[U-Boot] [U-Boot PATCH 0/8] spi: Driver cleanup series
Driver cleanup series list - Minor code cleanups - tab space, comments etc - Zapping unneeded drivers - Moving header code into driver .c files for easy accessing - Arranged the driver code format to [1] for more readable [1] http://lists.denx.de/pipermail/u-boot/2013-August/160473.html
thanks! -- Jagan.
Jagannadha Sutradharudu Teki (8): sf: Adjust tab space's spi: Zap andes_spi driver spi: Zap ftssp010_spi driver spi: Zap oc_tiny_spi driver spi: xilinx_spi: Move header code to driver spi: xilinx_spi: Driver clean-up spi: davinci_spi: Move header code to driver spi: davinci_spi: Driver cleanup
drivers/mtd/spi/sf_internal.h | 20 +- drivers/spi/Makefile | 3 - drivers/spi/andes_spi.c | 284 ------------------------ drivers/spi/andes_spi.h | 115 ---------- drivers/spi/davinci_spi.c | 369 ++++++++++++++++++++----------- drivers/spi/davinci_spi.h | 121 ---------- drivers/spi/ftssp010_spi.c | 498 ------------------------------------------ drivers/spi/oc_tiny_spi.c | 245 --------------------- drivers/spi/xilinx_spi.c | 153 +++++++++---- drivers/spi/xilinx_spi.h | 138 ------------ include/spi.h | 12 +- include/spi_flash.h | 8 +- 12 files changed, 367 insertions(+), 1599 deletions(-) delete mode 100644 drivers/spi/andes_spi.c delete mode 100644 drivers/spi/andes_spi.h delete mode 100644 drivers/spi/davinci_spi.h delete mode 100644 drivers/spi/ftssp010_spi.c delete mode 100644 drivers/spi/oc_tiny_spi.c delete mode 100644 drivers/spi/xilinx_spi.h
Tab space's got adjusted on relevent files.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com --- drivers/mtd/spi/sf_internal.h | 20 ++++++++++---------- include/spi.h | 12 ++++++------ include/spi_flash.h | 8 ++++---- 3 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 785f7a9..58007de 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -31,9 +31,9 @@ enum spi_read_cmds { };
/* Normal - Extended - Full command set */ -#define RD_NORM (ARRAY_SLOW | ARRAY_FAST) -#define RD_EXTN (RD_NORM | DUAL_OUTPUT_FAST | DUAL_IO_FAST) -#define RD_FULL (RD_EXTN | QUAD_OUTPUT_FAST | QUAD_IO_FAST) +#define RD_NORM (ARRAY_SLOW | ARRAY_FAST) +#define RD_EXTN (RD_NORM | DUAL_OUTPUT_FAST | DUAL_IO_FAST) +#define RD_FULL (RD_EXTN | QUAD_OUTPUT_FAST | QUAD_IO_FAST)
/* sf param flags */ enum { @@ -67,12 +67,12 @@ enum { #define CMD_WRITE_STATUS 0x01 #define CMD_PAGE_PROGRAM 0x02 #define CMD_WRITE_DISABLE 0x04 -#define CMD_READ_STATUS 0x05 +#define CMD_READ_STATUS 0x05 #define CMD_QUAD_PAGE_PROGRAM 0x32 #define CMD_READ_STATUS1 0x35 #define CMD_WRITE_ENABLE 0x06 -#define CMD_READ_CONFIG 0x35 -#define CMD_FLAG_STATUS 0x70 +#define CMD_READ_CONFIG 0x35 +#define CMD_FLAG_STATUS 0x70
/* Read commands */ #define CMD_READ_ARRAY_SLOW 0x03 @@ -94,7 +94,7 @@ enum { /* Common status */ #define STATUS_WIP (1 << 0) #define STATUS_QEB_WINSPAN (1 << 1) -#define STATUS_QEB_MXIC (1 << 6) +#define STATUS_QEB_MXIC (1 << 6) #define STATUS_PEC (1 << 7)
#ifdef CONFIG_SYS_SPI_ST_ENABLE_WP_PIN @@ -103,13 +103,13 @@ enum {
/* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) -#define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) +#define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) #define SPI_FLASH_SECTOR_ERASE_TIMEOUT (10 * CONFIG_SYS_HZ)
/* SST specific */ #ifdef CONFIG_SPI_FLASH_SST # define CMD_SST_BP 0x02 /* Byte Program */ -# define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */ +# define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */
int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, const void *buf); @@ -124,7 +124,7 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id]) * @ext_jedec: Device ext_jedec ID * @sector_size: Sector size of this device - * @nr_sectors: No.of sectors on this device + * @nr_sectors: No.of sectors on this device * @e_rd_cmd: Enum list for read commands * @flags: Important param, for flash specific behaviour */ diff --git a/include/spi.h b/include/spi.h index 7829063..44abe68 100644 --- a/include/spi.h +++ b/include/spi.h @@ -30,7 +30,7 @@ #define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ #define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */ #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) -#define SPI_XFER_U_PAGE (1 << 5) +#define SPI_XFER_U_PAGE (1 << 5)
/* SPI TX operation modes */ #define SPI_OPM_TX_QPP (1 << 0) @@ -43,18 +43,18 @@ #define SPI_OPM_RX_DIO (1 << 3) #define SPI_OPM_RX_QOF (1 << 4) #define SPI_OPM_RX_QIOF (1 << 5) -#define SPI_OPM_RX_EXTN (SPI_OPM_RX_AS | SPI_OPM_RX_AF | SPI_OPM_RX_DOUT | \ - SPI_OPM_RX_DIO | SPI_OPM_RX_QOF | \ - SPI_OPM_RX_QIOF) +#define SPI_OPM_RX_EXTN (SPI_OPM_RX_AS | SPI_OPM_RX_AF | \ + SPI_OPM_RX_DOUT | SPI_OPM_RX_DIO | \ + SPI_OPM_RX_QOF | SPI_OPM_RX_QIOF)
/* SPI bus connection options - see enum spi_dual_flash */ #define SPI_CONN_DUAL_SHARED (1 << 0) -#define SPI_CONN_DUAL_SEPARATED (1 << 1) +#define SPI_CONN_DUAL_SEPARATED (1 << 1)
/* Header byte that marks the start of the message */ #define SPI_PREAMBLE_END_BYTE 0xec
-#define SPI_DEFAULT_WORDLEN 8 +#define SPI_DEFAULT_WORDLEN 8
#ifdef CONFIG_DM_SPI /* TODO(sjg@chromium.org): Remove this and use max_hz from struct spi_slave */ diff --git a/include/spi_flash.h b/include/spi_flash.h index 4791b94..481b4dd 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -38,12 +38,12 @@ struct spi_slave; * * @spi: SPI slave * @name: Name of SPI flash - * @dual_flash: Indicates dual flash memories - dual stacked, parallel + * @dual_flash: Indicates dual flash memories - dual stacked, parallel * @shift: Flash shift useful in dual parallel * @size: Total flash size * @page_size: Write (page) size * @sector_size: Sector size - * @erase_size: Erase size + * @erase_size: Erase size * @bank_read_cmd: Bank read cmd * @bank_write_cmd: Bank write cmd * @bank_curr: Current flash bank @@ -51,8 +51,8 @@ struct spi_slave; * @erase_cmd: Erase cmd 4K, 32K, 64K * @read_cmd: Read cmd - Array Fast, Extn read and quad read. * @write_cmd: Write cmd - page and quad program. - * @dummy_byte: Dummy cycles for read operation. - * @memory_map: Address of read-only SPI flash access + * @dummy_byte: Dummy cycles for read operation. + * @memory_map: Address of read-only SPI flash access * @read: Flash read ops: Read len bytes at offset into buf * Supported cmds: Fast Array Read * @write: Flash write ops: Write len bytes from buf into offset
Zap andes_spi driver since the boards used this driver is no longer been active.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Macpaul Lin macpaul@andestech.com --- drivers/spi/Makefile | 1 - drivers/spi/andes_spi.c | 284 ------------------------------------------------ drivers/spi/andes_spi.h | 115 -------------------- 3 files changed, 400 deletions(-) delete mode 100644 drivers/spi/andes_spi.c delete mode 100644 drivers/spi/andes_spi.h
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index e288692..93065b7 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -17,7 +17,6 @@ endif
obj-$(CONFIG_EP93XX_SPI) += ep93xx_spi.o obj-$(CONFIG_ALTERA_SPI) += altera_spi.o -obj-$(CONFIG_ANDES_SPI) += andes_spi.o obj-$(CONFIG_ARMADA100_SPI) += armada100_spi.o obj-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o diff --git a/drivers/spi/andes_spi.c b/drivers/spi/andes_spi.c deleted file mode 100644 index 82aed75..0000000 --- a/drivers/spi/andes_spi.c +++ /dev/null @@ -1,284 +0,0 @@ -/* - * Driver of Andes SPI Controller - * - * (C) Copyright 2011 Andes Technology - * Macpaul Lin macpaul@andestech.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <spi.h> - -#include <asm/io.h> -#include "andes_spi.h" - -void spi_init(void) -{ - /* do nothing */ -} - -static void andes_spi_spit_en(struct andes_spi_slave *ds) -{ - unsigned int dcr = readl(&ds->regs->dcr); - - debug("%s: dcr: %x, write value: %x\n", - __func__, dcr, (dcr | ANDES_SPI_DCR_SPIT)); - - writel((dcr | ANDES_SPI_DCR_SPIT), &ds->regs->dcr); -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct andes_spi_slave *ds; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ds = spi_alloc_slave(struct andes_spi_slave, bus, cs); - if (!ds) - return NULL; - - ds->regs = (struct andes_spi_regs *)CONFIG_SYS_SPI_BASE; - - /* - * The hardware of andes_spi will set its frequency according - * to APB/AHB bus clock. Hence the hardware doesn't allow changing of - * requency and so the user requested speed is always ignored. - */ - ds->freq = max_hz; - - return &ds->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct andes_spi_slave *ds = to_andes_spi(slave); - - free(ds); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct andes_spi_slave *ds = to_andes_spi(slave); - unsigned int apb; - unsigned int baud; - - /* Enable the SPI hardware */ - writel(ANDES_SPI_CR_SPIRST, &ds->regs->cr); - udelay(1000); - - /* setup format */ - baud = ((CONFIG_SYS_CLK_FREQ / CONFIG_SYS_SPI_CLK / 2) - 1) & 0xFF; - - /* - * SPI_CLK = AHB bus clock / ((BAUD + 1)*2) - * BAUD = AHB bus clock / SPI_CLK / 2) - 1 - */ - apb = (readl(&ds->regs->apb) & 0xffffff00) | baud; - writel(apb, &ds->regs->apb); - - /* no interrupts */ - writel(0, &ds->regs->ie); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - struct andes_spi_slave *ds = to_andes_spi(slave); - - /* Disable the SPI hardware */ - writel(ANDES_SPI_CR_SPIRST, &ds->regs->cr); -} - -static int andes_spi_read(struct spi_slave *slave, unsigned int len, - u8 *rxp, unsigned long flags) -{ - struct andes_spi_slave *ds = to_andes_spi(slave); - unsigned int i, left; - unsigned int data; - - debug("%s: slave: %x, len: %d, rxp: %x, flags: %d\n", - __func__, slave, len, rxp, flags); - - debug("%s: data: ", __func__); - while (len > 0) { - left = min(len, 4); - data = readl(&ds->regs->data); - - debug(" "); - for (i = 0; i < left; i++) { - debug("%02x ", data & 