[PATCH] remove obsolete option CONFIG_JFFS2_CMDLINE
This option is obsolete since 2009 and can be removed globally.
CC: Stefan Roese sr@denx.de Signed-off-by: Holger Brunck holger.brunck@hitachi-powergrids.com --- include/configs/ethernut5.h | 1 - include/configs/km/km-powerpc.h | 2 -- include/configs/kmp204x.h | 3 --- include/configs/pm9263.h | 1 - include/configs/stmark2.h | 1 - scripts/config_whitelist.txt | 1 - 6 files changed, 9 deletions(-)
diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index b513b4bc68..ca249d9d2b 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -62,7 +62,6 @@
/* JFFS2 */ #ifdef CONFIG_CMD_JFFS2 -#define CONFIG_JFFS2_CMDLINE #define CONFIG_JFFS2_NAND #endif
diff --git a/include/configs/km/km-powerpc.h b/include/configs/km/km-powerpc.h index 7bfe12fecb..3be926c103 100644 --- a/include/configs/km/km-powerpc.h +++ b/include/configs/km/km-powerpc.h @@ -9,8 +9,6 @@
/* Do boardspecific init for all boards */
-#define CONFIG_JFFS2_CMDLINE - /* EEprom support 24C08, 24C16, 24C64 */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 /* 8 Byte write page */ diff --git a/include/configs/kmp204x.h b/include/configs/kmp204x.h index ec1254e747..d1eb7b574b 100644 --- a/include/configs/kmp204x.h +++ b/include/configs/kmp204x.h @@ -337,9 +337,6 @@ int get_scl(void); * additionnal command line configuration. */
-/* we don't need flash support */ -#undef CONFIG_JFFS2_CMDLINE - /* * For booting Linux, the board info and command line data * have to be in the first 64 MB of memory, since this is diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 0ed4b1aaa2..6c882b6ff9 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -190,7 +190,6 @@
#endif
-#define CONFIG_JFFS2_CMDLINE 1 #define CONFIG_JFFS2_NAND 1 #define CONFIG_JFFS2_DEV "nand0" /* NAND device jffs2 lives on */ #define CONFIG_JFFS2_PART_OFFSET 0 /* start of jffs2 partition */ diff --git a/include/configs/stmark2.h b/include/configs/stmark2.h index d9a2f75e73..da162cbb11 100644 --- a/include/configs/stmark2.h +++ b/include/configs/stmark2.h @@ -49,7 +49,6 @@ #define CONFIG_SYS_MCFRRTC_BASE 0xFC0A8000
/* spi not partitions */ -#define CONFIG_JFFS2_CMDLINE #define CONFIG_JFFS2_DEV "nor0"
/* Timer */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a9508448d4..be3a4b3e9a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -848,7 +848,6 @@ CONFIG_IRAM_STACK CONFIG_IRAM_TOP CONFIG_IRDA_BASE CONFIG_IS_ENABLED -CONFIG_JFFS2_CMDLINE CONFIG_JFFS2_DEV CONFIG_JFFS2_LZO CONFIG_JFFS2_NAND
Thanks, Stefan
- additionnal command line configuration.
- For booting Linux, the board info and command line data
- have to be in the first 64 MB of memory, since this is
#endif
Viele Grüße, Stefan
CC: Stefan Roese sr@denx.de Signed-off-by: Holger Brunck holger.brunck@hitachi-powergrids.com Reviewed-by: Stefan Roese sr@denx.de
Holger Brunck
Stefan Roese
