[PATCH v3 0/5] net: hifemac: a few cleanups
- Fix the use of log_msg_ret() and add dev_xxx() for error reporting. - Register mdio subnode as a mdio bus device for hifemac. - Implement ops needed by `net stats` - Make functions static.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- Changes in v3: - hisi-femac: add missing `static` to avoid polluting global namespace. - Link to v2: https://lore.kernel.org/r/20240122-net-v2-0-78a368896f62@outlook.com
Changes in v2: - hisi-femac: add statistics related operations - Link to v1: https://lore.kernel.org/r/20240119-net-v1-0-d1feb8e16ac6@outlook.com
--- Yang Xiwen (5): net: hifemac_mdio: use log_msg_ret() correctly, report error by dev_err() net: hifemac: fix log reporting net: hifemac: register MDIO bus device for subnode net: hifemac: implement `net stats` needed ops net: hifemac: make some functions static
drivers/net/hifemac.c | 229 +++++++++++++++++++++++++++++++++++++-------- drivers/net/hifemac_mdio.c | 11 ++- 2 files changed, 198 insertions(+), 42 deletions(-) --- base-commit: f7cca7ccc5117eaafcc2bde91ad1bed6fee7cfc3 change-id: 20240119-net-72a32675eeb4
The initial commit used log_msg_ret() wrongly. Fix that by moving error report to a separate dev_err() call and shrink the first argument of log_msg_ret() to no more than 4 chars.
Fixes: 6b5c8d98e204 ("net: add hifemac_mdio MDIO bus driver for HiSilicon platform")
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/net/hifemac_mdio.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/drivers/net/hifemac_mdio.c b/drivers/net/hifemac_mdio.c index 343c5f3a38..0b59d06091 100644 --- a/drivers/net/hifemac_mdio.c +++ b/drivers/net/hifemac_mdio.c @@ -8,6 +8,7 @@ #include <dm.h> #include <clk.h> #include <miiphy.h> +#include <dm/device_compat.h> #include <linux/io.h> #include <linux/iopoll.h>
@@ -74,7 +75,8 @@ static int hisi_femac_mdio_of_to_plat(struct udevice *dev) data->membase = dev_remap_addr(dev); if (IS_ERR(data->membase)) { ret = PTR_ERR(data->membase); - return log_msg_ret("Failed to remap base addr", ret); + dev_err(dev, "Failed to remap base addr %d\n", ret); + return log_msg_ret("mdio", ret); }
// clk is optional @@ -89,8 +91,10 @@ static int hisi_femac_mdio_probe(struct udevice *dev) int ret;
ret = clk_prepare_enable(data->clk); - if (ret) - return log_msg_ret("Failed to enable clk", ret); + if (ret) { + dev_err(dev, "Failed to enable clock: %d\n", ret); + return log_msg_ret("clk", ret); + }
return 0; } @@ -112,5 +116,6 @@ U_BOOT_DRIVER(hisi_femac_mdio_driver) = { .of_to_plat = hisi_femac_mdio_of_to_plat, .probe = hisi_femac_mdio_probe, .ops = &hisi_femac_mdio_ops, + .plat_auto = sizeof(struct mdio_perdev_priv), .priv_auto = sizeof(struct hisi_femac_mdio_data), };
For the series, applied to u-boot/next, thanks!
shrink the first argument of log_msg_ret(), add dev_xxx() functions for error reporting.
