[U-Boot] [PATCH 00/13] manage protocols in a linked list
Up to now the protocols of an EFI handle where contained in an array of fixed size. With the patch series the protocols are managed in a linked list. This both saves memory and gives more flexibility.
The LocateDevicePath boot service is implemented according to the UEFI specification.
A unit test for the LocateDevicePath boot service and the device path to text protocol are added.
Some bug fixes are provided.
This patch series is to be merged after efi_loader: refactor protocols management https://patchwork.ozlabs.org/project/uboot/list/?series=10409
Heinrich Schuchardt (13): efi_loader: efi_bootmgr: do not make hidden assignments efi_loader: size of media device path node represenation efi_loader: efi_dp_str should print path not node efi_loader: fix efi_convert_device_node_to_text efi_loader: reimplement LocateDevicePath efi_selftest: test EFI_DEVICE_PATH_TO_TEXT_PROTOCOL efi_loader: efi_disk: use efi_add_protocol efi_loader: efi_net: use efi_add_protocol efi_loader: efi_gop: use efi_add_protocol efi_loader: simplify efi_open_protocol efi_loader: simplify find_obj efi_loader: manage protocols in a linked list efi_selftest: compile without special compiler flags
include/efi_loader.h | 6 +- lib/efi_loader/efi_bootmgr.c | 4 +- lib/efi_loader/efi_boottime.c | 249 +++++++++++---------- lib/efi_loader/efi_device_path.c | 43 ++-- lib/efi_loader/efi_device_path_to_text.c | 161 +++++++------- lib/efi_loader/efi_disk.c | 40 ++-- lib/efi_loader/efi_gop.c | 16 +- lib/efi_loader/efi_net.c | 35 +-- lib/efi_selftest/Makefile | 24 +- lib/efi_selftest/efi_selftest_devicepath.c | 340 +++++++++++++++++++++++++++++ 10 files changed, 643 insertions(+), 275 deletions(-) create mode 100644 lib/efi_selftest/efi_selftest_devicepath.c
Assignments should not be made in the middle of nowhere.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_bootmgr.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 857d88a879..d8d0e495f7 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -120,10 +120,10 @@ static void *try_load_entry(uint16_t n, struct efi_device_path **device_path,
if (lo.attributes & LOAD_OPTION_ACTIVE) { efi_status_t ret; - u16 *str = NULL; + u16 *str = efi_dp_str(lo.file_path);
debug("%s: trying to load "%ls" from: %ls\n", __func__, - lo.label, (str = efi_dp_str(lo.file_path))); + lo.label, str); efi_free_pool(str);
ret = efi_load_image_from_path(lo.file_path, &image);
u16 *str = NULL;
efi_free_pool(str);lo.label, str);
I believe the idea was to only go through efi_dp_str() if debugging is enabled.
Maybe write it as
#ifdef DEBUG u16 *str = efi_dp_str(...); #else u16 *str = NULL, #endif
instead?
Alex
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 857d88a879..d8d0e495f7 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -120,10 +120,10 @@ static void *try_load_entry(uint16_t n, struct efi_device_path **device_path, if (lo.attributes & LOAD_OPTION_ACTIVE) { efi_status_t ret; - u16 *str = NULL; + u16 *str = efi_dp_str(lo.file_path); debug("%s: trying to load "%ls" from: %ls\n", __func__, - lo.label, (str = efi_dp_str(lo.file_path))); + lo.label, str); efi_free_pool(str);
Maybe write it as
#ifdef DEBUG
We would have to evaluate _DEBUG here like debug does.
Regards
Heinrich
instead?
Alex
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_loader.h | 6 ++- lib/efi_loader/efi_boottime.c | 107 ++++++++++++++++++++---------------------- lib/efi_loader/efi_disk.c | 1 + lib/efi_loader/efi_gop.c | 1 + lib/efi_loader/efi_net.c | 1 + 5 files changed, 58 insertions(+), 58 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index e1f0af3496..a73bbc1269 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -101,6 +101,8 @@ extern unsigned int __efi_runtime_rel_start, __efi_runtime_rel_stop; * interface (usually a struct with callback functions), this struct maps the * protocol GUID to the respective protocol interface */ struct efi_handler { + /* Link to the list of protocols of a handle */ + struct list_head link; const efi_guid_t *guid; void *protocol_interface; }; @@ -115,8 +117,8 @@ struct efi_handler { struct efi_object { /* Every UEFI object is part of a global object list */ struct list_head link; - /* We support up to 16 "protocols" an object can be accessed through */ - struct efi_handler protocols[16]; + /* The list of protocols */ + struct list_head protocols; /* The object spawner can either use this for data or as identifier */ void *handle; }; diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 2b3db162a1..cee0cb1390 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -339,6 +339,7 @@ efi_status_t efi_create_handle(void **handle) return r; memset(obj, 0, sizeof(struct efi_object)); obj->handle = obj; + INIT_LIST_HEAD(&obj->protocols); list_add_tail(&obj->link, &efi_obj_list); *handle = obj; return r; @@ -715,18 +716,17 @@ efi_status_t efi_search_protocol(const void *handle, struct efi_handler **handler) { struct efi_object *efiobj; - size_t i; - struct efi_handler *protocol; + struct list_head *lhandle;
if (!handle || !protocol_guid) return EFI_INVALID_PARAMETER; efiobj = efi_search_obj(handle); if (!efiobj) return EFI_INVALID_PARAMETER; - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - protocol = &efiobj->protocols[i]; - if (!protocol->guid) - continue; + list_for_each(lhandle, &efiobj->protocols) { + struct efi_handler *protocol; + + protocol = list_entry(lhandle, struct efi_handler, link); if (!guidcmp(protocol->guid, protocol_guid)) { if (handler) *handler = protocol; @@ -750,7 +750,6 @@ efi_status_t efi_add_protocol(const void *handle, const efi_guid_t *protocol, struct efi_object *efiobj; struct efi_handler *handler; efi_status_t ret; - size_t i;
efiobj = efi_search_obj(handle); if (!efiobj) @@ -761,16 +760,10 @@ efi_status_t efi_add_protocol(const void *handle, const efi_guid_t *protocol, handler = calloc(1, sizeof(struct efi_handler)); if (!handler) return EFI_OUT_OF_RESOURCES; - /* Install protocol in first empty slot. */ - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - handler = &efiobj->protocols[i]; - if (handler->guid) - continue; - handler->guid = protocol; - handler->protocol_interface = protocol_interface; - return EFI_SUCCESS; - } - return EFI_OUT_OF_RESOURCES; + handler->guid = protocol; + handler->protocol_interface = protocol_interface; + list_add_tail(&handler->link, &efiobj->protocols); + return EFI_SUCCESS; }
/* @@ -790,10 +783,10 @@ efi_status_t efi_remove_protocol(const void *handle, const efi_guid_t *protocol, ret = efi_search_protocol(handle, protocol, &handler); if (ret != EFI_SUCCESS) return ret; - if (handler->protocol_interface != protocol_interface) - return EFI_NOT_FOUND; - handler->guid = NULL; - handler->protocol_interface = NULL; + if (guidcmp(handler->guid, protocol)) + return EFI_INVALID_PARAMETER; + list_del(&handler->link); + free(handler); return EFI_SUCCESS; }