0xff); - *rxp++ = data; - data >>= 8; - len--; - } - } - debug("\n"); - - return 0; -} - -static int andes_spi_write(struct spi_slave *slave, unsigned int wlen, - unsigned int rlen, const u8 *txp, unsigned long flags) -{ - struct andes_spi_slave *ds = to_andes_spi(slave); - unsigned int data; - unsigned int i, left; - unsigned int spit_enabled = 0; - - debug("%s: slave: %x, wlen: %d, rlen: %d, txp: %x, flags: %x\n", - __func__, slave, wlen, rlen, txp, flags); - - /* The value of wlen and rlen wrote to register must minus 1 */ - if (rlen == 0) /* write only */ - writel(ANDES_SPI_DCR_MODE_WO | ANDES_SPI_DCR_WCNT(wlen-1) | - ANDES_SPI_DCR_RCNT(0), &ds->regs->dcr); - else /* write then read */ - writel(ANDES_SPI_DCR_MODE_WR | ANDES_SPI_DCR_WCNT(wlen-1) | - ANDES_SPI_DCR_RCNT(rlen-1), &ds->regs->dcr); - - /* wait till SPIBSY is cleared */ - while (readl(&ds->regs->st) & ANDES_SPI_ST_SPIBSY) - ; - - /* data write process */ - debug("%s: txp: ", __func__); - while (wlen > 0) { - /* clear the data */ - data = 0; - - /* data are usually be read 32bits once a time */ - left = min(wlen, 4); - - for (i = 0; i < left; i++) { - debug("%x ", *txp); - data |= *txp++ << (i * 8); - wlen--; - } - debug("\n"); - - debug("data: %08x\n", data); - debug("streg before write: %08x\n", readl(&ds->regs->st)); - /* wait till TXFULL is deasserted */ - while (readl(&ds->regs->st) & ANDES_SPI_ST_TXFEL) - ; - writel(data, &ds->regs->data); - debug("streg after write: %08x\n", readl(&ds->regs->st)); - - - if (spit_enabled == 0) { - /* enable SPIT bit - trigger the tx and rx progress */ - andes_spi_spit_en(ds); - spit_enabled = 1; - } - - } - debug("\n"); - - return 0; -} - -/* - * spi_xfer: - * Since andes_spi doesn't support independent command transaction, - * that is, write and than read must be operated in continuous - * execution, there is no need to set dcr and trigger spit again in - * RX process. - */ -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - unsigned int len; - static int op_nextime; - static u8 tmp_cmd[5]; - static int tmp_wlen; - unsigned int i; - - if (bitlen == 0) - /* Finish any previously submitted transfers */ - goto out; - - if (bitlen % 8) { - /* Errors always terminate an ongoing transfer */ - flags |= SPI_XFER_END; - goto out; - } - - len = bitlen / 8; - - debug("%s: slave: %08x, bitlen: %d, dout: " - "%08x, din: %08x, flags: %d, len: %d\n", - __func__, slave, bitlen, dout, din, flags, len); - - /* - * Important: - * andes_spi's hardware doesn't support 2 data channel. The read - * and write cmd/data share the same register (data register). - * - * If a command has write and read transaction, you cannot do write - * this time and then do read on next time. - * - * A command writes first with a read response must indicating - * the read length in write operation. Hence the write action must - * be stored temporary and wait until the next read action has been - * arrived. Then we flush the write and read action out together. - */ - if (!dout) { - if (op_nextime == 1) { - /* flags should be SPI_XFER_END, value is 2 */ - op_nextime = 0; - andes_spi_write(slave, tmp_wlen, len, tmp_cmd, flags); - } - return andes_spi_read(slave, len, din, flags); - } else if (!din) { - if (flags == SPI_XFER_BEGIN) { - /* store the write command and do operation next time */ - op_nextime = 1; - memset(tmp_cmd, 0, sizeof(tmp_cmd)); - memcpy(tmp_cmd, dout, len); - - debug("%s: tmp_cmd: ", __func__); - for (i = 0; i < len; i++) - debug("%x ", *(tmp_cmd + i)); - debug("\n"); - - tmp_wlen = len; - } else { - /* - * flags should be (SPI_XFER_BEGIN | SPI_XFER_END), - * the value is 3. - */ - if (op_nextime == 1) { - /* flags should be SPI_XFER_END, value is 2 */ - op_nextime = 0; - /* flags 3 implies write only */ - andes_spi_write(slave, tmp_wlen, 0, tmp_cmd, 3); - } - - debug("flags: %x\n", flags); - return andes_spi_write(slave, len, 0, dout, flags); - } - } - -out: - return 0; -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return bus == 0 && cs == 0; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - /* do nothing */ -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - /* do nothing */ -} diff --git a/drivers/spi/andes_spi.h b/drivers/spi/andes_spi.h deleted file mode 100644 index b7d2945..0000000 --- a/drivers/spi/andes_spi.h +++ /dev/null @@ -1,115 +0,0 @@ -/* - * Register definitions for the Andes SPI Controller - * - * (C) Copyright 2011 Andes Technology - * Macpaul Lin macpaul@andestech.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __ANDES_SPI_H -#define __ANDES_SPI_H - -struct andes_spi_regs { - unsigned int apb; /* 0x00 - APB SPI interface setting */ - unsigned int pio; /* 0x04 - PIO reg */ - unsigned int cr; /* 0x08 - SPI Control reg */ - unsigned int st; /* 0x0c - SPI Status reg */ - unsigned int ie; /* 0x10 - Interrupt Enable reg */ - unsigned int ist; /* 0x14 - Interrupt Status reg */ - unsigned int dcr; /* 0x18 - data control reg */ - unsigned int data; /* 0x1c - data register */ - unsigned int ahb; /* 0x20 - AHB SPI interface setting */ - unsigned int ver; /* 0x3c - SPI version reg */ -}; - -#define BIT(x) (1 << (x)) - -/* 0x00 - APB SPI interface setting register */ -#define ANDES_SPI_APB_BAUD(x) (((x) & 0xff) < 0) -#define ANDES_SPI_APB_CSHT(x) (((x) & 0xf) < 16) -#define ANDES_SPI_APB_SPNTS BIT(20) /* 0: normal, 1: delay */ -#define ANDES_SPI_APB_CPHA BIT(24) /* 0: Sampling at odd edges */ -#define ANDES_SPI_APB_CPOL BIT(25) /* 0: SCK low, 1: SCK high */ -#define ANDES_SPI_APB_MSSL BIT(26) /* 0: SPI Master, 1: slave */ - -/* 0x04 - PIO register */ -#define ANDES_SPI_PIO_MISO BIT(0) /* input value of pin MISO */ -#define ANDES_SPI_PIO_MOSI BIT(1) /* I/O value of pin MOSI */ -#define ANDES_SPI_PIO_SCK BIT(2) /* I/O value of pin SCK */ -#define ANDES_SPI_PIO_CS BIT(3) /* I/O value of pin CS */ -#define ANDES_SPI_PIO_PIOE BIT(4) /* Programming IO Enable */ - -/* 0x08 - SPI Control register */ -#define ANDES_SPI_CR_SPIRST BIT(0) /* SPI mode reset */ -#define ANDES_SPI_CR_RXFRST BIT(1) /* RxFIFO reset */ -#define ANDES_SPI_CR_TXFRST BIT(2) /* TxFIFO reset */ -#define ANDES_SPI_CR_RXFTH(x) (((x) & 0x1f) << 10) /* RxFIFO Threshold */ -#define ANDES_SPI_CR_TXFTH(x) (((x) & 0x1f) << 18) /* TxFIFO Threshold */ - -/* 0x0c - SPI Status register */ -#define ANDES_SPI_ST_SPIBSY BIT(0) /* SPI Transfer is active */ -#define ANDES_SPI_ST_RXFEM BIT(8) /* RxFIFO Empty Flag */ -#define ANDES_SPI_ST_RXFEL BIT(9) /* RxFIFO Full Flag */ -#define ANDES_SPI_ST_RXFVE(x) (((x) >> 10) & 0x1f) -#define ANDES_SPI_ST_TXFEM BIT(16) /* TxFIFO Empty Flag */ -#define ANDES_SPI_ST_TXFEL BIT(7) /* TxFIFO Full Flag */ -#define ANDES_SPI_ST_TXFVE(x) (((x) >> 18) & 0x1f) - -/* 0x10 - Interrupt Enable register */ -#define ANDES_SPI_IE_RXFORIE BIT(0) /* RxFIFO overrun intr */ -#define ANDES_SPI_IE_TXFURIE BIT(1) /* TxFOFO underrun intr */ -#define ANDES_SPI_IE_RXFTHIE BIT(2) /* RxFIFO threshold intr */ -#define ANDES_SPI_IE_TXFTHIE BIT(3) /* TxFIFO threshold intr */ -#define ANDES_SPI_IE_SPIEIE BIT(4) /* SPI transmit END intr */ -#define ANDES_SPI_IE_SPCFIE BIT(5) /* AHB/APB TxReq conflict */ - -/* 0x14 - Interrupt Status Register */ -#define ANDES_SPI_IST_RXFORI BIT(0) /* has RxFIFO overrun */ -#define ANDES_SPI_IST_TXFURI BIT(1) /* has TxFOFO underrun */ -#define ANDES_SPI_IST_RXFTHI BIT(2) /* has RxFIFO threshold */ -#define ANDES_SPI_IST_TXFTHI BIT(3) /* has TxFIFO threshold */ -#define ANDES_SPI_IST_SPIEI BIT(4) /* has SPI transmit END */ -#define ANDES_SPI_IST_SPCFI BIT(5) /* has AHB/APB TxReq conflict */ - -/* 0x18 - Data Control Register */ -#define ANDES_SPI_DCR_RCNT(x) (((x) & 0x3ff) << 0) -#define ANDES_SPI_DCR_DYCNT(x) (((x) & 0x7) << 12) -#define ANDES_SPI_DCR_WCNT(x) (((x) & 0x3ff) << 16) -#define ANDES_SPI_DCR_TRAMODE(x) (((x) & 0x7) << 28) -#define ANDES_SPI_DCR_SPIT BIT(31) /* SPI bus trigger */ - -#define ANDES_SPI_DCR_MODE_WRCON ANDES_SPI_DCR_TRAMODE(0) /* w/r at the same time */ -#define ANDES_SPI_DCR_MODE_WO ANDES_SPI_DCR_TRAMODE(1) /* write only */ -#define ANDES_SPI_DCR_MODE_RO ANDES_SPI_DCR_TRAMODE(2) /* read only */ -#define ANDES_SPI_DCR_MODE_WR ANDES_SPI_DCR_TRAMODE(3) /* write, read */ -#define ANDES_SPI_DCR_MODE_RW ANDES_SPI_DCR_TRAMODE(4) /* read, write */ -#define ANDES_SPI_DCR_MODE_WDR ANDES_SPI_DCR_TRAMODE(5) /* write, dummy, read */ -#define ANDES_SPI_DCR_MODE_RDW ANDES_SPI_DCR_TRAMODE(6) /* read, dummy, write */ -#define ANDES_SPI_DCR_MODE_RECEIVE ANDES_SPI_DCR_TRAMODE(7) /* receive */ - -/* 0x20 - AHB SPI interface setting register */ -#define ANDES_SPI_AHB_BAUD(x) (((x) & 0xff) < 0) -#define ANDES_SPI_AHB_CSHT(x) (((x) & 0xf) < 16) -#define ANDES_SPI_AHB_SPNTS BIT(20) /* 0: normal, 1: delay */ -#define ANDES_SPI_AHB_CPHA BIT(24) /* 0: Sampling at odd edges */ -#define ANDES_SPI_AHB_CPOL BIT(25) /* 0: SCK low, 1: SCK high */ -#define ANDES_SPI_AHB_MSSL BIT(26) /* only Master mode */ - -/* 0x3c - Version Register - (Year V.MAJOR.MINOR) */ -#define ANDES_SPI_VER_MINOR(x) (((x) >> 0) & 0xf) -#define ANDES_SPI_VER_MAJOR(x) (((x) >> 8) & 0xf) -#define ANDES_SPI_VER_YEAR(x) (((x) >> 16) & 0xf) - -struct andes_spi_slave { - struct spi_slave slave; - struct andes_spi_regs *regs; - unsigned int freq; -}; - -static inline struct andes_spi_slave *to_andes_spi(struct spi_slave *slave) -{ - return container_of(slave, struct andes_spi_slave, slave); -} - -#endif /* __ANDES_SPI_H */
