[U-Boot-Users] Hardhat Linux over-riding u-boot IRQ/ PCI configuration mappings
Hello all, I'm using u-boot4 to boot an MPC8266ADS-PCI board, which does so successfully. I have a 4-port USB2.0 hub in one of the pci slots. The problem is twofold. 1. When I download hardhat linux to the board using NFS it seems to override u-boots PCI memory map, and 2. doesn't seem to pick up the Interrupt controller properly as it cannot assign an IRQ to the devices (or I am not assigning the IRQ properly). Does anyone know what I have to do to change the hardhat settings to either - correctly mirror what has been setup in u-boot, or ignore its own settings and simpliy use the existing bootloader configuration. Thanks in advance for any correspondence.
CPU: MPC8260 (Rev 14, Mask A.0(A) 2K25A) at 198 MHz Board: Motorola MPC8266ADS I2C: ready DRAM: SDRAM configuration read from SPD Size per side = 16MB Organization: 1 sides, 2 banks, 9 Columns, 11 Rows, Data width = 64 bits Refresh rate = 33, CAS latency = 2 Total size: 16 MB FLASH: 8 MB In: serial Out: serial Err: serial Net: FCC2 ETHERNET Hit any key to stop autoboot: 0 TFTP from server 10.137.49.203; our IP address is 10.137.49.201 Filename 'image'. Load address: 0x100000 Loading: done Bytes transferred = 1727680 (1a5cc0 hex) ## Booting image at 00100000 ... Image Name: pciOrigHACK Image Type: PowerPC Linux Kernel Image (uncompressed) Data Size: 1727616 Bytes = 1.6 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK OK Memory BAT mapping: BAT2=8Mb, BAT3=4Mb, residual: 8Mb Linux version 2.4.20-pre7 (root@MPC8266) (gcc version 2.95.3 20010315 (release/MontaVista)) #6 Thu Aug 14 14:26:03 BST 2003 pcibios_alloc_controller OUTPUT from pcibios_alloc_controllermpc82xx_bridge_init hostbridge=18c01057
assigning resources
mpc82xx_bridge_init returned success MPC82XXPCI.C pciauto_bus_scan
PCI Autoconfig: PCIAUTO_SETUP_BARS Found Bus 0, Device 23, Function 0 PCI Autoconfig: BAR 0x10, Mem size=0x1000, address=0xe2fff000 PCI Autoconfig: PCIAUTO_SETUP_BARS Found Bus 0, Device 23, Function 1 PCI Autoconfig: BAR 0x10, Mem size=0x1000, address=0xe2ffe000 PCI Autoconfig: PCIAUTO_SETUP_BARS Found Bus 0, Device 23, Function 2 PCI Autoconfig: BAR 0x10, Mem size=0x100, address=0xe2ffdf00 On node 0 totalpages: 3072 zone(0): 3072 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/nfs rw mem=12M nfsroot=10.137.49.203:/tftpboot/SID ip=10.137.49.201:10.137.49.203::255.255.255.192:adsh Warning: real time clock seems stuck! Calibrating delay loop... 131.89 BogoMIPS Memory: 9960k available (1236k kernel code, 540k data, 68k init, 0k highmem) Dentry cache hash table entries: 2048 (order: 2, 16384 bytes) Inode cache hash table entries: 1024 (order: 1, 8192 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 4096 (order: 2, 16384 bytes) POSIX conformance testing by UNIFIX PCI: Probing PCI hardware PCI:00:00.0 Resource 0 [00000000-0001ffff] is unassigned PCI:00:00.0 Resource 1 [00000000-00ffffff] is unassigned PCI: bridge rsrc e1000000..e1ffffff (100), parent c015fd28 PCI: bridge rsrc e2000000..e2ffffff (200), parent c015fd44 PCI:00:17.0: Resource 0: e2fff000-e2ffffff (f=200) PCI:00:17.1: Resource 0: e2ffe000-e2ffefff (f=200) PCI:00:17.2: Resource 0: e2ffdf00-e2ffdfff (f=200) Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd CPM UART driver version 0.01 ttyS0 on SCC1 at 0x8000, BRG1 ttyS1 on SCC2 at 0x8100, BRG2 pty: 256 Unix98 ptys configured eth0: FCC ENET Version 0.3, 00:02:b3:b7:c9:41 loop: loaded (max 8 devices) PPP generic driver version 2.4.2 Linux video capture interface: v1.00 usb.c: registered new driver usbdevfs usb.c: registered new driver hub hcd.c: Found HC with no IRQ. Check BIOS/PCI 00:17.2 setup! usb-uhci.c: $Revision: 1.275 $ time 17:58:58 Aug 13 2003 usb-uhci.c: High bandwidth mode enabled usb-uhci.c: v1.275:USB Universal Host Controller Interface driver usb-ohci.c: found OHCI device with no IRQ assigned. check BIOS settings! DEBUG Device Disabled!! usb-ohci.c: found OHCI device with no IRQ assigned. check BIOS settings! DEBUG Device Disabled!! usb.c: registered new driver hiddev usb.c: registered new driver hid hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik vojtech@suse.cz hid-core.c: USB HID support drivers usb.c: registered new driver stv680 stv680.c: [usb_stv680_init:1624] STV(i): usb camera driver version v0.25 registering stv680.c: STV0680 USB Camera Driver v0.25 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 512 bind 1024) IP-Config: Complete: device=eth0, addr=10.137.49.201, mask=255.255.255.192, gw=255.255.255.255, host=ads8266, domain=, nis-domain=(none), bootserver=10.137.49.203, rootserver=10.137.49.203, rootpath= NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. Looking up port of RPC 100003/2 on 10.137.49.203 Looking up port of RPC 100005/1 on 10.137.49.203 VFS: Mounted root (nfs filesystem). Freeing unused kernel memory: 68k init init-2.05b#
_________________________________________________________________ Tired of spam? Get advanced junk mail protection with MSN 8. http://join.msn.com/?page=features/junkmail
I don't know the answer to your question, but I want to correct the subject. This kernel is not a MontaVista Linux kernel (or previously called Hard Hat Linux.) You may be using the Hard Hat Linux as userspace, but the problems you are seeing are related to the kernel you have choosen.
--Mark
C Doyle
Mark Hatle
