[U-Boot-Users] Pull request: u-boot-fdt.git
Dear Wolfgang,
The patches by David I've picked up from dtc and applied to track libfdt.
The patches by Kumar improve the "fdt" command.
All patches were posted previously (prior to the merge window opening).
Thanks, gvb
The following changes since commit fdeb932b1c8a3b615463995c3452d30ee0b12a33: Wolfgang Denk (1): Merge branch 'master' of git://www.denx.de/git/u-boot-blackfin
git://www.denx.de/git/u-boot-fdt.git master
David Gibson (5): libfdt: Add fdt_set_name() function libfdt: Add and use a node iteration helper function. libfdt: Fix NOP handling bug in fdt_add_subnode_namelen() libfdt: Trivial cleanup for CHECK_HEADER) libfdt: Remove no longer used code from fdt_node_offset_by_compatible()
Kumar Gala (2): Add sub-commands to fdt Fix fdt boardsetup command parsing
common/cmd_fdt.c | 113 +++++++++++++++++++- include/libfdt.h | 32 ++++++ libfdt/fdt.c | 46 +++++++- libfdt/fdt_ro.c | 277 ++++++++++++++-------------------------------- libfdt/fdt_rw.c | 34 +++++- libfdt/libfdt_internal.h | 7 + 6 files changed, 305 insertions(+), 204 deletions(-)
In message 47E06E47.40402@gmail.com you wrote:
Dear Wolfgang,
Thanks, gvb
Done, thanks.
Jerry Van Baren
