[U-Boot] [PATCH 1/4] imx: add module fuse support
There are different parts from one SoC. Take i.MX6ULL for example, some part might not have ENET, some might have; some might not have USB, some might have. The information could be got from OCOTP, to make one image support the different parts, we need runtime disable linux kernel dts node and uboot driver probe if the corresponding module not exists in the part.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/mach-imx/module_fuse.h | 127 +++++++++++ arch/arm/include/asm/mach-imx/sys_proto.h | 1 + arch/arm/mach-imx/Kconfig | 7 + arch/arm/mach-imx/mx6/Makefile | 1 + arch/arm/mach-imx/mx6/module_fuse.c | 322 ++++++++++++++++++++++++++++ 5 files changed, 458 insertions(+) create mode 100644 arch/arm/include/asm/mach-imx/module_fuse.h create mode 100644 arch/arm/mach-imx/mx6/module_fuse.c
diff --git a/arch/arm/include/asm/mach-imx/module_fuse.h b/arch/arm/include/asm/mach-imx/module_fuse.h new file mode 100644 index 0000000000..6b93f0402e --- /dev/null +++ b/arch/arm/include/asm/mach-imx/module_fuse.h @@ -0,0 +1,127 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __MODULE_FUSE_H__ +#define __MODULE_FUSE_H__ + +enum fuse_module_type { + MODULE_TSC, + MODULE_ADC1, + MODULE_ADC2, + MODULE_SIM1, + MODULE_SIM2, + MODULE_FLEXCAN1, + MODULE_FLEXCAN2, + MODULE_SPDIF, + MODULE_EIM, + MODULE_SD1, + MODULE_SD2, + MODULE_SD3, + MODULE_SD4, + MODULE_QSPI1, + MODULE_QSPI2, + MODULE_GPMI, + MODULE_APBHDMA, + MODULE_LCDIF, + MODULE_PXP, + MODULE_CSI, + MODULE_ENET1, + MODULE_ENET2, + MODULE_CAAM, + MODULE_USB_OTG1, + MODULE_USB_OTG2, + MODULE_SAI2, + MODULE_SAI3, + MODULE_BEE, + MODULE_UART1, + MODULE_UART2, + MODULE_UART3, + MODULE_UART4, + MODULE_UART5, + MODULE_UART6, + MODULE_UART7, + MODULE_UART8, + MODULE_PWM5, + MODULE_PWM6, + MODULE_PWM7, + MODULE_PWM8, + MODULE_ECSPI1, + MODULE_ECSPI2, + MODULE_ECSPI3, + MODULE_ECSPI4, + MODULE_ECSPI5, + MODULE_I2C1, + MODULE_I2C2, + MODULE_I2C3, + MODULE_I2C4, + MODULE_GPT1, + MODULE_GPT2, + MODULE_EPIT1, + MODULE_EPIT2, + MODULE_EPDC, + MODULE_ESAI, + MODULE_DCP, + MODULE_DCP_CRYPTO, +}; + +struct fuse_entry_desc { + enum fuse_module_type module; + const char *node_path; + u32 fuse_word_offset; + u32 fuse_bit_offset; + u32 status; +}; + +#if !IS_ENABLED(CONFIG_IMX_MODULE_FUSE) +static inline u32 check_module_fused(enum fuse_module_type module) +{ + return 0; +}; + +static inline u32 esdhc_fused(u32 base_addr) +{ + return 0; +}; + +static inline u32 ecspi_fused(u32 base_addr) +{ + return 0; +}; + +static inline u32 uart_fused(u32 base_addr) +{ + return 0; +}; + +static inline u32 usb_fused(u32 base_addr) +{ + return 0; +}; + +static inline u32 qspi_fused(u32 base_addr) +{ + return 0; +}; + +static inline u32 i2c_fused(u32 base_addr) +{ + return 0; +}; + +static inline u32 enet_fused(u32 base_addr) +{ + return 0; +}; +#else +u32 check_module_fused(enum fuse_module_type module); +u32 esdhc_fused(u32 base_addr); +u32 ecspi_fused(u32 base_addr); +u32 uart_fused(u32 base_addr); +u32 usb_fused(u32 base_addr); +u32 qspi_fused(u32 base_addr); +u32 i2c_fused(u32 base_addr); +u32 enet_fused(u32 base_addr); +#endif +#endif /* __MODULE_FUSE_H__ */ diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index 79cb4e6dc9..14b016ee99 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -9,6 +9,7 @@
#include <asm/io.h> #include <asm/mach-imx/regs-common.h> +#include <asm/mach-imx/module_fuse.h> #include <common.h> #include "../arch-imx/cpu.h"
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index d3942f6b3f..b8625962a6 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -27,6 +27,13 @@ config IMX_BOOTAUX help bootaux [addr] to boot auxiliary core.
+config IMX_MODULE_FUSE + bool "i.MX Module Fuse" + depends on ARCH_MX6 + help + i.MX module fuse to runtime disable some driver, including + Linux OS device node. + config USE_IMXIMG_PLUGIN bool "Use imximage plugin code" depends on ARCH_MX7 || ARCH_MX6 || ARCH_MX7ULP diff --git a/arch/arm/mach-imx/mx6/Makefile b/arch/arm/mach-imx/mx6/Makefile index 81e2913d14..7ea8f91e4f 100644 --- a/arch/arm/mach-imx/mx6/Makefile +++ b/arch/arm/mach-imx/mx6/Makefile @@ -6,6 +6,7 @@ # (C) Copyright 2011 Freescale Semiconductor, Inc.
