[PATCH v2 01/12] rockchip: rk3228-power: sync power domain dt-binding header from Linux
In order to update the DT for rk3228 sync the power domain dt-binding header. This is the state as of v5.17 in Linux.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- include/dt-bindings/power/rk3228-power.h | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+) create mode 100644 include/dt-bindings/power/rk3228-power.h
diff --git a/include/dt-bindings/power/rk3228-power.h b/include/dt-bindings/power/rk3228-power.h new file mode 100644 index 00000000..6a8dc1bf --- /dev/null +++ b/include/dt-bindings/power/rk3228-power.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_POWER_RK3228_POWER_H__ +#define __DT_BINDINGS_POWER_RK3228_POWER_H__ + +/** + * RK3228 idle id Summary. + */ + +#define RK3228_PD_CORE 0 +#define RK3228_PD_MSCH 1 +#define RK3228_PD_BUS 2 +#define RK3228_PD_SYS 3 +#define RK3228_PD_VIO 4 +#define RK3228_PD_VOP 5 +#define RK3228_PD_VPU 6 +#define RK3228_PD_RKVDEC 7 +#define RK3228_PD_GPU 8 +#define RK3228_PD_PERI 9 +#define RK3228_PD_GMAC 10 + +#endif
In order to update the DT for rk3228 sync the clock dt-binding header. This is the state as of v5.17 in Linux.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- include/dt-bindings/clock/rk3228-cru.h | 54 +++++++++++++++++++++++++- 1 file changed, 52 insertions(+), 2 deletions(-)
diff --git a/include/dt-bindings/clock/rk3228-cru.h b/include/dt-bindings/clock/rk3228-cru.h index 1217d523..de550ea5 100644 --- a/include/dt-bindings/clock/rk3228-cru.h +++ b/include/dt-bindings/clock/rk3228-cru.h @@ -1,6 +1,7 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0-or-later */ /* - * (C) Copyright 2017 Rockchip Electronics Co., Ltd. + * Copyright (c) 2015 Rockchip Electronics Co. Ltd. + * Author: Jeffy Chen jeffy.chen@rock-chips.com */
#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3228_H @@ -39,6 +40,7 @@ #define SCLK_EMMC_DRV 117 #define SCLK_SDMMC_SAMPLE 118 #define SCLK_SDIO_SAMPLE 119 +#define SCLK_SDIO_SRC 120 #define SCLK_EMMC_SAMPLE 121 #define SCLK_VOP 122 #define SCLK_HDMI_HDCP 123 @@ -51,6 +53,18 @@ #define SCLK_MAC_TX 130 #define SCLK_MAC_PHY 131 #define SCLK_MAC_OUT 132 +#define SCLK_VDEC_CABAC 133 +#define SCLK_VDEC_CORE 134 +#define SCLK_RGA 135 +#define SCLK_HDCP 136 +#define SCLK_HDMI_CEC 137 +#define SCLK_CRYPTO 138 +#define SCLK_TSP 139 +#define SCLK_HSADC 140 +#define SCLK_WIFI 141 +#define SCLK_OTGPHY0 142 +#define SCLK_OTGPHY1 143 +#define SCLK_HDMI_PHY 144
/* dclk gates */ #define DCLK_VOP 190 @@ -58,15 +72,32 @@
/* aclk gates */ #define ACLK_DMAC 194 +#define ACLK_CPU 195 +#define ACLK_VPU_PRE 196 +#define ACLK_RKVDEC_PRE 197 +#define ACLK_RGA_PRE 198 +#define ACLK_IEP_PRE 199 +#define ACLK_HDCP_PRE 200 +#define ACLK_VOP_PRE 201 +#define ACLK_VPU 202 +#define ACLK_RKVDEC 203 +#define ACLK_IEP 204 +#define ACLK_RGA 205 +#define ACLK_HDCP 206 #define ACLK_PERI 210 #define ACLK_VOP 211 #define ACLK_GMAC 212 +#define ACLK_GPU 213
/* pclk gates */ #define PCLK_GPIO0 320 #define PCLK_GPIO1 321 #define PCLK_GPIO2 322 #define PCLK_GPIO3 323 +#define PCLK_VIO_H2P 324 +#define PCLK_HDCP 325 +#define PCLK_EFUSE_1024 326 +#define PCLK_EFUSE_256 327 #define PCLK_GRF 329 #define PCLK_I2C0 332 #define PCLK_I2C1 333 @@ -79,6 +110,7 @@ #define PCLK_TSADC 344 #define PCLK_PWM 350 #define PCLK_TIMER 353 +#define PCLK_CPU 354 #define PCLK_PERI 363 #define PCLK_HDMI_CTRL 364 #define PCLK_HDMI_PHY 365 @@ -94,6 +126,24 @@ #define HCLK_SDMMC 456 #define HCLK_SDIO 457 #define HCLK_EMMC 459 +#define HCLK_CPU 460 +#define HCLK_VPU_PRE 461 +#define HCLK_RKVDEC_PRE 462 +#define HCLK_VIO_PRE 463 +#define HCLK_VPU 464 +#define HCLK_RKVDEC 465 +#define HCLK_VIO 466 +#define HCLK_RGA 467 +#define HCLK_IEP 468 +#define HCLK_VIO_H2P 469 +#define HCLK_HDCP_MMU 470 +#define HCLK_HOST0 471 +#define HCLK_HOST1 472 +#define HCLK_HOST2 473 +#define HCLK_OTG 474 +#define HCLK_TSP 475 +#define HCLK_M_CRYPTO 476 +#define HCLK_S_CRYPTO 477 #define HCLK_PERI 478
#define CLK_NR_CLKS (HCLK_PERI + 1)
In order to sync rk322x.dtsi from Linux, move all U-boot specific properties in separate dtsi files.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3229-evb-u-boot.dtsi | 28 +++++++++++++++ arch/arm/dts/rk3229-evb.dts | 17 --------- arch/arm/dts/rk322x-u-boot.dtsi | 54 +++++++++++++++++++++++++++++ arch/arm/dts/rk322x.dtsi | 37 -------------------- 4 files changed, 82 insertions(+), 54 deletions(-) create mode 100644 arch/arm/dts/rk3229-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk322x-u-boot.dtsi
diff --git a/arch/arm/dts/rk3229-evb-u-boot.dtsi b/arch/arm/dts/rk3229-evb-u-boot.dtsi new file mode 100644 index 00000000..b65149c2 --- /dev/null +++ b/arch/arm/dts/rk3229-evb-u-boot.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk322x-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart2; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x96 0xC8 0x1F3 0xF 0x8000004D 0x4 0x4E 0x6 0x3 + 0x0 0x6 0x5 0xC 0x10 0x6 0x4 0x4 + 0x5 0x4 0x200 0x3 0xA 0x40 0x0 0x1 + 0x5 0x5 0x3 0xC 0x1E 0x100 0x0 0x4 + 0x0 0x924>; + rockchip,phy-timing = <0x220 0x1 0x0 0x0 0x0 0x4 0x60>; + rockchip,sdram-params = <0x428B188 0x0 0x21 0x472 0x15 + 0 300 3 0 120>; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index 632cdc9b..66a3ba23 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -11,10 +11,6 @@ model = "Rockchip RK3229 Evaluation board"; compatible = "rockchip,rk3229-evb", "rockchip,rk3229";
- chosen { - stdout-path = &uart2; - }; - memory@60000000 { device_type = "memory"; reg = <0x60000000 0x40000000>; @@ -38,17 +34,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x96 0xC8 0x1F3 0xF 0x8000004D 0x4 0x4E 0x6 0x3 - 0x0 0x6 0x5 0xC 0x10 0x6 0x4 0x4 - 0x5 0x4 0x200 0x3 0xA 0x40 0x0 0x1 - 0x5 0x5 0x3 0xC 0x1E 0x100 0x0 0x4 - 0x0 0x924>; - rockchip,phy-timing = <0x220 0x1 0x0 0x0 0x0 0x4 0x60>; - rockchip,sdram-params = <0x428B188 0x0 0x21 0x472 0x15 - 0 300 3 0 120>; -}; - &gmac { assigned-clocks = <&cru SCLK_MAC_EXTCLK>, <&cru SCLK_MAC>; assigned-clock-parents = <&ext_gmac>, <&cru SCLK_MAC_EXTCLK>; @@ -66,7 +51,6 @@ };
&emmc { - u-boot,dm-pre-reloc; status = "okay"; };
@@ -82,7 +66,6 @@ };
&uart2 { - u-boot,dm-pre-reloc; status = "okay"; };
diff --git a/arch/arm/dts/rk322x-u-boot.dtsi b/arch/arm/dts/rk322x-u-boot.dtsi new file mode 100644 index 00000000..ea5e8359 --- /dev/null +++ b/arch/arm/dts/rk322x-u-boot.dtsi @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/ { + bus_intmem@10080000 { + compatible = "mmio-sram"; + reg = <0x10080000 0x9000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x10080000 0x9000>; + + smp-sram@0 { + compatible = "rockchip,rk322x-smp-sram"; + reg = <0x00 0x10>; + }; + + ddr_sram: ddr-sram@1000 { + compatible = "rockchip,rk322x-ddr-sram"; + reg = <0x1000 0x8000>; + }; + }; + + dmc: dmc@11200000 { + compatible = "rockchip,rk3228-dmc", "syscon"; + reg = <0x11200000 0x3fc + 0x12000000 0x400>; + rockchip,cru = <&cru>; + rockchip,grf = <&grf>; + rockchip,msch = <&service_msch>; + rockchip,sram = <&ddr_sram>; + u-boot,dm-pre-reloc; + }; + + service_msch: syscon@31090000 { + compatible = "rockchip,rk3228-msch", "syscon"; + reg = <0x31090000 0x2000>; + u-boot,dm-pre-reloc; + }; +}; + +&cru { + u-boot,dm-pre-reloc; +}; + +&emmc { + max-frequency = <150000000>; +}; + +&grf { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + max-frequency = <150000000>; +}; diff --git a/arch/arm/dts/rk322x.dtsi b/arch/arm/dts/rk322x.dtsi index 4a8be5da..3245da3c 100644 --- a/arch/arm/dts/rk322x.dtsi +++ b/arch/arm/dts/rk322x.dtsi @@ -107,22 +107,6 @@ #clock-cells = <0>; };
- bus_intmem@10080000 { - compatible = "mmio-sram"; - reg = <0x10080000 0x9000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x10080000 0x9000>; - smp-sram@0 { - compatible = "rockchip,rk322x-smp-sram"; - reg = <0x00 0x10>; - }; - ddr_sram: ddr-sram@1000 { - compatible = "rockchip,rk322x-ddr-sram"; - reg = <0x1000 0x8000>; - }; - }; - i2s1: i2s1@100b0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100b0000 0x4000>; @@ -165,7 +149,6 @@ };
grf: syscon@11000000 { - u-boot,dm-pre-reloc; compatible = "rockchip,rk3228-grf", "syscon"; reg = <0x11000000 0x1000>; }; @@ -317,7 +300,6 @@ };
cru: clock-controller@110e0000 { - u-boot,dm-pre-reloc; compatible = "rockchip,rk3228-cru"; reg = <0x110e0000 0x1000>; rockchip,grf = <&grf>; @@ -387,7 +369,6 @@ sdmmc: dwmmc@30000000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30000000 0x4000>; - max-frequency = <150000000>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; @@ -414,7 +395,6 @@ emmc: dwmmc@30020000 { compatible = "rockchip,rk3288-dw-mshc"; reg = <0x30020000 0x4000>; - max-frequency = <150000000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; @@ -768,21 +748,4 @@ }; }; }; - - dmc: dmc@11200000 { - u-boot,dm-pre-reloc; - compatible = "rockchip,rk3228-dmc", "syscon"; - rockchip,cru = <&cru>; - rockchip,grf = <&grf>; - rockchip,msch = <&service_msch>; - reg = <0x11200000 0x3fc - 0x12000000 0x400>; - rockchip,sram = <&ddr_sram>; - }; - - service_msch: syscon@31090000 { - u-boot,dm-pre-reloc; - compatible = "rockchip,rk3228-msch", "syscon"; - reg = <0x31090000 0x2000>; - }; };
Sync rk322x.dtsi from Linux version 5.17.
Changed V2: update rename usb20_otg label --- arch/arm/dts/rk3229-evb.dts | 2 +- arch/arm/dts/rk322x.dtsi | 846 +++++++++++++++++++++++++++++------- 2 files changed, 695 insertions(+), 153 deletions(-)
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index 66a3ba23..d2681d1a 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -69,6 +69,6 @@ status = "okay"; };
-&usb20_otg { +&usb_otg { status = "okay"; }; diff --git a/arch/arm/dts/rk322x.dtsi b/arch/arm/dts/rk322x.dtsi index 3245da3c..8eed9e3a 100644 --- a/arch/arm/dts/rk322x.dtsi +++ b/arch/arm/dts/rk322x.dtsi @@ -1,7 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> @@ -9,6 +6,7 @@ #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/clock/rk3228-cru.h> #include <dt-bindings/thermal/thermal.h> +#include <dt-bindings/power/rk3228-power.h>
/ { #address-cells = <1>; @@ -20,8 +18,7 @@ serial0 = &uart0; serial1 = &uart1; serial2 = &uart2; - mmc0 = &emmc; - mmc1 = &sdmmc; + spi0 = &spi0; };
cpus { @@ -33,13 +30,11 @@ compatible = "arm,cortex-a7"; reg = <0xf00>; resets = <&cru SRST_CORE0>; - operating-points = < - /* KHz uV */ - 816000 1000000 - >; + operating-points-v2 = <&cpu0_opp_table>; #cooling-cells = <2>; /* min followed by max */ clock-latency = <40000>; clocks = <&cru ARMCLK>; + enable-method = "psci"; };
cpu1: cpu@f01 { @@ -47,6 +42,9 @@ compatible = "arm,cortex-a7"; reg = <0xf01>; resets = <&cru SRST_CORE1>; + operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + enable-method = "psci"; };
cpu2: cpu@f02 { @@ -54,6 +52,9 @@ compatible = "arm,cortex-a7"; reg = <0xf02>; resets = <&cru SRST_CORE2>; + operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + enable-method = "psci"; };
cpu3: cpu@f03 { @@ -61,23 +62,37 @@ compatible = "arm,cortex-a7"; reg = <0xf03>; resets = <&cru SRST_CORE3>; + operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + enable-method = "psci"; }; };
- amba { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges; + cpu0_opp_table: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared;
- pdma: pdma@110f0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x110f0000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC>; - clock-names = "apb_pclk"; + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <950000>; + clock-latency-ns = <40000>; + opp-suspend; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <975000>; + }; + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1000000>; + }; + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1175000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1275000>; }; };
@@ -90,6 +105,11 @@ interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; };
+ psci { + compatible = "arm,psci-1.0", "arm,psci-0.2"; + method = "smc"; + }; + timer { compatible = "arm,armv7-timer"; arm,cpu-registers-not-fw-configured; @@ -107,12 +127,15 @@ #clock-cells = <0>; };
+ display_subsystem: display-subsystem { + compatible = "rockchip,display-subsystem"; + ports = <&vop_out>; + }; + i2s1: i2s1@100b0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100b0000 0x4000>; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>; dmas = <&pdma 14>, <&pdma 15>; @@ -126,8 +149,6 @@ compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100c0000 0x4000>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0_8CH>; dmas = <&pdma 11>, <&pdma 12>; @@ -135,12 +156,23 @@ status = "disabled"; };
+ spdif: spdif@100d0000 { + compatible = "rockchip,rk3228-spdif"; + reg = <0x100d0000 0x1000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_SPDIF>, <&cru HCLK_SPDIF_8CH>; + clock-names = "mclk", "hclk"; + dmas = <&pdma 10>; + dma-names = "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx>; + status = "disabled"; + }; + i2s2: i2s2@100e0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100e0000 0x4000>; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2_2CH>; dmas = <&pdma 0>, <&pdma 1>; @@ -149,8 +181,124 @@ };
grf: syscon@11000000 { - compatible = "rockchip,rk3228-grf", "syscon"; + compatible = "rockchip,rk3228-grf", "syscon", "simple-mfd"; reg = <0x11000000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + + io_domains: io-domains { + compatible = "rockchip,rk3228-io-voltage-domain"; + status = "disabled"; + }; + + power: power-controller { + compatible = "rockchip,rk3228-power-controller"; + #power-domain-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + + power-domain@RK3228_PD_VIO { + reg = <RK3228_PD_VIO>; + clocks = <&cru ACLK_HDCP>, + <&cru SCLK_HDCP>, + <&cru ACLK_IEP>, + <&cru HCLK_IEP>, + <&cru ACLK_RGA>, + <&cru HCLK_RGA>, + <&cru SCLK_RGA>; + pm_qos = <&qos_hdcp>, + <&qos_iep>, + <&qos_rga_r>, + <&qos_rga_w>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_VOP { + reg = <RK3228_PD_VOP>; + clocks =<&cru ACLK_VOP>, + <&cru DCLK_VOP>, + <&cru HCLK_VOP>; + pm_qos = <&qos_vop>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_VPU { + reg = <RK3228_PD_VPU>; + clocks = <&cru ACLK_VPU>, + <&cru HCLK_VPU>; + pm_qos = <&qos_vpu>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_RKVDEC { + reg = <RK3228_PD_RKVDEC>; + clocks = <&cru ACLK_RKVDEC>, + <&cru HCLK_RKVDEC>, + <&cru SCLK_VDEC_CABAC>, + <&cru SCLK_VDEC_CORE>; + pm_qos = <&qos_rkvdec_r>, + <&qos_rkvdec_w>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_GPU { + reg = <RK3228_PD_GPU>; + clocks = <&cru ACLK_GPU>; + pm_qos = <&qos_gpu>; + #power-domain-cells = <0>; + }; + }; + + u2phy0: usb2phy@760 { + compatible = "rockchip,rk3228-usb2phy"; + reg = <0x0760 0x0c>; + clocks = <&cru SCLK_OTGPHY0>; + clock-names = "phyclk"; + clock-output-names = "usb480m_phy0"; + #clock-cells = <0>; + status = "disabled"; + + u2phy0_otg: otg-port { + interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "otg-bvalid", "otg-id", + "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + + u2phy0_host: host-port { + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + }; + + u2phy1: usb2phy@800 { + compatible = "rockchip,rk3228-usb2phy"; + reg = <0x0800 0x0c>; + clocks = <&cru SCLK_OTGPHY1>; + clock-names = "phyclk"; + clock-output-names = "usb480m_phy1"; + #clock-cells = <0>; + status = "disabled"; + + u2phy1_otg: otg-port { + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + + u2phy1_host: host-port { + interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + }; };
uart0: serial@11010000 { @@ -189,12 +337,29 @@ clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; - pinctrl-0 = <&uart21_xfer>; + pinctrl-0 = <&uart2_xfer>; reg-shift = <2>; reg-io-width = <4>; status = "disabled"; };
+ efuse: efuse@11040000 { + compatible = "rockchip,rk3228-efuse"; + reg = <0x11040000 0x20>; + clocks = <&cru PCLK_EFUSE_256>; + clock-names = "pclk_efuse"; + #address-cells = <1>; + #size-cells = <1>; + + /* Data cells */ + efuse_id: id@7 { + reg = <0x7 0x10>; + }; + cpu_leakage: cpu_leakage@17 { + reg = <0x17 0x1>; + }; + }; + i2c0: i2c@11050000 { compatible = "rockchip,rk3228-i2c"; reg = <0x11050000 0x1000>; @@ -247,12 +412,32 @@ status = "disabled"; };
+ spi0: spi@11090000 { + compatible = "rockchip,rk3228-spi"; + reg = <0x11090000 0x1000>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; + clock-names = "spiclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0 &spi0_cs1>; + status = "disabled"; + }; + + wdt: watchdog@110a0000 { + compatible = "rockchip,rk3228-wdt", "snps,dw-wdt"; + reg = <0x110a0000 0x100>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_CPU>; + status = "disabled"; + }; + pwm0: pwm@110b0000 { compatible = "rockchip,rk3288-pwm"; reg = <0x110b0000 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; status = "disabled"; @@ -263,7 +448,6 @@ reg = <0x110b0010 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; status = "disabled"; @@ -274,7 +458,6 @@ reg = <0x110b0020 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; status = "disabled"; @@ -285,18 +468,17 @@ reg = <0x110b0030 0x10>; #pwm-cells = <2>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; status = "disabled"; };
timer: timer@110c0000 { - compatible = "rockchip,rk3288-timer"; + compatible = "rockchip,rk3228-timer", "rockchip,rk3288-timer"; reg = <0x110c0000 0x20>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&xin24m>, <&cru PCLK_TIMER>; - clock-names = "timer", "pclk"; + clocks = <&cru PCLK_TIMER>, <&xin24m>; + clock-names = "pclk", "timer"; };
cru: clock-controller@110e0000 { @@ -305,8 +487,29 @@ rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>; - assigned-clocks = <&cru PLL_GPLL>; - assigned-clock-rates = <594000000>; + assigned-clocks = + <&cru PLL_GPLL>, <&cru ARMCLK>, + <&cru PLL_CPLL>, <&cru ACLK_PERI>, + <&cru HCLK_PERI>, <&cru PCLK_PERI>, + <&cru ACLK_CPU>, <&cru HCLK_CPU>, + <&cru PCLK_CPU>; + assigned-clock-rates = + <594000000>, <816000000>, + <500000000>, <150000000>, + <150000000>, <75000000>, + <150000000>, <150000000>, + <75000000>; + }; + + pdma: pdma@110f0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x110f0000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC>; + clock-names = "apb_pclk"; };
thermal-zones { @@ -338,12 +541,18 @@ map0 { trip = <&cpu_alert0>; cooling-device = - <&cpu0 THERMAL_NO_LIMIT 6>; + <&cpu0 THERMAL_NO_LIMIT 6>, + <&cpu1 THERMAL_NO_LIMIT 6>, + <&cpu2 THERMAL_NO_LIMIT 6>, + <&cpu3 THERMAL_NO_LIMIT 6>; }; map1 { trip = <&cpu_alert1>; cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; @@ -355,53 +564,220 @@ interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; clock-names = "tsadc", "apb_pclk"; + assigned-clocks = <&cru SCLK_TSADC>; + assigned-clock-rates = <32768>; resets = <&cru SRST_TSADC>; reset-names = "tsadc-apb"; pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&otp_gpio>; + pinctrl-0 = <&otp_pin>; pinctrl-1 = <&otp_out>; - pinctrl-2 = <&otp_gpio>; - #thermal-sensor-cells = <0>; + pinctrl-2 = <&otp_pin>; + #thermal-sensor-cells = <1>; rockchip,hw-tshut-temp = <95000>; status = "disabled"; };
- sdmmc: dwmmc@30000000 { + hdmi_phy: hdmi-phy@12030000 { + compatible = "rockchip,rk3228-hdmi-phy"; + reg = <0x12030000 0x10000>; + clocks = <&cru PCLK_HDMI_PHY>, <&xin24m>, <&cru DCLK_HDMI_PHY>; + clock-names = "sysclk", "refoclk", "refpclk"; + #clock-cells = <0>; + clock-output-names = "hdmiphy_phy"; + #phy-cells = <0>; + status = "disabled"; + }; + + gpu: gpu@20000000 { + compatible = "rockchip,rk3228-mali", "arm,mali-400"; + reg = <0x20000000 0x10000>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gp", + "gpmmu", + "pp0", + "ppmmu0", + "pp1", + "ppmmu1"; + clocks = <&cru ACLK_GPU>, <&cru ACLK_GPU>; + clock-names = "bus", "core"; + power-domains = <&power RK3228_PD_GPU>; + resets = <&cru SRST_GPU_A>; + status = "disabled"; + }; + + vpu: video-codec@20020000 { + compatible = "rockchip,rk3228-vpu", "rockchip,rk3399-vpu"; + reg = <0x20020000 0x800>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "vepu", "vdpu"; + clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; + clock-names = "aclk", "hclk"; + iommus = <&vpu_mmu>; + power-domains = <&power RK3228_PD_VPU>; + }; + + vpu_mmu: iommu@20020800 { + compatible = "rockchip,iommu"; + reg = <0x20020800 0x100>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_VPU>; + #iommu-cells = <0>; + }; + + vdec: video-codec@20030000 { + compatible = "rockchip,rk3228-vdec", "rockchip,rk3399-vdec"; + reg = <0x20030000 0x480>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>, + <&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>; + clock-names = "axi", "ahb", "cabac", "core"; + assigned-clocks = <&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>; + assigned-clock-rates = <300000000>, <300000000>; + iommus = <&vdec_mmu>; + power-domains = <&power RK3228_PD_RKVDEC>; + }; + + vdec_mmu: iommu@20030480 { + compatible = "rockchip,iommu"; + reg = <0x20030480 0x40>, <0x200304c0 0x40>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_RKVDEC>; + #iommu-cells = <0>; + }; + + vop: vop@20050000 { + compatible = "rockchip,rk3228-vop"; + reg = <0x20050000 0x1ffc>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_VOP>, <&cru DCLK_VOP>, <&cru HCLK_VOP>; + clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + resets = <&cru SRST_VOP_A>, <&cru SRST_VOP_H>, <&cru SRST_VOP_D>; + reset-names = "axi", "ahb", "dclk"; + iommus = <&vop_mmu>; + power-domains = <&power RK3228_PD_VOP>; + status = "disabled"; + + vop_out: port { + #address-cells = <1>; + #size-cells = <0>; + + vop_out_hdmi: endpoint@0 { + reg = <0>; + remote-endpoint = <&hdmi_in_vop>; + }; + }; + }; + + vop_mmu: iommu@20053f00 { + compatible = "rockchip,iommu"; + reg = <0x20053f00 0x100>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_VOP>; + #iommu-cells = <0>; + status = "disabled"; + }; + + rga: rga@20060000 { + compatible = "rockchip,rk3228-rga", "rockchip,rk3288-rga"; + reg = <0x20060000 0x1000>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>; + clock-names = "aclk", "hclk", "sclk"; + power-domains = <&power RK3228_PD_VIO>; + resets = <&cru SRST_RGA>, <&cru SRST_RGA_A>, <&cru SRST_RGA_H>; + reset-names = "core", "axi", "ahb"; + }; + + iep_mmu: iommu@20070800 { + compatible = "rockchip,iommu"; + reg = <0x20070800 0x100>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_VIO>; + #iommu-cells = <0>; + status = "disabled"; + }; + + hdmi: hdmi@200a0000 { + compatible = "rockchip,rk3228-dw-hdmi"; + reg = <0x200a0000 0x20000>; + reg-io-width = <4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + assigned-clocks = <&cru SCLK_HDMI_PHY>; + assigned-clock-parents = <&hdmi_phy>; + clocks = <&cru SCLK_HDMI_HDCP>, <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_CEC>; + clock-names = "isfr", "iahb", "cec"; + pinctrl-names = "default"; + pinctrl-0 = <&hdmii2c_xfer &hdmi_hpd &hdmi_cec>; + resets = <&cru SRST_HDMI_P>; + reset-names = "hdmi"; + phys = <&hdmi_phy>; + phy-names = "hdmi"; + rockchip,grf = <&grf>; + status = "disabled"; + + ports { + hdmi_in: port { + #address-cells = <1>; + #size-cells = <0>; + hdmi_in_vop: endpoint@0 { + reg = <0>; + remote-endpoint = <&vop_out_hdmi>; + }; + }; + }; + }; + + sdmmc: mmc@30000000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30000000 0x4000>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; status = "disabled"; };
- sdio: dwmmc@30010000 { + sdio: mmc@30010000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30010000 0x4000>; interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&sdio_clk &sdio_cmd &sdio_bus4>; status = "disabled"; };
- emmc: dwmmc@30020000 { - compatible = "rockchip,rk3288-dw-mshc"; + emmc: mmc@30020000 { + compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30020000 0x4000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <37500000>; + max-frequency = <37500000>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; bus-width = <8>; - default-sample-phase = <158>; - num-slots = <1>; + rockchip,default-sample-phase = <158>; fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; @@ -410,13 +786,79 @@ status = "disabled"; };
- usb20_otg: usb@30040000 { - compatible = "rockchip,rk3229-usb", "rockchip,rk3288-usb", + usb_otg: usb@30040000 { + compatible = "rockchip,rk3228-usb", "rockchip,rk3066-usb", "snps,dwc2"; reg = <0x30040000 0x40000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - hnp-srp-disable; + clocks = <&cru HCLK_OTG>; + clock-names = "otg"; dr_mode = "otg"; + g-np-tx-fifo-size = <16>; + g-rx-fifo-size = <280>; + g-tx-fifo-size = <256 128 128 64 32 16>; + phys = <&u2phy0_otg>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + usb_host0_ehci: usb@30080000 { + compatible = "generic-ehci"; + reg = <0x30080000 0x20000>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&u2phy0>; + phys = <&u2phy0_host>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host0_ohci: usb@300a0000 { + compatible = "generic-ohci"; + reg = <0x300a0000 0x20000>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&u2phy0>; + phys = <&u2phy0_host>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host1_ehci: usb@300c0000 { + compatible = "generic-ehci"; + reg = <0x300c0000 0x20000>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&u2phy1>; + phys = <&u2phy1_otg>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host1_ohci: usb@300e0000 { + compatible = "generic-ohci"; + reg = <0x300e0000 0x20000>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&u2phy1>; + phys = <&u2phy1_otg>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host2_ehci: usb@30100000 { + compatible = "generic-ehci"; + reg = <0x30100000 0x20000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST2>, <&u2phy1>; + phys = <&u2phy1_host>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host2_ohci: usb@30120000 { + compatible = "generic-ohci"; + reg = <0x30120000 0x20000>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST2>, <&u2phy1>; + phys = <&u2phy1_host>; + phy-names = "usb"; status = "disabled"; };
@@ -439,6 +881,51 @@ status = "disabled"; };
+ qos_iep: qos@31030080 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030080 0x20>; + }; + + qos_rga_w: qos@31030100 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030100 0x20>; + }; + + qos_hdcp: qos@31030180 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030180 0x20>; + }; + + qos_rga_r: qos@31030200 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030200 0x20>; + }; + + qos_vpu: qos@31040000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31040000 0x20>; + }; + + qos_gpu: qos@31050000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31050000 0x20>; + }; + + qos_vop: qos@31060000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31060000 0x20>; + }; + + qos_rkvdec_r: qos@31070000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31070000 0x20>; + }; + + qos_rkvdec_w: qos@31070080 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31070080 0x20>; + }; + gic: interrupt-controller@32010000 { compatible = "arm,gic-400"; interrupt-controller; @@ -459,7 +946,7 @@ #size-cells = <1>; ranges;
- gpio0: gpio0@11110000 { + gpio0: gpio@11110000 { compatible = "rockchip,gpio-bank"; reg = <0x11110000 0x100>; interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; @@ -472,7 +959,7 @@ #interrupt-cells = <2>; };
- gpio1: gpio1@11120000 { + gpio1: gpio@11120000 { compatible = "rockchip,gpio-bank"; reg = <0x11120000 0x100>; interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; @@ -485,7 +972,7 @@ #interrupt-cells = <2>; };
- gpio2: gpio2@11130000 { + gpio2: gpio@11130000 { compatible = "rockchip,gpio-bank"; reg = <0x11130000 0x100>; interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; @@ -498,7 +985,7 @@ #interrupt-cells = <2>; };
- gpio3: gpio3@11140000 { + gpio3: gpio@11140000 { compatible = "rockchip,gpio-bank"; reg = <0x11140000 0x100>; interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; @@ -529,222 +1016,277 @@
sdmmc { sdmmc_clk: sdmmc-clk { - rockchip,pins = <1 16 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <1 RK_PC0 1 &pcfg_pull_none_drv_12ma>; };
sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <1 15 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <1 RK_PB7 1 &pcfg_pull_none_drv_12ma>; };
sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <1 18 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <1 19 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <1 20 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <1 21 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <1 RK_PC2 1 &pcfg_pull_none_drv_12ma>, + <1 RK_PC3 1 &pcfg_pull_none_drv_12ma>, + <1 RK_PC4 1 &pcfg_pull_none_drv_12ma>, + <1 RK_PC5 1 &pcfg_pull_none_drv_12ma>; }; };
sdio { sdio_clk: sdio-clk { - rockchip,pins = <3 0 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <3 RK_PA0 1 &pcfg_pull_none_drv_12ma>; };
sdio_cmd: sdio-cmd { - rockchip,pins = <3 1 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <3 RK_PA1 1 &pcfg_pull_none_drv_12ma>; };
sdio_bus4: sdio-bus4 { - rockchip,pins = <3 2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <3 3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <3 4 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <3 5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <3 RK_PA2 1 &pcfg_pull_none_drv_12ma>, + <3 RK_PA3 1 &pcfg_pull_none_drv_12ma>, + <3 RK_PA4 1 &pcfg_pull_none_drv_12ma>, + <3 RK_PA5 1 &pcfg_pull_none_drv_12ma>; }; };
emmc { emmc_clk: emmc-clk { - rockchip,pins = <2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA7 2 &pcfg_pull_none>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <1 RK_PC6 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PC6 2 &pcfg_pull_none>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <1 RK_PD0 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD1 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD2 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD3 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD4 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD5 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD6 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD7 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PD0 2 &pcfg_pull_none>, + <1 RK_PD1 2 &pcfg_pull_none>, + <1 RK_PD2 2 &pcfg_pull_none>, + <1 RK_PD3 2 &pcfg_pull_none>, + <1 RK_PD4 2 &pcfg_pull_none>, + <1 RK_PD5 2 &pcfg_pull_none>, + <1 RK_PD6 2 &pcfg_pull_none>, + <1 RK_PD7 2 &pcfg_pull_none>; }; };
gmac { rgmii_pins: rgmii-pins { - rockchip,pins = <2 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC6 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC7 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PB1 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PB5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC0 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC5 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PC4 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 1 &pcfg_pull_none>, + <2 RK_PB4 1 &pcfg_pull_none>, + <2 RK_PD1 1 &pcfg_pull_none>, + <2 RK_PC3 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC2 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC6 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC7 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB1 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB5 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC1 1 &pcfg_pull_none>, + <2 RK_PC0 1 &pcfg_pull_none>, + <2 RK_PC5 2 &pcfg_pull_none>, + <2 RK_PC4 2 &pcfg_pull_none>, + <2 RK_PB3 1 &pcfg_pull_none>, + <2 RK_PB0 1 &pcfg_pull_none>; };