@@ -806,17 +799,22 @@ efi_status_t efi_remove_protocol(const void *handle, const efi_guid_t *protocol, efi_status_t efi_remove_all_protocols(const void *handle) { struct efi_object *efiobj; - struct efi_handler *handler; - size_t i; + struct list_head *lhandle; + struct list_head *pos;
efiobj = efi_search_obj(handle); if (!efiobj) return EFI_INVALID_PARAMETER; + list_for_each_safe(lhandle, pos, &efiobj->protocols) { + struct efi_handler *protocol; + efi_status_t ret;
- for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - handler = &efiobj->protocols[i]; - handler->guid = NULL; - handler->protocol_interface = NULL; + protocol = list_entry(lhandle, struct efi_handler, link); + + ret = efi_remove_protocol(handle, protocol->guid, + protocol->protocol_interface); + if (ret != EFI_SUCCESS) + return ret; } return EFI_SUCCESS; } @@ -1171,6 +1169,7 @@ void efi_setup_loaded_image(struct efi_loaded_image *info, struct efi_object *ob if (device_path) info->device_handle = efi_dp_find_obj(device_path, NULL);
+ INIT_LIST_HEAD(&obj->protocols); list_add_tail(&obj->link, &efi_obj_list); /* * When asking for the device path interface, return @@ -1648,8 +1647,7 @@ static efi_status_t EFIAPI efi_protocols_per_handle(void *handle, { unsigned long buffer_size; struct efi_object *efiobj; - unsigned long i, j; - struct list_head *lhandle; + struct list_head *protocol_handle; efi_status_t r;
EFI_ENTRY("%p, %p, %p", handle, protocol_buffer, @@ -1660,36 +1658,33 @@ static efi_status_t EFIAPI efi_protocols_per_handle(void *handle,
*protocol_buffer = NULL; *protocol_buffer_count = 0; - list_for_each(lhandle, &efi_obj_list) { - efiobj = list_entry(lhandle, struct efi_object, link);
- if (efiobj->handle != handle) - continue; + efiobj = efi_search_obj(handle); + if (!efiobj) + return EFI_EXIT(EFI_INVALID_PARAMETER);
- /* Count protocols */ - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - if (efiobj->protocols[i].guid) - ++*protocol_buffer_count; - } - /* Copy guids */ - if (*protocol_buffer_count) { - buffer_size = sizeof(efi_guid_t *) * - *protocol_buffer_count; - r = efi_allocate_pool(EFI_ALLOCATE_ANY_PAGES, - buffer_size, - (void **)protocol_buffer); - if (r != EFI_SUCCESS) - return EFI_EXIT(r); - j = 0; - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); ++i) { - if (efiobj->protocols[i].guid) { - (*protocol_buffer)[j] = (void *) - efiobj->protocols[i].guid; - ++j; - } - } + /* Count protocols */ + list_for_each(protocol_handle, &efiobj->protocols) { + ++*protocol_buffer_count; + } + + /* Copy guids */ + if (*protocol_buffer_count) { + size_t j = 0; + + buffer_size = sizeof(efi_guid_t *) * *protocol_buffer_count; + r = efi_allocate_pool(EFI_ALLOCATE_ANY_PAGES, buffer_size, + (void **)protocol_buffer); + if (r != EFI_SUCCESS) + return EFI_EXIT(r); + list_for_each(protocol_handle, &efiobj->protocols) { + struct efi_handler *protocol; + + protocol = list_entry(protocol_handle, + struct efi_handler, link); + (*protocol_buffer)[j] = (void *)protocol->guid; + ++j; } - break; }
return EFI_EXIT(EFI_SUCCESS); diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 1d6cf3122f..af8db40e19 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -224,6 +224,7 @@ static void efi_disk_add_dev(const char *name, goto out_of_memory;
/* Hook up to the device list */ + INIT_LIST_HEAD(&diskobj->parent.protocols); list_add_tail(&diskobj->parent.link, &efi_obj_list);
/* Fill in object data */ diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index 7b74d6ef33..498184d754 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -180,6 +180,7 @@ int efi_gop_register(void) }
/* Hook up to the device list */ + INIT_LIST_HEAD(&gopobj->parent.protocols); list_add_tail(&gopobj->parent.link, &efi_obj_list);
/* Fill in object data */ diff --git a/lib/efi_loader/efi_net.c b/lib/efi_loader/efi_net.c index 8b2f682351..74a67c5365 100644 --- a/lib/efi_loader/efi_net.c +++ b/lib/efi_loader/efi_net.c @@ -296,6 +296,7 @@ int efi_net_register(void) goto out_of_memory;
/* Hook net up to the device list */ + INIT_LIST_HEAD(&netobj->parent.protocols); list_add_tail(&netobj->parent.link, &efi_obj_list);
I guess you did not mean to send this email? :)
Alex
Alex
Yes this is duplicate to [PATCH 12/13] efi_loader: manage protocols in a linked list
Regards
Heinrich
In the format specifier we want to specify the maximum width in case an ending \0 is missing.
So slen must be used as precision and not as field width.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_device_path_to_text.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 62771338f0..98617cf163 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -153,7 +153,7 @@ static char *dp_media(char *s, struct efi_device_path *dp) struct efi_device_path_file_path *fp = (struct efi_device_path_file_path *)dp; int slen = (dp->length - sizeof(*dp)) / 2; - s += sprintf(s, "/%-*ls", slen, fp->str); + s += sprintf(s, "/%-.*ls", slen, fp->str); break; } default:
efi_dp_str is meant to print a device path and not a device node.
The old coding only worked because efi_convert_device_node_to_text was screwed up to expect paths instead of nodes.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_device_path_to_text.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 98617cf163..ad248cb492 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -208,13 +208,6 @@ static uint16_t *efi_convert_device_node_to_text( return out; }
-/* helper for debug prints.. efi_free_pool() the result. */ -uint16_t *efi_dp_str(struct efi_device_path *dp) -{ - return efi_convert_device_node_to_text(dp, true, true); -} - - static uint16_t EFIAPI *efi_convert_device_node_to_text_ext( struct efi_device_path *device_node, bool display_only, @@ -251,6 +244,12 @@ static uint16_t EFIAPI *efi_convert_device_path_to_text( return buffer; }
+/* helper for debug prints.. efi_free_pool() the result. */ +uint16_t *efi_dp_str(struct efi_device_path *dp) +{ + return EFI_CALL(efi_convert_device_path_to_text(dp, true, true)); +} + const struct efi_device_path_to_text_protocol efi_device_path_to_text = { .convert_device_node_to_text = efi_convert_device_node_to_text_ext, .convert_device_path_to_text = efi_convert_device_path_to_text,
We need to implement to different functions for the EFI_DEVICE_PATH_TO_TEXT_PROTOCOL: ConvertDeviceNodeToText ConvertDevicePathToText
A recent patch screwed up efi_convert_device_node_to_text to expect a device path and not a node.
The patch makes both service functions work again.
efi_convert_device_node_to_text is renamed to efi_convert_single_device_node_to_text and efi_convert_device_node_to_text_ext is renamed to efi_convert_device_node_to_text to avoid future confusion.
A test of ConvertDeviceNodeToText will be provided in a follow-up patch.