obj-y := soc.o clock.o +obj-$(CONFIG_IMX_MODULE_FUSE) += module_fuse.o obj-$(CONFIG_SPL_BUILD) += ddr.o obj-$(CONFIG_MP) += mp.o obj-$(CONFIG_MX6UL_LITESOM) += litesom.o diff --git a/arch/arm/mach-imx/mx6/module_fuse.c b/arch/arm/mach-imx/mx6/module_fuse.c new file mode 100644 index 0000000000..417264b15c --- /dev/null +++ b/arch/arm/mach-imx/mx6/module_fuse.c @@ -0,0 +1,322 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <common.h> +#include <fdt_support.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/imx-regs.h> +#include <asm/mach-imx/module_fuse.h> +#include <linux/errno.h> + +static struct fuse_entry_desc mx6_fuse_descs[] = { +#if defined(CONFIG_MX6ULL) + {MODULE_TSC, "/soc/aips-bus@2000000/tsc@2040000", 0x430, 22}, + {MODULE_ADC2, "/soc/aips-bus@2100000/adc@219c000", 0x430, 23}, + {MODULE_EPDC, "/soc/aips-bus@2200000/epdc@228c000", 0x430, 24}, + {MODULE_ESAI, "/soc/aips-bus@2000000/spba-bus@2000000/esai@2024000", 0x430, 25}, + {MODULE_FLEXCAN1, "/soc/aips-bus@2000000/can@2090000", 0x430, 26}, + {MODULE_FLEXCAN2, "/soc/aips-bus@2000000/can@2094000", 0x430, 27}, + {MODULE_SPDIF, "/soc/aips-bus@2000000/spba-bus@2000000/spdif@2004000", 0x440, 2}, + {MODULE_EIM, "/soc/aips-bus@2100000/weim@21b8000", 0x440, 3}, + {MODULE_SD1, "/soc/aips-bus@2100000/usdhc@2190000", 0x440, 4}, + {MODULE_SD2, "/soc/aips-bus@2100000/usdhc@2194000", 0x440, 5}, + {MODULE_QSPI1, "/soc/aips-bus@2100000/qspi@21e0000", 0x440, 6}, + {MODULE_GPMI, "/soc/gpmi-nand@1806000", 0x440, 7}, + {MODULE_APBHDMA, "/soc/dma-apbh@1804000", 0x440, 7}, + {MODULE_LCDIF, "/soc/aips-bus@2100000/lcdif@21c8000", 0x440, 8}, + {MODULE_PXP, "/soc/aips-bus@2100000/pxp@21cc000", 0x440, 9}, + {MODULE_CSI, "/soc/aips-bus@2100000/csi@21c4000", 0x440, 10}, + {MODULE_ADC1, "/soc/aips-bus@2100000/adc@2198000", 0x440, 11}, + {MODULE_ENET1, "/soc/aips-bus@2100000/ethernet@2188000", 0x440, 12}, + {MODULE_ENET2, "/soc/aips-bus@2000000/ethernet@20b4000", 0x440, 13}, + {MODULE_DCP, "/soc/aips-bus@2200000/dcp@2280000", 0x440, 14}, + {MODULE_USB_OTG2, "/soc/aips-bus@2100000/usb@2184200", 0x440, 15}, + {MODULE_SAI2, "/soc/aips-bus@2000000/spba-bus@2000000/sai@202c000", 0x440, 24}, + {MODULE_SAI3, "/soc/aips-bus@2000000/spba-bus@2000000/sai@2030000", 0x440, 24}, + {MODULE_DCP_CRYPTO, "/soc/aips-bus@2200000/dcp@2280000", 0x440, 25}, + {MODULE_UART5, "/soc/aips-bus@2100000/serial@21f4000", 0x440, 26}, + {MODULE_UART6, "/soc/aips-bus@2100000/serial@21fc000", 0x440, 26}, + {MODULE_UART7, "/soc/aips-bus@2000000/spba-bus@2000000/serial@2018000", 0x440, 26}, + {MODULE_UART8, "/soc/aips-bus@2200000/serial@2288000", 0x440, 26}, + {MODULE_PWM5, "/soc/aips-bus@2000000/pwm@20f0000", 0x440, 27}, + {MODULE_PWM6, "/soc/aips-bus@2000000/pwm@20f4000", 0x440, 27}, + {MODULE_PWM7, "/soc/aips-bus@2000000/pwm@20f8000", 0x440, 27}, + {MODULE_PWM8, "/soc/aips-bus@2000000/pwm@20fc000", 0x440, 27}, + {MODULE_ECSPI3, "/soc/aips-bus@2000000/spba-bus@2000000/ecspi@2010000", 0x440, 28}, + {MODULE_ECSPI4, "/soc/aips-bus@2000000/spba-bus@2000000/ecspi@2014000", 0x440, 28}, + {MODULE_I2C3, "/soc/aips-bus@2100000/i2c@21a8000", 0x440, 29}, + {MODULE_I2C4, "/soc/aips-bus@2100000/i2c@21f8000", 0x440, 29}, + {MODULE_GPT2, "/soc/aips-bus@2000000/gpt@20e8000", 0x440, 30}, + {MODULE_EPIT2, "/soc/aips-bus@2000000/epit@20d4000", 0x440, 31}, + /* Paths for older imx tree: */ + {MODULE_TSC, "/soc/aips-bus@02000000/tsc@02040000", 0x430, 22}, + {MODULE_ADC2, "/soc/aips-bus@02100000/adc@0219c000", 0x430, 23}, + {MODULE_EPDC, "/soc/aips-bus@02200000/epdc@0228c000", 0x430, 24}, + {MODULE_ESAI, "/soc/aips-bus@02000000/spba-bus@02000000/esai@02024000", 0x430, 25}, + {MODULE_FLEXCAN1, "/soc/aips-bus@02000000/can@02090000", 0x430, 26}, + {MODULE_FLEXCAN2, "/soc/aips-bus@02000000/can@02094000", 0x430, 27}, + {MODULE_SPDIF, "/soc/aips-bus@02000000/spba-bus@02000000/spdif@02004000", 0x440, 2}, + {MODULE_EIM, "/soc/aips-bus@02100000/weim@021b8000", 0x440, 3}, + {MODULE_SD1, "/soc/aips-bus@02100000/usdhc@02190000", 0x440, 4}, + {MODULE_SD2, "/soc/aips-bus@02100000/usdhc@02194000", 0x440, 5}, + {MODULE_QSPI1, "/soc/aips-bus@02100000/qspi@021e0000", 0x440, 6}, + {MODULE_GPMI, "/soc/gpmi-nand@01806000", 0x440, 7}, + {MODULE_APBHDMA, "/soc/dma-apbh@01804000", 0x440, 7}, + {MODULE_LCDIF, "/soc/aips-bus@02100000/lcdif@021c8000", 0x440, 8}, + {MODULE_PXP, "/soc/aips-bus@02100000/pxp@021cc000", 0x440, 9}, + {MODULE_CSI, "/soc/aips-bus@02100000/csi@021c4000", 0x440, 10}, + {MODULE_ADC1, "/soc/aips-bus@02100000/adc@02198000", 0x440, 11}, + {MODULE_ENET1, "/soc/aips-bus@02100000/ethernet@02188000", 0x440, 12}, + {MODULE_ENET2, "/soc/aips-bus@02000000/ethernet@020b4000", 0x440, 13}, + {MODULE_DCP, "/soc/aips-bus@02200000/dcp@02280000", 0x440, 14}, + {MODULE_USB_OTG2, "/soc/aips-bus@02100000/usb@02184200", 0x440, 15}, + {MODULE_SAI2, "/soc/aips-bus@02000000/spba-bus@02000000/sai@0202c000", 0x440, 24}, + {MODULE_SAI3, "/soc/aips-bus@02000000/spba-bus@02000000/sai@02030000", 0x440, 24}, + {MODULE_DCP_CRYPTO, "/soc/aips-bus@02200000/dcp@02280000", 0x440, 25}, + {MODULE_UART5, "/soc/aips-bus@02100000/serial@021f4000", 0x440, 26}, + {MODULE_UART6, "/soc/aips-bus@02100000/serial@021fc000", 0x440, 26}, + {MODULE_UART7, "/soc/aips-bus@02000000/spba-bus@02000000/serial@02018000", 0x440, 26}, + {MODULE_UART8, "/soc/aips-bus@02200000/serial@02288000", 0x440, 26}, + {MODULE_PWM5, "/soc/aips-bus@02000000/pwm@020f0000", 0x440, 27}, + {MODULE_PWM6, "/soc/aips-bus@02000000/pwm@020f4000", 0x440, 27}, + {MODULE_PWM7, "/soc/aips-bus@02000000/pwm@020f8000", 0x440, 27}, + {MODULE_PWM8, "/soc/aips-bus@02000000/pwm@020fc000", 0x440, 27}, + {MODULE_ECSPI3, "/soc/aips-bus@02000000/spba-bus@02000000/ecspi@02010000", 0x440, 28}, + {MODULE_ECSPI4, "/soc/aips-bus@02000000/spba-bus@02000000/ecspi@02014000", 0x440, 28}, + {MODULE_I2C3, "/soc/aips-bus@02100000/i2c@021a8000", 0x440, 29}, + {MODULE_I2C4, "/soc/aips-bus@02100000/i2c@021f8000", 0x440, 29}, + {MODULE_GPT2, "/soc/aips-bus@02000000/gpt@020e8000", 0x440, 30}, + {MODULE_EPIT2, "/soc/aips-bus@02000000/epit@020d4000", 0x440, 