[PATCH v2] arm: mach-k3: Move K3 common schema.yaml out of board directory
This file is common for all K3, move it out of board/ directory and into mach-k3. As we need to change the path in k3-binman.dtsi let's take this opportunity to switch to absolute paths which makes adding non-TI boards (like Toradex Verdin) not need to override these paths.
Signed-off-by: Andrew Davis afd@ti.com ---
Changes for v2: - Rebased on -next
.../dts/k3-am625-verdin-wifi-dev-binman.dtsi | 66 ------------------- arch/arm/dts/k3-binman.dtsi | 28 ++++---- .../common => arch/arm/mach-k3}/schema.yaml | 0 3 files changed, 14 insertions(+), 80 deletions(-) rename {board/ti/common => arch/arm/mach-k3}/schema.yaml (100%)
diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi index ed2c4482ef0..dd832ee1f3d 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi @@ -5,72 +5,6 @@
#include "k3-binman.dtsi"
-#ifndef CONFIG_ARM64 - -&bcfg_yaml { - schema = "../../ti/common/schema.yaml"; -}; - -&pcfg_yaml { - schema = "../../ti/common/schema.yaml"; -}; - -&rcfg_yaml { - schema = "../../ti/common/schema.yaml"; -}; - -&scfg_yaml { - schema = "../../ti/common/schema.yaml"; -}; - -/* combined-tifs-cfg */ - -&bcfg_yaml_tifs { - schema = "../../ti/common/schema.yaml"; -}; - -&pcfg_yaml_tifs { - schema = "../../ti/common/schema.yaml"; -}; - -&rcfg_yaml_tifs { - schema = "../../ti/common/schema.yaml"; -}; - -&scfg_yaml_tifs { - schema = "../../ti/common/schema.yaml"; -}; - -/* combined-dm-cfg */ - -&pcfg_yaml_dm { - schema = "../../ti/common/schema.yaml"; -}; - -&rcfg_yaml_dm { - schema = "../../ti/common/schema.yaml"; -}; - -/* combined-sysfw-cfg */ - -&bcfg_yaml_sysfw { - schema = "../../ti/common/schema.yaml"; -}; - -&pcfg_yaml_sysfw { - schema = "../../ti/common/schema.yaml"; -}; - -&rcfg_yaml_sysfw { - schema = "../../ti/common/schema.yaml"; -}; - -&scfg_yaml_sysfw { - schema = "../../ti/common/schema.yaml"; -}; - -#endif /* CONFIG_ARM64 */ - #ifdef CONFIG_TARGET_VERDIN_AM62_R5
&binman { diff --git a/arch/arm/dts/k3-binman.dtsi b/arch/arm/dts/k3-binman.dtsi index c7513e1a5dd..cd9926a0169 100644 --- a/arch/arm/dts/k3-binman.dtsi +++ b/arch/arm/dts/k3-binman.dtsi @@ -32,28 +32,28 @@ filename = "board-cfg.bin"; bcfg_yaml: ti-board-config { config = "board-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; }; pm-cfg { filename = "pm-cfg.bin"; pcfg_yaml: ti-board-config { config = "pm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; }; rm-cfg { filename = "rm-cfg.bin"; rcfg_yaml: ti-board-config { config = "rm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; }; sec-cfg { filename = "sec-cfg.bin"; scfg_yaml: ti-board-config { config = "sec-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; }; combined-tifs-cfg { @@ -61,19 +61,19 @@ ti-board-config { bcfg_yaml_tifs: board-cfg { config = "board-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; scfg_yaml_tifs: sec-cfg { config = "sec-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; pcfg_yaml_tifs: pm-cfg { config = "pm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; rcfg_yaml_tifs: rm-cfg { config = "rm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; }; }; @@ -82,11 +82,11 @@ ti-board-config { pcfg_yaml_dm: pm-cfg { config = "pm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; rcfg_yaml_dm: rm-cfg { config = "rm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; }; }; @@ -95,19 +95,19 @@ ti-board-config { bcfg_yaml_sysfw: board-cfg { config = "board-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; scfg_yaml_sysfw: sec-cfg { config = "sec-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; pcfg_yaml_sysfw: pm-cfg { config = "pm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; rcfg_yaml_sysfw: rm-cfg { config = "rm-cfg.yaml"; - schema = "board/ti/common/schema.yaml"; + schema = "arch/arm/mach-k3/schema.yaml"; }; }; }; diff --git a/board/ti/common/schema.yaml b/arch/arm/mach-k3/schema.yaml similarity index 100% rename from board/ti/common/schema.yaml rename to arch/arm/mach-k3/schema.yaml
Andrew Davis
