[PATCH] clk/qcom: apq8016: allow apq8016_clk_init_uart() to be called externally
When U-Boot as running as the first stage bootloader on MSM8916 devices, early debug UART requires turning on the clocks (for some reason the pre-loader turns them off?!).
To simplify developing for this platform, allow the apq8016_clk_init_uart() function to be called externally. Developers can call this from the serial_msm debug uart driver to configure the clocks before the driver model is available.
As it is only possible to enable early debug UART in custom builds of U-Boot, this solution at least gives developers the option.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- This patch was meant to be in v5 of my Qualcomm generic board support series[1], but got lost somewhere in the mix.
[1]: https://lore.kernel.org/u-boot/CAFA6WYNXE3x8sKRB8BBpODCfXbZeeVpKPu0-qt7ezsY-... --- drivers/clk/qcom/clock-apq8016.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/qcom/clock-apq8016.c b/drivers/clk/qcom/clock-apq8016.c index 9de0ad5ed32d..e6647f7c41dd 100644 --- a/drivers/clk/qcom/clock-apq8016.c +++ b/drivers/clk/qcom/clock-apq8016.c @@ -102,22 +102,22 @@ static const struct bcr_regs uart2_regs = { .D = BLSP1_UART2_APPS_D, };
/* UART: 115200 */ -static int clk_init_uart(struct msm_clk_priv *priv) +int apq8016_clk_init_uart(phys_addr_t base) { /* Enable AHB clock */ - clk_enable_vote_clk(priv->base, &gcc_blsp1_ahb_clk); + clk_enable_vote_clk(base, &gcc_blsp1_ahb_clk);
/* 7372800 uart block clock @ GPLL0 */ - clk_rcg_set_rate_mnd(priv->base, &uart2_regs, 1, 144, 15625, + clk_rcg_set_rate_mnd(base, &uart2_regs, 1, 144, 15625, CFG_CLK_SRC_GPLL0, 16);
/* Vote for gpll0 clock */ - clk_enable_gpll0(priv->base, &gpll0_vote_clk); + clk_enable_gpll0(base, &gpll0_vote_clk);
/* Enable core clk */ - clk_enable_cbc(priv->base + BLSP1_UART2_APPS_CBCR); + clk_enable_cbc(base + BLSP1_UART2_APPS_CBCR);
return 0; }
@@ -132,9 +132,9 @@ static ulong apq8016_clk_set_rate(struct clk *clk, ulong rate) case GCC_SDCC2_APPS_CLK: /* SDC2 */ return clk_init_sdc(priv, 1, rate); break; case GCC_BLSP1_UART2_APPS_CLK: /* UART2 */ - return clk_init_uart(priv); + return apq8016_clk_init_uart(priv->base); break; default: return 0; }
Applied, thanks!
[1/1] clk/qcom: apq8016: allow apq8016_clk_init_uart() to be called externally commit: cbf3152f6afff25c25aa69ae06488671ca0aa765
Caleb Connolly