Zap ftssp010_spi driver since the boards used this driver is no longer been active.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Kuo-Jung Su dantesu@faraday-tech.com Cc: Axel Lin axel.lin@ingics.com --- drivers/spi/Makefile | 1 - drivers/spi/ftssp010_spi.c | 498 --------------------------------------------- 2 files changed, 499 deletions(-) delete mode 100644 drivers/spi/ftssp010_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 93065b7..1e3611d 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -28,7 +28,6 @@ obj-$(CONFIG_CF_QSPI) += cf_qspi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o -obj-$(CONFIG_FTSSP010_SPI) += ftssp010_spi.o obj-$(CONFIG_ICH_SPI) += ich.o obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o obj-$(CONFIG_LPC32XX_SSP) += lpc32xx_ssp.o diff --git a/drivers/spi/ftssp010_spi.c b/drivers/spi/ftssp010_spi.c deleted file mode 100644 index c7d6480..0000000 --- a/drivers/spi/ftssp010_spi.c +++ /dev/null @@ -1,498 +0,0 @@ -/* - * (C) Copyright 2013 - * Faraday Technology Corporation. http://www.faraday-tech.com/tw/ - * Kuo-Jung Su dantesu@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <linux/compat.h> -#include <asm/io.h> -#include <malloc.h> -#include <spi.h> - -#ifndef CONFIG_FTSSP010_BASE_LIST -#define CONFIG_FTSSP010_BASE_LIST { CONFIG_FTSSP010_BASE } -#endif - -#ifndef CONFIG_FTSSP010_GPIO_BASE -#define CONFIG_FTSSP010_GPIO_BASE 0 -#endif - -#ifndef CONFIG_FTSSP010_GPIO_LIST -#define CONFIG_FTSSP010_GPIO_LIST { CONFIG_FTSSP010_GPIO_BASE } -#endif - -#ifndef CONFIG_FTSSP010_CLOCK -#define CONFIG_FTSSP010_CLOCK clk_get_rate("SSP"); -#endif - -#ifndef CONFIG_FTSSP010_TIMEOUT -#define CONFIG_FTSSP010_TIMEOUT 100 -#endif - -/* FTSSP010 chip registers */ -struct ftssp010_regs { - uint32_t cr[3];/* control register */ - uint32_t sr; /* status register */ - uint32_t icr; /* interrupt control register */ - uint32_t isr; /* interrupt status register */ - uint32_t dr; /* data register */ - uint32_t rsvd[17]; - uint32_t revr; /* revision register */ - uint32_t fear; /* feature register */ -}; - -/* Control Register 0 */ -#define CR0_FFMT_MASK (7 << 12) -#define CR0_FFMT_SSP (0 << 12) -#define CR0_FFMT_SPI (1 << 12) -#define CR0_FFMT_MICROWIRE (2 << 12) -#define CR0_FFMT_I2S (3 << 12) -#define CR0_FFMT_AC97 (4 << 12) -#define CR0_FLASH (1 << 11) -#define CR0_FSDIST(x) (((x) & 0x03) << 8) -#define CR0_LOOP (1 << 7) /* loopback mode */ -#define CR0_LSB (1 << 6) /* LSB */ -#define CR0_FSPO (1 << 5) /* fs atcive low (I2S only) */ -#define CR0_FSJUSTIFY (1 << 4) -#define CR0_OPM_SLAVE (0 << 2) -#define CR0_OPM_MASTER (3 << 2) -#define CR0_OPM_I2S_MSST (3 << 2) /* master stereo mode */ -#define CR0_OPM_I2S_MSMO (2 << 2) /* master mono mode */ -#define CR0_OPM_I2S_SLST (1 << 2) /* slave stereo mode */ -#define CR0_OPM_I2S_SLMO (0 << 2) /* slave mono mode */ -#define CR0_SCLKPO (1 << 1) /* clock polarity */ -#define CR0_SCLKPH (1 << 0) /* clock phase */ - -/* Control Register 1 */ -#define CR1_PDL(x) (((x) & 0xff) << 24) /* padding length */ -#define CR1_SDL(x) ((((x) - 1) & 0x1f) << 16) /* data length */ -#define CR1_DIV(x) (((x) - 1) & 0xffff) /* clock divider */ - -/* Control Register 2 */ -#define CR2_CS(x) (((x) & 3) << 10) /* CS/FS select */ -#define CR2_FS (1 << 9) /* CS/FS signal level */ -#define CR2_TXEN (1 << 8) /* tx enable */ -#define CR2_RXEN (1 << 7) /* rx enable */ -#define CR2_RESET (1 << 6) /* chip reset */ -#define CR2_TXFC (1 << 3) /* tx fifo Clear */ -#define CR2_RXFC (1 << 2) /* rx fifo Clear */ -#define CR2_TXDOE (1 << 1) /* tx data output enable */ -#define CR2_EN (1 << 0) /* chip enable */ - -/* Status Register */ -#define SR_RFF (1 << 0) /* rx fifo full */ -#define SR_TFNF (1 << 1) /* tx fifo not full */ -#define SR_BUSY (1 << 2) /* chip busy */ -#define SR_RFVE(reg) (((reg) >> 4) & 0x1f) /* rx fifo valid entries */ -#define SR_TFVE(reg) (((reg) >> 12) & 0x1f) /* tx fifo valid entries */ - -/* Feature Register */ -#define FEAR_BITS(reg) ((((reg) >> 0) & 0xff) + 1) /* data width */ -#define FEAR_RFSZ(reg) ((((reg) >> 8) & 0xff) + 1) /* rx fifo size */ -#define FEAR_TFSZ(reg) ((((reg) >> 16) & 0xff) + 1) /* tx fifo size */ -#define FEAR_AC97 (1 << 24) -#define FEAR_I2S (1 << 25) -#define FEAR_SPI_MWR (1 << 26) -#define FEAR_SSP (1 << 27) -#define FEAR_SPDIF (1 << 28) - -/* FTGPIO010 chip registers */ -struct ftgpio010_regs { - uint32_t out; /* 0x00: Data Output */ - uint32_t in; /* 0x04: Data Input */ - uint32_t dir; /* 0x08: Direction */ - uint32_t bypass; /* 0x0c: Bypass */ - uint32_t set; /* 0x10: Data Set */ - uint32_t clr; /* 0x14: Data Clear */ - uint32_t pull_up; /* 0x18: Pull-Up Enabled */ - uint32_t pull_st; /* 0x1c: Pull State (0=pull-down, 1=pull-up) */ -}; - -struct ftssp010_gpio { - struct ftgpio010_regs *regs; - uint32_t pin; -}; - -struct ftssp010_spi { - struct spi_slave slave; - struct ftssp010_gpio gpio; - struct ftssp010_regs *regs; - uint32_t fifo; - uint32_t mode; - uint32_t div; - uint32_t clk; - uint32_t speed; - uint32_t revision; -}; - -static inline struct ftssp010_spi *to_ftssp010_spi(struct spi_slave *slave) -{ - return container_of(slave, struct ftssp010_spi, slave); -} - -static int get_spi_chip(int bus, struct ftssp010_spi *chip) -{ - uint32_t fear, base[] = CONFIG_FTSSP010_BASE_LIST; - - if (bus >= ARRAY_SIZE(base) || !base[bus]) - return -1; - - chip->regs = (struct ftssp010_regs *)base[bus]; - - chip->revision = readl(&chip->regs->revr); - - fear = readl(&chip->regs->fear); - chip->fifo = min_t(uint32_t, FEAR_TFSZ(fear), FEAR_RFSZ(fear)); - - return 0; -} - -static int get_spi_gpio(int bus, struct ftssp010_gpio *chip) -{ - uint32_t base[] = CONFIG_FTSSP010_GPIO_LIST; - - if (bus >= ARRAY_SIZE(base) || !base[bus]) - return -1; - - chip->regs = (struct ftgpio010_regs *)(base[bus] & 0xfff00000); - chip->pin = base[bus] & 0x1f; - - /* make it an output pin */ - setbits_le32(&chip->regs->dir, 1 << chip->pin); - - return 0; -} - -static int ftssp010_wait(struct ftssp010_spi *chip) -{ - struct ftssp010_regs *regs = chip->regs; - ulong t; - - /* wait until device idle */ - for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { - if (!(readl(®s->sr) & SR_BUSY)) - return 0; - } - - puts("ftspi010: busy timeout\n"); - - return -1; -} - -static int ftssp010_wait_tx(struct ftssp010_spi *chip) -{ - struct ftssp010_regs *regs = chip->regs; - ulong t; - - /* wait until tx fifo not full */ - for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { - if (readl(®s->sr) & SR_TFNF) - return 0; - } - - puts("ftssp010: tx timeout\n"); - - return -1; -} - -static int ftssp010_wait_rx(struct ftssp010_spi *chip) -{ - struct ftssp010_regs *regs = chip->regs; - ulong t; - - /* wait until rx fifo not empty */ - for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { - if (SR_RFVE(readl(®s->sr))) - return 0; - } - - puts("ftssp010: rx timeout\n"); - - return -1; -} - -static int ftssp010_spi_work_transfer_v2(struct ftssp010_spi *chip, - const void *tx_buf, void *rx_buf, int len, uint flags) -{ - struct ftssp010_regs *regs = chip->regs; - const uint8_t *txb = tx_buf; - uint8_t *rxb = rx_buf; - - while (len > 0) { - int i, depth = min(chip->fifo >> 2, len); - uint32_t xmsk = 0; - - if (tx_buf) { - for (i = 0; i < depth; ++i) { - ftssp010_wait_tx(chip); - writel(*txb++, ®s->dr); - } - xmsk |= CR2_TXEN | CR2_TXDOE; - if ((readl(®s->cr[2]) & xmsk) != xmsk) - setbits_le32(®s->cr[2], xmsk); - } - if (rx_buf) { - xmsk |= CR2_RXEN; - if ((readl(®s->cr[2]) & xmsk) != xmsk) - setbits_le32(®s->cr[2], xmsk); - for (i = 0; i < depth; ++i) { - ftssp010_wait_rx(chip); - *rxb++ = (uint8_t)readl(®s->dr); - } - } - - len -= depth; - } - - return 0; -} - -static int ftssp010_spi_work_transfer_v1(struct ftssp010_spi *chip, - const void *tx_buf, void *rx_buf, int len, uint flags) -{ - struct ftssp010_regs *regs = chip->regs; - const uint8_t *txb = tx_buf; - uint8_t *rxb = rx_buf; - - while (len > 0) { - int i, depth = min(chip->fifo >> 2, len); - uint32_t tmp; - - for (i = 0; i < depth; ++i) { - ftssp010_wait_tx(chip); - writel(txb ? (*txb++) : 0, ®s->dr); - } - for (i = 0; i < depth; ++i) { - ftssp010_wait_rx(chip); - tmp = readl(®s->dr); - if (rxb) - *rxb++ = (uint8_t)tmp; - } - - len -= depth; - } - - return 0; -} - -static void ftssp010_cs_set(struct ftssp010_spi *chip, int high) -{ - struct ftssp010_regs *regs = chip->regs; - struct ftssp010_gpio *gpio = &chip->gpio; - uint32_t mask; - - /* cs pull high/low */ - if (chip->revision >= 0x11900) { - mask = CR2_CS(chip->slave.cs) | (high ? CR2_FS : 0); - writel(mask, ®s->cr[2]); - } else if (gpio->regs) { - mask = 1 << gpio->pin; - if (high) - writel(mask, &gpio->regs->set); - else - writel(mask, &gpio->regs->clr); - } - - /* extra delay for signal propagation */ - udelay_masked(1); -} - -/* - * Determine if a SPI chipselect is valid. - * This function is provided by the board if the low-level SPI driver - * needs it to determine if a given chipselect is actually valid. - * - * Returns: 1 if bus:cs identifies a valid chip on this board, 0 - * otherwise. - */ -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - struct ftssp010_spi chip; - - if (get_spi_chip(bus, &chip)) - return 0; - - if (!cs) - return 1; - else if ((cs < 4) && (chip.revision >= 0x11900)) - return 1; - - return 0; -} - -/* - * Activate a SPI chipselect. - * This function is provided by the board code when using a driver - * that can't control its chipselects automatically (e.g. - * common/soft_spi.c). When called, it should activate the chip select - * to the device identified by "slave". - */ -void spi_cs_activate(struct spi_slave *slave) -{ - struct ftssp010_spi *chip = to_ftssp010_spi(slave); - struct ftssp010_regs *regs = chip->regs; - - /* cs pull */ - if (chip->mode & SPI_CS_HIGH) - ftssp010_cs_set(chip, 1); - else - ftssp010_cs_set(chip, 0); - - /* chip enable + fifo clear */ - setbits_le32(®s->cr[2], CR2_EN | CR2_TXFC | CR2_RXFC); -} - -/* - * Deactivate a SPI chipselect. - * This function is provided by the board code when using a driver - * that can't control its chipselects automatically (e.g. - * common/soft_spi.c). When called, it should deactivate the chip - * select to the device identified by "slave". - */ -void spi_cs_deactivate(struct spi_slave *slave) -{ - struct ftssp010_spi *chip = to_ftssp010_spi(slave); - - /* wait until chip idle */ - ftssp010_wait(chip); - - /* cs pull */ - if (chip->mode & SPI_CS_HIGH) - ftssp010_cs_set(chip, 0); - else - ftssp010_cs_set(chip, 1); -} - -void spi_init(void) -{ - /* nothing to do */ -} - -struct spi_slave *spi_setup_slave(uint bus, uint cs, uint max_hz, uint mode) -{ - struct ftssp010_spi *chip; - - if (mode & SPI_3WIRE) { - puts("ftssp010: can't do 3-wire\n"); - return NULL; - } - - if (mode & SPI_SLAVE) { - puts("ftssp010: can't do slave mode\n"); - return NULL; - } - - if (mode & SPI_PREAMBLE) { - puts("ftssp010: can't skip preamble bytes\n"); - return NULL; - } - - if (!spi_cs_is_valid(bus, cs)) { - puts("ftssp010: invalid (bus, cs)\n"); - return NULL; - } - - chip = spi_alloc_slave(struct ftssp010_spi, bus, cs); - if (!chip) - return NULL; - - if (get_spi_chip(bus, chip)) - goto free_out; - - if (chip->revision < 0x11900 && get_spi_gpio(bus, &chip->gpio)) { - puts("ftssp010: Before revision 1.19.0, its clock & cs are\n" - "controlled by tx engine which is not synced with rx engine,\n" - "so the clock & cs might be shutdown before rx engine\n" - "finishs its jobs.