31}, +#elif defined(CONFIG_MX6UL) + {MODULE_TSC, "/soc/aips-bus@2000000/tsc@2040000", 0x430, 22}, + {MODULE_ADC2, "/soc/aips-bus@2100000/adc@219c000", 0x430, 23}, + {MODULE_SIM1, "/soc/aips-bus@2100000/sim@218c000", 0x430, 24}, + {MODULE_SIM2, "/soc/aips-bus@2100000/sim@21b4000", 0x430, 25}, + {MODULE_FLEXCAN1, "/soc/aips-bus@2000000/can@2090000", 0x430, 26}, + {MODULE_FLEXCAN2, "/soc/aips-bus@2000000/can@2094000", 0x430, 27}, + {MODULE_SPDIF, "/soc/aips-bus@2000000/spba-bus@2000000/spdif@2004000", 0x440, 2}, + {MODULE_EIM, "/soc/aips-bus@2100000/weim@21b8000", 0x440, 3}, + {MODULE_SD1, "/soc/aips-bus@2100000/usdhc@2190000", 0x440, 4}, + {MODULE_SD2, "/soc/aips-bus@2100000/usdhc@2194000", 0x440, 5}, + {MODULE_QSPI1, "/soc/aips-bus@2100000/qspi@21e0000", 0x440, 6}, + {MODULE_GPMI, "/soc/gpmi-nand@1806000", 0x440, 7}, + {MODULE_APBHDMA, "/soc/dma-apbh@1804000", 0x440, 7}, + {MODULE_LCDIF, "/soc/aips-bus@2100000/lcdif@21c8000", 0x440, 8}, + {MODULE_PXP, "/soc/aips-bus@2100000/pxp@21cc000", 0x440, 9}, + {MODULE_CSI, "/soc/aips-bus@2100000/csi@21c4000", 0x440, 10}, + {MODULE_ADC1, "/soc/aips-bus@2100000/adc@2198000", 0x440, 11}, + {MODULE_ENET1, "/soc/aips-bus@2100000/ethernet@2188000", 0x440, 12}, + {MODULE_ENET2, "/soc/aips-bus@2000000/ethernet@20b4000", 0x440, 13}, + {MODULE_CAAM, "/soc/aips-bus@2100000/caam@2140000", 0x440, 14}, + {MODULE_USB_OTG2, "/soc/aips-bus@2100000/usb@2184200", 0x440, 15}, + {MODULE_SAI2, "/soc/aips-bus@2000000/spba-bus@2000000/sai@202c000", 0x440, 24}, + {MODULE_SAI3, "/soc/aips-bus@2000000/spba-bus@2000000/sai@2030000", 0x440, 24}, + {MODULE_BEE, "/soc/aips-bus@2000000/bee@2044000", 0x440, 25}, + {MODULE_UART5, "/soc/aips-bus@2100000/serial@21f4000", 0x440, 26}, + {MODULE_UART6, "/soc/aips-bus@2100000/serial@21fc000", 0x440, 26}, + {MODULE_UART7, "/soc/aips-bus@2000000/spba-bus@2000000/serial@2018000", 0x440, 26}, + {MODULE_UART8, "/soc/aips-bus@2000000/spba-bus@2000000/serial@2024000", 0x440, 26}, + {MODULE_PWM5, "/soc/aips-bus@2000000/pwm@20f0000", 0x440, 27}, + {MODULE_PWM6, "/soc/aips-bus@2000000/pwm@20f4000", 0x440, 27}, + {MODULE_PWM7, "/soc/aips-bus@2000000/pwm@20f8000", 0x440, 27}, + {MODULE_PWM8, "/soc/aips-bus@2000000/pwm@20fc000", 0x440, 27}, + {MODULE_ECSPI3, "/soc/aips-bus@2000000/spba-bus@2000000/ecspi@2010000", 0x440, 28}, + {MODULE_ECSPI4, "/soc/aips-bus@2000000/spba-bus@2000000/ecspi@2014000", 0x440, 28}, + {MODULE_I2C3, "/soc/aips-bus@2100000/i2c@21a8000", 0x440, 29}, + {MODULE_I2C4, "/soc/aips-bus@2100000/i2c@21f8000", 0x440, 29}, + {MODULE_GPT2, "/soc/aips-bus@2000000/gpt@20e8000", 0x440, 30}, + {MODULE_EPIT2, "/soc/aips-bus@2000000/epit@20d4000", 0x440, 31}, + /* Paths for older imx tree: */ + {MODULE_TSC, "/soc/aips-bus@02000000/tsc@02040000", 0x430, 22}, + {MODULE_ADC2, "/soc/aips-bus@02100000/adc@0219c000", 0x430, 23}, + {MODULE_SIM1, "/soc/aips-bus@02100000/sim@0218c000", 0x430, 24}, + {MODULE_SIM2, "/soc/aips-bus@02100000/sim@021b4000", 0x430, 25}, + {MODULE_FLEXCAN1, "/soc/aips-bus@02000000/can@02090000", 0x430, 26}, + {MODULE_FLEXCAN2, "/soc/aips-bus@02000000/can@02094000", 0x430, 27}, + {MODULE_SPDIF, "/soc/aips-bus@02000000/spba-bus@02000000/spdif@02004000", 0x440, 2}, + {MODULE_EIM, "/soc/aips-bus@02100000/weim@021b8000", 0x440, 3}, + {MODULE_SD1, "/soc/aips-bus@02100000/usdhc@02190000", 0x440, 4}, + {MODULE_SD2, "/soc/aips-bus@02100000/usdhc@02194000", 0x440, 5}, + {MODULE_QSPI1, "/soc/aips-bus@02100000/qspi@021e0000", 0x440, 6}, + {MODULE_GPMI, "/soc/gpmi-nand@01806000", 0x440, 7}, + {MODULE_APBHDMA, "/soc/dma-apbh@01804000", 0x440, 7}, + {MODULE_LCDIF, "/soc/aips-bus@02100000/lcdif@021c8000", 0x440, 8}, + {MODULE_PXP, "/soc/aips-bus@02100000/pxp@021cc000", 0x440, 9}, + {MODULE_CSI, "/soc/aips-bus@02100000/csi@021c4000", 0x440, 10}, + {MODULE_ADC1, "/soc/aips-bus@02100000/adc@02198000", 0x440, 11}, + {MODULE_ENET1, "/soc/aips-bus@02100000/ethernet@02188000", 0x440, 12}, + {MODULE_ENET2, "/soc/aips-bus@02000000/ethernet@020b4000", 0x440, 13}, + {MODULE_CAAM, "/soc/aips-bus@02100000/caam@2140000", 0x440, 14}, + {MODULE_USB_OTG2, "/soc/aips-bus@02100000/usb@02184200", 0x440, 15}, + {MODULE_SAI2, "/soc/aips-bus@02000000/spba-bus@02000000/sai@0202c000", 0x440, 24}, + {MODULE_SAI3, "/soc/aips-bus@02000000/spba-bus@02000000/sai@02030000", 0x440, 24}, + {MODULE_BEE, "/soc/aips-bus@02000000/bee@02044000", 0x440, 25}, + {MODULE_UART5, "/soc/aips-bus@02100000/serial@021f4000", 0x440, 26}, + {MODULE_UART6, "/soc/aips-bus@02100000/serial@021fc000", 0x440, 26}, + {MODULE_UART7, "/soc/aips-bus@02000000/spba-bus@02000000/serial@02018000", 0x440, 26}, + {MODULE_UART8, "/soc/aips-bus@02000000/spba-bus@02000000/serial@02024000", 0x440, 26}, + {MODULE_PWM5, "/soc/aips-bus@02000000/pwm@020f0000", 0x440, 27}, + {MODULE_PWM6, "/soc/aips-bus@02000000/pwm@020f4000", 0x440, 27}, + {MODULE_PWM7, "/soc/aips-bus@02000000/pwm@020f8000", 0x440, 27}, + {MODULE_PWM8, "/soc/aips-bus@02000000/pwm@020fc000", 0x440, 27}, + {MODULE_ECSPI3, "/soc/aips-bus@02000000/spba-bus@02000000/ecspi@02010000", 0x440, 28}, + {MODULE_ECSPI4, "/soc/aips-bus@02000000/spba-bus@02000000/ecspi@02014000", 0x440, 28}, + {MODULE_I2C3, "/soc/aips-bus@02100000/i2c@021a8000", 0x440, 29}, + {MODULE_I2C4, "/soc/aips-bus@02100000/i2c@021f8000", 0x440, 29}, + {MODULE_GPT2, "/soc/aips-bus@02000000/gpt@020e8000", 0x440, 30}, + {MODULE_EPIT2, "/soc/aips-bus@02000000/epit@020d4000", 0x440, 31}, +#endif +}; + +u32 check_module_fused(enum fuse_module_type module) +{ + u32 i, reg; + + for (i = 0; i < ARRAY_SIZE(mx6_fuse_descs); i++) { + if (mx6_fuse_descs[i].module == module) { + reg = readl(OCOTP_BASE_ADDR + + mx6_fuse_descs[i].fuse_word_offset); + if (reg & BIT(mx6_fuse_descs[i].fuse_bit_offset)) + return 1; /* disabled */ + else + return 0; /* enabled */ + } + } + + return 0; /* Not has a fuse, always enabled */ +} + +#ifdef CONFIG_OF_SYSTEM_SETUP +int ft_system_setup(void *blob, bd_t *bd) +{ + const char *status = "disabled"; + u32 i, reg; + int rc, off; + + for (i = 0; i < ARRAY_SIZE(mx6_fuse_descs); i++) { + reg = readl(OCOTP_BASE_ADDR + + mx6_fuse_descs[i].fuse_word_offset); + if (reg & BIT(mx6_fuse_descs[i].fuse_bit_offset)) { + off = fdt_path_offset(blob, + mx6_fuse_descs[i].node_path); + + if (off < 0) + continue; /* Not found, skip it */ +add_status: + rc = fdt_setprop(blob, nodeoff, "status", status, + strlen(status) + 1); + if (rc) { + if (rc == -FDT_ERR_NOSPACE) { + rc = fdt_increase_size(blob, 512); + if (!rc) + goto add_status; + } + printf("Unable to update property %s:%s, err=%s\n", mx6_fuse_descs[i].node_path, "status", fdt_strerror(rc)); + } else { + printf("Modify %s disabled\n", mx6_fuse_descs[i].node_path); + } + } + } + + return 0; +} +#endif + +u32 esdhc_fused(u32 base_addr) +{ + switch (base_addr) { + case USDHC1_BASE_ADDR: + return check_module_fused(MODULE_SD1); + case USDHC2_BASE_ADDR: + return check_module_fused(MODULE_SD2); +#ifdef USDHC3_BASE_ADDR + case USDHC3_BASE_ADDR: + return check_module_fused(MODULE_SD3); +#endif +#ifdef USDHC4_BASE_ADDR + case USDHC4_BASE_ADDR: + return check_module_fused(MODULE_SD4); +#endif + default: + return 0; + } +} + +u32 ecspi_fused(u32 base_addr) +{ + switch (base_addr) { + case ECSPI1_BASE_ADDR: + return check_module_fused(MODULE_ECSPI1); + case ECSPI2_BASE_ADDR: + return check_module_fused(MODULE_ECSPI2); + case ECSPI3_BASE_ADDR: + return check_module_fused(MODULE_ECSPI3); + case ECSPI4_BASE_ADDR: + return check_module_fused(MODULE_ECSPI4); +#ifdef ECSPI5_BASE_ADDR + case ECSPI5_BASE_ADDR: + return check_module_fused(MODULE_ECSPI5); +#endif + default: + return 0; + } +} + +u32 usb_fused(u32 base_addr) +{ + int i = (base_addr - USB_BASE_ADDR) / 0x200; + + return check_module_fused(MODULE_USB_OTG1 + i); +} + +u32 qspi_fused(u32 base_addr) +{ + switch (base_addr) { +#ifdef QSPI1_BASE_ADDR + case QSPI1_BASE_ADDR: + return check_module_fused(MODULE_QSPI1); +#endif + +#ifdef QSPI2_BASE_ADDR + case QSPI2_BASE_ADDR: + return check_module_fused(MODULE_QSPI2); +#endif + default: + return 0; + } +} + +u32 i2c_fused(u32 base_addr) +{ + switch (base_addr) { + case I2C1_BASE_ADDR: + return check_module_fused(MODULE_I2C1); + case I2C2_BASE_ADDR: + return check_module_fused(MODULE_I2C2); + case I2C3_BASE_ADDR: + return check_module_fused(MODULE_I2C3); +#ifdef I2C4_BASE_ADDR + case I2C4_BASE_ADDR: + return check_module_fused(MODULE_I2C4); +#endif + } + + return 0; +} + +u32 enet_fused(u32 base_addr) +{ + switch (base_addr) { + case ENET_BASE_ADDR: + return check_module_fused(MODULE_ENET1); +#ifdef ENET2_BASE_ADDR + case ENET2_BASE_ADDR: + return check_module_fused(MODULE_ENET2); +#endif + default: + return 0; + } +}
Add fuse check for I2C. If the fuse indicate the module not work in the SoC, let's fail the initialization.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/i2c/mxc_i2c.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 2e157bca58..fd2d858854 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -18,6 +18,7 @@ #include <asm/arch/imx-regs.h> #include <linux/errno.h> #include <asm/mach-imx/mxc_i2c.h> +#include <asm/mach-imx/sys_proto.h> #include <asm/io.h> #include <i2c.h> #include <watchdog.h> @@ -740,6 +741,14 @@ void bus_i2c_init(int index, int speed, int unused, return; }
+ if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { + if (i2c_fused((u32)mxc_i2c_buses[index].base)) { + printf("I2C@0x%x is fused, disable it\n", + (u32)mxc_i2c_buses[index].base); + return; + } + } + /* * Warning: Be careful to allow the assignment to a static * variable here. This function could be called while U-Boot is @@ -885,6 +894,13 @@ static int mxc_i2c_probe(struct udevice *bus) if (addr == FDT_ADDR_T_NONE) return -EINVAL;
+ if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { + if (i2c_fused(addr)) { + printf("I2C@0x%lx is fused, disable it\n", addr); + return -ENODEV; + } + } + i2c_bus->base = addr; i2c_bus->index = bus->seq; i2c_bus->bus = bus;
Add fuse check for USB. If the fuse indicate the module not work in the SoC, let's fail the initialization.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/usb/host/ehci-mx6.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index e9e6ed596d..3d67f04041 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -353,6 +353,13 @@ int ehci_hcd_init(int index, enum usb_init_type init, if (index > 3) return -EINVAL;
+ if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { + if (usb_fused((u32)ehci)) { + printf("USB@0x%x is fused, disable it\n", (u32)ehci); + return -ENODEV; + } + } + ret = ehci_mx6_common_init(ehci, index); if (ret) return ret; @@ -549,6 +556,13 @@ static int ehci_usb_probe(struct udevice *dev) struct ehci_hcor *hcor; int ret;
+ if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { + if (usb_fused((u32)ehci)) { + printf("USB@0x%x is fused, disable it\n", (u32)ehci); + return -ENODEV; + } + } + priv->ehci = ehci; priv->portnr = dev->seq; priv->init_type = type;
Add fuse check for fec. If the fuse indicate the module not work in the SoC, let's fail the initialization.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/net/fec_mxc.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index d7c080943a..602b655455 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1185,6 +1185,13 @@ int fecmxc_initialize_multi(bd_t *bd, int dev_id, int phy_id, uint32_t addr) #endif int ret;
+ if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { + if (enet_fused(addr)) { + printf("Ethernet@0x%x is fused, disable it\n", addr); + return -ENODEV; + } + } + #ifdef CONFIG_FEC_MXC_MDIO_BASE /* * The i.MX28 has two ethernet interfaces, but they are not equal. @@ -1323,6 +1330,14 @@ static int fecmxc_probe(struct udevice *dev) uint32_t start; int ret;
+ if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { + if (enet_fused((u32)priv->eth)) { + printf("Ethernet@0x%x is fused, disable it\n", + (u32)priv->eth); + return -ENODEV; + } + } + if (IS_ENABLED(CONFIG_IMX8)) { ret = clk_get_by_name(dev, "ipg", &priv->ipg_clk); if (ret < 0) {
"indicates the module will not work"
Please reword this. Something like "SoC fuse indicates Ethernet@0x%x is unavailable."
return -ENODEV;
Same.