Fixes: adae4313cdd efi_loader: flesh out device-path to text Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_device_path_to_text.c | 148 +++++++++++++++++-------------- 1 file changed, 82 insertions(+), 66 deletions(-)
diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index ad248cb492..3a9d5e4122 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -12,12 +12,31 @@ #define MAC_OUTPUT_LEN 22 #define UNKNOWN_OUTPUT_LEN 23
+#define MAX_NODE_LEN 512 +#define MAX_PATH_LEN 1024 + const efi_guid_t efi_guid_device_path_to_text_protocol = EFI_DEVICE_PATH_TO_TEXT_PROTOCOL_GUID;
+static u16 *efi_str_to_u16(char *str) +{ + efi_uintn_t len; + u16 *out; + efi_status_t ret; + + len = strlen(str) + 1; + ret = efi_allocate_pool(EFI_ALLOCATE_ANY_PAGES, len * sizeof(u16), + (void **)&out); + if (ret != EFI_SUCCESS) + return NULL; + ascii2unicode(out, str); + out[len - 1] = 0; + return out; +} + static char *dp_unknown(char *s, struct efi_device_path *dp) { - s += sprintf(s, "/UNKNOWN(%04x,%04x)", dp->type, dp->sub_type); + s += sprintf(s, "UNKNOWN(%04x,%04x)", dp->type, dp->sub_type); return s; }
@@ -27,7 +46,7 @@ static char *dp_hardware(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_MEMORY: { struct efi_device_path_memory *mdp = (struct efi_device_path_memory *)dp; - s += sprintf(s, "/MemoryMapped(0x%x,0x%llx,0x%llx)", + s += sprintf(s, "MemoryMapped(0x%x,0x%llx,0x%llx)", mdp->memory_type, mdp->start_address, mdp->end_address); @@ -36,7 +55,7 @@ static char *dp_hardware(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_VENDOR: { struct efi_device_path_vendor *vdp = (struct efi_device_path_vendor *)dp; - s += sprintf(s, "/VenHw(%pUl)", &vdp->guid); + s += sprintf(s, "VenHw(%pUl)", &vdp->guid); break; } default: @@ -52,7 +71,7 @@ static char *dp_acpi(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_ACPI_DEVICE: { struct efi_device_path_acpi_path *adp = (struct efi_device_path_acpi_path *)dp; - s += sprintf(s, "/Acpi(PNP%04x", EISA_PNP_NUM(adp->hid)); + s += sprintf(s, "Acpi(PNP%04x", EISA_PNP_NUM(adp->hid)); if (adp->uid) s += sprintf(s, ",%d", adp->uid); s += sprintf(s, ")"); @@ -71,7 +90,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_MSG_USB: { struct efi_device_path_usb *udp = (struct efi_device_path_usb *)dp; - s += sprintf(s, "/Usb(0x%x,0x%x)", udp->parent_port_number, + s += sprintf(s, "Usb(0x%x,0x%x)", udp->parent_port_number, udp->usb_interface); break; } @@ -82,7 +101,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) if (mdp->if_type != 0 && mdp->if_type != 1) break;
- s += sprintf(s, "/MAC(%02x%02x%02x%02x%02x%02x,0x%1x)", + s += sprintf(s, "MAC(%02x%02x%02x%02x%02x%02x,0x%1x)", mdp->mac.addr[0], mdp->mac.addr[1], mdp->mac.addr[2], mdp->mac.addr[3], mdp->mac.addr[4], mdp->mac.addr[5], @@ -94,7 +113,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) struct efi_device_path_usb_class *ucdp = (struct efi_device_path_usb_class *)dp;
- s += sprintf(s, "/USBClass(%x,%x,%x,%x,%x)", + s += sprintf(s, "USBClass(%x,%x,%x,%x,%x)", ucdp->vendor_id, ucdp->product_id, ucdp->device_class, ucdp->device_subclass, ucdp->device_protocol); @@ -108,7 +127,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) "SDCard" : "MMC"; struct efi_device_path_sd_mmc_path *sddp = (struct efi_device_path_sd_mmc_path *)dp; - s += sprintf(s, "/%s(Slot%u)", typename, sddp->slot_number); + s += sprintf(s, "%s(Slot%u)", typename, sddp->slot_number); break; } default: @@ -128,15 +147,15 @@ static char *dp_media(char *s, struct efi_device_path *dp)
switch (hddp->signature_type) { case SIG_TYPE_MBR: - s += sprintf(s, "/HD(Part%d,Sig%08x)", + s += sprintf(s, "HD(Part%d,Sig%08x)", hddp->partition_number, *(uint32_t *)sig); break; case SIG_TYPE_GUID: - s += sprintf(s, "/HD(Part%d,Sig%pUl)", + s += sprintf(s, "HD(Part%d,Sig%pUl)", hddp->partition_number, sig); default: - s += sprintf(s, "/HD(Part%d,MBRType=%02x,SigType=%02x)", + s += sprintf(s, "HD(Part%d,MBRType=%02x,SigType=%02x)", hddp->partition_number, hddp->partmap_type, hddp->signature_type); } @@ -146,14 +165,16 @@ static char *dp_media(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_CDROM_PATH: { struct efi_device_path_cdrom_path *cddp = (struct efi_device_path_cdrom_path *)dp; - s += sprintf(s, "/CDROM(0x%x)", cddp->boot_entry); + s += sprintf(s, "CDROM(0x%x)", cddp->boot_entry); break; } case DEVICE_PATH_SUB_TYPE_FILE_PATH: { struct efi_device_path_file_path *fp = (struct efi_device_path_file_path *)dp; int slen = (dp->length - sizeof(*dp)) / 2; - s += sprintf(s, "/%-.*ls", slen, fp->str); + if (slen > MAX_NODE_LEN - 2) + slen = MAX_NODE_LEN - 2; + s += sprintf(s, "%-.*ls", slen, fp->str); break; } default: @@ -163,65 +184,56 @@ static char *dp_media(char *s, struct efi_device_path *dp) return s; }
-static uint16_t *efi_convert_device_node_to_text( - struct efi_device_path *dp, - bool display_only, - bool allow_shortcuts) +/* + * Converts a single node to a char string. + * + * @buffer output buffer + * @dp device path or node + * @return end of string + */ +static char *efi_convert_single_device_node_to_text( + char *buffer, + struct efi_device_path *dp) { - unsigned long len; - efi_status_t r; - char buf[512]; /* this ought be be big enough for worst case */ - char *str = buf; - uint16_t *out; - - while (dp) { - switch (dp->type) { - case DEVICE_PATH_TYPE_HARDWARE_DEVICE: - str = dp_hardware(str, dp); - break; - case DEVICE_PATH_TYPE_ACPI_DEVICE: - str = dp_acpi(str, dp); - break; - case DEVICE_PATH_TYPE_MESSAGING_DEVICE: - str = dp_msging(str, dp); - break; - case DEVICE_PATH_TYPE_MEDIA_DEVICE: - str = dp_media(str, dp); - break; - default: - str = dp_unknown(str, dp); - } + char *str = buffer;
- dp = efi_dp_next(dp); + switch (dp->type) { + case DEVICE_PATH_TYPE_HARDWARE_DEVICE: + str = dp_hardware(str, dp); + break; + case DEVICE_PATH_TYPE_ACPI_DEVICE: + str = dp_acpi(str, dp); + break; + case DEVICE_PATH_TYPE_MESSAGING_DEVICE: + str = dp_msging(str, dp); + break; + case DEVICE_PATH_TYPE_MEDIA_DEVICE: + str = dp_media(str, dp); + break; + default: + str = dp_unknown(str, dp); }
- *str++ = '\0'; - - len = str - buf; - r = efi_allocate_pool(EFI_ALLOCATE_ANY_PAGES, 2 * len, (void **)&out); - if (r != EFI_SUCCESS) - return NULL; - - ascii2unicode(out, buf); - out[len - 1] = 0; - - return out; + *str = '\0'; + return str; }
-static uint16_t EFIAPI *efi_convert_device_node_to_text_ext( +static uint16_t EFIAPI *efi_convert_device_node_to_text( struct efi_device_path *device_node, bool display_only, bool allow_shortcuts) { - uint16_t *buffer; + char str[MAX_NODE_LEN]; + uint16_t *text;