\n" - "If possible, please add a dedicated gpio for it.\n"); - } - - chip->mode = mode; - chip->clk = CONFIG_FTSSP010_CLOCK; - chip->div = 2; - if (max_hz) { - while (chip->div < 0xffff) { - if ((chip->clk / (2 * chip->div)) <= max_hz) - break; - chip->div += 1; - } - } - chip->speed = chip->clk / (2 * chip->div); - - return &chip->slave; - -free_out: - free(chip); - return NULL; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct ftssp010_spi *chip = to_ftssp010_spi(slave); - - free(chip); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct ftssp010_spi *chip = to_ftssp010_spi(slave); - struct ftssp010_regs *regs = chip->regs; - - writel(CR1_SDL(8) | CR1_DIV(chip->div), ®s->cr[1]); - - if (chip->revision >= 0x11900) { - writel(CR0_OPM_MASTER | CR0_FFMT_SPI | CR0_FSPO | CR0_FLASH, - ®s->cr[0]); - writel(CR2_TXFC | CR2_RXFC, - ®s->cr[2]); - } else { - writel(CR0_OPM_MASTER | CR0_FFMT_SPI | CR0_FSPO, - ®s->cr[0]); - writel(CR2_TXFC | CR2_RXFC | CR2_EN | CR2_TXDOE, - ®s->cr[2]); - } - - if (chip->mode & SPI_LOOP) - setbits_le32(®s->cr[0], CR0_LOOP); - - if (chip->mode & SPI_CPOL) - setbits_le32(®s->cr[0], CR0_SCLKPO); - - if (chip->mode & SPI_CPHA) - setbits_le32(®s->cr[0], CR0_SCLKPH); - - spi_cs_deactivate(slave); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - struct ftssp010_spi *chip = to_ftssp010_spi(slave); - struct ftssp010_regs *regs = chip->regs; - - writel(0, ®s->cr[2]); -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - struct ftssp010_spi *chip = to_ftssp010_spi(slave); - uint32_t len = bitlen >> 3; - - if (flags & SPI_XFER_BEGIN) - spi_cs_activate(slave); - - if (chip->revision >= 0x11900) - ftssp010_spi_work_transfer_v2(chip, dout, din, len, flags); - else - ftssp010_spi_work_transfer_v1(chip, dout, din, len, flags); - - if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); - - return 0; -}
2015-04-22 2:26 GMT+08:00 Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com:
I'm not sure if this is correct thing to do... It's fine to drop unmaintained boards, but a driver can/may be used by different boards. So If someday the boards(or new boards) that need this driver becomes active, it needs to add back this(and all required) driver(s).
Regards, Axel
Hi Axel,
I understand your point, but if none of the sw using these drivers will make orphan driver and to reduce the code size atleast some thing is not used now.
Ok, if any boards require these may be they will write or reuse it from past that depends on the future decision.
Any comments from ML?
thanks!
Zap oc_tiny_spi driver since the boards used this driver is no longer been active.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Thomas Chou thomas@wytron.com.tw --- drivers/spi/Makefile | 1 - drivers/spi/oc_tiny_spi.c | 245 ---------------------------------------------- 2 files changed, 246 deletions(-) delete mode 100644 drivers/spi/oc_tiny_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 1e3611d..507c315 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -35,7 +35,6 @@ obj-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o obj-$(CONFIG_MXC_SPI) += mxc_spi.o obj-$(CONFIG_MXS_SPI) += mxs_spi.o -obj-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_SANDBOX_SPI) += sandbox_spi.o obj-$(CONFIG_SH_SPI) += sh_spi.o diff --git a/drivers/spi/oc_tiny_spi.c b/drivers/spi/oc_tiny_spi.c deleted file mode 100644 index 4de5d00..0000000 --- a/drivers/spi/oc_tiny_spi.c +++ /dev/null @@ -1,245 +0,0 @@ -/* - * Opencore tiny_spi driver - * - * http://opencores.org/project,tiny_spi - * - * based on bfin_spi.c - * Copyright (c) 2005-2008 Analog Devices Inc. - * Copyright (C) 2010 Thomas Chou thomas@wytron.com.tw - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <malloc.h> -#include <spi.h> -#include <asm/gpio.h> - -#define TINY_SPI_STATUS_TXE 0x1 -#define TINY_SPI_STATUS_TXR 0x2 - -struct tiny_spi_regs { - unsigned rxdata; /* Rx data reg */ - unsigned txdata; /* Tx data reg */ - unsigned status; /* Status reg */ - unsigned control; /* Control reg */ - unsigned baud; /* Baud reg */ -}; - -struct tiny_spi_host { - uint base; - uint freq; - uint baudwidth; -}; -static const struct tiny_spi_host tiny_spi_host_list[] = - CONFIG_SYS_TINY_SPI_LIST; - -struct tiny_spi_slave { - struct spi_slave slave; - const struct tiny_spi_host *host; - uint mode; - uint baud; - uint flg; -}; -#define to_tiny_spi_slave(s) container_of(s, struct tiny_spi_slave, slave) - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return bus < ARRAY_SIZE(tiny_spi_host_list) && gpio_is_valid(cs); -} - -void spi_cs_activate(struct spi_slave *slave) -{ - struct tiny_spi_slave *tiny_spi = to_tiny_spi_slave(slave); - unsigned int cs = slave->cs; - - gpio_set_value(cs, tiny_spi->flg); - debug("%s: SPI_CS_GPIO:%x\n", __func__, gpio_get_value(cs)); -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - struct tiny_spi_slave *tiny_spi = to_tiny_spi_slave(slave); - unsigned int cs = slave->cs; - - gpio_set_value(cs, !tiny_spi->flg); - debug("%s: SPI_CS_GPIO:%x\n", __func__, gpio_get_value(cs)); -} - -void spi_set_speed(struct spi_slave *slave, uint hz) -{ - struct tiny_spi_slave *tiny_spi = to_tiny_spi_slave(slave); - const struct tiny_spi_host *host = tiny_spi->host; - - tiny_spi->baud = min(DIV_ROUND_UP(host->freq, hz * 2), - (1 << host->baudwidth)) - 1; - debug("%s: speed %u actual %u\n", __func__, hz, - host->freq / ((tiny_spi->baud + 1) * 2)); -} - -void spi_init(void) -{ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int hz, unsigned int mode) -{ - struct tiny_spi_slave *tiny_spi; - - if (!spi_cs_is_valid(bus, cs) || gpio_request(cs, "tiny_spi")) - return NULL; - - tiny_spi = spi_alloc_slave(struct tiny_spi_slave, bus, cs); - if (!tiny_spi) - return NULL; - - tiny_spi->host = &tiny_spi_host_list[bus]; - tiny_spi->mode = mode & (SPI_CPOL | SPI_CPHA); - tiny_spi->flg = mode & SPI_CS_HIGH ? 1 : 0; - spi_set_speed(&tiny_spi->slave, hz); - - debug("%s: bus:%i cs:%i base:%lx\n", __func__, - bus, cs, tiny_spi->host->base); - return &tiny_spi->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct tiny_spi_slave *tiny_spi = to_tiny_spi_slave(slave); - - gpio_free(slave->cs); - free(tiny_spi); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct tiny_spi_slave *tiny_spi = to_tiny_spi_slave(slave); - struct tiny_spi_regs *regs = (void *)tiny_spi->host->base; - - debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); - gpio_direction_output(slave->cs, !tiny_spi->flg); - writel(tiny_spi->mode, ®s->control); - writel(tiny_spi->baud, ®s->baud); - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); -} - -#ifndef CONFIG_TINY_SPI_IDLE_VAL -# define CONFIG_TINY_SPI_IDLE_VAL 0xff -#endif - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) -{ - struct tiny_spi_slave *tiny_spi = to_tiny_spi_slave(slave); - struct tiny_spi_regs *regs = (void *)tiny_spi->host->base; - const u8 *txp = dout; - u8 *rxp = din; - uint bytes = bitlen / 8; - uint i; - - debug("%s: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", __func__, - slave->bus, slave->cs, bitlen, bytes, flags); - if (bitlen == 0) - goto done; - - /* assume to do 8 bits transfers */ - if (bitlen % 8) { - flags |= SPI_XFER_END; - goto done; - } - - if (flags & SPI_XFER_BEGIN) - spi_cs_activate(slave); - - /* we need to tighten the transfer loop */ - if (txp && rxp) { - writeb(*txp++, ®s->txdata); - if (bytes > 1) { - writeb(*txp++, ®s->txdata); - for (i = 2; i < bytes; i++) { - u8 rx, tx = *txp++; - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXR)) - ; - rx = readb(®s->txdata); - writeb(tx, ®s->txdata); - *rxp++ = rx; - } - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXR)) - ; - *rxp++ = readb(®s->txdata); - } - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXE)) - ; - *rxp++ = readb(®s->rxdata); - } else if (rxp) { - writeb(CONFIG_TINY_SPI_IDLE_VAL, ®s->txdata); - if (bytes > 1) { - writeb(CONFIG_TINY_SPI_IDLE_VAL, - ®s->txdata); - for (i = 2; i < bytes; i++) { - u8 rx; - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXR)) - ; - rx = readb(®s->txdata); - writeb(CONFIG_TINY_SPI_IDLE_VAL, - ®s->txdata); - *rxp++ = rx; - } - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXR)) - ; - *rxp++ = readb(®s->txdata); - } - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXE)) - ; - *rxp++ = readb(®s->rxdata); - } else if (txp) { - writeb(*txp++, ®s->txdata); - if (bytes > 1) { - writeb(*txp++, ®s->txdata); - for (i = 2; i < bytes; i++) { - u8 tx = *txp++; - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXR)) - ; - writeb(tx, ®s->txdata); - } - } - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXE)) - ; - } else { - writeb(CONFIG_TINY_SPI_IDLE_VAL, ®s->txdata); - if (bytes > 1) { - writeb(CONFIG_TINY_SPI_IDLE_VAL, - ®s->txdata); - for (i = 2; i < bytes; i++) { - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXR)) - ; - writeb(CONFIG_TINY_SPI_IDLE_VAL, - ®s->txdata); - } - } - while (!(readb(®s->status) & - TINY_SPI_STATUS_TXE)) - ; - } - - done: - if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); - - return 0; -}
