[U-Boot] [PATCH v3 1/1] efi_selftest: LoadImage from file device path
Provide a unit test that calls LoadImage() with a file device path and executes the application via StartImage().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 do not use library function efi_free_pool() but boot time service v2 correct a comment --- lib/efi_selftest/Makefile | 3 + lib/efi_selftest/efi_selftest_loadimage.c | 529 ++++++++++++++++++++++ 2 files changed, 532 insertions(+) create mode 100644 lib/efi_selftest/efi_selftest_loadimage.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 779f549940..2194dc7e33 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -51,6 +51,7 @@ endif ifeq ($(CONFIG_SANDBOX)$(CONFIG_CPU_V7M)$(CONFIG_X86_64),)
obj-y += \ +efi_selftest_loadimage.o \ efi_selftest_startimage_exit.o \ efi_selftest_startimage_return.o
@@ -68,6 +69,8 @@ $(obj)/efi_miniapp_file_image_return.h: $(obj)/efi_selftest_miniapp_return.efi $(obj)/../../tools/file2include $(obj)/efi_selftest_miniapp_return.efi > \ $(obj)/efi_miniapp_file_image_return.h
+$(obj)/efi_selftest_loadimage.o: $(obj)/efi_miniapp_file_image_exit.h + $(obj)/efi_selftest_startimage_exit.o: $(obj)/efi_miniapp_file_image_exit.h
$(obj)/efi_selftest_startimage_return.o: $(obj)/efi_miniapp_file_image_return.h diff --git a/lib/efi_selftest/efi_selftest_loadimage.c b/lib/efi_selftest/efi_selftest_loadimage.c new file mode 100644 index 0000000000..bb7f8b5376 --- /dev/null +++ b/lib/efi_selftest/efi_selftest_loadimage.c @@ -0,0 +1,529 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * efi_selftest_loadimage + * + * Copyright (c) 2019 Heinrich Schuchardt xypron.glpk@gmx.de + * + * This test checks the LoadImage and StartImage boot service. + * + * The efi_selftest_miniapp_exit.efi application is loaded via a file device + * path and started. + */ + +#include <efi_selftest.h> +/* Include containing the efi_selftest_miniapp_exit.efi application */ +#include "efi_miniapp_file_image_exit.h" + +/* Block size of compressed disk image */ +#define COMPRESSED_DISK_IMAGE_BLOCK_SIZE 8 + +/* Binary logarithm of the block size */ +#define LB_BLOCK_SIZE 9 + +#define FILE_NAME L"app.efi" +#define VOLUME_NAME L"EfiDisk" + +static struct efi_boot_services *boottime; +static efi_handle_t handle_image; +static efi_handle_t handle_volume; + +static const efi_guid_t guid_device_path = DEVICE_PATH_GUID; +static const efi_guid_t guid_simple_file_system_protocol = + EFI_SIMPLE_FILE_SYSTEM_PROTOCOL_GUID; +static const efi_guid_t guid_file_info = EFI_FILE_INFO_GUID; +static const efi_guid_t guid_file_system_info = EFI_FILE_SYSTEM_INFO_GUID; + +/* One 8 byte block of the compressed disk image */ +struct line { + size_t addr; + char *line; +}; + +/* Compressed file image */ +struct compressed_file_image { + size_t length; + struct line lines[]; +}; + +/* File info including file name */ +struct file_info { + struct efi_file_info info; + u16 file_name[sizeof(FILE_NAME)]; +}; + +/* File system info including volume name */ +struct file_system_info { + struct efi_file_system_info info; + u16 file_name[sizeof(VOLUME_NAME)]; +}; + +/* Compressed file image */ +static struct compressed_file_image img = EFI_ST_DISK_IMG; + +/* Pointer to decompressed file image */ +static u8 *image; + +/* File info */ +static struct file_info priv_file_info = { + { + .size = sizeof(struct file_info), + .attribute = EFI_FILE_READ_ONLY, + }, + FILE_NAME, +}; + +/* Pointer to file info */ +struct efi_file_info *file_info = &priv_file_info.info; + +/* Volume device path */ +static struct { + struct efi_device_path_vendor vendor; + struct efi_device_path