UEFI update files missing on sandbox?
Hi Sughosh,
I thought that all your patches were merged but now when I build sandbox I don't see the capsule-update files generated. Is there something missing?
hi Simon,
On Sun, 10 Sept 2023 at 04:10, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
The building of the EFI capsules was moved to the corresponding test setup. This was based on feedback from Tom Rini [1], where he had suggested that instead of having the binman nodes for the capsules as part of the sandbox dtb, it should rather be highlighted in the document.
-sughosh
[1] - https://lists.denx.de/pipermail/u-boot/2023-August/526987.html
Hi Sughosh,
On Sun, 10 Sept 2023 at 04:54, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Simon,
Hi Sughosh,
Hmmm that was not how I was hoping it would work.
Is there a way to make the build create the files?
...I just found efi_capsule_data()
I really don't like this at all...it is running a part of the build system in the test. We have to do this in some cases, e.g. for tracing we must run with a special build of sandbox, but it should not be necessary for EFI capsules.
I would really like the sandbox build to produce the capsules needed for tests, without any extra effort. As it is, there is no way to try this out.
-sughosh
Hi Sughosh,
On Sun, 10 Sept 2023 at 13:13, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
hi Simon,
Hi Sughosh,
How about we add a single capsule update to the sandbox build, so that it produces an update file containing U-Boot? Is that easy to do?
hi Simon,
On Wed, 13 Sept 2023 at 23:37, Simon Glass sjg@chromium.org wrote:
Hi Sughosh,
Hi Sughosh,
hi Simon,
Hi Sughosh,
Not a difficult thing at all. But is Tom okay with this? I moved the capsule generation to the tests based on his feedback. So I would like to hear what he has to say on this. I don't want to keep doing this again and again.
-sughosh
Sughosh Ganu
