[U-Boot] [PATCH 2/2] EXYNOS: mmc: support DesignWare Controller for Samsung-SoC
Support DesignWare MMC Controller for Samsung Specific.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Signed-off-by: Rajeshawari Shinde rajeshwari.s@samsung.com --- arch/arm/include/asm/arch-exynos/dwmmc.h | 36 ++++++++++++++++++ drivers/mmc/exynos_dw_mmc.c | 60 ++++++++++++++++++++++++++++++ 2 files changed, 96 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/dwmmc.h create mode 100644 drivers/mmc/exynos_dw_mmc.c
diff --git a/arch/arm/include/asm/arch-exynos/dwmmc.h b/arch/arm/include/asm/arch-exynos/dwmmc.h new file mode 100644 index 0000000..2e4354d --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/dwmmc.h @@ -0,0 +1,36 @@ +/* + * (C) Copyright 2012 SAMSUNG Electronics + * Jaehoon Chung jh80.chung@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#define DWMCI_CLKSEL 0x09C +#define DWMCI_SHIFT_0 0x0 +#define DWMCI_SHIFT_1 0x1 +#define DWMCI_SHIFT_2 0x2 +#define DWMCI_SHIFT_3 0x3 +#define DWMCI_SET_SAMPLE_CLK(x) (x) +#define DWMCI_SET_DRV_CLK(x) ((x) << 16) +#define DWMCI_SET_DIV_RATIO(x) ((x) << 24) + +int exynos_dwmci_init(u32 regbase, u32 quirks, int bus_width, int index); + +static inline unsigned int exynos_dwmmc_init(int index, int bus_width) +{ + unsigned int base = samsung_get_base_mmc() + (0x10000 * index); + return exynos_dwmci_init(base, 50000000, 400000, index); +} diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c new file mode 100644 index 0000000..e9b0e1d --- /dev/null +++ b/drivers/mmc/exynos_dw_mmc.c @@ -0,0 +1,60 @@ +/* + * (C) Copyright 2012 SAMSUNG Electronics + * Jaehoon Chung jh80.chung@samsung.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <malloc.h> +#include <dwmmc.h> +#include <asm/arch/dwmmc.h> +#include <asm/arch/clk.h> + +static char *EXYNOS_NAME = "EXYNOS DWMMC"; + +static void exynos_dwmci_clksel(struct dwmci_host *host) +{ + u32 val; + val = DWMCI_SET_SAMPLE_CLK(DWMCI_SHIFT_0) | + DWMCI_SET_DRV_CLK(DWMCI_SHIFT_0) | DWMCI_SET_DIV_RATIO(0); + + dwmci_writel(host, DWMCI_CLKSEL, val); +} + +int exynos_dwmci_init(u32 regbase, u32 quirks, int bus_width, int index) +{ + struct dwmci_host *host = NULL; + host = (struct dwmci_host *)malloc(sizeof(struct dwmci_host)); + if (!host) { + printf("dwmci_host malloc fail!\n"); + return 1; + } + + host->name = EXYNOS_NAME; + host->ioaddr = (void *)regbase; + host->quirks = quirks; + host->buswidth = bus_width; + host->fifoth_val = 0x20100010; + host->clksel = exynos_dwmci_clksel; + host->dev_index = index; + host->get_mmc_clk = get_mmc_clk; + + add_dwmci(host, 52000000, 400000, index); + + return 0; +} +
Hi Jaehoon Chung,
- (C) Copyright 2012 SAMSUNG Electronics
- Jaehoon Chung jh80.chung@samsung.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
We donot use bus_width here ?
u32 val;
if (!host) {
return 1;
Can this hard coding be removed?
Can this be just mmc_clk, just a suggestion.
-- 1.7.4.1 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On 07/03/2012 02:39 PM, Rajeshwari Birje wrote:
Hi Jaehoon Chung,
It's missing.
u32 val;
if (!host) {
return 1;
Sure, we can remove this, then should be calculated with register's value at dw_mmc.c. But we have two approaches.. 1) Use the register value. 2) Set the fifoth_Val. If you want to remove, don't mind..but i didn't ensure to work well.
Sure..i will change the host->mmc_clk.
Hi Jaehoon Chung,
Hi Jaehoon Chung,
It's missing.
ok
u32 val;
if (!host) {
return 1;
- Use the register value.
- Set the fifoth_Val.
If not working well, we can at least define it in header file saying #define FIFOTH_VAL 0x20100010 host->fifoth_va = FIFOTH_VAL;
ok
Jaehoon Chung
Rajeshwari Birje
