[U-Boot] [PATCH] MX27: add missing get_tbclk()
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/mx27/timer.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index 5af9359..226c0a5 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -171,3 +171,11 @@ void __udelay(unsigned long usec) while (get_ticks() < tmp) /* loop till event */ /*NOP*/; } + +ulong get_tbclk(void) +{ + ulong tbclk; + + tbclk = CONFIG_MX27_CLK32; + return tbclk; +}
- ulong tbclk;
- tbclk = CONFIG_MX27_CLK32;
- return tbclk;
Why not simply ... return CONFIG... ? M
- ulong tbclk;
- return tbclk;
Yes, right, as I already did for the other i.MX....
Fixed in V2
Stefano
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes since V1: - return directly CONFIG_MX27_CLK32 instead using temporary variable (Marek Vasut)
arch/arm/cpu/arm926ejs/mx27/timer.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index 5af9359..a5dd684 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -171,3 +171,8 @@ void __udelay(unsigned long usec) while (get_ticks() < tmp) /* loop till event */ /*NOP*/; } + +ulong get_tbclk(void) +{ + return CONFIG_MX27_CLK32; +}
Stefano Babic