EFI_ENTRY("%p, %d, %d", device_node, display_only, allow_shortcuts);
- buffer = efi_convert_device_node_to_text(device_node, display_only, - allow_shortcuts); + efi_convert_single_device_node_to_text(str, device_node); + + text = efi_str_to_u16(str);
EFI_EXIT(EFI_SUCCESS); - return buffer; + return text; }
static uint16_t EFIAPI *efi_convert_device_path_to_text( @@ -229,19 +241,23 @@ static uint16_t EFIAPI *efi_convert_device_path_to_text( bool display_only, bool allow_shortcuts) { - uint16_t *buffer; + uint16_t *text; + char buffer[MAX_PATH_LEN]; + char *str = buffer;
EFI_ENTRY("%p, %d, %d", device_path, display_only, allow_shortcuts);
- /* - * Our device paths are all of depth one. So its is sufficient to - * to convert the first node. - */ - buffer = efi_convert_device_node_to_text(device_path, display_only, - allow_shortcuts); + while (device_path && + str + MAX_NODE_LEN < buffer + MAX_PATH_LEN) { + *str++ = '/'; + str = efi_convert_single_device_node_to_text(str, device_path); + device_path = efi_dp_next(device_path); + } + + text = efi_str_to_u16(buffer);
/* helper for debug prints.. efi_free_pool() the result. */ @@ -251,6 +267,6 @@ uint16_t *efi_dp_str(struct efi_device_path *dp) }
const struct efi_device_path_to_text_protocol efi_device_path_to_text = { - .convert_device_node_to_text = efi_convert_device_node_to_text_ext, + .convert_device_node_to_text = efi_convert_device_node_to_text, .convert_device_path_to_text = efi_convert_device_path_to_text, };
The current implementation of efi_locate_device_path does not match the UEFI specification. It completely ignores the protocol parameters.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 106 ++++++++++++++++++++++++++++++------------ 1 file changed, 76 insertions(+), 30 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 9b5512f086..7457d54739 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1080,36 +1080,6 @@ static efi_status_t EFIAPI efi_locate_handle_ext( buffer_size, buffer)); }
-/* - * Get the device path and handle of an device implementing a protocol. - * - * This function implements the LocateDevicePath service. - * See the Unified Extensible Firmware Interface (UEFI) specification - * for details. - * - * @protocol GUID of the protocol - * @device_path device path - * @device handle of the device - * @return status code - */ -static efi_status_t EFIAPI efi_locate_device_path( - const efi_guid_t *protocol, - struct efi_device_path **device_path, - efi_handle_t *device) -{ - struct efi_object *efiobj; - - EFI_ENTRY("%pUl, %p, %p", protocol, device_path, device); - - efiobj = efi_dp_find_obj(*device_path, device_path); - if (!efiobj) - return EFI_EXIT(EFI_NOT_FOUND); - - *device = efiobj->handle; - - return EFI_EXIT(EFI_SUCCESS); -} - /* Collapses configuration table entries, removing index i */ static void efi_remove_configuration_table(int i) { @@ -1813,6 +1783,82 @@ static efi_status_t EFIAPI efi_locate_protocol(const efi_guid_t *protocol, return EFI_EXIT(EFI_NOT_FOUND); }
+/* + * Get the device path and handle of an device implementing a protocol. + * + * This function implements the LocateDevicePath service. + * See the Unified Extensible Firmware Interface (UEFI) specification + * for details. + * + * @protocol GUID of the protocol + * @device_path device path + * @device handle of the device + * @return status code + */ +static efi_status_t EFIAPI efi_locate_device_path( + const efi_guid_t *protocol, + struct efi_device_path **device_path, + efi_handle_t *device) +{ + struct efi_device_path *dp; + size_t i; + struct efi_handler *handler; + efi_handle_t *handles; + size_t len, len_dp; + size_t len_best = 0; + efi_uintn_t no_handles; + u8 *remainder; + efi_status_t ret; + + EFI_ENTRY("%pUl, %p, %p", protocol, device_path, device); + + if (!protocol || !device_path || !*device_path || !device) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + /* Find end of device path */ + len = efi_dp_size(*device_path); + + /* Get all handles implementing the protocol */ + ret = EFI_CALL(efi_locate_handle_buffer(BY_PROTOCOL, protocol, NULL, + &no_handles, &handles)); + if (ret != EFI_SUCCESS) + goto out; + + for (i = 0; i < no_handles; ++i) { + /* Find the device path protocol */ + ret = efi_search_protocol(handles[i], &efi_guid_device_path, + &handler); + if (ret != EFI_SUCCESS) + continue; + dp = (struct efi_device_path *)handler->protocol_interface; + len_dp = efi_dp_size(dp); + /* + * This handle can only be a better fit + * if its device path length is longer then the best fit and + * if its device path length is shorter of equal the searched + * device path. + */ + if (len_dp <= len_best || len_dp > len) + continue; + /* Check if dp is a subpath of device_path. */ + if (memcmp(*device_path, dp, len_dp)) + continue; + *device = handles[i]; + len_best = len_dp; + } + if (len_best) { + remainder = (u8 *)*device_path + len_best; + *device_path = (struct efi_device_path *)remainder; + ret = EFI_SUCCESS; + } else { + ret = EFI_NOT_FOUND; + } +out: + return EFI_EXIT(ret); +} + /* * Install multiple protocol interfaces. *
Provide a test for the EFI_DEVICE_PATH_TO_TEXT_PROTOCOL protocol.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Makefile | 3 + lib/efi_selftest/efi_selftest_devicepath.c | 340 +++++++++++++++++++++++++++++ 2 files changed, 343 insertions(+) create mode 100644 lib/efi_selftest/efi_selftest_devicepath.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 1851c17db6..d280eca5c3 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -11,6 +11,8 @@ CFLAGS_efi_selftest.o := $(CFLAGS_EFI) CFLAGS_REMOVE_efi_selftest.o := $(CFLAGS_NON_EFI) CFLAGS_efi_selftest_console.o := $(CFLAGS_EFI) CFLAGS_REMOVE_efi_selftest_console.o := $(CFLAGS_NON_EFI) +CFLAGS_efi_selftest_devicepathe.o := $(CFLAGS_EFI) +CFLAGS_REMOVE_efi_selftest_devicepath.o := $(CFLAGS_NON_EFI) CFLAGS_efi_selftest_events.o := $(CFLAGS_EFI) CFLAGS_REMOVE_efi_selftest_events.o := $(CFLAGS_NON_EFI) CFLAGS_efi_selftest_exitbootservices.o := $(CFLAGS_EFI) @@ -33,6 +35,7 @@ CFLAGS_REMOVE_efi_selftest_watchdog.o := $(CFLAGS_NON_EFI) obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += \ efi_selftest.o \ efi_selftest_console.o \ +efi_selftest_devicepath.o \ efi_selftest_events.o \ efi_selftest_exitbootservices.o \ efi_selftest_gop.o \ diff --git a/lib/efi_selftest/efi_selftest_devicepath.c b/lib/efi_selftest/efi_selftest_devicepath.c new file mode 100644 index 0000000000..6c6185c050 --- /dev/null +++ b/lib/efi_selftest/efi_selftest_devicepath.c @@ -0,0 +1,340 @@ +/* + * efi_selftest_devicepath + * + * Copyright (c) 2017 Heinrich Schuchardt xypron.glpk@gmx.de + * + * SPDX-License-Identifier: GPL-2.0+ + * + * This unit test checks the following protocol services: + * DevicePathToText + */ + +#include <efi_selftest.h> + +static struct efi_boot_services *boottime; + +static efi_handle_t handle1; +static efi_handle_t handle2; +static efi_handle_t handle3; + +struct interface { + void (EFIAPI * inc)(void); +} interface; + +static efi_guid_t guid_protocol = + EFI_GUID(0xdbca4c98, 0x6cb0, 0x694d, + 0x08, 0x72, 0x81, 0x9c, 0x65, 0x0c, 0xbb, 0x7d); + +static efi_guid_t guid_vendor1 = + EFI_GUID(0xdbca4c98, 0x6cb0, 0x694d, + 0x08, 0x72, 0x81, 0x9c, 0x65, 0x0c, 0xbb, 0xb1); + +static efi_guid_t guid_vendor2 = + EFI_GUID(0xdbca4c98, 0x6cb0, 0x694d, + 0x08, 0x72, 0x81, 0x9c, 0x65, 0x0c, 0xbb, 0xa2); + +static efi_guid_t guid_vendor3 = + EFI_GUID(0xdbca4c98, 0x6cb0, 0x694d, + 0x08, 0x72, 0x81, 0x9c, 0x65, 0x0c, 0xbb, 0xc3); + +static u8 *dp1; +static u8 *dp2; +static u8 *dp3; + +struct efi_device_path_to_text_protocol *device_path_to_text; + +/* + * Setup unit test. + * + * Create three handles. Install a new protocol on two of them and + * provice device paths. + * + * handle1 + * guid interface + * handle2 + * guid interface + * handle3 + * + * @handle: handle of the loaded image + * @systable: system table + */ +static int setup(const efi_handle_t img_handle, + const struct efi_system_table *systable) +{ + struct efi_device_path_vendor vendor_node; + struct efi_device_path end_node; + efi_status_t ret; + + boottime = systable->boottime; + + ret = boottime->locate_protocol(&efi_guid_device_path_to_text_protocol, + NULL, (void **)&device_path_to_text); + if (ret != EFI_SUCCESS) { + device_path_to_text = NULL; + efi_st_printf( + "Device path to text protocol is not available.\n"); + return EFI_ST_FAILURE; + } + + ret = boottime->allocate_pool(EFI_LOADER_DATA, + sizeof(struct efi_device_path_vendor) + + sizeof(struct efi_device_path), + (void **)&dp1); + if (ret != EFI_SUCCESS) + goto out_of_memory; + + ret = boottime->allocate_pool(EFI_LOADER_DATA, 2 * + sizeof(struct efi_device_path_vendor) + + sizeof(struct efi_device_path), + (void **)&dp2); + if (ret != EFI_SUCCESS) + goto out_of_memory; + + ret = boottime->allocate_pool(EFI_LOADER_DATA, 3 * + sizeof(struct efi_device_path_vendor) + + sizeof(struct efi_device_path), + (void **)&dp3); + if (ret != EFI_SUCCESS) + goto out_of_memory; + + vendor_node.dp.type = DEVICE_PATH_TYPE_HARDWARE_DEVICE; + vendor_node.dp.sub_type = DEVICE_PATH_SUB_TYPE_VENDOR; + vendor_node.dp.length = sizeof(struct efi_device_path_vendor); + + boottime->copy_mem(&vendor_node.guid, &guid_vendor1, + sizeof(efi_guid_t)); + boottime->copy_mem(dp1, &vendor_node, + sizeof(struct efi_device_path_vendor)); + boottime->copy_mem(dp2, &vendor_node, + sizeof(struct efi_device_path_vendor)); + boottime->copy_mem(dp3, &vendor_node, + sizeof(struct efi_device_path_vendor)); + + boottime->copy_mem(&vendor_node.guid, &guid_vendor2, + sizeof(efi_guid_t)); + boottime->copy_mem(dp2 + sizeof(struct efi_device_path_vendor), + &vendor_node, sizeof(struct efi_device_path_vendor)); + boottime->copy_mem(dp3 + sizeof(struct efi_device_path_vendor), + &vendor_node, sizeof(struct efi_device_path_vendor)); + + boottime->copy_mem(&vendor_node.guid, &guid_vendor3, + sizeof(efi_guid_t)); + boottime->copy_mem(dp3 + 2 * sizeof(struct efi_device_path_vendor), + &vendor_node, sizeof(struct efi_device_path_vendor)); + + end_node.type = DEVICE_PATH_TYPE_END; + end_node.sub_type = DEVICE_PATH_SUB_TYPE_END; + end_node.length = sizeof(struct efi_device_path); + boottime->copy_mem(dp1 + sizeof(struct efi_device_path_vendor), + &end_node, sizeof(struct efi_device_path)); + boottime->copy_mem(dp2 + 2 * sizeof(struct efi_device_path_vendor), + &end_node, sizeof(struct efi_device_path)); + boottime->copy_mem(dp3 + 3 * sizeof(struct efi_device_path_vendor), + &end_node, sizeof(struct efi_device_path)); + + ret = boottime->install_protocol_interface(&handle1, + &efi_guid_device_path, + EFI_NATIVE_INTERFACE, + dp1); + if (ret != EFI_SUCCESS) { + efi_st_error("InstallProtocolInterface failed\n"); + return EFI_ST_FAILURE; + } + ret = boottime->install_protocol_interface(&handle1, + &guid_protocol, + EFI_NATIVE_INTERFACE, + &interface); + if (ret != EFI_SUCCESS) { + efi_st_error("InstallProtocolInterface failed\n"); + return EFI_ST_FAILURE; + } + ret = boottime->install_protocol_interface(&handle2, + &efi_guid_device_path, + EFI_NATIVE_INTERFACE, + dp2); + if (ret != EFI_SUCCESS) { + efi_st_error("InstallProtocolInterface failed\n"); + return EFI_ST_FAILURE; + } + ret = boottime->install_protocol_interface(&handle2, + &guid_protocol, + EFI_NATIVE_INTERFACE, + &interface); + if (ret != EFI_SUCCESS) { + efi_st_error("InstallProtocolInterface failed\n"); + return EFI_ST_FAILURE; + } + ret = boottime->install_protocol_interface(&handle3, + &efi_guid_device_path, + EFI_NATIVE_INTERFACE, + dp3); + if (ret != EFI_SUCCESS) { + efi_st_error("InstallProtocolInterface failed\n"); + return EFI_ST_FAILURE; + } + return EFI_ST_SUCCESS; + +out_of_memory: + efi_st_error("Out of memory\n"); + return EFI_ST_FAILURE; +} + +/* + * Tear down unit test. + * + */ +static int teardown(void) +{ + efi_status_t ret; + + ret = boottime->uninstall_protocol_interface(&handle1, + &efi_guid_device_path, + dp1); + if (ret != EFI_SUCCESS) + efi_st_todo("UninstallProtocolInterface failed\n"); + ret = boottime->uninstall_protocol_interface(&handle1, + &guid_protocol, + &interface); + if (ret != EFI_SUCCESS) + efi_st_todo("UninstallProtocolInterface failed\n"); + ret = boottime->uninstall_protocol_interface(&handle2, + &efi_guid_device_path, + dp2); + if (ret != EFI_SUCCESS) + efi_st_todo("UninstallProtocolInterface failed\n"); + ret = boottime->uninstall_protocol_interface(&handle2, + &guid_protocol, + &interface); + if (ret != EFI_SUCCESS) + efi_st_todo("UninstallProtocolInterface failed\n"); + ret = boottime->uninstall_protocol_interface(&handle3, + &efi_guid_device_path, + dp3); + if (ret != EFI_SUCCESS) + efi_st_todo("UninstallProtocolInterface failed\n"); + if (dp1) { + ret = boottime->free_pool(dp1); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + } + } + if (dp2) { + ret = boottime->free_pool(dp2); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + } + } + if (dp3) { + ret = boottime->free_pool(dp3); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + } + } + return EFI_ST_SUCCESS; +} + +/* + * Execute unit test. + * + */ +static int