rmii_pins: rmii-pins { - rockchip,pins = <2 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PB5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC0 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB7 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 1 &pcfg_pull_none>, + <2 RK_PB4 1 &pcfg_pull_none>, + <2 RK_PD1 1 &pcfg_pull_none>, + <2 RK_PC3 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC2 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB5 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC1 1 &pcfg_pull_none>, + <2 RK_PC0 1 &pcfg_pull_none>, + <2 RK_PB0 1 &pcfg_pull_none>, + <2 RK_PB7 1 &pcfg_pull_none>; };
phy_pins: phy-pins { - rockchip,pins = <2 RK_PB6 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 2 &pcfg_pull_none>, + <2 RK_PB0 2 &pcfg_pull_none>; + }; + }; + + hdmi { + hdmi_hpd: hdmi-hpd { + rockchip,pins = <0 RK_PB7 1 &pcfg_pull_down>; + }; + + hdmii2c_xfer: hdmii2c-xfer { + rockchip,pins = <0 RK_PA6 2 &pcfg_pull_none>, + <0 RK_PA7 2 &pcfg_pull_none>; + }; + + hdmi_cec: hdmi-cec { + rockchip,pins = <0 RK_PC4 1 &pcfg_pull_none>; }; };
i2c0 { i2c0_xfer: i2c0-xfer { - rockchip,pins = <0 RK_PA0 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>, + <0 RK_PA1 1 &pcfg_pull_none>; }; };
i2c1 { i2c1_xfer: i2c1-xfer { - rockchip,pins = <0 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PA3 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA2 1 &pcfg_pull_none>, + <0 RK_PA3 1 &pcfg_pull_none>; }; };
i2c2 { i2c2_xfer: i2c2-xfer { - rockchip,pins = <2 RK_PC4 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PC4 1 &pcfg_pull_none>, + <2 RK_PC5 1 &pcfg_pull_none>; }; };
i2c3 { i2c3_xfer: i2c3-xfer { - rockchip,pins = <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PA7 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA6 1 &pcfg_pull_none>, + <0 RK_PA7 1 &pcfg_pull_none>; + }; + }; + + spi0 { + spi0_clk: spi0-clk { + rockchip,pins = <0 RK_PB1 2 &pcfg_pull_up>; + }; + spi0_cs0: spi0-cs0 { + rockchip,pins = <0 RK_PB6 2 &pcfg_pull_up>; + }; + spi0_tx: spi0-tx { + rockchip,pins = <0 RK_PB3 2 &pcfg_pull_up>; + }; + spi0_rx: spi0-rx { + rockchip,pins = <0 RK_PB5 2 &pcfg_pull_up>; + }; + spi0_cs1: spi0-cs1 { + rockchip,pins = <1 RK_PB4 1 &pcfg_pull_up>; + }; + }; + + spi1 { + spi1_clk: spi1-clk { + rockchip,pins = <0 RK_PC7 2 &pcfg_pull_up>; + }; + spi1_cs0: spi1-cs0 { + rockchip,pins = <2 RK_PA2 2 &pcfg_pull_up>; + }; + spi1_rx: spi1-rx { + rockchip,pins = <2 RK_PA0 2 &pcfg_pull_up>; + }; + spi1_tx: spi1-tx { + rockchip,pins = <2 RK_PA1 2 &pcfg_pull_up>; + }; + spi1_cs1: spi1-cs1 { + rockchip,pins = <2 RK_PA3 2 &pcfg_pull_up>; }; };
i2s1 { i2s1_bus: i2s1-bus { - rockchip,pins = <0 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PA4 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PB0 1 &pcfg_pull_none>, + <0 RK_PB1 1 &pcfg_pull_none>, + <0 RK_PB3 1 &pcfg_pull_none>, + <0 RK_PB4 1 &pcfg_pull_none>, + <0 RK_PB5 1 &pcfg_pull_none>, + <0 RK_PB6 1 &pcfg_pull_none>, + <1 RK_PA2 2 &pcfg_pull_none>, + <1 RK_PA4 2 &pcfg_pull_none>, + <1 RK_PA5 2 &pcfg_pull_none>; }; };
pwm0 { pwm0_pin: pwm0-pin { - rockchip,pins = <3 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <3 RK_PC5 1 &pcfg_pull_none>; }; };
pwm1 { pwm1_pin: pwm1-pin { - rockchip,pins = <0 RK_PD6 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PD6 2 &pcfg_pull_none>; }; };
pwm2 { pwm2_pin: pwm2-pin { - rockchip,pins = <1 RK_PB4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB4 2 &pcfg_pull_none>; }; };
pwm3 { pwm3_pin: pwm3-pin { - rockchip,pins = <1 RK_PB3 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB3 2 &pcfg_pull_none>; + }; + }; + + spdif { + spdif_tx: spdif-tx { + rockchip,pins = <3 RK_PD7 2 &pcfg_pull_none>; }; };
tsadc { - otp_gpio: otp-gpio { + otp_pin: otp-pin { rockchip,pins = <0 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; };
otp_out: otp-out { - rockchip,pins = <0 RK_PD0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PD0 2 &pcfg_pull_none>; }; };
uart0 { uart0_xfer: uart0-xfer { - rockchip,pins = <2 RK_PD2 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PD3 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PD2 1 &pcfg_pull_none>, + <2 RK_PD3 1 &pcfg_pull_none>; };
uart0_cts: uart0-cts { - rockchip,pins = <2 RK_PD5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PD5 1 &pcfg_pull_none>; };
uart0_rts: uart0-rts { - rockchip,pins = <0 RK_PC1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC1 1 &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { - rockchip,pins = <1 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PB2 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB1 1 &pcfg_pull_none>, + <1 RK_PB2 1 &pcfg_pull_none>; };
uart1_cts: uart1-cts { - rockchip,pins = <1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB0 1 &pcfg_pull_none>; };
uart1_rts: uart1-rts { - rockchip,pins = <1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB3 1 &pcfg_pull_none>; }; };
uart2 { uart2_xfer: uart2-xfer { - rockchip,pins = <1 RK_PC2 RK_FUNC_2 &pcfg_pull_up>, - <1 RK_PC3 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PC2 2 &pcfg_pull_up>, + <1 RK_PC3 2 &pcfg_pull_none>; };
- uart2_cts: uart2-cts { - rockchip,pins = <0 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; + uart21_xfer: uart21-xfer { + rockchip,pins = <1 RK_PB2 2 &pcfg_pull_up>, + <1 RK_PB1 2 &pcfg_pull_none>; };
- uart2_rts: uart2-rts { - rockchip,pins = <0 RK_PD0 RK_FUNC_1 &pcfg_pull_none>; + uart2_cts: uart2-cts { + rockchip,pins = <0 RK_PD1 1 &pcfg_pull_none>; }; - };
- uart2-1 { - uart21_xfer: uart21-xfer { - rockchip,pins = <1 10 RK_FUNC_2 &pcfg_pull_up>, - <1 9 RK_FUNC_2 &pcfg_pull_none>; + uart2_rts: uart2-rts { + rockchip,pins = <0 RK_PD0 1 &pcfg_pull_none>; }; }; };
Sync rk3229-evb.dts from Linux version 5.17.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3229-evb.dts | 212 +++++++++++++++++++++++++++++++++--- arch/arm/dts/rk3229.dtsi | 52 +++++++++ 2 files changed, 249 insertions(+), 15 deletions(-) create mode 100644 arch/arm/dts/rk3229.dtsi
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index d2681d1a..797476e8 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -1,21 +1,32 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2017 Rockchip Electronics Co., Ltd. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
/dts-v1/;
-#include "rk322x.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3229.dtsi"
/ { model = "Rockchip RK3229 Evaluation board"; compatible = "rockchip,rk3229-evb", "rockchip,rk3229";
+ aliases { + mmc0 = &emmc; + }; + memory@60000000 { device_type = "memory"; reg = <0x60000000 0x40000000>; };
+ dc_12v: dc-12v-regulator { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + ext_gmac: ext_gmac { compatible = "fixed-clock"; clock-frequency = <125000000>; @@ -23,6 +34,18 @@ #clock-cells = <0>; };
+ vcc_host: vcc-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PC4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc_host"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + }; + vcc_phy: vcc-phy-regulator { compatible = "regulator-fixed"; enable-active-high; @@ -31,7 +54,95 @@ regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; + vin-supply = <&vccio_1v8>; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vccio_1v8: vccio-1v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "vccio_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vccio_3v3: vccio-3v3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vccio_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vdd_arm: vdd-arm-regulator { + compatible = "pwm-regulator"; + pwms = <&pwm1 0 25000 1>; + pwm-supply = <&vcc_sys>; + regulator-name = "vdd_arm"; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; }; + + vdd_log: vdd-log-regulator { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + pwm-supply = <&vcc_sys>; + regulator-name = "vdd_log"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-always-on; + regulator-boot-on; + }; + + gpio_keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_key>; + + power_key: power-key { + label = "GPIO Key Power"; + gpios = <&gpio3 23 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + debounce-interval = <100>; + wakeup-source; + }; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&cpu1 { + cpu-supply = <&vdd_arm>; +}; + +&cpu2 { + cpu-supply = <&vdd_arm>; +}; + +&cpu3 { + cpu-supply = <&vdd_arm>; +}; + +&emmc { + cap-mmc-highspeed; + non-removable; + status = "okay"; };
&gmac { @@ -50,25 +161,96 @@ status = "okay"; };
-&emmc { +&io_domains { status = "okay"; + + vccio1-supply = <&vccio_3v3>; + vccio2-supply = <&vccio_1v8>; + vccio4-supply = <&vccio_3v3>; };
-&sdmmc { +&pinctrl { + keys { + pwr_key: pwr-key { + rockchip,pins = <3 RK_PC7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <3 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm1 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ status = "okay"; - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - supports-sd; };
&uart2 { status = "okay"; };
+&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + phy-supply = <&vcc_host>; + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc_host>; + status = "okay"; + }; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host2_ehci { + status = "okay"; +}; + +&usb_host2_ohci { + status = "okay"; +}; + &usb_otg { - status = "okay"; + status = "okay"; }; diff --git a/arch/arm/dts/rk3229.dtsi b/arch/arm/dts/rk3229.dtsi new file mode 100644 index 00000000..c340fb30 --- /dev/null +++ b/arch/arm/dts/rk3229.dtsi @@ -0,0 +1,52 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd + */ + +#include "rk322x.dtsi" + +/ { + compatible = "rockchip,rk3229"; + + /delete-node/ opp-table0; + + cpu0_opp_table: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <950000>; + clock-latency-ns = <40000>; + opp-suspend; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <975000>; + }; + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1000000>; + }; + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1175000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1275000>; + }; + opp-1296000000 { + opp-hz = /bits/ 64 <1296000000>; + opp-microvolt = <1325000>; + }; + opp-1392000000 { + opp-hz = /bits/ 64 <1392000000>; + opp-microvolt = <1375000>; + }; + opp-1464000000 { + opp-hz = /bits/ 64 <1464000000>; + opp-microvolt = <1400000>; + }; + }; +};
In order to update the DT for rk3288 sync the power domain dt-binding header. This is the state as of v5.17 in Linux. Change location to be more in line with other SoCs.
Changed V2: changed include rk3288.dtsi --- arch/arm/dts/rk3288.dtsi | 2 +- include/dt-bindings/power-domain/rk3288.h | 11 -------- include/dt-bindings/power/rk3288-power.h | 32 +++++++++++++++++++++++ 3 files changed, 33 insertions(+), 12 deletions(-) delete mode 100644 include/dt-bindings/power-domain/rk3288.h create mode 100644 include/dt-bindings/power/rk3288-power.h
diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 22bb06ce..2086dbfd 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -5,7 +5,7 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/clock/rk3288-cru.h> -#include <dt-bindings/power-domain/rk3288.h> +#include <dt-bindings/power/rk3288-power.h> #include <dt-bindings/thermal/thermal.h> #include <dt-bindings/video/rk3288.h> #include "skeleton.dtsi" diff --git a/include/dt-bindings/power-domain/rk3288.h b/include/dt-bindings/power-domain/rk3288.h deleted file mode 100644 index ca68c114..00000000 --- a/include/dt-bindings/power-domain/rk3288.h +++ /dev/null @@ -1,11 +0,0 @@ -#ifndef __DT_BINDINGS_POWER_DOMAIN_RK3288_H__ -#define __DT_BINDINGS_POWER_DOMAIN_RK3288_H__ - -/* RK3288 power domain index */ -#define RK3288_PD_GPU 0 -#define RK3288_PD_VIO 1 -#define RK3288_PD_VIDEO 2 -#define RK3288_PD_HEVC 3 -#define RK3288_PD_PERI 4 - -#endif diff --git a/include/dt-bindings/power/rk3288-power.h b/include/dt-bindings/power/rk3288-power.h new file mode 100644 index 00000000..f710b56c --- /dev/null +++ b/include/dt-bindings/power/rk3288-power.h @@ -0,0 +1,32 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_POWER_RK3288_POWER_H__ +#define __DT_BINDINGS_POWER_RK3288_POWER_H__ + +/** + * RK3288 Power Domain and Voltage Domain Summary. + */ + +/* VD_CORE */ +#define RK3288_PD_A17_0 0 +#define RK3288_PD_A17_1 1 +#define RK3288_PD_A17_2 2 +#define RK3288_PD_A17_3 3 +#define RK3288_PD_SCU 4 +#define RK3288_PD_DEBUG 5 +#define RK3288_PD_MEM 6 + +/* VD_LOGIC */ +#define RK3288_PD_BUS 7 +#define RK3288_PD_PERI 8 +#define RK3288_PD_VIO 9 +#define RK3288_PD_ALIVE 10 +#define RK3288_PD_HEVC 11 +#define RK3288_PD_VIDEO 12 + +/* VD_GPU */ +#define RK3288_PD_GPU 13 + +/* VD_PMU */ +#define RK3288_PD_PMU 14 + +#endif
In order to update the DT for rk3288 sync the clock dt-binding header. This is the state as of v5.17 in Linux. Keep SCLK_MAC_PLL in use for rk3288 clock driver.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- include/dt-bindings/clock/rk3288-cru.h | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/include/dt-bindings/clock/rk3288-cru.h b/include/dt-bindings/clock/rk3288-cru.h index e368d767..453f6671 100644 --- a/include/dt-bindings/clock/rk3288-cru.h +++ b/include/dt-bindings/clock/rk3288-cru.h @@ -1,9 +1,12 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0-or-later */ /* * Copyright (c) 2014 MundoReader S.L. * Author: Heiko Stuebner heiko@sntech.de */
+#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H + /* core clocks */ #define PLL_APLL 1 #define PLL_DPLL 2 @@ -74,6 +77,9 @@ #define SCLK_USBPHY480M_SRC 122 #define SCLK_PVTM_CORE 123 #define SCLK_PVTM_GPU 124 +#define SCLK_CRYPTO 125 +#define SCLK_MIPIDSI_24M 126 +#define SCLK_VIP_OUT 127
#define SCLK_MAC_PLL 150 #define SCLK_MAC 151 @@ -153,6 +159,9 @@ #define PCLK_DDRUPCTL1 366 #define PCLK_PUBL1 367 #define PCLK_WDT 368 +#define PCLK_EFUSE256 369 +#define PCLK_EFUSE1024 370 +#define PCLK_ISP_IN 371
/* hclk gates */ #define HCLK_GPS 448 @@ -368,3 +377,5 @@ #define SRST_TSP_CLKIN0 189 #define SRST_TSP_CLKIN1 190 #define SRST_TSP_27M 191 + +#endif
In order to sync rk3288.dtsi from Linux it needed to move all u-boot specific properties in separate dtsi files.
Changed V2: combine U-boot specific changes add bus_intmem label use current led node name --- arch/arm/dts/rk3288-evb-u-boot.dtsi | 11 +++ arch/arm/dts/rk3288-evb.dts | 11 --- arch/arm/dts/rk3288-firefly-u-boot.dtsi | 31 ++++++++ arch/arm/dts/rk3288-firefly.dts | 17 ---- arch/arm/dts/rk3288-firefly.dtsi | 3 - arch/arm/dts/rk3288-miqi-u-boot.dtsi | 20 +++++ arch/arm/dts/rk3288-miqi.dts | 11 --- arch/arm/dts/rk3288-miqi.dtsi | 2 - arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi | 44 +++++++++++ arch/arm/dts/rk3288-phycore-rdk.dts | 18 ----- arch/arm/dts/rk3288-phycore-som.dtsi | 6 -- arch/arm/dts/rk3288-popmetal-u-boot.dtsi | 11 +++ arch/arm/dts/rk3288-popmetal.dts | 11 --- arch/arm/dts/rk3288-rock2-square-u-boot.dtsi | 30 +++++++ arch/arm/dts/rk3288-rock2-square.dts | 18 ----- arch/arm/dts/rk3288-u-boot.dtsi | 79 ++++++++++++++++--- arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi | 14 ++++ arch/arm/dts/rk3288-veyron-jerry.dts | 11 --- arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi | 14 ++++ arch/arm/dts/rk3288-veyron-mickey.dts | 11 --- arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi | 14 ++++ arch/arm/dts/rk3288-veyron-minnie.dts | 11 --- arch/arm/dts/rk3288-veyron-u-boot.dtsi | 62 +++++++++++++++ arch/arm/dts/rk3288-veyron.dtsi | 39 --------- arch/arm/dts/rk3288.dtsi | 49 +----------- 25 files changed, 320 insertions(+), 228 deletions(-) create mode 100644 arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-rock2-square-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi
diff --git a/arch/arm/dts/rk3288-evb-u-boot.dtsi b/arch/arm/dts/rk3288-evb-u-boot.dtsi index 8ac7840f..c8f51207 100644 --- a/arch/arm/dts/rk3288-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3288-evb-u-boot.dtsi @@ -5,6 +5,17 @@
#include "rk3288-u-boot.dtsi"
+&dmc { + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; +}; + &pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-evb.dts b/arch/arm/dts/rk3288-evb.dts index eac91a87..bb24a96c 100644 --- a/arch/arm/dts/rk3288-evb.dts +++ b/arch/arm/dts/rk3288-evb.dts @@ -15,17 +15,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x2>; - rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; -}; - &pwm1 { status = "okay"; }; diff --git a/arch/arm/dts/rk3288-firefly-u-boot.dtsi b/arch/arm/dts/rk3288-firefly-u-boot.dtsi index 8b9c3831..cc84d7c4 100644 --- a/arch/arm/dts/rk3288-firefly-u-boot.dtsi +++ b/arch/arm/dts/rk3288-firefly-u-boot.dtsi @@ -5,6 +5,37 @@
+/ { + config { + u-boot,dm-pre-reloc; + u-boot,boot-led = "firefly:green:power"; + }; + + leds { + u-boot,dm-pre-reloc; + + work { + u-boot,dm-pre-reloc; + }; + + power { + u-boot,dm-pre-reloc; + }; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + /* Add a dummy value to cause of-platdata think this is bytes */ + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; + &pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-firefly.dts b/arch/arm/dts/rk3288-firefly.dts index 1cff04e7..72982efd 100644 --- a/arch/arm/dts/rk3288-firefly.dts +++ b/arch/arm/dts/rk3288-firefly.dts @@ -13,23 +13,6 @@ chosen { stdout-path = &uart2; }; - - config { - u-boot,dm-pre-reloc; - u-boot,boot-led = "firefly:green:power"; - }; -}; - -&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - /* Add a dummy value to cause of-platdata think this is bytes */ - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
&ir { diff --git a/arch/arm/dts/rk3288-firefly.dtsi b/arch/arm/dts/rk3288-firefly.dtsi index b7f279f7..1117d391 100644 --- a/arch/arm/dts/rk3288-firefly.dtsi +++ b/arch/arm/dts/rk3288-firefly.dtsi @@ -37,11 +37,9 @@ };
leds { - u-boot,dm-pre-reloc; compatible = "gpio-leds";
work { - u-boot,dm-pre-reloc; gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; label = "firefly:blue:user"; linux,default-trigger = "rc-feedback"; @@ -50,7 +48,6 @@ };
power { - u-boot,dm-pre-reloc; gpios = <&gpio8 2 GPIO_ACTIVE_LOW>; label = "firefly:green:power"; linux,default-trigger = "default-on"; diff --git a/arch/arm/dts/rk3288-miqi-u-boot.dtsi b/arch/arm/dts/rk3288-miqi-u-boot.dtsi index 4f63fc9f..2a74fdd1 100644 --- a/arch/arm/dts/rk3288-miqi-u-boot.dtsi +++ b/arch/arm/dts/rk3288-miqi-u-boot.dtsi @@ -4,6 +4,26 @@ */
#include "rk3288-u-boot.dtsi" +/ { + leds { + u-boot,dm-pre-reloc; + + work { + u-boot,dm-pre-reloc; + }; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +};
&pinctrl { u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/rk3288-miqi.dts b/arch/arm/dts/rk3288-miqi.dts index e47170c6..4a2f249e 100644 --- a/arch/arm/dts/rk3288-miqi.dts +++ b/arch/arm/dts/rk3288-miqi.dts @@ -14,14 +14,3 @@ stdout-path = "serial2:115200n8"; }; }; - -&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi index 432f744b..cb80cbf2 100644 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ b/arch/arm/dts/rk3288-miqi.dtsi @@ -34,11 +34,9 @@
work { - u-boot,dm-pre-reloc; gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; label = "miqi:green:user"; linux,default-trigger = "default-on"; diff --git a/arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi b/arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi new file mode 100644 index 00000000..30f4cb10 --- /dev/null +++ b/arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-u-boot.dtsi" + +&dmc { + rockchip,num-channels = <2>; + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xe 0xe>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 5 1>; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + +&i2c0 { + u-boot,dm-pre-reloc; + + rk818: pmic@1c { + u-boot,dm-pre-reloc; + + regulators { + u-boot,dm-pre-reloc; + }; + }; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3288-phycore-rdk.dts b/arch/arm/dts/rk3288-phycore-rdk.dts index cc392109..ebea8e67 100644 --- a/arch/arm/dts/rk3288-phycore-rdk.dts +++ b/arch/arm/dts/rk3288-phycore-rdk.dts @@ -112,19 +112,6 @@ }; };
-&dmc { - rockchip,num-channels = <2>; - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xe 0xe>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 5 1>; -}; - &gmac { status = "okay"; }; @@ -175,8 +162,6 @@ };
&pinctrl { - u-boot,dm-pre-reloc; - pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { bias-pull-up; drive-strength = <12>; @@ -246,8 +231,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; - bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; @@ -268,7 +251,6 @@ };
diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 02d11968..821525f7 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -149,8 +149,6 @@
&emmc { status = "okay"; - u-boot,dm-pre-reloc; - bus-width = <8>; cap-mmc-highspeed; disable-wp; @@ -201,8 +199,6 @@
&i2c0 { status = "okay"; - u-boot,dm-pre-reloc; - clock-frequency = <400000>;
rk818: pmic@1c { @@ -216,7 +212,6 @@ rockchip,system-power-controller; wakeup-source; #clock-cells = <1>; - u-boot,dm-pre-reloc;
vcc1-supply = <&vdd_sys>; vcc2-supply = <&vdd_sys>; @@ -230,7 +225,6 @@ vddio-supply = <&vdd_3v3_io>;
regulators { - u-boot,dm-pre-reloc; vdd_log: DCDC_REG1 { regulator-name = "vdd_log"; regulator-always-on; diff --git a/arch/arm/dts/rk3288-popmetal-u-boot.dtsi b/arch/arm/dts/rk3288-popmetal-u-boot.dtsi index 8ac7840f..3782253c 100644 --- a/arch/arm/dts/rk3288-popmetal-u-boot.dtsi +++ b/arch/arm/dts/rk3288-popmetal-u-boot.dtsi @@ -5,6 +5,17 @@
+&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; + &pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-popmetal.dts b/arch/arm/dts/rk3288-popmetal.dts index 5c6d06f2..736dc51e 100644 --- a/arch/arm/dts/rk3288-popmetal.dts +++ b/arch/arm/dts/rk3288-popmetal.dts @@ -15,17 +15,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; - &pwm1 { status = "okay"; }; diff --git a/arch/arm/dts/rk3288-rock2-square-u-boot.dtsi b/arch/arm/dts/rk3288-rock2-square-u-boot.dtsi new file mode 100644 index 00000000..509f789b --- /dev/null +++ b/arch/arm/dts/rk3288-rock2-square-u-boot.dtsi @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; + +&gpio7 { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3288-rock2-square.dts b/arch/arm/dts/rk3288-rock2-square.dts index 11c580a0..41676696 100644 --- a/arch/arm/dts/rk3288-rock2-square.dts +++ b/arch/arm/dts/rk3288-rock2-square.dts @@ -96,7 +96,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; @@ -139,7 +138,6 @@ };
&pinctrl { - u-boot,dm-pre-reloc; ir { ir_int: ir-int { rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; @@ -171,7 +169,6 @@
&uart2 { status = "okay"; - u-boot,dm-pre-reloc; reg-shift = <2>; };
@@ -182,18 +179,3 @@ &usb_host0_ehci { status = "okay"; }; - -&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; - -&gpio7 { - u-boot,dm-pre-reloc; -}; diff --git a/arch/arm/dts/rk3288-u-boot.dtsi b/arch/arm/dts/rk3288-u-boot.dtsi index e3c6c10f..8a59ec75 100644 --- a/arch/arm/dts/rk3288-u-boot.dtsi +++ b/arch/arm/dts/rk3288-u-boot.dtsi @@ -7,10 +7,52 @@ #include "rockchip-optee.dtsi"
/ { + aliases { + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + gpio3 = &gpio3; + gpio4 = &gpio4; + gpio5 = &gpio5; + gpio6 = &gpio6; + gpio7 = &gpio7; + gpio8 = &gpio8; + mmc0 = &emmc; + mmc1 = &sdmmc; + mmc2 = &sdio0; + mmc3 = &sdio1; + }; + chosen { u-boot,spl-boot-order = \ "same-as-spl", &emmc, &sdmmc; }; + + dmc: dmc@ff610000 { + compatible = "rockchip,rk3288-dmc", "syscon"; + reg = <0x0 0xff610000 0x0 0x3fc + 0x0 0xff620000 0x0 0x294 + 0x0 0xff630000 0x0 0x3fc + 0x0 0xff640000 0x0 0x294>; + clocks = <&cru PCLK_DDRUPCTL0>, <&cru PCLK_PUBL0>, + <&cru PCLK_DDRUPCTL1>, <&cru PCLK_PUBL1>, + <&cru ARMCLK>; + clock-names = "pclk_ddrupctl0", "pclk_publ0", + "pclk_ddrupctl1", "pclk_publ1", + "arm_clk"; + rockchip,cru = <&cru>; + rockchip,grf = <&grf>; + rockchip,noc = <&noc>; + rockchip,pmu = <&pmu>; + rockchip,sgrf = <&sgrf>; + rockchip,sram = <&ddr_sram>; + u-boot,dm-pre-reloc; + }; + + noc: syscon@ffac0000 { + compatible = "rockchip,rk3288-noc", "syscon"; + reg = <0x0 0xffac0000 0x0 0x2000>; + }; };
#ifdef CONFIG_ROCKCHIP_SPI_IMAGE @@ -37,38 +79,53 @@ }; #endif
-&dmc { - u-boot,dm-pre-reloc; +&bus_intmem { + ddr_sram: ddr-sram@1000 { + compatible = "rockchip,rk3288-ddr-sram"; + reg = <0x1000 0x4000>; + }; };
-&pmu { +&cru { u-boot,dm-pre-reloc; };
-&sgrf { +&gpio7 { u-boot,dm-pre-reloc; };
-&cru { +&grf { u-boot,dm-pre-reloc; };
-&grf { +&pmu { u-boot,dm-pre-reloc; };
-&vopb { +&sgrf { u-boot,dm-pre-reloc; };
-&vopl { - u-boot,dm-pre-reloc; +&uart0 { + clock-frequency = <24000000>; +}; + +&uart1 { + clock-frequency = <24000000>; };
-&noc { +&uart2 { + clock-frequency = <24000000>; +}; + +&uart3 { + clock-frequency = <24000000>; +}; + +&vopb { u-boot,dm-pre-reloc; };
-&gpio7 { +&vopl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi new file mode 100644 index 00000000..2cc6b090 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-veyron-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f4 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index c251d9d5..ff7669eb 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -66,17 +66,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f4 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; - &gpio_keys { power { gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; diff --git a/arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi new file mode 100644 index 00000000..213a46ba --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-veyron-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 1>; +}; diff --git a/arch/arm/dts/rk3288-veyron-mickey.dts b/arch/arm/dts/rk3288-veyron-mickey.dts index e0dc3620..0521d9e0 100644 --- a/arch/arm/dts/rk3288-veyron-mickey.dts +++ b/arch/arm/dts/rk3288-veyron-mickey.dts @@ -161,17 +161,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x2>; - rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 1>; -}; - &emmc { /delete-property/mmc-hs200-1_8v; }; diff --git a/arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi new file mode 100644 index 00000000..8211da41 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-veyron-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x1>; + rockchip,sdram-params = <0x20d266a4 0x5b6 6 533000000 6 13 0>; +}; diff --git a/arch/arm/dts/rk3288-veyron-minnie.dts b/arch/arm/dts/rk3288-veyron-minnie.dts index 646f6ae7..b56a3f4f 100644 --- a/arch/arm/dts/rk3288-veyron-minnie.dts +++ b/arch/arm/dts/rk3288-veyron-minnie.dts @@ -137,17 +137,6 @@ power-supply = <&backlight_regulator>; };
-&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x1>; - rockchip,sdram-params = <0x20d266a4 0x5b6 6 533000000 6 13 0>; -}; - &emmc { /delete-property/mmc-hs200-1_8v; }; diff --git a/arch/arm/dts/rk3288-veyron-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-u-boot.dtsi index 899fe6e7..c8b33fea 100644 --- a/arch/arm/dts/rk3288-veyron-u-boot.dtsi +++ b/arch/arm/dts/rk3288-veyron-u-boot.dtsi @@ -5,7 +5,69 @@
+/ { + chosen { + u-boot,spl-boot-order = &spi_flash; + }; +}; + +&dmc { + logic-supply = <&vdd_logic>; + rockchip,odt-disable-freq = <333000000>; + rockchip,dll-disable-freq = <333000000>; + rockchip,sr-enable-freq = <333000000>; + rockchip,pd-enable-freq = <666000000>; + rockchip,auto-self-refresh-cnt = <0>; + rockchip,auto-power-down-cnt = <64>; + rockchip,ddr-speed-bin = <21>; + rockchip,trcd = <10>; + rockchip,trp = <10>; + operating-points = < + /* KHz uV */ + 200000 1050000 + 333000 1100000 + 533000 1150000 + 666000 1200000 + >; +}; + +&gpio3 { + u-boot,dm-pre-reloc; +}; + &gpio7 { u-boot,dm-pre-reloc; };
+&gpio8 { + u-boot,dm-pre-reloc; +}; + +&i2c0 { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&rk808 { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&spi2 { + u-boot,dm-pre-reloc; +}; + +&spi_flash { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; + diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 8754043b..4a9c27a4 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -16,7 +16,6 @@
chosen { stdout-path = &uart2; - u-boot,spl-boot-order = &spi_flash; };
firmware { @@ -220,26 +219,6 @@ cpu0-supply = <&vdd_cpu>; };
-&dmc { - logic-supply = <&vdd_logic>; - rockchip,odt-disable-freq = <333000000>; - rockchip,dll-disable-freq = <333000000>; - rockchip,sr-enable-freq = <333000000>; - rockchip,pd-enable-freq = <666000000>; - rockchip,auto-self-refresh-cnt = <0>; - rockchip,auto-power-down-cnt = <64>; - rockchip,ddr-speed-bin = <21>; - rockchip,trcd = <10>; - rockchip,trp = <10>; - operating-points = < - /* KHz uV */ - 200000 1050000 - 333000 1100000 - 533000 1150000 - 666000 1200000 - >; -}; - &efuse { status = "okay"; }; @@ -299,10 +278,8 @@
&spi2 { status = "okay"; - u-boot,dm-pre-reloc;
spi_flash: spiflash@0 { - u-boot,dm-pre-reloc; compatible = "spidev", "jedec,spi-nor"; spi-max-frequency = <20000000>; /* Reduce for Dediprog em100 pro */ reg = <0>; @@ -315,7 +292,6 @@ clock-frequency = <400000>; i2c-scl-falling-time-ns = <50>; /* 2.5ns measured */ i2c-scl-rising-time-ns = <100>; /* 45ns measured */ - u-boot,dm-pre-reloc;
rk808: pmic@1b { compatible = "rockchip,rk808"; @@ -328,7 +304,6 @@ rockchip,system-power-controller; wakeup-source; #clock-cells = <1>; - u-boot,dm-pre-reloc;
vcc1-supply = <&vcc33_sys>; vcc2-supply = <&vcc33_sys>; @@ -557,7 +532,6 @@
@@ -601,7 +575,6 @@ };
&pinctrl { - u-boot,dm-pre-reloc; pinctrl-names = "default", "sleep"; pinctrl-0 = < /* Common for sleep and wake, but no owners */ @@ -826,15 +799,3 @@ assigned-clocks = <&cru SCLK_USBPHY480M_SRC>; assigned-clock-parents = <&cru SCLK_OTGPHY0>; }; - -&sdmmc { - u-boot,dm-pre-reloc; -}; - -&gpio3 { - u-boot,dm-pre-reloc; -}; - -&gpio8 { - u-boot,dm-pre-reloc; -}; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 2086dbfd..c4abfa37 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -15,25 +15,12 @@
interrupt-parent = <&gic>; aliases { - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; - gpio4 = &gpio4; - gpio5 = &gpio5; - gpio6 = &gpio6; - gpio7 = &gpio7; - gpio8 = &gpio8; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; i2c3 = &i2c3; i2c4 = &i2c4; i2c5 = &i2c5; - mmc0 = &emmc; - mmc1 = &sdmmc; - mmc2 = &sdio0; - mmc3 = &sdio1; mshc0 = &emmc; mshc1 = &sdmmc; mshc2 = &sdio0; @@ -323,7 +310,6 @@ interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -337,7 +323,6 @@ interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -351,7 +336,6 @@ interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -364,7 +348,6 @@ interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -378,7 +361,6 @@ interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -476,26 +458,6 @@ status = "disabled"; };
- dmc: dmc@ff610000 { - compatible = "rockchip,rk3288-dmc", "syscon"; - rockchip,cru = <&cru>; - rockchip,grf = <&grf>; - rockchip,pmu = <&pmu>; - rockchip,sgrf = <&sgrf>; - rockchip,noc = <&noc>; - reg = <0xff610000 0x3fc - 0xff620000 0x294 - 0xff630000 0x3fc - 0xff640000 0x294>; - rockchip,sram = <&ddr_sram>; - clocks = <&cru PCLK_DDRUPCTL0>, <&cru PCLK_PUBL0>, - <&cru PCLK_DDRUPCTL1>, <&cru PCLK_PUBL1>, - <&cru ARMCLK>; - clock-names = "pclk_ddrupctl0", "pclk_publ0", - "pclk_ddrupctl1", "pclk_publ1", - "arm_clk"; - }; - i2c0: i2c@ff650000 { compatible = "rockchip,rk3288-i2c"; reg = <0xff650000 0x1000>; @@ -570,7 +532,7 @@ status = "disabled"; };
- bus_intmem@ff700000 { + bus_intmem: bus_intmem@ff700000 { compatible = "mmio-sram"; reg = <0xff700000 0x18000>; #address-cells = <1>; @@ -580,10 +542,6 @@ compatible = "rockchip,rk3066-smp-sram"; reg = <0x00 0x10>; }; - ddr_sram: ddr-sram@1000 { - compatible = "rockchip,rk3288-ddr-sram"; - reg = <0x1000 0x4000>; - }; };
sram@ff720000 { @@ -912,11 +870,6 @@ status = "disabled"; };
- noc: syscon@ffac0000 { - compatible = "rockchip,rk3288-noc", "syscon"; - reg = <0xffac0000 0x2000>; - }; - efuse: efuse@ffb40000 { compatible = "rockchip,rk3288-efuse"; reg = <0xffb40000 0x10000>;
Sync rk3288.dtsi from Linux version 5.17.