Move the header code into driver for more readable and easy to access it.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Michal Simek michal.simek@xilinx.com --- drivers/spi/xilinx_spi.c | 113 +++++++++++++++++++++++++++++++++++++- drivers/spi/xilinx_spi.h | 138 ----------------------------------------------- 2 files changed, 112 insertions(+), 139 deletions(-) delete mode 100644 drivers/spi/xilinx_spi.h
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 56d99d1..8073edc 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -21,7 +21,118 @@ #include <malloc.h> #include <spi.h>
-#include "xilinx_spi.h" +/* + * Xilinx SPI Register Definition + * + * [1]: [0]/ip_documentation/xps_spi.pdf + * page 8, Register Descriptions + * [2]: [0]/ip_documentation/axi_spi_ds742.pdf + * page 7, Register Overview Table + */ +struct xilinx_spi_reg { + u32 __space0__[7]; + u32 dgier; /* Device Global Interrupt Enable Register (DGIER) */ + u32 ipisr; /* IP Interrupt Status Register (IPISR) */ + u32 __space1__; + u32 ipier; /* IP Interrupt Enable Register (IPIER) */ + u32 __space2__[5]; + u32 srr; /* Softare Reset Register (SRR) */ + u32 __space3__[7]; + u32 spicr; /* SPI Control Register (SPICR) */ + u32 spisr; /* SPI Status Register (SPISR) */ + u32 spidtr; /* SPI Data Transmit Register (SPIDTR) */ + u32 spidrr; /* SPI Data Receive Register (SPIDRR) */ + u32 spissr; /* SPI Slave Select Register (SPISSR) */ + u32 spitfor; /* SPI Transmit FIFO Occupancy Register (SPITFOR) */ + u32 spirfor; /* SPI Receive FIFO Occupancy Register (SPIRFOR) */ +}; + +/* Device Global Interrupt Enable Register (dgier), [1] p15, [2] p15 */ +#define DGIER_GIE (1 << 31) + +/* IP Interrupt Status Register (ipisr), [1] p15, [2] p15 */ +#define IPISR_DRR_NOT_EMPTY (1 << 8) +#define IPISR_SLAVE_SELECT (1 << 7) +#define IPISR_TXF_HALF_EMPTY (1 << 6) +#define IPISR_DRR_OVERRUN (1 << 5) +#define IPISR_DRR_FULL (1 << 4) +#define IPISR_DTR_UNDERRUN (1 << 3) +#define IPISR_DTR_EMPTY (1 << 2) +#define IPISR_SLAVE_MODF (1 << 1) +#define IPISR_MODF (1 << 0) + +/* IP Interrupt Enable Register (ipier), [1] p17, [2] p18 */ +#define IPIER_DRR_NOT_EMPTY (1 << 8) +#define IPIER_SLAVE_SELECT (1 << 7) +#define IPIER_TXF_HALF_EMPTY (1 << 6) +#define IPIER_DRR_OVERRUN (1 << 5) +#define IPIER_DRR_FULL (1 << 4) +#define IPIER_DTR_UNDERRUN (1 << 3) +#define IPIER_DTR_EMPTY (1 << 2) +#define IPIER_SLAVE_MODF (1 << 1) +#define IPIER_MODF (1 << 0) + +/* Softare Reset Register (srr), [1] p9, [2] p8 */ +#define SRR_RESET_CODE 0x0000000A + +/* SPI Control Register (spicr), [1] p9, [2] p8 */ +#define SPICR_LSB_FIRST (1 << 9) +#define SPICR_MASTER_INHIBIT (1 << 8) +#define SPICR_MANUAL_SS (1 << 7) +#define SPICR_RXFIFO_RESEST (1 << 6) +#define SPICR_TXFIFO_RESEST (1 << 5) +#define SPICR_CPHA (1 << 4) +#define SPICR_CPOL (1 << 3) +#define SPICR_MASTER_MODE (1 << 2) +#define SPICR_SPE (1 << 1) +#define SPICR_LOOP (1 << 0) + +/* SPI Status Register (spisr), [1] p11, [2] p10 */ +#define SPISR_SLAVE_MODE_SELECT (1 << 5) +#define SPISR_MODF (1 << 4) +#define SPISR_TX_FULL (1 << 3) +#define SPISR_TX_EMPTY (1 << 2) +#define SPISR_RX_FULL (1 << 1) +#define SPISR_RX_EMPTY (1 << 0) + +/* SPI Data Transmit Register (spidtr), [1] p12, [2] p12 */ +#define SPIDTR_8BIT_MASK (0xff << 0) +#define SPIDTR_16BIT_MASK (0xffff << 0) +#define SPIDTR_32BIT_MASK (0xffffffff << 0) + +/* SPI Data Receive Register (spidrr), [1] p12, [2] p12 */ +#define SPIDRR_8BIT_MASK (0xff << 0) +#define SPIDRR_16BIT_MASK (0xffff << 0) +#define SPIDRR_32BIT_MASK (0xffffffff << 0) + +/* SPI Slave Select Register (spissr), [1] p13, [2] p13 */ +#define SPISSR_MASK(cs) (1 << (cs)) +#define SPISSR_ACT(cs) ~SPISSR_MASK(cs) +#define SPISSR_OFF ~0UL + +/* SPI Transmit FIFO Occupancy Register (spitfor), [1] p13, [2] p14 */ +#define SPITFOR_OCYVAL_POS 0 +#define SPITFOR_OCYVAL_MASK (0xf << SPITFOR_OCYVAL_POS) + +/* SPI Receive FIFO Occupancy Register (spirfor), [1] p14, [2] p14 */ +#define SPIRFOR_OCYVAL_POS 0 +#define SPIRFOR_OCYVAL_MASK (0xf << SPIRFOR_OCYVAL_POS) + +/* SPI Software Reset Register (ssr) */ +#define SPISSR_RESET_VALUE 0x0a + +struct xilinx_spi_slave { + struct spi_slave slave; + struct xilinx_spi_reg *regs; + unsigned int freq; + unsigned int mode; +}; + +static inline struct xilinx_spi_slave *to_xilinx_spi_slave( + struct spi_slave *slave) +{ + return container_of(slave, struct xilinx_spi_slave, slave); +}
#ifndef CONFIG_SYS_XILINX_SPI_LIST #define CONFIG_SYS_XILINX_SPI_LIST { CONFIG_SYS_SPI_BASE } diff --git a/drivers/spi/xilinx_spi.h b/drivers/spi/xilinx_spi.h deleted file mode 100644 index ce7d82c..0000000 --- a/drivers/spi/xilinx_spi.h +++ /dev/null @@ -1,138 +0,0 @@ -/* - * Xilinx SPI driver - * - * XPS/AXI bus interface - * - * based on bfin_spi.c, by way of altera_spi.c - * Copyright (c) 2005-2008 Analog Devices Inc. - * Copyright (c) 2010 Thomas Chou thomas@wytron.com.tw - * Copyright (c) 2010 Graeme Smecher graeme.smecher@mail.mcgill.ca - * Copyright (c) 2012 Stephan Linz linz@li-pro.net - * - * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_spi.pdf - * [0]/ip_documentation/axi_spi_ds742.pdf - */ -#ifndef _XILINX_SPI_ -#define _XILINX_SPI_ - -#include <asm/types.h> -#include <asm/io.h> - -/* - * Xilinx SPI Register Definition - * - * [1]: [0]/ip_documentation/xps_spi.pdf - * page 8, Register Descriptions - * [2]: [0]/ip_documentation/axi_spi_ds742.pdf - * page 7, Register Overview Table - */ -struct xilinx_spi_reg { - u32 __space0__[7]; - u32 dgier; /* Device Global Interrupt Enable Register (DGIER) */ - u32 ipisr; /* IP Interrupt Status Register (IPISR) */ - u32 __space1__; - u32 ipier; /* IP Interrupt Enable Register (IPIER) */ - u32 __space2__[5]; - u32 srr; /* Softare Reset Register (SRR) */ - u32 __space3__[7]; - u32 spicr; /* SPI Control Register (SPICR) */ - u32 spisr; /* SPI Status Register (SPISR) */ - u32 spidtr; /* SPI Data Transmit Register (SPIDTR) */ - u32 spidrr; /* SPI Data Receive Register (SPIDRR) */ - u32 spissr; /* SPI Slave Select Register (SPISSR) */ - u32 spitfor; /* SPI Transmit FIFO Occupancy Register (SPITFOR) */ - u32 spirfor; /* SPI Receive FIFO Occupancy Register (SPIRFOR) */ -}; - -/* Device Global Interrupt Enable Register (dgier), [1] p15, [2] p15 */ -#define DGIER_GIE (1 << 31) - -/* IP Interrupt Status Register (ipisr), [1] p15, [2] p15 */ -#define IPISR_DRR_NOT_EMPTY (1 << 8) -#define IPISR_SLAVE_SELECT (1 << 7) -#define IPISR_TXF_HALF_EMPTY (1 << 6) -#define IPISR_DRR_OVERRUN (1 << 5) -#define IPISR_DRR_FULL (1 << 4) -#define IPISR_DTR_UNDERRUN (1 << 3) -#define IPISR_DTR_EMPTY (1 << 2) -#define IPISR_SLAVE_MODF (1 << 1) -#define IPISR_MODF (1 << 0) - -/* IP Interrupt Enable Register (ipier), [1] p17, [2] p18 */ -#define IPIER_DRR_NOT_EMPTY (1 << 8) -#define IPIER_SLAVE_SELECT (1 << 7) -#define IPIER_TXF_HALF_EMPTY (1 << 6) -#define IPIER_DRR_OVERRUN (1 << 5) -#define IPIER_DRR_FULL (1 << 4) -#define IPIER_DTR_UNDERRUN (1 << 3) -#define IPIER_DTR_EMPTY (1 << 2) -#define IPIER_SLAVE_MODF (1 << 1) -#define IPIER_MODF (1 << 0) - -/* Softare Reset Register (srr), [1] p9, [2] p8 */ -#define SRR_RESET_CODE 0x0000000A - -/* SPI Control Register (spicr), [1] p9, [2] p8 */ -#define SPICR_LSB_FIRST (1 << 9) -#define SPICR_MASTER_INHIBIT (1 << 8) -#define SPICR_MANUAL_SS (1 << 7) -#define SPICR_RXFIFO_RESEST (1 << 6) -#define SPICR_TXFIFO_RESEST (1 << 5) -#define SPICR_CPHA (1 << 4) -#define SPICR_CPOL (1 << 3) -#define SPICR_MASTER_MODE (1 << 2) -#define SPICR_SPE (1 << 1) -#define SPICR_LOOP (1 << 0) - -/* SPI Status Register (spisr), [1] p11, [2] p10 */ -#define SPISR_SLAVE_MODE_SELECT (1 << 5) -#define SPISR_MODF (1 << 4) -#define SPISR_TX_FULL (1 << 3) -#define SPISR_TX_EMPTY (1 << 2) -#define SPISR_RX_FULL (1 << 1) -#define SPISR_RX_EMPTY (1 << 0) - -/* SPI Data Transmit Register (spidtr), [1] p12, [2] p12 */ -#define SPIDTR_8BIT_MASK (0xff << 0) -#define SPIDTR_16BIT_MASK (0xffff << 0) -#define SPIDTR_32BIT_MASK (0xffffffff << 0) - -/* SPI Data Receive Register (spidrr), [1] p12, [2] p12 */ -#define SPIDRR_8BIT_MASK (0xff << 0) -#define SPIDRR_16BIT_MASK (0xffff << 0) -#define SPIDRR_32BIT_MASK (0xffffffff << 0) - -/* SPI Slave Select Register (spissr), [1] p13, [2] p13 */ -#define SPISSR_MASK(cs) (1 << (cs)) -#define SPISSR_ACT(cs) ~SPISSR_MASK(cs) -#define SPISSR_OFF ~0UL - -/* SPI Transmit FIFO Occupancy Register (spitfor), [1] p13, [2] p14 */ -#define SPITFOR_OCYVAL_POS 0 -#define SPITFOR_OCYVAL_MASK (0xf << SPITFOR_OCYVAL_POS) - -/* SPI Receive FIFO Occupancy Register (spirfor), [1] p14, [2] p14 */ -#define SPIRFOR_OCYVAL_POS 0 -#define SPIRFOR_OCYVAL_MASK (0xf << SPIRFOR_OCYVAL_POS) - -/* SPI Software Reset Register (ssr) */ -#define SPISSR_RESET_VALUE 0x0a - -struct xilinx_spi_slave { - struct spi_slave slave; - struct xilinx_spi_reg *regs; - unsigned int freq; - unsigned int mode; -}; - -static inline struct xilinx_spi_slave *to_xilinx_spi_slave( - struct spi_slave *slave) -{ - return container_of(slave, struct xilinx_spi_slave, slave); -} - -#endif /* _XILINX_SPI_ */
- Xilinx SPI Register Definition
- page 8, Register Descriptions
- page 7, Register Overview Table
- u32 __space1__;
- Xilinx SPI driver
- XPS/AXI bus interface
- based on bfin_spi.c, by way of altera_spi.c
- Copyright (c) 2005-2008 Analog Devices Inc.