Fixes: 9d8f78a2a79f7 ("net: add hifemac Ethernet driver for HiSilicon platform")
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/net/hifemac.c | 110 +++++++++++++++++++++++++++++++++----------------- 1 file changed, 73 insertions(+), 37 deletions(-)
diff --git a/drivers/net/hifemac.c b/drivers/net/hifemac.c index b61a29e636..1088f3eca3 100644 --- a/drivers/net/hifemac.c +++ b/drivers/net/hifemac.c @@ -245,8 +245,10 @@ static int hisi_femac_start(struct udevice *dev) hisi_femac_rx_refill(priv);
ret = phy_startup(priv->phy); - if (ret) - return log_msg_ret("Failed to startup phy", ret); + if (ret) { + dev_err(dev, "Failed to startup phy: %d\n", ret); + return log_msg_ret("phy", ret); + }
if (!priv->phy->link) { debug("%s: link down\n", __func__); @@ -281,8 +283,10 @@ static int hisi_femac_send(struct udevice *dev, void *packet, int length)
// wait until FIFO is empty ret = wait_for_bit_le32(priv->glb_base + GLB_IRQ_RAW, IRQ_INT_TX_PER_PACKET, true, 50, false); - if (ret == -ETIMEDOUT) - return log_msg_ret("FIFO timeout", ret); + if (ret == -ETIMEDOUT) { + dev_err(dev, "FIFO timeout\n"); + return log_msg_ret("net", ret); + }
return 0; } @@ -340,35 +344,45 @@ int hisi_femac_of_to_plat(struct udevice *dev) };
priv->port_base = dev_remap_addr_name(dev, "port"); - if (IS_ERR(priv->port_base)) - return log_msg_ret("Failed to remap port address space", PTR_ERR(priv->port_base)); + if (!priv->port_base) { + dev_err(dev, "Failed to remap port address space\n"); + return log_msg_ret("net", -EINVAL); + }
priv->glb_base = dev_remap_addr_name(dev, "glb"); - if (IS_ERR(priv->glb_base)) - return log_msg_ret("Failed to remap global address space", PTR_ERR(priv->glb_base)); + if (IS_ERR(priv->glb_base)) { + dev_err(dev, "Failed to remap global address space\n"); + return log_msg_ret("net", -EINVAL); + }
for (i = 0; i < ARRAY_SIZE(clk_strs); i++) { priv->clks[i] = devm_clk_get(dev, clk_strs[i]); if (IS_ERR(priv->clks[i])) { dev_err(dev, "Error getting clock %s\n", clk_strs[i]); - return log_msg_ret("Failed to get clocks", PTR_ERR(priv->clks[i])); + return log_msg_ret("clk", PTR_ERR(priv->clks[i])); } }
priv->mac_rst = devm_reset_control_get(dev, "mac"); - if (IS_ERR(priv->mac_rst)) - return log_msg_ret("Failed to get MAC reset", PTR_ERR(priv->mac_rst)); + if (IS_ERR(priv->mac_rst)) { + dev_err(dev, "Failed to get MAC reset %ld\n", PTR_ERR(priv->mac_rst)); + return log_msg_ret("rst", PTR_ERR(priv->mac_rst)); + }
priv->phy_rst = devm_reset_control_get(dev, "phy"); - if (IS_ERR(priv->phy_rst)) - return log_msg_ret("Failed to get PHY reset", PTR_ERR(priv->phy_rst)); + if (IS_ERR(priv->phy_rst)) { + dev_err(dev, "Failed to get PHY reset %ld\n", PTR_ERR(priv->phy_rst)); + return log_msg_ret("rst", PTR_ERR(priv->phy_rst)); + }
ret = dev_read_u32_array(dev, PHY_RESET_DELAYS_PROPERTY, priv->phy_reset_delays, DELAYS_NUM); - if (ret < 0) - return log_msg_ret("Failed to get PHY reset delays", ret); + if (ret < 0) { + dev_err(dev, "Failed to get PHY reset delays %d\n", ret); + return log_msg_ret("rst", ret); + }
priv->mac_reset_delay = dev_read_u32_default(dev, MAC_RESET_DELAY_PROPERTY, @@ -385,32 +399,44 @@ static int hisi_femac_phy_reset(struct hisi_femac_priv *priv)
