[PATCH v5 17/20] spl: nor: add lzma decompression support for legacy image
This patch adds support for decompressing LZMA compressed u-boot payload in legacy uImage format.
Using this patch together with u-boot-lzma.img is useful for NOR flashes as they can reduce the size and load time of u-boot payload.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: removed unused code. add description for cache flushing --- common/spl/spl_nor.c | 51 +++++++++++++++++++++++++++++++++++++++----- 1 file changed, 46 insertions(+), 5 deletions(-)
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index b1e79b9ded..b8e133e7b6 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -4,8 +4,17 @@ */
#include <common.h> +#include <cpu_func.h> #include <spl.h>
+#include <lzma/LzmaTypes.h> +#include <lzma/LzmaDec.h> +#include <lzma/LzmaTools.h> + +#ifndef CONFIG_SYS_BOOTM_LEN +#define CONFIG_SYS_BOOTM_LEN (8 << 20) +#endif + static ulong spl_nor_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) { @@ -27,6 +36,9 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, int ret; __maybe_unused const struct image_header *header; __maybe_unused struct spl_load_info load; + __maybe_unused SizeT lzma_len; + struct image_header hdr; + uintptr_t dataptr;
/* * Loading of the payload to SDRAM is done with skipping of @@ -107,14 +119,43 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, spl_nor_get_uboot_base()); }
- ret = spl_parse_image_header(spl_image, - (const struct image_header *)spl_nor_get_uboot_base()); + /* Payload image may not be aligned, so copy it for safety. */ + memcpy(&hdr, (void *)spl_nor_get_uboot_base(), sizeof(hdr)); + ret = spl_parse_image_header(spl_image, &hdr); if (ret) return ret;
- memcpy((void *)(unsigned long)spl_image->load_addr, - (void *)(spl_nor_get_uboot_base() + sizeof(struct image_header)), - spl_image->size); + dataptr = spl_nor_get_uboot_base() + sizeof(struct image_header); + + switch (image_get_comp(&hdr)) { + case IH_COMP_NONE: + memmove((void *)(unsigned long)spl_image->load_addr, + (void *)dataptr, spl_image->size); + break; +#if IS_ENABLED(CONFIG_SPL_LZMA) + case IH_COMP_LZMA: + lzma_len = CONFIG_SYS_BOOTM_LEN; + + ret = lzmaBuffToBuffDecompress((void *)spl_image->load_addr, + &lzma_len, (void *)dataptr, + spl_image->size); + + if (ret) { + printf("LZMA decompression error: %d\n", ret); + return ret; + } + + spl_image->size = lzma_len; + break; +#endif + default: + debug("Compression method %s is not supported\n", + genimg_get_comp_short_name(image_get_comp(&hdr))); + return -EINVAL; + } + + /* Flush instruction cache */ + flush_cache((unsigned long)spl_image->load_addr, spl_image->size);
return 0; }
This is v5. What has changed since v4?
uintptr_t dataptr; /* * Loading of the payload to SDRAM is done with skipping of
spl_image->size);
case IH_COMP_NONE:
break;
case IH_COMP_LZMA:
spl_image->size);
Is using CONFIG_SYS_BOOTM_LEN correct here at all? The name says it is used for bootm but now it is used for SPL loading U-Boot as well. How do we know this is the available memory size for both use cases? (And no, you're not adding this, it is being used in spl_fit.c already. Still, I'm not sure this is correct.)
if (ret) {
return ret;
break;
default:
return -EINVAL;
Is this "add description for cache flushing" mentioned in the log above? I can see from the function name that you're flushing cache. Only I still don't see why this is necessary here (but not in the rest of the code where SPL starts a U-Boot image).
flush_cache((unsigned long)spl_image->load_addr, spl_image->size); return 0;
2.17.1
<snip>
I just wanted to inform you that I'm working on a patchset, making this lzma decompression for legacy images more generic. So that this patchset which is pending for quite a while can be integrated hopefully in the next merge window.
I'll post the complete patchset in v6 with my changes later today...
Thanks, Stefan
Simon Goldschmidt
Stefan Roese
Weijie Gao
