[U-Boot] [PATCH 1/3] usb: ehci-mx6: implement ofdata_to_platdata
Implement ofdata_to_platdata to set the type to host or device. - Check "dr-mode" property. - If there is no "dr-mode", check phy_ctrl for i.MX6 and phy_status for i.MX7
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de --- drivers/usb/host/ehci-mx6.c | 66 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 66 insertions(+)
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 48889c1..91413c9 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -15,10 +15,13 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> #include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/sys_proto.h> #include <dm.h>
#include "ehci.h"
+DECLARE_GLOBAL_DATA_PTR; + #define USB_OTGREGS_OFFSET 0x000 #define USB_H1REGS_OFFSET 0x200 #define USB_H2REGS_OFFSET 0x400 @@ -48,6 +51,7 @@ #define ANADIG_USB2_PLL_480_CTRL_EN_USB_CLKS 0x00000040
#define USBNC_OFFSET 0x200 +#define USBNC_PHY_STATUS_OFFSET 0x23C #define USBNC_PHYSTATUS_ID_DIG (1 << 4) /* otg_id status */ #define USBNC_PHYCFG2_ACAENB (1 << 4) /* otg_id detection enable */ #define UCTRL_PWR_POL (1 << 9) /* OTG Polarity of Power Pin */ @@ -417,6 +421,67 @@ static const struct ehci_ops mx6_ehci_ops = { .init_after_reset = mx6_init_after_reset };
+static int ehci_usb_ofdata_to_platdata(struct udevice *dev) +{ + struct usb_platdata *plat = dev_get_platdata(dev); + void *__iomem addr = (void *__iomem)dev_get_addr(dev); + void *__iomem phy_ctrl, *__iomem phy_status; + const void *blob = gd->fdt_blob; + int offset = dev->of_offset, phy_off; + const char *mode; + u32 val; + + mode = fdt_getprop(blob, offset, "dr_mode", NULL); + if (mode) { + if (strcmp(mode, "peripheral") == 0) + plat->init_type = USB_INIT_DEVICE; + else if (strcmp(mode, "host") == 0) + plat->init_type = USB_INIT_HOST; + else if (strcmp(mode, "otg") == 0) + plat->init_type = USB_INIT_HOST; + else + return -EINVAL; + } else { + /* + * About fsl,usbphy, Refer to + * Documentation/devicetree/bindings/usb/ci-hdrc-usb2.txt. + */ + if (is_mx6()) { + phy_off = fdtdec_lookup_phandle(blob, + offset, + "fsl,usbphy"); + if (phy_off < 0) + return -EINVAL; + + addr = (void __iomem *)fdtdec_get_addr(blob, phy_off, + "reg"); + if ((fdt_addr_t)addr == FDT_ADDR_T_NONE) + return -EINVAL; + + phy_ctrl = (void __iomem *)(addr + USBPHY_CTRL); + val = readl(phy_ctrl); + + if (val & USBPHY_CTRL_OTG_ID) + plat->init_type = USB_INIT_DEVICE; + else + plat->init_type = USB_INIT_HOST; + } else if (is_mx7()) { + phy_status = (void __iomem *)(addr + + USBNC_PHY_STATUS_OFFSET); + val = readl(phy_status); + + if (val & USBNC_PHYSTATUS_ID_DIG) + plat->init_type = USB_INIT_DEVICE; + else + plat->init_type = USB_INIT_HOST; + } else { + return -EINVAL; + } + } + + return 0; +} + static int ehci_usb_probe(struct udevice *dev) { struct usb_platdata *plat = dev_get_platdata(dev); @@ -460,6 +525,7 @@ U_BOOT_DRIVER(usb_mx6) = { .name = "ehci_mx6", .id = UCLASS_USB, .of_match = mx6_usb_ids, + .ofdata_to_platdata = ehci_usb_ofdata_to_platdata, .probe = ehci_usb_probe, .remove = ehci_deregister, .ops = &ehci_usb_ops,
Drop board_ehci_power when dm usb used and switch to use regulator api to handle vbus.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de --- drivers/usb/host/ehci-mx6.c | 30 +++++++++++++++++++++++++++--- 1 file changed, 27 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 91413c9..123befe 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -17,6 +17,7 @@ #include <asm/imx-common/iomux-v3.h> #include <asm/imx-common/sys_proto.h> #include <dm.h> +#include <power/regulator.h>
#include "ehci.h"
@@ -388,6 +389,7 @@ int ehci_hcd_stop(int index) struct ehci_mx6_priv_data { struct ehci_ctrl ctrl; struct usb_ehci *ehci; + struct udevice *vbus_supply; enum usb_init_type init_type; int portnr; }; @@ -403,7 +405,15 @@ static int mx6_init_after_reset(struct ehci_ctrl *dev) if (ret) return ret;