// Disable MAC clk before phy reset ret = clk_disable(priv->clks[CLK_MAC]); - if (ret < 0) - return log_msg_ret("Failed to disable MAC clock", ret); + if (ret < 0) { + pr_err("%s: Failed to disable MAC clock %d\n", __func__, ret); + return log_msg_ret("clk", ret); + } ret = clk_disable(priv->clks[CLK_BUS]); - if (ret < 0) - return log_msg_ret("Failed to disable bus clock", ret); + if (ret < 0) { + pr_err("%s: Failed to disable bus clock %d\n", __func__, ret); + return log_msg_ret("clk", ret); + }
udelay(delays[PRE_DELAY]);
ret = reset_assert(rst); - if (ret < 0) - return log_msg_ret("Failed to assert reset", ret); + if (ret < 0) { + pr_err("%s: Failed to assert reset %d\n", __func__, ret); + return log_msg_ret("rst", ret); + }
udelay(delays[PULSE]);
ret = reset_deassert(rst); - if (ret < 0) - return log_msg_ret("Failed to deassert reset", ret); + if (ret < 0) { + pr_err("%s: Failed to deassert reset %d\n", __func__, ret); + return log_msg_ret("rst", ret); + }
udelay(delays[POST_DELAY]);
ret = clk_enable(priv->clks[CLK_MAC]); - if (ret < 0) - return log_msg_ret("Failed to enable MAC clock", ret); + if (ret < 0) { + pr_err("%s: Failed to enable MAC clock %d\n", __func__, ret); + return log_msg_ret("clk", ret); + } ret = clk_enable(priv->clks[CLK_BUS]); - if (ret < 0) - return log_msg_ret("Failed to enable MAC bus clock", ret); + if (ret < 0) { + pr_err("%s: Failed to enable MAC bus clock %d\n", __func__, ret); + return log_msg_ret("clk", ret); + }
return 0; } @@ -423,30 +449,40 @@ int hisi_femac_probe(struct udevice *dev) // Enable clocks for (i = 0; i < CLK_NUM; i++) { ret = clk_prepare_enable(priv->clks[i]); - if (ret < 0) - return log_msg_ret("Failed to enable clks", ret); + if (ret < 0) { + dev_err(dev, "Failed to enable clk %d: %d\n", i, ret); + return log_msg_ret("clk", ret); + } }
// Reset MAC ret = reset_assert(priv->mac_rst); - if (ret < 0) - return log_msg_ret("Failed to assert MAC reset", ret); + if (ret < 0) { + dev_err(dev, "Failed to assert MAC reset: %d\n", ret); + return log_msg_ret("net", ret); + }
udelay(priv->mac_reset_delay);
ret = reset_deassert(priv->mac_rst); - if (ret < 0) - return log_msg_ret("Failed to deassert MAC reset", ret); + if (ret < 0) { + dev_err(dev, "Failed to deassert MAC reset: %d\n", ret); + return log_msg_ret("net", ret); + }
// Reset PHY ret = hisi_femac_phy_reset(priv); - if (ret < 0) - return log_msg_ret("Failed to reset phy", ret); + if (ret < 0) { + dev_err(dev, "Failed to reset PHY: %d\n", ret); + return log_msg_ret("net", ret); + }
// Connect to PHY priv->phy = dm_eth_phy_connect(dev); - if (!priv->phy) - return log_msg_ret("Failed to connect to phy", -EINVAL); + if (!priv->phy) { + dev_err(dev, "Failed to connect to phy\n"); + return log_msg_ret("phy", -EINVAL); + }
hisi_femac_port_init(priv); return 0;
register internal MDIO bus device if it is a subnode.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/net/hifemac.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/drivers/net/hifemac.c b/drivers/net/hifemac.c index 1088f3eca3..39c0233b62 100644 --- a/drivers/net/hifemac.c +++ b/drivers/net/hifemac.c @@ -15,6 +15,7 @@ #include <wait_bit.h> #include <asm/io.h> #include <dm/device_compat.h> +#include <dm/lists.h> #include <linux/delay.h> #include <linux/kernel.h>