execute(void) +{ + struct efi_device_path *remaining_dp; + void *handle; + /* + * This device path node ends with the letter 't' of 'u-boot'. + * The following '.bin' does not belong to the node but is + * helps to test the correct truncation. + */ + struct { + struct efi_device_path dp; + u16 text[12]; + } __packed dp_node = { + { DEVICE_PATH_TYPE_MEDIA_DEVICE, + DEVICE_PATH_SUB_TYPE_FILE_PATH, + sizeof(struct efi_device_path) + 12}, + L"u-boot.bin", + }; + u16 *string; + efi_status_t ret; + + /* Test ConvertDevicePathToText */ + string = device_path_to_text->convert_device_path_to_text( + (struct efi_device_path *)dp2, true, false); + if (!string) { + efi_st_error("ConvertDevicePathToText failed\n"); + return EFI_ST_FAILURE; + } + efi_st_printf("dp2: %ps\n", string); + if (efi_st_strcmp_16_8( + string, + "/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbb1)/VenHw(dbca4c98-6cb0-694d-0872-819c650cbba2)") + ) { + efi_st_error("Incorrect text from ConvertDevicePathToText\n"); + return EFI_ST_FAILURE; + } + + ret = boottime->free_pool(string); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + } + + /* Test ConvertDeviceNodeToText */ + string = device_path_to_text->convert_device_node_to_text( + (struct efi_device_path *)&dp_node, true, false); + if (!string) { + efi_st_error("ConvertDeviceNodeToText failed\n"); + return EFI_ST_FAILURE; + } + efi_st_printf("dp_node: %ps\n", string); + ret = boottime->free_pool(string); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + } + if (efi_st_strcmp_16_8(string, "u-boot")) { + efi_st_error( + "Incorrect conversion by ConvertDeviceNodeToText\n"); + return EFI_ST_FAILURE; + } + + /* Test LocateDevicePath */ + remaining_dp = (struct efi_device_path *)dp3; + ret = boottime->locate_device_path(&guid_protocol, &remaining_dp, + &handle); + if (ret != EFI_SUCCESS) { + efi_st_error("LocateDevicePath failed\n"); + return EFI_ST_FAILURE; + } + if (handle != handle2) { + efi_st_error("LocateDevicePath returned wrong handle\n"); + return EFI_ST_FAILURE; + } + string = device_path_to_text->convert_device_path_to_text(remaining_dp, + true, false); + if (!string) { + efi_st_error("ConvertDevicePathToText failed\n"); + return EFI_ST_FAILURE; + } + efi_st_printf("remaining device path: %ps\n", string); + if (efi_st_strcmp_16_8(string, + "/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbc3)") + ) { + efi_st_error("LocateDevicePath: wrong remaining device path\n"); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} + +EFI_UNIT_TEST(devicepath) = { + .name = "device path", + .phase = EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, + .setup = setup, + .execute = execute, + .teardown = teardown, +};
Use efi_add_protocol to install protocols.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_disk.c | 39 +++++++++++++++++++++++---------------- 1 file changed, 23 insertions(+), 16 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index c6f0d732c1..1d6cf3122f 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -213,33 +213,40 @@ static void efi_disk_add_dev(const char *name, unsigned int part) { struct efi_disk_obj *diskobj; + efi_status_t ret;
/* Don't add empty devices */ if (!desc->lba) return;
diskobj = calloc(1, sizeof(*diskobj)); - if (!diskobj) { - printf("ERROR: Out of memory\n"); - return; - } + if (!diskobj) + goto out_of_memory; + + /* Hook up to the device list */ + list_add_tail(&diskobj->parent.link, &efi_obj_list);
/* Fill in object data */ diskobj->dp = efi_dp_from_part(desc, part); diskobj->part = part; - diskobj->parent.protocols[0].guid = &efi_block_io_guid; - diskobj->parent.protocols[0].protocol_interface = &diskobj->ops; - diskobj->parent.protocols[1].guid = &efi_guid_device_path; - diskobj->parent.protocols[1].protocol_interface = diskobj->dp; + diskobj->parent.handle = diskobj; + ret = efi_add_protocol(diskobj->parent.handle, &efi_block_io_guid, + &diskobj->ops); + if (ret != EFI_SUCCESS) + goto out_of_memory; + ret = efi_add_protocol(diskobj->parent.handle, &efi_guid_device_path, + diskobj->dp); + if (ret != EFI_SUCCESS) + goto out_of_memory; if (part >= 1) { diskobj->volume = efi_simple_file_system(desc, part, diskobj->dp); - diskobj->parent.protocols[2].guid = - &efi_simple_file_system_protocol_guid; - diskobj->parent.protocols[2].protocol_interface = - diskobj->volume; + ret = efi_add_protocol(diskobj->parent.handle, + &efi_simple_file_system_protocol_guid, + &diskobj->volume); + if (ret != EFI_SUCCESS) + goto out_of_memory; } - diskobj->parent.handle = diskobj; diskobj->ops = block_io_disk_template; diskobj->ifname = if_typename; diskobj->dev_index = dev_index; @@ -253,9 +260,9 @@ static void efi_disk_add_dev(const char *name, diskobj->media.io_align = desc->blksz; diskobj->media.last_block = desc->lba - offset; diskobj->ops.media = &diskobj->media; - - /* Hook up to the device list */ - list_add_tail(&diskobj->parent.link, &efi_obj_list); + return; +out_of_memory: + printf("ERROR: Out of memory\n"); }
static int efi_disk_create_eltorito(struct blk_desc *desc,
Use efi_add_protocol to add protocols.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_net.c | 34 ++++++++++++++++++++-------------- 1 file changed, 20 insertions(+), 14 deletions(-)
diff --git a/lib/efi_loader/efi_net.c b/lib/efi_loader/efi_net.c index a7b101e830..8b2f682351 100644 --- a/lib/efi_loader/efi_net.c +++ b/lib/efi_loader/efi_net.c @@ -292,20 +292,26 @@ int efi_net_register(void)
/* We only expose the "active" eth device, so one is enough */ netobj = calloc(1, sizeof(*netobj)); - if (!netobj) { - printf("ERROR: Out of memory\n"); - return 1; - } + if (!netobj) + goto out_of_memory; + + /* Hook net up to the device list */ + list_add_tail(&netobj->parent.link, &efi_obj_list);
/* Fill in object data */ - netobj->parent.protocols[0].guid = &efi_net_guid; - netobj->parent.protocols[0].protocol_interface = &netobj->net; - netobj->parent.protocols[1].guid = &efi_guid_device_path; - netobj->parent.protocols[1].protocol_interface = - efi_dp_from_eth(); - netobj->parent.protocols[2].guid = &efi_pxe_guid; - netobj->parent.protocols[2].protocol_interface = &netobj->pxe; netobj->parent.handle = &netobj->net; + r = efi_add_protocol(netobj->parent.handle, &efi_net_guid, + &netobj->net); + if (r != EFI_SUCCESS) + goto out_of_memory; + r = efi_add_protocol(netobj->parent.handle, &efi_guid_device_path, + efi_dp_from_eth()); + if (r != EFI_SUCCESS) + goto out_of_memory; + r = efi_add_protocol(netobj->parent.handle, &efi_pxe_guid, + &netobj->pxe); + if (r != EFI_SUCCESS) + goto out_of_memory; netobj->net.revision = EFI_SIMPLE_NETWORK_PROTOCOL_REVISION; netobj->net.start = efi_net_start; netobj->net.stop = efi_net_stop; @@ -330,9 +336,6 @@ int efi_net_register(void) if (dhcp_ack) netobj->pxe_mode.dhcp_ack = *dhcp_ack;