- board_ehci_power(priv->portnr, (type == USB_INIT_DEVICE) ? 0 : 1); + if (priv->vbus_supply) { + ret = regulator_set_enable(priv->vbus_supply, + (type == USB_INIT_DEVICE) ? + false : true); + if (ret) { + puts("Error enabling VBUS supply\n"); + return ret; + } + }
if (type == USB_INIT_DEVICE) return 0; @@ -487,19 +497,33 @@ static int ehci_usb_probe(struct udevice *dev) struct usb_platdata *plat = dev_get_platdata(dev); struct usb_ehci *ehci = (struct usb_ehci *)dev_get_addr(dev); struct ehci_mx6_priv_data *priv = dev_get_priv(dev); + enum usb_init_type type = plat->init_type; struct ehci_hccr *hccr; struct ehci_hcor *hcor; int ret;
priv->ehci = ehci; priv->portnr = dev->seq; - priv->init_type = plat->init_type; + priv->init_type = type; + + ret = device_get_supply_regulator(dev, "vbus-supply", + &priv->vbus_supply); + if (ret) + debug("%s: No vbus supply\n", dev->name);
ret = ehci_mx6_common_init(ehci, priv->portnr); if (ret) return ret;
- board_ehci_power(priv->portnr, (priv->init_type == USB_INIT_DEVICE) ? 0 : 1); + if (priv->vbus_supply) { + ret = regulator_set_enable(priv->vbus_supply, + (type == USB_INIT_DEVICE) ? + false : true); + if (ret) { + puts("Error enabling VBUS supply\n"); + return ret; + } + }
if (priv->init_type == USB_INIT_HOST) { setbits_le32(&ehci->usbmode, CM_HOST);
Add usb support for mx6sllevk board.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- board/freescale/mx6sllevk/mx6sllevk.c | 18 ++++++++++++++++++ configs/mx6sllevk_defconfig | 5 +++++ configs/mx6sllevk_plugin_defconfig | 5 +++++ include/configs/mx6sllevk.h | 9 +++++++++ 4 files changed, 37 insertions(+)
diff --git a/board/freescale/mx6sllevk/mx6sllevk.c b/board/freescale/mx6sllevk/mx6sllevk.c index 74a27a3..e6679fd 100644 --- a/board/freescale/mx6sllevk/mx6sllevk.c +++ b/board/freescale/mx6sllevk/mx6sllevk.c @@ -129,3 +129,21 @@ int mmc_map_to_kernel_blk(int devno) { return devno; } + +#define USB_OTHERREGS_OFFSET 0x800 +#define UCTRL_PWR_POL (1 << 9) + +int board_ehci_hcd_init(int port) +{ + u32 *usbnc_usb_ctrl; + + if (port > 1) + return -EINVAL; + + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET + + port * 4); + + /* Set Power polarity */ + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); + return 0; +} diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index 8ae049e..267cdc6 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -34,3 +35,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index e6be979..63d5bbc 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -35,3 +36,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y diff --git a/include/configs/mx6sllevk.h b/include/configs/mx6sllevk.h index b9f25cf..3f665a3 100644 --- a/include/configs/mx6sllevk.h +++ b/include/configs/mx6sllevk.h @@ -149,4 +149,13 @@
#define CONFIG_IOMUX_LPSR
+/* USB Configs */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_RTL8152 +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#endif + #endif /* __CONFIG_H */
Can't we do this from driver itself, .probe or somewhere?
if (port > 1)
return -EINVAL;
port * 4);
I think this is even should managed from driver isn't it?
thanks!
-----Original Message----- From: Jagan Teki [mailto:jagan@openedev.com] Sent: Wednesday, December 21, 2016 10:02 PM To: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de; Marek Vasut marex@denx.de; u- boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 3/3] imx: mx6sllevk: add usb support
This is to handle OTG power polarity, which is board specific. There is no dts property now, so I add this in board file just like other fsl boards. When there is an dts property upstreamed in Linux side, we could use that and move this code into driver part.
if (port > 1)
return -EINVAL;
port * 4);
PORT_PTS_PTW)
Thanks for pointing this out. This is not needed by DM USB, I'll remove it in V2.
Thanks, Peng.
