[PATCH 0/6] riscv: adds T-Head C9xx basic and GMAC support.
This patchset adds T-Head C9xx basic support in arch/riscv/, updates TH1520 Soc/Lichee Pi4A dts files for GMAC support. Also enable designware ethernet & realtek phy in default configs, and some boot env option for booting linux from Ethernet.
Signed-off-by: Wei Fu wefu@redhat.com Co-authored-by: Yixun Lan dlan@gentoo.org
Wei Fu (6): cpu: add t-head's c9xx riscv/dts: add gmac node for th1520. riscv/dts: add gmac node for lichee-pi-4a net/designware: add compatible for "snps,dwmac" config/th1520_lpi4a_defconfig:enable designware ethernet & realtek phy config/th1520_lpi4a.h: add more env option for booting linux
arch/riscv/Kconfig | 1 + arch/riscv/cpu/c9xx/Kconfig | 12 ++++++ arch/riscv/cpu/c9xx/Makefile | 5 +++ arch/riscv/cpu/c9xx/cpu.c | 51 ++++++++++++++++++++++++++ arch/riscv/cpu/c9xx/dram.c | 36 ++++++++++++++++++ arch/riscv/dts/th1520-lichee-pi-4a.dts | 5 +++ arch/riscv/dts/th1520.dtsi | 33 +++++++++++++++++ arch/riscv/include/asm/csr.h | 2 + board/thead/th1520_lpi4a/Kconfig | 3 +- configs/th1520_lpi4a_defconfig | 8 +++- drivers/net/designware.c | 1 + include/configs/th1520_lpi4a.h | 12 ++++++ 12 files changed, 166 insertions(+), 3 deletions(-) create mode 100644 arch/riscv/cpu/c9xx/Kconfig create mode 100644 arch/riscv/cpu/c9xx/Makefile create mode 100644 arch/riscv/cpu/c9xx/cpu.c create mode 100644 arch/riscv/cpu/c9xx/dram.c
Signed-off-by: Wei Fu wefu@redhat.com Co-authored-by: Yixun Lan dlan@gentoo.org --- arch/riscv/Kconfig | 1 + arch/riscv/cpu/c9xx/Kconfig | 12 ++++++++ arch/riscv/cpu/c9xx/Makefile | 5 ++++ arch/riscv/cpu/c9xx/cpu.c | 51 ++++++++++++++++++++++++++++++++ arch/riscv/cpu/c9xx/dram.c | 36 ++++++++++++++++++++++ arch/riscv/include/asm/csr.h | 2 ++ board/thead/th1520_lpi4a/Kconfig | 3 +- 7 files changed, 109 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index ac52c5e6da..ac3b802abe 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -97,6 +97,7 @@ source "arch/riscv/cpu/fu540/Kconfig" source "arch/riscv/cpu/fu740/Kconfig" source "arch/riscv/cpu/generic/Kconfig" source "arch/riscv/cpu/jh7110/Kconfig" +source "arch/riscv/cpu/c9xx/Kconfig"
# architecture-specific options below
diff --git a/arch/riscv/cpu/c9xx/Kconfig b/arch/riscv/cpu/c9xx/Kconfig new file mode 100644 index 0000000000..5a84bcacd6 --- /dev/null +++ b/arch/riscv/cpu/c9xx/Kconfig @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2017-2020 Alibaba Group Holding Limited + +config RISCV_THEAD + bool + select ARCH_EARLY_INIT_R + imply CPU + imply CPU_RISCV + imply RISCV_TIMER + imply RISCV_RDTIME + imply CMD_CPU diff --git a/arch/riscv/cpu/c9xx/Makefile b/arch/riscv/cpu/c9xx/Makefile new file mode 100644 index 0000000000..e3f776cb41 --- /dev/null +++ b/arch/riscv/cpu/c9xx/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2017-2020 Alibaba Group Holding Limited + +obj-y += cpu.o dram.o diff --git a/arch/riscv/cpu/c9xx/cpu.c b/arch/riscv/cpu/c9xx/cpu.c