- Copyright (c) 2010 Thomas Chou thomas@wytron.com.tw
- Copyright (c) 2010 Graeme Smecher graeme.smecher@mail.mcgill.ca
- Copyright (c) 2012 Stephan Linz linz@li-pro.net
- [0]/ip_documentation/axi_spi_ds742.pdf
- u32 __space1__;
Acked-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
- Zap unneeded macros - Re-arrange the code - Removed __attribute__((weak)) - Replace __func__ macro with func names to save macro transition. - Re-arranged comment lines. - Arrange driver code in more readable format[1]
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Michal Simek michal.simek@xilinx.com --- drivers/spi/xilinx_spi.c | 164 ++++++++++++++++------------------------------- 1 file changed, 57 insertions(+), 107 deletions(-)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 8073edc..650e494 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -1,79 +1,31 @@ /* * Xilinx SPI driver * - * supports 8 bit SPI transfers only, with or w/o FIFO + * Supports 8 bit SPI transfers only, with or w/o FIFO * - * based on bfin_spi.c, by way of altera_spi.c - * Copyright (c) 2005-2008 Analog Devices Inc. - * Copyright (c) 2010 Thomas Chou thomas@wytron.com.tw - * Copyright (c) 2010 Graeme Smecher graeme.smecher@mail.mcgill.ca + * Based on bfin_spi.c, by way of altera_spi.c * Copyright (c) 2012 Stephan Linz linz@li-pro.net + * Copyright (c) 2010 Graeme Smecher graeme.smecher@mail.mcgill.ca + * Copyright (c) 2010 Thomas Chou thomas@wytron.com.tw + * Copyright (c) 2005-2008 Analog Devices Inc. * * SPDX-License-Identifier: GPL-2.0+ - * - * [0]: http://www.xilinx.com/support/documentation - * - * [S]: [0]/ip_documentation/xps_spi.pdf - * [0]/ip_documentation/axi_spi_ds742.pdf */ + #include <config.h> #include <common.h> #include <malloc.h> #include <spi.h>
/* - * Xilinx SPI Register Definition + * [0]: http://www.xilinx.com/support/documentation * + * Xilinx SPI Register Definitions * [1]: [0]/ip_documentation/xps_spi.pdf * page 8, Register Descriptions * [2]: [0]/ip_documentation/axi_spi_ds742.pdf * page 7, Register Overview Table */ -struct xilinx_spi_reg { - u32 __space0__[7]; - u32 dgier; /* Device Global Interrupt Enable Register (DGIER) */ - u32 ipisr; /* IP Interrupt Status Register (IPISR) */ - u32 __space1__; - u32 ipier; /* IP Interrupt Enable Register (IPIER) */ - u32 __space2__[5]; - u32 srr; /* Softare Reset Register (SRR) */ - u32 __space3__[7]; - u32 spicr; /* SPI Control Register (SPICR) */ - u32 spisr; /* SPI Status Register (SPISR) */ - u32 spidtr; /* SPI Data Transmit Register (SPIDTR) */ - u32 spidrr; /* SPI Data Receive Register (SPIDRR) */ - u32 spissr; /* SPI Slave Select Register (SPISSR) */ - u32 spitfor; /* SPI Transmit FIFO Occupancy Register (SPITFOR) */ - u32 spirfor; /* SPI Receive FIFO Occupancy Register (SPIRFOR) */ -}; - -/* Device Global Interrupt Enable Register (dgier), [1] p15, [2] p15 */ -#define DGIER_GIE (1 << 31) - -/* IP Interrupt Status Register (ipisr), [1] p15, [2] p15 */ -#define IPISR_DRR_NOT_EMPTY (1 << 8) -#define IPISR_SLAVE_SELECT (1 << 7) -#define IPISR_TXF_HALF_EMPTY (1 << 6) -#define IPISR_DRR_OVERRUN (1 << 5) -#define IPISR_DRR_FULL (1 << 4) -#define IPISR_DTR_UNDERRUN (1 << 3) -#define IPISR_DTR_EMPTY (1 << 2) -#define IPISR_SLAVE_MODF (1 << 1) -#define IPISR_MODF (1 << 0) - -/* IP Interrupt Enable Register (ipier), [1] p17, [2] p18 */ -#define IPIER_DRR_NOT_EMPTY (1 << 8) -#define IPIER_SLAVE_SELECT (1 << 7) -#define IPIER_TXF_HALF_EMPTY (1 << 6) -#define IPIER_DRR_OVERRUN (1 << 5) -#define IPIER_DRR_FULL (1 << 4) -#define IPIER_DTR_UNDERRUN (1 << 3) -#define IPIER_DTR_EMPTY (1 << 2) -#define IPIER_SLAVE_MODF (1 << 1) -#define IPIER_MODF (1 << 0) - -/* Softare Reset Register (srr), [1] p9, [2] p8 */ -#define SRR_RESET_CODE 0x0000000A
/* SPI Control Register (spicr), [1] p9, [2] p8 */ #define SPICR_LSB_FIRST (1 << 9) @@ -110,17 +62,42 @@ struct xilinx_spi_reg { #define SPISSR_ACT(cs) ~SPISSR_MASK(cs) #define SPISSR_OFF ~0UL
-/* SPI Transmit FIFO Occupancy Register (spitfor), [1] p13, [2] p14 */ -#define SPITFOR_OCYVAL_POS 0 -#define SPITFOR_OCYVAL_MASK (0xf << SPITFOR_OCYVAL_POS) - -/* SPI Receive FIFO Occupancy Register (spirfor), [1] p14, [2] p14 */ -#define SPIRFOR_OCYVAL_POS 0 -#define SPIRFOR_OCYVAL_MASK (0xf << SPIRFOR_OCYVAL_POS) - /* SPI Software Reset Register (ssr) */ #define SPISSR_RESET_VALUE 0x0a
+#define XILSPI_MAX_XFER_BITS 8 +#define XILSPI_SPICR_DFLT_ON (SPICR_MANUAL_SS | SPICR_MASTER_MODE | \ + SPICR_SPE) +#define XILSPI_SPICR_DFLT_OFF (SPICR_MASTER_INHIBIT | SPICR_MANUAL_SS) + +#ifndef CONFIG_XILINX_SPI_IDLE_VAL +#define CONFIG_XILINX_SPI_IDLE_VAL 0xff +#endif + +#ifndef CONFIG_SYS_XILINX_SPI_LIST +#define CONFIG_SYS_XILINX_SPI_LIST { CONFIG_SYS_SPI_BASE } +#endif + +/* xilinx spi register set */ +struct xilinx_spi_reg { + u32 __space0__[7]; + u32 dgier; /* Device Global Interrupt Enable Register (DGIER) */ + u32 ipisr; /* IP Interrupt Status Register (IPISR) */ + u32 __space1__; + u32 ipier; /* IP Interrupt Enable Register (IPIER) */ + u32 __space2__[5]; + u32 srr; /* Softare Reset Register (SRR) */ + u32 __space3__[7]; + u32 spicr; /* SPI Control Register (SPICR) */ + u32 spisr; /* SPI Status Register (SPISR) */ + u32 spidtr; /* SPI Data Transmit Register (SPIDTR) */ + u32 spidrr; /* SPI Data Receive Register (SPIDRR) */ + u32 spissr; /* SPI Slave Select Register (SPISSR) */ + u32 spitfor; /* SPI Transmit FIFO Occupancy Register (SPITFOR) */ + u32 spirfor; /* SPI Receive FIFO Occupancy Register (SPIRFOR) */ +}; + +/* xilinx spi slave */ struct xilinx_spi_slave { struct spi_slave slave; struct xilinx_spi_reg *regs; @@ -129,37 +106,17 @@ struct xilinx_spi_slave { };
static inline struct xilinx_spi_slave *to_xilinx_spi_slave( - struct spi_slave *slave) + struct spi_slave *slave) { return container_of(slave, struct xilinx_spi_slave, slave); }
-#ifndef CONFIG_SYS_XILINX_SPI_LIST -#define CONFIG_SYS_XILINX_SPI_LIST { CONFIG_SYS_SPI_BASE } -#endif - -#ifndef CONFIG_XILINX_SPI_IDLE_VAL -#define CONFIG_XILINX_SPI_IDLE_VAL 0xff -#endif - -#define XILSPI_SPICR_DFLT_ON (SPICR_MANUAL_SS | \ - SPICR_MASTER_MODE | \ - SPICR_SPE) - -#define XILSPI_SPICR_DFLT_OFF (SPICR_MASTER_INHIBIT | \ - SPICR_MANUAL_SS) - -#define XILSPI_MAX_XFER_BITS 8 - static unsigned long xilinx_spi_base_list[] = CONFIG_SYS_XILINX_SPI_LIST; - -__attribute__((weak)) int spi_cs_is_valid(unsigned int bus, unsigned int cs) { return bus < ARRAY_SIZE(xilinx_spi_base_list) && cs < 32; }
-__attribute__((weak)) void spi_cs_activate(struct spi_slave *slave) { struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); @@ -167,7 +124,6 @@ void spi_cs_activate(struct spi_slave *slave) writel(SPISSR_ACT(slave->cs), &xilspi->regs->spissr); }
-__attribute__((weak)) void spi_cs_deactivate(struct spi_slave *slave) { struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); @@ -180,33 +136,26 @@ void spi_init(void) /* do nothing */ }
-void spi_set_speed(struct spi_slave *slave, uint hz) -{ - /* xilinx spi core does not support programmable speed */ -} - struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { struct xilinx_spi_slave *xilspi;
if (!spi_cs_is_valid(bus, cs)) { - printf("XILSPI error: %s: unsupported bus %d / cs %d\n", - __func__, bus, cs); + printf("XILSPI error: unsupported bus %d / cs %d\n", bus, cs); return NULL; }
xilspi = spi_alloc_slave(struct xilinx_spi_slave, bus, cs); if (!xilspi) { - printf("XILSPI error: %s: malloc of SPI structure failed\n", - __func__); + printf("XILSPI error: malloc of SPI structure failed\n"); return NULL; } xilspi->regs = (struct xilinx_spi_reg *)xilinx_spi_base_list[bus]; xilspi->freq = max_hz; xilspi->mode = mode; - debug("%s: bus:%i cs:%i base:%p mode:%x max_hz:%d\n", __func__, - bus, cs, xilspi->regs, xilspi->mode, xilspi->freq); + debug("spi_setup_slave: bus:%i cs:%i base:%p mode:%x max_hz:%d\n", + bus, cs, xilspi->regs, xilspi->mode, xilspi->freq);
writel(SPISSR_RESET_VALUE, &xilspi->regs->srr);
@@ -225,7 +174,7 @@ int spi_claim_bus(struct spi_slave *slave) struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave); u32 spicr;
- debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + debug("spi_claim_bus: bus:%i cs:%i\n", slave->bus, slave->cs); writel(SPISSR_OFF, &xilspi->regs->spissr);