Changed V2: rename mipi_dsi0 label move io_domains remove hdmi_audio veyron node change memory@0 reg size --- arch/arm/dts/rk3288-evb.dtsi | 7 +- arch/arm/dts/rk3288-firefly.dtsi | 3 +- arch/arm/dts/rk3288-miqi.dtsi | 30 +- arch/arm/dts/rk3288-phycore-som.dtsi | 32 +- arch/arm/dts/rk3288-popmetal.dtsi | 32 +- arch/arm/dts/rk3288-rock2-som.dtsi | 2 +- arch/arm/dts/rk3288-thermal.dtsi | 87 -- arch/arm/dts/rk3288-tinker.dtsi | 2 +- arch/arm/dts/rk3288-veyron-jerry.dts | 6 - arch/arm/dts/rk3288-veyron.dtsi | 35 +- arch/arm/dts/rk3288.dtsi | 1479 +++++++++++++++++--------- 11 files changed, 1037 insertions(+), 678 deletions(-) delete mode 100644 arch/arm/dts/rk3288-thermal.dtsi
diff --git a/arch/arm/dts/rk3288-evb.dtsi b/arch/arm/dts/rk3288-evb.dtsi index 04902c0b..21f812ab 100644 --- a/arch/arm/dts/rk3288-evb.dtsi +++ b/arch/arm/dts/rk3288-evb.dtsi @@ -6,8 +6,9 @@ #include "rk3288.dtsi"
/ { - memory { - reg = <0 0x80000000>; + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; };
ext_gmac: external-gmac-clock { @@ -448,7 +449,7 @@ status = "okay"; };
-&mipi_dsi0 { +&mipi_dsi { status = "disabled"; rockchip,panel = <&panel>; display-timings { diff --git a/arch/arm/dts/rk3288-firefly.dtsi b/arch/arm/dts/rk3288-firefly.dtsi index 1117d391..0924e388 100644 --- a/arch/arm/dts/rk3288-firefly.dtsi +++ b/arch/arm/dts/rk3288-firefly.dtsi @@ -7,7 +7,8 @@
/ { memory { - reg = <0 0x80000000>; + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; };
ext_gmac: external-gmac-clock { diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi index cb80cbf2..15797f7d 100644 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ b/arch/arm/dts/rk3288-miqi.dtsi @@ -8,7 +8,7 @@ / { memory { device_type = "memory"; - reg = <0 0x80000000>; + reg = <0x0 0x0 0x0 0x80000000>; };
ext_gmac: external-gmac-clock { @@ -18,21 +18,6 @@ clock-output-names = "ext_gmac"; };
- io_domains: io-domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - rockchip,grf = <&grf>; - - audio-supply = <&vcca_33>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc_18>; - }; - - leds { compatible = "gpio-leds";
@@ -277,6 +262,19 @@ status = "okay"; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + &pinctrl { pcfg_output_high: pcfg-output-high { output-high; diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 821525f7..7ecc06f9 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -55,7 +55,7 @@ */ memory { device_type = "memory"; - reg = <0 0x8000000>; + reg = <0x0 0x0 0x0 0x80000000>; };
aliases { @@ -71,22 +71,6 @@ clock-output-names = "ext_gmac"; };
- io_domains: io_domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - - status = "okay"; - sdcard-supply = <&vdd_io_sd>; - flash0-supply = <&vdd_emmc_io>; - flash1-supply = <&vdd_misc_1v8>; - gpio1830-supply = <&vdd_3v3_io>; - gpio30-supply = <&vdd_3v3_io>; - bb-supply = <&vdd_3v3_io>; - dvp-supply = <&vdd_3v3_io>; - lcdc-supply = <&vdd_3v3_io>; - wifi-supply = <&vdd_3v3_io>; - audio-supply = <&vdd_3v3_io>; - }; - leds: user-leds { compatible = "gpio-leds"; pinctrl-names = "default"; @@ -197,6 +181,20 @@ ddc-i2c-bus = <&i2c5>; };
+&io_domains { + status = "okay"; + sdcard-supply = <&vdd_io_sd>; + flash0-supply = <&vdd_emmc_io>; + flash1-supply = <&vdd_misc_1v8>; + gpio1830-supply = <&vdd_3v3_io>; + gpio30-supply = <&vdd_3v3_io>; + bb-supply = <&vdd_3v3_io>; + dvp-supply = <&vdd_3v3_io>; + lcdc-supply = <&vdd_3v3_io>; + wifi-supply = <&vdd_3v3_io>; + audio-supply = <&vdd_3v3_io>; +}; + &i2c0 { status = "okay"; clock-frequency = <400000>; diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi index 63785eb5..24151bd2 100644 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ b/arch/arm/dts/rk3288-popmetal.dtsi @@ -42,8 +42,8 @@
/ { memory{ + reg = <0x0 0x0 0x0 0x80000000>; device_type = "memory"; - reg = <0 0x80000000>; };
ext_gmac: external-gmac-clock { @@ -69,22 +69,6 @@ }; };
- io_domains: io-domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - rockchip,grf = <&grf>; - - audio-supply = <&vcca_33>; - bb-supply = <&vcc_io>; - dvp-supply = <&vcc18_dvp>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vccio_wl>; - }; - ir: ir-receiver { compatible = "gpio-ir-receiver"; gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; @@ -441,6 +425,20 @@ status = "okay"; };
+&io_domains { + status = "okay"; + audio-supply = <&vcca_33>; + bb-supply = <&vcc_io>; + dvp-supply = <&vcc18_dvp>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vccio_wl>; +}; + &pinctrl { ak8963 { comp_int: comp-int { diff --git a/arch/arm/dts/rk3288-rock2-som.dtsi b/arch/arm/dts/rk3288-rock2-som.dtsi index 1ece66f3..aa34cd02 100644 --- a/arch/arm/dts/rk3288-rock2-som.dtsi +++ b/arch/arm/dts/rk3288-rock2-som.dtsi @@ -43,8 +43,8 @@
/ { memory { - reg = <0x0 0x80000000>; device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; };
emmc_pwrseq: emmc-pwrseq { diff --git a/arch/arm/dts/rk3288-thermal.dtsi b/arch/arm/dts/rk3288-thermal.dtsi deleted file mode 100644 index 87dd8142..00000000 --- a/arch/arm/dts/rk3288-thermal.dtsi +++ /dev/null @@ -1,87 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for RK3288 SoC thermal - * - * Copyright (c) 2014, Fuzhou Rockchip Electronics Co., Ltd - */ - -#include <dt-bindings/thermal/thermal.h> - -reserve_thermal: reserve_thermal { - polling-delay-passive = <1000>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - /* sensor ID */ - thermal-sensors = <&tsadc 0>; - -}; - -cpu_thermal: cpu_thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - /* sensor ID */ - thermal-sensors = <&tsadc 1>; - linux,hwmon; - - trips { - cpu_alert0: cpu_alert0 { - temperature = <70000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert1: cpu_alert1 { - temperature = <75000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_crit: cpu_crit { - temperature = <100000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu_alert0>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT 6>; - }; - map1 { - trip = <&cpu_alert1>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; -}; - -gpu_thermal: gpu_thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - /* sensor ID */ - thermal-sensors = <&tsadc 2>; - linux,hwmon; - - trips { - gpu_alert0: gpu_alert0 { - temperature = <80000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - gpu_crit: gpu_crit { - temperature = <100000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&gpu_alert0>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; -}; diff --git a/arch/arm/dts/rk3288-tinker.dtsi b/arch/arm/dts/rk3288-tinker.dtsi index 2f816af4..99de2a9f 100644 --- a/arch/arm/dts/rk3288-tinker.dtsi +++ b/arch/arm/dts/rk3288-tinker.dtsi @@ -42,8 +42,8 @@
/ { memory { + reg = <0x0 0x0 0x0 0x80000000>; device_type = "memory"; - reg = <0x0 0x80000000>; };
ext_gmac: external-gmac-clock { diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index ff7669eb..40fee55c 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -137,12 +137,6 @@ }; };
- edp { - edp_hpd: edp_hpd { - rockchip,pins = <7 11 RK_FUNC_2 &pcfg_pull_down>; - }; - }; - emmc { /* Make sure eMMC is not in reset */ emmc_deassert_reset: emmc-deassert-reset { diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 4a9c27a4..d7145cd1 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -11,7 +11,7 @@
/ { memory { - reg = <0x0 0x80000000>; + reg = <0x0 0x0 0x0 0x80000000>; };
chosen { @@ -198,21 +198,6 @@ /* Faux input supply. See bt_regulator description. */ vin-supply = <&bt_regulator>; }; - - io-domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - rockchip,grf = <&grf>; - - audio-supply = <&vcc18_codec>; - bb-supply = <&vcc33_io>; - dvp-supply = <&vcc_18>; - flash0-supply = <&vcc18_flashio>; - gpio1830-supply = <&vcc33_io>; - gpio30-supply = <&vcc33_io>; - lcdc-supply = <&vcc33_lcd>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc18_wl>; - }; };
&cpu0 { @@ -503,6 +488,20 @@ clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcc18_codec>; + bb-supply = <&vcc33_io>; + dvp-supply = <&vcc_18>; + flash0-supply = <&vcc18_flashio>; + gpio1830-supply = <&vcc33_io>; + gpio30-supply = <&vcc33_io>; + lcdc-supply = <&vcc33_lcd>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc18_wl>; +}; + &wdt { status = "okay"; }; @@ -560,10 +559,6 @@ status = "okay"; };
-&hdmi_audio { - status = "okay"; -}; - &gpu { status = "okay"; }; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index c4abfa37..85d56c63 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> @@ -7,14 +7,18 @@ #include <dt-bindings/clock/rk3288-cru.h> #include <dt-bindings/power/rk3288-power.h> #include <dt-bindings/thermal/thermal.h> -#include <dt-bindings/video/rk3288.h> -#include "skeleton.dtsi" +#include <dt-bindings/soc/rockchip,boot-mode.h>
/ { + #address-cells = <2>; + #size-cells = <2>; + compatible = "rockchip,rk3288";
interrupt-parent = <&gic>; + aliases { + ethernet0 = &gmac; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -35,6 +39,15 @@ spi2 = &spi2; };
+ arm-pmu { + compatible = "arm,cortex-a12-pmu"; + interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -45,85 +58,119 @@ device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x500>; - operating-points = < - /* KHz uV */ - 1800000 1400000 - 1704000 1350000 - 1608000 1300000 - 1512000 1250000 - 1416000 1200000 - 1200000 1100000 - 1008000 1050000 - 816000 1000000 - 696000 950000 - 600000 900000 - 408000 900000 - 216000 900000 - 126000 900000 - >; + resets = <&cru SRST_CORE0>; + operating-points-v2 = <&cpu_opp_table>; #cooling-cells = <2>; /* min followed by max */ clock-latency = <40000>; clocks = <&cru ARMCLK>; - resets = <&cru SRST_CORE0>; + dynamic-power-coefficient = <370>; }; - cpu@501 { + cpu1: cpu@501 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x501>; resets = <&cru SRST_CORE1>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; - cpu@502 { + cpu2: cpu@502 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x502>; resets = <&cru SRST_CORE2>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; - cpu@503 { + cpu3: cpu@503 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x503>; resets = <&cru SRST_CORE3>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; };
- amba { - compatible = "arm,amba-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges; + cpu_opp_table: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared;
- dmac_peri: dma-controller@ff250000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xff250000 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC2>; - clock-names = "apb_pclk"; - }; - - dmac_bus_ns: dma-controller@ff600000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xff600000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; - status = "disabled"; + opp-126000000 { + opp-hz = /bits/ 64 <126000000>; + opp-microvolt = <900000>; + }; + opp-216000000 { + opp-hz = /bits/ 64 <216000000>; + opp-microvolt = <900000>; }; + opp-312000000 { + opp-hz = /bits/ 64 <312000000>; + opp-microvolt = <900000>; + }; + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <900000>; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <900000>; + }; + opp-696000000 { + opp-hz = /bits/ 64 <696000000>; + opp-microvolt = <950000>; + }; + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1000000>; + }; + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1050000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1100000>; + }; + opp-1416000000 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1200000>; + }; + opp-1512000000 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <1300000>; + }; + opp-1608000000 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <1350000>; + }; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges;
- dmac_bus_s: dma-controller@ffb20000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xffb20000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; + /* + * The rk3288 cannot use the memory area above 0xfe000000 + * for dma operations for some reason. While there is + * probably a better solution available somewhere, we + * haven't found it yet and while devices with 2GB of ram + * are not affected, this issue prevents 4GB from booting. + * So to make these devices at least bootable, block + * this area for the time being until the real solution + * is found. + */ + dma-unusable@fe000000 { + reg = <0x0 0xfe000000 0x0 0x1000000>; }; };
@@ -135,14 +182,22 @@ };
timer { - arm,use-physical-timer; compatible = "arm,armv7-timer"; + arm,cpu-registers-not-fw-configured; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; clock-frequency = <24000000>; - always-on; + arm,no-tick-in-suspend; + }; + + timer: timer@ff810000 { + compatible = "rockchip,rk3288-timer"; + reg = <0x0 0xff810000 0x0 0x20>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_TIMER>, <&xin24m>; + clock-names = "pclk", "timer"; };
display-subsystem { @@ -150,61 +205,71 @@ ports = <&vopl_out>, <&vopb_out>; };
- sdmmc: dwmmc@ff0c0000 { + sdmmc: mmc@ff0c0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - reg = <0xff0c0000 0x4000>; + reg = <0x0 0xff0c0000 0x0 0x4000>; + resets = <&cru SRST_MMC0>; + reset-names = "reset"; status = "disabled"; };
- sdio0: dwmmc@ff0d0000 { + sdio0: mmc@ff0d0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, <&cru SCLK_SDIO0_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - reg = <0xff0d0000 0x4000>; + reg = <0x0 0xff0d0000 0x0 0x4000>; + resets = <&cru SRST_SDIO0>; + reset-names = "reset"; status = "disabled"; };
- sdio1: dwmmc@ff0e0000 { + sdio1: mmc@ff0e0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO1>, <&cru SCLK_SDIO1>, <&cru SCLK_SDIO1_DRV>, <&cru SCLK_SDIO1_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - reg = <0xff0e0000 0x4000>; + reg = <0x0 0xff0e0000 0x0 0x4000>; + resets = <&cru SRST_SDIO1>; + reset-names = "reset"; status = "disabled"; };
- emmc: dwmmc@ff0f0000 { + emmc: mmc@ff0f0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - reg = <0xff0f0000 0x4000>; + reg = <0x0 0xff0f0000 0x0 0x4000>; + resets = <&cru SRST_EMMC>; + reset-names = "reset"; status = "disabled"; };
saradc: saradc@ff100000 { compatible = "rockchip,saradc"; - reg = <0xff100000 0x100>; + reg = <0x0 0xff100000 0x0 0x100>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; #io-channel-cells = <1>; clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; clock-names = "saradc", "apb_pclk"; + resets = <&cru SRST_SARADC>; + reset-names = "saradc-apb"; status = "disabled"; };
@@ -217,7 +282,7 @@ interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; - reg = <0xff110000 0x1000>; + reg = <0x0 0xff110000 0x0 0x1000>; #address-cells = <1>; #size-cells = <0>; status = "disabled"; @@ -232,7 +297,7 @@ interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; - reg = <0xff120000 0x1000>; + reg = <0x0 0xff120000 0x0 0x1000>; #address-cells = <1>; #size-cells = <0>; status = "disabled"; @@ -247,7 +312,7 @@ interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; - reg = <0xff130000 0x1000>; + reg = <0x0 0xff130000 0x0 0x1000>; #address-cells = <1>; #size-cells = <0>; status = "disabled"; @@ -255,7 +320,7 @@
i2c1: i2c@ff140000 { compatible = "rockchip,rk3288-i2c"; - reg = <0xff140000 0x1000>; + reg = <0x0 0xff140000 0x0 0x1000>; interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; @@ -268,7 +333,7 @@
i2c3: i2c@ff150000 { compatible = "rockchip,rk3288-i2c"; - reg = <0xff150000 0x1000>; + reg = <0x0 0xff150000 0x0 0x1000>; interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; @@ -281,7 +346,7 @@
i2c4: i2c@ff160000 { compatible = "rockchip,rk3288-i2c"; - reg = <0xff160000 0x1000>; + reg = <0x0 0xff160000 0x0 0x1000>; interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; @@ -294,7 +359,7 @@
i2c5: i2c@ff170000 { compatible = "rockchip,rk3288-i2c"; - reg = <0xff170000 0x1000>; + reg = <0x0 0xff170000 0x0 0x1000>; interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; @@ -304,14 +369,17 @@ pinctrl-0 = <&i2c5_xfer>; status = "disabled"; }; + uart0: serial@ff180000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0xff180000 0x100>; + reg = <0x0 0xff180000 0x0 0x100>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 1>, <&dmac_peri 2>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>; status = "disabled"; @@ -319,12 +387,14 @@
uart1: serial@ff190000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0xff190000 0x100>; + reg = <0x0 0xff190000 0x0 0x100>; interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 3>, <&dmac_peri 4>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart1_xfer>; status = "disabled"; @@ -332,7 +402,7 @@
uart2: serial@ff690000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0xff690000 0x100>; + reg = <0x0 0xff690000 0x0 0x100>; interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; @@ -342,14 +412,17 @@ pinctrl-0 = <&uart2_xfer>; status = "disabled"; }; + uart3: serial@ff1b0000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0xff1b0000 0x100>; + reg = <0x0 0xff1b0000 0x0 0x100>; interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 7>, <&dmac_peri 8>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart3_xfer>; status = "disabled"; @@ -357,40 +430,136 @@
uart4: serial@ff1c0000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0xff1c0000 0x100>; + reg = <0x0 0xff1c0000 0x0 0x100>; interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 9>, <&dmac_peri 10>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart4_xfer>; status = "disabled"; }; - thermal: thermal-zones { - #include "rk3288-thermal.dtsi" + + dmac_peri: dma-controller@ff250000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff250000 0x0 0x4000>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC2>; + clock-names = "apb_pclk"; + }; + + thermal-zones { + reserve_thermal: reserve-thermal { + polling-delay-passive = <1000>; /* milliseconds */ + polling-delay = <5000>; /* milliseconds */ + + thermal-sensors = <&tsadc 0>; + }; + + cpu_thermal: cpu-thermal { + polling-delay-passive = <100>; /* milliseconds */ + polling-delay = <5000>; /* milliseconds */ + + thermal-sensors = <&tsadc 1>; + + trips { + cpu_alert0: cpu_alert0 { + temperature = <70000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + cpu_alert1: cpu_alert1 { + temperature = <75000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + cpu_crit: cpu_crit { + temperature = <90000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = + <&cpu0 THERMAL_NO_LIMIT 6>, + <&cpu1 THERMAL_NO_LIMIT 6>, + <&cpu2 THERMAL_NO_LIMIT 6>, + <&cpu3 THERMAL_NO_LIMIT 6>; + }; + map1 { + trip = <&cpu_alert1>; + cooling-device = + <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + gpu_thermal: gpu-thermal { + polling-delay-passive = <100>; /* milliseconds */ + polling-delay = <5000>; /* milliseconds */ + + thermal-sensors = <&tsadc 2>; + + trips { + gpu_alert0: gpu_alert0 { + temperature = <70000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_crit: gpu_crit { + temperature = <90000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&gpu_alert0>; + cooling-device = + <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; };
tsadc: tsadc@ff280000 { compatible = "rockchip,rk3288-tsadc"; - reg = <0xff280000 0x100>; + reg = <0x0 0xff280000 0x0 0x100>; interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; clock-names = "tsadc", "apb_pclk"; resets = <&cru SRST_TSADC>; reset-names = "tsadc-apb"; - pinctrl-names = "otp_out"; - pinctrl-0 = <&otp_out>; + pinctrl-names = "init", "default", "sleep"; + pinctrl-0 = <&otp_pin>; + pinctrl-1 = <&otp_out>; + pinctrl-2 = <&otp_pin>; #thermal-sensor-cells = <1>; - hw-shut-temp = <125000>; + rockchip,grf = <&grf>; + rockchip,hw-tshut-temp = <95000>; status = "disabled"; };
gmac: ethernet@ff290000 { compatible = "rockchip,rk3288-gmac"; - reg = <0xff290000 0x10000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; + reg = <0x0 0xff290000 0x0 0x10000>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq", "eth_wake_irq"; rockchip,grf = <&grf>; clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, <&cru SCLK_MAC_TX>, @@ -400,20 +569,22 @@ "mac_clk_rx", "mac_clk_tx", "clk_mac_ref", "clk_mac_refout", "aclk_mac", "pclk_mac"; + resets = <&cru SRST_MAC>; + reset-names = "stmmaceth"; + status = "disabled"; };
usb_host0_ehci: usb@ff500000 { compatible = "generic-ehci"; - reg = <0xff500000 0x100>; + reg = <0x0 0xff500000 0x0 0x100>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST0>; - clock-names = "usbhost"; phys = <&usbphy1>; phy-names = "usb"; status = "disabled"; };
- /* NOTE: doesn't work on RK3288, but fixed on RK3288W */ + /* NOTE: doesn't work on RK3288, but was fixed on RK3288W */ usb_host0_ohci: usb@ff520000 { compatible = "generic-ohci"; reg = <0x0 0xff520000 0x0 0x100>; @@ -427,23 +598,28 @@ usb_host1: usb@ff540000 { compatible = "rockchip,rk3288-usb", "rockchip,rk3066-usb", "snps,dwc2"; - reg = <0xff540000 0x40000>; + reg = <0x0 0xff540000 0x0 0x40000>; interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST1>; clock-names = "otg"; + dr_mode = "host"; phys = <&usbphy2>; phy-names = "usb2-phy"; + snps,reset-phy-on-wake; status = "disabled"; };
usb_otg: usb@ff580000 { compatible = "rockchip,rk3288-usb", "rockchip,rk3066-usb", "snps,dwc2"; - reg = <0xff580000 0x40000>; + reg = <0x0 0xff580000 0x0 0x40000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_OTG0>; clock-names = "otg"; dr_mode = "otg"; + g-np-tx-fifo-size = <16>; + g-rx-fifo-size = <275>; + g-tx-fifo-size = <256 128 128 64 64 32>; phys = <&usbphy0>; phy-names = "usb2-phy"; status = "disabled"; @@ -451,16 +627,28 @@
usb_hsic: usb@ff5c0000 { compatible = "generic-ehci"; - reg = <0xff5c0000 0x100>; + reg = <0x0 0xff5c0000 0x0 0x100>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_HSIC>; - clock-names = "usbhost"; + status = "disabled"; + }; + + dmac_bus_ns: dma-controller@ff600000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff600000 0x0 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC1>; + clock-names = "apb_pclk"; status = "disabled"; };
i2c0: i2c@ff650000 { compatible = "rockchip,rk3288-i2c"; - reg = <0xff650000 0x1000>; + reg = <0x0 0xff650000 0x0 0x1000>; interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; @@ -473,7 +661,7 @@
i2c2: i2c@ff660000 { compatible = "rockchip,rk3288-i2c"; - reg = <0xff660000 0x1000>; + reg = <0x0 0xff660000 0x0 0x1000>; interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; @@ -486,82 +674,194 @@
pwm0: pwm@ff680000 { compatible = "rockchip,rk3288-pwm"; - reg = <0xff680000 0x10>; + reg = <0x0 0xff680000 0x0 0x10>; #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
pwm1: pwm@ff680010 { compatible = "rockchip,rk3288-pwm"; - reg = <0xff680010 0x10>; + reg = <0x0 0xff680010 0x0 0x10>; #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
pwm2: pwm@ff680020 { compatible = "rockchip,rk3288-pwm"; - reg = <0xff680020 0x10>; + reg = <0x0 0xff680020 0x0 0x10>; #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
pwm3: pwm@ff680030 { compatible = "rockchip,rk3288-pwm"; - reg = <0xff680030 0x10>; - #pwm-cells = <2>; + reg = <0x0 0xff680030 0x0 0x10>; + #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
- bus_intmem: bus_intmem@ff700000 { + bus_intmem: sram@ff700000 { compatible = "mmio-sram"; - reg = <0xff700000 0x18000>; + reg = <0x0 0xff700000 0x0 0x18000>; #address-cells = <1>; #size-cells = <1>; - ranges = <0 0xff700000 0x18000>; + ranges = <0 0x0 0xff700000 0x18000>; smp-sram@0 { compatible = "rockchip,rk3066-smp-sram"; reg = <0x00 0x10>; }; };
- sram@ff720000 { + pmu_sram: sram@ff720000 { compatible = "rockchip,rk3288-pmu-sram", "mmio-sram"; - reg = <0xff720000 0x1000>; + reg = <0x0 0xff720000 0x0 0x1000>; };
pmu: power-management@ff730000 { - compatible = "rockchip,rk3288-pmu", "syscon"; - reg = <0xff730000 0x100>; + compatible = "rockchip,rk3288-pmu", "syscon", "simple-mfd"; + reg = <0x0 0xff730000 0x0 0x100>; + + power: power-controller { + compatible = "rockchip,rk3288-power-controller"; + #power-domain-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + + assigned-clocks = <&cru SCLK_EDP_24M>; + assigned-clock-parents = <&xin24m>; + + /* + * Note: Although SCLK_* are the working clocks + * of device without including on the NOC, needed for + * synchronous reset. + * + * The clocks on the which NOC: + * ACLK_IEP/ACLK_VIP/ACLK_VOP0 are on ACLK_VIO0_NIU. + * ACLK_ISP/ACLK_VOP1 are on ACLK_VIO1_NIU. + * ACLK_RGA is on ACLK_RGA_NIU. + * The others (HCLK_*,PLCK_*) are on HCLK_VIO_NIU. + * + * Which clock are device clocks: + * clocks devices + * *_IEP IEP:Image Enhancement Processor + * *_ISP ISP:Image Signal Processing + * *_VIP VIP:Video Input Processor + * *_VOP* VOP:Visual Output Processor + * *_RGA RGA + * *_EDP* EDP + * *_LVDS_* LVDS + * *_HDMI HDMI + * *_MIPI_* MIPI + */ + power-domain@RK3288_PD_VIO { + reg = <RK3288_PD_VIO>; + clocks = <&cru ACLK_IEP>, + <&cru ACLK_ISP>, + <&cru ACLK_RGA>, + <&cru ACLK_VIP>, + <&cru ACLK_VOP0>, + <&cru ACLK_VOP1>, + <&cru DCLK_VOP0>, + <&cru DCLK_VOP1>, + <&cru HCLK_IEP>, + <&cru HCLK_ISP>, + <&cru HCLK_RGA>, + <&cru HCLK_VIP>, + <&cru HCLK_VOP0>, + <&cru HCLK_VOP1>, + <&cru PCLK_EDP_CTRL>, + <&cru PCLK_HDMI_CTRL>, + <&cru PCLK_LVDS_PHY>, + <&cru PCLK_MIPI_CSI>, + <&cru PCLK_MIPI_DSI0>, + <&cru PCLK_MIPI_DSI1>, + <&cru SCLK_EDP_24M>, + <&cru SCLK_EDP>, + <&cru SCLK_ISP_JPE>, + <&cru SCLK_ISP>, + <&cru SCLK_RGA>; + pm_qos = <&qos_vio0_iep>, + <&qos_vio1_vop>, + <&qos_vio1_isp_w0>, + <&qos_vio1_isp_w1>, + <&qos_vio0_vop>, + <&qos_vio0_vip>, + <&qos_vio2_rga_r>, + <&qos_vio2_rga_w>, + <&qos_vio1_isp_r>; + #power-domain-cells = <0>; + }; + + /* + * Note: The following 3 are HEVC(H.265) clocks, + * and on the ACLK_HEVC_NIU (NOC). + */ + power-domain@RK3288_PD_HEVC { + reg = <RK3288_PD_HEVC>; + clocks = <&cru ACLK_HEVC>, + <&cru SCLK_HEVC_CABAC>, + <&cru SCLK_HEVC_CORE>; + pm_qos = <&qos_hevc_r>, + <&qos_hevc_w>; + #power-domain-cells = <0>; + }; + + /* + * Note: ACLK_VCODEC/HCLK_VCODEC are VCODEC + * (video endecoder & decoder) clocks that on the + * ACLK_VCODEC_NIU and HCLK_VCODEC_NIU (NOC). + */ + power-domain@RK3288_PD_VIDEO { + reg = <RK3288_PD_VIDEO>; + clocks = <&cru ACLK_VCODEC>, + <&cru HCLK_VCODEC>; + pm_qos = <&qos_video>; + #power-domain-cells = <0>; + }; + + /* + * Note: ACLK_GPU is the GPU clock, + * and on the ACLK_GPU_NIU (NOC). + */ + power-domain@RK3288_PD_GPU { + reg = <RK3288_PD_GPU>; + clocks = <&cru ACLK_GPU>; + pm_qos = <&qos_gpu_r>, + <&qos_gpu_w>; + #power-domain-cells = <0>; + }; + }; + + reboot-mode { + compatible = "syscon-reboot-mode"; + offset = <0x94>; + mode-normal = <BOOT_NORMAL>; + mode-recovery = <BOOT_RECOVERY>; + mode-bootloader = <BOOT_FASTBOOT>; + mode-loader = <BOOT_BL_DOWNLOAD>; + }; };
sgrf: syscon@ff740000 { compatible = "rockchip,rk3288-sgrf", "syscon"; - reg = <0xff740000 0x1000>; + reg = <0x0 0xff740000 0x0 0x1000>; };
cru: clock-controller@ff760000 { compatible = "rockchip,rk3288-cru"; - reg = <0xff760000 0x1000>; + reg = <0x0 0xff760000 0x0 0x1000>; rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>; @@ -578,27 +878,77 @@ };
grf: syscon@ff770000 { - compatible = "rockchip,rk3288-grf", "syscon"; - reg = <0xff770000 0x1000>; + compatible = "rockchip,rk3288-grf", "syscon", "simple-mfd"; + reg = <0x0 0xff770000 0x0 0x1000>; + + edp_phy: edp-phy { + compatible = "rockchip,rk3288-dp-phy"; + clocks = <&cru SCLK_EDP_24M>; + clock-names = "24m"; + #phy-cells = <0>; + status = "disabled"; + }; + + io_domains: io-domains { + compatible = "rockchip,rk3288-io-voltage-domain"; + status = "disabled"; + }; + + usbphy: usbphy { + compatible = "rockchip,rk3288-usb-phy"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + usbphy0: usb-phy@320 { + #phy-cells = <0>; + reg = <0x320>; + clocks = <&cru SCLK_OTGPHY0>; + clock-names = "phyclk"; + #clock-cells = <0>; + resets = <&cru SRST_USBOTG_PHY>; + reset-names = "phy-reset"; + }; + + usbphy1: usb-phy@334 { + #phy-cells = <0>; + reg = <0x334>; + clocks = <&cru SCLK_OTGPHY1>; + clock-names = "phyclk"; + #clock-cells = <0>; + resets = <&cru SRST_USBHOST0_PHY>; + reset-names = "phy-reset"; + }; + + usbphy2: usb-phy@348 { + #phy-cells = <0>; + reg = <0x348>; + clocks = <&cru SCLK_OTGPHY2>; + clock-names = "phyclk"; + #clock-cells = <0>; + resets = <&cru SRST_USBHOST1_PHY>; + reset-names = "phy-reset"; + }; + }; };
wdt: watchdog@ff800000 { compatible = "rockchip,rk3288-wdt", "snps,dw-wdt"; - reg = <0xff800000 0x100>; + reg = <0x0 0xff800000 0x0 0x100>; clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; };
spdif: sound@ff88b0000 { compatible = "rockchip,rk3288-spdif", "rockchip,rk3066-spdif"; - reg = <0xff8b0000 0x10000>; + reg = <0x0 0xff8b0000 0x0 0x10000>; #sound-dai-cells = <0>; - clock-names = "hclk", "mclk"; - clocks = <&cru HCLK_SPDIF8CH>, <&cru SCLK_SPDIF8CH>; + clocks = <&cru SCLK_SPDIF8CH>, <&cru HCLK_SPDIF8CH>; + clock-names = "mclk", "hclk"; dmas = <&dmac_bus_s 3>; dma-names = "tx"; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&spdif_tx>; rockchip,grf = <&grf>; @@ -607,59 +957,107 @@
