[U-Boot] [UBOOT PATCH] arasan: nfc: Add initial nand driver support for arasan
Added initial nand driver support for arasan nand flash controller.This supports nand erase,nand read, nand write This uses the hardware ECC for read and write operations
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/arasan_nfc.c | 1187 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 1188 insertions(+) create mode 100644 drivers/mtd/nand/arasan_nfc.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 347ea62..9080835 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -66,6 +66,7 @@ obj-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o obj-$(CONFIG_NAND_OMAP_ELM) += omap_elm.o obj-$(CONFIG_NAND_PLAT) += nand_plat.o obj-$(CONFIG_NAND_DOCG4) += docg4.o +obj-$(CONFIG_ARASAN_NFC) += arasan_nfc.o
else # minimal SPL drivers
diff --git a/drivers/mtd/nand/arasan_nfc.c b/drivers/mtd/nand/arasan_nfc.c new file mode 100644 index 0000000..3eaab8f --- /dev/null +++ b/drivers/mtd/nand/arasan_nfc.c @@ -0,0 +1,1187 @@ +/* + * Arasan NAND Flash Controller Driver + * + * Copyright (C) 2014 - 2015 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/nand.h> +#include <linux/mtd/partitions.h> +#include <linux/mtd/nand_ecc.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <nand.h> + +struct arasan_nand_info { +#ifdef CONFIG_MTD_PARTITIONS + struct mtd_partition *parts; +#endif + void __iomem *nand_base; + u32 page; +}; + +struct nand_regs { + u32 pkt_reg; + u32 memadr_reg1; + u32 memadr_reg2; + u32 cmd_reg; + u32 pgm_reg; + u32 intsts_enr; + u32 intsig_enr; + u32 intsts_reg; + u32 rdy_busy; + u32 cms_sysadr_reg; + u32 flash_sts_reg; + u32 tmg_reg; + u32 buf_dataport; + u32 ecc_reg; + u32 ecc_errcnt_reg; + u32 ecc_sprcmd_reg; + u32 errcnt_1bitreg; + u32 errcnt_2bitreg; + u32 errcnt_3bitreg; + u32 errcnt_4bitreg; + u32 dma_sysadr0_reg; + u32 dma_bufbdry_reg; + u32 cpu_rls_reg; + u32 errcnt_5bitreg; + u32 errcnt_6bitreg; + u32 errcnt_7bitreg; + u32 errcnt_8bitreg; + u32 data_if_reg; +}; +#define arasan_nand_base ((struct nand_regs *)ARASAN_NAND_BASEADDR) + +struct arasan_nand_command_format { + u8 cmd1; + u8 cmd2; + u8 addr_cycles; + u32 pgm; +}; + +#define ONDIE_ECC_FEATURE_ADDR 0x90 + +#define ARASAN_PROG_RD_MASK 0x00000001 +#define ARASAN_PROG_BLK_ERS_MASK 0x00000004 +#define ARASAN_PROG_RD_ID_MASK 0x00000040 +#define ARASAN_PROG_RD_STS_MASK 0x00000008 +#define ARASAN_PROG_PG_PROG_MASK 0x00000010 +#define ARASAN_PROG_RD_PARAM_PG_MASK 0x00000080 +#define ARASAN_PROG_RST_MASK 0x00000100 +#define ARASAN_PROG_GET_FTRS_MASK 0x00000200 +#define ARASAN_PROG_SET_FTRS_MASK 0x00000400 +#define ARASAN_PROG_CHNG_ROWADR_END_MASK 0x00400000 + +#define ARASAN_NAND_CMD_ECC_ON_MASK 0x80000000 +#define ARASAN_NAND_CMD_CMD12_MASK 0xFFFF +#define ARASAN_NAND_CMD_PG_SIZE_MASK 0x3800000 +#define ARASAN_NAND_CMD_PG_SIZE_SHIFT 23 +#define ARASAN_NAND_CMD_CMD2_SHIFT 8 +#define ARASAN_NAND_CMD_ADDR_CYCL_MASK 0x70000000 +#define ARASAN_NAND_CMD_ADDR_CYCL_SHIFT 28 + +#define ARASAN_NAND_MEM_ADDR1_PAGE_MASK 0xFFFF0000 +#define ARASAN_NAND_MEM_ADDR1_COL_MASK 0xFFFF +#define ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT 16 +#define ARASAN_NAND_MEM_ADDR2_PAGE_MASK 0xFF +#define ARASAN_NAND_MEM_ADDR2_CS_MASK 0xC0000000 +#define ARASAN_NAND_MEM_ADDR2_BCH_MASK 0xE000000 +#define ARASAN_NAND_MEM_ADDR2_BCH_SHIFT 25 + +#define ARASAN_NAND_INT_STS_ERR_EN_MASK 0x10 +#define ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK 0x08 +#define ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK 0x02 +#define ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK 0x01 +#define ARASAN_NAND_INT_STS_XFR_CMPLT_MASK 0x04 + +#define ARASAN_NAND_PKT_REG_PKT_CNT_MASK 0xFFF000 +#define ARASAN_NAND_PKT_REG_PKT_SIZE_MASK 0x7FF +#define ARASAN_NAND_PKT_REG_PKT_CNT_SHFT 12 + +#define ARASAN_NAND_ROW_ADDR_CYCL_MASK 0x0F +#define ARASAN_NAND_COL_ADDR_CYCL_MASK 0xF0 +#define ARASAN_NAND_COL_ADDR_CYCL_SHIFT 4 + +#define ARASAN_NAND_PKTSIZE_1K 1024 +#define ARASAN_NAND_PKTSIZE_512 512 + +#define ARASAN_NAND_POLL_TIMEOUT 1000000 +#define ARASAN_NAND_INVALID_ADDR_CYCL 0xFF + +struct arasan_nand_command_format *curr_cmd; + +typedef enum { + NAND_ADDR_CYCL_NONE, + NAND_ADDR_CYCL_ONE, + NAND_ADDR_CYCL_ROW, + NAND_ADDR_CYCL_COL, + NAND_ADDR_CYCL_BOTH, +} addr_cycles_t; + +static struct arasan_nand_command_format