@@ -337,6 +338,8 @@ int hisi_femac_of_to_plat(struct udevice *dev) { int ret, i; struct hisi_femac_priv *priv = dev_get_priv(dev); + ofnode mdio_node; + bool mdio_registered = false; static const char * const clk_strs[] = { [CLK_MAC] = "mac", [CLK_BUS] = "bus", @@ -388,6 +391,31 @@ int hisi_femac_of_to_plat(struct udevice *dev) MAC_RESET_DELAY_PROPERTY, MAC_RESET_ASSERT_PERIOD);
+ /* Create MDIO bus */ + ofnode_for_each_subnode(mdio_node, dev_ofnode(dev)) { + const char *subnode_name = ofnode_get_name(mdio_node); + struct udevice *mdiodev; + + // Skip subnodes not starting with "mdio" + if (strncmp(subnode_name, "mdio", 4)) + continue; + + ret = device_bind_driver_to_node(dev, "hisi-femac-mdio", + subnode_name, mdio_node, &mdiodev); + if (ret) { + dev_err(dev, "Failed to register MDIO bus device %d\n", ret); + return log_msg_ret("net", ret); + } + + mdio_registered = true; + break; + } + + if (!mdio_registered) { + dev_err(dev, "No MDIO subnode is found!\n"); + return log_msg_ret("mdio", -ENODATA); + } + return 0; }
3 operations needed by `net stats` are implemented. New `net stats` output some useful info.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/net/hifemac.c | 87 +++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 87 insertions(+)
diff --git a/drivers/net/hifemac.c b/drivers/net/hifemac.c index 39c0233b62..d24023eefd 100644 --- a/drivers/net/hifemac.c +++ b/drivers/net/hifemac.c @@ -16,6 +16,8 @@ #include <asm/io.h> #include <dm/device_compat.h> #include <dm/lists.h> +#include <linux/bitfield.h> +#include <linux/ethtool.h> #include <linux/delay.h> #include <linux/kernel.h>
@@ -125,6 +127,57 @@ struct hisi_femac_priv { u32 link_status; };
+struct hisi_femac_stat_entry { + const char *name; + u32 offset; + u32 mask; +}; + +/* please refer to the datasheet for the description of these entries */ +static const struct hisi_femac_stat_entry hisi_femac_stats_table[] = { + { "rxsof_cnt", 0x584, GENMASK(31, 28) }, + { "rxeof_cnt", 0x584, GENMASK(27, 24) }, + { "rxcrcok_cnt", 0x584, GENMASK(23, 20) }, + { "rxcrcbad_cnt", 0x584, GENMASK(19, 16) }, + { "txsof_cnt", 0x584, GENMASK(15, 12) }, + { "txeof_cnt", 0x584, GENMASK(11, 8) }, + { "txcrcok_cnt", 0x584, GENMASK(7, 4) }, + { "txcrcbad_cnt", 0x584, GENMASK(3, 0) }, + { "pkts_cpu", 0x5a0, GENMASK(15, 0) }, + { "addr_cpu", 0x5a4, GENMASK(15, 0) }, + { "pkts_port", 0x5a8, GENMASK(15, 0) }, + { "pkts_cpu2tx", 0x5ac, GENMASK(15, 0) }, + { "rxdvrise", 0x600, GENMASK(31, 0) }, + { "ifinoctets", 0x604, GENMASK(31, 0) }, + { "octets_rx", 0x608, GENMASK(31, 0) }, + { "local_mac_match", 0x60c, GENMASK(31, 0) }, + { "pkts", 0x610, GENMASK(31, 0) }, + { "broadcastpkts", 0x614, GENMASK(31, 0) }, + { "multicastpkts", 0x618, GENMASK(31, 0) }, + { "ifinucastpkts", 0x61c, GENMASK(31, 0) }, + { "ifinerrors", 0x620, GENMASK(31, 0) }, + { "crcerr", 0x624, GENMASK(31, 0) }, + { "abnormalsizepkts", 0x628, GENMASK(31, 