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
- u32 *usbnc_usb_ctrl;
- if (port > 1)
return -EINVAL;
- usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET +
port * 4);
- /* Set Power polarity */
- setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL);
Is this function similar to what usb_oc_config() does ?
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Wednesday, December 21, 2016 10:10 PM To: Peng Fan peng.fan@nxp.com; sbabic@denx.de Cc: u-boot@lists.denx.de; van.freenix@gmail.com Subject: Re: [PATCH 3/3] imx: mx6sllevk: add usb support
- if (port > 1)
return -EINVAL;
port * 4);
No, this bit is not for overcurrent. According to RM, this is OTG Power Polarity This bit should be set according to power switch's enable polarity. 1 Power switch has an active-high enable input 0 Power switch has an active-low enable input
This is board specific.
Regards, Peng.
-- Best regards, Marek Vasut
- if (port > 1)
return -EINVAL;
port * 4);
Great, except it should also be part of the driver , the same way as polarity is configured, yes ?
Hi Marek,
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, December 22, 2016 12:40 PM To: Peng Fan peng.fan@nxp.com; sbabic@denx.de Cc: u-boot@lists.denx.de; van.freenix@gmail.com Subject: Re: [PATCH 3/3] imx: mx6sllevk: add usb support
- if (port > 1)
return -EINVAL;
port * 4);
polarity.
I just found that there is code for mx7, http://lists.denx.de/pipermail/u-boot/2016-July/260321.html
Then do you agree I add such piece code in usb_power_config for mx6? " #ifdef CONFIG_MXC_USB_OTG_HACTIVE setbits_le32(ctrl, UCTRL_PWR_POL); #else clrbits_le32(ctrl, UCTRL_PWR_POL); #endif "
Thanks, Peng
On 12/22/2016 07:03 AM, Peng Fan wrote:
Hi Marek,
- if (port > 1)
return -EINVAL;
port * 4);
polarity.
Didn't you add DT support in a patch sent like ... yesterday ? :) Just use DT property instead of ifdef.
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, December 22, 2016 2:12 PM To: Peng Fan peng.fan@nxp.com; sbabic@denx.de Cc: u-boot@lists.denx.de; van.freenix@gmail.com Subject: Re: [PATCH 3/3] imx: mx6sllevk: add usb support
Hi Marek,
+int board_ehci_hcd_init(int port) {
- if (port > 1)
return -EINVAL;
port * 4);
polarity.
There is no property for otg power polatiry in upstream Linux. I would not like to introduce one in U-Boot. We can drop the ifdef when there is an property in upstream. What do you think?
Regards, Peng.
Hi Marek,
On 12/21/2016 09:14 AM, Peng Fan wrote: > Add usb support for mx6sllevk board. > > Signed-off-by: Peng Fan peng.fan@nxp.com > Cc: Stefano Babic sbabic@denx.de > ---
> + > +#define USB_OTHERREGS_OFFSET 0x800 > +#define UCTRL_PWR_POL (1 << 9) > + > +int board_ehci_hcd_init(int port) { > + u32 *usbnc_usb_ctrl; > + > + if (port > 1) > + return -EINVAL; > + > + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR +
> + port * 4); > + > + /* Set Power polarity */ > + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); > + return 0; > +}
polarity.
So uh, how can the USB work in mainline Linux on that board ?
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, December 22, 2016 3:12 PM To: Peng Fan peng.fan@nxp.com; sbabic@denx.de Cc: u-boot@lists.denx.de; van.freenix@gmail.com Subject: Re: [PATCH 3/3] imx: mx6sllevk: add usb support
Hi Marek,
> -----Original Message----- > From: Marek Vasut [mailto:marex@denx.de] > Sent: Wednesday, December 21, 2016 10:10 PM > To: Peng Fan peng.fan@nxp.com; sbabic@denx.de > Cc: u-boot@lists.denx.de; van.freenix@gmail.com > Subject: Re: [PATCH 3/3] imx: mx6sllevk: add usb support > > On 12/21/2016 09:14 AM, Peng Fan wrote: >> Add usb support for mx6sllevk board. >> >> Signed-off-by: Peng Fan peng.fan@nxp.com >> Cc: Stefano Babic sbabic@denx.de >> --- [......]
