[U-Boot] [PATCH 0/8 V7] EXYNOS5: Enable I2C support
This patch set enables I2C support for EXYNOS5. This patchset modifies the s3c24x0 I2C driver to use same for EXYNOS5. Multichannel support has been added to the s3c24x0 I2C driver. s3c24x0_i2c struct has been moved to a common place as it can used by different SOC's.
Changes in V2: - Incorporated review comments from Simon Glass. - Aligned the pinmux functionality as per latest comments Changes in V3: - Incorporated review comments from Joonyoung Shim for I2C driver. Changes in V4: - Resolved build error for S3C2410. Changes in V5: - Pinmux setting moved to board file. - Multi Bus I2C offset calculation done based on EXYNOS_I2C_SPACE. - Peripheral id calculation removed from i2c driver. Changes in V6: - Incorporated review comments from Simon Glass. Changes in V7: - Incorporated review comments from Joonyoung Shim.
Rajeshwari Shinde (8): EXYNOS: CLK: Add i2c clock EXYNOS: Add I2C base address. EXYNOS5: define EXYNOS5_I2C_SPACING EXYNOS: PINMUX: Add pinmux support for I2C I2C: Move struct s3c24x0_i2c to a common place. I2C: Modify the I2C driver for EXYNOS5 I2C: Add support for Multi channel CONFIG: SMDK5250: I2C: Enable I2C
arch/arm/cpu/armv7/exynos/clock.c | 33 ++++ arch/arm/cpu/armv7/exynos/pinmux.c | 52 +++++++ arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/cpu.h | 5 + arch/arm/include/asm/arch-exynos/periph.h | 8 + arch/arm/include/asm/arch-s3c24x0/s3c24x0.h | 10 -- board/samsung/smdk5250/smdk5250.c | 30 ++++- drivers/i2c/s3c24x0_i2c.c | 221 +++++++++++++++++--------- drivers/i2c/s3c24x0_i2c.h | 33 ++++ include/configs/smdk5250.h | 10 ++ 10 files changed, 315 insertions(+), 88 deletions(-) create mode 100644 drivers/i2c/s3c24x0_i2c.h
This adds i2c clock information for EXYNOS5.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Doug Anderson dianders@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- changes in V2: - Incorporated comments from Simon Glass which are removed extra braces around (readl(&clk->div_top1)) >> 24 and gave a tab space for return statement. Changes in V3: - None Changes in V4: - None Changes in V5: - None. Changes in V6: - Incorporated review comments from Simon Glass. Changes in V7: - None. arch/arm/cpu/armv7/exynos/clock.c | 33 ++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/clk.h | 1 + 2 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 672598f..de3db8e 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -605,6 +605,29 @@ void exynos4_set_mipi_clk(void) writel(cfg, &clk->div_lcd0); }
+/* + * I2C + * + * exynos5: obtaining the I2C clock + */ +static unsigned long exynos5_get_i2c_clk(void) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + unsigned long aclk_66, aclk_66_pre, sclk; + unsigned int ratio; + + sclk = get_pll_clk(MPLL); + + ratio = (readl(&clk->div_top1)) >> 24; + ratio &= 0x7; + aclk_66_pre = sclk / (ratio + 1); + ratio = readl(&clk->div_top0); + ratio &= 0x7; + aclk_66 = aclk_66_pre / (ratio + 1); + return aclk_66; +} + unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) @@ -621,6 +644,16 @@ unsigned long get_arm_clk(void) return exynos4_get_arm_clk(); }
+unsigned long get_i2c_clk(void) +{ + if (cpu_is_exynos5()) { + return exynos5_get_i2c_clk(); + } else { + debug("I2C clock is not set for this CPU\n"); + return 0; + } +} + unsigned long get_pwm_clk(void) { if (cpu_is_exynos5()) diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index e99339a..5529025 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -31,6 +31,7 @@
