[PATCH] arm: move _end to linker symbols
commit 6e2228fb052b ("Merge patch series "Clean up arm linker scripts") was cleaning up linker scripts for armv7 and v8 but was leaving _end and __secure_stack_start/end.
commit d0b5d9da5de2 ("arm: make _end compiler-generated") was moving _end to be compiler generated. _end is defined as c variable in its own section to force the compiler emit relative a reference. However, defining those in the linker script will do the same thing since [0].
So let's remove the special sections from the linker scripts, the variable definitions from sections.c and define them as a symbols. It's worth noting that _image_binary_end symbol is now redundant and can be removed in the future.
- SPL
The .end section has been removed from the new binary [ 5] .end PROGBITS 00000000fffdf488 000000000002f488 0 0000000000000000 0000000000000000 0 1 [0000000000000003]: WRITE, ALLOC
$~ bloat-o-meter kria_old/spl/u-boot-spl krina_new/spl/u-boot-spl add/remove: 0/0 grow/shrink: 0/0 up/down: 0/0 (0) Function old new delta Total: Before=115980, After=115980, chg +0.00%
$~ readelf -sW kria_old/u-boot kria_new/u-boot | grep -w _end 12047: 000000000813a0f0 0 OBJECT GLOBAL DEFAULT 11 _end 12047: 000000000813a118 0 NOTYPE GLOBAL DEFAULT 11 _end
$~ readelf -sW kria_old/spl/u-boot-spl kria_new/spl/u-boot-spl | grep -w _end 1605: 00000000fffdf488 0 OBJECT GLOBAL DEFAULT 5 _end 1603: 00000000fffdf498 0 NOTYPE GLOBAL DEFAULT 4 _end
$~ readelf -sW old/u-boot new/u-boot | grep -w _end 8847: 0000000000103710 0 OBJECT GLOBAL DEFAULT 11 _end 8847: 0000000000103738 0 NOTYPE GLOBAL DEFAULT 11 _end
$~ readelf -sW old_v7/u-boot new_v7/u-boot | grep -w _end 10638: 000da824 0 OBJECT GLOBAL DEFAULT 10 _end 10637: 000da84c 0 NOTYPE GLOBAL DEFAULT 10 _end
- For both QEMU instances $~ bloat-o-meter old/u-boot new/u-boot add/remove: 0/0 grow/shrink: 1/0 up/down: 20/0 (20) Function old new delta version_string 50 70 +20 Total: Before=656915, After=656935, chg +0.00%
[0] binutils commit 6b3b0ab89663 ("Make linker assigned symbol dynamic only for shared object")
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- arch/arm/cpu/arm1136/u-boot-spl.lds | 6 +----- arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds | 6 +----- arch/arm/cpu/armv8/u-boot-spl.lds | 7 +------ arch/arm/cpu/u-boot-spl.lds | 6 +----- arch/arm/cpu/u-boot.lds | 6 +----- arch/arm/lib/sections.c | 1 - arch/arm/mach-aspeed/ast2600/u-boot-spl.lds | 6 +----- arch/arm/mach-at91/arm926ejs/u-boot-spl.lds | 7 +------ arch/arm/mach-at91/armv7/u-boot-spl.lds | 7 +------ arch/arm/mach-omap2/u-boot-spl.lds | 7 +------ arch/arm/mach-rockchip/u-boot-tpl-v8.lds | 7 +------ arch/arm/mach-zynq/u-boot.lds | 6 +----- board/davinci/da8xxevm/u-boot-spl-da850evm.lds | 7 +------ board/samsung/common/exynos-uboot-spl.lds | 6 +----- 14 files changed, 13 insertions(+), 72 deletions(-)
diff --git a/arch/arm/cpu/arm1136/u-boot-spl.lds b/arch/arm/cpu/arm1136/u-boot-spl.lds index f83988fd7e6a..b7af29183a97 100644 --- a/arch/arm/cpu/arm1136/u-boot-spl.lds +++ b/arch/arm/cpu/arm1136/u-boot-spl.lds @@ -33,11 +33,7 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram . = ALIGN(4); __image_copy_end = .; - - .end : - { - *(.__end) - } + _end = .;
