[U-Boot] [PATCH 1/2] mpc5200: a3m071/a4m2k: Fix problem with increased global_data struct
The v2013.04 release has this patch set included:
5cb48582 "Add architecture-specific global data"
With this, the global_data struct is now common and new variables have been added. Resulting in a bigger struct. Unfortunately the currently allocated 128 bytes are just a bit too small for this new struct. So lets increase the reserved space to solve this issue.
Please note that this problem might hit some other platforms which currently reserve a tight space of 128 bytes for the global_data struct!
Signed-off-by: Stefan Roese sr@denx.de --- include/configs/a3m071.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index 13f3226..b0264c2 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -121,8 +121,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE
- -#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_SIZE 256 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
Also move the environment offset a bit to allow bigger u-boot images.
Signed-off-by: Stefan Roese sr@denx.de --- include/configs/a3m071.h | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index b0264c2..b2d3642 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -88,7 +88,10 @@ */ #define CONFIG_SYS_FLASH_BASE 0xfc000000 #define CONFIG_SYS_FLASH_SIZE 0x02000000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x80000) +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256
The changes to a3m071/a4m2k in summary are: - Enable CAN1 on I2C in GPS Port Configuration - Enable SPI on PSC2 - Activate network console - New flash partitioning - Fix some typos - Pass host name to Linux - Change rootfs to squashfs,jffs2 - Enable UBI/UBIFS support - Enable FIT support
Signed-off-by: Stefan Roese sr@denx.de --- v2: - Not only redundant env but also some other fixes and updates included - Therefore the patch subject has been changed
board/a3m071/a3m071.c | 26 +++++++++++---- include/configs/a3m071.h | 87 ++++++++++++++++++++++++++++++++++-------------- 2 files changed, 82 insertions(+), 31 deletions(-)
diff --git a/board/a3m071/a3m071.c b/board/a3m071/a3m071.c index 0f9f883..c62ba62 100644 --- a/board/a3m071/a3m071.c +++ b/board/a3m071/a3m071.c @@ -8,7 +8,7 @@ * (C) Copyright 2006 * MicroSys GmbH * - * Copyright 2012 Stefan Roese sr@denx.de + * Copyright 2012-2013 Stefan Roese sr@denx.de * * See file CREDITS for list of people who contributed to this * project. @@ -241,12 +241,26 @@ void spl_board_init(void)
/* And write new value back to register */ out_be32(&mm->ipbi_ws_ctrl, val); -#endif
- /* - * No need to change the pin multiplexing (MPC5XXX_GPS_PORT_CONFIG) - * as all 3 config versions (failsave level) have the same setup. - */ + + /* Setup pin multiplexing */ + if (failsavelevel == 2) { + /* fpga-version ok */ +#if defined(CONFIG_SYS_GPS_PORT_CONFIG_2) + out_be32(&gpio->port_config, CONFIG_SYS_GPS_PORT_CONFIG_2); +#endif + } else if (failsavelevel == 1) { + /* digiboard-version ok - fpga not */ +#if defined(CONFIG_SYS_GPS_PORT_CONFIG_1) + out_be32(&gpio->port_config, CONFIG_SYS_GPS_PORT_CONFIG_1); +#endif + } else { + /* full failsave-mode */ +#if defined(CONFIG_SYS_GPS_PORT_CONFIG) + out_be32(&gpio->port_config, CONFIG_SYS_GPS_PORT_CONFIG); +#endif + } +#endif
/* * Setup gpio_wkup_7 as watchdog AS INPUT to disable it - see diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index bcf3853..f8832f4 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -1,5 +1,5 @@ /* - * Copyright 2012 Stefan Roese sr@denx.de + * Copyright 2012-2013 Stefan Roese sr@denx.de * * See file CREDITS for list of people who contributed to this * project. @@ -59,6 +59,38 @@ #define CONFIG_CMD_CACHE #define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO +#define CONFIG_CMD_DHCP +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_SERVERIP +#define CONFIG_BOOTP_MAY_FAIL +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_SERVERIP +#define CONFIG_NET_RETRY_COUNT 3 +#define CONFIG_CMD_LINK_LOCAL +#define CONFIG_NETCONSOLE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_CMD_PING +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_PARTITIONS /* needed for UBI */ +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=fc000000.flash" +#define MTDPARTS_DEFAULT "mtdparts=fc000000.flash:512k(u-boot)," \ + "256k(env)," \ + "128k(hwinfo)," \ + "1M(nvramsim)," \ + "128k(dtb)," \ + "5M(kernel)," \ + "128k(sysinfo)," \ + "7552k(root)," \ + "4M(app)," \ + "13568k(data)" +#define CONFIG_LZO /* needed for UBI */ +#define CONFIG_RBTREE /* needed for UBI */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_FIT