unsigned long get_pll_clk(int pllreg); unsigned long get_arm_clk(void); +unsigned long get_i2c_clk(void); unsigned long get_pwm_clk(void); unsigned long get_uart_clk(int dev_index); void set_mmc_clk(int dev_index, unsigned int div);
This patch adds the base address for I2C.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - None Changes in V5: - None Changes in V6: - None Changes in V7: - None. arch/arm/include/asm/arch-exynos/cpu.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 0c341d4..ab46b70 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -49,6 +49,7 @@ #define EXYNOS4_USB_HOST_EHCI_BASE 0x12580000 #define EXYNOS4_USBPHY_BASE 0x125B0000 #define EXYNOS4_UART_BASE 0x13800000 +#define EXYNOS4_I2C_BASE 0x13860000 #define EXYNOS4_ADC_BASE 0x13910000 #define EXYNOS4_PWMTIMER_BASE 0x139D0000 #define EXYNOS4_MODEM_BASE 0x13A00000 @@ -76,6 +77,7 @@ #define EXYNOS5_MMC_BASE 0x12200000 #define EXYNOS5_SROMC_BASE 0x12250000 #define EXYNOS5_UART_BASE 0x12C00000 +#define EXYNOS5_I2C_BASE 0x12C60000 #define EXYNOS5_PWMTIMER_BASE 0x12DD0000 #define EXYNOS5_GPIO_PART2_BASE 0x13400000 #define EXYNOS5_FIMD_BASE 0x14400000 @@ -148,6 +150,7 @@ SAMSUNG_BASE(adc, ADC_BASE) SAMSUNG_BASE(clock, CLOCK_BASE) SAMSUNG_BASE(sysreg, SYSREG_BASE) SAMSUNG_BASE(fimd, FIMD_BASE) +SAMSUNG_BASE(i2c, I2C_BASE) SAMSUNG_BASE(mipi_dsim, MIPI_DSIM_BASE) SAMSUNG_BASE(gpio_part1, GPIO_PART1_BASE) SAMSUNG_BASE(gpio_part2, GPIO_PART2_BASE)
This patch defined EXYNOS5_I2C_SPACING used to calculate I2C channel base address.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V6: - New patch. Changes in V7: - None arch/arm/include/asm/arch-exynos/cpu.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index ab46b70..0e6ea87 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -58,6 +58,8 @@ #define EXYNOS4_GPIO_PART4_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS5 */ +#define EXYNOS5_I2C_SPACING 0x10000 + #define EXYNOS5_GPIO_PART4_BASE 0x03860000 #define EXYNOS5_PRO_ID 0x10000000 #define EXYNOS5_CLOCK_BASE 0x10010000
This patch adds pinmux code for I2C.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - Aligned the pinmux functionality as per the latest comments. Changes in V3: - None Changes in V4: - None Changes in V5: - None Changes in V6: - None Changes in V7: - None. arch/arm/cpu/armv7/exynos/pinmux.c | 52 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/periph.h | 8 ++++ 2 files changed, 60 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 0e91a6c..7776add 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -188,6 +188,48 @@ static void exynos5_sromc_config(int flags) } }
+static void exynos5_i2c_config(int peripheral, int flags) +{ + + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + + switch (peripheral) { + case PERIPH_ID_I2C0: + s5p_gpio_cfg_pin(&gpio1->b3, 0, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->b3, 1, GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C1: + s5p_gpio_cfg_pin(&gpio1->b3, 2, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->b3, 3, GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C2: + s5p_gpio_cfg_pin(&gpio1->a0, 6, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a0, 7, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C3: + s5p_gpio_cfg_pin(&gpio1->a1, 2, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a1, 3, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C4: + s5p_gpio_cfg_pin(&gpio1->a2, 0, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a2, 1, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C5: + s5p_gpio_cfg_pin(&gpio1->a2, 2, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a2, 3, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C6: + s5p_gpio_cfg_pin(&gpio1->b1, 