[PATCH] configs: versal_net: Enable CONFIG_LTO for mini qspi/ospi
Adding a tiny bit more code for mini u-boot leads to a OCM image overflow. Fix this by enabling LTO for this board, so that such changes still can be made to the common U-Boot code.
Enable building mini u-boot image with LTO, which results in about 8KB reduction in size.
Signed-off-by: Michal Simek michal.simek@amd.com Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- configs/xilinx_versal_net_mini_ospi_defconfig | 1 + configs/xilinx_versal_net_mini_qspi_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/xilinx_versal_net_mini_ospi_defconfig b/configs/xilinx_versal_net_mini_ospi_defconfig index 5f42243d22..d78c9f8059 100644 --- a/configs/xilinx_versal_net_mini_ospi_defconfig +++ b/configs/xilinx_versal_net_mini_ospi_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="versal-net-mini-ospi-single" CONFIG_SYS_MEM_RSVD_FOR_MMU=y # CONFIG_PSCI_RESET is not set CONFIG_SYS_LOAD_ADDR=0xBBF80000 +CONFIG_LTO=y # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_versal_net_mini_qspi_defconfig b/configs/xilinx_versal_net_mini_qspi_defconfig index 4fa83faa40..b0567f857a 100644 --- a/configs/xilinx_versal_net_mini_qspi_defconfig +++ b/configs/xilinx_versal_net_mini_qspi_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="versal-net-mini-qspi-single" CONFIG_SYS_MEM_RSVD_FOR_MMU=y # CONFIG_PSCI_RESET is not set CONFIG_SYS_LOAD_ADDR=0xBBF80000 +CONFIG_LTO=y # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y # CONFIG_AUTOBOOT is not set
Applied. M
Michal Simek