(u32)priv->eth);
return -ENODEV;
-- 2.16.4
Subject: Re: [U-Boot] [PATCH 4/4] net: fec: add fuse check
Fix in V2.
- addr);
Fix in v2.
return -ENODEV;
equal.
Same.
Fix in V2.
Thanks, Peng.
(u32)priv->eth);
return -ENODEV;
-- 2.16.4
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flist
s.denx.de%2Flistinfo%2Fu-boot&data=02%7C01%7Cpeng.fan%40nxp.co m%7C
e6ff4f39e3c4498965d308d70f1dabd6%7C686ea1d3bc2b4c6fa92cd99c5c301 635%7C
0%7C0%7C636994492429835169&sdata=IM0QAmsTXC%2BnpZOqtGW XGslK2VD5n7n
pehzJ6i1XqIo%3D&reserved=0
Hi Peng,
If I understand correctly the concept is interesting to make the final binary smaller.
- Copyright 2019 NXP
- MODULE_TSC,
- MODULE_ADC1,
- MODULE_ADC2,
- MODULE_SIM1,
- MODULE_SIM2,
- MODULE_FLEXCAN1,
- MODULE_FLEXCAN2,
- MODULE_SPDIF,
- MODULE_EIM,
- MODULE_SD1,
- MODULE_SD2,
- MODULE_SD3,
- MODULE_SD4,
- MODULE_QSPI1,
- MODULE_QSPI2,
- MODULE_GPMI,
- MODULE_APBHDMA,
- MODULE_LCDIF,
- MODULE_PXP,
- MODULE_CSI,
- MODULE_ENET1,
- MODULE_ENET2,
- MODULE_CAAM,
- MODULE_USB_OTG1,
- MODULE_USB_OTG2,
- MODULE_SAI2,
- MODULE_SAI3,
- MODULE_BEE,
- MODULE_UART1,
- MODULE_UART2,
- MODULE_UART3,
- MODULE_UART4,
- MODULE_UART5,
- MODULE_UART6,
- MODULE_UART7,
- MODULE_UART8,
- MODULE_PWM5,
- MODULE_PWM6,
- MODULE_PWM7,
- MODULE_PWM8,
- MODULE_ECSPI1,
- MODULE_ECSPI2,
- MODULE_ECSPI3,
- MODULE_ECSPI4,
- MODULE_ECSPI5,
- MODULE_I2C1,
- MODULE_I2C2,
- MODULE_I2C3,
- MODULE_I2C4,
- MODULE_GPT1,
- MODULE_GPT2,
- MODULE_EPIT1,
- MODULE_EPIT2,
- MODULE_EPDC,
- MODULE_ESAI,
- MODULE_DCP,
- MODULE_DCP_CRYPTO,
- enum fuse_module_type module;
- const char *node_path;
- u32 fuse_word_offset;
- u32 fuse_bit_offset;
- u32 status;
- bool "i.MX Module Fuse"
- depends on ARCH_MX6
- help
- {MODULE_TSC, "/soc/aips-bus@2000000/tsc@2040000", 0x430, 22},
- {MODULE_ADC2, "/soc/aips-bus@2100000/adc@219c000", 0x430,
23},
- {MODULE_EPDC, "/soc/aips-bus@2200000/epdc@228c000", 0x430,
24},
- {MODULE_ESAI,
- {MODULE_FLEXCAN1, "/soc/aips-bus@2000000/can@2090000",
0x430, 26},
- {MODULE_FLEXCAN2, "/soc/aips-bus@2000000/can@2094000",
0x430, 27},
- {MODULE_SPDIF,
- {MODULE_EIM, "/soc/aips-bus@2100000/weim@21b8000", 0x440, 3},
- {MODULE_SD1, "/soc/aips-bus@2100000/usdhc@2190000", 0x440,
4},
- {MODULE_SD2, "/soc/aips-bus@2100000/usdhc@2194000", 0x440,
5},
- {MODULE_QSPI1, "/soc/aips-bus@2100000/qspi@21e0000", 0x440,
6},
- {MODULE_GPMI, "/soc/gpmi-nand@1806000", 0x440, 7},
- {MODULE_APBHDMA, "/soc/dma-apbh@1804000", 0x440, 7},
- {MODULE_LCDIF, "/soc/aips-bus@2100000/lcdif@21c8000", 0x440,
8},
- {MODULE_PXP, "/soc/aips-bus@2100000/pxp@21cc000", 0x440, 9},
- {MODULE_CSI, "/soc/aips-bus@2100000/csi@21c4000", 0x440, 10},
- {MODULE_ADC1, "/soc/aips-bus@2100000/adc@2198000", 0x440,
11},
- {MODULE_ENET1, "/soc/aips-bus@2100000/ethernet@2188000",
0x440, 12},
- {MODULE_ENET2, "/soc/aips-bus@2000000/ethernet@20b4000",
0x440, 13},
- {MODULE_DCP, "/soc/aips-bus@2200000/dcp@2280000", 0x440, 14},
- {MODULE_USB_OTG2, "/soc/aips-bus@2100000/usb@2184200",
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
- {MODULE_DCP_CRYPTO, "/soc/aips-bus@2200000/dcp@2280000",
0x440, 25},
- {MODULE_UART5, "/soc/aips-bus@2100000/serial@21f4000",
0x440, 26},
- {MODULE_UART6, "/soc/aips-bus@2100000/serial@21fc000",
0x440, 26},
- {MODULE_UART7,
- {MODULE_UART8, "/soc/aips-bus@2200000/serial@2288000",
0x440, 26},
- {MODULE_PWM5, "/soc/aips-bus@2000000/pwm@20f0000", 0x440,
27},
- {MODULE_PWM6, "/soc/aips-bus@2000000/pwm@20f4000", 0x440,
27},
- {MODULE_PWM7, "/soc/aips-bus@2000000/pwm@20f8000", 0x440,
27},
- {MODULE_PWM8, "/soc/aips-bus@2000000/pwm@20fc000", 0x440,
27},
- {MODULE_ECSPI3,
- {MODULE_ECSPI4,
- {MODULE_I2C3, "/soc/aips-bus@2100000/i2c@21a8000", 0x440,
29},
- {MODULE_I2C4, "/soc/aips-bus@2100000/i2c@21f8000", 0x440,
29},
- {MODULE_GPT2, "/soc/aips-bus@2000000/gpt@20e8000", 0x440,
30},
- {MODULE_EPIT2, "/soc/aips-bus@2000000/epit@20d4000", 0x440,
31},
- /* Paths for older imx tree: */
- {MODULE_TSC, "/soc/aips-bus@02000000/tsc@02040000", 0x430,
22},
- {MODULE_ADC2, "/soc/aips-bus@02100000/adc@0219c000", 0x430,
23},
- {MODULE_EPDC, "/soc/aips-bus@02200000/epdc@0228c000", 0x430,
24},
- {MODULE_ESAI,
- {MODULE_FLEXCAN1, "/soc/aips-bus@02000000/can@02090000",
0x430, 26},
- {MODULE_FLEXCAN2, "/soc/aips-bus@02000000/can@02094000",
0x430, 27},
- {MODULE_SPDIF,
- {MODULE_EIM, "/soc/aips-bus@02100000/weim@021b8000", 0x440,
3},
- {MODULE_SD1, "/soc/aips-bus@02100000/usdhc@02190000", 0x440,
4},
- {MODULE_SD2, "/soc/aips-bus@02100000/usdhc@02194000", 0x440,
