1 0x70a1 + MX6SX_PAD_QSPI1A_DATA2__QSPI1_A_DATA_2 0x70a1 + MX6SX_PAD_QSPI1A_DATA3__QSPI1_A_DATA_3 0x70a1 + MX6SX_PAD_QSPI1A_SCLK__QSPI1_A_SCLK 0x70a1 + MX6SX_PAD_QSPI1A_SS0_B__QSPI1_A_SS0_B 0x70a1 + MX6SX_PAD_QSPI1B_DATA0__QSPI1_B_DATA_0 0x70a1 + MX6SX_PAD_QSPI1B_DATA1__QSPI1_B_DATA_1 0x70a1 + MX6SX_PAD_QSPI1B_DATA2__QSPI1_B_DATA_2 0x70a1 + MX6SX_PAD_QSPI1B_DATA3__QSPI1_B_DATA_3 0x70a1 + MX6SX_PAD_QSPI1B_SCLK__QSPI1_B_SCLK 0x70a1 + MX6SX_PAD_QSPI1B_SS0_B__QSPI1_B_SS0_B 0x70a1 + >; + }; + pinctrl_uart1: uart1grp { fsl,pins = < MX6SX_PAD_GPIO1_IO04__UART1_TX 0x1b0b1 diff --git a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c index 975af2c..6e606da 100644 --- a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c +++ b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c @@ -218,32 +218,8 @@ int board_early_init_f(void) }
#ifdef CONFIG_FSL_QSPI - -#define QSPI_PAD_CTRL1 \ - (PAD_CTL_SRE_FAST | PAD_CTL_SPEED_HIGH | \ - PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_47K_UP | PAD_CTL_DSE_40ohm) - -static iomux_v3_cfg_t const quadspi_pads[] = { - MX6_PAD_QSPI1A_SS0_B__QSPI1_A_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1A_SCLK__QSPI1_A_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1A_DATA0__QSPI1_A_DATA_0 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1A_DATA1__QSPI1_A_DATA_1 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1A_DATA2__QSPI1_A_DATA_2 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1A_DATA3__QSPI1_A_DATA_3 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1B_SS0_B__QSPI1_B_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1B_SCLK__QSPI1_B_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1B_DATA0__QSPI1_B_DATA_0 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1B_DATA1__QSPI1_B_DATA_1 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1B_DATA2__QSPI1_B_DATA_2 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), - MX6_PAD_QSPI1B_DATA3__QSPI1_B_DATA_3 | MUX_PAD_CTRL(QSPI_PAD_CTRL1), -}; - int board_qspi_init(void) { - /* Set the iomux */ - imx_iomux_v3_setup_multiple_pads(quadspi_pads, - ARRAY_SIZE(quadspi_pads)); - /* Set the clock */ enable_qspi_clk(0);
diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index be95cc0..d7941e8 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -35,6 +35,8 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y
Ye Li