3, GPIO_FUNC(0x4)); + s5p_gpio_cfg_pin(&gpio1->b1, 4, GPIO_FUNC(0x4)); + break; + case PERIPH_ID_I2C7: + s5p_gpio_cfg_pin(&gpio1->b2, 2, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->b2, 3, GPIO_FUNC(0x3)); + break; + } +} + static int exynos5_pinmux_config(int peripheral, int flags) { switch (peripheral) { @@ -205,6 +247,16 @@ static int exynos5_pinmux_config(int peripheral, int flags) case PERIPH_ID_SROMC: exynos5_sromc_config(flags); break; + case PERIPH_ID_I2C0: + case PERIPH_ID_I2C1: + case PERIPH_ID_I2C2: + case PERIPH_ID_I2C3: + case PERIPH_ID_I2C4: + case PERIPH_ID_I2C5: + case PERIPH_ID_I2C6: + case PERIPH_ID_I2C7: + exynos5_i2c_config(peripheral, flags); + break; default: debug("%s: invalid peripheral %d", __func__, peripheral); return -1; diff --git a/arch/arm/include/asm/arch-exynos/periph.h b/arch/arm/include/asm/arch-exynos/periph.h index 5db25aa..b861d7d 100644 --- a/arch/arm/include/asm/arch-exynos/periph.h +++ b/arch/arm/include/asm/arch-exynos/periph.h @@ -30,6 +30,14 @@ * */ enum periph_id { + PERIPH_ID_I2C0, + PERIPH_ID_I2C1, + PERIPH_ID_I2C2, + PERIPH_ID_I2C3, + PERIPH_ID_I2C4, + PERIPH_ID_I2C5, + PERIPH_ID_I2C6, + PERIPH_ID_I2C7, PERIPH_ID_SDMMC0, PERIPH_ID_SDMMC1, PERIPH_ID_SDMMC2,
struct s3c24x0_i2c is being moved to common local header file so that the same can be used by s3c series and exynos series SoCs.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Doug Anderson dianders@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - None Changes in V5: - None Changes in V6: - None Chnages in V7: - None arch/arm/include/asm/arch-s3c24x0/s3c24x0.h | 10 -------- drivers/i2c/s3c24x0_i2c.h | 33 +++++++++++++++++++++++++++ 2 files changed, 33 insertions(+), 10 deletions(-) create mode 100644 drivers/i2c/s3c24x0_i2c.h
diff --git a/arch/arm/include/asm/arch-s3c24x0/s3c24x0.h b/arch/arm/include/asm/arch-s3c24x0/s3c24x0.h index ca978c9..0f75c31 100644 --- a/arch/arm/include/asm/arch-s3c24x0/s3c24x0.h +++ b/arch/arm/include/asm/arch-s3c24x0/s3c24x0.h @@ -343,16 +343,6 @@ struct s3c24x0_watchdog { u32 wtcnt; };
- -/* IIC (see manual chapter 20) */ -struct s3c24x0_i2c { - u32 iiccon; - u32 iicstat; - u32 iicadd; - u32 iicds; -}; - - /* IIS (see manual chapter 21) */ struct s3c24x0_i2s { #ifdef __BIG_ENDIAN diff --git a/drivers/i2c/s3c24x0_i2c.h b/drivers/i2c/s3c24x0_i2c.h new file mode 100644 index 0000000..2dd4b06 --- /dev/null +++ b/drivers/i2c/s3c24x0_i2c.h @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _S3C24X0_I2C_H +#define _S3C24X0_I2C_H + +struct s3c24x0_i2c { + u32 iiccon; + u32 iicstat; + u32 iicadd; + u32 iicds; + u32 iiclc; +}; +#endif /* _S3C24X0_I2C_H */
This patch modifies the S3C I2C driver to suppport EXYNOS5. The cahnges made to driver are as follows: - I2C base address is passed as a parameter to many functions to avoid multiple #ifdef - Channel initialisation is moved to a commom funation as it is required by i2c_init. - Hardcoding for I2CCON_ACKGEN removed. - Replaced printf with debug. - Checkpatch issues resolved. - Pinmux setting will be done in board/samsung/smdk5250/smdk5250.c to avoid repeated setting of gpio lines, as it have multi bus support.