i2s: i2s@ff890000 { compatible = "rockchip,rk3288-i2s", "rockchip,rk3066-i2s"; - reg = <0xff890000 0x10000>; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - #sound-dai-cells = <1>; + reg = <0x0 0xff890000 0x0 0x10000>; + #sound-dai-cells = <0>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>; + clock-names = "i2s_clk", "i2s_hclk"; dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; dma-names = "tx", "rx"; - clock-names = "i2s_hclk", "i2s_clk"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>; pinctrl-names = "default"; pinctrl-0 = <&i2s0_bus>; + rockchip,playback-channels = <8>; + rockchip,capture-channels = <2>; + status = "disabled"; + }; + + crypto: cypto-controller@ff8a0000 { + compatible = "rockchip,rk3288-crypto"; + reg = <0x0 0xff8a0000 0x0 0x4000>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_CRYPTO>, <&cru HCLK_CRYPTO>, + <&cru SCLK_CRYPTO>, <&cru ACLK_DMAC1>; + clock-names = "aclk", "hclk", "sclk", "apb_pclk"; + resets = <&cru SRST_CRYPTO>; + reset-names = "crypto-rst"; + }; + + iep_mmu: iommu@ff900800 { + compatible = "rockchip,iommu"; + reg = <0x0 0xff900800 0x0 0x40>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + status = "disabled"; + }; + + isp_mmu: iommu@ff914000 { + compatible = "rockchip,iommu"; + reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_ISP>, <&cru HCLK_ISP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + rockchip,disable-mmu-reset; status = "disabled"; };
+ rga: rga@ff920000 { + compatible = "rockchip,rk3288-rga"; + reg = <0x0 0xff920000 0x0 0x180>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>; + clock-names = "aclk", "hclk", "sclk"; + power-domains = <&power RK3288_PD_VIO>; + resets = <&cru SRST_RGA_CORE>, <&cru SRST_RGA_AXI>, <&cru SRST_RGA_AHB>; + reset-names = "core", "axi", "ahb"; + }; + vopb: vop@ff930000 { compatible = "rockchip,rk3288-vop"; - reg = <0xff930000 0x19c>; + reg = <0x0 0xff930000 0x0 0x19c>, <0x0 0xff931000 0x0 0x1000>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + power-domains = <&power RK3288_PD_VIO>; resets = <&cru SRST_LCDC0_AXI>, <&cru SRST_LCDC0_AHB>, <&cru SRST_LCDC0_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopb_mmu>; - power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + vopb_out: port { #address-cells = <1>; #size-cells = <0>; - vopb_out_edp: endpoint@0 { + + vopb_out_hdmi: endpoint@0 { reg = <0>; - remote-endpoint = <&edp_in_vopb>; + remote-endpoint = <&hdmi_in_vopb>; }; - vopb_out_hdmi: endpoint@1 { + + vopb_out_edp: endpoint@1 { reg = <1>; - remote-endpoint = <&hdmi_in_vopb>; + remote-endpoint = <&edp_in_vopb>; }; - vopb_out_lvds: endpoint@2 { + + vopb_out_mipi: endpoint@2 { reg = <2>; - remote-endpoint = <&lvds_in_vopb>; - }; - vopb_out_mipi: endpoint@3 { - reg = <3>; remote-endpoint = <&mipi_in_vopb>; };
+ vopb_out_lvds: endpoint@3 { + reg = <3>; + remote-endpoint = <&lvds_in_vopb>; + }; }; };
vopb_mmu: iommu@ff930300 { compatible = "rockchip,iommu"; - reg = <0xff930300 0x100>; + reg = <0x0 0xff930300 0x0 0x100>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vopb_mmu"; + clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; + clock-names = "aclk", "iface"; power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled"; @@ -667,272 +1065,365 @@
vopl: vop@ff940000 { compatible = "rockchip,rk3288-vop"; - reg = <0xff940000 0x19c>; + reg = <0x0 0xff940000 0x0 0x19c>, <0x0 0xff941000 0x0 0x1000>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + power-domains = <&power RK3288_PD_VIO>; resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopl_mmu>; - power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + vopl_out: port { #address-cells = <1>; #size-cells = <0>; - vopl_out_edp: endpoint@0 { + + vopl_out_hdmi: endpoint@0 { reg = <0>; - remote-endpoint = <&edp_in_vopl>; + remote-endpoint = <&hdmi_in_vopl>; }; - vopl_out_hdmi: endpoint@1 { + + vopl_out_edp: endpoint@1 { reg = <1>; - remote-endpoint = <&hdmi_in_vopl>; + remote-endpoint = <&edp_in_vopl>; }; - vopl_out_lvds: endpoint@2 { + + vopl_out_mipi: endpoint@2 { reg = <2>; - remote-endpoint = <&lvds_in_vopl>; - }; - vopl_out_mipi: endpoint@3 { - reg = <3>; remote-endpoint = <&mipi_in_vopl>; };
+ vopl_out_lvds: endpoint@3 { + reg = <3>; + remote-endpoint = <&lvds_in_vopl>; + }; }; };
vopl_mmu: iommu@ff940300 { compatible = "rockchip,iommu"; - reg = <0xff940300 0x100>; + reg = <0x0 0xff940300 0x0 0x100>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vopl_mmu"; + clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; + clock-names = "aclk", "iface"; power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled"; };
- edp: edp@ff970000 { - compatible = "rockchip,rk3288-edp"; - reg = <0xff970000 0x4000>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_EDP>, <&cru SCLK_EDP_24M>, <&cru PCLK_EDP_CTRL>; - rockchip,grf = <&grf>; - clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; - resets = <&cru 111>; - reset-names = "edp"; + mipi_dsi: mipi@ff960000 { + compatible = "rockchip,rk3288-mipi-dsi", "snps,dw-mipi-dsi"; + reg = <0x0 0xff960000 0x0 0x4000>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_MIPIDSI_24M>, <&cru PCLK_MIPI_DSI0>; + clock-names = "ref", "pclk"; power-domains = <&power RK3288_PD_VIO>; + rockchip,grf = <&grf>; status = "disabled"; + ports { - edp_in: port { + mipi_in: port { #address-cells = <1>; #size-cells = <0>; - edp_in_vopb: endpoint@0 { + mipi_in_vopb: endpoint@0 { reg = <0>; - remote-endpoint = <&vopb_out_edp>; + remote-endpoint = <&vopb_out_mipi>; }; - edp_in_vopl: endpoint@1 { + mipi_in_vopl: endpoint@1 { reg = <1>; - remote-endpoint = <&vopl_out_edp>; + remote-endpoint = <&vopl_out_mipi>; }; }; }; };
- hdmi: hdmi@ff980000 { - compatible = "rockchip,rk3288-dw-hdmi"; - reg = <0xff980000 0x20000>; - reg-io-width = <4>; - ddc-i2c-bus = <&i2c5>; + lvds: lvds@ff96c000 { + compatible = "rockchip,rk3288-lvds"; + reg = <0x0 0xff96c000 0x0 0x4000>; + clocks = <&cru PCLK_LVDS_PHY>; + clock-names = "pclk_lvds"; + pinctrl-names = "lcdc"; + pinctrl-0 = <&lcdc_ctl>; + power-domains = <&power RK3288_PD_VIO>; rockchip,grf = <&grf>; - interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>; - clock-names = "iahb", "isfr"; status = "disabled"; + ports { - hdmi_in: port { + #address-cells = <1>; + #size-cells = <0>; + + lvds_in: port@0 { + reg = <0>; + #address-cells = <1>; #size-cells = <0>; - hdmi_in_vopb: endpoint@0 { + + lvds_in_vopb: endpoint@0 { reg = <0>; - remote-endpoint = <&vopb_out_hdmi>; + remote-endpoint = <&vopb_out_lvds>; }; - hdmi_in_vopl: endpoint@1 { + lvds_in_vopl: endpoint@1 { reg = <1>; - remote-endpoint = <&vopl_out_hdmi>; + remote-endpoint = <&vopl_out_lvds>; }; }; }; };
- lvds: lvds@ff96c000 { - compatible = "rockchip,rk3288-lvds"; - reg = <0xff96c000 0x4000>; - clocks = <&cru PCLK_LVDS_PHY>; - clock-names = "pclk_lvds"; - pinctrl-names = "default"; - pinctrl-0 = <&lcdc0_ctl>; + edp: dp@ff970000 { + compatible = "rockchip,rk3288-dp"; + reg = <0x0 0xff970000 0x0 0x4000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_EDP>, <&cru PCLK_EDP_CTRL>; + clock-names = "dp", "pclk"; + phys = <&edp_phy>; + phy-names = "dp"; + resets = <&cru SRST_EDP>; + reset-names = "dp"; rockchip,grf = <&grf>; status = "disabled"; + ports { #address-cells = <1>; #size-cells = <0>; - lvds_in: port@0 { + edp_in: port@0 { reg = <0>; #address-cells = <1>; #size-cells = <0>; - lvds_in_vopb: endpoint@0 { + edp_in_vopb: endpoint@0 { reg = <0>; - remote-endpoint = <&vopb_out_lvds>; + remote-endpoint = <&vopb_out_edp>; }; - lvds_in_vopl: endpoint@1 { + edp_in_vopl: endpoint@1 { reg = <1>; - remote-endpoint = <&vopl_out_lvds>; + remote-endpoint = <&vopl_out_edp>; }; }; }; };
- mipi_dsi0: mipi@ff960000 { - compatible = "rockchip,rk3288_mipi_dsi"; - reg = <0xff960000 0x4000>; - clocks = <&cru PCLK_MIPI_DSI0>; - clock-names = "pclk_mipi"; - /*pinctrl-names = "default"; - pinctrl-0 = <&lcdc0_ctl>;*/ + hdmi: hdmi@ff980000 { + compatible = "rockchip,rk3288-dw-hdmi"; + reg = <0x0 0xff980000 0x0 0x20000>; + reg-io-width = <4>; + #sound-dai-cells = <0>; rockchip,grf = <&grf>; - #address-cells = <1>; - #size-cells = <0>; + interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>, <&cru SCLK_HDMI_CEC>; + clock-names = "iahb", "isfr", "cec"; + power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + ports { - reg = <1>; - mipi_in: port { + hdmi_in: port { #address-cells = <1>; #size-cells = <0>; - mipi_in_vopb: endpoint@0 { + hdmi_in_vopb: endpoint@0 { reg = <0>; - remote-endpoint = <&vopb_out_mipi>; + remote-endpoint = <&vopb_out_hdmi>; }; - mipi_in_vopl: endpoint@1 { + hdmi_in_vopl: endpoint@1 { reg = <1>; - remote-endpoint = <&vopl_out_mipi>; + remote-endpoint = <&vopl_out_hdmi>; }; }; }; };
- hdmi_audio: hdmi_audio { - compatible = "rockchip,rk3288-hdmi-audio"; - i2s-controller = <&i2s>; - status = "disable"; - }; - vpu: video-codec@ff9a0000 { compatible = "rockchip,rk3288-vpu"; - reg = <0xff9a0000 0x800>; + reg = <0x0 0xff9a0000 0x0 0x800>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "vepu", "vdpu"; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; - clock-names = "aclk_vcodec", "hclk_vcodec"; - power-domains = <&power RK3288_PD_VIDEO>; + clock-names = "aclk", "hclk"; iommus = <&vpu_mmu>; + power-domains = <&power RK3288_PD_VIDEO>; };
vpu_mmu: iommu@ff9a0800 { compatible = "rockchip,iommu"; - reg = <0xff9a0800 0x100>; + reg = <0x0 0xff9a0800 0x0 0x100>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vpu_mmu"; + clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; power-domains = <&power RK3288_PD_VIDEO>; + }; + + hevc_mmu: iommu@ff9c0440 { + compatible = "rockchip,iommu"; + reg = <0x0 0xff9c0440 0x0 0x40>, <0x0 0xff9c0480 0x0 0x40>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_HEVC>, <&cru HCLK_HEVC>; + clock-names = "aclk", "iface"; #iommu-cells = <0>; + status = "disabled"; };
gpu: gpu@ffa30000 { - compatible = "arm,malit764", - "arm,malit76x", - "arm,malit7xx", - "arm,mali-midgard"; - reg = <0xffa30000 0x10000>; + compatible = "rockchip,rk3288-mali", "arm,mali-t760"; + reg = <0x0 0xffa30000 0x0 0x10000>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "JOB", "MMU", "GPU"; + interrupt-names = "job", "mmu", "gpu"; clocks = <&cru ACLK_GPU>; - clock-names = "aclk_gpu"; - operating-points = < - /* KHz uV */ - 100000 950000 - 200000 950000 - 300000 1000000 - 400000 1100000 - /* 500000 1200000 - See crosbug.com/p/33857 */ - 600000 1250000 - >; + operating-points-v2 = <&gpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ power-domains = <&power RK3288_PD_GPU>; status = "disabled"; };
- efuse: efuse@ffb40000 { - compatible = "rockchip,rk3288-efuse"; - reg = <0xffb40000 0x10000>; - status = "disabled"; + gpu_opp_table: opp-table-1 { + compatible = "operating-points-v2"; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + opp-microvolt = <950000>; + }; + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + opp-microvolt = <950000>; + }; + opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + opp-microvolt = <1000000>; + }; + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + opp-microvolt = <1100000>; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <1250000>; + }; };
- gic: interrupt-controller@ffc01000 { - compatible = "arm,gic-400"; - interrupt-controller; - #interrupt-cells = <3>; - #address-cells = <0>; + qos_gpu_r: qos@ffaa0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffaa0000 0x0 0x20>; + };
- reg = <0xffc01000 0x1000>, - <0xffc02000 0x1000>, - <0xffc04000 0x2000>, - <0xffc06000 0x2000>; - interrupts = <GIC_PPI 9 0xf04>; + qos_gpu_w: qos@ffaa0080 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffaa0080 0x0 0x20>; };
- cpuidle: cpuidle { - compatible = "rockchip,rk3288-cpuidle"; + qos_vio1_vop: qos@ffad0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0000 0x0 0x20>; };
- usbphy: phy { - compatible = "rockchip,rk3288-usb-phy"; - rockchip,grf = <&grf>; + qos_vio1_isp_w0: qos@ffad0100 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0100 0x0 0x20>; + }; + + qos_vio1_isp_w1: qos@ffad0180 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0180 0x0 0x20>; + }; + + qos_vio0_vop: qos@ffad0400 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0400 0x0 0x20>; + }; + + qos_vio0_vip: qos@ffad0480 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0480 0x0 0x20>; + }; + + qos_vio0_iep: qos@ffad0500 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0500 0x0 0x20>; + }; + + qos_vio2_rga_r: qos@ffad0800 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0800 0x0 0x20>; + }; + + qos_vio2_rga_w: qos@ffad0880 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0880 0x0 0x20>; + }; + + qos_vio1_isp_r: qos@ffad0900 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0900 0x0 0x20>; + }; + + qos_video: qos@ffae0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffae0000 0x0 0x20>; + }; + + qos_hevc_r: qos@ffaf0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffaf0000 0x0 0x20>; + }; + + qos_hevc_w: qos@ffaf0080 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffaf0080 0x0 0x20>; + }; + + dmac_bus_s: dma-controller@ffb20000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xffb20000 0x0 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC1>; + clock-names = "apb_pclk"; + }; + + efuse: efuse@ffb40000 { + compatible = "rockchip,rk3288-efuse"; + reg = <0x0 0xffb40000 0x0 0x20>; #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; + #size-cells = <1>; + clocks = <&cru PCLK_EFUSE256>; + clock-names = "pclk_efuse";
- usbphy0: usb-phy0 { - #phy-cells = <0>; - reg = <0x320>; - clocks = <&cru SCLK_OTGPHY0>; - clock-names = "phyclk"; + cpu_id: cpu-id@7 { + reg = <0x07 0x10>; }; - - usbphy1: usb-phy1 { - #phy-cells = <0>; - reg = <0x334>; - clocks = <&cru SCLK_OTGPHY1>; - clock-names = "phyclk"; + cpu_leakage: cpu_leakage@17 { + reg = <0x17 0x1>; }; + };
- usbphy2: usb-phy2 { - #phy-cells = <0>; - reg = <0x348>; - clocks = <&cru SCLK_OTGPHY2>; - clock-names = "phyclk"; - }; + gic: interrupt-controller@ffc01000 { + compatible = "arm,gic-400"; + interrupt-controller; + #interrupt-cells = <3>; + #address-cells = <0>; + + reg = <0x0 0xffc01000 0x0 0x1000>, + <0x0 0xffc02000 0x0 0x2000>, + <0x0 0xffc04000 0x0 0x2000>, + <0x0 0xffc06000 0x0 0x2000>; + interrupts = <GIC_PPI 9 0xf04>; };
pinctrl: pinctrl { compatible = "rockchip,rk3288-pinctrl"; rockchip,grf = <&grf>; rockchip,pmu = <&pmu>; - #address-cells = <1>; - #size-cells = <1>; + #address-cells = <2>; + #size-cells = <2>; ranges;
- gpio0: gpio0@ff750000 { + gpio0: gpio@ff750000 { compatible = "rockchip,gpio-bank"; - reg = <0xff750000 0x100>; + reg = <0x0 0xff750000 0x0 0x100>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO0>;
@@ -943,9 +1434,9 @@ #interrupt-cells = <2>; };
- gpio1: gpio1@ff780000 { + gpio1: gpio@ff780000 { compatible = "rockchip,gpio-bank"; - reg = <0xff780000 0x100>; + reg = <0x0 0xff780000 0x0 0x100>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO1>;
@@ -956,9 +1447,9 @@ #interrupt-cells = <2>; };
- gpio2: gpio2@ff790000 { + gpio2: gpio@ff790000 { compatible = "rockchip,gpio-bank"; - reg = <0xff790000 0x100>; + reg = <0x0 0xff790000 0x0 0x100>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO2>;
@@ -969,9 +1460,9 @@ #interrupt-cells = <2>; };
- gpio3: gpio3@ff7a0000 { + gpio3: gpio@ff7a0000 { compatible = "rockchip,gpio-bank"; - reg = <0xff7a0000 0x100>; + reg = <0x0 0xff7a0000 0x0 0x100>; interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO3>;
@@ -982,9 +1473,9 @@ #interrupt-cells = <2>; };
- gpio4: gpio4@ff7b0000 { + gpio4: gpio@ff7b0000 { compatible = "rockchip,gpio-bank"; - reg = <0xff7b0000 0x100>; + reg = <0x0 0xff7b0000 0x0 0x100>; interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO4>;
@@ -995,9 +1486,9 @@ #interrupt-cells = <2>; };
- gpio5: gpio5@ff7c0000 { + gpio5: gpio@ff7c0000 { compatible = "rockchip,gpio-bank"; - reg = <0xff7c0000 0x100>; + reg = <0x0 0xff7c0000 0x0 0x100>; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO5>;
@@ -1008,9 +1499,9 @@ #interrupt-cells = <2>; };
- gpio6: gpio6@ff7d0000 { + gpio6: gpio@ff7d0000 { compatible = "rockchip,gpio-bank"; - reg = <0xff7d0000 0x100>; + reg = <0x0 0xff7d0000 0x0 0x100>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO6>;
@@ -1021,9 +1512,9 @@ #interrupt-cells = <2>; };
- gpio7: gpio7@ff7e0000 { + gpio7: gpio@ff7e0000 { compatible = "rockchip,gpio-bank"; - reg = <0xff7e0000 0x100>; + reg = <0x0 0xff7e0000 0x0 0x100>; interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO7>;
@@ -1034,9 +1525,9 @@ #interrupt-cells = <2>; };
- gpio8: gpio8@ff7f0000 { + gpio8: gpio@ff7f0000 { compatible = "rockchip,gpio-bank"; - reg = <0xff7f0000 0x100>; + reg = <0x0 0xff7f0000 0x0 0x100>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO8>;
@@ -1051,6 +1542,24 @@ hdmi_cec_c0: hdmi-cec-c0 { rockchip,pins = <7 RK_PC0 2 &pcfg_pull_none>; }; + + hdmi_cec_c7: hdmi-cec-c7 { + rockchip,pins = <7 RK_PC7 4 &pcfg_pull_none>; + }; + + hdmi_ddc: hdmi-ddc { + rockchip,pins = <7 RK_PC3 2 &pcfg_pull_none>, + <7 RK_PC4 2 &pcfg_pull_none>; + }; + + hdmi_ddc_unwedge: hdmi-ddc-unwedge { + rockchip,pins = <7 RK_PC3 RK_FUNC_GPIO &pcfg_output_low>, + <7 RK_PC4 2 &pcfg_pull_none>; + }; + }; + + pcfg_output_low: pcfg-output-low { + output-low; };
pcfg_pull_up: pcfg-pull-up { @@ -1070,472 +1579,424 @@ drive-strength = <12>; };
- sleep { + suspend { global_pwroff: global-pwroff { - rockchip,pins = <0 0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>; };
ddrio_pwroff: ddrio-pwroff { - rockchip,pins = <0 1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; };
ddr0_retention: ddr0-retention { - rockchip,pins = <0 2 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <0 RK_PA2 1 &pcfg_pull_up>; };
ddr1_retention: ddr1-retention { - rockchip,pins = <0 3 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <0 RK_PA3 1 &pcfg_pull_up>; + }; + }; + + edp { + edp_hpd: edp-hpd { + rockchip,pins = <7 RK_PB3 2 &pcfg_pull_down>; }; };
i2c0 { i2c0_xfer: i2c0-xfer { - rockchip,pins = <0 15 RK_FUNC_1 &pcfg_pull_none>, - <0 16 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PB7 1 &pcfg_pull_none>, + <0 RK_PC0 1 &pcfg_pull_none>; }; };
i2c1 { i2c1_xfer: i2c1-xfer { - rockchip,pins = <8 4 RK_FUNC_1 &pcfg_pull_none>, - <8 5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <8 RK_PA4 1 &pcfg_pull_none>, + <8 RK_PA5 1 &pcfg_pull_none>; }; };
i2c2 { i2c2_xfer: i2c2-xfer { - rockchip,pins = <6 9 RK_FUNC_1 &pcfg_pull_none>, - <6 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PB1 1 &pcfg_pull_none>, + <6 RK_PB2 1 &pcfg_pull_none>; }; };
i2c3 { i2c3_xfer: i2c3-xfer { - rockchip,pins = <2 16 RK_FUNC_1 &pcfg_pull_none>, - <2 17 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PC0 1 &pcfg_pull_none>, + <2 RK_PC1 1 &pcfg_pull_none>; }; };
i2c4 { i2c4_xfer: i2c4-xfer { - rockchip,pins = <7 17 RK_FUNC_1 &pcfg_pull_none>, - <7 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC1 1 &pcfg_pull_none>, + <7 RK_PC2 1 &pcfg_pull_none>; }; };
i2c5 { i2c5_xfer: i2c5-xfer { - rockchip,pins = <7 19 RK_FUNC_1 &pcfg_pull_none>, - <7 20 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC3 1 &pcfg_pull_none>, + <7 RK_PC4 1 &pcfg_pull_none>; }; };
i2s0 { i2s0_bus: i2s0-bus { - rockchip,pins = <6 0 RK_FUNC_1 &pcfg_pull_none>, - <6 1 RK_FUNC_1 &pcfg_pull_none>, - <6 2 RK_FUNC_1 &pcfg_pull_none>, - <6 3 RK_FUNC_1 &pcfg_pull_none>, - <6 4 RK_FUNC_1 &pcfg_pull_none>, - <6 8 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PA0 1 &pcfg_pull_none>, + <6 RK_PA1 1 &pcfg_pull_none>, + <6 RK_PA2 1 &pcfg_pull_none>, + <6 RK_PA3 1 &pcfg_pull_none>, + <6 RK_PA4 1 &pcfg_pull_none>, + <6 RK_PB0 1 &pcfg_pull_none>; }; };
- lcdc0 { - lcdc0_ctl: lcdc0-ctl { - rockchip,pins = <1 24 RK_FUNC_1 &pcfg_pull_none>, - <1 25 RK_FUNC_1 &pcfg_pull_none>, - <1 26 RK_FUNC_1 &pcfg_pull_none>, - <1 27 RK_FUNC_1 &pcfg_pull_none>; + lcdc { + lcdc_ctl: lcdc-ctl { + rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>, + <1 RK_PD1 1 &pcfg_pull_none>, + <1 RK_PD2 1 &pcfg_pull_none>, + <1 RK_PD3 1 &pcfg_pull_none>; }; };
sdmmc { sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none>; };
sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up>; };
- sdmmc_cd: sdmcc-cd { - rockchip,pins = <6 22 RK_FUNC_1 &pcfg_pull_up>; + sdmmc_cd: sdmmc-cd { + rockchip,pins = <6 RK_PC6 1 &pcfg_pull_up>; };
sdmmc_bus1: sdmmc-bus1 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>; };
sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up>, - <6 17 RK_FUNC_1 &pcfg_pull_up>, - <6 18 RK_FUNC_1 &pcfg_pull_up>, - <6 19 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>, + <6 RK_PC1 1 &pcfg_pull_up>, + <6 RK_PC2 1 &pcfg_pull_up>, + <6 RK_PC3 1 &pcfg_pull_up>; }; };
sdio0 { sdio0_bus1: sdio0-bus1 { - rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>; };
sdio0_bus4: sdio0-bus4 { - rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_up>, - <4 21 RK_FUNC_1 &pcfg_pull_up>, - <4 22 RK_FUNC_1 &pcfg_pull_up>, - <4 23 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>, + <4 RK_PC5 1 &pcfg_pull_up>, + <4 RK_PC6 1 &pcfg_pull_up>, + <4 RK_PC7 1 &pcfg_pull_up>; };
sdio0_cmd: sdio0-cmd { - rockchip,pins = <4 24 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD0 1 &pcfg_pull_up>; };
sdio0_clk: sdio0-clk { - rockchip,pins = <4 25 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none>; };
sdio0_cd: sdio0-cd { - rockchip,pins = <4 26 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD2 1 &pcfg_pull_up>; };
sdio0_wp: sdio0-wp { - rockchip,pins = <4 27 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD3 1 &pcfg_pull_up>; };
sdio0_pwr: sdio0-pwr { - rockchip,pins = <4 28 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD4 1 &pcfg_pull_up>; };
sdio0_bkpwr: sdio0-bkpwr { - rockchip,pins = <4 29 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD5 1 &pcfg_pull_up>; };
sdio0_int: sdio0-int { - rockchip,pins = <4 30 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD6 1 &pcfg_pull_up>; }; };
sdio1 { sdio1_bus1: sdio1-bus1 { - rockchip,pins = <3 24 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>; };
sdio1_bus4: sdio1-bus4 { - rockchip,pins = <3 24 RK_FUNC_4 &pcfg_pull_up>, - <3 25 RK_FUNC_4 &pcfg_pull_up>, - <3 26 RK_FUNC_4 &pcfg_pull_up>, - <3 27 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>, + <3 RK_PD1 4 &pcfg_pull_up>, + <3 RK_PD2 4 &pcfg_pull_up>, + <3 RK_PD3 4 &pcfg_pull_up>; };
sdio1_cd: sdio1-cd { - rockchip,pins = <3 28 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD4 4 &pcfg_pull_up>; };
sdio1_wp: sdio1-wp { - rockchip,pins = <3 29 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD5 4 &pcfg_pull_up>; };
sdio1_bkpwr: sdio1-bkpwr { - rockchip,pins = <3 30 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD6 4 &pcfg_pull_up>; };
sdio1_int: sdio1-int { - rockchip,pins = <3 31 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD7 4 &pcfg_pull_up>; };
sdio1_cmd: sdio1-cmd { - rockchip,pins = <4 6 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <4 RK_PA6 4 &pcfg_pull_up>; };
sdio1_clk: sdio1-clk { - rockchip,pins = <4 7 RK_FUNC_4 &pcfg_pull_none>; + rockchip,pins = <4 RK_PA7 4 &pcfg_pull_none>; };
sdio1_pwr: sdio1-pwr { - rockchip,pins = <4 9 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <4 RK_PB1 4 &pcfg_pull_up>; }; };
emmc { emmc_clk: emmc-clk { - rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PC0 2 &pcfg_pull_up>; };
emmc_pwr: emmc-pwr { - rockchip,pins = <3 9 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PB1 2 &pcfg_pull_up>; };
emmc_bus1: emmc-bus1 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>; };
emmc_bus4: emmc-bus4 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>, - <3 1 RK_FUNC_2 &pcfg_pull_up>, - <3 2 RK_FUNC_2 &pcfg_pull_up>, - <3 3 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, + <3 RK_PA1 2 &pcfg_pull_up>, + <3 RK_PA2 2 &pcfg_pull_up>, + <3 RK_PA3 2 &pcfg_pull_up>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>, - <3 1 RK_FUNC_2 &pcfg_pull_up>, - <3 2 RK_FUNC_2 &pcfg_pull_up>, - <3 3 RK_FUNC_2 &pcfg_pull_up>, - <3 4 RK_FUNC_2 &pcfg_pull_up>, - <3 5 RK_FUNC_2 &pcfg_pull_up>, - <3 6 RK_FUNC_2 &pcfg_pull_up>, - <3 7 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, + <3 RK_PA1 2 &pcfg_pull_up>, + <3 RK_PA2 2 &pcfg_pull_up>, + <3 RK_PA3 2 &pcfg_pull_up>, + <3 RK_PA4 2 &pcfg_pull_up>, + <3 RK_PA5 2 &pcfg_pull_up>, + <3 RK_PA6 2 &pcfg_pull_up>, + <3 RK_PA7 2 &pcfg_pull_up>; }; };
spi0 { spi0_clk: spi0-clk { - rockchip,pins = <5 12 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB4 1 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { - rockchip,pins = <5 13 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB5 1 &pcfg_pull_up>; }; spi0_tx: spi0-tx { - rockchip,pins = <5 14 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB6 1 &pcfg_pull_up>; }; spi0_rx: spi0-rx { - rockchip,pins = <5 15 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB7 1 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { - rockchip,pins = <5 16 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PC0 1 &pcfg_pull_up>; }; }; spi1 { spi1_clk: spi1-clk { - rockchip,pins = <7 12 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB4 2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { - rockchip,pins = <7 13 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB5 2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { - rockchip,pins = <7 14 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB6 2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { - rockchip,pins = <7 15 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB7 2 &pcfg_pull_up>; }; };
spi2 { spi2_cs1: spi2-cs1 { - rockchip,pins = <8 3 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PA3 1 &pcfg_pull_up>; }; spi2_clk: spi2-clk { - rockchip,pins = <8 6 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PA6 1 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { - rockchip,pins = <8 7 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PA7 1 &pcfg_pull_up>; }; spi2_rx: spi2-rx { - rockchip,pins = <8 8 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PB0 1 &pcfg_pull_up>; }; spi2_tx: spi2-tx { - rockchip,pins = <8 9 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PB1 1 &pcfg_pull_up>; }; };
uart0 { uart0_xfer: uart0-xfer { - rockchip,pins = <4 16 RK_FUNC_1 &pcfg_pull_up>, - <4 17 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PC0 1 &pcfg_pull_up>, + <4 RK_PC1 1 &pcfg_pull_none>; };
uart0_cts: uart0-cts { - rockchip,pins = <4 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PC2 1 &pcfg_pull_up>; };
uart0_rts: uart0-rts { - rockchip,pins = <4 19 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PC3 1 &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { - rockchip,pins = <5 8 RK_FUNC_1 &pcfg_pull_up>, - <5 9 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB0 1 &pcfg_pull_up>, + <5 RK_PB1 1 &pcfg_pull_none>; };
uart1_cts: uart1-cts { - rockchip,pins = <5 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB2 1 &pcfg_pull_up>; };
uart1_rts: uart1-rts { - rockchip,pins = <5 11 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB3 1 &pcfg_pull_none>; }; };
uart2 { uart2_xfer: uart2-xfer { - rockchip,pins = <7 22 RK_FUNC_1 &pcfg_pull_up>, - <7 23 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC6 1 &pcfg_pull_up>, + <7 RK_PC7 1 &pcfg_pull_none>; }; /* no rts / cts for uart2 */ };
uart3 { uart3_xfer: uart3-xfer { - rockchip,pins = <7 7 RK_FUNC_1 &pcfg_pull_up>, - <7 8 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PA7 1 &pcfg_pull_up>, + <7 RK_PB0 1 &pcfg_pull_none>; };
uart3_cts: uart3-cts { - rockchip,pins = <7 9 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PB1 1 &pcfg_pull_up>; };
uart3_rts: uart3-rts { - rockchip,pins = <7 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PB2 1 &pcfg_pull_none>; }; };
uart4 { uart4_xfer: uart4-xfer { - rockchip,pins = <5 12 3 &pcfg_pull_up>, - <5 13 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB7 3 &pcfg_pull_up>, + <5 RK_PB6 3 &pcfg_pull_none>; };
uart4_cts: uart4-cts { - rockchip,pins = <5 14 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>; };
uart4_rts: uart4-rts { - rockchip,pins = <5 15 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB5 3 &pcfg_pull_none>; }; };
tsadc { + otp_pin: otp-pin { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + otp_out: otp-out { - rockchip,pins = <0 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PB2 1 &pcfg_pull_none>; }; };
pwm0 { pwm0_pin: pwm0-pin { - rockchip,pins = <7 0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PA0 1 &pcfg_pull_none>; }; };
pwm1 { pwm1_pin: pwm1-pin { - rockchip,pins = <7 1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PA1 1 &pcfg_pull_none>; }; };
pwm2 { pwm2_pin: pwm2-pin { - rockchip,pins = <7 22 RK_FUNC_3 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC6 3 &pcfg_pull_none>; }; };
pwm3 { pwm3_pin: pwm3-pin { - rockchip,pins = <7 23 RK_FUNC_3 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC7 3 &pcfg_pull_none>; }; };
