[U-Boot] [PATCH] usb: remove unnecessary packed attributes
We don't actually need to pack those structs, as they are not used to do actual hardware access.
This avoids some unaligned accesses and therefore makes the EHCI stack work on ARMv7 without compiler workarounds.
Signed-off-by: Lucas Stach dev@lynxeye.de --- drivers/usb/host/ehci-hcd.c | 2 +- include/usb.h | 2 +- 2 Dateien geändert, 2 Zeilen hinzugefügt(+), 2 Zeilen entfernt(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 18b4bc6..2f4fa5e 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -45,7 +45,7 @@ static struct descriptor { struct usb_linux_config_descriptor config; struct usb_linux_interface_descriptor interface; struct usb_endpoint_descriptor endpoint; -} __attribute__ ((packed)) descriptor = { +} descriptor = { { 0x8, /* bDescLength */ 0x29, /* bDescriptorType: hub descriptor */ diff --git a/include/usb.h b/include/usb.h index ba3d169..63730ee 100644 --- a/include/usb.h +++ b/include/usb.h @@ -369,7 +369,7 @@ struct usb_hub_descriptor { unsigned char PortPowerCtrlMask[(USB_MAXCHILDREN+1+7)/8]; /* DeviceRemovable and PortPwrCtrlMask want to be variable-length bitmaps that hold max 255 entries. (bit0 is ignored) */ -} __attribute__ ((packed)); +};
struct usb_hub_device {
Dear Lucas Stach,
I need to review this properly, will get back to it soon.
Until then, CCing other good fellows.
Best regards, Marek Vasut
Dear Marek Vasut,
Dear Lucas Stach,
My 7th sense is telling me, these descriptors are sent across the bus. ehci_submit_root() puts them into buffer and then ehci_submit_async() blasts them. I believe they must be packed, otherwise the format expected by devices on the bus won't match and it'll fall apart.
Dear Marek,
it seems you are right. Though it works for me this may be pure luck. So please disregard this patch, I'll fix this up more properly.
Thanks, Lucas
Am Donnerstag, den 30.08.2012, 22:59 +0200 schrieb Marek Vasut:
Dear Marek Vasut,
Dear Lucas Stach,
Dear Lucas Stach,
Dear Marek,
Cool thing we caught it :-)
http://www.denx.de/wiki/U-Boot/Patches btw read up here ... don't top-post ... you know the drill.
Thanks, Lucas
Dear Marek Vasut,
Dear Lucas Stach,
length
Lucas Stach
