[U-Boot-Users] SMSC LAN8700 and LAN8187
Hello,
Does anyone know if u-boot will work with the SMSC LAN8700 (same interface as LAN8187) Ethernet transceiver? Specifically I am trying to use it with the Atmel AT91SAM9260 microcontroller using MII. I am developing a board similar to the AT91SAM9260-EK evaluation kit and would like to replace the Davicom DM9161a. If u-boot currently doesn't work with the LAN8700 can anyone provide me with a little guidance as to the magnitude of the effort to add this transceiver to u-boot? Sorry if my question is a bit naive, I am a newbie when it comes to u-boot.
Thanks, Kevin
On 21:03 Mon 12 May , Kevin Greer wrote:
Hello,
Normaly you will have no problem
the LAN8700 is really simple.
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD <plagnioj <at> jcrosoft.com> writes:
Hello,
Best Regards, J.
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
Kevin,
We tested 8700 in MII mode, it works OK. - Recompile u-boot to use MII instead of RMII - Swap the pins PA10, PA11 to PA23,PA24 for TX(2:3)
We will be testing that in the kernel(2.6.25) soon, hopefully that will work OK too.
Norman
Kevin Greer
Norman Cheung
