[U-Boot] [PATCH] rockchip: video: mipi: Do not write to the version register
There was a copy and paste error where the data enable setting was written to the version register.
Signed-off-by: Richard Röjfors richard@puffinpack.se --- drivers/video/rockchip/rk_mipi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index 4fe8f47441..88bf56ea09 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -106,7 +106,7 @@ int rk_mipi_dsi_enable(struct udevice *dev, rk_mipi_dsi_write(regs, VSYNC_ACTIVE_LOW, val);
val = (timing->flags & DISPLAY_FLAGS_DE_LOW) ? 1 : 0; - rk_mipi_dsi_write(regs, DISPLAY_FLAGS_DE_LOW, val); + rk_mipi_dsi_write(regs, DATAEN_ACTIVE_LOW, val);
val = (timing->flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) ? 1 : 0; rk_mipi_dsi_write(regs, COLORM_ACTIVE_LOW, val);
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Philipp Tomsich
Richard Röjfors