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Doug Anderson dianders@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - Removed #define for I2C cahnnels from hearder file except for I2C0. - Incorporated review comments from Simon Glass. Changes in V3: - Incorporated review comments from Joonyoung Shim. - Reduced the number of #ifdef by modifying get_i2c_base function. - Removed duplicate code. Changes in V4: - Resolved build error for s3c2410. Changes in V5: - Pinmux setting will be done in board/samsung/smdk5250/smdk5250.c to avoid repeated setting of gpio lines, as it have multi bus support. - I2C bus offset calulation done based on EXYNOS_I2C_SPACING - Peripharal related code removed. Changes in V6: - g_current_bus made common to all platforms. Changes in V7: - moved get_base_i2c after initialising g_current_bus to 0. - Corrected && to & when waiting for previous transfer to finish in i2c_init. - i2c_ch_init uses the arguments passed in i2c_init. drivers/i2c/s3c24x0_i2c.c | 194 +++++++++++++++++++++++++++------------------ 1 files changed, 117 insertions(+), 77 deletions(-)
diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index ba6f39b..26c0755 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -27,10 +27,15 @@ */
#include <common.h> +#ifdef CONFIG_EXYNOS5 +#include <asm/arch/clk.h> +#include <asm/arch/cpu.h> +#else #include <asm/arch/s3c24x0_cpu.h> - +#endif #include <asm/io.h> #include <i2c.h> +#include "s3c24x0_i2c.h"
#ifdef CONFIG_HARD_I2C
@@ -45,6 +50,7 @@
#define I2CSTAT_BSY 0x20 /* Busy bit */ #define I2CSTAT_NACK 0x01 /* Nack bit */ +#define I2CCON_ACKGEN 0x80 /* Acknowledge generation */ #define I2CCON_IRPND 0x10 /* Interrupt pending bit */ #define I2C_MODE_MT 0xC0 /* Master Transmit Mode */ #define I2C_MODE_MR 0x80 /* Master Receive Mode */ @@ -53,6 +59,10 @@
#define I2C_TIMEOUT 1 /* 1 second */
+ +static unsigned int g_current_bus; /* Stores Current I2C Bus */ + +#ifndef CONFIG_EXYNOS5 static int GetI2CSDA(void) { struct s3c24x0_gpio *gpio = s3c24x0_get_base_gpio(); @@ -77,16 +87,17 @@ static void SetI2CSCL(int x) struct s3c24x0_gpio *gpio = s3c24x0_get_base_gpio();
#ifdef CONFIG_S3C2410 - writel((readl(&gpio->gpedat) & ~0x4000) | (x & 1) << 14, &gpio->gpedat); + writel((readl(&gpio->gpedat) & ~0x4000) | + (x & 1) << 14, &gpio->gpedat); #endif #ifdef CONFIG_S3C2400 writel((readl(&gpio->pgdat) & ~0x0040) | (x & 1) << 6, &gpio->pgdat); #endif } +#endif
-static int WaitForXfer(void) +static int WaitForXfer(struct s3c24x0_i2c *i2c) { - struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c(); int i;
i = I2C_TIMEOUT * 10000; @@ -98,35 +109,75 @@ static int WaitForXfer(void) return (readl(&i2c->iiccon) & I2CCON_IRPND) ? I2C_OK : I2C_NOK_TOUT; }
-static int IsACK(void) +static int IsACK(struct s3c24x0_i2c *i2c) { - struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c(); - return !(readl(&i2c->iicstat) & I2CSTAT_NACK); }
-static void ReadWriteByte(void) +static void ReadWriteByte(struct s3c24x0_i2c *i2c) { - struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c(); - writel(readl(&i2c->iiccon) & ~I2CCON_IRPND, &i2c->iiccon); }
+static struct s3c24x0_i2c *get_base_i2c(void) +{ +#ifdef CONFIG_EXYNOS5 + struct s3c24x0_i2c *i2c = (struct s3c24x0_i2c *)(samsung_get_base_i2c() + + (EXYNOS5_I2C_SPACING + * g_current_bus)); + return i2c; +#else + return s3c24x0_get_base_i2c(); +#endif +} + +static void i2c_ch_init(struct s3c24x0_i2c *i2c, int speed, int slaveadd) +{ + ulong freq, pres = 16, div; +#ifdef CONFIG_EXYNOS5 + freq = get_i2c_clk(); +#else + freq = get_PCLK(); +#endif + /* calculate prescaler and divisor values */ + if ((freq / pres / (16 + 1)) > speed) + /* set prescaler to 512 */ + pres = 512; + + div = 0; + while ((freq / pres / (div + 1)) > speed) + div++; + + /* set prescaler, divisor according to freq, also set ACKGEN, IRQ */ + writel((div & 0x0F) | 0xA0 | ((pres == 512) ? 0x40 : 0), &i2c->iiccon); + + /* init to SLAVE REVEIVE and set slaveaddr */ + writel(0, &i2c->iicstat); + writel(slaveadd, &i2c->iicadd); + /* program Master Transmit (and implicit STOP) */ + writel(I2C_MODE_MT | I2C_TXRX_ENA, &i2c->iicstat); +} + void i2c_init(int speed, int slaveadd) { - struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c(); + struct s3c24x0_i2c *i2c; +#ifndef CONFIG_EXYNOS5 struct s3c24x0_gpio *gpio = s3c24x0_get_base_gpio(); - ulong freq, pres = 16, div; +#endif int i;