arasan_nand_commands[] = { + {NAND_CMD_READ0, NAND_CMD_READSTART, NAND_ADDR_CYCL_BOTH, + ARASAN_PROG_RD_MASK}, + {NAND_CMD_RNDOUT, NAND_CMD_RNDOUTSTART, NAND_ADDR_CYCL_COL, + ARASAN_PROG_RD_MASK}, + {NAND_CMD_READID, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_RD_ID_MASK}, + {NAND_CMD_STATUS, NAND_CMD_NONE, NAND_ADDR_CYCL_NONE, + ARASAN_PROG_RD_STS_MASK}, + {NAND_CMD_SEQIN, NAND_CMD_PAGEPROG, NAND_ADDR_CYCL_BOTH, + ARASAN_PROG_PG_PROG_MASK}, + {NAND_CMD_RNDIN, NAND_CMD_NONE, NAND_ADDR_CYCL_COL, + ARASAN_PROG_CHNG_ROWADR_END_MASK}, + {NAND_CMD_ERASE1, NAND_CMD_ERASE2, NAND_ADDR_CYCL_ROW, + ARASAN_PROG_BLK_ERS_MASK}, + {NAND_CMD_RESET, NAND_CMD_NONE, NAND_ADDR_CYCL_NONE, + ARASAN_PROG_RST_MASK}, + {NAND_CMD_PARAM, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_RD_PARAM_PG_MASK}, + {NAND_CMD_GET_FEATURES, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_GET_FTRS_MASK}, + {NAND_CMD_SET_FEATURES, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_SET_FTRS_MASK}, + {NAND_CMD_NONE, NAND_CMD_NONE, NAND_ADDR_CYCL_NONE, 0}, +}; + +struct arasan_ecc_matrix { + u32 pagesize; + u8 ecc_codeword_size; + u8 eccbits; + u8 slcmlc; + u16 eccaddr; + u16 eccsize; +}; + +static const struct arasan_ecc_matrix ecc_matrix[] = { + {512, 9, 1, 0, 0x20D, 0x3}, + {512, 9, 4, 1, 0x209, 0x7}, + {512, 9, 8, 1, 0x203, 0xD}, + /* + * 2K byte page + */ + {2048, 9, 1, 0, 0x834, 0xC}, + {2048, 9, 4, 1, 0x826, 0x1A}, + {2048, 9, 8, 1, 0x80c, 0x34}, + {2048, 9, 12, 1, 0x822, 0x4E}, + {2048, 9, 16, 1, 0x808, 0x68}, + {2048, 10, 24, 1, 0x81c, 0x54}, + /* + * 4K byte page + */ + {4096, 9, 1, 0, 0x1068, 0x18}, + {4096, 9, 4, 1, 0x104c, 0x34}, + {4096, 9, 8, 1, 0x1018, 0x68}, + {4096, 9, 12, 1, 0x1044, 0x9C}, + {4096, 9, 16, 1, 0x1010, 0xD0}, + {4096, 10, 24, 1, 0x1038, 0xA8}, + /* + * 8K byte page + */ + {8192, 9, 1, 0, 0x20d0, 0x30}, + {8192, 9, 4, 1, 0x2098, 0x68}, + {8192, 9, 8, 1, 0x2030, 0xD0}, + {8192, 9, 12, 1, 0x2088, 0x138}, + {8192, 9, 16, 1, 0x2020, 0x1A0}, + {8192, 24, 10, 1, 0x2070, 0x150}, + /* + * 16K byte page + */ + {16384, 9, 1, 0, 0x4460, 0x60}, + {16384, 9, 4, 1, 0x43f0, 0xD0}, + {16384, 9, 8, 1, 0x4320, 0x1A0}, + {16384, 9, 12, 1, 0x4250, 0x270}, + {16384, 9, 16, 1, 0x4180, 0x340}, + {16384, 10, 24, 1, 0x4220, 0x2A0} +}; + +u32 buf_data[16384]; +u32 buf_index = 0; + +static struct nand_ecclayout nand_oob; + +static void arasan_nand_select_chip(struct mtd_info *mtd, int chip) +{ +} + +static void arasan_nand_enable_ecc(void) +{ + u32 reg_val; + + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val |= ARASAN_NAND_CMD_ECC_ON_MASK; + + writel(reg_val, &arasan_nand_base->cmd_reg); +} + +static u8 arasan_nand_get_addrcycle(struct mtd_info *mtd) +{ + u8 addrcycles; + struct nand_chip *chip = mtd->priv; + + switch (curr_cmd->addr_cycles) { + case NAND_ADDR_CYCL_NONE: + addrcycles = 0; + break; + case NAND_ADDR_CYCL_ONE: + addrcycles = 1; + break; + case NAND_ADDR_CYCL_ROW: + addrcycles = chip->onfi_params.addr_cycles & + ARASAN_NAND_ROW_ADDR_CYCL_MASK; + break; + case NAND_ADDR_CYCL_COL: + addrcycles = (chip->onfi_params.addr_cycles & + ARASAN_NAND_COL_ADDR_CYCL_MASK) >> + ARASAN_NAND_COL_ADDR_CYCL_SHIFT; + break; + case NAND_ADDR_CYCL_BOTH: + addrcycles = chip->onfi_params.addr_cycles & + ARASAN_NAND_ROW_ADDR_CYCL_MASK; + addrcycles += (chip->onfi_params.addr_cycles & + ARASAN_NAND_COL_ADDR_CYCL_MASK) >> + ARASAN_NAND_COL_ADDR_CYCL_SHIFT; + break; + default: + addrcycles = ARASAN_NAND_INVALID_ADDR_CYCL; + break; + } + return addrcycles; +} + +static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) +{ + struct nand_chip *chip = mtd->priv; + u32 reg_val, i, pktsize, pktnum; + u32 *bufptr = (u32 *)buf; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u32 rdcount = 0; + u8 addr_cycles; + + if (chip->ecc_step_ds >= ARASAN_NAND_PKTSIZE_1K) + pktsize = ARASAN_NAND_PKTSIZE_1K; + else + pktsize = ARASAN_NAND_PKTSIZE_512; + + if (size%pktsize) + pktnum = size/pktsize + 1; + else + pktnum = size/pktsize; + + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_ERR_EN_MASK | + ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (pktnum << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | + pktsize; + writel(reg_val, &arasan_nand_base->pkt_reg); + + arasan_nand_enable_ecc(); + addr_cycles = arasan_nand_get_addrcycle(mtd); + writel((NAND_CMD_RNDOUTSTART << 8) | NAND_CMD_RNDOUT | + (addr_cycles << 28), &arasan_nand_base->ecc_sprcmd_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (rdcount < pktnum) { + timeout = ARASAN_NAND_POLL_TIMEOUT; + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK) && timeout) { + timeout--; + } + if (!timeout) { + puts("arasan_read_page: timedout:Buff RDY\n"); + return -1; + } + + rdcount++; + + if (pktnum == rdcount) { + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + } else { + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_reg); + + for (i = 0; i < pktsize/4; i++) + bufptr[i] = readl(&arasan_nand_base->buf_dataport); + + + bufptr += pktsize/4; + + if (rdcount >= pktnum) + break; + + writel(ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + + timeout = ARASAN_NAND_POLL_TIMEOUT; + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + if (!timeout) { + puts("arasan rd_page timedout:Xfer CMPLT\n"); + return -1; + } + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); + + if (readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK) { + printf("arasan rd_page:sbiterror\n"); + return -1; + } + + if (readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_ERR_EN_MASK) { + mtd->ecc_stats.failed++; + printf("arasan rd_page:multibiterror\n"); + return -1; + } + + return 0; +} + +static int arasan_nand_read_page_hwecc(struct mtd_info *mtd, + struct nand_chip *chip, u8 *buf, int oob_required, int page) +{ + int status; + + status = arasan_nand_read_page(mtd, buf, (mtd->writesize)); + + if (oob_required) + chip->ecc.read_oob(mtd, chip, page); + + return status; +} + +static void arasan_nand_fill_tx(const u8 *buf, int len) +{ + u32 *nand = &arasan_nand_base->buf_dataport; + + if (((unsigned long)buf & 0x3) != 0) { + if (((unsigned long)buf & 0x1) != 0) { + if (len) { + writeb(*buf, nand); + buf += 1; + len--; + } + } + + if (((unsigned long)buf & 0x3) != 0) { + if (len >= 2) { + writew(*(u16 *)buf, nand); + buf += 2; + len -= 2; + } + } + } + + while (len >= 4) { + writel(*(u32 *)buf, nand); + buf += 4; + len -= 4; + } + + if (len) { + if (len >= 2) { + writew(*(u16 *)buf, nand); + buf += 2; + len -= 2; + } + + if (len) + writeb(*buf, nand); + } +} + +static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, + struct nand_chip *chip, const u8 *buf, int oob_required) +{ + u32 reg_val, i, pktsize, pktnum; + u32 *bufptr = (u32 *)buf; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u32 size = mtd->writesize; + u32 rdcount = 0; + u8 column_addr_cycles; + struct arasan_nand_info *xnand = chip->priv; + + if (chip->ecc_step_ds >= ARASAN_NAND_PKTSIZE_1K) + pktsize = ARASAN_NAND_PKTSIZE_1K; + else + pktsize = ARASAN_NAND_PKTSIZE_512; + + if (size % pktsize) + pktnum = size/pktsize + 1; + else + pktnum = size/pktsize; + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (pktnum << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | pktsize; + writel(reg_val, &arasan_nand_base->pkt_reg); + + arasan_nand_enable_ecc(); + column_addr_cycles = (chip->onfi_params.addr_cycles & + ARASAN_NAND_COL_ADDR_CYCL_MASK) >> + ARASAN_NAND_COL_ADDR_CYCL_SHIFT; + writel((NAND_CMD_RNDIN | (column_addr_cycles << 28)), + &arasan_nand_base->ecc_sprcmd_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (rdcount < pktnum) { + timeout = ARASAN_NAND_POLL_TIMEOUT; + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK) && timeout) { + timeout--; + } + + if (!timeout) { + puts("arasan_write_page: timedout:Buff RDY\n"); + return -1; + } + + rdcount++; + + if (pktnum == rdcount) { + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + } else { + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_reg); + + for (i = 0; i < pktsize/4; i++) + writel(bufptr[i], &arasan_nand_base->buf_dataport); + + bufptr += pktsize/4; + + if (rdcount >= pktnum) + break; + + writel(ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + + timeout = ARASAN_NAND_POLL_TIMEOUT; + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + if (!timeout) { + puts("arasan write_page timedout:Xfer CMPLT\n"); + return -1; + } + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK , + &arasan_nand_base->intsts_reg); + + if (oob_required) + chip->ecc.write_oob(mtd, chip, xnand->page); + + return 0; +} + +static int arasan_nand_read_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + chip->cmdfunc(mtd, NAND_CMD_READOOB, 0, page); + chip->read_buf(mtd, chip->oob_poi, (mtd->oobsize)); + + return 0; +} + +static int arasan_nand_write_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + int status = 0; + const u8 *buf = chip->oob_poi; + + chip->cmdfunc(mtd, NAND_CMD_SEQIN, mtd->writesize, page); + chip->write_buf(mtd, buf, (mtd->oobsize)); + + return status; +} + +static void arasan_nand_reset(struct arasan_nand_command_format *curr_cmd) +{ + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u32 cmd_reg = 0; + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + cmd_reg = readl(&arasan_nand_base->cmd_reg); + cmd_reg &= ~ARASAN_NAND_CMD_CMD12_MASK; + + cmd_reg |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + writel(cmd_reg, &arasan_nand_base->cmd_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + if (!timeout) + puts("ERROR:arasan_nand_reset