new file mode 100644 index 0000000000..4b21edd62b --- /dev/null +++ b/arch/riscv/cpu/c9xx/cpu.c @@ -0,0 +1,51 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017-2020 Alibaba Group Holding Limited + */ + +#include <asm/cache.h> +#include <asm/csr.h> +#include <cpu_func.h> + +/* + * cleanup_before_linux() is called just before we call linux + * it prepares the processor for linux + * + * we disable interrupt and caches. + */ +int cleanup_before_linux(void) +{ + cache_flush(); + + return 0; +} + +void flush_dcache_range(unsigned long start, unsigned long end) +{ + register unsigned long i asm("a0") = start & ~(CONFIG_SYS_CACHELINE_SIZE - 1); + + for (; i < end; i += CONFIG_SYS_CACHELINE_SIZE) + asm volatile(".long 0x0295000b"); /* dcache.cpa a0 */ + + sync_is(); +} + +void invalidate_dcache_range(unsigned long start, unsigned long end) +{ + register unsigned long i asm("a0") = start & ~(CONFIG_SYS_CACHELINE_SIZE - 1); + + for (; i < end; i += CONFIG_SYS_CACHELINE_SIZE) + asm volatile(".long 0x02b5000b"); /* dcache.cipa a0 */ + + sync_is(); +} + +void invalid_dcache_range(unsigned long start, unsigned long end) +{ + register unsigned long i asm("a0") = start & ~(CONFIG_SYS_CACHELINE_SIZE - 1); + + for (; i < end; i += CONFIG_SYS_CACHELINE_SIZE) + asm volatile(".long 0x02a5000b"); /* dcache.ipa a0 */ + + sync_is(); +} diff --git a/arch/riscv/cpu/c9xx/dram.c b/arch/riscv/cpu/c9xx/dram.c new file mode 100644 index 0000000000..614d7bf1cc --- /dev/null +++ b/arch/riscv/cpu/c9xx/dram.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <fdtdec.h> +#include <init.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +phys_size_t board_get_usable_ram_top(phys_size_t total_size) +{ + /* + * Ensure that we run from first 4GB so that all + * addresses used by U-Boot are 32bit addresses. + * + * This in-turn ensures that 32bit DMA capable + * devices work fine because DMA mapping APIs will + * provide 32bit DMA addresses only. + */ + if (gd->ram_top >= SZ_4G) + return SZ_4G - 1; + + return gd->ram_top; +} diff --git a/arch/riscv/include/asm/csr.h b/arch/riscv/include/asm/csr.h index 986f951c31..3102de6cbb 100644 --- a/arch/riscv/include/asm/csr.h +++ b/arch/riscv/include/asm/csr.h @@ -145,6 +145,8 @@ #define CSR_MARCHID 0xf12 #define CSR_MHARTID 0xf14
+#define sync_is() asm volatile (".long 0x01b0000b") + #ifndef __ASSEMBLY__
#define csr_swap(csr, val) \ diff --git a/board/thead/th1520_lpi4a/Kconfig b/board/thead/th1520_lpi4a/Kconfig index 622246127c..bef0638e80 100644 --- a/board/thead/th1520_lpi4a/Kconfig +++ b/board/thead/th1520_lpi4a/Kconfig @@ -11,7 +11,7 @@ config SYS_VENDOR default "thead"
config SYS_CPU - default "generic" + default "c9xx"
config SYS_CONFIG_NAME default "th1520_lpi4a" @@ -30,6 +30,7 @@ config SPL_OPENSBI_LOAD_ADDR config BOARD_SPECIFIC_OPTIONS def_bool y select ARCH_EARLY_INIT_R + select RISCV_THEAD imply CPU imply CPU_RISCV imply RISCV_TIMER if RISCV_SMODE
Hi!
