Hi All,
Is it Possible from Linux to set an environment variable of u-Boot.?
This is for Firmware up gradation.
Currently Linux has 4 mtd partitions in flash
mtd0 : U-Boot mtd1: JFFS file system (Golden image) mtd2: JFFS file system (Silver image) mtd3: Configs
U boot does an fsload of uImage(Linux image) from Golden JFFS and boots up Linux.
Now from Linux I can download a new JFFS(Silver) and flash it to mtd2 partition of Flash.
Is there any mechanism that Linux acknowledges the u-boot about the new jffs image that next time it has to do an fsload of uImage(Linux image) from Silver JFFS , not Golden JFFS.
I thought of Doing this using some environment variables .
But after a successful download of new jffs and writing to mtd2 partition , How will Linux update the environment variable of U-boot?
Any better idea for firmware up gradation?
Expecting your Suggestions and Help
Thanks Rahanesh
Dear Rahanesh,
If your environment is stored in NOR or NAND flash, then you can use the tools from the tools/env/ directory (fw_setenv / fw_printenv).
It should be trivial to adapt the code for other storage devices, too.
Use fw_setenv.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Any sufficiently advanced technology is indistinguishable from magic. - Arthur C. Clarke
Hi Wolfgang Denk,
Thank you very much for the reply!!!
Few questions:
1) You said " If your environment is stored in NOR or NAND flash, then you can use
the tools from the tools/env/ directory (fw_setenv / fw_printenv)."
*It is already stored in NOR Flash. This is not in a separate partition. Should it be in a separate partition? Currently uboot.bin and environment variable are in mtd1 partition. Any problem? Should i create another partition for environment variables alone?
*2) I have downloaded these tools from* http://packages.debian.org/unstable/main/uboot-envtools *. I am not able to make it. I need to cross compile this for MIPS. Can u suggest me an url where i can get the stable and compilable src code.
Thanks Rahanesh
Wolfgang Denk wrote:
Dear Rahanesh,
Use fw_setenv.
Dear Rahanesh,
You are welcome.
Few questions:
Hm... please do not top-post / full quote. Please make sure to read http://www.netmeister.org/news/learn2quote.html
- You said " If your environment is stored in NOR or NAND flash, then
you can use
That's fine. A separate partition is not needed. the fw_*env tools can be easily configured for your setup.
No changes are necessary.
The tools come as part of the U-Boot source code. Please see http://www.denx.de/wiki/U-Boot/SourceCode for details.
Rahanesh