gmac { rgmii_pins: rgmii-pins { - rockchip,pins = <3 30 3 &pcfg_pull_none>, - <3 31 3 &pcfg_pull_none>, - <3 26 3 &pcfg_pull_none>, - <3 27 3 &pcfg_pull_none>, - <3 28 3 &pcfg_pull_none_12ma>, - <3 29 3 &pcfg_pull_none_12ma>, - <3 24 3 &pcfg_pull_none_12ma>, - <3 25 3 &pcfg_pull_none_12ma>, - <4 0 3 &pcfg_pull_none>, - <4 5 3 &pcfg_pull_none>, - <4 6 3 &pcfg_pull_none>, - <4 9 3 &pcfg_pull_none_12ma>, - <4 4 3 &pcfg_pull_none_12ma>, - <4 1 3 &pcfg_pull_none>, - <4 3 3 &pcfg_pull_none>; + rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, + <3 RK_PD7 3 &pcfg_pull_none>, + <3 RK_PD2 3 &pcfg_pull_none>, + <3 RK_PD3 3 &pcfg_pull_none>, + <3 RK_PD4 3 &pcfg_pull_none_12ma>, + <3 RK_PD5 3 &pcfg_pull_none_12ma>, + <3 RK_PD0 3 &pcfg_pull_none_12ma>, + <3 RK_PD1 3 &pcfg_pull_none_12ma>, + <4 RK_PA0 3 &pcfg_pull_none>, + <4 RK_PA5 3 &pcfg_pull_none>, + <4 RK_PA6 3 &pcfg_pull_none>, + <4 RK_PB1 3 &pcfg_pull_none_12ma>, + <4 RK_PA4 3 &pcfg_pull_none_12ma>, + <4 RK_PA1 3 &pcfg_pull_none>, + <4 RK_PA3 3 &pcfg_pull_none>; };
rmii_pins: rmii-pins { - rockchip,pins = <3 30 3 &pcfg_pull_none>, - <3 31 3 &pcfg_pull_none>, - <3 28 3 &pcfg_pull_none>, - <3 29 3 &pcfg_pull_none>, - <4 0 3 &pcfg_pull_none>, - <4 5 3 &pcfg_pull_none>, - <4 4 3 &pcfg_pull_none>, - <4 1 3 &pcfg_pull_none>, - <4 2 3 &pcfg_pull_none>, - <4 3 3 &pcfg_pull_none>; + rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, + <3 RK_PD7 3 &pcfg_pull_none>, + <3 RK_PD4 3 &pcfg_pull_none>, + <3 RK_PD5 3 &pcfg_pull_none>, + <4 RK_PA0 3 &pcfg_pull_none>, + <4 RK_PA5 3 &pcfg_pull_none>, + <4 RK_PA4 3 &pcfg_pull_none>, + <4 RK_PA1 3 &pcfg_pull_none>, + <4 RK_PA2 3 &pcfg_pull_none>, + <4 RK_PA3 3 &pcfg_pull_none>; }; };
spdif { spdif_tx: spdif-tx { - rockchip,pins = <RK_GPIO6 11 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PB3 1 &pcfg_pull_none>; }; }; }; - - power: power-controller { - compatible = "rockchip,rk3288-power-controller"; - #power-domain-cells = <1>; - rockchip,pmu = <&pmu>; - #address-cells = <1>; - #size-cells = <0>; - - pd_gpu { - reg = <RK3288_PD_GPU>; - clocks = <&cru ACLK_GPU>; - }; - - pd_hevc { - reg = <RK3288_PD_HEVC>; - clocks = <&cru ACLK_HEVC>, - <&cru SCLK_HEVC_CABAC>, - <&cru SCLK_HEVC_CORE>, - <&cru HCLK_HEVC>; - }; - - pd_vio { - reg = <RK3288_PD_VIO>; - clocks = <&cru ACLK_IEP>, - <&cru ACLK_ISP>, - <&cru ACLK_RGA>, - <&cru ACLK_VIP>, - <&cru ACLK_VOP0>, - <&cru ACLK_VOP1>, - <&cru DCLK_VOP0>, - <&cru DCLK_VOP1>, - <&cru HCLK_IEP>, - <&cru HCLK_ISP>, - <&cru HCLK_RGA>, - <&cru HCLK_VIP>, - <&cru HCLK_VOP0>, - <&cru HCLK_VOP1>, - <&cru PCLK_EDP_CTRL>, - <&cru PCLK_HDMI_CTRL>, - <&cru PCLK_LVDS_PHY>, - <&cru PCLK_MIPI_CSI>, - <&cru PCLK_MIPI_DSI0>, - <&cru PCLK_MIPI_DSI1>, - <&cru SCLK_EDP_24M>, - <&cru SCLK_EDP>, - <&cru SCLK_HDMI_CEC>, - <&cru SCLK_HDMI_HDCP>, - <&cru SCLK_ISP_JPE>, - <&cru SCLK_ISP>, - <&cru SCLK_RGA>; - }; - - pd_video { - reg = <RK3288_PD_VIDEO>; - clocks = <&cru ACLK_VCODEC>, - <&cru HCLK_VCODEC>; - }; - }; };
Sync rk3288 DT boards that have support both in Linux 5.17 as in U-boot.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Changed V2: update change led labels --- arch/arm/dts/rk3288-firefly-u-boot.dtsi | 4 +- arch/arm/dts/rk3288-firefly.dts | 17 +- arch/arm/dts/rk3288-firefly.dtsi | 160 +++++-- arch/arm/dts/rk3288-miqi-u-boot.dtsi | 2 +- arch/arm/dts/rk3288-miqi.dts | 431 ++++++++++++++++++- arch/arm/dts/rk3288-miqi.dtsi | 418 ------------------ arch/arm/dts/rk3288-phycore-rdk.dts | 109 +++-- arch/arm/dts/rk3288-phycore-som.dtsi | 111 +---- arch/arm/dts/rk3288-popmetal.dts | 505 +++++++++++++++++++++- arch/arm/dts/rk3288-popmetal.dtsi | 545 ------------------------ arch/arm/dts/rk3288-rock2-som.dtsi | 93 ++-- arch/arm/dts/rk3288-rock2-square.dts | 215 +++++++--- arch/arm/dts/rk3288-tinker-s.dts | 9 +- arch/arm/dts/rk3288-tinker.dts | 30 +- arch/arm/dts/rk3288-tinker.dtsi | 405 +++++++++--------- 15 files changed, 1554 insertions(+), 1500 deletions(-) delete mode 100644 arch/arm/dts/rk3288-miqi.dtsi delete mode 100644 arch/arm/dts/rk3288-popmetal.dtsi
diff --git a/arch/arm/dts/rk3288-firefly-u-boot.dtsi b/arch/arm/dts/rk3288-firefly-u-boot.dtsi index cc84d7c4..c43d3281 100644 --- a/arch/arm/dts/rk3288-firefly-u-boot.dtsi +++ b/arch/arm/dts/rk3288-firefly-u-boot.dtsi @@ -14,11 +14,11 @@ leds { u-boot,dm-pre-reloc;
- work { + work_led: led-0 { u-boot,dm-pre-reloc; };
- power { + power_led: led-1 { u-boot,dm-pre-reloc; }; }; diff --git a/arch/arm/dts/rk3288-firefly.dts b/arch/arm/dts/rk3288-firefly.dts index 72982efd..313459da 100644 --- a/arch/arm/dts/rk3288-firefly.dts +++ b/arch/arm/dts/rk3288-firefly.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2014, 2015 FUKAUMI Naoki naobsd@gmail.com */ @@ -9,31 +9,22 @@ / { model = "Firefly-RK3288"; compatible = "firefly,firefly-rk3288", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; };
&ir { - gpios = <&gpio7 0 GPIO_ACTIVE_LOW>; + gpios = <&gpio7 RK_PA0 GPIO_ACTIVE_LOW>; };
&pinctrl { act8846 { pmic_vsel: pmic-vsel { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_output_low>; + rockchip,pins = <7 RK_PB6 RK_FUNC_GPIO &pcfg_output_low>; }; };
ir { ir_int: ir-int { - rockchip,pins = <7 0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3288-firefly.dtsi b/arch/arm/dts/rk3288-firefly.dtsi index 0924e388..7fb58230 100644 --- a/arch/arm/dts/rk3288-firefly.dtsi +++ b/arch/arm/dts/rk3288-firefly.dtsi @@ -1,16 +1,38 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2014, 2015 FUKAUMI Naoki naobsd@gmail.com */
+#include <dt-bindings/input/input.h> #include "rk3288.dtsi"
/ { - memory { + memory@0 { device_type = "memory"; reg = <0x0 0x0 0x0 0x80000000>; };
+ adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + + button-recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <0>; + }; + }; + + dovdd_1v8: dovdd-1v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "dovdd_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc28_dvp>; + }; + ext_gmac: external-gmac-clock { compatible = "fixed-clock"; #clock-cells = <0>; @@ -27,11 +49,11 @@ keys: gpio-keys { compatible = "gpio-keys";
- button@0 { - gpio-key,wakeup = <1>; - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; + power { + wakeup-source; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; label = "GPIO Power"; - linux,code = <116>; + linux,code = <KEY_POWER>; pinctrl-names = "default"; pinctrl-0 = <&pwr_key>; }; @@ -40,24 +62,24 @@ leds { compatible = "gpio-leds";
- work { - gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; + work_led: led-0 { + gpios = <&gpio8 RK_PA1 GPIO_ACTIVE_LOW>; label = "firefly:blue:user"; linux,default-trigger = "rc-feedback"; pinctrl-names = "default"; - pinctrl-0 = <&work_led>; + pinctrl-0 = <&work_led_pin>; };
- power { - gpios = <&gpio8 2 GPIO_ACTIVE_LOW>; + power_led: led-1 { + gpios = <&gpio8 RK_PA2 GPIO_ACTIVE_LOW>; label = "firefly:green:power"; linux,default-trigger = "default-on"; pinctrl-names = "default"; - pinctrl-0 = <&power_led>; + pinctrl-0 = <&power_led_pin>; }; };
- vcc_sys: vsys-regulator { + vbat_wl: vcc_sys: vsys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc_sys"; regulator-min-microvolt = <5000000>; @@ -68,7 +90,7 @@
vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_pwr>; regulator-name = "vcc_sd"; @@ -99,7 +121,7 @@ vcc_host_5v: usb-host-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&host_vbus_drv>; regulator-name = "vcc_host_5v"; @@ -112,7 +134,7 @@ vcc_otg_5v: usb-otg-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&otg_vbus_drv>; regulator-name = "vcc_otg_5v"; @@ -121,6 +143,23 @@ regulator-always-on; vin-supply = <&vcc_5v>; }; + + /* + * A TT8142 creates both dovdd_1v8 and vcc28_dvp, controlled + * by the dvp_pwr pin. + */ + vcc28_dvp: vcc28-dvp-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&dvp_pwr>; + regulator-name = "vcc28_dvp"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + vin-supply = <&vcc_io>; + }; };
&cpu0 { @@ -128,12 +167,10 @@ };
&emmc { - broken-cd; bus-width = <8>; cap-mmc-highspeed; disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; vmmc-supply = <&vcc_io>; @@ -151,12 +188,17 @@ phy-mode = "rgmii"; snps,reset-active-low; snps,reset-delays-us = <0 10000 1000000>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; tx_delay = <0x30>; rx_delay = <0x10>; status = "okay"; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &hdmi { ddc-i2c-bus = <&i2c5>; status = "okay"; @@ -175,6 +217,8 @@ regulator-max-microvolt = <1350000>; regulator-always-on; regulator-boot-on; + regulator-enable-ramp-delay = <300>; + regulator-ramp-delay = <8000>; vin-supply = <&vcc_sys>; };
@@ -196,7 +240,7 @@ clock-frequency = <32768>; clock-output-names = "xin32k"; interrupt-parent = <&gpio7>; - interrupts = <4 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA4 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&rtc_int>; }; @@ -208,6 +252,14 @@ pinctrl-0 = <&pmic_vsel>, <&pwr_hold>; system-power-controller;
+ vp1-supply = <&vcc_sys>; + vp2-supply = <&vcc_sys>; + vp3-supply = <&vcc_sys>; + vp4-supply = <&vcc_sys>; + inl1-supply = <&vcc_sys>; + inl2-supply = <&vcc_sys>; + inl3-supply = <&vcc_20>; + regulators { vcc_ddr: REG1 { regulator-name = "vcc_ddr"; @@ -276,7 +328,7 @@ regulator-always-on; };
- vcc_18: REG11 { + vccio_wl: vcc_18: REG11 { regulator-name = "vcc_18"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -309,6 +361,21 @@ status = "okay"; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + bb-supply = <&vcc_io>; + dvp-supply = <&dovdd_1v8>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vccio_wl>; +}; + &pinctrl { pcfg_output_high: pcfg-output-high { output-high; @@ -325,43 +392,49 @@
act8846 { pwr_hold: pwr-hold { - rockchip,pins = <0 1 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + dvp { + dvp_pwr: dvp-pwr { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
gmac { phy_int: phy-int { - rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; };
phy_pmeb: phy-pmeb { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; };
phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>; }; };
hym8563 { rtc_int: rtc-int { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <7 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; }; };
keys { pwr_key: pwr-key { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; };
leds { - power_led: power-led { - rockchip,pins = <8 2 RK_FUNC_GPIO &pcfg_pull_none>; + power_led_pin: power-led-pin { + rockchip,pins = <8 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; };
- work_led: work-led { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_none>; + work_led_pin: work-led-pin { + rockchip,pins = <8 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -392,17 +465,17 @@
usb_host { host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; };
usbhub_rst: usbhub-rst { - rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <8 RK_PA3 RK_FUNC_GPIO &pcfg_output_high>; }; };
usb_otg { otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; @@ -413,15 +486,14 @@ };
&sdio0 { - broken-cd; bus-width = <4>; disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>; - vmmc-supply = <&vcc_18>; - status = "disabled"; + vmmc-supply = <&vbat_wl>; + vqmmc-supply = <&vccio_wl>; + status = "okay"; };
&sdmmc { @@ -430,10 +502,10 @@ cap-sd-highspeed; card-detect-delay = <200>; disable-wp; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; status = "okay"; };
@@ -443,6 +515,12 @@ status = "okay"; };
+&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>, <&uart0_cts>, <&uart0_rts>; @@ -461,6 +539,10 @@ status = "okay"; };
+&usbphy { + status = "okay"; +}; + &usb_host1 { pinctrl-names = "default"; pinctrl-0 = <&usbhub_rst>; diff --git a/arch/arm/dts/rk3288-miqi-u-boot.dtsi b/arch/arm/dts/rk3288-miqi-u-boot.dtsi index 2a74fdd1..f2611aaa 100644 --- a/arch/arm/dts/rk3288-miqi-u-boot.dtsi +++ b/arch/arm/dts/rk3288-miqi-u-boot.dtsi @@ -8,7 +8,7 @@ leds { u-boot,dm-pre-reloc;
- work { + work_led: led-0 { u-boot,dm-pre-reloc; }; }; diff --git a/arch/arm/dts/rk3288-miqi.dts b/arch/arm/dts/rk3288-miqi.dts index 4a2f249e..713f55e1 100644 --- a/arch/arm/dts/rk3288-miqi.dts +++ b/arch/arm/dts/rk3288-miqi.dts @@ -1,10 +1,11 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de */
/dts-v1/; -#include "rk3288-miqi.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3288.dtsi"
/ { model = "mqmaker MiQi"; @@ -13,4 +14,428 @@ chosen { stdout-path = "serial2:115200n8"; }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + ext_gmac: external-gmac-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <125000000>; + clock-output-names = "ext_gmac"; + }; + + leds { + compatible = "gpio-leds"; + + work_led: led-0 { + gpios = <&gpio7 RK_PA2 GPIO_ACTIVE_HIGH>; + label = "miqi:green:user"; + linux,default-trigger = "timer"; + }; + }; + + vcc_flash: flash-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_flash"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_io>; + }; + + vcc_host: usb-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc_sd: sdmmc-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_pwr>; + regulator-name = "vcc_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + vin-supply = <&vcc_io>; + }; + + vcc_sys: vsys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&emmc { + bus-width = <8>; + cap-mmc-highspeed; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_flash>; + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_MAC>; + assigned-clock-parents = <&ext_gmac>; + clock_in_out = "input"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>; + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; + tx_delay = <0x30>; + rx_delay = <0x10>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c5>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + status = "okay"; + + vdd_cpu: syr827@40 { + compatible = "silergy,syr827"; + fcs,suspend-voltage-selector = <1>; + reg = <0x40>; + regulator-name = "vdd_cpu"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + regulator-enable-ramp-delay = <300>; + regulator-ramp-delay = <8000>; + vin-supply = <&vcc_sys>; + }; + + vdd_gpu: syr828@41 { + compatible = "silergy,syr828"; + fcs,suspend-voltage-selector = <1>; + reg = <0x41>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + hym8563: hym8563@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "xin32k"; + }; + + act8846: act8846@5a { + compatible = "active-semi,act8846"; + reg = <0x5a>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_vsel>; + system-power-controller; + + vp1-supply = <&vcc_sys>; + vp2-supply = <&vcc_sys>; + vp3-supply = <&vcc_sys>; + vp4-supply = <&vcc_sys>; + inl1-supply = <&vcc_sys>; + inl2-supply = <&vcc_sys>; + inl3-supply = <&vcc_20>; + + regulators { + vcc_ddr: REG1 { + regulator-name = "vcc_ddr"; + regulator-always-on; + }; + + vcc_io: REG2 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdd_log: REG3 { + regulator-name = "vdd_log"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + vcc_20: REG4 { + regulator-name = "vcc_20"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + vccio_sd: REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdd10_lcd: REG6 { + regulator-name = "vdd10_lcd"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vcca_18: REG7 { + regulator-name = "vcca_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vcca_33: REG8 { + regulator-name = "vcca_33"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc_lan: REG9 { + regulator-name = "vcc_lan"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vdd_10: REG10 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vcc_18: REG11 { + regulator-name = "vcc_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc18_lcd: REG12 { + regulator-name = "vcc18_lcd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c4 { + status = "okay"; +}; + +&i2c5 { + status = "okay"; +}; + +&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + +&pinctrl { + pcfg_output_high: pcfg-output-high { + output-high; + }; + + pcfg_output_low: pcfg-output-low { + output-low; + }; + + pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { + bias-pull-up; + drive-strength = <12>; + }; + + act8846 { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pmic_sleep: pmic-sleep { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_output_low>; + }; + + pmic_vsel: pmic-vsel { + rockchip,pins = <7 RK_PA1 RK_FUNC_GPIO &pcfg_output_low>; + }; + }; + + gmac { + phy_int: phy-int { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + phy_pmeb: phy-pmeb { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + phy_rst: phy-rst { + rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + sdmmc { + /* + * Default drive strength isn't enough to achieve even + * high-speed mode on firefly board so bump up to 12ma. + */ + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC1 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC2 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC3 1 &pcfg_pull_up_drv_12ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_12ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_12ma>; + }; + + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb_host { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&saradc { + vref-supply = <&vcc_18>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; + vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&uart3 { + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&usb_host1 { + status = "okay"; +}; + +&usb_otg { + /* + * The otg controller is the only system power source, + * so needs to always stay in device mode. + */ + dr_mode = "peripheral"; + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&wdt { + status = "okay"; }; diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi deleted file mode 100644 index 15797f7d..00000000 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ /dev/null @@ -1,418 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de - */ - -#include "rk3288.dtsi" - -/ { - memory { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - }; - - leds { - compatible = "gpio-leds"; - - work { - gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; - label = "miqi:green:user"; - linux,default-trigger = "default-on"; - pinctrl-names = "default"; - pinctrl-0 = <&led_ctl>; - }; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc_flash>; - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - clock_in_out = "input"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - vdd_cpu: syr827@40 { - compatible = "silergy,syr827"; - fcs,suspend-voltage-selector = <1>; - reg = <0x40>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - regulator-enable-ramp-delay = <300>; - regulator-ramp-delay = <8000>; - vin-supply = <&vcc_sys>; - }; - - vdd_gpu: syr828@41 { - compatible = "silergy,syr828"; - fcs,suspend-voltage-selector = <1>; - reg = <0x41>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - hym8563: hym8563@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - }; - - act8846: act8846@5a { - compatible = "active-semi,act8846"; - reg = <0x5a>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_vsel>; - system-power-controller; - - vp1-supply = <&vcc_sys>; - vp2-supply = <&vcc_sys>; - vp3-supply = <&vcc_sys>; - vp4-supply = <&vcc_sys>; - inl1-supply = <&vcc_sys>; - inl2-supply = <&vcc_sys>; - inl3-supply = <&vcc_20>; - - regulators { - vcc_ddr: REG1 { - regulator-name = "vcc_ddr"; - regulator-always-on; - }; - - vcc_io: REG2 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_log: REG3 { - regulator-name = "vdd_log"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-always-on; - }; - - vcc_20: REG4 { - regulator-name = "vcc_20"; - regulator-min-microvolt = <2000000>; - regulator-max-microvolt = <2000000>; - regulator-always-on; - }; - - vccio_sd: REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd10_lcd: REG6 { - regulator-name = "vdd10_lcd"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcca_18: REG7 { - regulator-name = "vcca_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vcca_33: REG8 { - regulator-name = "vcca_33"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_lan: REG9 { - regulator-name = "vcc_lan"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vdd_10: REG10 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcc_18: REG11 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc18_lcd: REG12 { - regulator-name = "vcc18_lcd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - audio-supply = <&vcca_33>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc_18>; -}; - -&pinctrl { - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { - bias-pull-up; - drive-strength = <12>; - }; - - act8846 { - pmic_int: pmic-int { - rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - pmic_sleep: pmic-sleep { - rockchip,pins = <0 0 RK_FUNC_GPIO &pcfg_output_low>; - }; - - pmic_vsel: pmic-vsel { - rockchip,pins = <7 1 RK_FUNC_GPIO &pcfg_output_low>; - }; - }; - - gmac { - phy_int: phy-int { - rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_pmeb: phy-pmeb { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - leds { - led_ctl: led-ctl { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - /* - * Default drive strength isn't enough to achieve even - * high-speed mode on firefly board so bump up to 12ma. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_12ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - vref-supply = <&vcc_18>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc_host>; - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-phycore-rdk.dts b/arch/arm/dts/rk3288-phycore-rdk.dts index ebea8e67..1e33859d 100644 --- a/arch/arm/dts/rk3288-phycore-rdk.dts +++ b/arch/arm/dts/rk3288-phycore-rdk.dts @@ -1,60 +1,20 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device tree file for Phytec PCM-947 carrier board * Copyright (C) 2017 PHYTEC Messtechnik GmbH * Author: Wadim Egorov w.egorov@phytec.de - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/;
#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/leds-pca9532.h> #include "rk3288-phycore-som.dtsi"
/ { model = "Phytec RK3288 PCM-947"; compatible = "phytec,rk3288-pcm-947", "phytec,rk3288-phycore-som", "rockchip,rk3288";
- chosen { - stdout-path = &uart2; - }; - user_buttons: user-buttons { compatible = "gpio-keys"; pinctrl-names = "default"; @@ -155,6 +115,36 @@
&i2c4 { status = "okay"; + + /* PCA9533 - 4-bit LED dimmer */ + leddim: leddimmer@62 { + compatible = "nxp,pca9533"; + reg = <0x62>; + + led1 { + label = "red:user1"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + + led2 { + label = "green:user2"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + + led3 { + label = "blue:user3"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + + led4 { + label = "red:user4"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + }; };
&i2c5 { @@ -170,15 +160,15 @@ buttons { user_button_pins: user-button-pins { /* button 1 */ - rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_pull_up>, + rockchip,pins = <8 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>, /* button 2 */ - <8 0 RK_FUNC_GPIO &pcfg_pull_up>; + <8 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
rv4162 { i2c_rtc_int: i2c-rtc-int { - rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <5 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; }; };
@@ -188,44 +178,44 @@ * high-speed mode on pcm-947 board so bump up to 12 mA. */ sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC1 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC2 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC3 1 &pcfg_pull_up_drv_12ma>; };
sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_12ma>; + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_12ma>; };
sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_12ma>; };
sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
touchscreen { ts_irq_pin: ts-irq-pin { - rockchip,pins = <5 15 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <5 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; }; };
usb_host { host0_vbus_drv: host0-vbus-drv { - rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; };
host1_vbus_drv: host1-vbus-drv { - rockchip,pins = <2 0 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
usb_otg { otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; @@ -236,10 +226,13 @@ cap-sd-highspeed; card-detect-delay = <200>; disable-wp; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vdd_io_sd>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vdd_sd>; vqmmc-supply = <&vdd_io_sd>; status = "okay"; }; diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 7ecc06f9..db463d2f 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -1,45 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device tree file for Phytec phyCORE-RK3288 SoM * Copyright (C) 2017 PHYTEC Messtechnik GmbH * Author: Wadim Egorov w.egorov@phytec.de - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
#include <dt-bindings/net/ti-dp83867.h> @@ -61,7 +24,6 @@ aliases { rtc0 = &i2c_rtc; rtc1 = &rk818; - eeprom0 = &i2c_eeprom_id; };
ext_gmac: external-gmac-clock { @@ -74,9 +36,9 @@ leds: user-leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&user_led>; + pinctrl-0 = <&user_led_pin>;
- user { + user_led: led-0 { label = "green_led"; gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; @@ -111,33 +73,12 @@ }; };
-&cpu0 { - cpu0-supply = <&vdd_cpu>; - operating-points = < - /* KHz uV */ - 1800000 1400000 - 1608000 1350000 - 1512000 1300000 - 1416000 1200000 - 1200000 1100000 - 1008000 1050000 - 816000 1000000 - 696000 950000 - 600000 900000 - 408000 900000 - 312000 900000 - 216000 900000 - 126000 900000 - >; -}; - &emmc { status = "okay"; bus-width = <8>; cap-mmc-highspeed; disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; vmmc-supply = <&vdd_3v3_io>; @@ -173,6 +114,7 @@ ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; enet-phy-lane-no-swap; + ti,clk-output-sel = <DP83867_CLK_O_SEL_CHN_A_TCLK>; }; }; }; @@ -200,7 +142,6 @@ clock-frequency = <400000>;
rk818: pmic@1c { - status = "okay"; compatible = "rockchip,rk818"; reg = <0x1c>; interrupt-parent = <&gpio0>; @@ -359,11 +300,10 @@ regulator-name = "vdd_io_sd"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3300000>; + regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; + regulator-off-in-suspend; }; }; }; @@ -376,13 +316,6 @@ pagesize = <32>; };
- /* M24C32-D Identification page */ - i2c_eeprom_id: eeprom@58 { - compatible = "atmel,24c32"; - reg = <0x58>; - pagesize = <32>; - }; - vdd_cpu: regulator@60 { compatible = "fcs,fan53555"; reg = <0x60>; @@ -409,49 +342,49 @@ * We also have external pulls, so disable the internal ones. */ emmc_clk: emmc-clk { - rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_12ma>; + rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none_12ma>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_12ma>; + rockchip,pins = <3 RK_PC0 2 &pcfg_pull_none_12ma>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 1 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 2 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 3 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 4 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 5 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 6 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 7 RK_FUNC_2 &pcfg_pull_none_12ma>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_none_12ma>, + <3 RK_PA1 2 &pcfg_pull_none_12ma>, + <3 RK_PA2 2 &pcfg_pull_none_12ma>, + <3 RK_PA3 2 &pcfg_pull_none_12ma>, + <3 RK_PA4 2 &pcfg_pull_none_12ma>, + <3 RK_PA5 2 &pcfg_pull_none_12ma>, + <3 RK_PA6 2 &pcfg_pull_none_12ma>, + <3 RK_PA7 2 &pcfg_pull_none_12ma>; }; };
gmac { phy_int: phy-int { - rockchip,pins = <4 2 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; };
leds { - user_led: user-led { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_output_high>; + user_led_pin: user-led-pin { + rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_output_high>; }; };
pmic { pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; };
/* Pin for switching state between sleep and non-sleep state */ pmic_sleep: pmic-sleep { - rockchip,pins = <RK_GPIO0 0 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3288-popmetal.dts b/arch/arm/dts/rk3288-popmetal.dts index 736dc51e..8c7376d6 100644 --- a/arch/arm/dts/rk3288-popmetal.dts +++ b/arch/arm/dts/rk3288-popmetal.dts @@ -1,20 +1,513 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2014, 2015 Andy Yan andy.yan@rock-chips.com */
/dts-v1/; -#include "rk3288-popmetal.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3288.dtsi"
/ { model = "PopMetal-RK3288"; compatible = "chipspark,popmetal-rk3288", "rockchip,rk3288";