spicr = XILSPI_SPICR_DFLT_ON; @@ -246,7 +195,7 @@ void spi_release_bus(struct spi_slave *slave) { struct xilinx_spi_slave *xilspi = to_xilinx_spi_slave(slave);
- debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + debug("spi_release_bus: bus:%i cs:%i\n", slave->bus, slave->cs); writel(SPISSR_OFF, &xilspi->regs->spissr); writel(XILSPI_SPICR_DFLT_OFF, &xilspi->regs->spicr); } @@ -262,14 +211,15 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, unsigned rxecount = 17; /* max. 16 elements in FIFO, leftover 1 */ unsigned global_timeout;
- debug("%s: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", __func__, - slave->bus, slave->cs, bitlen, bytes, flags); + debug("spi_xfer: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", + slave->bus, slave->cs, bitlen, bytes, flags); + if (bitlen == 0) goto done;
if (bitlen % XILSPI_MAX_XFER_BITS) { - printf("XILSPI warning: %s: Not a multiple of %d bits\n", - __func__, XILSPI_MAX_XFER_BITS); + printf("XILSPI warning: Not a multiple of %d bits\n", + XILSPI_MAX_XFER_BITS); flags |= SPI_XFER_END; goto done; } @@ -281,7 +231,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
if (!rxecount) { - printf("XILSPI error: %s: Rx buffer not empty\n", __func__); + printf("XILSPI error: Rx buffer not empty\n"); return -1; }
@@ -296,7 +246,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, unsigned timeout = global_timeout; /* get Tx element from data out buffer and count up */ unsigned char d = txp ? *txp++ : CONFIG_XILINX_SPI_IDLE_VAL; - debug("%s: tx:%x ", __func__, d); + debug("spi_xfer: tx:%x ", d);
/* write out and wait for processing (receive data) */ writel(d & SPIDTR_8BIT_MASK, &xilspi->regs->spidtr); @@ -307,7 +257,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
if (!timeout) { - printf("XILSPI error: %s: Xfer timeout\n", __func__); + printf("XILSPI error: Xfer timeout\n"); return -1; }
@@ -315,7 +265,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, d = readl(&xilspi->regs->spidrr) & SPIDRR_8BIT_MASK; if (rxp) *rxp++ = d; - debug("rx:%x\n", d); + debug("spi_xfer: rx:%x\n", d); }
done:
[1] http://lists.denx.de/pipermail/u-boot/2013-August/160473.html
- Xilinx SPI driver
- supports 8 bit SPI transfers only, with or w/o FIFO
- Supports 8 bit SPI transfers only, with or w/o FIFO
- Based on bfin_spi.c, by way of altera_spi.c
- Xilinx SPI Register Definitions
- u32 __space1__;
SPICR_SPE)
- u32 __space1__;
SPICR_SPE)
SPICR_MANUAL_SS)
__func__, bus, cs);
return NULL; }
__func__);
return NULL; } xilspi->regs = (struct xilinx_spi_reg *)xilinx_spi_base_list[bus]; xilspi->freq = max_hz; xilspi->mode = mode;printf("XILSPI error: malloc of SPI structure failed\n");
- debug("spi_release_bus: bus:%i cs:%i\n", slave->bus, slave->cs); writel(SPISSR_OFF, &xilspi->regs->spissr); writel(XILSPI_SPICR_DFLT_OFF, &xilspi->regs->spicr);
flags |= SPI_XFER_END; goto done; }XILSPI_MAX_XFER_BITS);
if (!rxecount) {
return -1; }printf("XILSPI error: Rx buffer not empty\n");
if (!timeout) {
}printf("XILSPI error: Xfer timeout\n"); return -1;
done:
Hopefully there is functional change there.
Thanks, Michal
- Xilinx SPI driver
u32 __space0__[7];
u32 __space1__;
u32 __space2__[5];
u32 __space3__[7];
SPICR_SPE)
u32 __space0__[7];
u32 __space1__;
u32 __space2__[5];
u32 __space3__[7];
SPICR_SPE)
SPICR_MANUAL_SS)
__func__, bus, cs);
printf("XILSPI error: unsupported bus %d / cs %d\n", bus, cs); return NULL; } xilspi = spi_alloc_slave(struct xilinx_spi_slave, bus, cs); if (!xilspi) {
__func__);
bus, cs, xilspi->regs, xilspi->mode, xilspi->freq); writel(SPISSR_RESET_VALUE, &xilspi->regs->srr);
debug("spi_claim_bus: bus:%i cs:%i\n", slave->bus, slave->cs); writel(SPISSR_OFF, &xilspi->regs->spissr); spicr = XILSPI_SPICR_DFLT_ON;
if (bitlen == 0) goto done; if (bitlen % XILSPI_MAX_XFER_BITS) {
if (!rxecount) {
debug("spi_xfer: tx:%x ", d); /* write out and wait for processing (receive data) */ writel(d & SPIDTR_8BIT_MASK, &xilspi->regs->spidtr);
if (!timeout) {
done:
It's debug print update similar to tx, may be I will add note on commit message.
thanks!
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Rex Chang rchang@ti.com Cc: Murali Karicheri m-karicheri2@ti.com --- drivers/spi/davinci_spi.c | 110 ++++++++++++++++++++++++++++++++++++++++- drivers/spi/davinci_spi.h | 121 ---------------------------------------------- 2 files changed, 109 insertions(+), 122 deletions(-) delete mode 100644 drivers/spi/davinci_spi.h
diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index bf18362..e0ecf99 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -13,7 +13,115 @@ #include <malloc.h> #include <asm/io.h> #include <asm/arch/hardware.h> -#include "davinci_spi.h" + +struct davinci_spi_regs { + dv_reg gcr0; /* 0x00 */ + dv_reg gcr1; /* 0x04 */ + dv_reg int0; /* 0x08 */ + dv_reg lvl; /* 0x0c */ + dv_reg flg; /* 0x10 */ + dv_reg pc0; /* 0x14 */ + dv_reg pc1; /* 0x18 */ + dv_reg pc2; /* 0x1c */ + dv_reg pc3; /* 0x20 */ + dv_reg pc4; /* 0x24 */ + dv_reg pc5; /* 0x28 */ + dv_reg rsvd[3]; + dv_reg dat0; /* 0x38 */ + dv_reg dat1; /* 0x3c */ + dv_reg buf; /* 0x40 */ + dv_reg emu; /* 0x44 */ + dv_reg delay; /* 0x48 */ + dv_reg def; /* 0x4c */ + dv_reg fmt0; /* 0x50 */ + dv_reg fmt1; /* 0x54 */ + dv_reg fmt2; /* 0x58 */ + dv_reg fmt3; /* 0x5c */ + dv_reg intvec0; /* 0x60 */ + dv_reg intvec1; /* 0x64 */ +}; + +#define BIT(x) (1 << (x)) + +/* SPIGCR0 */ +#define SPIGCR0_SPIENA_MASK 0x1 +#define SPIGCR0_SPIRST_MASK 0x0 + +/* SPIGCR0 */ +#define SPIGCR1_CLKMOD_MASK BIT(1) +#define SPIGCR1_MASTER_MASK BIT(0) +#define SPIGCR1_SPIENA_MASK BIT(24) + +/* SPIPC0 */ +#define SPIPC0_DIFUN_MASK BIT(11) /* SIMO */ +#define SPIPC0_DOFUN_MASK BIT(10) /* SOMI */ +#define SPIPC0_CLKFUN_MASK BIT(9) /* CLK */ +#define SPIPC0_EN0FUN_MASK BIT(0) + +/* SPIFMT0 */ +#define SPIFMT_SHIFTDIR_SHIFT 20 +#define SPIFMT_POLARITY_SHIFT 17 +#define SPIFMT_PHASE_SHIFT 16 +#define SPIFMT_PRESCALE_SHIFT 8 + +/* SPIDAT1 */ +#define SPIDAT1_CSHOLD_SHIFT 28 +#define SPIDAT1_CSNR_SHIFT 16 + +/* SPIDELAY */ +#define SPI_C2TDELAY_SHIFT 24 +#define SPI_T2CDELAY_SHIFT 16 + +/* SPIBUF */ +#define SPIBUF_RXEMPTY_MASK BIT(31) +#define SPIBUF_TXFULL_MASK BIT(29) + +/* SPIDEF */ +#define SPIDEF_CSDEF0_MASK BIT(0) + +#define SPI0_BUS 0 +#define SPI0_BASE CONFIG_SYS_SPI_BASE +/* + * Define default SPI0_NUM_CS as 1 for existing platforms that uses this + * driver. Platform can configure number of CS using CONFIG_SYS_SPI0_NUM_CS + * if more than one CS is supported and by defining CONFIG_SYS_SPI0. + */ +#ifndef CONFIG_SYS_SPI0 +#define SPI0_NUM_CS 1 +#else +#define SPI0_NUM_CS CONFIG_SYS_SPI0_NUM_CS +#endif + +/* + * define CONFIG_SYS_SPI1 when platform has spi-1 device (bus #1) and + * CONFIG_SYS_SPI1_NUM_CS defines number of CS on this bus + */ +#ifdef CONFIG_SYS_SPI1 +#define SPI1_BUS 1 +#define SPI1_NUM_CS CONFIG_SYS_SPI1_NUM_CS +#define SPI1_BASE CONFIG_SYS_SPI1_BASE +#endif + +/* + * define CONFIG_SYS_SPI2 when platform has spi-2 device (bus #2) and + * CONFIG_SYS_SPI2_NUM_CS defines number of CS on this bus + */ +#ifdef CONFIG_SYS_SPI2 +#define SPI2_BUS 2 +#define SPI2_NUM_CS CONFIG_SYS_SPI2_NUM_CS +#define SPI2_BASE CONFIG_SYS_SPI2_BASE +#endif + +struct davinci_spi_slave { + struct spi_slave slave; + struct davinci_spi_regs *regs; + unsigned int freq; +}; + +static inline struct davinci_spi_slave *to_davinci_spi(struct spi_slave *slave) +{ + return container_of(slave, struct davinci_spi_slave, slave); +}