- /* wait for some time to give previous transfer a chance to finish */ + /* By default i2c channel 0 is the current bus */ + g_current_bus = 0; + i2c = get_base_i2c();
+ /* wait for some time to give previous transfer a chance to finish */ i = I2C_TIMEOUT * 1000; - while ((readl(&i2c->iicstat) && I2CSTAT_BSY) && (i > 0)) { + while ((readl(&i2c->iicstat) & I2CSTAT_BSY) && (i > 0)) { udelay(1000); i--; }
+#ifndef CONFIG_EXYNOS5 if ((readl(&i2c->iicstat) & I2CSTAT_BSY) || GetI2CSDA() == 0) { #ifdef CONFIG_S3C2410 ulong old_gpecon = readl(&gpio->gpecon); @@ -170,27 +221,8 @@ void i2c_init(int speed, int slaveadd) writel(old_gpecon, &gpio->pgcon); #endif } - - /* calculate prescaler and divisor values */ - freq = get_PCLK(); - if ((freq / pres / (16 + 1)) > speed) - /* set prescaler to 512 */ - pres = 512; - - div = 0; - while ((freq / pres / (div + 1)) > speed) - div++; - - /* set prescaler, divisor according to freq, also set - * ACKGEN, IRQ */ - writel((div & 0x0F) | 0xA0 | ((pres == 512) ? 0x40 : 0), &i2c->iiccon); - - /* init to SLAVE REVEIVE and set slaveaddr */ - writel(0, &i2c->iicstat); - writel(slaveadd, &i2c->iicadd); - /* program Master Transmit (and implicit STOP) */ - writel(I2C_MODE_MT | I2C_TXRX_ENA, &i2c->iicstat); - +#endif /* #ifndef CONFIG_EXYNOS5 */ + i2c_ch_init(i2c, speed, slaveadd); }
/* @@ -200,19 +232,19 @@ void i2c_init(int speed, int slaveadd) * by the char, we could make it larger if needed. If it is * 0 we skip the address write cycle. */ -static -int i2c_transfer(unsigned char cmd_type, - unsigned char chip, - unsigned char addr[], - unsigned char addr_len, - unsigned char data[], unsigned short data_len) +static int i2c_transfer(struct s3c24x0_i2c *i2c, + unsigned char cmd_type, + unsigned char chip, + unsigned char addr[], + unsigned char addr_len, + unsigned char data[], + unsigned short data_len) { - struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c(); int i, result;
if (data == 0 || data_len == 0) { /*Don't support data transfer of no length or to address 0 */ - printf("i2c_transfer: bad call\n"); + debug("i2c_transfer: bad call\n"); return I2C_NOK; }
@@ -226,7 +258,7 @@ int i2c_transfer(unsigned char cmd_type, if (readl(&i2c->iicstat) & I2CSTAT_BSY) return I2C_NOK_TOUT;
- writel(readl(&i2c->iiccon) | 0x80, &i2c->iiccon); + writel(readl(&i2c->iiccon) | I2CCON_ACKGEN, &i2c->iiccon); result = I2C_OK;
switch (cmd_type) { @@ -238,16 +270,16 @@ int i2c_transfer(unsigned char cmd_type, &i2c->iicstat); i = 0; while ((i < addr_len) && (result == I2C_OK)) { - result = WaitForXfer(); + result = WaitForXfer(i2c); writel(addr[i], &i2c->iicds); - ReadWriteByte(); + ReadWriteByte(i2c); i++; } i = 0; while ((i < data_len) && (result == I2C_OK)) { - result = WaitForXfer(); + result = WaitForXfer(i2c); writel(data[i], &i2c->iicds); - ReadWriteByte(); + ReadWriteByte(i2c); i++; } } else { @@ -257,19 +289,19 @@ int i2c_transfer(unsigned char cmd_type, &i2c->iicstat); i = 0; while ((i < data_len) && (result = I2C_OK)) { - result = WaitForXfer(); + result = WaitForXfer(i2c); writel(data[i], &i2c->iicds); - ReadWriteByte(); + ReadWriteByte(i2c); i++; } }
if (result == I2C_OK) - result = WaitForXfer(); + result = WaitForXfer(i2c);
/* send STOP */ writel(I2C_MODE_MR | I2C_TXRX_ENA, &i2c->iicstat); - ReadWriteByte(); + ReadWriteByte(i2c); break;