>> + >> +#define USB_OTHERREGS_OFFSET 0x800 >> +#define UCTRL_PWR_POL (1 << 9) >> + >> +int board_ehci_hcd_init(int port) { >> + u32 *usbnc_usb_ctrl; >> + >> + if (port > 1) >> + return -EINVAL; >> + >> + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR +
> + >> + port * 4); >> + >> + /* Set Power polarity */ >> + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); >> + return 0; >> +} > > Is this function similar to what usb_oc_config() does ?
polarity.
Confirmed with IC, if using gpio to control vbus power, no need to configure this bit. Since in dts, we are using gpio regulator to control vbus, this piece code in patch 3/3 can be discarded. I'll drop it in V2.
Thanks, Peng.
Hi Marek,
On 12/22/2016 02:13 AM, Peng Fan wrote: > > >> -----Original Message----- >> From: Marek Vasut [mailto:marex@denx.de] >> Sent: Wednesday, December 21, 2016 10:10 PM >> To: Peng Fan peng.fan@nxp.com; sbabic@denx.de >> Cc: u-boot@lists.denx.de; van.freenix@gmail.com >> Subject: Re: [PATCH 3/3] imx: mx6sllevk: add usb support >> >> On 12/21/2016 09:14 AM, Peng Fan wrote: >>> Add usb support for mx6sllevk board. >>> >>> Signed-off-by: Peng Fan peng.fan@nxp.com >>> Cc: Stefano Babic sbabic@denx.de >>> --- > [......] > >>> + >>> +#define USB_OTHERREGS_OFFSET 0x800 >>> +#define UCTRL_PWR_POL (1 << 9) >>> + >>> +int board_ehci_hcd_init(int port) { >>> + u32 *usbnc_usb_ctrl; >>> + >>> + if (port > 1) >>> + return -EINVAL; >>> + >>> + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR +
>> + >>> + port * 4); >>> + >>> + /* Set Power polarity */ >>> + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); >>> + return 0; >>> +} >> >> Is this function similar to what usb_oc_config() does ? > > No, this bit is not for overcurrent. According to RM, this is OTG > Power Polarity This bit should be set according to power switch's > enable polarity. > 1 Power switch has an active-high enable input > 0 Power switch has an active-low enable input > > This is board specific.
Hum, OK. Let's revisit this when we need this then ?
>>>> +#define USB_OTHERREGS_OFFSET 0x800 >>>> +#define UCTRL_PWR_POL (1 << 9) >>>> + >>>> +int board_ehci_hcd_init(int port) { >>>> + u32 *usbnc_usb_ctrl; >>>> + >>>> + if (port > 1) >>>> + return -EINVAL; >>>> + >>>> + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR +
>>> + >>>> + port * 4); >>>> + >>>> + /* Set Power polarity */ >>>> + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); >>>> + return 0; >>>> +} >>> >>> Is this function similar to what usb_oc_config() does ? >> >> No, this bit is not for overcurrent. According to RM, this is >> OTG Power Polarity This bit should be set according to power >> switch's enable > polarity. >> 1 Power switch has an active-high enable input >> 0 Power switch has an active-low enable input >> >> This is board specific. > > Great, except it should also be part of the driver , the same way > as polarity is configured, yes ?
this bit.
Take i.MX6SLL as an example, The pin key_col4 can be configured with the two functions. [1] MX6_PAD_KEY_COL4__USB_OTG1_PWR [2] MX6_PAD_KEY_COL4__GPIO4_IO00
In fsl i.mx uboot code, the common way is to use [1] and configure the polarity to enable the vbus power. But in kernel, it is configured as [2] and use gpio regulator to enable the vbus power.
This is board specific. There is no upstream property for this bit. When there is an upstream property for this, We could add it in probe function for those that use [1] in dts pinmux.
Now I am using the same dts from kernel which this pinmux configured as [2], so this piece code is not needed for now.
Thanks, Peng.
On 12/22/2016 09:55 AM, Peng Fan wrote:
>>>>> +#define USB_OTHERREGS_OFFSET 0x800 >>>>> +#define UCTRL_PWR_POL (1 << 9) >>>>> + >>>>> +int board_ehci_hcd_init(int port) { >>>>> + u32 *usbnc_usb_ctrl; >>>>> + >>>>> + if (port > 1) >>>>> + return -EINVAL; >>>>> + >>>>> + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET >>>> + >>>>> + port * 4); >>>>> + >>>>> + /* Set Power polarity */ >>>>> + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); >>>>> + return 0; >>>>> +} >>>> >>>> Is this function similar to what usb_oc_config() does ? >>> >>> No, this bit is not for overcurrent. According to RM, this is >>> OTG Power Polarity This bit should be set according to power >>> switch's enable >> polarity. >>> 1 Power switch has an active-high enable input >>> 0 Power switch has an active-low enable input >>> >>> This is board specific. >> >> Great, except it should also be part of the driver , the same way >> as polarity is configured, yes ? > > I just found that there is code for mx7, > http://lists.denx.de/pipermail/u-boot/2016-July/260321.html > > Then do you agree I add such piece code in usb_power_config for mx6? > " > #ifdef CONFIG_MXC_USB_OTG_HACTIVE > setbits_le32(ctrl, UCTRL_PWR_POL); #else > clrbits_le32(ctrl, UCTRL_PWR_POL); #endif "
this bit.