end; +} __packed dp_volume = { + .vendor = { + .dp = { + .type = DEVICE_PATH_TYPE_HARDWARE_DEVICE, + .sub_type = DEVICE_PATH_SUB_TYPE_VENDOR, + .length = sizeof(struct efi_device_path_vendor), + }, + .guid = EFI_GUID(0x4f9a0ebf, 0xa179, 0x88a6, 0x25, 0x68, + 0x10, 0x72, 0xb1, 0x93, 0x51, 0x71), + }, + .end = { + .type = DEVICE_PATH_TYPE_END, + .sub_type = DEVICE_PATH_SUB_TYPE_END, + .length = sizeof(struct efi_device_path), + } +}; + +/* File device path */ +static struct { + struct efi_device_path_vendor vendor; + struct efi_device_path path; + u16 file[sizeof(FILE_NAME)]; + struct efi_device_path end; +} __packed dp_file = { + .vendor = { + .dp = { + .type = DEVICE_PATH_TYPE_HARDWARE_DEVICE, + .sub_type = DEVICE_PATH_SUB_TYPE_VENDOR, + .length = sizeof(struct efi_device_path_vendor), + }, + .guid = EFI_GUID(0x4f9a0ebf, 0xa179, 0x88a6, 0x25, 0x68, + 0x10, 0x72, 0xb1, 0x93, 0x51, 0x71), + }, + .path = { + .type = DEVICE_PATH_TYPE_MEDIA_DEVICE, + .sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH, + .length = sizeof(struct efi_device_path) + sizeof(dp_file.file), + }, + .file = FILE_NAME, + .end = { + .type = DEVICE_PATH_TYPE_END, + .sub_type = DEVICE_PATH_SUB_TYPE_END, + .length = sizeof(struct efi_device_path), + } +}; + +/* File system info */ +static struct file_system_info priv_file_system_info = { + { + .size = sizeof(struct file_system_info), + .read_only = true, + .volume_size = 0x100000, + .free_space = 0x0, + .block_size = 0x200, + }, + VOLUME_NAME +}; + +/* Pointer to file system info */ +static struct efi_file_system_info *file_system_info = + &priv_file_system_info.info; + +/* Forward definitions of file and file system functions */ +static efi_status_t EFIAPI open_volume + (struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root); + +static efi_status_t EFIAPI open + (struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, u64 attributes); + +static efi_status_t EFIAPI close(struct efi_file_handle *this); + +static efi_status_t EFIAPI delete(struct efi_file_handle *this); + +static efi_status_t EFIAPI read + (struct efi_file_handle *this, efi_uintn_t *buffer_size, void *buffer); + +static efi_status_t EFIAPI write + (struct efi_file_handle *this, efi_uintn_t *buffer_size, void *buffer); + +static efi_status_t EFIAPI getpos(struct efi_file_handle *this, u64 *pos); + +static efi_status_t EFIAPI setpos(struct efi_file_handle *this, u64 pos); + +static efi_status_t EFIAPI getinfo + (struct efi_file_handle *this, const efi_guid_t *info_type, + efi_uintn_t *buffer_size, void *buffer); + +static efi_status_t EFIAPI setinfo + (struct efi_file_handle *this, const efi_guid_t *info_type, + efi_uintn_t buffer_size, void *buffer); + +static efi_status_t EFIAPI flush(struct efi_file_handle *this); + +/* Internal information about status of file system */ +static struct { + /* Difference of volume open count minus volume close count */ + int volume_open_count; + /* Difference of file open count minus file close count */ + int file_open_count; + /* File size */ + u64 file_size; + /* Current position in file */ + u64 file_pos; +} priv; + +/* EFI_FILE_PROTOCOL for file */ +static struct efi_file_handle file = { + .rev = 0x00010000, + .open = open, + .close = close, + .delete = delete, + .read = read, + .write = write, + .getpos = getpos, + .setpos = setpos, + .getinfo = getinfo, + .setinfo = setinfo, + .flush = flush, +}; + +/* EFI_FILE_PROTOCOL for root directory */ +static struct efi_file_handle volume = { + .rev = 0x00010000, + .open = open, + .close = close, + .delete = delete, + .read = read, + .write = write, + .getpos = getpos, + .setpos = setpos, + .getinfo = getinfo, + .setinfo = setinfo, + .flush = flush, +}; + +/* EFI_SIMPLE_FILE_SYSTEM_PROTOCOL of the block device */ +struct efi_simple_file_system_protocol file_system = { + .rev = 0x00010000, + .open_volume = open_volume, +}; + +static efi_status_t EFIAPI open_volume + (struct efi_simple_file_system_protocol *this, + struct efi_file_handle **root) +{ + if (this != &file_system || !root) + return EFI_INVALID_PARAMETER; + + *root = &volume; + priv.volume_open_count++; + + return EFI_SUCCESS; +} + +static efi_status_t EFIAPI open + (struct efi_file_handle *this, + struct efi_file_handle **new_handle, + u16 *file_name, u64 open_mode, u64 attributes) +{ + if (this != &volume) + return EFI_INVALID_PARAMETER; + + *new_handle = &file; + priv.file_pos = 0; + priv.file_open_count++; + + return EFI_SUCCESS; +} + +static efi_status_t EFIAPI close(struct efi_file_handle *this) +{ + if (this == &file) + priv.file_open_count--; + else if (this == &volume) + priv.volume_open_count--; + else + return EFI_INVALID_PARAMETER; + + return EFI_SUCCESS; +} + +static efi_status_t EFIAPI delete(struct efi_file_handle *this) +{ + if (this != &file) + return EFI_INVALID_PARAMETER; + + return EFI_UNSUPPORTED; +} + +static efi_status_t EFIAPI read + (struct efi_file_handle *this, efi_uintn_t *buffer_size, void *buffer) +{ + if (this != &file) + return EFI_INVALID_PARAMETER; + + if (priv.file_pos >= img.length) + *buffer_size = 0; + else if (priv.file_pos + *buffer_size > img.length) + *buffer_size = img.length - priv.file_pos; + + boottime->copy_mem(buffer, &image[priv.file_pos], *buffer_size); + priv.file_pos += *buffer_size; + + return EFI_SUCCESS; +} + +static efi_status_t EFIAPI write + (struct efi_file_handle *this, efi_uintn_t *buffer_size, void *buffer) +{ + if (this != &file) + return EFI_INVALID_PARAMETER; + + return EFI_UNSUPPORTED; +} + +static efi_status_t EFIAPI getpos(struct efi_file_handle *this, u64 *pos) +{ + if (this != &file) + return EFI_INVALID_PARAMETER; + + *pos = priv.file_pos; + + return EFI_SUCCESS; +} + +static efi_status_t EFIAPI setpos(struct efi_file_handle *this, u64 pos) +{ + if (this != &file) + return EFI_INVALID_PARAMETER; + + priv.file_pos = pos; + + return EFI_SUCCESS; +} + +static efi_status_t EFIAPI getinfo + (struct efi_file_handle *this, const efi_guid_t *info_type, + efi_uintn_t *buffer_size, void *buffer) +{ + if (this == &file) { + if (efi_st_memcmp(info_type, &guid_file_info, + sizeof(efi_guid_t))) + return EFI_INVALID_PARAMETER; + if (*buffer_size >= sizeof(struct file_info)) { + boottime->copy_mem(buffer, file_info, + sizeof(struct file_info)); + } else { + *buffer_size = sizeof(struct file_info); + return EFI_BUFFER_TOO_SMALL; + } + } else if (this == &volume) { + if (efi_st_memcmp(info_type, &guid_file_system_info, + sizeof(efi_guid_t))) + return EFI_INVALID_PARAMETER; + if (*buffer_size >= sizeof(struct file_system_info)) { + boottime->copy_mem(buffer, file_system_info, + sizeof(struct file_system_info)); + } else { + *buffer_size = sizeof(struct file_system_info); + return EFI_BUFFER_TOO_SMALL; + } + } else { + return EFI_INVALID_PARAMETER; + } + return EFI_SUCCESS; +} + +static efi_status_t EFIAPI setinfo + (struct efi_file_handle *this, const efi_guid_t *info_type, + efi_uintn_t buffer_size, void *buffer) +{ + if (this != &file) + return EFI_INVALID_PARAMETER; + + return EFI_UNSUPPORTED; +} + +static efi_status_t EFIAPI flush(struct efi_file_handle *this) +{ + if (this != &file) + return EFI_INVALID_PARAMETER; + + return EFI_UNSUPPORTED; +} + +/* + * Decompress the disk image. + * + * @image decompressed disk image + * @return status code + */ +static efi_status_t decompress(u8 **image) +{ + u8 *buf; + size_t i; + size_t addr; + size_t len; + efi_status_t ret; + + ret = boottime->allocate_pool(EFI_LOADER_DATA, img.length, + (void **)&buf); + if (ret != EFI_SUCCESS) { + efi_st_error("Out of memory\n"); + return ret; + } + boottime->set_mem(buf, img.length, 0); + + for (i = 0; ; ++i) { + if (!img.lines[i].line) + break; + addr = img.lines[i].addr; + len = COMPRESSED_DISK_IMAGE_BLOCK_SIZE; + if (addr + len > img.length) + len = img.length - addr; + boottime->copy_mem(buf + addr, img.lines[i].line, len); + } + *image = buf; + priv.file_size = img.length; + file_info->file_size = img.length; + return ret; +} + +/* + * Setup unit test. + * + * Decompress application image and provide a handle for the in memory block + * device. + * + * @handle: handle of the loaded image + * @systable: system table + * @return: EFI_ST_SUCCESS for success + */ +static int setup(const efi_handle_t handle, + const struct efi_system_table *systable) +{ + efi_status_t ret; + + handle_image = handle; + boottime = systable->boottime; + + /* Load the application image into memory */ + decompress(&image); + + ret = boottime->install_protocol_interface + (&handle_volume, &guid_device_path, EFI_NATIVE_INTERFACE, + &dp_volume); + if (ret != EFI_SUCCESS) { + efi_st_error("Failed to install device path\n"); + return EFI_ST_FAILURE; + } + ret = boottime->install_protocol_interface + (&handle_volume, &guid_simple_file_system_protocol, + EFI_NATIVE_INTERFACE, &file_system); + if (ret != EFI_SUCCESS) { + efi_st_error("Failed to install simple file system protocol\n"); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} + +/* + * Tear down unit test. + * + * Uninstall protocols and free memory. + * + * @return: EFI_ST_SUCCESS for success + */ +static int teardown(void) +{ + efi_status_t ret = EFI_ST_SUCCESS; + + if (handle_volume) { + ret = boottime->uninstall_protocol_interface + (handle_volume, &guid_simple_file_system_protocol, + &file_system); + if (ret != EFI_SUCCESS) { + efi_st_error + ("Failed to uninstall simple file system protocol\n"); + return EFI_ST_FAILURE; + } + ret = boottime->uninstall_protocol_interface + (handle_volume, &guid_device_path, &dp_volume); + if (ret != EFI_SUCCESS) { + efi_st_error + ("Failed to uninstall device path protocol\n"); + return EFI_ST_FAILURE; + } + } + + if (image) { + ret = boottime->free_pool(image); + if (ret != EFI_SUCCESS) { + efi_st_error("Failed to free image\n"); + return EFI_ST_FAILURE; + } + } + return ret; +} + +/* + * Execute unit test. + * + * Load and start the application image. + * + * @return: EFI_ST_SUCCESS for success + */ +static int execute(void) +{ + efi_status_t ret; + efi_handle_t handle; + + ret = boottime->load_image(false, handle_image, &dp_file.vendor.dp, + NULL, 0, &handle); + if (ret != EFI_SUCCESS) { + efi_st_error("Failed to load image\n"); + return EFI_ST_FAILURE; + } + ret = boottime->start_image(handle, NULL, NULL); + if (ret != EFI_UNSUPPORTED) { + efi_st_error("Wrong return value from application\n"); + return EFI_ST_FAILURE; + } + + if (priv.file_open_count) { + efi_st_error("File open count = %d, expected 0\n", + priv.file_open_count); + return EFI_ST_FAILURE; + } + if (priv.volume_open_count) { + efi_st_error("Volume open count = %d, expected 0\n", + priv.volume_open_count); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} + +EFI_UNIT_TEST(loadimage) = { + .name = "load image from file", + .phase = EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, + .setup = setup, + .execute = execute, + .teardown = teardown, +};