case I2C_READ: @@ -279,13 +311,13 @@ int i2c_transfer(unsigned char cmd_type, /* send START */ writel(readl(&i2c->iicstat) | I2C_START_STOP, &i2c->iicstat); - result = WaitForXfer(); - if (IsACK()) { + result = WaitForXfer(i2c); + if (IsACK(i2c)) { i = 0; while ((i < addr_len) && (result == I2C_OK)) { writel(addr[i], &i2c->iicds); - ReadWriteByte(); - result = WaitForXfer(); + ReadWriteByte(i2c); + result = WaitForXfer(i2c); i++; }
@@ -293,16 +325,17 @@ int i2c_transfer(unsigned char cmd_type, /* resend START */ writel(I2C_MODE_MR | I2C_TXRX_ENA | I2C_START_STOP, &i2c->iicstat); - ReadWriteByte(); - result = WaitForXfer(); + ReadWriteByte(i2c); + result = WaitForXfer(i2c); i = 0; while ((i < data_len) && (result == I2C_OK)) { /* disable ACK for final READ */ if (i == data_len - 1) writel(readl(&i2c->iiccon) - & ~0x80, &i2c->iiccon); - ReadWriteByte(); - result = WaitForXfer(); + & ~I2CCON_ACKGEN, + &i2c->iiccon); + ReadWriteByte(i2c); + result = WaitForXfer(i2c); data[i] = readl(&i2c->iicds); i++; } @@ -316,17 +349,18 @@ int i2c_transfer(unsigned char cmd_type, /* send START */ writel(readl(&i2c->iicstat) | I2C_START_STOP, &i2c->iicstat); - result = WaitForXfer(); + result = WaitForXfer(i2c);
- if (IsACK()) { + if (IsACK(i2c)) { i = 0; while ((i < data_len) && (result == I2C_OK)) { /* disable ACK for final READ */ if (i == data_len - 1) writel(readl(&i2c->iiccon) & - ~0x80, &i2c->iiccon); - ReadWriteByte(); - result = WaitForXfer(); + ~I2CCON_ACKGEN, + &i2c->iiccon); + ReadWriteByte(i2c); + result = WaitForXfer(i2c); data[i] = readl(&i2c->iicds); i++; } @@ -337,22 +371,24 @@ int i2c_transfer(unsigned char cmd_type,
default: - printf("i2c_transfer: bad call\n"); + debug("i2c_transfer: bad call\n"); result = I2C_NOK; break; }
- return (result); + return result; }
int i2c_probe(uchar chip) { + struct s3c24x0_i2c *i2c; uchar buf[1];
+ i2c = get_base_i2c(); buf[0] = 0;
/* @@ -360,16 +396,17 @@ int i2c_probe(uchar chip) * address was <ACK>ed (i.e. there was a chip at that address which * drove the data line low). */ - return i2c_transfer(I2C_READ, chip << 1, 0, 0, buf, 1) != I2C_OK; + return i2c_transfer(i2c, I2C_READ, chip << 1, 0, 0, buf, 1) != I2C_OK; }
int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) { + struct s3c24x0_i2c *i2c; uchar xaddr[4]; int ret;
if (alen > 4) { - printf("I2C read: addr len %d not supported\n", alen); + debug("I2C read: addr len %d not supported\n", alen); return 1; }
@@ -396,10 +433,11 @@ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) chip |= ((addr >> (alen * 8)) & CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW); #endif - if ((ret = - i2c_transfer(I2C_READ, chip << 1, &xaddr[4 - alen], alen, - buffer, len)) != 0) { - printf("I2c read: failed %d\n", ret); + i2c = get_base_i2c(); + ret = i2c_transfer(i2c, I2C_READ, chip << 1, &xaddr[4 - alen], alen, + buffer, len); + if (ret != 0) { + debug("I2c read: failed %d\n", ret); return 1; } return 0; @@ -407,10 +445,11 @@ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len)
int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) { + struct s3c24x0_i2c *i2c; uchar xaddr[4];
if (alen > 4) { - printf("I2C write: addr len %d not supported\n", alen); + debug("I2C write: addr len %d not supported\n", alen); return 1; }
@@ -436,8 +475,9 @@ int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) chip |= ((addr >> (alen * 8)) & CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW); #endif + i2c = get_base_i2c(); return (i2c_transfer - (I2C_WRITE, chip << 1, &xaddr[4 - alen], alen, buffer, + (i2c, I2C_WRITE, chip << 1, &xaddr[4 - alen], alen, buffer, len) != 0); } #endif /* CONFIG_HARD_I2C */