- chosen { - stdout-path = &uart2; + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; }; + + ext_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "ext_gmac"; + #clock-cells = <0>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + pinctrl-names = "default"; + pinctrl-0 = <&pwrbtn>; + + power { + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + label = "GPIO Key Power"; + linux,input-type = <1>; + wakeup-source; + debounce-interval = <100>; + }; + }; + + ir: ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ir_int>; + }; + + vcc_flash: flash-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_flash"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_io>; + }; + + vcc_sd: sdmmc-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_pwr>; + regulator-name = "vcc_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + vin-supply = <&vcc_io>; + }; + + vcc_sys: vsys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + /* + * A PT5128 creates both dovdd_1v8 and vcc28_dvp, controlled + * by the dvp_pwr pin. + */ + vcc18_dvp: vcc18-dvp-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc18-dvp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc28_dvp>; + }; + + vcc28_dvp: vcc28-dvp-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&dvp_pwr>; + regulator-name = "vcc28_dvp"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + vin-supply = <&vcc_io>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&emmc { + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_flash>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; /* wp not hooked up */ + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&gmac { + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + clock_in_out = "input"; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_HIGH>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; + assigned-clocks = <&cru SCLK_MAC>; + assigned-clock-parents = <&ext_gmac>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + tx_delay = <0x30>; + rx_delay = <0x10>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c5>; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int &global_pwroff>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; + vcc8-supply = <&vcc_18>; + vcc9-supply = <&vcc_io>; + vcc10-supply = <&vcc_io>; + vcc11-supply = <&vcc_sys>; + vcc12-supply = <&vcc_io>; + vddio-supply = <&vcc_io>; + + regulators { + vdd_cpu: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-name = "vdd_arm"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-name = "vdd_gpu"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_ddr"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_io"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_lan: LDO_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_lan"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_sd: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vccio_sd"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_10: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd_10"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc18_lcd: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc18_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + ldo5: LDO_REG5 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "ldo5"; + }; + + vdd10_lcd: LDO_REG6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd10_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_18: LDO_REG7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_18"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca_33: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcca_33"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_wl: SWITCH_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vccio_wl"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_lcd: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + + ak8963: ak8963@d { + compatible = "asahi-kasei,ak8975"; + reg = <0x0d>; + interrupt-parent = <&gpio8>; + interrupts = <RK_PA1 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&comp_int>; + vdd-supply = <&vcc_io>; + vid-supply = <&vcc_io>; + }; + + l3g4200d: l3g4200d@69 { + compatible = "st,l3g4200d-gyro"; + st,drdy-int-pin = <2>; + reg = <0x69>; + vdd-supply = <&vcc_io>; + vddio-supply = <&vcc_io>; + }; + + mma8452: mma8452@1d { + compatible = "fsl,mma8452"; + reg = <0x1d>; + interrupt-parent = <&gpio8>; + interrupts = <RK_PA0 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&gsensor_int>; + }; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c3 { + status = "okay"; +}; + +&i2c4 { + status = "okay"; +}; + +&i2c5 { + status = "okay"; +}; + +&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + bb-supply = <&vcc_io>; + dvp-supply = <&vcc18_dvp>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vccio_wl>; +}; + +&pinctrl { + ak8963 { + comp_int: comp-int { + rockchip,pins = <8 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + dvp { + dvp_pwr: dvp-pwr { + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + ir { + ir_int: ir-int { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + mma8452 { + gsensor_int: gsensor-int { + rockchip,pins = <8 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sdmmc { + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&uart3 { + status = "okay"; +}; + +&uart4 { + status = "okay"; +}; + +&usbphy { + status = "okay"; };
-&pwm1 { +&usb_otg { status = "okay"; }; diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi deleted file mode 100644 index 24151bd2..00000000 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ /dev/null @@ -1,545 +0,0 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#include "rk3288.dtsi" - -/ { - memory{ - reg = <0x0 0x0 0x0 0x80000000>; - device_type = "memory"; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - #clock-cells = <0>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - power { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,input-type = <1>; - wakeup-source; - debounce-interval = <100>; - }; - }; - - ir: ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_int>; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - /* - * A PT5128 creates both dovdd_1v8 and vcc28_dvp, controlled - * by the dvp_pwr pin. - */ - vcc18_dvp: vcc18-dvp-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc18-dvp"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc28_dvp>; - }; - - vcc28_dvp: vcc28-dvp-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 17 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&dvp_pwr>; - regulator-name = "vcc28_dvp"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-always-on; - vin-supply = <&vcc_io>; - }; - - vcc5v0_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc5v0_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc_flash>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&gmac { - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio4 7 0>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - clock-frequency = <400000>; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_18>; - vcc9-supply = <&vcc_io>; - vcc10-supply = <&vcc_io>; - vcc11-supply = <&vcc_sys>; - vcc12-supply = <&vcc_io>; - vddio-supply = <&vcc_io>; - - regulators { - vdd_cpu: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_arm"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_io"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_lan: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_lan"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vccio_sd: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_10: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc18_lcd: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - ldo5: LDO_REG5 { - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "ldo5"; - }; - - vdd10_lcd: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd10_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_18: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca_33: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcca_33"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vccio_wl: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vccio_wl"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_lcd: SWITCH_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; - clock-frequency = <400000>; - - ak8963: ak8963@0d { - compatible = "asahi-kasei,ak8975"; - reg = <0x0d>; - interrupt-parent = <&gpio8>; - interrupts = <1 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&comp_int>; - }; - - l3g4200d: l3g4200d@68 { - compatible = "st,l3g4200d-gyro"; - st,drdy-int-pin = <2>; - reg = <0x6b>; - }; - - mma8452: mma8452@1d { - compatible = "fsl,mma8452"; - reg = <0x1d>; - interrupt-parent = <&gpio8>; - interrupts = <0 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&gsensor_int>; - }; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c3 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - audio-supply = <&vcca_33>; - bb-supply = <&vcc_io>; - dvp-supply = <&vcc18_dvp>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vccio_wl>; -}; - -&pinctrl { - ak8963 { - comp_int: comp-int { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - dvp { - dvp_pwr: dvp-pwr { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - ir { - ir_int: ir-int { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - mma8452 { - gsensor_int: gsensor-int { - rockchip,pins = <8 0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&uart0 { - status = "okay"; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&uart4 { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-rock2-som.dtsi b/arch/arm/dts/rk3288-rock2-som.dtsi index aa34cd02..76363b8a 100644 --- a/arch/arm/dts/rk3288-rock2-som.dtsi +++ b/arch/arm/dts/rk3288-rock2-som.dtsi @@ -1,57 +1,19 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include <dt-bindings/pwm/pwm.h> #include "rk3288.dtsi"
/ { - memory { - device_type = "memory"; + memory@0 { reg = <0x0 0x0 0x0 0x80000000>; + device_type = "memory"; };
emmc_pwrseq: emmc-pwrseq { compatible = "mmc-pwrseq-emmc"; pinctrl-0 = <&emmc_reset>; pinctrl-names = "default"; - reset-gpios = <&gpio3 9 GPIO_ACTIVE_LOW>; + reset-gpios = <&gpio3 RK_PB1 GPIO_ACTIVE_LOW>; };
ext_gmac: external-gmac-clock { @@ -61,6 +23,15 @@ clock-output-names = "ext_gmac"; };
+ vcc_flash: flash-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_flash"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us = <150>; + vin-supply = <&vcc_io>; + }; + vcc_sys: vsys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc_sys"; @@ -80,11 +51,11 @@ cap-mmc-highspeed; disable-wp; non-removable; - num-slots = <1>; mmc-pwrseq = <&emmc_pwrseq>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_flash>; status = "okay"; };
@@ -96,13 +67,18 @@ phy-supply = <&vccio_pmu>; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins &phy_rst>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; snps,reset-active-low; snps,reset-delays-us = <0 10000 30000>; rx_delay = <0x10>; tx_delay = <0x30>; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &i2c0 { status = "okay";
@@ -126,7 +102,7 @@ regulator-always-on; };
- vcc_io: REG2 { + vcc_io: vccio_codec: REG2 { regulator-name = "VCC_IO"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -233,24 +209,43 @@ }; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcc_io>; + bb-supply = <&vcc_io>; + dvp-supply = <&vcc_18>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vccio_pmu>; + gpio30-supply = <&vccio_pmu>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + &pinctrl { pcfg_output_high: pcfg-output-high { output-high; };
emmc { - emmc_reset: emmc-reset { - rockchip,pins = <3 9 RK_FUNC_GPIO &pcfg_pull_none>; - }; + emmc_reset: emmc-reset { + rockchip,pins = <3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; };
gmac { phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>; }; }; };
+&saradc { + vref-supply = <&vcc_18>; +}; + &tsadc { rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ rockchip,hw-tshut-polarity = <0>; /* tshut polarity 0:LOW 1:HIGH */ diff --git a/arch/arm/dts/rk3288-rock2-square.dts b/arch/arm/dts/rk3288-rock2-square.dts index 41676696..c4d1d142 100644 --- a/arch/arm/dts/rk3288-rock2-square.dts +++ b/arch/arm/dts/rk3288-rock2-square.dts @@ -1,44 +1,7 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
/dts-v1/; +#include <dt-bindings/input/input.h> #include "rk3288-rock2-som.dtsi"
/ { @@ -49,9 +12,51 @@ stdout-path = "serial2:115200n8"; };
+ adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + + button-recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <0>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + power { + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Power"; + linux,code = <KEY_POWER>; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_key>; + wakeup-source; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + + heartbeat_led: led-0 { + gpios = <&gpio7 RK_PB7 GPIO_ACTIVE_LOW>; + label = "rock2:green:state1"; + linux,default-trigger = "heartbeat"; + }; + + mmc_led: led-1 { + gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_LOW>; + label = "rock2:blue:state2"; + linux,default-trigger = "mmc0"; + }; + }; + ir: ir-receiver { compatible = "gpio-ir-receiver"; - gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; + gpios = <&gpio8 RK_PA1 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&ir_int>; }; @@ -65,27 +70,56 @@ }; };
+ sata_pwr: sata-prw-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 13 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&sata_pwr_en>; + /* Always turn on the 5V sata power connector */ + regulator-always-on; + regulator-name = "sata_pwr"; + }; + spdif_out: spdif-out { compatible = "linux,spdif-dit"; #sound-dai-cells = <0>; };
+ sound-i2s { + compatible = "rockchip,rk3288-hdmi-analog"; + pinctrl-names = "default"; + pinctrl-0 = <&phone_ctl>, <&hp_det>; + rockchip,audio-codec = <&es8388>; + rockchip,hp-det-gpios = <&gpio7 7 GPIO_ACTIVE_HIGH>; + rockchip,hp-en-gpios = <&gpio8 0 GPIO_ACTIVE_HIGH>; + rockchip,i2s-controller = <&i2s>; + rockchip,model = "I2S"; + rockchip,routing = "Analog", "LOUT2", + "Analog", "ROUT2"; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&hym8563>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable>; + reset-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; + }; + vcc_usb_host: vcc-host-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&host_vbus_drv>; - /* Always on as the rockchip usb phy doesn't have a vbus-supply - * property - */ - regulator-always-on; regulator-name = "vcc_host"; };
vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_pwr>; regulator-name = "vcc_sd"; @@ -95,13 +129,25 @@ }; };
+&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk &sdio0_int>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_18>; + status = "okay"; +}; + &sdmmc { bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; card-detect-delay = <200>; disable-wp; /* wp not hooked up */ - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; vmmc-supply = <&vcc_sd>; @@ -119,63 +165,124 @@ };
&i2c0 { - hym8563@51 { + hym8563: hym8563@51 { compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; clock-frequency = <32768>; clock-output-names = "xin32k"; interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA4 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&pmic_int>;
+&i2c2 { + status = "okay"; + + es8388: es8388@10 { + compatible = "everest,es8388", "everest,es8328"; + reg = <0x10>; + AVDD-supply = <&vccio_codec>; + DVDD-supply = <&vccio_codec>; + HPVDD-supply = <&vccio_codec>; + PVDD-supply = <&vccio_codec>; + clocks = <&cru SCLK_I2S0_OUT>; + }; +}; + &i2c5 { status = "okay"; };
+&i2s { + status = "okay"; +}; + &pinctrl { ir { ir_int: ir-int { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <8 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + keys { + pwr_key: pwr-key { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; };
pmic { pmic_int: pmic-int { - rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + headphone { + hp_det: hp-det { + rockchip,pins = <7 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + phone_ctl: phone-ctl { + rockchip,pins = <8 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
usb { host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sata { + sata_pwr_en: sata-pwr-en { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
sdmmc { sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio { + wifi_enable: wifi-enable { + rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; };
+&saradc { + status = "okay"; +}; + &spdif { status = "okay"; };
&uart2 { status = "okay"; - reg-shift = <2>; };
&usbphy { status = "okay"; };
+&usbphy1 { + vbus-supply = <&vcc_usb_host>; +}; + &usb_host0_ehci { status = "okay"; }; + +&usb_host1 { + status = "okay"; +}; + +&usb_otg { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3288-tinker-s.dts b/arch/arm/dts/rk3288-tinker-s.dts index cc7ac5f8..970e1385 100644 --- a/arch/arm/dts/rk3288-tinker-s.dts +++ b/arch/arm/dts/rk3288-tinker-s.dts @@ -10,10 +10,6 @@ / { model = "Rockchip RK3288 Asus Tinker Board S"; compatible = "asus,rk3288-tinker-s", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; };
&emmc { @@ -27,3 +23,8 @@ mmc-ddr-1_8v; status = "okay"; }; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec_c0>; +}; diff --git a/arch/arm/dts/rk3288-tinker.dts b/arch/arm/dts/rk3288-tinker.dts index 8b1848c3..1e43527a 100644 --- a/arch/arm/dts/rk3288-tinker.dts +++ b/arch/arm/dts/rk3288-tinker.dts @@ -1,33 +1,13 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. */
/dts-v1/; + #include "rk3288-tinker.dtsi"
/ { - model = "Tinker-RK3288"; - compatible = "rockchip,rk3288-tinker", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; -}; - -&pinctrl { - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm1 { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc5v0_host>; - status = "okay"; + model = "Rockchip RK3288 Asus Tinker Board"; + compatible = "asus,rk3288-tinker", "rockchip,rk3288"; }; diff --git a/arch/arm/dts/rk3288-tinker.dtsi b/arch/arm/dts/rk3288-tinker.dtsi index 99de2a9f..9c1e38c5 100644 --- a/arch/arm/dts/rk3288-tinker.dtsi +++ b/arch/arm/dts/rk3288-tinker.dtsi @@ -1,46 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. */
#include "rk3288.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/clock/rockchip,rk808.h>
/ { + chosen { + stdout-path = "serial2:115200n8"; + }; + memory { reg = <0x0 0x0 0x0 0x80000000>; device_type = "memory"; @@ -48,23 +19,26 @@
ext_gmac: external-gmac-clock { compatible = "fixed-clock"; + #clock-cells = <0>; clock-frequency = <125000000>; clock-output-names = "ext_gmac"; - #clock-cells = <0>; };
gpio-keys { compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; autorepeat;
pinctrl-names = "default"; pinctrl-0 = <&pwrbtn>;
button@0 { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; label = "GPIO Key Power"; linux,input-type = <1>; - gpio-key,wakeup = <1>; + wakeup-source; debounce-interval = <100>; }; }; @@ -72,14 +46,44 @@ gpio-leds { compatible = "gpio-leds";
- pwr-led { - gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; + act_led: led-0 { + gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + + heartbeat_led: led-1 { + gpios = <&gpio1 RK_PD1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + pwr_led: led-2 { + gpios = <&gpio0 RK_PA3 GPIO_ACTIVE_HIGH>; linux,default-trigger = "default-on"; }; + };
- act-led { - gpios=<&gpio2 3 GPIO_ACTIVE_LOW>; - linux,default-trigger="mmc0"; + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 RK808_CLKOUT1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable>; + reset-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_LOW>, + <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,name = "rockchip,tinker-codec"; + simple-audio-card,mclk-fs = <512>; + + simple-audio-card,codec { + sound-dai = <&hdmi>; + }; + + simple-audio-card,cpu { + sound-dai = <&i2s>; }; };
@@ -92,11 +96,6 @@ regulator-boot-on; };
- /* - * NOTE: vcc_sd isn't hooked up on v1.0 boards where power comes from - * vcc_io directly. Those boards won't be able to power cycle SD cards - * but it shouldn't hurt to toggle this pin there anyway. - */ vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; @@ -108,80 +107,66 @@ startup-delay-us = <100000>; vin-supply = <&vcc_io>; }; - - vcc5v0_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc5v0_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; };
&cpu0 { cpu0-supply = <&vdd_cpu>; };
-&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; /* wp not hooked up */ - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - status = "okay"; - supports-sd; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; +&cpu_opp_table { + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <1350000>; + }; + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1400000>; + }; };
&gmac { - phy-supply = <&vcc33_lan>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio4 7 0>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; assigned-clocks = <&cru SCLK_MAC>; assigned-clock-parents = <&ext_gmac>; + clock_in_out = "input"; + phy-mode = "rgmii"; + phy-supply = <&vcc33_lan>; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio4 7 0>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; tx_delay = <0x30>; rx_delay = <0x10>; status = "okay"; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &hdmi { ddc-i2c-bus = <&i2c5>; status = "okay"; };
&i2c0 { - status = "okay"; clock-frequency = <400000>; + status = "okay";
rk808: pmic@1b { compatible = "rockchip,rk808"; reg = <0x1b>; interrupt-parent = <&gpio0>; interrupts = <4 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + dvs-gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>, + <&gpio0 12 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; + pinctrl-0 = <&pmic_int &global_pwroff &dvs_1 &dvs_2>; rockchip,system-power-controller; wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2";
vcc1-supply = <&vcc_sys>; vcc2-supply = <&vcc_sys>; @@ -189,20 +174,21 @@ vcc4-supply = <&vcc_sys>; vcc6-supply = <&vcc_sys>; vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_18>; + vcc8-supply = <&vcc_io>; vcc9-supply = <&vcc_io>; vcc10-supply = <&vcc_io>; vcc11-supply = <&vcc_sys>; vcc12-supply = <&vcc_io>; - vddio-supply = <&vcc18_ldo1>; + vddio-supply = <&vcc_io>;
regulators { vdd_cpu: DCDC_REG1 { regulator-always-on; regulator-boot-on; regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; + regulator-max-microvolt = <1400000>; regulator-name = "vdd_arm"; + regulator-ramp-delay = <6000>; regulator-state-mem { regulator-off-in-suspend; }; @@ -214,6 +200,7 @@ regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; regulator-name = "vdd_gpu"; + regulator-ramp-delay = <6000>; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <1000000>; @@ -359,47 +346,149 @@
&i2c2 { status = "okay"; - headset: nau8825@1a { - compatible = "nuvoton,nau8825"; - #sound-dai-cells = <0>; - reg = <0x1a>; - interrupt-parent = <&gpio6>; - interrupts = <5 IRQ_TYPE_LEVEL_LOW>; - nuvoton,jkdet-enable = <1>; - nuvoton,jkdet-pull-enable = <1>; - nuvoton,jkdet-pull-up = <0>; - nuvoton,jkdet-polarity = <1>; - nuvoton,vref-impedance = <2>; - nuvoton,micbias-voltage = <6>; - nuvoton,sar-threshold-num = <4>; - nuvoton,sar-threshold = <0xa 0x14 0x26 0x73>; - nuvoton,sar-hysteresis = <0>; - nuvoton,sar-voltage = <6>; - nuvoton,sar-compare-time = <0>; - nuvoton,sar-sampling-time = <0>; - nuvoton,short-key-debounce = <3>; - nuvoton,jack-insert-debounce = <7>; - nuvoton,jack-eject-debounce = <7>; - clock-names = "mclk"; - clocks = <&cru SCLK_I2S0_OUT>; - }; };
-&wdt { +&i2s { + #sound-dai-cells = <0>; status = "okay"; };
+&io_domains { + status = "okay"; + + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + +&pinctrl { + pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { + drive-strength = <8>; + }; + + pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { + bias-pull-up; + drive-strength = <8>; + }; + + backlight { + bl_en: bl-en { + rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + eth_phy { + eth_phy_pwr: eth-phy-pwr { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + dvs_1: dvs-1 { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + dvs_2: dvs-2 { + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sdmmc { + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_8ma>, + <6 RK_PC1 1 &pcfg_pull_up_drv_8ma>, + <6 RK_PC2 1 &pcfg_pull_up_drv_8ma>, + <6 RK_PC3 1 &pcfg_pull_up_drv_8ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_8ma>; + }; + + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pwr_3g: pwr-3g { + rockchip,pins = <7 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio { + wifi_enable: wifi-enable { + rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>, + <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + &pwm0 { status = "okay"; };
&saradc { vref-supply = <&vcc18_ldo1>; - status ="okay"; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + broken-cd; + disable-wp; /* wp not hooked up */ + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + status = "okay"; + vmmc-supply = <&vcc33_sd>; + vqmmc-supply = <&vccio_sd>; +}; + +&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + max-frequency = <50000000>; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>, <&sdio0_int>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_18>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ + status = "okay"; };
&uart0 { @@ -422,12 +511,6 @@ status = "okay"; };
-&tsadc { - rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ - status = "okay"; -}; - &usbphy { status = "okay"; }; @@ -441,7 +524,7 @@ };
&usb_otg { - status= "okay"; + status = "okay"; };
&vopb { @@ -460,72 +543,6 @@ status = "okay"; };
-&pinctrl { - pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { - drive-strength = <8>; - }; - - pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - backlight { - bl_en: bl-en { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - eth_phy { - eth_phy_pwr: eth-phy-pwr { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - /* - * Default drive strength isn't enough to achieve even - * high-speed mode on EVB board so bump up to 8ma. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_8ma>; - }; - - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pwr_3g: pwr-3g { - rockchip,pins = <7 8 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; +&wdt { + status = "okay"; };
Sync rk3288-veyron DT from Linux version 5.17.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Changed V2: update add label spi_flash veyron --- arch/arm/dts/rk3288-veyron-analog-audio.dtsi | 99 +++ .../dts/rk3288-veyron-broadcom-bluetooth.dtsi | 22 + arch/arm/dts/rk3288-veyron-chromebook.dtsi | 115 ++-- arch/arm/dts/rk3288-veyron-edp.dtsi | 141 ++++ arch/arm/dts/rk3288-veyron-jerry.dts | 506 +++++++++++--- arch/arm/dts/rk3288-veyron-mickey.dts | 343 +++++++--- arch/arm/dts/rk3288-veyron-minnie.dts | 441 +++++++----- arch/arm/dts/rk3288-veyron-sdmmc.dtsi | 89 +++ arch/arm/dts/rk3288-veyron-speedy.dts | 303 ++++++-- arch/arm/dts/rk3288-veyron.dtsi | 645 ++++++------------ 10 files changed, 1799 insertions(+), 905 deletions(-) create mode 100644 arch/arm/dts/rk3288-veyron-analog-audio.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-edp.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-sdmmc.dtsi
diff --git a/arch/arm/dts/rk3288-veyron-analog-audio.dtsi b/arch/arm/dts/rk3288-veyron-analog-audio.dtsi new file mode 100644 index 00000000..51208d16 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-analog-audio.dtsi @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Google Veyron (and derivatives) fragment for the max98090 audio + * codec and analog headphone jack. + * + * Copyright 2016 Google, Inc + */ + +/ { + sound { + compatible = "rockchip,rockchip-audio-max98090"; + pinctrl-names = "default"; + pinctrl-0 = <&mic_det>, <&hp_det>; + rockchip,model = "VEYRON-I2S"; + rockchip,i2s-controller = <&i2s>; + rockchip,audio-codec = <&max98090>; + rockchip,hp-det-gpios = <&gpio6 RK_PA5 GPIO_ACTIVE_HIGH>; + rockchip,mic-det-gpios = <&gpio6 RK_PB3 GPIO_ACTIVE_LOW>; + rockchip,headset-codec = <&headsetcodec>; + rockchip,hdmi-codec = <&hdmi>; + }; +}; + +&i2c2 { + max98090: max98090@10 { + compatible = "maxim,max98090"; + reg = <0x10>; + interrupt-parent = <&gpio6>; + interrupts = <RK_PA7 IRQ_TYPE_EDGE_FALLING>; + clock-names = "mclk"; + clocks = <&cru SCLK_I2S0_OUT>; + pinctrl-names = "default"; + pinctrl-0 = <&int_codec>; + }; +}; + +&i2c4 { + headsetcodec: ts3a227e@3b { + compatible = "ti,ts3a227e"; + reg = <0x3b>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ts3a227e_int_l>; + ti,micbias = <7>; /* MICBIAS = 2.8V */ + }; +}; + +&i2s { + status = "okay"; +}; + +&io_domains { + audio-supply = <&vcc18_codec>; +}; + +&rk808 { + vcc10-supply = <&vcc33_sys>; + + regulators { + vcc18_codec: LDO_REG6 { + regulator-name = "vcc18_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; +}; + +&pinctrl { + codec { + hp_det: hp-det { + rockchip,pins = <6 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + /* + * HACK: We're going to _pull down_ this _active low_ interrupt + * so that it never fires. We don't need this interrupt because + * we've got a ts3a227e chip but the driver requires it. + */ + int_codec: int-codec { + rockchip,pins = <6 RK_PA7 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + mic_det: mic-det { + rockchip,pins = <6 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + headset { + ts3a227e_int_l: ts3a227e-int-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; diff --git a/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi b/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi new file mode 100644 index 00000000..a10d25ac --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Google Veyron (and derivatives) fragment for the Broadcom 43450 bluetooth + * chip. + * + * Copyright 2019 Google, Inc + */ + +&uart0 { + bluetooth { + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l>, <&bt_enable_l>, + <&bt_dev_wake>; + + compatible = "brcm,bcm43540-bt"; + host-wakeup-gpios = <&gpio4 RK_PD7 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio4 RK_PD5 GPIO_ACTIVE_HIGH>; + device-wakeup-gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; + max-speed = <3000000>; + brcm,bt-pcm-int-params = [01 02 00 01 01]; + }; +}; diff --git a/arch/arm/dts/rk3288-veyron-chromebook.dtsi b/arch/arm/dts/rk3288-veyron-chromebook.dtsi index 143eaae2..05112c25 100644 --- a/arch/arm/dts/rk3288-veyron-chromebook.dtsi +++ b/arch/arm/dts/rk3288-veyron-chromebook.dtsi @@ -1,39 +1,45 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron (and derivatives) board device tree source + * Chromebook specific parts * - * Copyright 2014 Google, Inc + * Copyright 2015 Google, Inc */