5},
- {MODULE_QSPI1, "/soc/aips-bus@02100000/qspi@021e0000",
0x440, 6},
- {MODULE_GPMI, "/soc/gpmi-nand@01806000", 0x440, 7},
- {MODULE_APBHDMA, "/soc/dma-apbh@01804000", 0x440, 7},
- {MODULE_LCDIF, "/soc/aips-bus@02100000/lcdif@021c8000",
0x440, 8},
- {MODULE_PXP, "/soc/aips-bus@02100000/pxp@021cc000", 0x440,
9},
- {MODULE_CSI, "/soc/aips-bus@02100000/csi@021c4000", 0x440,
10},
- {MODULE_ADC1, "/soc/aips-bus@02100000/adc@02198000", 0x440,
11},
- {MODULE_ENET1, "/soc/aips-bus@02100000/ethernet@02188000",
0x440, 12},
- {MODULE_ENET2, "/soc/aips-bus@02000000/ethernet@020b4000",
0x440, 13},
- {MODULE_DCP, "/soc/aips-bus@02200000/dcp@02280000", 0x440,
14},
- {MODULE_USB_OTG2, "/soc/aips-bus@02100000/usb@02184200",
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
- {MODULE_DCP_CRYPTO, "/soc/aips-bus@02200000/dcp@02280000",
0x440, 25},
- {MODULE_UART5, "/soc/aips-bus@02100000/serial@021f4000",
0x440, 26},
- {MODULE_UART6, "/soc/aips-bus@02100000/serial@021fc000",
0x440, 26},
- {MODULE_UART7,
- {MODULE_UART8, "/soc/aips-bus@02200000/serial@02288000",
0x440, 26},
- {MODULE_PWM5, "/soc/aips-bus@02000000/pwm@020f0000", 0x440,
27},
- {MODULE_PWM6, "/soc/aips-bus@02000000/pwm@020f4000", 0x440,
27},
- {MODULE_PWM7, "/soc/aips-bus@02000000/pwm@020f8000", 0x440,
27},
- {MODULE_PWM8, "/soc/aips-bus@02000000/pwm@020fc000", 0x440,
27},
- {MODULE_ECSPI3,
- {MODULE_ECSPI4,
- {MODULE_I2C3, "/soc/aips-bus@02100000/i2c@021a8000", 0x440,
29},
- {MODULE_I2C4, "/soc/aips-bus@02100000/i2c@021f8000", 0x440,
29},
- {MODULE_GPT2, "/soc/aips-bus@02000000/gpt@020e8000", 0x440,
30},
- {MODULE_EPIT2, "/soc/aips-bus@02000000/epit@020d4000",
23},
- {MODULE_SIM1, "/soc/aips-bus@2100000/sim@218c000", 0x430,
24},
- {MODULE_SIM2, "/soc/aips-bus@2100000/sim@21b4000", 0x430,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
4},
5},
6},
8},
11},
0x440, 12},
0x440, 13},
- {MODULE_CAAM, "/soc/aips-bus@2100000/caam@2140000", 0x440,
14},
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
- {MODULE_BEE, "/soc/aips-bus@2000000/bee@2044000", 0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
- {MODULE_UART8,
27},
27},
27},
27},
- {MODULE_ECSPI3,
- {MODULE_ECSPI4,
29},
29},
30},
31},
22},
23},
- {MODULE_SIM1, "/soc/aips-bus@02100000/sim@0218c000", 0x430,
24},
- {MODULE_SIM2, "/soc/aips-bus@02100000/sim@021b4000", 0x430,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
3},
4},
5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
- {MODULE_CAAM, "/soc/aips-bus@02100000/caam@2140000", 0x440,
14},
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
- {MODULE_BEE, "/soc/aips-bus@02000000/bee@02044000", 0x440,
25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
- {MODULE_UART8,
27},
27},
27},
27},
- {MODULE_ECSPI3,
- {MODULE_ECSPI4,
29},
29},
30},
I'm wondering if there would be a way to avoid the hardcoded DTS patch ("/soc/aips-bus@02000000/epit@020d4000") ?
Maybe, after reading the the OCOTP values this could be found dynamically (by using the e.g. i2c@021f8000 string) on the DTS already stored in RAM (which is thereafter passed to Linux kernel at bootm execution) ?
- u32 i, reg;
- for (i = 0; i < ARRAY_SIZE(mx6_fuse_descs); i++) {
if (reg &
else
- return 0; /* Not has a fuse, always enabled */
- const char *status = "disabled";
- u32 i, reg;
- int rc, off;
if (off < 0)
+add_status:
status,
if (rc) {
512);
if (!rc)
goto add_status;
} else {
+} +#endif
- switch (base_addr) {
- case USDHC1_BASE_ADDR:
- case USDHC2_BASE_ADDR:
- case USDHC3_BASE_ADDR:
- case USDHC4_BASE_ADDR:
- default:
- case ECSPI1_BASE_ADDR:
- case ECSPI2_BASE_ADDR:
- case ECSPI3_BASE_ADDR:
- case ECSPI4_BASE_ADDR:
- case ECSPI5_BASE_ADDR:
- default:
- int i = (base_addr - USB_BASE_ADDR) / 0x200;
- return check_module_fused(MODULE_USB_OTG1 + i);
- case QSPI1_BASE_ADDR:
- case QSPI2_BASE_ADDR:
- default:
- case I2C1_BASE_ADDR:
- case I2C2_BASE_ADDR:
- case I2C3_BASE_ADDR:
- case I2C4_BASE_ADDR:
- case ENET_BASE_ADDR:
- case ENET2_BASE_ADDR:
- default:
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz,
Subject: Re: [U-Boot] [PATCH 1/4] imx: add module fuse support
Hi Peng,
No. This is to use one image to support multiple parts of a same kind SoC. So this patch will make the uboot image size larger.
As described in commit log, some i.MX6UL parts not have enet, some have Enet, so we need find a method to make the same image could work on the two parts, that is what this patch does.
Thanks, Peng.