I tested this and it works fine. I also happen to have the glue layer ported from the Linux somewhere on my machine. If you're interested, please reach out to me and I'll arrange a patch. I have a few remarks on this patch:
+config RISCV_THEAD
- bool
- select ARCH_EARLY_INIT_R
- imply CPU
- imply CPU_RISCV
- imply RISCV_TIMER
- imply RISCV_RDTIME
- imply CMD_CPU
- Copyright (C) 2017-2020 Alibaba Group Holding Limited
- cleanup_before_linux() is called just before we call linux
- it prepares the processor for linux
- we disable interrupt and caches.
- cache_flush();
- register unsigned long i asm("a0") = start & ~(CONFIG_SYS_CACHELINE_SIZE - 1);
Isn't this just round_down/ALIGN_DOWN macro?
- for (; i < end; i += CONFIG_SYS_CACHELINE_SIZE)
- sync_is();
`th.dcache.cipa` not only invalidates the dcache, but also flushes it which is not expected here. In practice, this leads to a bug with the dwmac driver: when U-Boot handles an ARP request, it overwrites the ARP request with the ARP response in-place, directly in the ring buffer[^1]. When re-using the same buffer later on, the driver will flush this data instead of invalidating it[^2], and you'll read the ARP response you just sent instead of the packet just written by the chip.
This can easily be reproduced by downloading a big file using TFTP. As soon as you receive an ARP request, U-Boot hangs, timeouts and requests the packet again. It also makes TCP completely unusable.
You can use `th.dcache.ipa` instead, as implemented in `invalid_dcache_range`.
[^1] https://github.com/u-boot/u-boot/blob/a5ec56aea1a56737a4e124d058a6920d16f5e6... [^2] https://github.com/u-boot/u-boot/blob/a5ec56aea1a56737a4e124d058a6920d16f5e6...
- sync_is();
I think this isn't used anywhere.
- sync_is();
- Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com
- return fdtdec_setup_mem_size_base();
- return fdtdec_setup_memory_banksize();
- if (gd->ram_top >= SZ_4G)
return SZ_4G - 1;
- return gd->ram_top;
I believe this instruction is also T-Head specific (at least my disassembler doesn't know it). I doubt it belongs here.
Best regards, Nils
config SYS_CPU
- default "generic"
default "c9xx"
- select RISCV_THEAD imply CPU imply CPU_RISCV imply RISCV_TIMER if RISCV_SMODE
Signed-off-by: Wei Fu wefu@redhat.com Co-authored-by: Yixun Lan dlan@gentoo.org --- arch/riscv/dts/th1520.dtsi | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/riscv/dts/th1520.dtsi b/arch/riscv/dts/th1520.dtsi index f7bfa42243..d68c446a6b 100644 --- a/arch/riscv/dts/th1520.dtsi +++ b/arch/riscv/dts/th1520.dtsi @@ -128,6 +128,13 @@ #clock-cells = <0>; };
+ dummy_apb: apb-clock { + compatible = "fixed-clock"; + clock-frequency = <62500000>; + clock-output-names = "dummy_apb"; + #clock-cells = <0>; + }; + uart_sclk: uart-sclk-clock { compatible = "fixed-clock"; clock-output-names = "uart_sclk"; @@ -163,6 +170,32 @@ <&cpu3_intc 3>, <&cpu3_intc 7>; };
+ gmac0: ethernet@ffe7070000 { + compatible = "snps,dwmac"; + reg = <0xff 0xe7070000 0x0 0x2000>; + clocks = <&dummy_apb>; + clock-names = "stmmaceth"; + snps,pbl = <32>; + snps,fixed-burst; + + phy-mode = "rgmii-id"; + phy-handle = <&phy_88E1111_a>; + status = "disabled"; + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + + phy_88E1111_a: ethernet-phy@1 { + reg = <0x1>; + }; + + phy_88E1111_b: ethernet-phy@2 { + reg = <0x2>; + }; + }; + }; + uart0: serial@ffe7014000 { compatible = "snps,dw-apb-uart"; reg = <0xff 0xe7014000 0x0 0x100>;