.bss : { diff --git a/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds index 7e20448f8108..7c6309246f8b 100644 --- a/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds +++ b/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds @@ -49,11 +49,7 @@ SECTIONS __bss_end = .; }
- .end : - { - *(.__end) - } - + _end = .; _image_binary_end = .;
.dynsym _image_binary_end : { *(.dynsym) } diff --git a/arch/arm/cpu/armv8/u-boot-spl.lds b/arch/arm/cpu/armv8/u-boot-spl.lds index ef8af67e11c3..215cedd69a8c 100644 --- a/arch/arm/cpu/armv8/u-boot-spl.lds +++ b/arch/arm/cpu/armv8/u-boot-spl.lds @@ -53,12 +53,7 @@ SECTIONS
. = ALIGN(8); __image_copy_end = .; - - .end : { - . = ALIGN(8); - *(.__end) - } >.sram - + _end = .; _image_binary_end = .;
.bss : { diff --git a/arch/arm/cpu/u-boot-spl.lds b/arch/arm/cpu/u-boot-spl.lds index 9ed62395a9c5..eee463a1b1c6 100644 --- a/arch/arm/cpu/u-boot-spl.lds +++ b/arch/arm/cpu/u-boot-spl.lds @@ -53,12 +53,8 @@ SECTIONS __rel_dyn_end = .; }
- .end : - { - *(.__end) - } - _image_binary_end = .; + _end = .;
.bss __rel_dyn_start (OVERLAY) : { __bss_start = .; diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 707b19795f08..2f50087f57a9 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -166,11 +166,7 @@ SECTIONS __rel_dyn_end = .; }
/* diff --git a/arch/arm/lib/sections.c b/arch/arm/lib/sections.c index db5463b2bbbc..07efabaa7dc8 100644 --- a/arch/arm/lib/sections.c +++ b/arch/arm/lib/sections.c @@ -23,4 +23,3 @@ char __secure_start[0] __section(".__secure_start"); char __secure_end[0] __section(".__secure_end"); char __secure_stack_start[0] __section(".__secure_stack_start"); char __secure_stack_end[0] __section(".__secure_stack_end"); -char _end[0] __section(".__end"); diff --git a/arch/arm/mach-aspeed/ast2600/u-boot-spl.lds b/arch/arm/mach-aspeed/ast2600/u-boot-spl.lds index ada6570d9712..9502a7384b53 100644 --- a/arch/arm/mach-aspeed/ast2600/u-boot-spl.lds +++ b/arch/arm/mach-aspeed/ast2600/u-boot-spl.lds @@ -61,11 +61,7 @@ SECTIONS __rel_dyn_end = .; } > .nor
- .end : - { - *(.__end) - } > .nor - + _end = .; _image_binary_end = .;
.bss : { diff --git a/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds b/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds index 1a8bf94dee0c..09cf838cf96e 100644 --- a/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds +++ b/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds @@ -33,12 +33,7 @@ SECTIONS
. = ALIGN(4); __image_copy_end = .; - - .end : - { - *(.__end) - } >.sram - + _end = .; _image_binary_end = .;
.bss : diff --git a/arch/arm/mach-at91/armv7/u-boot-spl.lds b/arch/arm/mach-at91/armv7/u-boot-spl.lds index 6ca725fc4ce0..460a91d93ec4 100644 --- a/arch/arm/mach-at91/armv7/u-boot-spl.lds +++ b/arch/arm/mach-at91/armv7/u-boot-spl.lds @@ -40,12 +40,7 @@ SECTIONS
.bss : diff --git a/arch/arm/mach-omap2/u-boot-spl.lds b/arch/arm/mach-omap2/u-boot-spl.lds index 1d6e5d45b468..3bb759d8a1c8 100644 --- a/arch/arm/mach-omap2/u-boot-spl.lds +++ b/arch/arm/mach-omap2/u-boot-spl.lds @@ -39,12 +39,7 @@ SECTIONS
