[U-Boot] [PATCH 1/1] DaVinci: fix ddr2 vtp i/o calibration
Previously, only the low 5 bits (NCH) were being transfered from DDRVTPR to DDRVTPIOCR, the bits 5-9 where zeroed.
VTP_RECAL should be bit 15, not 18.
The only mainline board affected by this change is davinci_sonata. The other Davinci boards define CONFIG_SKIP_LOWLEVEL_INIT.
However, if the program that loads u-boot on these boards copied the code from u-boot, they will need fixed as well.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com
Please get tested by acks before applying, where tested by means an overnight memory test.
Thanks Troy --- arch/arm/cpu/arm926ejs/davinci/lowlevel_init.S | 7 +++---- 1 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/lowlevel_init.S b/arch/arm/cpu/arm926ejs/davinci/lowlevel_init.S index 5b39484..0e45426 100644 --- a/arch/arm/cpu/arm926ejs/davinci/lowlevel_init.S +++ b/arch/arm/cpu/arm926ejs/davinci/lowlevel_init.S @@ -523,9 +523,8 @@ VTPLock:
ldr r6, DDRVTPR ldr r7, [r6] - and r7, r7, $0x1f - and r8, r7, $0x3e0 - orr r8, r7, r8 + mov r8, r7, LSL #32-10 + mov r8, r8, LSR #32-10 /* grab low 10 bits */ ldr r7, VTP_RECAL orr r8, r7, r8 ldr r7, VTP_EN @@ -644,7 +643,7 @@ VTP_LOCK_COUNT: VTP_MASK: .word 0xffffdfff VTP_RECAL: - .word 0x40000 + .word 0x08000 VTP_EN: .word 0x02000 CFGTEST:
Troy Kisky