timedout\n"); + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); +} + +static u8 arasan_nand_page(struct mtd_info *mtd) +{ + u8 page_val = 0; + + switch (mtd->writesize) { + case 512: + page_val = 0; + break; + case 2048: + page_val = 1; + break; + case 4096: + page_val = 2; + break; + case 8192: + page_val = 3; + break; + case 16384: + page_val = 4; + break; + case 1024: + page_val = 5; + break; + default: + break; + } + + return page_val; +} + +static void arasan_nand_send_wrcmd(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val, page; + u8 page_val, addr_cycles; + + writel(ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + if (curr_cmd->cmd1 == NAND_CMD_SEQIN) { + reg_val &= ~ARASAN_NAND_CMD_PG_SIZE_MASK; + page_val = arasan_nand_page(mtd); + reg_val |= (page_val << ARASAN_NAND_CMD_PG_SIZE_SHIFT); + } + + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + addr_cycles = arasan_nand_get_addrcycle(mtd); + reg_val |= (addr_cycles << + ARASAN_NAND_CMD_ADDR_CYCL_SHIFT); + writel(reg_val, &arasan_nand_base->cmd_reg); + + if (page_addr == -1) + page_addr = 0; + + page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & + ARASAN_NAND_MEM_ADDR1_PAGE_MASK; + column &= ARASAN_NAND_MEM_ADDR1_COL_MASK; + writel(page|column, &arasan_nand_base->memadr_reg1); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; + reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); + writel(reg_val, &arasan_nand_base->memadr_reg2); + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); +} + +static void arasan_nand_write_buf(struct mtd_info *mtd, const u8 *buf, int len) +{ + u32 reg_val; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + + reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | len; + writel(reg_val, &arasan_nand_base->pkt_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK) && timeout) { + timeout--; + } + + if (!timeout) + puts("ERROR:arasan_nand_write_buf timedout:Buff RDY\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_reg); + + arasan_nand_fill_tx(buf, len); + + timeout = ARASAN_NAND_POLL_TIMEOUT; + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + if (!timeout) + puts("ERROR:arasan_nand_write_buf timedout:Xfer CMPLT\n"); + + writel(readl(&arasan_nand_base->intsts_enr) | + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + writel(readl(&arasan_nand_base->intsts_reg) | + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); +} + +static void arasan_nand_erase(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val, page; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u8 row_addr_cycles; + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + row_addr_cycles = arasan_nand_get_addrcycle(mtd); + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + reg_val |= (row_addr_cycles << + ARASAN_NAND_CMD_ADDR_CYCL_SHIFT); + + writel(reg_val, &arasan_nand_base->cmd_reg); + + page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & + ARASAN_NAND_MEM_ADDR1_PAGE_MASK; + column = page_addr & ARASAN_NAND_MEM_ADDR1_COL_MASK; + writel(page | column, &arasan_nand_base->memadr_reg1); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; + reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); + writel(reg_val, &arasan_nand_base->memadr_reg2); + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + if (!timeout) + puts("ERROR:arasan_nand_erase timedout:Xfer CMPLT\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); +} + +static void arasan_nand_read_status(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u8 addr_cycles; + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + addr_cycles = arasan_nand_get_addrcycle(mtd); + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + reg_val |= (addr_cycles << + ARASAN_NAND_CMD_ADDR_CYCL_SHIFT); + + writel(reg_val, &arasan_nand_base->cmd_reg); + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | 1; + writel(reg_val, &arasan_nand_base->pkt_reg); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); + + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + + if (!timeout) + puts("ERROR:arasan_nand_read_status timedout:Xfer CMPLT\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); +} + +static void arasan_nand_send_rdcmd(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val, addr_cycles, page; + u8 page_val; + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + + if (curr_cmd->cmd1 == NAND_CMD_RNDOUT || + curr_cmd->cmd1 == NAND_CMD_READ0) { + reg_val &= ~ARASAN_NAND_CMD_PG_SIZE_MASK; + page_val = arasan_nand_page(mtd); + reg_val |= (page_val << ARASAN_NAND_CMD_PG_SIZE_SHIFT); + } + + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + + addr_cycles = arasan_nand_get_addrcycle(mtd); + reg_val |= (addr_cycles << 28); + writel(reg_val, &arasan_nand_base->cmd_reg); + + if (page_addr == -1) + page_addr = 0; + + page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & + ARASAN_NAND_MEM_ADDR1_PAGE_MASK; + column &= ARASAN_NAND_MEM_ADDR1_COL_MASK; + writel(page | column, &arasan_nand_base->memadr_reg1); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; + reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); + writel(reg_val, &arasan_nand_base->memadr_reg2); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); + buf_index = 0; +} + +static u8 arasan_read_byte(void) +{ + u8 *bufptr = (u8 *)&buf_data[0]; + u8 val; + + val = *(bufptr + buf_index); + buf_index++; + + return val; +} + +static void arasan_nand_read_buf(struct mtd_info *mtd, u8 *buf, int size) +{ + u32 reg_val, i; + u32 *bufptr = (u32 *)buf; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | size; + writel(reg_val, &arasan_nand_base->pkt_reg); + + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK) && timeout) { + timeout--; + } + + if (!timeout) + puts("ERROR:arasan_nand_read_buf timedout:Buff RDY\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_reg); + + buf_index = 0; + for (i = 0; i < size / 4; i++) + bufptr[i] = readl(&arasan_nand_base->buf_dataport); + + if (size & 0x03) + bufptr[i] = readl(&arasan_nand_base->buf_dataport); + + timeout = ARASAN_NAND_POLL_TIMEOUT; + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + + if (!timeout) + puts("ERROR:arasan_nand_read_buf timedout:Xfer CMPLT\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); +} + +static u8 arasan_nand_read_byte(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd->priv; + u32 size; + struct nand_onfi_params *p; + + if (buf_index == 0) { + p = &chip->onfi_params; + if (curr_cmd->cmd1 == NAND_CMD_READID) + size = 4; + else if (curr_cmd->cmd1 == NAND_CMD_PARAM) + size = sizeof(struct nand_onfi_params); + else if (curr_cmd->cmd1 == NAND_CMD_RNDOUT) + size = le16_to_cpu(p->ext_param_page_length) * 16; + else if (curr_cmd->cmd1 == NAND_CMD_GET_FEATURES) + size = 4; + else if (curr_cmd->cmd1 == NAND_CMD_STATUS) + return readb(&arasan_nand_base->flash_sts_reg); + else + size = 8; + chip->read_buf(mtd, (u8 *)&buf_data[0], size); + } + + return arasan_read_byte(); +} + +static void arasan_nand_cmd_function(struct mtd_info *mtd, unsigned int command, + int column, int page_addr) +{ + u32 i; + struct nand_chip *chip = mtd->priv; + struct arasan_nand_info *xnand = chip->priv; + + curr_cmd = NULL; + writel(0x4, &arasan_nand_base->intsts_enr); + + if ((command == NAND_CMD_READOOB) && + (mtd->writesize > 512)) { + column += mtd->writesize; + command = NAND_CMD_READ0; + } + + /* Get the command format */ + for (i = 0; (arasan_nand_commands[i].cmd1 != NAND_CMD_NONE || + arasan_nand_commands[i].cmd2 != NAND_CMD_NONE); i++) { + if (command == arasan_nand_commands[i].cmd1) { + curr_cmd = &arasan_nand_commands[i]; + break; + } + } + + if (curr_cmd == NULL) { + printf("Unsupported Command; 0x%x\n", command); + return; + } + + if (curr_cmd->cmd1 == NAND_CMD_RESET) + arasan_nand_reset(curr_cmd); + + if ((curr_cmd->cmd1 == NAND_CMD_READID) || + (curr_cmd->cmd1 == NAND_CMD_PARAM) || + (curr_cmd->cmd1 == NAND_CMD_RNDOUT) || + (curr_cmd->cmd1 == NAND_CMD_GET_FEATURES) || + (curr_cmd->cmd1 == NAND_CMD_READ0)) + arasan_nand_send_rdcmd(curr_cmd, column, page_addr, mtd); + + if ((curr_cmd->cmd1 == NAND_CMD_SET_FEATURES) || + (curr_cmd->cmd1 == NAND_CMD_SEQIN)) { + xnand->page = page_addr; + arasan_nand_send_wrcmd(curr_cmd, column, page_addr, mtd); + } + + if (curr_cmd->cmd1 == NAND_CMD_ERASE1) + arasan_nand_erase(curr_cmd, column, page_addr, mtd); + + if (curr_cmd->cmd1 == NAND_CMD_STATUS) + arasan_nand_read_status(curr_cmd, column, page_addr, mtd); +} + +static void arasan_nand_ecc_init(struct mtd_info *mtd) +{ + u32 found = 0; + u8 bchmodeval = 0; + u32 regval, eccpos_start, i; + struct nand_chip *nand_chip = mtd->priv; + + for (i = 0; i < sizeof(ecc_matrix)/sizeof(struct arasan_ecc_matrix); + i++) { + if ((ecc_matrix[i].pagesize == mtd->writesize) && + ((1 << ecc_matrix[i].ecc_codeword_size) >= + nand_chip->ecc_step_ds)) { + if (ecc_matrix[i].eccbits >= + nand_chip->ecc_strength_ds) { + found = i; + break; + } else { + found = i; + } + } + } + + if (found) { + regval = ecc_matrix[i].eccaddr | (ecc_matrix[i].eccsize << 16) | + (ecc_matrix[i].slcmlc << 27); + writel(regval, &arasan_nand_base->ecc_reg); + + if (ecc_matrix[i].slcmlc) { + switch (ecc_matrix[i].eccbits) { + case 16: + bchmodeval = 0x0; + break; + case 12: + bchmodeval = 