#include <dt-bindings/clock/rockchip,rk808.h> #include <dt-bindings/input/input.h> #include "rk3288-veyron.dtsi" +#include "rk3288-veyron-analog-audio.dtsi" +#include "rk3288-veyron-edp.dtsi" +#include "rk3288-veyron-sdmmc.dtsi"
/ { aliases { + /* Assign 20 so we don't get confused w/ builtin ones */ i2c20 = &i2c_tunnel; - video0 = &vopl; - video1 = &vopb; - }; - - gpio_keys: gpio-keys { - pinctrl-0 = <&pwr_key_h &ap_lid_int_l>; - lid { - label = "Lid"; - gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; - linux,code = <0>; /* SW_LID */ - linux,input-type = <5>; /* EV_SW */ - debounce-interval = <1>; - gpio-key,wakeup; - }; };
gpio-charger { compatible = "gpio-charger"; - gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>; + charger-type = "mains"; + gpios = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&ac_present_ap>; - charger-type = "mains"; + }; + + lid_switch: lid-switch { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&ap_lid_int_l>; + + lid { + label = "Lid"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <SW_LID>; + linux,input-type = <EV_SW>; + debounce-interval = <1>; + }; };
/* A non-regulated voltage from power supply or battery */ @@ -56,7 +62,7 @@ vcc5_host1: vcc5-host1-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 11 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&host1_pwr_en>; regulator-name = "vcc5_host1"; @@ -68,7 +74,7 @@ vcc5v_otg: vcc5v-otg-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&usbotg_pwren_h>; regulator-name = "vcc5_host2"; @@ -78,34 +84,34 @@ };
&rk808 { + vcc11-supply = <&vcc_5v>; + regulators { vcc33_ccd: LDO_REG8 { + regulator-name = "vcc33_ccd"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_ccd"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; }; }; };
&spi0 { status = "okay"; - spi-activate-delay = <100>; - spi-max-frequency = <3000000>; - spi-deactivate-delay = <200>;
cros_ec: ec@0 { compatible = "google,cros-ec-spi"; - spi-max-frequency = <3000000>; + reg = <0>; + google,cros-ec-spi-pre-delay = <30>; interrupt-parent = <&gpio7>; - interrupts = <7 IRQ_TYPE_LEVEL_LOW>; - ec-interrupt = <&gpio7 7 GPIO_ACTIVE_LOW>; + interrupts = <RK_PA7 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; pinctrl-0 = <&ec_int>; - reg = <0>; - google,cros-ec-spi-pre-delay = <30>; + spi-max-frequency = <3000000>;
i2c_tunnel: i2c-tunnel { compatible = "google,cros-ec-i2c-tunnel"; @@ -118,86 +124,59 @@
&i2c4 { trackpad@15 { - compatible = "elan,i2c_touchpad"; + compatible = "elan,ekth3000"; + reg = <0x15>; interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA3 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&trackpad_int>; - reg = <0x15>; vcc-supply = <&vcc33_io>; wakeup-source; }; };
&pinctrl { - pinctrl-0 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Wake only */ - &suspend_l_wake - &bt_dev_wake_awake - >; - pinctrl-1 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Sleep only */ - &suspend_l_sleep - &bt_dev_wake_sleep - >; - buttons { ap_lid_int_l: ap-lid-int-l { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; }; };
charger { ac_present_ap: ac-present-ap { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
cros-ec { ec_int: ec-int { - rockchip,pins = <7 7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_wp_gpio: sdmmc-wp-gpio { - rockchip,pins = <7 10 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <7 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; }; };
suspend { suspend_l_wake: suspend-l-wake { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_low>; + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_output_low>; };
suspend_l_sleep: suspend-l-sleep { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_output_high>; }; };
trackpad { trackpad_int: trackpad-int { - rockchip,pins = <7 3 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <7 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; }; };
usb-host { host1_pwr_en: host1-pwr-en { - rockchip,pins = <0 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; };
usbotg_pwren_h: usbotg-pwren-h { - rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; diff --git a/arch/arm/dts/rk3288-veyron-edp.dtsi b/arch/arm/dts/rk3288-veyron-edp.dtsi new file mode 100644 index 00000000..32c0f107 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-edp.dtsi @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Google Veyron (and derivatives) fragment for the edp displays + * + * Copyright 2019 Google LLC + */ + +/ { + backlight_regulator: backlight-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 RK_PB4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bl_pwr_en>; + regulator-name = "backlight_regulator"; + vin-supply = <&vcc33_sys>; + startup-delay-us = <15000>; + }; + + panel_regulator: panel-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio7 RK_PB6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&lcd_enable_h>; + regulator-name = "panel_regulator"; + vin-supply = <&vcc33_sys>; + }; + + vcc18_lcd: vcc18-lcd { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 RK_PB5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&avdd_1v8_disp_en>; + regulator-name = "vcc18_lcd"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc18_wl>; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + brightness-levels = <0 255>; + num-interpolated-steps = <255>; + default-brightness-level = <128>; + enable-gpios = <&gpio7 RK_PA2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bl_en>; + pwms = <&pwm0 0 1000000 0>; + post-pwm-on-delay-ms = <10>; + pwm-off-delay-ms = <10>; + power-supply = <&backlight_regulator>; + }; + + panel: panel { + compatible = "innolux,n116bge"; + status = "okay"; + power-supply = <&panel_regulator>; + backlight = <&backlight>; + + panel-timing { + clock-frequency = <74250000>; + hactive = <1366>; + hfront-porch = <136>; + hback-porch = <60>; + hsync-len = <30>; + hsync-active = <0>; + vactive = <768>; + vfront-porch = <8>; + vback-porch = <12>; + vsync-len = <12>; + vsync-active = <0>; + }; + + ports { + panel_in: port { + panel_in_edp: endpoint { + remote-endpoint = <&edp_out_panel>; + }; + }; + }; + }; +}; + +&edp { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&edp_hpd>; + + ports { + edp_out: port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + edp_out_panel: endpoint@0 { + reg = <0>; + remote-endpoint = <&panel_in_edp>; + }; + }; + }; +}; + +&edp_phy { + status = "okay"; +}; + +&pwm0 { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&pinctrl { + backlight { + bl_pwr_en: bl_pwr_en { + rockchip,pins = <2 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bl_en: bl-en { + rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + lcd { + lcd_enable_h: lcd-en { + rockchip,pins = <7 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + avdd_1v8_disp_en: avdd-1v8-disp-en { + rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index 40fee55c..2c916c50 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -1,8 +1,8 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron Jerry Rev 3+ board device tree source * - * Copyright 2014 Google, Inc + * Copyright 2015 Google, Inc */
/dts-v1/; @@ -11,162 +11,454 @@
/ { model = "Google Jerry"; - compatible = "google,veyron-jerry-rev7", "google,veyron-jerry-rev6", + compatible = "google,veyron-jerry-rev15", "google,veyron-jerry-rev14", + "google,veyron-jerry-rev13", "google,veyron-jerry-rev12", + "google,veyron-jerry-rev11", "google,veyron-jerry-rev10", + "google,veyron-jerry-rev7", "google,veyron-jerry-rev6", "google,veyron-jerry-rev5", "google,veyron-jerry-rev4", "google,veyron-jerry-rev3", "google,veyron-jerry", "google,veyron", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; - - sound { - compatible = "rockchip,audio-max98090-jerry"; - - cpu { - sound-dai = <&i2s 0>; - }; - - codec { - sound-dai = <&max98090 0>; - }; - }; -}; - -&gpio_keys { - power { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - }; -}; - -&backlight { - power-supply = <&backlight_regulator>; -}; - -&panel { - power-supply= <&panel_regulator>; };
&rk808 { pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l &dvs_1 &dvs_2>; - dvs-gpios = <&gpio7 12 GPIO_ACTIVE_HIGH>, - <&gpio7 15 GPIO_ACTIVE_HIGH>; + dvs-gpios = <&gpio7 RK_PB4 GPIO_ACTIVE_HIGH>, + <&gpio7 RK_PB7 GPIO_ACTIVE_HIGH>;
regulators { mic_vcc: LDO_REG2 { + regulator-name = "mic_vcc"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "mic_vcc"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; }; }; };
+&sdio0 { + #address-cells = <1>; + #size-cells = <0>; + + mwifiex: wifi@1 { + compatible = "marvell,sd8897"; + reg = <1>; + + marvell,caldata-txpwrlimit-2g = /bits/ 8 < +0x01 0x00 0x06 0x00 0x08 0x02 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x01 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x02 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x03 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x04 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x05 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x06 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x07 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x08 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x09 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x0a 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x0b 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x0c 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x0d 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09>; + + marvell,caldata-txpwrlimit-5g-sub0 = /bits/ 8 < +0x01 0x00 0x06 0x00 0xf0 0x01 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x24 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x28 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 +0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 +0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x2c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 +0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 +0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x30 +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 +0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x34 0x01 0x0c +0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x38 0x01 0x0c 0x02 0x0c +0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a +0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 +0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 +0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x3c 0x01 0x0c 0x02 0x0c 0x03 0x0c +0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a +0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 +0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 +0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x40 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a +0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 +0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05>; + + marvell,caldata-txpwrlimit-5g-sub1 = /bits/ 8 < +0x01 0x00 0x06 0x00 0xaa 0x02 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x64 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x68 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 +0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 +0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x6c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 +0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 +0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x70 +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 +0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x74 0x01 0x0c +0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x78 0x01 0x0c 0x02 0x0c +0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a +0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 +0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 +0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x7c 0x01 0x0c 0x02 0x0c 0x03 0x0c +0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a +0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 +0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 +0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x80 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a +0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 +0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x84 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x88 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 +0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 +0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x8c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 +0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 +0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05>; + + marvell,caldata-txpwrlimit-5g-sub2 = /bits/ 8 < +0x01 0x00 0x06 0x00 0x36 0x01 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x95 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 +0x0e 0x08 0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x04 0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x99 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 +0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 +0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x9d 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 +0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 +0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0xa1 +0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 0x08 0x08 +0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 0x10 0x04 +0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0xa5 0x01 0x0b +0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 0x08 0x08 0x09 0x08 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 0x10 0x04 0x11 0x04 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05>; + }; +}; + &sdmmc { + disable-wp; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>; - disable-wp; };
&vcc_5v { enable-active-high; - gpio = <&gpio7 21 GPIO_ACTIVE_HIGH>; + gpio = <&gpio7 RK_PC5 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&drv_5v>; };
&vcc50_hdmi { enable-active-high; - gpio = <&gpio5 19 GPIO_ACTIVE_HIGH>; + gpio = <&gpio5 RK_PC3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&vcc50_hdmi_en>; };
-&edp { - pinctrl-names = "default"; - pinctrl-0 = <&edp_hpd>; +&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "DDRIO_PWROFF", + "DDRIO_RETEN", + "TS3A227E_INT_L", + "PMIC_INT_L", + "PWR_KEY_L", + "AP_LID_INT_L", + "EC_IN_RW", + + "AC_PRESENT_AP", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OTP_OUT", + "HOST1_PWR_EN", + "USBOTG_PWREN_H", + "AP_WARM_RESET_H", + "nFAULT2", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "SUSPEND_L", + "USB_INT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "", + "EMMC_RST_L", + "", + "", + "BL_PWR_EN", + "AVDD_1V8_DISP_EN"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS", + "UART0_RTS", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "BT_DEV_WAKE", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio5 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "SPI0_CLK", + "SPI0_CS0", + "SPI0_TXD", + "SPI0_RXD", + + "", + "", + "", + "VCC50_HDMI_EN"; +}; + +&gpio6 { + gpio-line-names = "I2S0_SCLK", + "I2S0_LRCK_RX", + "I2S0_LRCK_TX", + "I2S0_SDI", + "I2S0_SDO0", + "HP_DET_H", + "", + "INT_CODEC", + + "I2S0_CLK", + "I2C2_SDA", + "I2C2_SCL", + "MICDET", + "", + "", + "", + "", + + "SDMMC_D0", + "SDMMC_D1", + "SDMMC_D2", + "SDMMC_D3", + "SDMMC_CLK", + "SDMMC_CMD"; +}; + +&gpio7 { + gpio-line-names = "LCDC_BL", + "PWM_LOG", + "BL_EN", + "TRACKPAD_INT", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "EC_INT", + + "CPU_NMI", + "DVSOK", + "", + "EDP_HPD", + "DVS1", + "nFAULT1", + "LCD_EN", + "DVS2", + + "VCC5V_GOOD_H", + "I2C4_SDA_TP", + "I2C4_SCL_TP", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "5V_DRV", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; };
&pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; + pinctrl-names = "default", "sleep"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Wake only */ + &suspend_l_wake + &bt_dev_wake_awake + >; + pinctrl-1 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Sleep only */ + &suspend_l_sleep + &bt_dev_wake_sleep + >;
buck-5v { drv_5v: drv-5v { - rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - emmc { - /* Make sure eMMC is not in reset */ - emmc_deassert_reset: emmc-deassert-reset { - rockchip,pins = <2 9 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
hdmi { vcc50_hdmi_en: vcc50-hdmi-en { - rockchip,pins = <5 19 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd { - lcd_enable_h: lcd-en { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - avdd_1v8_disp_en: avdd-1v8-disp-en { - rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <5 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
pmic { dvs_1: dvs-1 { - rockchip,pins = <7 12 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <7 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>; };
dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <7 RK_PB7 RK_FUNC_GPIO &pcfg_pull_down>; }; }; }; @@ -182,24 +474,18 @@ pinctrl-0 = <&i2c4_xfer &trackpad_int>;
trackpad@15 { - compatible = "elan,i2c_touchpad"; - interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; /* * Remove the inherited pinctrl settings to avoid clashing * with bus-wide ones. */ /delete-property/pinctrl-names; /delete-property/pinctrl-0; - reg = <0x15>; - vcc-supply = <&vcc33_io>; - wakeup-source; };
trackpad@2c { compatible = "hid-over-i2c"; interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA3 IRQ_TYPE_EDGE_FALLING>; reg = <0x2c>; hid-descr-addr = <0x0020>; vcc-supply = <&vcc33_io>; diff --git a/arch/arm/dts/rk3288-veyron-mickey.dts b/arch/arm/dts/rk3288-veyron-mickey.dts index 0521d9e0..ffd1121d 100644 --- a/arch/arm/dts/rk3288-veyron-mickey.dts +++ b/arch/arm/dts/rk3288-veyron-mickey.dts @@ -1,49 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron Mickey Rev 0 board device tree source * * Copyright 2015 Google, Inc - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/; -#include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi"
/ { model = "Google Mickey"; @@ -65,6 +29,13 @@ regulator-boot-on; vin-supply = <&vcc33_sys>; }; + + sound { + compatible = "rockchip,rockchip-audio-max98090"; + rockchip,model = "VEYRON-HDMI"; + rockchip,hdmi-codec = <&hdmi>; + rockchip,i2s-controller = <&i2s>; + }; };
&cpu_thermal { @@ -112,14 +83,18 @@ cooling-maps { /* * After 1st level, throttle the CPU down to as low as 1.4 GHz - * and don't let the GPU go faster than 400 MHz. Note that we - * won't throttle the GPU lower than 400 MHz due to CPU - * heat--we'll let the GPU do the rest itself. + * and don't let the GPU go faster than 400 MHz. */ cpu_warm_limit_cpu { trip = <&cpu_alert_warm>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT 4>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT 4>, + <&cpu1 THERMAL_NO_LIMIT 4>, + <&cpu2 THERMAL_NO_LIMIT 4>, + <&cpu3 THERMAL_NO_LIMIT 4>; + }; + cpu_warm_limit_gpu { + trip = <&cpu_alert_warm>; + cooling-device = <&gpu 1 1>; };
/* @@ -140,29 +115,100 @@ */ cpu_almost_hot_limit_cpu { trip = <&cpu_alert_almost_hot>; - cooling-device = - <&cpu0 5 6>; + cooling-device = <&cpu0 5 6>, <&cpu1 5 6>, <&cpu2 5 6>, + <&cpu3 5 6>; }; cpu_hot_limit_cpu { trip = <&cpu_alert_hot>; - cooling-device = - <&cpu0 7 7>; + cooling-device = <&cpu0 7 7>, <&cpu1 7 7>, <&cpu2 7 7>, + <&cpu3 7 7>; }; cpu_hotter_limit_cpu { trip = <&cpu_alert_hotter>; - cooling-device = - <&cpu0 7 8>; + cooling-device = <&cpu0 7 8>, <&cpu1 7 8>, <&cpu2 7 8>, + <&cpu3 7 8>; }; cpu_very_hot_limit_cpu { trip = <&cpu_alert_very_hot>; - cooling-device = - <&cpu0 8 THERMAL_NO_LIMIT>; + cooling-device = <&cpu0 8 THERMAL_NO_LIMIT>, + <&cpu1 8 THERMAL_NO_LIMIT>, + <&cpu2 8 THERMAL_NO_LIMIT>, + <&cpu3 8 THERMAL_NO_LIMIT>; + }; + + /* At very hot, don't let GPU go over 300 MHz */ + cpu_very_hot_limit_gpu { + trip = <&cpu_alert_very_hot>; + cooling-device = <&gpu 2 2>; }; }; };
-&emmc { - /delete-property/mmc-hs200-1_8v; +&gpu_thermal { + /delete-node/ trips; + /delete-node/ cooling-maps; + + trips { + gpu_alert_warmish: gpu_alert_warmish { + temperature = <60000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_alert_warm: gpu_alert_warm { + temperature = <65000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_alert_hotter: gpu_alert_hotter { + temperature = <84000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_alert_very_very_hot: gpu_alert_very_very_hot { + temperature = <86000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_crit: gpu_crit { + temperature = <90000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + /* After 1st level throttle the GPU down to as low as 400 MHz */ + gpu_warmish_limit_gpu { + trip = <&gpu_alert_warmish>; + cooling-device = <&gpu THERMAL_NO_LIMIT 1>; + }; + + /* + * Slightly after we throttle the GPU, we'll also make sure that + * the CPU can't go faster than 1.4 GHz. Note that we won't + * throttle the CPU lower than 1.4 GHz due to GPU heat--we'll + * let the CPU do the rest itself. + */ + gpu_warm_limit_cpu { + trip = <&gpu_alert_warm>; + cooling-device = <&cpu0 4 4>, + <&cpu1 4 4>, + <&cpu2 4 4>, + <&cpu3 4 4>; + }; + + /* When hot, GPU goes down to 300 MHz */ + gpu_hotter_limit_gpu { + trip = <&gpu_alert_hotter>; + cooling-device = <&gpu 2 2>; + }; + + /* When really hot, don't let GPU go _above_ 300 MHz */ + gpu_very_very_hot_limit_gpu { + trip = <&gpu_alert_very_very_hot>; + cooling-device = <&gpu 2 THERMAL_NO_LIMIT>; + }; + }; };
&i2c2 { @@ -175,15 +221,13 @@
&i2s { status = "okay"; - clock-names = "i2s_hclk", "i2s_clk", "i2s_clk_out"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
/delete-property/ vcc6-supply; /delete-property/ vcc12-supply; @@ -216,40 +260,183 @@ }; };
+&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "", + "", + "", + "PMIC_INT_L", + "POWER_BUTTON_L", + "", + "", + + "", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OT_RESET", + "", + "", + "AP_WARM_RESET_H", + "", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "", + "nFALUT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "", + "EMMC_RST_L"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS_L", + "UART0_RTS_L", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "BT_DEV_WAKE", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio7 { + gpio-line-names = "", + "PWM_LOG", + "", + "", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "", + + "CPU_NMI", + "DVSOK", + "HDMI_WAKE", + "POWER_HDMI_ON", + "DVS1", + "", + "", + "DVS2", + + "HDMI_CEC", + "", + "", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; +}; + &pinctrl { + pinctrl-names = "default"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + >; + hdmi { power_hdmi_on: power-hdmi-on { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
-&sdmmc { - status = "disabled"; -}; - -&sdio0 { - status = "disabled"; -}; - -&sdmmc { - status = "disabled"; -}; - -&spi0 { - status = "disabled"; -}; - &usb_host0_ehci { status = "disabled"; }; @@ -260,7 +447,7 @@
&vcc50_hdmi { enable-active-high; - gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&power_hdmi_on>; }; diff --git a/arch/arm/dts/rk3288-veyron-minnie.dts b/arch/arm/dts/rk3288-veyron-minnie.dts index b56a3f4f..82fc6fba 100644 --- a/arch/arm/dts/rk3288-veyron-minnie.dts +++ b/arch/arm/dts/rk3288-veyron-minnie.dts @@ -1,49 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron Minnie Rev 0+ board device tree source * * Copyright 2015 Google, Inc - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/; #include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi"
/ { model = "Google Minnie"; @@ -52,111 +16,31 @@ "google,veyron-minnie-rev0", "google,veyron-minnie", "google,veyron", "rockchip,rk3288";
- backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - startup-delay-us = <100000>; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; + volume_buttons: volume-buttons { + compatible = "gpio-keys"; pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - sound { - compatible = "rockchip,audio-max98090-jerry"; + pinctrl-0 = <&volum_down_l &volum_up_l>;
- cpu { - sound-dai = <&i2s 0>; + volum_down { + label = "Volum_down"; + gpios = <&gpio5 RK_PB3 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEDOWN>; + debounce-interval = <100>; };
- codec { - sound-dai = <&max98090 0>; + volum_up { + label = "Volum_up"; + gpios = <&gpio5 RK_PB2 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEUP>; + debounce-interval = <100>; }; }; };
&backlight { /* Minnie panel PWM must be >= 1%, so start non-zero brightness at 3 */ - brightness-levels = < - 0 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - power-supply = <&backlight_regulator>; -}; - -&emmc { - /delete-property/mmc-hs200-1_8v; -}; - -&gpio_keys { - pinctrl-0 = <&pwr_key_h &ap_lid_int_l &volum_down_l &volum_up_l>; - - volum_down { - label = "Volum_down"; - gpios = <&gpio5 11 GPIO_ACTIVE_LOW>; - linux,code = <KEY_VOLUMEDOWN>; - debounce-interval = <100>; - }; - - volum_up { - label = "Volum_up"; - gpios = <&gpio5 10 GPIO_ACTIVE_LOW>; - linux,code = <KEY_VOLUMEUP>; - debounce-interval = <100>; - }; + brightness-levels = <3 255>; + num-interpolated-steps = <252>; };
&i2c_tunnel { @@ -177,18 +61,31 @@ compatible = "elan,ekth3500"; reg = <0x10>; interrupt-parent = <&gpio2>; - interrupts = <14 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PB6 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&touch_int &touch_rst>; - reset-gpios = <&gpio2 15 GPIO_ACTIVE_LOW>; + reset-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_LOW>; vcc33-supply = <&vcc33_touch>; vccio-supply = <&vcc33_touch>; }; };
&panel { - compatible = "auo,b101ean01", "simple-panel"; - power-supply= <&panel_regulator>; + compatible = "auo,b101ean01"; + + /delete-node/ panel-timing; + + panel-timing { + clock-frequency = <66666667>; + hactive = <1280>; + hfront-porch = <18>; + hback-porch = <21>; + hsync-len = <32>; + vactive = <800>; + vfront-porch = <4>; + vback-porch = <8>; + vsync-len = <18>; + }; };
&rk808 { @@ -217,86 +114,302 @@ &sdmmc { disable-wp; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>; };
+&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "DDRIO_PWROFF", + "DDRIO_RETEN", + "TS3A227E_INT_L", + "PMIC_INT_L", + "PWR_KEY_L", + "AP_LID_INT_L", + "EC_IN_RW", + + "AC_PRESENT_AP", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OTP_OUT", + "HOST1_PWR_EN", + "USBOTG_PWREN_H", + "AP_WARM_RESET_H", + "nFALUT2", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "SUSPEND_L", + "USB_INT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "PROCHOT#", + "EMMC_RST_L", + "", + "", + "BL_PWR_EN", + "AVDD_1V8_DISP_EN", + "TOUCH_INT", + "TOUCH_RST", + + "I2C3_SCL_TP", + "I2C3_SDA_TP"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS", + "UART0_RTS", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "dev_wake", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio5 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "Volum_Up#", + "Volum_Down#", + "SPI0_CLK", + "SPI0_CS0", + "SPI0_TXD", + "SPI0_RXD", + + "", + "", + "", + "VCC50_HDMI_EN"; +}; + +&gpio6 { + gpio-line-names = "I2S0_SCLK", + "I2S0_LRCK_RX", + "I2S0_LRCK_TX", + "I2S0_SDI", + "I2S0_SDO0", + "HP_DET_H", + "", + "INT_CODEC", + + "I2S0_CLK", + "I2C2_SDA", + "I2C2_SCL", + "MICDET", + "", + "", + "", + "", + + "SDMMC_D0", + "SDMMC_D1", + "SDMMC_D2", + "SDMMC_D3", + "SDMMC_CLK", + "SDMMC_CMD"; +}; + +&gpio7 { + gpio-line-names = "LCDC_BL", + "PWM_LOG", + "BL_EN", + "TRACKPAD_INT", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "EC_INT", + + "CPU_NMI", + "DVS_OK", + "SDMMC_WP", + "EDP_HPD", + "DVS1", + "nFALUT1", + "LCD_EN", + "DVS2", + + "VCC5V_GOOD_H", + "I2C4_SDA_TP", + "I2C4_SCL_TP", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "5V_DRV", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; +}; + &pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; + pinctrl-names = "default", "sleep"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Wake only */ + &suspend_l_wake + >; + pinctrl-1 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Sleep only */ + &suspend_l_sleep + >;
buck-5v { drv_5v: drv-5v { - rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
buttons { volum_down_l: volum-down-l { - rockchip,pins = <5 11 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <5 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>; };
volum_up_l: volum-up-l { - rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <5 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; }; };
prochot { gpio_prochot: gpio-prochot { - rockchip,pins = <2 8 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
