RE: [U-Boot-Users] Using a second I2C interface
I've can post a diff to some code we use to do this. I didn't look at it to closely, but it has worked well. Select a device, then standard commands go to it.
Regards, Richard W.
A clean design should allow to switch I2C busses usign a command; additionally, I think we should try to stay backward-compatible with the existing code. Eventually this is not too difficult: similar to the "ide" or "usb" commands we could create a new command "i2c device" which takes as argument the number of the I2C bus which shal become the current (= active) bus. Then all existing I2C related commands can be left unchanged (and "i2c device" without arguments should of course print the ID of the current bus).
In parallel, existing I2C commands could be changed to migrate to a new "i2c" group of commands: "imd" would become "i2c md", "imw" becomes "i2c mw", "iprobe" becomes "i2c probe", etc. For some (long) transition period old and new commands could be provided in parallel (at least optionally). Later, the old syntax could be dropped.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Ever try. Ever fail. No matter. Try again. Fail again. Fail better. -- S. Beckett
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=k&kid%120709&bid&3057&da... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Woodruff, Richard
