[U-Boot] [PATCH v5 10/16] imx6: icorem6: Rename engicam icorem6 defconfig files
Rename defconfig files for better compatible with respective board names and dts files.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v5: - Add missing CONFIG_VIDEO_IPUV3 in configs/imx6q_icore_[mmc|nand]_defconfig
board/engicam/icorem6/MAINTAINERS | 6 ++- board/engicam/icorem6/README | 19 ++++----- ...re_mmc_defconfig => imx6dl_icore_mmc_defconfig} | 0 ..._nand_defconfig => imx6dl_icore_nand_defconfig} | 0 configs/imx6q_icore_mmc_defconfig | 47 ++++++++++++++++++++++ configs/imx6q_icore_nand_defconfig | 42 +++++++++++++++++++ 6 files changed, 100 insertions(+), 14 deletions(-) rename configs/{imx6qdl_icore_mmc_defconfig => imx6dl_icore_mmc_defconfig} (100%) rename configs/{imx6qdl_icore_nand_defconfig => imx6dl_icore_nand_defconfig} (100%) create mode 100644 configs/imx6q_icore_mmc_defconfig create mode 100644 configs/imx6q_icore_nand_defconfig
diff --git a/board/engicam/icorem6/MAINTAINERS b/board/engicam/icorem6/MAINTAINERS index a425afb..0ef3a2c 100644 --- a/board/engicam/icorem6/MAINTAINERS +++ b/board/engicam/icorem6/MAINTAINERS @@ -3,5 +3,7 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: board/engicam/icorem6 F: include/configs/imx6qdl_icore.h -F: configs/imx6qdl_icore_mmc_defconfig -F: configs/imx6qdl_icore_nand_defconfig +F: configs/imx6q_icore_mmc_defconfig +F: configs/imx6q_icore_nand_defconfig +F: configs/imx6dl_icore_mmc_defconfig +F: configs/imx6dl_icore_nand_defconfig diff --git a/board/engicam/icorem6/README b/board/engicam/icorem6/README index e47f85f..6461c0a 100644 --- a/board/engicam/icorem6/README +++ b/board/engicam/icorem6/README @@ -1,18 +1,16 @@ -How to use U-Boot on Engicam i.CoreM6 DualLite/Solo and Quad/Dual Starter Kit: +How to use U-Boot on Engicam i.CoreM6 Solo/DualLite and Quad/Dual Starter Kit: -----------------------------------------------------------------------------
-- Configure U-Boot for Engicam i.CoreM6 QDL: - $ make mrproper -$ make imx6qdl_icore_mmc_defconfig - -- Build for i.CoreM6 DualLite/Solo
-$ make +- Configure U-Boot for Engicam i.CoreM6 Quad/Dual: +$ make imx6q_icore_mmc_defconfig
-- Build for i.CoreM6 Quad/Dual +- Configure U-Boot for Engicam i.CoreM6 Solo/DualLite: +$ make imx6dl_icore_mmc_defconfig
-$ make DEVICE_TREE=imx6q-icore +- Build U-Boot +$ make
This will generate the SPL image called SPL and the u-boot-dtb.img.
@@ -33,6 +31,3 @@ MMC Boot: JM3 Closed
- Insert the micro SD card in the board, power it up and U-Boot messages should come up. - -- Note: For loading Linux on Quad/Dual modules set the dtb as - icorem6qdl> setenv fdt_file imx6q-icore.dtb diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6dl_icore_mmc_defconfig similarity index 100% rename from configs/imx6qdl_icore_mmc_defconfig rename to configs/imx6dl_icore_mmc_defconfig diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig similarity index 100% rename from configs/imx6qdl_icore_nand_defconfig rename to configs/imx6dl_icore_nand_defconfig diff --git a/configs/imx6q_icore_mmc_defconfig b/configs/imx6q_icore_mmc_defconfig new file mode 100644 index 0000000..8f812b4 --- /dev/null +++ b/configs/imx6q_icore_mmc_defconfig @@ -0,0 +1,47 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_MX6Q_ICORE=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_DEFAULT_FDT_FILE="imx6q-icore.dtb" +CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" +CONFIG_SYS_PROMPT="icorem6qdl> " +CONFIG_SPL=y +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTO_COMPLETE=y +CONFIG_SYS_MAXARGS=32 +# CONFIG_CMD_IMLS is not set +# CONFIG_BLK is not set +# CONFIG_DM_MMC_OPS is not set +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_LIBFDT=y +CONFIG_FEC_MXC=y +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_SYS_I2C_MXC=y +CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SPL_EXT_SUPPORT=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig new file mode 100644 index 0000000..4735be8 --- /dev/null +++ b/configs/imx6q_icore_nand_defconfig @@ -0,0 +1,42 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_MX6Q_ICORE=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_NAND" +CONFIG_DEFAULT_FDT_FILE="imx6q-icore.dtb" +CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" +CONFIG_SYS_PROMPT="icorem6qdl> " +CONFIG_SPL=y +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_HUSH_PARSER=y +CONFIG_AUTO_COMPLETE=y +CONFIG_SYS_MAXARGS=32 +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_NAND=y +CONFIG_CMD_CACHE=y +CONFIG_OF_LIBFDT=y +CONFIG_FEC_MXC=y +CONFIG_MXC_UART=y +CONFIG_NAND_MXS=y +CONFIG_IMX_THERMAL=y +# CONFIG_BLK is not set +# CONFIG_DM_MMC_OPS is not set +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_SYS_I2C_MXC=y +CONFIG_VIDEO=y +CONFIG_VIDEO_IPUV3=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SPL_DMA_SUPPORT=y
Changes for v5:
ok, we are now quite ready. I am building everything again and then I push to the server.
Regards, Stefano
Jagan Teki
Stefano Babic