- MODULE_TSC,
- MODULE_ADC1,
- MODULE_ADC2,
- MODULE_SIM1,
- MODULE_SIM2,
- MODULE_FLEXCAN1,
- MODULE_FLEXCAN2,
- MODULE_SPDIF,
- MODULE_EIM,
- MODULE_SD1,
- MODULE_SD2,
- MODULE_SD3,
- MODULE_SD4,
- MODULE_QSPI1,
- MODULE_QSPI2,
- MODULE_GPMI,
- MODULE_APBHDMA,
- MODULE_LCDIF,
- MODULE_PXP,
- MODULE_CSI,
- MODULE_ENET1,
- MODULE_ENET2,
- MODULE_CAAM,
- MODULE_USB_OTG1,
- MODULE_USB_OTG2,
- MODULE_SAI2,
- MODULE_SAI3,
- MODULE_BEE,
- MODULE_UART1,
- MODULE_UART2,
- MODULE_UART3,
- MODULE_UART4,
- MODULE_UART5,
- MODULE_UART6,
- MODULE_UART7,
- MODULE_UART8,
- MODULE_PWM5,
- MODULE_PWM6,
- MODULE_PWM7,
- MODULE_PWM8,
- MODULE_ECSPI1,
- MODULE_ECSPI2,
- MODULE_ECSPI3,
- MODULE_ECSPI4,
- MODULE_ECSPI5,
- MODULE_I2C1,
- MODULE_I2C2,
- MODULE_I2C3,
- MODULE_I2C4,
- MODULE_GPT1,
- MODULE_GPT2,
- MODULE_EPIT1,
- MODULE_EPIT2,
- MODULE_EPDC,
- MODULE_ESAI,
- MODULE_DCP,
- u32 status;
+#if !IS_ENABLED(CONFIG_IMX_MODULE_FUSE) +static inline u32 check_module_fused(enum fuse_module_type module) {
+static inline u32 esdhc_fused(u32 base_addr) {
+static inline u32 ecspi_fused(u32 base_addr) {
+static inline u32 uart_fused(u32 base_addr) {
+static inline u32 usb_fused(u32 base_addr) {
+static inline u32 qspi_fused(u32 base_addr) {
+static inline u32 i2c_fused(u32 base_addr) {
+static inline u32 enet_fused(u32 base_addr) {
- help
+#include <common.h> +#include <fdt_support.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/imx-regs.h> +#include <asm/mach-imx/module_fuse.h> #include <linux/errno.h>
+static struct fuse_entry_desc mx6_fuse_descs[] = { #if +defined(CONFIG_MX6ULL)
23},
24},
- {MODULE_ESAI,
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
4},
5},
6},
8},
11},
0x440, 12},
0x440, 13},
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
26},
0x440, 26},
27},
27},
27},
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
31},
22},
23},
24},
- {MODULE_ESAI,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
3},
4},
5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
0x440, 26},
27},
27},
27},
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
23},
24},
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
4},
5},
6},
8},
11},
0x440, 12},
0x440, 13},
14},
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
0x440, 26},
0x440, 26},
- {MODULE_UART7,
26},
- {MODULE_UART8,
26},
27},
27},
27},
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
31},
22},
23},
24},
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
3},
4},
5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
- {MODULE_UART8,
0x440,
26},
27},
27},
27},
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
+u32 check_module_fused(enum fuse_module_type module) {
- u32 i, reg;
if (reg &
else
- return 0; /* Not has a fuse, always enabled */ }
+#ifdef CONFIG_OF_SYSTEM_SETUP +int ft_system_setup(void *blob, bd_t *bd) {
- u32 i, reg;
- int rc, off;
if (off < 0)
+add_status:
status,
if (rc) {
512);
if (!rc)
goto add_status;
} else {
+} +#endif
return check_module_fused(MODULE_SD2); #ifdef
USDHC3_BASE_ADDR
return check_module_fused(MODULE_SD3); #endif #ifdef
+USDHC4_BASE_ADDR
return check_module_fused(MODULE_SD4); #endif
- default:
- default:
- return check_module_fused(MODULE_USB_OTG1 + i); }
return check_module_fused(MODULE_QSPI1); #endif
return check_module_fused(MODULE_QSPI2); #endif
- default:
return check_module_fused(MODULE_I2C3); #ifdef
I2C4_BASE_ADDR
return check_module_fused(MODULE_I2C4); #endif
return check_module_fused(MODULE_ENET1); #ifdef
ENET2_BASE_ADDR
return check_module_fused(MODULE_ENET2); #endif
- default:
Lukasz Majewski
Hi Peng,
Hi Lukasz,
Hi Peng,
Is there any markings on the SoC? (like MX6ULXXXXXX) which indicates which SoC has enet and which doesn't have one?
Ok. Thanks for explanation.
Thanks, Peng.
- MODULE_TSC,
- MODULE_ADC1,
- MODULE_ADC2,
- MODULE_SIM1,
- MODULE_SIM2,
- MODULE_FLEXCAN1,
- MODULE_FLEXCAN2,
- MODULE_SPDIF,
- MODULE_EIM,
- MODULE_SD1,
- MODULE_SD2,
- MODULE_SD3,
- MODULE_SD4,
- MODULE_QSPI1,
- MODULE_QSPI2,
- MODULE_GPMI,
- MODULE_APBHDMA,
- MODULE_LCDIF,
- MODULE_PXP,
- MODULE_CSI,
- MODULE_ENET1,
- MODULE_ENET2,
- MODULE_CAAM,
- MODULE_USB_OTG1,
- MODULE_USB_OTG2,
- MODULE_SAI2,
- MODULE_SAI3,
- MODULE_BEE,
- MODULE_UART1,
- MODULE_UART2,
- MODULE_UART3,
- MODULE_UART4,
- MODULE_UART5,
- MODULE_UART6,
- MODULE_UART7,
- MODULE_UART8,
- MODULE_PWM5,
- MODULE_PWM6,
- MODULE_PWM7,
- MODULE_PWM8,
- MODULE_ECSPI1,
- MODULE_ECSPI2,
- MODULE_ECSPI3,
- MODULE_ECSPI4,
- MODULE_ECSPI5,
- MODULE_I2C1,
- MODULE_I2C2,
- MODULE_I2C3,
- MODULE_I2C4,
- MODULE_GPT1,
- MODULE_GPT2,
- MODULE_EPIT1,
- MODULE_EPIT2,
- MODULE_EPDC,
- MODULE_ESAI,
- MODULE_DCP,
- u32 status;
- help
including
22},
23},
0x430, 24},
- {MODULE_ESAI,
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
14},
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
26},
0x440, 26},
27},
27},
27},
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
0x440, 31},
0x430, 22},
0x430, 23},
0x430, 24},
- {MODULE_ESAI,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
0x440, 9},
0x440, 10},
0x440, 11},
- {MODULE_ENET1,
- {MODULE_ENET2,
0x440, 14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
0x440, 26},
0x440, 27},
0x440, 27},
0x440, 27},
0x440, 27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
0x440, 29},
0x440, 29},
0x440, 30},
22},
23},
24},
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
0x440, 14},
0x440, 15},
- {MODULE_SAI2,
- {MODULE_SAI3,
25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
26},
- {MODULE_UART8,
26},
27},
27},
27},
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
0x440, 31},
0x430, 22},
0x430, 23},
0x430, 24},
0x430, 25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
0x440, 9},
0x440, 10},
0x440, 11},
- {MODULE_ENET1,
- {MODULE_ENET2,
0x440, 14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
- {MODULE_UART8,
0x440,
26},
0x440, 27},
0x440, 27},
0x440, 27},
0x440, 27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
0x440, 29},
0x440, 29},
0x440, 30},
- u32 i, reg;
if (reg &
else
- u32 i, reg;
- int rc, off;
if (reg &
if (off < 0)
*/ +add_status:
status,
if (rc) {
rc =
if (!rc)
goto add_status;
} else {
+} +#endif
USDHC3_BASE_ADDR
#ifdef +USDHC4_BASE_ADDR
- default:
- default:
- default:
I2C4_BASE_ADDR
ENET2_BASE_ADDR
- default:
Lukasz Majewski
Lukasz Majewski
Hi Lukasz,
Hi Peng,
Hi Lukasz,
Hi Peng,
I do not have that marketing information. We just have the information that to use fuse to indicate whether the module is there.
Regards, Peng.
Thanks, Peng.
