[U-Boot-Users] tftpboot question
Hi all, and sorry for disturbing you again. I'm trying to load an image from a tftp server using tftpboot. Server is reachable, and running. Address of image is correct. U-boot contacts the right IP, then tries to load the image and intead of printing "#" as documented, prints "T" (it means timeout I suppose). But I continue getting an error message: "Retry count exceeded" Then the procedure starts again.
What this behaviour can depend from? I excluded tftp configuration problems and network problems.
Thanks in andvance
1. You can ping your server from within u-boot, right?
2. You can tftp download your image locally on your server, right?
best regards rick
Thanks in andvance
I would suspect your ethernet receiver is having problems with larger packets (probably a hardware configuration issue). I don't know what processor you are using, but a classic problem is that short packets (pings) work because the packet fits entirely in the ethernet FIFO buffer, but long packets (tftp data) break because the ethernet FIFO cannot buffer the whole packet and the at-speed store to SDRAM is broken (cannot keep up with packets of length 1500 or so bytes and/or SDRAM bursting is broken).
gvb
eagle keeper
Jerry Van Baren
richard@uclinux.net