Signed-off-by: Wei Fu wefu@redhat.com Co-authored-by: Yixun Lan dlan@gentoo.org --- arch/riscv/dts/th1520-lichee-pi-4a.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/riscv/dts/th1520-lichee-pi-4a.dts b/arch/riscv/dts/th1520-lichee-pi-4a.dts index a1248b2ee3..29f990c7be 100644 --- a/arch/riscv/dts/th1520-lichee-pi-4a.dts +++ b/arch/riscv/dts/th1520-lichee-pi-4a.dts @@ -20,6 +20,7 @@ serial3 = &uart3; serial4 = &uart4; serial5 = &uart5; + ethernet0 = &gmac0; };
chosen { @@ -30,3 +31,7 @@ &uart0 { status = "okay"; }; + +&gmac0 { + status = "okay"; +};
Signed-off-by: Wei Fu wefu@redhat.com Co-authored-by: Yixun Lan dlan@gentoo.org --- drivers/net/designware.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index c222197b11..bc2726485b 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -861,6 +861,7 @@ static const struct udevice_id designware_eth_ids[] = { { .compatible = "amlogic,meson6-dwmac" }, { .compatible = "st,stm32-dwmac" }, { .compatible = "snps,arc-dwmac-3.70a" }, + { .compatible = "snps,dwmac" }, { } };
Signed-off-by: Wei Fu wefu@redhat.com Co-authored-by: Yixun Lan dlan@gentoo.org --- configs/th1520_lpi4a_defconfig | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/configs/th1520_lpi4a_defconfig b/configs/th1520_lpi4a_defconfig index 49ff92f6de..b7d049b9d2 100644 --- a/configs/th1520_lpi4a_defconfig +++ b/configs/th1520_lpi4a_defconfig @@ -58,16 +58,20 @@ CONFIG_CMD_BOOTMENU=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y -# CONFIG_NET is not set # CONFIG_BLOCK_CACHE is not set # CONFIG_GPIO is not set # CONFIG_I2C is not set # CONFIG_INPUT is not set # CONFIG_DM_MMC is not set # CONFIG_MTD is not set +CONFIG_PHY_REALTEK=y +CONFIG_RTL8211X_PHY_FORCE_MASTER=y +CONFIG_RTL8211F_PHY_FORCE_EEE_RXC_ON=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_DW_ALTDESCRIPTOR=y # CONFIG_POWER is not set CONFIG_SYS_NS16550=y -CONFIG_RISCV_TIMER=y +# CONFIG_REGEX is not set CONFIG_AES=y CONFIG_BLAKE2=y CONFIG_SHA512=y
Signed-off-by: Wei Fu wefu@redhat.com Co-authored-by: Yixun Lan dlan@gentoo.org --- include/configs/th1520_lpi4a.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/configs/th1520_lpi4a.h b/include/configs/th1520_lpi4a.h index 87496a52c4..6c0c4bc50d 100644 --- a/include/configs/th1520_lpi4a.h +++ b/include/configs/th1520_lpi4a.h @@ -17,6 +17,18 @@ /* Environment options */
#define CFG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x82000000\0" \ + "kernel_comp_addr_r=0x88000000\0" \ + "kernel_comp_size=0x4000000\0" \ + "ramdisk_addr_r=0x8d300000\0" \ + "fdt_addr_r=0x8e000000\0" \ + "fdt_addr_fixed=0x20000000\0" \ + "scriptaddr=0x8e400000\0" \ + "scriptfile=uEnv_light_lpi4a.txt\0" \ + "devtype=mmc\0" \ + "devnum=0\0" \ + "bootpart=2\0" \ + "bootcmd=ext4load mmc ${devnum}:${bootpart} ${scriptaddr} ${scriptfile}; env import -t ${scriptaddr} ${filesize};boot\0" \ "PS1=[LPi4A]# \0"
#endif /* __TH1520_LPI4A_H */
It would be really good to see this moved over to using standard boot and plain text environment instead of adding to the technical debt here, thanks.
Nils Le Roux
wefu@redhat.com