Well, can you submit a proposal with the new prop for devicetree@ ? It can then be improved in linux too ...
Hi Marek,
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, December 22, 2016 4:58 PM To: Peng Fan peng.fan@nxp.com; sbabic@denx.de Cc: u-boot@lists.denx.de; van.freenix@gmail.com Subject: Re: [PATCH 3/3] imx: mx6sllevk: add usb support
>>>>>> +#define USB_OTHERREGS_OFFSET 0x800 >>>>>> +#define UCTRL_PWR_POL (1 << 9) >>>>>> + >>>>>> +int board_ehci_hcd_init(int port) { >>>>>> + u32 *usbnc_usb_ctrl; >>>>>> + >>>>>> + if (port > 1) >>>>>> + return -EINVAL; >>>>>> + >>>>>> + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + > USB_OTHERREGS_OFFSET >>>>> + >>>>>> + port * 4); >>>>>> + >>>>>> + /* Set Power polarity */ >>>>>> + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); >>>>>> + return 0; >>>>>> +} >>>>> >>>>> Is this function similar to what usb_oc_config() does ? >>>> >>>> No, this bit is not for overcurrent. According to RM, this is >>>> OTG Power Polarity This bit should be set according to power >>>> switch's enable >>> polarity. >>>> 1 Power switch has an active-high enable input >>>> 0 Power switch has an active-low enable input >>>> >>>> This is board specific. >>> >>> Great, except it should also be part of the driver , the same >>> way as polarity is configured, yes ? >> >> I just found that there is code for mx7, >> http://lists.denx.de/pipermail/u-boot/2016-July/260321.html >> >> Then do you agree I add such piece code in usb_power_config for
mx6?
>> " >> #ifdef CONFIG_MXC_USB_OTG_HACTIVE >> setbits_le32(ctrl, UCTRL_PWR_POL); #else >> clrbits_le32(ctrl, UCTRL_PWR_POL); #endif " > > Didn't you add DT support in a patch sent like ... yesterday ? :) > Just use DT property instead of ifdef.
this bit.
power.
I'll talk with our internal Linux usb maintainer to see whether he has plan to do this.
Thanks, Peng.
#include "ehci.h"
- struct usb_platdata *plat = dev_get_platdata(dev);
- void *__iomem addr = (void *__iomem)dev_get_addr(dev);
- void *__iomem phy_ctrl, *__iomem phy_status;
- const void *blob = gd->fdt_blob;
- int offset = dev->of_offset, phy_off;
- const char *mode;
- u32 val;
- mode = fdt_getprop(blob, offset, "dr_mode", NULL);
- if (mode) {
Shouldn't this case check the phy status register ?
else
return -EINVAL;
- } else {
You can probably do return 0 in the if (mode) branch and then indent this whole else branch to the left.
if (is_mx6()) {
offset,
"fsl,usbphy");
if (phy_off < 0)
return -EINVAL;
"reg");
return -EINVAL;
else
else
} else {
return -EINVAL;
- .ofdata_to_platdata = ehci_usb_ofdata_to_platdata, .probe = ehci_usb_probe, .remove = ehci_deregister, .ops = &ehci_usb_ops,
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Wednesday, December 21, 2016 10:08 PM To: Peng Fan peng.fan@nxp.com; sbabic@denx.de Cc: u-boot@lists.denx.de; van.freenix@gmail.com; Simon Glass sjg@chromium.org Subject: Re: [PATCH 1/3] usb: ehci-mx6: implement ofdata_to_platdata
#include "ehci.h"
+static int ehci_usb_ofdata_to_platdata(struct udevice *dev) {
- const char *mode;
- u32 val;
- if (mode) {
Yeah. Thanks for pointing this out. Will fix it in V2.
else
return -EINVAL;
- } else {
Will fix this in V2.
Thanks, Peng.
Jagan Teki
Peng Fan