. = ALIGN(4); __image_copy_end = .; - - .end : - { - *(.__end) - } - + _end = .; _image_binary_end = .;
.bss : diff --git a/arch/arm/mach-rockchip/u-boot-tpl-v8.lds b/arch/arm/mach-rockchip/u-boot-tpl-v8.lds index ad32654085b3..958a1b70aefe 100644 --- a/arch/arm/mach-rockchip/u-boot-tpl-v8.lds +++ b/arch/arm/mach-rockchip/u-boot-tpl-v8.lds @@ -46,12 +46,7 @@ SECTIONS
. = ALIGN(8); __image_copy_end = .; - - .end : { - . = ALIGN(8); - *(.__end) - } - + _end = .; _image_binary_end = .;
.bss ALIGN(8) : { diff --git a/arch/arm/mach-zynq/u-boot.lds b/arch/arm/mach-zynq/u-boot.lds index 3e0c96c50556..f52523edf490 100644 --- a/arch/arm/mach-zynq/u-boot.lds +++ b/arch/arm/mach-zynq/u-boot.lds @@ -68,11 +68,7 @@ SECTIONS __rel_dyn_end = .; }
/* diff --git a/board/davinci/da8xxevm/u-boot-spl-da850evm.lds b/board/davinci/da8xxevm/u-boot-spl-da850evm.lds index 7e0f09f3b5b1..56d6f4f114b9 100644 --- a/board/davinci/da8xxevm/u-boot-spl-da850evm.lds +++ b/board/davinci/da8xxevm/u-boot-spl-da850evm.lds @@ -46,12 +46,7 @@ SECTIONS } >.sram
.bss : diff --git a/board/samsung/common/exynos-uboot-spl.lds b/board/samsung/common/exynos-uboot-spl.lds index 73cd97a1b1de..9d3b57e98dbb 100644 --- a/board/samsung/common/exynos-uboot-spl.lds +++ b/board/samsung/common/exynos-uboot-spl.lds @@ -41,11 +41,7 @@ SECTIONS . = ALIGN(4);
__image_copy_end = .; - - .end : - { - *(.__end) - } >.sram + _end = .;
.bss : {
- SPL
- .end :
*(.__end)
_end = .;
.bss : {
- .end :
*(.__end)
- .end : {
. = ALIGN(8);
*(.__end)
- } >.sram
.bss : {
- .end :
*(.__end)
_end = .;
- .end :
*(.__end)
- .end :
*(.__end)
- } > .nor
.bss : {
- .end :
*(.__end)
- } >.sram
.bss :
- .end :
*(.__end)
- } >.sram
- _end = .;
Does this have any kind of consequence in terms of checking the offset of .end vs the SRAM size ? (.sram)
.bss :
Hi Eugen
On Tue, 28 May 2024 at 09:40, Eugen Hristev eugen.hristev@collabora.com wrote:
- SPL
.end :
*(.__end)
_end = .; .bss : {
.end :
*(.__end)
_end = .; _image_binary_end = .; .dynsym _image_binary_end : { *(.dynsym) }
.end : {
. = ALIGN(8);
*(.__end)
} >.sram
_end = .; _image_binary_end = .; .bss : {
.end :
*(.__end)
_end = .; .bss __rel_dyn_start (OVERLAY) : { __bss_start = .;
.end :
*(.__end)
_end = .; _image_binary_end = .; /*
.end :
*(.__end)
} > .nor
.end :
*(.__end)
} >.sram
.end :
*(.__end)
} >.sram
_end = .;
The value of _end does grow by 16b on the SPL for the kria boards, but it doesn't seem to cause issues. I can only find a single assert on those checks in arch/microblaze/cpu/u-boot-spl.lds. Anything else you spotted?
Keeping in mind that the code used to be like that before that linker bug -- defining a linker symbol instead of a section, I don't think anything will blow up
/Ilias
*(.__end)
} >.sram
_end = .;
Also if you compile with -O2 instead of -Os the final binary and the _end memory address remain unchanged. So I assume the changes in the _end offset is due to compiler optimizations since the .end section is removed
Cheers /Ilias
/Ilias
Eugen Hristev
Ilias Apalodimas