0x1; + break; + case 8: + bchmodeval = 0x2; + break; + case 4: + bchmodeval = 0x3; + break; + case 24: + bchmodeval = 0x4; + break; + default: + bchmodeval = 0x0; + } + regval = readl(&arasan_nand_base->memadr_reg2); + regval &= ~ARASAN_NAND_MEM_ADDR2_BCH_MASK; + regval |= (bchmodeval << + ARASAN_NAND_MEM_ADDR2_BCH_SHIFT); + writel(regval, &arasan_nand_base->memadr_reg2); + } + + nand_oob.eccbytes = ecc_matrix[i].eccsize; + eccpos_start = mtd->oobsize - nand_oob.eccbytes; + + for (i = 0; i < nand_oob.eccbytes; i++) + nand_oob.eccpos[i] = eccpos_start + i; + + nand_oob.oobfree[0].offset = 2; + nand_oob.oobfree[0].length = eccpos_start - 2; + + if (ecc_matrix[i].eccbits == 24) + nand_chip->ecc.size = 1024; + else + nand_chip->ecc.size = 512; + + nand_chip->ecc.bytes = ecc_matrix[i].eccsize; + nand_chip->ecc.layout = &nand_oob; + } +} + +static int arasan_nand_init(struct nand_chip *nand_chip, int devnum) +{ + struct arasan_nand_info *xnand; + struct mtd_info *mtd; + u8 maf_id, dev_id; + int err = -1; + u8 get_feature[4]; + u8 set_feature[4] = {0x08, 0x00, 0x00, 0x00}; + int ondie_ecc_enabled = 0; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u32 i; + + xnand = calloc(1, sizeof(struct arasan_nand_info)); + if (!xnand) { + printf("%s: failed to allocate\n", __func__); + return -1; + } + + xnand->nand_base = (void *)ARASAN_NAND_BASEADDR; + mtd = &nand_info[0]; + nand_chip->priv = xnand; + mtd->priv = nand_chip; + + /* Set address of NAND IO lines */ + nand_chip->IO_ADDR_R = (void *)&arasan_nand_base->buf_dataport; + nand_chip->IO_ADDR_W = (void *)&arasan_nand_base->buf_dataport; + + /* Set the driver entry points for MTD */ + nand_chip->cmdfunc = arasan_nand_cmd_function; + nand_chip->select_chip = arasan_nand_select_chip; + nand_chip->read_byte = arasan_nand_read_byte; + + /* Buffer read/write routines */ + nand_chip->read_buf = arasan_nand_read_buf; + nand_chip->write_buf = arasan_nand_write_buf; + nand_chip->bbt_options = NAND_BBT_USE_FLASH; + + writel(0x0, &arasan_nand_base->cmd_reg); + writel(0x0, &arasan_nand_base->pgm_reg); + + /* first scan to find the device and get the page size */ + if (nand_scan_ident(mtd, 1, NULL)) { + printf("%s: nand_scan_ident failed\n", __func__); + goto fail; + } + + mtd->size = nand_chip->chipsize; + + /* Send the command for reading device ID */ + nand_chip->cmdfunc(mtd, NAND_CMD_RESET, -1, -1); + nand_chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); + + /* Read manufacturer and device IDs */ + maf_id = nand_chip->read_byte(mtd); + dev_id = nand_chip->read_byte(mtd); + + if ((maf_id == 0x2c) && ((dev_id == 0xf1) || + (dev_id == 0xa1) || (dev_id == 0xb1) || + (dev_id == 0xaa) || (dev_id == 0xba) || + (dev_id == 0xda) || (dev_id == 0xca) || + (dev_id == 0xac) || (dev_id == 0xbc) || + (dev_id == 0xdc) || (dev_id == 0xcc) || + (dev_id == 0xa3) || (dev_id == 0xb3) || + (dev_id == 0xd3) || (dev_id == 0xc3))) { + nand_chip->cmdfunc(mtd, NAND_CMD_SET_FEATURES, + ONDIE_ECC_FEATURE_ADDR, -1); + + for (i = 0; i < 4; i++) + writeb(set_feature[i], nand_chip->IO_ADDR_W); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + timeout--; + } + + if (!timeout) { + puts("ERROR:arasan_nand_init timedout:Xfer CMPLT\n"); + goto fail; + } + + writel(readl(&arasan_nand_base->intsts_enr) | + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + writel(readl(&arasan_nand_base->intsts_reg) | + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); + + nand_chip->cmdfunc(mtd, NAND_CMD_GET_FEATURES, + ONDIE_ECC_FEATURE_ADDR, -1); + + for (i = 0; i < 4; i++) + get_feature[i] = nand_chip->read_byte(mtd); + + if (get_feature[0] & 0x08) { + debug("%s: OnDie ECC flash\n", __func__); + ondie_ecc_enabled = 1; + } else { + printf("%s: Unable to detect OnDie ECC\n", __func__); + } + } + + if (!ondie_ecc_enabled) { + nand_chip->ecc.mode = NAND_ECC_HW; + nand_chip->ecc.strength = 1; + nand_chip->ecc.hwctl = NULL; + nand_chip->ecc.read_page = arasan_nand_read_page_hwecc; + nand_chip->ecc.write_page = arasan_nand_write_page_hwecc; + nand_chip->ecc.read_oob = arasan_nand_read_oob; + nand_chip->ecc.write_oob = arasan_nand_write_oob; + } + + arasan_nand_ecc_init(mtd); + + if (nand_scan_tail(mtd)) { + printf("%s: nand_scan_tailfailed\n", __func__); + goto fail; + } + if (nand_register(devnum)) { + printf("Nand Register Fail\n"); + goto fail; + } + + return 0; +fail: + kfree(xnand); + return err; +} +static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE]; + +void board_nand_init(void) +{ + struct nand_chip *nand = &nand_chip[0]; + + if (arasan_nand_init(nand, 0)) + puts("NAND init failed\n"); +}
Scott: Any comment on this one?
