[U-Boot] [PATCH] mmc: Minor cleanup of sdhci.c
Fixup prints to show where the print is done from, and a few minor formatting/grammar issues.
Signed-off-by: Darwin Rambo drambo@broadcom.com --- drivers/mmc/sdhci.c | 32 +++++++++++++++++++------------- 1 file changed, 19 insertions(+), 13 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 46ae9cb..1e86b92 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -24,7 +24,8 @@ static void sdhci_reset(struct sdhci_host *host, u8 mask) sdhci_writeb(host, mask, SDHCI_SOFTWARE_RESET); while (sdhci_readb(host, SDHCI_SOFTWARE_RESET) & mask) { if (timeout == 0) { - printf("Reset 0x%x never completed.\n", (int)mask); + printf("%s: Reset 0x%x never completed.\n", + __func__, (int)mask); return; } timeout--; @@ -79,7 +80,8 @@ static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data, do { stat = sdhci_readl(host, SDHCI_INT_STATUS); if (stat & SDHCI_INT_ERROR) { - printf("Error detected in status(0x%X)!\n", stat); + printf("%s: Error detected in status(0x%X)!\n", + __func__, stat); return -1; } if (stat & rdy) { @@ -102,7 +104,7 @@ static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data, if (timeout-- > 0) udelay(10); else { - printf("Transfer data timeout\n"); + printf("%s: Transfer data timeout\n", __func__); return -1; } } while (!(stat & SDHCI_INT_DATA_END)); @@ -147,7 +149,7 @@ int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd,
while (sdhci_readl(host, SDHCI_PRESENT_STATE) & mask) { if (time >= cmd_timeout) { - printf("MMC: %d busy ", mmc_dev); + printf("%s: MMC: %d busy ", __func__, mmc_dev); if (2 * cmd_timeout <= CONFIG_SDHCI_CMD_MAX_TIMEOUT) { cmd_timeout += cmd_timeout; printf("timeout increasing to: %u ms.\n", @@ -179,7 +181,7 @@ int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, if (data) flags |= SDHCI_CMD_DATA;
- /*Set Transfer mode regarding to data flag*/ + /* Set Transfer mode regarding to data flag */ if (data != 0) { sdhci_writeb(host, 0xe, SDHCI_TIMEOUT_CONTROL); mode = SDHCI_TRNS_BLK_CNT_EN; @@ -230,7 +232,7 @@ int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, if (host->quirks & SDHCI_QUIRK_BROKEN_R1B) return 0; else { - printf("Timeout for status update!\n"); + printf("%s: Timeout for status update!\n", __func__); return TIMEOUT; } } @@ -307,7 +309,8 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL)) & SDHCI_CLOCK_INT_STABLE)) { if (timeout == 0) { - printf("Internal clock never stabilised.\n"); + printf("%s: Internal clock never stabilised.\n", + __func__); return -1; } timeout--; @@ -397,7 +400,8 @@ int sdhci_init(struct mmc *mmc) if ((host->quirks & SDHCI_QUIRK_32BIT_DMA_ADDR) && !aligned_buffer) { aligned_buffer = memalign(8, 512*1024); if (!aligned_buffer) { - printf("Aligned buffer alloc failed!!!"); + printf("%s: Aligned buffer alloc failed!!!\n", + __func__); return -1; } } @@ -418,8 +422,8 @@ int sdhci_init(struct mmc *mmc) }
/* Enable only interrupts served by the SD controller */ - sdhci_writel(host, SDHCI_INT_DATA_MASK | SDHCI_INT_CMD_MASK - , SDHCI_INT_ENABLE); + sdhci_writel(host, SDHCI_INT_DATA_MASK | SDHCI_INT_CMD_MASK, + SDHCI_INT_ENABLE); /* Mask all sdhci interrupt sources */ sdhci_writel(host, 0x0, SDHCI_SIGNAL_ENABLE);
@@ -433,7 +437,7 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk)
mmc = malloc(sizeof(struct mmc)); if (!mmc) { - printf("mmc malloc fail!\n"); + printf("%s: mmc malloc fail!\n", __func__); return -1; }
@@ -450,7 +454,8 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) caps = sdhci_readl(host, SDHCI_CAPABILITIES); #ifdef CONFIG_MMC_SDMA if (!(caps & SDHCI_CAN_DO_SDMA)) { - printf("Your controller don't support sdma!!\n"); + printf("%s: Your controller doesn't support SDMA!!\n", + __func__); return -1; } #endif @@ -467,7 +472,8 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) mmc->f_max *= 1000000; } if (mmc->f_max == 0) { - printf("Hardware doesn't specify base clock frequency\n"); + printf("%s: Hardware doesn't specify base clock frequency\n", + __func__); return -1; } if (min_clk)
Hi, Darwin.
I didn't think that "__func__" is needs...in my case. There isn't the duplicated message, anywhere.
Best Regards, Jaehoon Chung
} timeout--;__func__, (int)mask); return;
} if (stat & rdy) {__func__, stat); return -1;
} } while (!(stat & SDHCI_INT_DATA_END));printf("%s: Transfer data timeout\n", __func__); return -1;
- /* Set Transfer mode regarding to data flag */ if (data != 0) { sdhci_writeb(host, 0xe, SDHCI_TIMEOUT_CONTROL); mode = SDHCI_TRNS_BLK_CNT_EN;
} }printf("%s: Timeout for status update!\n", __func__); return TIMEOUT;
} timeout--;__func__); return -1;
} }__func__); return -1;
- sdhci_writel(host, SDHCI_INT_DATA_MASK | SDHCI_INT_CMD_MASK,
/* Mask all sdhci interrupt sources */ sdhci_writel(host, 0x0, SDHCI_SIGNAL_ENABLE);SDHCI_INT_ENABLE);
return -1; }printf("%s: mmc malloc fail!\n", __func__);
return -1; }__func__);
return -1; } if (min_clk)__func__);
-----Original Message----- From: Jaehoon Chung [mailto:jh80.chung@samsung.com] Sent: Wednesday, December 25, 2013 11:32 PM To: Darwin Rambo; u-boot@lists.denx.de Cc: Pantelis Antoniou Subject: Re: [U-Boot] [PATCH] mmc: Minor cleanup of sdhci.c
Hi, Darwin.
Hi Jaehoon,
I think that the __func__ is needed to show where the prints are coming from when there are prints coming from many other functions outside of the sdhci subsystem as well. It is less confusing and faster to debug if prints in general show where they are coming from. Just because the prints are unique inside sdhci.c is not enough to remove the need for the prefix. This is especially true since the prints in this module are very generic such as "Error detected in status" or "Transfer data timeout". These messages are so generic that they could be from USB, I2C, NET, DMA, etc. Having the function prefix is a nice way to avoid having to search the code base for these generic strings.
Best regards, Darwin Rambo
mmc_cmd *cmd,
mmc_cmd *cmd,
mmc_cmd *cmd,
unsigned int clock)
!aligned_buffer) {
u32 min_clk)
u32 min_clk)
u32 min_clk)
Hi Darwin (Rambo? - cool name)
Hi, Darwin.
Hi Jaehoon,
mmc_cmd *cmd,
mmc_cmd *cmd,
mmc_cmd *cmd,
unsigned int clock)
!aligned_buffer) {
u32 min_clk)
u32 min_clk)
u32 min_clk)
Applied, thanks
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Darwin Rambo
Jaehoon Chung
Pantelis Antoniou