This adds multiple i2c channel support for I2C.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - None Changes in V5: - Pinmux setting of all bus done during board init. Changes in V6: - None Changes in V7: - None drivers/i2c/s3c24x0_i2c.c | 27 +++++++++++++++++++++++++++ 1 files changed, 27 insertions(+), 0 deletions(-)
diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index 26c0755..9bc4c7f 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -158,6 +158,33 @@ static void i2c_ch_init(struct s3c24x0_i2c *i2c, int speed, int slaveadd) writel(I2C_MODE_MT | I2C_TXRX_ENA, &i2c->iicstat); }
+/* + * MULTI BUS I2C support + */ + +#ifdef CONFIG_I2C_MULTI_BUS +int i2c_set_bus_num(unsigned int bus) +{ + struct s3c24x0_i2c *i2c; + + if ((bus < 0) || (bus >= CONFIG_MAX_I2C_NUM)) { + debug("Bad bus: %d\n", bus); + return -1; + } + + g_current_bus = bus; + i2c = get_base_i2c(); + i2c_ch_init(i2c, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + return 0; +} + +unsigned int i2c_get_bus_num(void) +{ + return g_current_bus; +} +#endif + void i2c_init(int speed, int slaveadd) { struct s3c24x0_i2c *i2c;
This enables I2C support on smdk5250. Pinmux setting moved to board file to avoid repeated setting of gpio lines.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Doug Anderson dianders@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - None Changes in V5: - Pinmux setting of gpio lines moved to board_early_init_f. Changes in V6: - EXYNOS_I2C_SPACING moved to cpu.h - board_i2c_init compiled only when CONFIG_DRIVER_S3C24X0_I2C is defined. Changes in V7: - board_i2c_init compiled only when CONFIG_SYS_I2C_INIT_BOARD is defined. board/samsung/smdk5250/smdk5250.c | 30 +++++++++++++++++++++++++++++- include/configs/smdk5250.h | 10 ++++++++++ 2 files changed, 39 insertions(+), 1 deletions(-)
diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index b593325..a5816e4 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -22,6 +22,7 @@
#include <common.h> #include <asm/io.h> +#include <i2c.h> #include <netdev.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> @@ -172,9 +173,36 @@ static int board_uart_init(void) return 0; }
+#ifdef CONFIG_SYS_I2C_INIT_BOARD +static int board_i2c_init(void) +{ + int i, err; + + for (i = 0; i < CONFIG_MAX_I2C_NUM; i++) { + err = exynos_pinmux_config((PERIPH_ID_I2C0 + i), + PINMUX_FLAG_NONE); + if (err) { + debug("I2C%d not configured\n", (PERIPH_ID_I2C0 + i)); + return err; + } + } + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + return 0; +} +#endif + #ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { - return board_uart_init(); + int err; + err = board_uart_init(); + if (err) { + debug("UART init failed\n"); + return err; + } +#ifdef CONFIG_SYS_I2C_INIT_BOARD + err = board_i2c_init(); +#endif + return err; } #endif diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index c0eaaf8..27dab76 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -198,6 +198,16 @@
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
+/* I2C */ +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_HARD_I2C +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 Kbps */ +#define CONFIG_DRIVER_S3C24X0_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_MAX_I2C_NUM 8 +#define CONFIG_SYS_I2C_SLAVE 0x0 + /* Ethernet Controllor Driver */ #ifdef CONFIG_CMD_NET #define CONFIG_SMC911X
On Tue, Jul 24, 2012 at 8:23 AM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
This series looks good to me (still).
-- 1.7.4.4
Rajeshwari Shinde