- /* Hook net up to the device list */ - list_add_tail(&netobj->parent.link, &efi_obj_list); - /* * Create WaitForPacket event. */ @@ -365,4 +368,7 @@ int efi_net_register(void) }
return 0; +out_of_memory: + printf("ERROR: Out of memory\n"); + return 1; }
Use efi_add_protocol to add protocol.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_gop.c | 15 ++++++++++----- 1 file changed, 10 insertions(+), 5 deletions(-)
diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index 7370eeee37..7b74d6ef33 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -132,6 +132,7 @@ int efi_gop_register(void) u32 bpix, col, row; u64 fb_base, fb_size; void *fb; + efi_status_t ret;
#ifdef CONFIG_DM_VIDEO struct udevice *vdev; @@ -178,10 +179,17 @@ int efi_gop_register(void) return 1; }
+ /* Hook up to the device list */ + list_add_tail(&gopobj->parent.link, &efi_obj_list); + /* Fill in object data */ - gopobj->parent.protocols[0].guid = &efi_gop_guid; - gopobj->parent.protocols[0].protocol_interface = &gopobj->ops; gopobj->parent.handle = &gopobj->ops; + ret = efi_add_protocol(gopobj->parent.handle, &efi_gop_guid, + &gopobj->ops); + if (ret != EFI_SUCCESS) { + printf("ERROR: Out of memory\n"); + return 1; + } gopobj->ops.query_mode = gop_query_mode; gopobj->ops.set_mode = gop_set_mode; gopobj->ops.blt = gop_blt; @@ -210,8 +218,5 @@ int efi_gop_register(void) gopobj->bpix = bpix; gopobj->fb = fb;
- /* Hook up to the device list */ - list_add_tail(&gopobj->parent.link, &efi_obj_list); - return 0; }
Use function efi_search_protocol.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 36 ++++++------------------------------ 1 file changed, 6 insertions(+), 30 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 7457d54739..2b3db162a1 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2051,8 +2051,7 @@ static efi_status_t EFIAPI efi_open_protocol( void **protocol_interface, void *agent_handle, void *controller_handle, uint32_t attributes) { - struct list_head *lhandle; - int i; + struct efi_handler *handler; efi_status_t r = EFI_INVALID_PARAMETER;
EFI_ENTRY("%p, %pUl, %p, %p, %p, 0x%x", handle, protocol, @@ -2065,8 +2064,6 @@ static efi_status_t EFIAPI efi_open_protocol( goto out; }
- EFI_PRINT_GUID("protocol", protocol); - switch (attributes) { case EFI_OPEN_PROTOCOL_BY_HANDLE_PROTOCOL: case EFI_OPEN_PROTOCOL_GET_PROTOCOL: @@ -2087,33 +2084,12 @@ static efi_status_t EFIAPI efi_open_protocol( goto out; }
- list_for_each(lhandle, &efi_obj_list) { - struct efi_object *efiobj; - efiobj = list_entry(lhandle, struct efi_object, link); - - if (efiobj->handle != handle) - continue; - - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - struct efi_handler *handler = &efiobj->protocols[i]; - const efi_guid_t *hprotocol = handler->guid; - if (!hprotocol) - continue; - if (!guidcmp(hprotocol, protocol)) { - if (attributes != - EFI_OPEN_PROTOCOL_TEST_PROTOCOL) { - *protocol_interface = - handler->protocol_interface; - } - r = EFI_SUCCESS; - goto out; - } - } - goto unsupported; - } + r = efi_search_protocol(handle, protocol, &handler); + if (r != EFI_SUCCESS) + goto out;
-unsupported: - r = EFI_UNSUPPORTED; + if (attributes != EFI_OPEN_PROTOCOL_TEST_PROTOCOL) + *protocol_interface = handler->protocol_interface; out: return EFI_EXIT(r); }
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_device_path.c | 43 ++++++++++++++++++---------------------- 1 file changed, 19 insertions(+), 24 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 024877161b..98034216da 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -128,32 +128,27 @@ static struct efi_object *find_obj(struct efi_device_path *dp, bool short_path, struct efi_object *efiobj;
list_for_each_entry(efiobj, &efi_obj_list, link) { - int i; - - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - struct efi_handler *handler = &efiobj->protocols[i]; - struct efi_device_path *obj_dp; - - if (!handler->guid) - break; - - if (guidcmp(handler->guid, &efi_guid_device_path)) - continue; - - obj_dp = handler->protocol_interface; - - do { - if (efi_dp_match(dp, obj_dp) == 0) { - if (rem) { - *rem = ((void *)dp) + - efi_dp_size(obj_dp); - } - return efiobj; + struct efi_handler *handler; + struct efi_device_path *obj_dp; + efi_status_t ret; + + ret = efi_search_protocol(efiobj->handle, + &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + obj_dp = handler->protocol_interface; + + do { + if (efi_dp_match(dp, obj_dp) == 0) { + if (rem) { + *rem = ((void *)dp) + + efi_dp_size(obj_dp); } + return efiobj; + }
- obj_dp = shorten_path(efi_dp_next(obj_dp)); - } while (short_path && obj_dp); - } + obj_dp = shorten_path(efi_dp_next(obj_dp)); + } while (short_path && obj_dp); }
return NULL;
- interface (usually a struct with callback functions), this struct maps the
- protocol GUID to the respective protocol interface */
- /* Link to the list of protocols of a handle */
- struct list_head link; const efi_guid_t *guid; void *protocol_interface; };
- /* The list of protocols */
- struct list_head protocols; /* The object spawner can either use this for data or as identifier */ void *handle; };
- INIT_LIST_HEAD(&obj->protocols); list_add_tail(&obj->link, &efi_obj_list); *handle = obj; return r;
- size_t i;
continue;
- list_for_each(lhandle, &efiobj->protocols) {
if (!guidcmp(protocol->guid, protocol_guid)) { if (handler) *handler = protocol;protocol = list_entry(lhandle, struct efi_handler, link);
size_t i;
if (handler->guid)
continue;
return EFI_SUCCESS;
- if (guidcmp(handler->guid, protocol))
- list_del(&handler->link);
- free(handler); return EFI_SUCCESS; }
- size_t i;
efi_status_t ret;
} return EFI_SUCCESS; }return ret;
- INIT_LIST_HEAD(&obj->protocols); list_add_tail(&obj->link, &efi_obj_list); /*
- When asking for the device path interface, return
continue;
- efiobj = efi_search_obj(handle);
- if (!efiobj)
/* Copy guids */
buffer_size,
return EFI_EXIT(r);
j = 0;
++j;
- list_for_each(protocol_handle, &efiobj->protocols) {
- /* Copy guids */
size_t j = 0;
return EFI_EXIT(r);
}++j;
break;
- INIT_LIST_HEAD(&diskobj->parent.protocols); list_add_tail(&diskobj->parent.link, &efi_obj_list);
This seems to have become quite a common theme now. Maybe it's about time we add a helper function to manually add a precreated object to the object list (and clear the protocol list along the way)?