Thanks, Michal
When will there be a config that enables this, and shouldn't new config options be done in kconfig?
- Arasan NAND Flash Controller Driver
- Copyright (C) 2014 - 2015 Xilinx, Inc.
- SPDX-License-Identifier: GPL-2.0
I believe GPL2+ is preferred for new U-Boot code.
- struct mtd_partition *parts;
No other U-Boot NAND driver references partitions -- why is this one different?
- void __iomem *nand_base;
- u32 page;
+struct nand_regs {
- u32 pkt_reg;
- u32 memadr_reg1;
- u32 memadr_reg2;
- u32 cmd_reg;
- u32 pgm_reg;
- u32 intsts_enr;
- u32 intsig_enr;
- u32 intsts_reg;
- u32 rdy_busy;
- u32 cms_sysadr_reg;
- u32 flash_sts_reg;
- u32 tmg_reg;
- u32 buf_dataport;
- u32 ecc_reg;
- u32 ecc_errcnt_reg;
- u32 ecc_sprcmd_reg;
- u32 errcnt_1bitreg;
- u32 errcnt_2bitreg;
- u32 errcnt_3bitreg;
- u32 errcnt_4bitreg;
- u32 dma_sysadr0_reg;
- u32 dma_bufbdry_reg;
- u32 cpu_rls_reg;
- u32 errcnt_5bitreg;
- u32 errcnt_6bitreg;
- u32 errcnt_7bitreg;
- u32 errcnt_8bitreg;
- u32 data_if_reg;
__iomem
Why is this global?
- u32 pagesize;
- u8 ecc_codeword_size;
- u8 eccbits;
- u8 slcmlc;
- u16 eccaddr;
- u16 eccsize;
- {512, 9, 1, 0, 0x20D, 0x3},
- {512, 9, 4, 1, 0x209, 0x7},
- {512, 9, 8, 1, 0x203, 0xD},
* 2K byte page
- {2048, 9, 1, 0, 0x834, 0xC},
- {2048, 9, 4, 1, 0x826, 0x1A},
- {2048, 9, 8, 1, 0x80c, 0x34},
- {2048, 9, 12, 1, 0x822, 0x4E},
- {2048, 9, 16, 1, 0x808, 0x68},
- {2048, 10, 24, 1, 0x81c, 0x54},
2K pages with more than 64 bytes ECC?
* 4K byte page
- {4096, 9, 1, 0, 0x1068, 0x18},
- {4096, 9, 4, 1, 0x104c, 0x34},
- {4096, 9, 8, 1, 0x1018, 0x68},
- {4096, 9, 12, 1, 0x1044, 0x9C},
- {4096, 9, 16, 1, 0x1010, 0xD0},
- {4096, 10, 24, 1, 0x1038, 0xA8},
* 8K byte page
- {8192, 9, 1, 0, 0x20d0, 0x30},
- {8192, 9, 4, 1, 0x2098, 0x68},
- {8192, 9, 8, 1, 0x2030, 0xD0},
- {8192, 9, 12, 1, 0x2088, 0x138},
- {8192, 9, 16, 1, 0x2020, 0x1A0},
- {8192, 24, 10, 1, 0x2070, 0x150},
* 16K byte page
- {16384, 9, 1, 0, 0x4460, 0x60},
- {16384, 9, 4, 1, 0x43f0, 0xD0},
- {16384, 9, 8, 1, 0x4320, 0x1A0},
- {16384, 9, 12, 1, 0x4250, 0x270},
- {16384, 9, 16, 1, 0x4180, 0x340},
- {16384, 10, 24, 1, 0x4220, 0x2A0}
Can this be reasonably computed at runtime?
Why are these global?
- u8 addrcycles;
- struct nand_chip *chip = mtd->priv;
- switch (curr_cmd->addr_cycles) {
- case NAND_ADDR_CYCL_NONE:
addrcycles = 0;
break;
- case NAND_ADDR_CYCL_ONE:
addrcycles = 1;
break;
- case NAND_ADDR_CYCL_ROW:
break;
- case NAND_ADDR_CYCL_COL:
break;
- case NAND_ADDR_CYCL_BOTH:
break;
- default:
break;
Nothing checks for this invalid value...