touchscreen { touch_int: touch-int { - rockchip,pins = <2 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; };
touch_rst: touch-rst { - rockchip,pins = <2 15 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; diff --git a/arch/arm/dts/rk3288-veyron-sdmmc.dtsi b/arch/arm/dts/rk3288-veyron-sdmmc.dtsi new file mode 100644 index 00000000..27fb06ce --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-sdmmc.dtsi @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Google Veyron (and derivatives) fragment for sdmmc cards + * + * Copyright 2015 Google, Inc + */ + +&io_domains { + sdcard-supply = <&vccio_sd>; +}; + +&pinctrl { + sdmmc { + /* + * We run sdmmc at max speed; bump up drive strength. + * We also have external pulls, so disable the internal ones. + */ + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_none_drv_8ma>, + <6 RK_PC1 1 &pcfg_pull_none_drv_8ma>, + <6 RK_PC2 1 &pcfg_pull_none_drv_8ma>, + <6 RK_PC3 1 &pcfg_pull_none_drv_8ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_none_drv_8ma>; + }; + + /* + * Builtin CD line is hooked to ground to prevent JTAG at boot + * (and also to get the voltage rail correct). + * Configure gpio6_C6 as GPIO so dw_mmc builtin CD doesn't + * think there's a card inserted + */ + sdmmc_cd_disabled: sdmmc-cd-disabled { + rockchip,pins = <6 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + /* This is where we actually hook up CD */ + sdmmc_cd_pin: sdmmc-cd-pin { + rockchip,pins = <7 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&rk808 { + vcc9-supply = <&vcc_5v>; + + regulators { + vccio_sd: LDO_REG4 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc33_sd: LDO_REG5 { + regulator-name = "vcc33_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; +}; + +&sdmmc { + status = "okay"; + + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + cd-gpios = <&gpio7 RK_PA5 GPIO_ACTIVE_LOW>; + rockchip,default-sample-phase = <90>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc33_sd>; + vqmmc-supply = <&vccio_sd>; +}; diff --git a/arch/arm/dts/rk3288-veyron-speedy.dts b/arch/arm/dts/rk3288-veyron-speedy.dts index 58c1fe96..4a3ea934 100644 --- a/arch/arm/dts/rk3288-veyron-speedy.dts +++ b/arch/arm/dts/rk3288-veyron-speedy.dts @@ -7,8 +7,8 @@
/dts-v1/; #include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi" #include "cros-ec-sbs.dtsi" -#include "rk3288-veyron-speedy-u-boot.dtsi"
/ { model = "Google Speedy"; @@ -17,44 +17,6 @@ "google,veyron-speedy-rev5", "google,veyron-speedy-rev4", "google,veyron-speedy-rev3", "google,veyron-speedy-rev2", "google,veyron-speedy", "google,veyron", "rockchip,rk3288"; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 RK_PB6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - startup-delay-us = <100000>; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PB5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PB4 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; -}; - -&backlight { - power-supply = <&backlight_regulator>; };
&cpu_alert0 { @@ -65,6 +27,10 @@ temperature = <70000>; };
+&cpu_crit { + temperature = <90000>; +}; + &edp { /delete-property/pinctrl-names; /delete-property/pinctrl-0; @@ -72,8 +38,12 @@ force-hpd; };
-&panel { - power-supply = <&panel_regulator>; +&gpu_alert0 { + temperature = <80000>; +}; + +&gpu_crit { + temperature = <90000>; };
&rk808 { @@ -84,7 +54,7 @@ &sdmmc { disable-wp; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>; };
@@ -102,42 +72,253 @@ pinctrl-0 = <&vcc50_hdmi_en>; };
+&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "DDRIO_PWROFF", + "DDRIO_RETEN", + "TS3A227E_INT_L", + "PMIC_INT_L", + "PWR_KEY_L", + "AP_LID_INT_L", + "EC_IN_RW", + + "AC_PRESENT_AP", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OTP_OUT", + "HOST1_PWR_EN", + "USBOTG_PWREN_H", + "AP_WARM_RESET_H", + "nFALUT2", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "SUSPEND_L", + "USB_INT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "PWRLIMIT#_CPU", + "EMMC_RST_L", + "", + "", + "BL_PWR_EN", + "AVDD_1V8_DISP_EN"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS", + "UART0_RTS", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "BT_DEV_WAKE", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio5 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "SPI0_CLK", + "SPI0_CS0", + "SPI0_TXD", + "SPI0_RXD", + + "", + "", + "", + "VCC50_HDMI_EN"; +}; + +&gpio6 { + gpio-line-names = "I2S0_SCLK", + "I2S0_LRCK_RX", + "I2S0_LRCK_TX", + "I2S0_SDI", + "I2S0_SDO0", + "HP_DET_H", + "ALS_INT", /* not connected */ + "INT_CODEC", + + "I2S0_CLK", + "I2C2_SDA", + "I2C2_SCL", + "MICDET", + "", + "", + "", + "", + + "SDMMC_D0", + "SDMMC_D1", + "SDMMC_D2", + "SDMMC_D3", + "SDMMC_CLK", + "SDMMC_CMD"; +}; + +&gpio7 { + gpio-line-names = "LCDC_BL", + "PWM_LOG", + "BL_EN", + "TRACKPAD_INT", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "EC_INT", + + "CPU_NMI", + "DVS_OK", + "", + "EDP_HOTPLUG", + "DVS1", + "nFALUT1", + "LCD_EN", + "DVS2", + + "VCC5V_GOOD_H", + "I2C4_SDA_TP", + "I2C4_SCL_TP", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "5V_DRV", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; +}; + &pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; + pinctrl-names = "default", "sleep"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Wake only */ + &suspend_l_wake + >; + pinctrl-1 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Sleep only */ + &suspend_l_sleep + >;
dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <7 RK_PB7 RK_FUNC_GPIO &pcfg_pull_down>; }; }; }; diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index d7145cd1..bd38e6ac 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -1,8 +1,8 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron (and derivatives) board device tree source * - * Copyright 2014 Google, Inc + * Copyright 2015 Google, Inc */
#include <dt-bindings/clock/rockchip,rk808.h> @@ -10,150 +10,83 @@ #include "rk3288.dtsi"
/ { - memory { - reg = <0x0 0x0 0x0 0x80000000>; - }; - chosen { - stdout-path = &uart2; + stdout-path = "serial2:115200n8"; };
- firmware { - chromeos { - pinctrl-names = "default"; - pinctrl-0 = <&fw_wp_ap>; - write-protect-gpio = <&gpio7 6 GPIO_ACTIVE_LOW>; - }; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - brightness-levels = < - 0 1 2 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - default-brightness-level = <128>; - enable-gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; - backlight-boot-off; - pinctrl-names = "default"; - pinctrl-0 = <&bl_en>; - pwms = <&pwm0 0 1000000 0>; + /* + * The default coreboot on veyron devices ignores memory@0 nodes + * and would instead create another memory node. + */ + memory { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; };
- panel: panel { - compatible ="cnm,n116bgeea2","simple-panel"; - status = "okay"; - power-supply = <&vcc33_lcd>; - backlight = <&backlight>; - };
- gpio_keys: gpio-keys { + power_button: power-button { compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_key_h>; + pinctrl-0 = <&pwr_key_l>; + power { label = "Power"; - gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; linux,code = <KEY_POWER>; debounce-interval = <100>; - gpio-key,wakeup; + wakeup-source; }; };
gpio-restart { compatible = "gpio-restart"; - gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>; + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&ap_warm_reset_h>; - priority = /bits/ 8 <200>; + priority = <200>; };
emmc_pwrseq: emmc-pwrseq { compatible = "mmc-pwrseq-emmc"; pinctrl-0 = <&emmc_reset>; pinctrl-names = "default"; - reset-gpios = <&gpio2 9 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio2 RK_PB1 GPIO_ACTIVE_HIGH>; };
- sound { - compatible = "rockchip,rockchip-audio-max98090"; - rockchip,model = "ROCKCHIP-I2S"; - rockchip,i2s-controller = <&i2s>; - rockchip,audio-codec = <&max98090>; - rockchip,hp-det-gpios = <&gpio6 5 GPIO_ACTIVE_HIGH>; - rockchip,mic-det-gpios = <&gpio6 11 GPIO_ACTIVE_LOW>; - rockchip,headset-codec = <&headsetcodec>; + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 RK808_CLKOUT1>; + clock-names = "ext_clock"; pinctrl-names = "default"; - pinctrl-0 = <&mic_det>, <&hp_det>; - }; - - vdd_logic: pwm-regulator { - compatible = "pwm-regulator"; - pwms = <&pwm1 0 2000 0>; - - voltage-table = <1350000 0>, - <1300000 10>, - <1250000 20>, - <1200000 31>, - <1150000 41>, - <1100000 52>, - <1050000 62>, - <1000000 72>, - < 950000 83>; + pinctrl-0 = <&wifi_enable_h>;
- regulator-min-microvolt = <950000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_logic"; - regulator-ramp-delay = <4000>; + /* + * Depending on the actual card populated GPIO4 D4 + * correspond to one of these signals on the module: + * + * D4: + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + reset-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; };
- vcc33_sys: vcc33-sys { + vcc_5v: vcc-5v { compatible = "regulator-fixed"; - regulator-name = "vcc33_sys"; + regulator-name = "vcc_5v"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vccsys>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; };
- vcc_5v: vcc-5v { + vcc33_sys: vcc33-sys { compatible = "regulator-fixed"; - regulator-name = "vcc_5v"; + regulator-name = "vcc33_sys"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; };
vcc50_hdmi: vcc50-hdmi { @@ -164,39 +97,21 @@ vin-supply = <&vcc_5v>; };
- bt_regulator: bt-regulator { - /* - * On the module itself this is one of these (depending - * on the actual card pouplated): - * - BT_I2S_WS_BT_RFDISABLE_L - * - No connect - */ - - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_enable_l>; - regulator-name = "bt_regulator"; - }; + vdd_logic: vdd-logic { + compatible = "pwm-regulator"; + regulator-name = "vdd_logic";
- wifi_regulator: wifi-regulator { - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ + pwms = <&pwm1 0 1994 0>; + pwm-supply = <&vcc33_sys>;
- compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 28 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - regulator-name = "wifi_regulator"; + pwm-dutycycle-range = <0x7b 0>; + pwm-dutycycle-unit = <0x94>;
- /* Faux input supply. See bt_regulator description. */ - vin-supply = <&bt_regulator>; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <4000>; }; };
@@ -204,71 +119,62 @@ cpu0-supply = <&vdd_cpu>; };
-&efuse { - status = "okay"; +&cpu_crit { + temperature = <100000>; +}; + +/* rk3288-c used in Veyron Chrome-devices has slightly changed OPPs */ +&cpu_opp_table { + /delete-node/ opp-312000000; + + opp-1512000000 { + opp-microvolt = <1250000>; + }; + opp-1608000000 { + opp-microvolt = <1300000>; + }; + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <1350000>; + }; + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1400000>; + }; };
&emmc { - broken-cd; + status = "okay"; + bus-width = <8>; cap-mmc-highspeed; + rockchip,default-sample-phase = <158>; + disable-wp; mmc-hs200-1_8v; mmc-pwrseq = <&emmc_pwrseq>; - disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8 &emmc_pwr>; - status = "okay"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; };
-&sdio0 { - broken-cd; - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - cap-sdio-irq; - card-external-vcc-supply = <&wifi_regulator>; - clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, - <&cru SCLK_SDIO0_SAMPLE>, <&rk808 RK808_CLKOUT1>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample", "card_ext_clock"; - keep-power-in-suspend; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>; +&gpu { + mali-supply = <&vdd_gpu>; status = "okay"; - vmmc-supply = <&vcc33_sys>; - vqmmc-supply = <&vcc18_wl>; };
-&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - card-detect-delay = <200>; - cd-gpios = <&gpio7 5 GPIO_ACTIVE_LOW>; - num-slots = <1>; - status = "okay"; - vmmc-supply = <&vcc33_sd>; - vqmmc-supply = <&vccio_sd>; +&gpu_alert0 { + temperature = <72500>; };
-&spi2 { - status = "okay"; +&gpu_crit { + temperature = <100000>; +};
- spi_flash: spiflash@0 { - compatible = "spidev", "jedec,spi-nor"; - spi-max-frequency = <20000000>; /* Reduce for Dediprog em100 pro */ - reg = <0>; - }; +&hdmi { + pinctrl-names = "default", "unwedge"; + pinctrl-0 = <&hdmi_ddc>; + pinctrl-1 = <&hdmi_ddc_unwedge>; + status = "okay"; };
&i2c0 { @@ -280,12 +186,12 @@
rk808: pmic@1b { compatible = "rockchip,rk808"; + reg = <0x1b>; clock-output-names = "xin32k", "wifibt_32kin"; interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; + interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l>; - reg = <0x1b>; rockchip,system-power-controller; wakeup-source; #clock-cells = <1>; @@ -297,39 +203,41 @@ vcc6-supply = <&vcc_5v>; vcc7-supply = <&vcc33_sys>; vcc8-supply = <&vcc33_sys>; - vcc9-supply = <&vcc_5v>; - vcc10-supply = <&vcc33_sys>; - vcc11-supply = <&vcc_5v>; vcc12-supply = <&vcc_18>; - vddio-supply = <&vcc33_io>;
regulators { vdd_cpu: DCDC_REG1 { + regulator-name = "vdd_arm"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1450000>; - regulator-name = "vdd_arm"; regulator-ramp-delay = <6001>; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; };
vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <800000>; regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; regulator-ramp-delay = <6001>; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; };
vcc135_ddr: DCDC_REG3 { + regulator-name = "vcc135_ddr"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc135_ddr"; - regulator-suspend-mem-enabled; + regulator-state-mem { + regulator-on-in-suspend; + }; };
/* @@ -340,12 +248,15 @@ * power measurement purposes). */ vcc18_wl: vcc18_flashio: vcc_18: DCDC_REG4 { + regulator-name = "vcc_18"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; - regulator-suspend-mem-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; };
/* @@ -356,60 +267,47 @@ * (such as danger) they're the same net. */ vcc33_io: LDO_REG1 { + regulator-name = "vcc33_io"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_io"; - regulator-suspend-mem-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; };
vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; - regulator-suspend-mem-microvolt = <1000000>; - }; - - vccio_sd: LDO_REG4 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-suspend-mem-disabled; - }; - - vcc33_sd: LDO_REG5 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_sd"; - regulator-suspend-mem-disabled; - }; - - vcc18_codec: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_codec"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; };
vdd10_lcd_pwren_h: LDO_REG7 { + regulator-name = "vdd10_lcd_pwren_h"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <2500000>; regulator-max-microvolt = <2500000>; - regulator-name = "vdd10_lcd_pwren_h"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; };
vcc33_lcd: SWITCH_REG1 { + regulator-name = "vcc33_lcd"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc33_lcd"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; }; }; }; @@ -436,24 +334,6 @@ clock-frequency = <100000>; i2c-scl-falling-time-ns = <50>; /* 10ns measured */ i2c-scl-rising-time-ns = <800>; /* 600ns measured */ - - max98090: max98090@10 { - compatible = "maxim,max98090"; - reg = <0x10>; - #sound-dai-cells = <0>; - interrupt-parent = <&gpio6>; - interrupts = <7 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&int_codec>; - }; -}; - -&i2c3 { - status = "okay"; - - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; };
&i2c4 { @@ -462,56 +342,61 @@ clock-frequency = <400000>; i2c-scl-falling-time-ns = <50>; /* 11ns measured */ i2c-scl-rising-time-ns = <300>; /* 225ns measured */ - - headsetcodec: ts3a227e@3b { - compatible = "ti,ts3a227e"; - reg = <0x3b>; - interrupt-parent = <&gpio0>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ts3a227e_int_l>; - ti,micbias = <7>; /* MICBIAS = 2.8V */ - }; -}; - -&i2c5 { - status = "okay"; - - clock-frequency = <100000>; - i2c-scl-falling-time-ns = <300>; - i2c-scl-rising-time-ns = <1000>; -}; - -&i2s { - status = "okay"; - clock-names = "i2s_hclk", "i2s_clk", "i2s_clk_out"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
&io_domains { status = "okay";
- audio-supply = <&vcc18_codec>; bb-supply = <&vcc33_io>; dvp-supply = <&vcc_18>; flash0-supply = <&vcc18_flashio>; gpio1830-supply = <&vcc33_io>; gpio30-supply = <&vcc33_io>; lcdc-supply = <&vcc33_lcd>; - sdcard-supply = <&vccio_sd>; wifi-supply = <&vcc18_wl>; };
-&wdt { +&pwm1 { + status = "okay"; +}; + +&sdio0 { status = "okay"; + + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc33_sys>; + vqmmc-supply = <&vcc18_wl>; };
-&pwm0 { +&spi2 { status = "okay"; + + rx-sample-delay-ns = <12>; + + spi_flash: flash@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <0>; + }; };
-&pwm1 { +&tsadc { status = "okay"; + + rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-temp = <125000>; };
&uart0 { @@ -520,9 +405,6 @@ /* Pins don't include flow control by default; add that in */ pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - /* We need to go faster than 24MHz, so adjust clock parents / rates */ - assigned-clocks = <&cru SCLK_UART0>; - assigned-clock-rates = <48000000>; };
&uart1 { @@ -531,67 +413,47 @@
&uart2 { status = "okay"; - reg-shift = <2>; };
-&vopb { +&usbphy { status = "okay"; };
-&vopb_mmu { +&usb_host0_ehci { status = "okay"; -};
-&vopl { - status = "okay"; + needs-reset-on-resume; };
-&vopl_mmu { +&usb_host1 { status = "okay"; + snps,need-phy-for-wake; };
-&edp { +&usb_otg { status = "okay"; - rockchip,panel = <&panel>; + + assigned-clocks = <&cru SCLK_USBPHY480M_SRC>; + assigned-clock-parents = <&usbphy0>; + dr_mode = "host"; + snps,need-phy-for-wake; };
-&hdmi { +&vopb { status = "okay"; };
-&gpu { +&vopb_mmu { status = "okay"; };
-&tsadc { - tsadc-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - tsadc-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ +&wdt { status = "okay"; };
&pinctrl { - pinctrl-names = "default", "sleep"; - pinctrl-0 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Wake only */ - &bt_dev_wake_awake - >; - pinctrl-1 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Sleep only */ - &bt_dev_wake_sleep - >; - - /* Add this for sdmmc pins to SD card */ pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { + bias-disable; drive-strength = <8>; };
@@ -608,33 +470,15 @@ output-low; };
- backlight { - bl_en: bl-en { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - buttons { - pwr_key_h: pwr-key-h { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - codec { - hp_det: hp-det { - rockchip,pins = <6 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - int_codec: int-codec { - rockchip,pins = <6 7 RK_FUNC_GPIO &pcfg_pull_up>; - }; - mic_det: mic-det { - rockchip,pins = <6 11 RK_FUNC_GPIO &pcfg_pull_up>; + pwr_key_l: pwr-key-l { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; };
emmc { emmc_reset: emmc-reset { - rockchip,pins = <2 9 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; };
/* @@ -642,54 +486,59 @@ * We also have external pulls, so disable the internal ones. */ emmc_clk: emmc-clk { - rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none_drv_8ma>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <3 RK_PC0 2 &pcfg_pull_none_drv_8ma>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 1 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 2 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 3 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 4 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 5 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 6 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 7 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; - }; - }; - - headset { - ts3a227e_int_l: ts3a227e-int-l { - rockchip,pins = <0 3 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA1 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA2 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA3 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA4 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA5 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA6 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA7 2 &pcfg_pull_none_drv_8ma>; }; };
pmic { pmic_int_l: pmic-int-l { - /* - * Causes jerry to hang when probing bus 0 - * rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - */ + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; }; };
reboot { ap_warm_reset_h: ap-warm-reset-h { - rockchip,pins = <RK_GPIO0 13 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + recovery-switch { + rec_mode_l: rec-mode-l { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; }; };
sdio0 { wifi_enable_h: wifienable-h { - rockchip,pins = <4 28 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; };
/* NOTE: mislabelled on schematic; should be bt_enable_h */ bt_enable_l: bt-enable-l { - rockchip,pins = <4 29 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake: bt-host-wake { + rockchip,pins = <4 RK_PD7 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <4 RK_PD7 RK_FUNC_GPIO &pcfg_pull_none>; };
/* @@ -697,100 +546,48 @@ * We also have external pulls, so disable the internal ones. */ sdio0_bus4: sdio0-bus4 { - rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 22 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 23 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <4 RK_PC4 1 &pcfg_pull_none_drv_8ma>, + <4 RK_PC5 1 &pcfg_pull_none_drv_8ma>, + <4 RK_PC6 1 &pcfg_pull_none_drv_8ma>, + <4 RK_PC7 1 &pcfg_pull_none_drv_8ma>; };
sdio0_cmd: sdio0-cmd { - rockchip,pins = <4 24 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <4 RK_PD0 1 &pcfg_pull_none_drv_8ma>; };
sdio0_clk: sdio0-clk { - rockchip,pins = <4 25 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none_drv_8ma>; };
/* * These pins are only present on very new veyron boards; on * older boards bt_dev_wake is simply always high. Note that - * gpio4_26 is a NC on old veyron boards, so it doesn't hurt + * gpio4_D2 is a NC on old veyron boards, so it doesn't hurt * to map this pin everywhere */ bt_dev_wake_sleep: bt-dev-wake-sleep { - rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_low>; + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_output_low>; };
bt_dev_wake_awake: bt-dev-wake-awake { - rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - sdmmc { - /* - * We run sdmmc at max speed; bump up drive strength. - * We also have external pulls, so disable the internal ones. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 17 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 18 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 19 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - /* - * Builtin CD line is hooked to ground to prevent JTAG at boot - * (and also to get the voltage rail correct). Make we - * configure gpio6_C6 as GPIO so dw_mmc builtin CD doesn't - * think there's a card inserted - */ - sdmmc_cd_disabled: sdmmc-cd-disabled { - rockchip,pins = <6 22 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_output_high>; };
- /* This is where we actually hook up CD */ - sdmmc_cd_gpio: sdmmc-cd-gpio { - rockchip,pins = <7 5 RK_FUNC_GPIO &pcfg_pull_none>; + bt_dev_wake: bt-dev-wake { + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
tpm { tpm_int_h: tpm-int-h { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; }; };
write-protect { fw_wp_ap: fw-wp-ap { - rockchip,pins = <7 6 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; - -&usbphy { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; - needs-reset-on-resume; -}; - -&usb_host1 { - status = "okay"; -}; - -&usb_otg { - dr_mode = "host"; - status = "okay"; - assigned-clocks = <&cru SCLK_USBPHY480M_SRC>; - assigned-clock-parents = <&cru SCLK_OTGPHY0>; -};
The DT node name pattern in mmc-controller.yaml for mmc is "^mmc(@.*)?$". The Rockchip mmc nodes have been synced with Linux, so update the boot_devices constants as well.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/mach-rockchip/rk3188/rk3188.c | 4 ++-- arch/arm/mach-rockchip/rk322x/rk322x.c | 4 ++-- arch/arm/mach-rockchip/rk3288/rk3288.c | 4 ++-- arch/arm/mach-rockchip/rk3328/rk3328.c | 4 ++-- arch/arm/mach-rockchip/rk3368/rk3368.c | 4 ++-- 5 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index 5a02914e..df8fa156 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -21,8 +21,8 @@ #define GRF_BASE 0x20008000
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/dwmmc@1021c000", - [BROM_BOOTSOURCE_SD] = "/dwmmc@10214000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@1021c000", + [BROM_BOOTSOURCE_SD] = "/mmc@10214000", };
#ifdef CONFIG_DEBUG_UART_BOARD_INIT diff --git a/arch/arm/mach-rockchip/rk322x/rk322x.c b/arch/arm/mach-rockchip/rk322x/rk322x.c index ad4ac62e..a304795f 100644 --- a/arch/arm/mach-rockchip/rk322x/rk322x.c +++ b/arch/arm/mach-rockchip/rk322x/rk322x.c @@ -9,8 +9,8 @@ #include <asm/arch-rockchip/hardware.h>
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/dwmmc@30020000", - [BROM_BOOTSOURCE_SD] = "/dwmmc@30000000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@30020000", + [BROM_BOOTSOURCE_SD] = "/mmc@30000000", };
#ifdef CONFIG_DEBUG_UART_BOARD_INIT diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index bc20bc5a..3ad28875 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -28,8 +28,8 @@ DECLARE_GLOBAL_DATA_PTR; #define GRF_BASE 0xff770000
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/dwmmc@ff0f0000", - [BROM_BOOTSOURCE_SD] = "/dwmmc@ff0c0000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@ff0f0000", + [BROM_BOOTSOURCE_SD] = "/mmc@ff0c0000", };
#ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/mach-rockchip/rk3328/rk3328.c b/arch/arm/mach-rockchip/rk3328/rk3328.c index ec3336cb..de17b886 100644 --- a/arch/arm/mach-rockchip/rk3328/rk3328.c +++ b/arch/arm/mach-rockchip/rk3328/rk3328.c @@ -21,8 +21,8 @@ DECLARE_GLOBAL_DATA_PTR; #define FW_DDR_CON_REG 0xFF7C0040
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/rksdmmc@ff520000", - [BROM_BOOTSOURCE_SD] = "/rksdmmc@ff500000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@ff520000", + [BROM_BOOTSOURCE_SD] = "/mmc@ff500000", };
static struct mm_region rk3328_mem_map[] = { diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index 9b7132d4..d0a6107e 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -58,8 +58,8 @@ static struct mm_region rk3368_mem_map[] = { struct mm_region *mem_map = rk3368_mem_map;
#ifdef CONFIG_ARCH_EARLY_INIT_R
Hi Johan,
I tested this series on snow and it seems fine.
I tried it on jerry and got:
DRAM init failed: -19
It also seemed fine on bob although my display is not coming up, for different reasons.
Regards
Simon
Hi Simon,
Thank you for your test report. As I don't always have the hardware, could the board maintainers help me identify u-boot specific property differences with Linux that need to be moved to a dtsi file.
Will send a new serie with fixes.
Johan
After I sync rk3288.dtsi I get this warning. fdt64_t is generated by a script and is not something that I can update the regmap_init_mem_plat function for. Any advice here?
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make chromebook_jerry_defconfig
CC spl/drivers/ram/rockchip/sdram_rk3288.o drivers/ram/rockchip/sdram_rk3288.c: In function ‘conv_of_plat’: drivers/ram/rockchip/sdram_rk3288.c:1032:41: warning: passing argument 2 of ‘regmap_init_mem_plat’ from incompatible pointer type [-Wincompatible-pointer-types] ret = regmap_init_mem_plat(dev, of_plat->reg, ~~~~~~~^~~~~ In file included from drivers/ram/rockchip/sdram_rk3288.c:18: include/regmap.h:391:58: note: expected ‘fdt_val_t *’ {aka ‘unsigned int *’} but argument is of type ‘fdt64_t *’ {aka ‘long long unsigned int *’} int regmap_init_mem_plat(struct udevice *dev, fdt_val_t *reg, int count,
On 3/3/22 04:37, Simon Glass wrote:
Hi Johan,
noc: syscon@ffac0000 { compatible = "rockchip,rk3288-noc", "syscon"; reg = <0x0 0xffac0000 0x0 0x2000>;
Forgot something. Does that help or is there more that needs to be fixed?
==> u-boot,dm-pre-reloc;
TODO: Must change/update dmc/noc reg size when I sync rk3288.dtsi.
In SPL or full U-boot?
rk3288-veyron-chromebook.dtsi:
aliases { i2c20 = &i2c_tunnel; video0 = &vopl; video1 = &vopb; };
Is this video alias something U-boot specific? Fixing U-boot video is beyond my U-boot knowledge.
Regards
Simon
On 3/3/22 15:37, Johan Jonker wrote:
Hi Simon,
Johan
A possible solution with:
config ROCKCHIP_RK3288 select PHYS_64BIT
Adding PHYS_64BIT leads to other warning like this:
drivers/video/rockchip/rk_vop.c: In function ‘rk_vop_probe’: drivers/video/rockchip/rk_vop.c:449:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] priv->regs = (struct rk3288_vop *)dev_read_addr(dev);
Conclusion: a direct rk3288.dtsi sync from Linux with 64bit gives too much work to drivers or DT reg changes.
Will look at a partial upgrade without reg size change.
Johan
Hi Johan,
Regards
Simon
Hi Johan,
On Thu, 3 Mar 2022 at 07:37, Johan Jonker jbx6244@gmail.com wrote:
Hi Simon,
Johan
Hi Johan,
See my other reply for jerry.
I might be able to make my lab available to you somehow.
There is no display in SPL.
Well that's OK, just keep the aliases around and perhaps upstream them? I am not quite sure why we need an ordering for the video, actually.
Johan Jonker
