[U-Boot] [PATCH] arm64: mvebu: armada-7040-db: Enable 10GB port 0 / SFI (KR)
This patch enables the mvpp2 port 0 usage on the Armada 7k DB by setting the correct PHY type (KR / SFI) for the COMPHY driver and enabling the ethernet0 device node in the dts.
Signed-off-by: Stefan Roese sr@denx.de Cc: Stefan Chulski stefanc@marvell.com Cc: Kostya Porotchkin kostap@marvell.com Cc: Nadav Haklai nadavh@marvell.com --- arch/arm/dts/armada-7040-db.dts | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/armada-7040-db.dts b/arch/arm/dts/armada-7040-db.dts index 84e0dbdc3d..54b888ac22 100644 --- a/arch/arm/dts/armada-7040-db.dts +++ b/arch/arm/dts/armada-7040-db.dts @@ -168,8 +168,7 @@ };
phy2 { - phy-type = <PHY_TYPE_SGMII0>; - phy-speed = <PHY_SPEED_1_25G>; + phy-type = <PHY_TYPE_KR>; };
phy3 { @@ -223,6 +222,11 @@ status = "okay"; };
+&cpm_eth0 { + status = "okay"; + phy-mode = "sfi"; /* lane-2 */ +}; + &cpm_eth1 { status = "okay"; phy = <&phy0>;
This patch fixes some remaining issues in the mvpp2 driver for the 10GB support on port 0. These changes are:
- Incorrect PCS configuration - Skip PHY configuration when no PHY is connected - Skip GMAC configurations if 10G SFI mode set
Signed-off-by: Stefan Chulski stefanc@marvell.com Signed-off-by: Stefan Roese sr@denx.de Cc: Kostya Porotchkin kostap@marvell.com Cc: Nadav Haklai nadavh@marvell.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/mvpp2.c | 55 ++++++++++++++++++++++++++++++++++++++--------------- 1 file changed, 40 insertions(+), 15 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 8ffe6c84d4..8fbff9f7b0 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -442,7 +442,7 @@ do { \ /* MPCS registers */
#define PCS40G_COMMON_CONTROL 0x14 -#define FORWARD_ERROR_CORRECTION_MASK BIT(1) +#define FORWARD_ERROR_CORRECTION_MASK BIT(10)
#define PCS_CLOCK_RESET 0x14c #define TX_SD_CLK_RESET_MASK BIT(0) @@ -3244,7 +3244,7 @@ static int gop_xpcs_mode(struct mvpp2_port *port, int num_of_lanes)
/* configure XG MAC mode */ val = readl(port->priv->xpcs_base + MVPP22_XPCS_GLOBAL_CFG_0_REG); - val &= ~MVPP22_XPCS_PCSMODE_OFFS; + val &= ~MVPP22_XPCS_PCSMODE_MASK; val &= ~MVPP22_XPCS_LANEACTIVE_MASK; val |= (2 * lane) << MVPP22_XPCS_LANEACTIVE_OFFS; writel(val, port->priv->xpcs_base + MVPP22_XPCS_GLOBAL_CFG_0_REG); @@ -4472,7 +4472,15 @@ static int mvpp2_rx_refill(struct mvpp2_port *port, /* Set hw internals when starting port */ static void mvpp2_start_dev(struct mvpp2_port *port) { - mvpp2_gmac_max_rx_size_set(port); + switch (port->phy_interface) { + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_SGMII: + mvpp2_gmac_max_rx_size_set(port); + default: + break; + } + mvpp2_txp_max_tx_size_set(port);
if (port->priv->hw_version == MVPP21) @@ -4567,11 +4575,16 @@ static int mvpp2_open(struct udevice *dev, struct mvpp2_port *port) return err; }
- err = mvpp2_phy_connect(dev, port); - if (err < 0) - return err; + if (port->phy_node) { + err = mvpp2_phy_connect(dev, port); + if (err < 0) + return err;
- mvpp2_link_event(port); + mvpp2_link_event(port); + } else { + mvpp2_egress_enable(port); + mvpp2_ingress_enable(port); + }
mvpp2_start_dev(port);
@@ -4716,13 +4729,19 @@ static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) const char *phy_mode_str; int phy_node; u32 id; - u32 phyaddr; + u32 phyaddr = 0; int phy_mode = -1;
phy_node = fdtdec_lookup_phandle(gd->fdt_blob, port_node, "phy"); - if (phy_node < 0) { - dev_err(&pdev->dev, "missing phy\n"); - return -ENODEV; + + if (phy_node > 0) { + phyaddr = fdtdec_get_int(gd->fdt_blob, phy_node, "reg", 0); + if (phyaddr < 0) { + dev_err(&pdev->dev, "could not find phy address\n"); + return -1; + } + } else { + phy_node = 0; }
phy_mode_str = fdt_getprop(gd->fdt_blob, port_node, "phy-mode", NULL); @@ -4748,8 +4767,6 @@ static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) port->phy_speed = fdtdec_get_int(gd->fdt_blob, port_node, "phy-speed", 1000);
- phyaddr = fdtdec_get_int(gd->fdt_blob, phy_node, "reg", 0); - port->id = id; if (port->priv->hw_version == MVPP21) port->first_rxq = port->id * rxq_number; @@ -5309,7 +5326,14 @@ static int mvpp2_start(struct udevice *dev) /* Reconfigure parser accept the original MAC address */ mvpp2_prs_update_mac_da(port, port->dev_addr);
- mvpp2_port_power_up(port); + switch (port->phy_interface) { + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_SGMII: + mvpp2_port_power_up(port); + default: + break; + }
mvpp2_open(dev, port);
@@ -5472,7 +5496,8 @@ static int mvpp2_probe(struct udevice *dev) port->gop_id * MVPP22_PORT_OFFSET;
/* Set phy address of the port */ - mvpp22_smi_phy_addr_cfg(port); + if(port->phy_node) + mvpp22_smi_phy_addr_cfg(port);
/* GoP Init */ gop_port_init(port);
Hi Joe,
Joe, are you okay with this patch? If yes, could you pull it via your net repository or do I have your ACK so that I can pull it via the marvell one?
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Joe Hershberger
Stefan Roese