- u32 reg_val, i, pktsize, pktnum;
- u32 *bufptr = (u32 *)buf;
- u32 timeout = ARASAN_NAND_POLL_TIMEOUT;
- u32 rdcount = 0;
- u8 addr_cycles;
- if (chip->ecc_step_ds >= ARASAN_NAND_PKTSIZE_1K)
- else
- if (size%pktsize)
Spaces around binary operators, here and elsewhere.
- while (rdcount < pktnum) {
timeout--;
if (!timeout) {
return -1;
Return a proper error code.
- u32 *nand = &arasan_nand_base->buf_dataport;
__iomem
const
- reg_val = readl(&arasan_nand_base->intsts_reg);
- writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK ,
No space before comma
int page)
- int status = 0;
- const u8 *buf = chip->oob_poi;
- chip->cmdfunc(mtd, NAND_CMD_SEQIN, mtd->writesize, page);
- chip->write_buf(mtd, buf, (mtd->oobsize));
Unnecessary parens.
- while (!(readl(&arasan_nand_base->intsts_reg) &
timeout--;
Timeouts should be based on real units of time rather than loop iterations.
- u8 page_val = 0;
- switch (mtd->writesize) {
- case 512:
page_val = 0;
break;
- case 2048:
page_val = 1;
break;
- case 4096:
page_val = 2;
break;
- case 8192:
page_val = 3;
break;
- case 16384:
page_val = 4;
break;
- case 1024:
page_val = 5;
break;
- default:
break;
Either print/return an error or get rid of the default:
- u8 *bufptr = (u8 *)&buf_data[0];
- u8 val;
- val = *(bufptr + buf_index);
- buf_index++;
- return val;
Why was buf_data declared as a u32 array if the only places that use it want a u8 array?
- u32 size;
- struct nand_onfi_params *p;
- if (buf_index == 0) {
size = 4;
size = 4;
else
size = 8;
- return arasan_read_byte();
The distinction between arasan_nand_read_byte() and arasan_read_byte() is not clear from the name. Isn't this whole file dealing with nand?
Why do you read_buf with varying fixed sizes rather than just reading a byte from the dataport? If the answer is performance, that doesn't make sense because read_byte is not used for high-performance paths.
- u32 i;
- struct arasan_nand_info *xnand = chip->priv;
- curr_cmd = NULL;
- writel(0x4, &arasan_nand_base->intsts_enr);
Please define a symbolic constant for 0x4.
- u32 found = 0;
- u8 bchmodeval = 0;
- u32 regval, eccpos_start, i;
- struct nand_chip *nand_chip = mtd->priv;
- for (i = 0; i < sizeof(ecc_matrix)/sizeof(struct arasan_ecc_matrix);
i < ARRAY_SIZE(ecc_matrix)
i++) {
found = i;
break;
} else {
found = i;
You have "found = i" on both sides of the if/else...
- if (found) {
Symbolic constants for 16 and 27
case 16:
bchmodeval = 0x0;
break;
case 12:
bchmodeval = 0x1;
break;
case 8:
bchmodeval = 0x2;
break;
case 4:
bchmodeval = 0x3;
break;
case 24:
bchmodeval = 0x4;
break;
default:
bchmodeval = 0x0;
Again, it's pointless to have a default: that merely turns one bad value into another (and bchmodeval has already been initialized to zero anyway).
- struct arasan_nand_info *xnand;
"x"?
- struct mtd_info *mtd;
- u8 maf_id, dev_id;
- int err = -1;
- u8 get_feature[4];
- u8 set_feature[4] = {0x08, 0x00, 0x00, 0x00};
- int ondie_ecc_enabled = 0;
- u32 i;
- xnand = calloc(1, sizeof(struct arasan_nand_info));
- if (!xnand) {
return -1;
- xnand->nand_base = (void *)ARASAN_NAND_BASEADDR;
__iomem
- mtd = &nand_info[0];
- nand_chip->priv = xnand;
- mtd->priv = nand_chip;
- /* Set address of NAND IO lines */
- nand_chip->IO_ADDR_R = (void *)&arasan_nand_base->buf_dataport;
- nand_chip->IO_ADDR_W = (void *)&arasan_nand_base->buf_dataport;
__iomem
Where do you even use IO_ADDR_R? And why can't the one place you use IO_ADDR_W use buf_dataport instead?
- /* first scan to find the device and get the page size */
- if (nand_scan_ident(mtd, 1, NULL)) {
goto fail;
- mtd->size = nand_chip->chipsize;
- /* Send the command for reading device ID */
- nand_chip->cmdfunc(mtd, NAND_CMD_RESET, -1, -1);
- nand_chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1);
Didn't nand_scan_ident() already read the ID?
- /* Read manufacturer and device IDs */
- maf_id = nand_chip->read_byte(mtd);
- dev_id = nand_chip->read_byte(mtd);
- if ((maf_id == 0x2c) && ((dev_id == 0xf1) ||
Where did this list come from? It feels like any logic that is based on specific NAND chips, rather than the controller, should be in the common NAND code.
Are these chips ONFI-compliant? If not, can you figure out the property you're looking for by decoding the Micron id bytes rather than using a list of devices?
timeout--;
if (!timeout) {
goto fail;
} else {
Please refactor this and elsewhere to reduce long functions.
- if (!ondie_ecc_enabled) {
- arasan_nand_ecc_init(mtd);
- if (nand_scan_tail(mtd)) {
goto fail;
s/tailfailed/tail failed/
- if (nand_register(devnum)) {
goto fail;
+fail:
- kfree(xnand);
- return err;
kfree() but calloc()? Is this code from Linux or not?
-Scott
Michal Simek
Scott Wood