/* * IPB Bus clocking configuration. @@ -88,7 +120,7 @@ */ #define CONFIG_SYS_FLASH_BASE 0xfc000000 #define CONFIG_SYS_FLASH_SIZE 0x02000000 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x80000)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256 @@ -109,6 +141,8 @@ #define CONFIG_ENV_SIZE 0x10000 #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
/* * Memory map @@ -127,8 +161,8 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
-#define CONFIG_SYS_MONITOR_LEN (256 << 10) -#define CONFIG_SYS_MALLOC_LEN (1 << 20) +#define CONFIG_SYS_MONITOR_LEN (512 << 10) +#define CONFIG_SYS_MALLOC_LEN (4 << 20) #define CONFIG_SYS_BOOTMAPSZ (8 << 20)
/* @@ -154,14 +188,14 @@ */
#ifdef CONFIG_A4M2K -#define CONFIG_SYS_GPS_PORT_CONFIG 0x0005C805 +#define CONFIG_SYS_GPS_PORT_CONFIG 0x1005C805 #else /* for failsave-level 0 - full failsave */ #define CONFIG_SYS_GPS_PORT_CONFIG 0x1005C005 /* for failsave-level 1 - only digiboard ok */ -#define CONFIG_SYS_GPS_PORT_CONFIG_1 0x1005C005 +#define CONFIG_SYS_GPS_PORT_CONFIG_1 0x1005C065 /* for failsave-level 2 - all ok */ -#define CONFIG_SYS_GPS_PORT_CONFIG_2 0x1005C005 +#define CONFIG_SYS_GPS_PORT_CONFIG_2 0x1005C065 #endif
#define CONFIG_WDOG_GPIO_PIN GPIO_WKUP_7 @@ -171,10 +205,10 @@
/* * Configuration matrix - * MSB LSB + * MSB LSB * failsave 0 0x1005C005 00010000000001011100000000000101 ( full failsave ) - * failsave 1 0x1005C005 00010000000001011100000000000101 ( digib.-ver ok ) - * failsave 2 0x1005C005 00010000000001011100000000000101 ( all ok ) + * failsave 1 0x1005C065 00010000000001011100000001100101 ( digib.-ver ok ) + * failsave 2 0x1005C065 00010000000001011100000001100101 ( all ok ) * || ||| || | ||| | | | | * || ||| || | ||| | | | | bit rev name * ++-+++-++--+---+++-+---+---+---+- 0 31 CS1 @@ -310,10 +344,12 @@ * Environment Configuration */
-#define CONFIG_BOOTDELAY 0 /* -1 disables auto-boot */ +#define CONFIG_BOOTDELAY 3 /* -1 disables auto-boot */ #undef CONFIG_BOOTARGS #define CONFIG_ZERO_BOOTDELAY_CHECK
+#define CONFIG_SYS_AUTOLOAD "n" + #define CONFIG_PREBOOT "echo;" \ "echo Type "run flash_mtd" to boot from flash with mtd filesystem;" \ "echo Type "run net_nfs" to boot from tftp with nfs filesystem;" \ @@ -321,11 +357,10 @@
-#define CONFIG_SYS_OS_BASE 0xfc080000 -#define CONFIG_SYS_FDT_BASE 0xfc060000 +#define CONFIG_SYS_OS_BASE 0xfc200000 +#define CONFIG_SYS_FDT_BASE 0xfc1e0000
#define CONFIG_EXTRA_ENV_SETTINGS \ - "hostname=" __stringify(CONFIG_HOSTNAME) "\0" \ "netdev=eth0\0" \ "verify=no\0" \ "loadaddr=200000\0" \ @@ -342,29 +377,31 @@ "nfsargs=setenv bootargs root=/dev/nfs rw " \ "nfsroot=${serverip}:${rootpath}\0" \ "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "mtdargs=setenv bootargs root=/dev/mtdblock4 rw rootfstype=jffs2\0" \ + "mtdargs=setenv bootargs root=/dev/mtdblock7 " \ + "rootfstype=squashfs,jffs2\0" \ + "addhost=setenv bootargs ${bootargs} " \ + "hostname=${hostname}\0" \ "addip=setenv bootargs ${bootargs} " \ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off panic=1\0" \ "addtty=setenv bootargs ${bootargs} " \ "console=${consoledev},${baudrate}\0" \ - "flash_nfs=run nfsargs addip addtty;" \ - "bootm ${kernel_addr} - ${fdtaddr}\0" \ - "flash_mtd=run mtdargs addip addtty;" \ - "bootm ${kernel_addr} - ${fdtaddr}\0" \ - "flash_self=run ramargs addip addtty;" \ + "flash_nfs=run nfsargs addip addtty addhost;" \ + "bootm ${kernel_addr} - ${fdt_addr}\0" \ + "flash_mtd=run mtdargs addip addtty addhost;" \ + "bootm ${kernel_addr} - ${fdt_addr}\0" \ + "flash_self=run ramargs addip addtty addhost;" \ "bootm ${kernel_addr} ${ramdisk_addr} ${fdt_addr}\0" \ "net_nfs=tftp ${kernel_addr_r} ${bootfile};" \ "tftp ${fdt_addr_r} ${fdtfile};" \ - "run nfsargs addip addtty;" \ + "run nfsargs addip addtty addhost;" \ "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ "load=tftp ${loadaddr} " __stringify(CONFIG_HOSTNAME) \ "/u-boot-img.bin\0" \ - "update=protect off fc000000 fc03ffff; " \ - "era fc000000 fc03ffff; cp.b ${loadaddr} fc000000 40000\0" \ + "update=protect off fc000000 fc07ffff; " \ + "era fc000000 fc07ffff;" \ + "cp.b ${loadaddr} fc000000 ${filesize}\0" \ "upd=run load;run update\0" \ - "bootdelay=3\0" \ - "bootcmd=run net_nfs\0" \ ""
#define CONFIG_BOOTCOMMAND "run flash_mtd"
Dear Stefan Roese,
- Fix some typos
v2:
Applied, thanks.
This patch now uses the automatically generated struct size instead to not run into this problem again.
Signed-off-by: Stefan Roese sr@denx.de --- v2: - Use automatically generated struct size instead instead of a fixed value
include/configs/a3m071.h | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index 13f3226..bcf3853 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -121,10 +121,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE
- -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
Dear Stefan Roese,
v2:
Applied, thanks.
Stefan Roese