100644
- MODULE_TSC,
- MODULE_ADC1,
- MODULE_ADC2,
- MODULE_SIM1,
- MODULE_SIM2,
- MODULE_FLEXCAN1,
- MODULE_FLEXCAN2,
- MODULE_SPDIF,
- MODULE_EIM,
- MODULE_SD1,
- MODULE_SD2,
- MODULE_SD3,
- MODULE_SD4,
- MODULE_QSPI1,
- MODULE_QSPI2,
- MODULE_GPMI,
- MODULE_APBHDMA,
- MODULE_LCDIF,
- MODULE_PXP,
- MODULE_CSI,
- MODULE_ENET1,
- MODULE_ENET2,
- MODULE_CAAM,
- MODULE_USB_OTG1,
- MODULE_USB_OTG2,
- MODULE_SAI2,
- MODULE_SAI3,
- MODULE_BEE,
- MODULE_UART1,
- MODULE_UART2,
- MODULE_UART3,
- MODULE_UART4,
- MODULE_UART5,
- MODULE_UART6,
- MODULE_UART7,
- MODULE_UART8,
- MODULE_PWM5,
- MODULE_PWM6,
- MODULE_PWM7,
- MODULE_PWM8,
- MODULE_ECSPI1,
- MODULE_ECSPI2,
- MODULE_ECSPI3,
- MODULE_ECSPI4,
- MODULE_ECSPI5,
- MODULE_I2C1,
- MODULE_I2C2,
- MODULE_I2C3,
- MODULE_I2C4,
- MODULE_GPT1,
- MODULE_GPT2,
- MODULE_EPIT1,
- MODULE_EPIT2,
- MODULE_EPDC,
- MODULE_ESAI,
- MODULE_DCP,
- u32 status;
- help
including
22},
23},
0x430, 24},
- {MODULE_ESAI,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
0x440, 26},
0x440,
27},
0x440,
27},
0x440,
27},
0x440,
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
0x440, 31},
0x430, 22},
0x430, 23},
0x430, 24},
- {MODULE_ESAI,
0x430,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
0x440, 9},
0x440, 10},
0x440, 11},
- {MODULE_ENET1,
- {MODULE_ENET2,
0x440, 14},
- {MODULE_USB_OTG2,
0x440, 15},
- {MODULE_SAI2,
0x440,
24},
- {MODULE_SAI3,
0x440,
24},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
0x440, 26},
0x440, 27},
0x440, 27},
0x440, 27},
0x440, 27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
0x440, 29},
0x440, 29},
0x440, 30},
22},
23},
24},
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
0x440, 14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
- {MODULE_UART8,
0x440,
26},
0x440,
27},
0x440,
27},
0x440,
27},
0x440,
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
0x440, 31},
0x430, 22},
0x430, 23},
0x430, 24},
0x430, 25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
0x440, 9},
0x440, 10},
0x440, 11},
- {MODULE_ENET1,
- {MODULE_ENET2,
0x440, 14},
- {MODULE_USB_OTG2,
0x440, 15},
- {MODULE_SAI2,
0x440,
24},
- {MODULE_SAI3,
0x440,
24},
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
- {MODULE_UART8,
0x440,
26},
0x440, 27},
0x440, 27},
0x440, 27},
0x440, 27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
0x440, 29},
0x440, 29},
0x440, 30},
- u32 i, reg;
if (reg &
else
- u32 i, reg;
- int rc, off;
if (reg &
if (off < 0)
*/ +add_status:
status,
if (rc) {
rc =
if (!rc)
goto add_status;
} else {
+} +#endif
USDHC3_BASE_ADDR
- default:
- default:
- default:
I2C4_BASE_ADDR
ENET2_BASE_ADDR
- default:
Lukasz Majewski
Lukasz Majewski
Hi Lukasz,
On 24.07.19 14:12, Peng Fan wrote:
Hi Lukasz,
Hi Peng,
Hi Lukasz,
Hi Peng,
Yes, you can look in the datasheets. For i.MX6ULL ([1], [2]) for example, there is a table in chapter 1.1, which describes the features for the different types and the corresponding part numbers. And the part numbers are printed on the chips.
Regards, Frieder
[1] https://www.nxp.com/docs/en/data-sheet/IMX6ULLCEC.pdf [2] https://www.nxp.com/docs/en/data-sheet/IMX6ULLIEC.pdf
Regards, Peng.
Thanks, Peng.
100644
- MODULE_TSC,
- MODULE_ADC1,
- MODULE_ADC2,
- MODULE_SIM1,
- MODULE_SIM2,
- MODULE_FLEXCAN1,
- MODULE_FLEXCAN2,
- MODULE_SPDIF,
- MODULE_EIM,
- MODULE_SD1,
- MODULE_SD2,
- MODULE_SD3,
- MODULE_SD4,
- MODULE_QSPI1,
- MODULE_QSPI2,
- MODULE_GPMI,
- MODULE_APBHDMA,
- MODULE_LCDIF,
- MODULE_PXP,
- MODULE_CSI,
- MODULE_ENET1,
- MODULE_ENET2,
- MODULE_CAAM,
- MODULE_USB_OTG1,
- MODULE_USB_OTG2,
- MODULE_SAI2,
- MODULE_SAI3,
- MODULE_BEE,
- MODULE_UART1,
- MODULE_UART2,
- MODULE_UART3,
- MODULE_UART4,
- MODULE_UART5,
- MODULE_UART6,
- MODULE_UART7,
- MODULE_UART8,
- MODULE_PWM5,
- MODULE_PWM6,
- MODULE_PWM7,
- MODULE_PWM8,
- MODULE_ECSPI1,
- MODULE_ECSPI2,
- MODULE_ECSPI3,
- MODULE_ECSPI4,
- MODULE_ECSPI5,
- MODULE_I2C1,
- MODULE_I2C2,
- MODULE_I2C3,
- MODULE_I2C4,
- MODULE_GPT1,
- MODULE_GPT2,
- MODULE_EPIT1,
- MODULE_EPIT2,
- MODULE_EPDC,
- MODULE_ESAI,
- MODULE_DCP,
- u32 status;
- help
including
- config USE_IMXIMG_PLUGIN bool "Use imximage plugin code" depends on ARCH_MX7 || ARCH_MX6 || ARCH_MX7ULP diff --git
22},
23},
0x430, 24},
- {MODULE_ESAI,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
0x440, 26},
0x440,
27},
0x440,
27},
0x440,
27},
0x440,
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
0x440, 31},
0x430, 22},
0x430, 23},
0x430, 24},
- {MODULE_ESAI,
0x430,
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
0x440, 9},
0x440, 10},
0x440, 11},
- {MODULE_ENET1,
- {MODULE_ENET2,
0x440, 14},
- {MODULE_USB_OTG2,
0x440, 15},
- {MODULE_SAI2,
0x440,
24},
- {MODULE_SAI3,
0x440,
24},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
0x440, 26},
0x440, 27},
0x440, 27},
0x440, 27},
0x440, 27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
0x440, 29},
0x440, 29},
0x440, 30},
22},
23},
24},
25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
9},
10},
11},
0x440, 12},
0x440, 13},
0x440, 14},
0x440, 15},
- {MODULE_SAI2,
24},
- {MODULE_SAI3,
24},
25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
- {MODULE_UART8,
0x440,
26},
0x440,
27},
0x440,
27},
0x440,
27},
0x440,
27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
29},
29},
30},
0x440, 31},
0x430, 22},
0x430, 23},
0x430, 24},
0x430, 25},
0x430, 26},
0x430, 27},
- {MODULE_SPDIF,
2},
0x440, 3},
0x440, 4},
0x440, 5},
0x440, 6},
0x440, 8},
0x440, 9},
0x440, 10},
0x440, 11},
- {MODULE_ENET1,
- {MODULE_ENET2,
0x440, 14},
- {MODULE_USB_OTG2,
0x440, 15},
- {MODULE_SAI2,
0x440,
24},
- {MODULE_SAI3,
0x440,
24},
0x440, 25},
0x440, 26},
0x440, 26},
- {MODULE_UART7,
0x440,
26},
- {MODULE_UART8,
0x440,
26},
0x440, 27},
0x440, 27},
0x440, 27},
0x440, 27},
- {MODULE_ECSPI3,
28},
- {MODULE_ECSPI4,
28},
0x440, 29},
0x440, 29},
0x440, 30},
- u32 i, reg;
if (reg &
else
- u32 i, reg;
- int rc, off;
if (reg &
if (off < 0)
*/ +add_status:
status,
if (rc) {
rc =
if (!rc)
goto add_status;
} else {
+} +#endif
USDHC3_BASE_ADDR
- default:
- default:
- default:
I2C4_BASE_ADDR
ENET2_BASE_ADDR
- default:
Lukasz Majewski
Lukasz Majewski
Hi Frieder,
Thanks for the info.
Regards, Frieder
Lukasz Majewski
Joe Hershberger
Lukasz Majewski
Peng Fan
Schrempf Frieder
