[U-Boot] [PATCH 1/2] AT91: fix TOP9000 built issues
Since I originally made and checked the TOP9000 support patch some changes to mainline broke the built. This small patch fixes this.
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- board/emk/top9000/Makefile | 6 +++--- board/emk/top9000/top9000.c | 2 +- include/configs/top9000.h | 8 ++++++-- 3 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/board/emk/top9000/Makefile b/board/emk/top9000/Makefile index 9b28048..3ac6f14 100644 --- a/board/emk/top9000/Makefile +++ b/board/emk/top9000/Makefile @@ -26,9 +26,9 @@
include $(TOPDIR)/config.mk
-LIB = $(obj)lib$(BOARD).a +LIB = $(obj)lib$(BOARD).o
-COBJS-y += top9000.o +COBJS-y += $(BOARD).o COBJS-$(CONFIG_ATMEL_SPI) += spi.o
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) @@ -36,7 +36,7 @@ OBJS := $(addprefix $(obj),$(COBJS-y)) SOBJS := $(addprefix $(obj),$(SOBJS))
$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS))
clean: rm -f $(SOBJS) $(OBJS) diff --git a/board/emk/top9000/top9000.c b/board/emk/top9000/top9000.c index b0fe2d6..73dd706 100644 --- a/board/emk/top9000/top9000.c +++ b/board/emk/top9000/top9000.c @@ -120,7 +120,7 @@ int board_mmc_getcd(u8 *cd, struct mmc *mmc)
int board_early_init_f(void) { - at91_shdwn_t *shdwn = (at91_shdwn_t *)AT91_SHDWN_BASE; + struct at91_shdwn *shdwn = (struct at91_shdwn *)AT91_SHDWN_BASE;
/* * make sure the board can be powered on by diff --git a/include/configs/top9000.h b/include/configs/top9000.h index ff3933b..814fb6c 100644 --- a/include/configs/top9000.h +++ b/include/configs/top9000.h @@ -40,9 +40,13 @@
/* * Warning: changing CONFIG_SYS_TEXT_BASE requires - * adapting the initial boot program + * adapting the initial boot program. + * Guard it since the definition finds its way to the command-line and + * causes warnings when this file is included */ -#define CONFIG_SYS_TEXT_BASE 0x21f00000 /* 31 MB into RAM */ +#ifndef CONFIG_SYS_TEXT_BASE +# define CONFIG_SYS_TEXT_BASE 0x21f00000 /* 31 MB into RAM */ +#endif
/* Command line configuration */ #include <config_cmd_default.h>
I wrote:
- Warning: changing CONFIG_SYS_TEXT_BASE requires
- adapting the initial boot program
- adapting the initial boot program.
- Guard it since the definition finds its way to the command-line and
- causes warnings when this file is included
Because I had this warning when building u-boot:
*** make u-boot.bin In file included from /home/reinhard/embedded/top9000/build/u-boot/include/config.h:5, from include/common.h:37: /home/reinhard/embedded/u-boot-atmel/include/configs/top9000.h:45:1: warning: "CONFIG_SYS_TEXT_BASE" redefined <command-line>: warning: this is the location of the previous definition
Since I found guarding the define a bit ugly, I removed it again, trying to investigate where exactly the definition in the command line came from.
Surprisingly, further builds did not ever again show that warning. I can only assume some stuff in the out-of-tree build was dormant and got removed when I did a "make clean".
A new patch without the guarding will follow soon.
Best Regards, Reinhard
Reinhard Meyer