Alex
diff --git a/include/efi_loader.h b/include/efi_loader.h index e1f0af3496..a73bbc1269 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -101,6 +101,8 @@ extern unsigned int __efi_runtime_rel_start, __efi_runtime_rel_stop; * interface (usually a struct with callback functions), this struct maps the * protocol GUID to the respective protocol interface */ struct efi_handler { + /* Link to the list of protocols of a handle */ + struct list_head link; const efi_guid_t *guid; void *protocol_interface; }; @@ -115,8 +117,8 @@ struct efi_handler { struct efi_object { /* Every UEFI object is part of a global object list */ struct list_head link; - /* We support up to 16 "protocols" an object can be accessed through */ - struct efi_handler protocols[16]; + /* The list of protocols */ + struct list_head protocols; /* The object spawner can either use this for data or as identifier */ void *handle; }; diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 2b3db162a1..cee0cb1390 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -339,6 +339,7 @@ efi_status_t efi_create_handle(void **handle) return r; memset(obj, 0, sizeof(struct efi_object)); obj->handle = obj; + INIT_LIST_HEAD(&obj->protocols); list_add_tail(&obj->link, &efi_obj_list); *handle = obj; return r; @@ -715,18 +716,17 @@ efi_status_t efi_search_protocol(const void *handle, struct efi_handler **handler) { struct efi_object *efiobj; - size_t i; - struct efi_handler *protocol; + struct list_head *lhandle; if (!handle || !protocol_guid) return EFI_INVALID_PARAMETER; efiobj = efi_search_obj(handle); if (!efiobj) return EFI_INVALID_PARAMETER; - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - protocol = &efiobj->protocols[i]; - if (!protocol->guid) - continue; + list_for_each(lhandle, &efiobj->protocols) { + struct efi_handler *protocol;
+ protocol = list_entry(lhandle, struct efi_handler, link); if (!guidcmp(protocol->guid, protocol_guid)) { if (handler) *handler = protocol; @@ -750,7 +750,6 @@ efi_status_t efi_add_protocol(const void *handle, const efi_guid_t *protocol, struct efi_object *efiobj; struct efi_handler *handler; efi_status_t ret; - size_t i; efiobj = efi_search_obj(handle); if (!efiobj) @@ -761,16 +760,10 @@ efi_status_t efi_add_protocol(const void *handle, const efi_guid_t *protocol, handler = calloc(1, sizeof(struct efi_handler)); if (!handler) return EFI_OUT_OF_RESOURCES; - /* Install protocol in first empty slot. */ - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - handler = &efiobj->protocols[i]; - if (handler->guid) - continue; - handler->guid = protocol; - handler->protocol_interface = protocol_interface; - return EFI_SUCCESS; - } - return EFI_OUT_OF_RESOURCES; + handler->guid = protocol; + handler->protocol_interface = protocol_interface; + list_add_tail(&handler->link, &efiobj->protocols); + return EFI_SUCCESS; } /* @@ -790,10 +783,10 @@ efi_status_t efi_remove_protocol(const void *handle, const efi_guid_t *protocol, ret = efi_search_protocol(handle, protocol, &handler); if (ret != EFI_SUCCESS) return ret; - if (handler->protocol_interface != protocol_interface) - return EFI_NOT_FOUND; - handler->guid = NULL; - handler->protocol_interface = NULL; + if (guidcmp(handler->guid, protocol)) + return EFI_INVALID_PARAMETER; + list_del(&handler->link); + free(handler); return EFI_SUCCESS; } @@ -806,17 +799,22 @@ efi_status_t efi_remove_protocol(const void *handle, const efi_guid_t *protocol, efi_status_t efi_remove_all_protocols(const void *handle) { struct efi_object *efiobj; - struct efi_handler *handler; - size_t i; + struct list_head *lhandle; + struct list_head *pos; efiobj = efi_search_obj(handle); if (!efiobj) return EFI_INVALID_PARAMETER; + list_for_each_safe(lhandle, pos, &efiobj->protocols) { + struct efi_handler *protocol; + efi_status_t ret; - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - handler = &efiobj->protocols[i]; - handler->guid = NULL; - handler->protocol_interface = NULL; + protocol = list_entry(lhandle, struct efi_handler, link);
+ ret = efi_remove_protocol(handle, protocol->guid, + protocol->protocol_interface); + if (ret != EFI_SUCCESS) + return ret; } return EFI_SUCCESS; } @@ -1171,6 +1169,7 @@ void efi_setup_loaded_image(struct efi_loaded_image *info, struct efi_object *ob if (device_path) info->device_handle = efi_dp_find_obj(device_path, NULL); + INIT_LIST_HEAD(&obj->protocols); list_add_tail(&obj->link, &efi_obj_list); /* * When asking for the device path interface, return @@ -1648,8 +1647,7 @@ static efi_status_t EFIAPI efi_protocols_per_handle(void *handle, { unsigned long buffer_size; struct efi_object *efiobj; - unsigned long i, j; - struct list_head *lhandle; + struct list_head *protocol_handle; efi_status_t r; EFI_ENTRY("%p, %p, %p", handle, protocol_buffer, @@ -1660,36 +1658,33 @@ static efi_status_t EFIAPI efi_protocols_per_handle(void *handle, *protocol_buffer = NULL; *protocol_buffer_count = 0; - list_for_each(lhandle, &efi_obj_list) { - efiobj = list_entry(lhandle, struct efi_object, link); - if (efiobj->handle != handle) - continue; + efiobj = efi_search_obj(handle); + if (!efiobj) + return EFI_EXIT(EFI_INVALID_PARAMETER); - /* Count protocols */ - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); i++) { - if (efiobj->protocols[i].guid) - ++*protocol_buffer_count; - } - /* Copy guids */ - if (*protocol_buffer_count) { - buffer_size = sizeof(efi_guid_t *) * - *protocol_buffer_count; - r = efi_allocate_pool(EFI_ALLOCATE_ANY_PAGES, - buffer_size, - (void **)protocol_buffer); - if (r != EFI_SUCCESS) - return EFI_EXIT(r); - j = 0; - for (i = 0; i < ARRAY_SIZE(efiobj->protocols); ++i) { - if (efiobj->protocols[i].guid) { - (*protocol_buffer)[j] = (void *) - efiobj->protocols[i].guid; - ++j; - } - } + /* Count protocols */ + list_for_each(protocol_handle, &efiobj->protocols) { + ++*protocol_buffer_count; + }
+ protocol = list_entry(protocol_handle, + struct efi_handler, link); + (*protocol_buffer)[j] = (void *)protocol->guid; + ++j; } - break; } return EFI_EXIT(EFI_SUCCESS); diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 1d6cf3122f..af8db40e19 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -224,6 +224,7 @@ static void efi_disk_add_dev(const char *name, goto out_of_memory; /* Hook up to the device list */ + INIT_LIST_HEAD(&diskobj->parent.protocols); list_add_tail(&diskobj->parent.link, &efi_obj_list);
Currently we have quite different ways to initialize parent->handle:
lib/efi_loader/efi_net.c:303: netobj->parent.handle = &netobj->net; lib/efi_loader/efi_gop.c:187: gopobj->parent.handle = &gopobj->ops; lib/efi_loader/efi_disk.c:233: diskobj->parent.handle = diskobj; lib/efi_loader/efi_boottime.c:1166 obj->handle = info; lib/efi_loader/efi_boottime.c:341: obj->handle = obj;
I could not find any place where we actually dereference a handle. So shouldn't such a helper function also set obj.handle = &obj?
I would prefer to put the introduction of the helper function into a separate patch.
So could you, please, merge patches 2-13 of the series. And I will follow up with:
New version of patch 1 which is really standalone. Fix ups for this patch and the previous patch series.
Regards
Heinrich
As the selftest is not compiled as an EFI binary we do not need special compiler flags.
This avoids the checkarmreloc error on vexpress_ca15_tc2.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Makefile | 25 ------------------------- 1 file changed, 25 deletions(-)
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index d280eca5c3..837e86228e 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -7,31 +7,6 @@ # This file only gets included with CONFIG_EFI_LOADER set, so all # object inclusion implicitly depends on it
-CFLAGS_efi_selftest.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_console.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_console.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_devicepathe.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_devicepath.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_events.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_events.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_exitbootservices.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_exitbootservices.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_gop.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_gop.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_manageprotocols.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_manageprotocols.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_snp.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_snp.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_textoutput.o := $(CFLAGS_EFI) -CFLAGS_REVMOE_efi_selftest_textoutput.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_tpl.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_tpl.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_util.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_util.o := $(CFLAGS_NON_EFI) -CFLAGS_efi_selftest_watchdog.o := $(CFLAGS_EFI) -CFLAGS_REMOVE_efi_selftest_watchdog.o := $(CFLAGS_NON_EFI) - obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += \ efi_selftest.o \ efi_selftest_console.o \
Alexander Graf