0) }, + { "dot3alignmenterr", 0x62c, GENMASK(31, 0) }, + { "dot3pause", 0x630, GENMASK(31, 0) }, + { "dropevents", 0x634, GENMASK(31, 0) }, + { "flux_frame_cnt", 0x638, GENMASK(31, 0) }, + { "flux_drop_cnt", 0x63c, GENMASK(31, 0) }, + { "mac_not2cpu_pkts", 0x64c, GENMASK(31, 0) }, + { "pkts_tx", 0x780, GENMASK(31, 0) }, + { "broadcastpkts_tx", 0x784, GENMASK(31, 0) }, + { "multicastpkts_tx", 0x788, GENMASK(31, 0) }, + { "ifoutucastpkts_tx", 0x78c, GENMASK(31, 0) }, + { "octets_tx", 0x790, GENMASK(31, 0) }, + { "dot3pause", 0x794, GENMASK(31, 0) }, + { "retry_times_tx", 0x798, GENMASK(31, 0) }, + { "collisions", 0x79c, GENMASK(31, 0) }, + { "dot3latecol", 0x7a0, GENMASK(31, 0) }, + { "dot3colok", 0x7a4, GENMASK(31, 0) }, + { "dot3excessivecol", 0x7a8, GENMASK(31, 0) }, + { "dot3colcnt", 0x7ac, GENMASK(31, 0) }, +}; + static void hisi_femac_irq_enable(struct hisi_femac_priv *priv, int irqs) { u32 val; @@ -334,6 +387,37 @@ static void hisi_femac_stop(struct udevice *dev) writel(SOFT_RESET_ALL, priv->glb_base + GLB_SOFT_RESET); }
+static int hisi_femac_get_sset_count(struct udevice *dev) +{ + return ARRAY_SIZE(hisi_femac_stats_table); +} + +static void hisi_femac_get_strings(struct udevice *dev, u8 *data) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(hisi_femac_stats_table); i++) + strcpy(data + i * ETH_GSTRING_LEN, hisi_femac_stats_table[i].name); +} + +/* Non-constant mask variant of FIELD_GET/FIELD_PREP */ +#define field_get(_mask, _reg) (((_reg) & (_mask)) >> (ffs(_mask) - 1)) + +static void hisi_femac_get_stats(struct udevice *dev, u64 *data) +{ + int i; + u32 mask, reg; + struct hisi_femac_priv *priv = dev_get_priv(dev); + void __iomem *port_base = priv->port_base; + + for (i = 0; i < ARRAY_SIZE(hisi_femac_stats_table); i++) { + mask = hisi_femac_stats_table[i].mask; + reg = readl(port_base + hisi_femac_stats_table[i].offset); + + data[i] = field_get(mask, reg); + } +} + int hisi_femac_of_to_plat(struct udevice *dev) { int ret, i; @@ -523,6 +607,9 @@ static const struct eth_ops hisi_femac_ops = { .free_pkt = hisi_femac_free_pkt, .stop = hisi_femac_stop, .write_hwaddr = hisi_femac_set_hw_mac_addr, + .get_sset_count = hisi_femac_get_sset_count, + .get_strings = hisi_femac_get_strings, + .get_stats = hisi_femac_get_stats, };
static const struct udevice_id hisi_femac_ids[] = {
They are not required to be global, make them static.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/net/hifemac.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/hifemac.c b/drivers/net/hifemac.c index d24023eefd..90cc247b3b 100644 --- a/drivers/net/hifemac.c +++ b/drivers/net/hifemac.c @@ -418,7 +418,7 @@ static void hisi_femac_get_stats(struct udevice *dev, u64 *data) } }
-int hisi_femac_of_to_plat(struct udevice *dev) +static int hisi_femac_of_to_plat(struct udevice *dev) { int ret, i; struct hisi_femac_priv *priv = dev_get_priv(dev); @@ -553,7 +553,7 @@ static int hisi_femac_phy_reset(struct hisi_femac_priv *priv) return 0; }
-int hisi_femac_probe(struct udevice *dev) +static int hisi_femac_probe(struct udevice *dev) { struct hisi_femac_priv *priv = dev_get_priv(dev); int ret, i;