void spi_init() { diff --git a/drivers/spi/davinci_spi.h b/drivers/spi/davinci_spi.h deleted file mode 100644 index d4612d3..0000000 --- a/drivers/spi/davinci_spi.h +++ /dev/null @@ -1,121 +0,0 @@ -/* - * Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/ - * - * Register definitions for the DaVinci SPI Controller - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _DAVINCI_SPI_H_ -#define _DAVINCI_SPI_H_ - -struct davinci_spi_regs { - dv_reg gcr0; /* 0x00 */ - dv_reg gcr1; /* 0x04 */ - dv_reg int0; /* 0x08 */ - dv_reg lvl; /* 0x0c */ - dv_reg flg; /* 0x10 */ - dv_reg pc0; /* 0x14 */ - dv_reg pc1; /* 0x18 */ - dv_reg pc2; /* 0x1c */ - dv_reg pc3; /* 0x20 */ - dv_reg pc4; /* 0x24 */ - dv_reg pc5; /* 0x28 */ - dv_reg rsvd[3]; - dv_reg dat0; /* 0x38 */ - dv_reg dat1; /* 0x3c */ - dv_reg buf; /* 0x40 */ - dv_reg emu; /* 0x44 */ - dv_reg delay; /* 0x48 */ - dv_reg def; /* 0x4c */ - dv_reg fmt0; /* 0x50 */ - dv_reg fmt1; /* 0x54 */ - dv_reg fmt2; /* 0x58 */ - dv_reg fmt3; /* 0x5c */ - dv_reg intvec0; /* 0x60 */ - dv_reg intvec1; /* 0x64 */ -}; - -#define BIT(x) (1 << (x)) - -/* SPIGCR0 */ -#define SPIGCR0_SPIENA_MASK 0x1 -#define SPIGCR0_SPIRST_MASK 0x0 - -/* SPIGCR0 */ -#define SPIGCR1_CLKMOD_MASK BIT(1) -#define SPIGCR1_MASTER_MASK BIT(0) -#define SPIGCR1_SPIENA_MASK BIT(24) - -/* SPIPC0 */ -#define SPIPC0_DIFUN_MASK BIT(11) /* SIMO */ -#define SPIPC0_DOFUN_MASK BIT(10) /* SOMI */ -#define SPIPC0_CLKFUN_MASK BIT(9) /* CLK */ -#define SPIPC0_EN0FUN_MASK BIT(0) - -/* SPIFMT0 */ -#define SPIFMT_SHIFTDIR_SHIFT 20 -#define SPIFMT_POLARITY_SHIFT 17 -#define SPIFMT_PHASE_SHIFT 16 -#define SPIFMT_PRESCALE_SHIFT 8 - -/* SPIDAT1 */ -#define SPIDAT1_CSHOLD_SHIFT 28 -#define SPIDAT1_CSNR_SHIFT 16 - -/* SPIDELAY */ -#define SPI_C2TDELAY_SHIFT 24 -#define SPI_T2CDELAY_SHIFT 16 - -/* SPIBUF */ -#define SPIBUF_RXEMPTY_MASK BIT(31) -#define SPIBUF_TXFULL_MASK BIT(29) - -/* SPIDEF */ -#define SPIDEF_CSDEF0_MASK BIT(0) - -#define SPI0_BUS 0 -#define SPI0_BASE CONFIG_SYS_SPI_BASE -/* - * Define default SPI0_NUM_CS as 1 for existing platforms that uses this - * driver. Platform can configure number of CS using CONFIG_SYS_SPI0_NUM_CS - * if more than one CS is supported and by defining CONFIG_SYS_SPI0. - */ -#ifndef CONFIG_SYS_SPI0 -#define SPI0_NUM_CS 1 -#else -#define SPI0_NUM_CS CONFIG_SYS_SPI0_NUM_CS -#endif - -/* - * define CONFIG_SYS_SPI1 when platform has spi-1 device (bus #1) and - * CONFIG_SYS_SPI1_NUM_CS defines number of CS on this bus - */ -#ifdef CONFIG_SYS_SPI1 -#define SPI1_BUS 1 -#define SPI1_NUM_CS CONFIG_SYS_SPI1_NUM_CS -#define SPI1_BASE CONFIG_SYS_SPI1_BASE -#endif - -/* - * define CONFIG_SYS_SPI2 when platform has spi-2 device (bus #2) and - * CONFIG_SYS_SPI2_NUM_CS defines number of CS on this bus - */ -#ifdef CONFIG_SYS_SPI2 -#define SPI2_BUS 2 -#define SPI2_NUM_CS CONFIG_SYS_SPI2_NUM_CS -#define SPI2_BASE CONFIG_SYS_SPI2_BASE -#endif - -struct davinci_spi_slave { - struct spi_slave slave; - struct davinci_spi_regs *regs; - unsigned int freq; -}; - -static inline struct davinci_spi_slave *to_davinci_spi(struct spi_slave *slave) -{ - return container_of(slave, struct davinci_spi_slave, slave); -} - -#endif /* _DAVINCI_SPI_H_ */
Arrange driver code in more readable format[1] for easy accessing and readable. [1] http://lists.denx.de/pipermail/u-boot/2013-August/160473.html
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Rex Chang rchang@ti.com Cc: Murali Karicheri m-karicheri2@ti.com --- drivers/spi/davinci_spi.c | 343 +++++++++++++++++++++++----------------------- 1 file changed, 173 insertions(+), 170 deletions(-)
diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index e0ecf99..0a036cc 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -8,39 +8,13 @@ * * SPDX-License-Identifier: GPL-2.0+ */ + #include <common.h> #include <spi.h> #include <malloc.h> #include <asm/io.h> #include <asm/arch/hardware.h>
-struct davinci_spi_regs { - dv_reg gcr0; /* 0x00 */ - dv_reg gcr1; /* 0x04 */ - dv_reg int0; /* 0x08 */ - dv_reg lvl; /* 0x0c */ - dv_reg flg; /* 0x10 */ - dv_reg pc0; /* 0x14 */ - dv_reg pc1; /* 0x18 */ - dv_reg pc2; /* 0x1c */ - dv_reg pc3; /* 0x20 */ - dv_reg pc4; /* 0x24 */ - dv_reg pc5; /* 0x28 */ - dv_reg rsvd[3]; - dv_reg dat0; /* 0x38 */ - dv_reg dat1; /* 0x3c */ - dv_reg buf; /* 0x40 */ - dv_reg emu; /* 0x44 */ - dv_reg delay; /* 0x48 */ - dv_reg def; /* 0x4c */ - dv_reg fmt0; /* 0x50 */ - dv_reg fmt1; /* 0x54 */ - dv_reg fmt2; /* 0x58 */ - dv_reg fmt3; /* 0x5c */ - dv_reg intvec0; /* 0x60 */ - dv_reg intvec1; /* 0x64 */ -}; - #define BIT(x) (1 << (x))
/* SPIGCR0 */ @@ -112,6 +86,35 @@ struct davinci_spi_regs { #define SPI2_BASE CONFIG_SYS_SPI2_BASE #endif
+/* davinci spi register set */ +struct davinci_spi_regs { + dv_reg gcr0; /* 0x00 */ + dv_reg gcr1; /* 0x04 */ + dv_reg int0; /* 0x08 */ + dv_reg lvl; /* 0x0c */ + dv_reg flg; /* 0x10 */ + dv_reg pc0; /* 0x14 */ + dv_reg pc1; /* 0x18 */ + dv_reg pc2; /* 0x1c */ + dv_reg pc3; /* 0x20 */ + dv_reg pc4; /* 0x24 */ + dv_reg pc5; /* 0x28 */ + dv_reg rsvd[3]; + dv_reg dat0; /* 0x38 */ + dv_reg dat1; /* 0x3c */ + dv_reg buf; /* 0x40 */ + dv_reg emu; /* 0x44 */ + dv_reg delay; /* 0x48 */ + dv_reg def; /* 0x4c */ + dv_reg fmt0; /* 0x50 */ + dv_reg fmt1; /* 0x54 */ + dv_reg fmt2; /* 0x58 */ + dv_reg fmt3; /* 0x5c */ + dv_reg intvec0; /* 0x60 */ + dv_reg intvec1; /* 0x64 */ +}; + +/* davinci spi slave */ struct davinci_spi_slave { struct spi_slave slave; struct davinci_spi_regs *regs; @@ -123,111 +126,6 @@ static inline struct davinci_spi_slave *to_davinci_spi(struct spi_slave *slave) return container_of(slave, struct davinci_spi_slave, slave); }
-void spi_init() -{ - /* do nothing */ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct davinci_spi_slave *ds; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ds = spi_alloc_slave(struct davinci_spi_slave, bus, cs); - if (!ds) - return NULL; - - switch (bus) { - case SPI0_BUS: - ds->regs = (struct davinci_spi_regs *)SPI0_BASE; - break; -#ifdef CONFIG_SYS_SPI1 - case SPI1_BUS: - ds->regs = (struct davinci_spi_regs *)SPI1_BASE; - break; -#endif -#ifdef CONFIG_SYS_SPI2 - case SPI2_BUS: - ds->regs = (struct davinci_spi_regs *)SPI2_BASE; - break; -#endif - default: /* Invalid bus number */ - return NULL; - } - - ds->freq = max_hz; - - return &ds->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - free(ds); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - unsigned int scalar; - - /* Enable the SPI hardware */ - writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); - udelay(1000); - writel(SPIGCR0_SPIENA_MASK, &ds->regs->gcr0); - - /* Set master mode, powered up and not activated */ - writel(SPIGCR1_MASTER_MASK | SPIGCR1_CLKMOD_MASK, &ds->regs->gcr1); - - /* CS, CLK, SIMO and SOMI are functional pins */ - writel(((1 << slave->cs) | SPIPC0_CLKFUN_MASK | - SPIPC0_DOFUN_MASK | SPIPC0_DIFUN_MASK), &ds->regs->pc0); - - /* setup format */ - scalar = ((CONFIG_SYS_SPI_CLK / ds->freq) - 1) & 0xFF; - - /* - * Use following format: - * character length = 8, - * clock signal delayed by half clk cycle, - * clock low in idle state - Mode 0, - * MSB shifted out first - */ - writel(8 | (scalar << SPIFMT_PRESCALE_SHIFT) | - (1 << SPIFMT_PHASE_SHIFT), &ds->regs->fmt0); - - /* - * Including a minor delay. No science here. Should be good even with - * no delay - */ - writel((50 << SPI_C2TDELAY_SHIFT) | - (50 << SPI_T2CDELAY_SHIFT), &ds->regs->delay); - - /* default chip select register */ - writel(SPIDEF_CSDEF0_MASK, &ds->regs->def); - - /* no interrupts */ - writel(0, &ds->regs->int0); - writel(0, &ds->regs->lvl); - - /* enable SPI */ - writel((readl(&ds->regs->gcr1) | SPIGCR1_SPIENA_MASK), &ds->regs->gcr1); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - /* Disable the SPI hardware */ - writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); -} - /* * This functions needs to act like a macro to avoid pipeline reloads in the * loops below. Use always_inline. This gains us about 160KiB/s and the bloat @@ -343,6 +241,149 @@ static int davinci_spi_read_write(struct spi_slave *slave, unsigned int len, } #endif
+int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + int ret = 0; + + switch (bus) { + case SPI0_BUS: + if (cs < SPI0_NUM_CS) + ret = 1; + break; +#ifdef CONFIG_SYS_SPI1 + case SPI1_BUS: + if (cs < SPI1_NUM_CS) + ret = 1; + break; +#endif +#ifdef CONFIG_SYS_SPI2 + case SPI2_BUS: + if (cs < SPI2_NUM_CS) + ret = 1; + break; +#endif + default: + /* Invalid bus number. Do nothing */ + break; + } + return ret; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void spi_init(void) +{ + /* do nothing */ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct davinci_spi_slave *ds; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ds = spi_alloc_slave(struct davinci_spi_slave, bus, cs); + if (!ds) + return NULL; + + switch (bus) { + case SPI0_BUS: + ds->regs = (struct davinci_spi_regs *)SPI0_BASE; + break; +#ifdef CONFIG_SYS_SPI1 + case SPI1_BUS: + ds->regs = (struct davinci_spi_regs *)SPI1_BASE; + break; +#endif +#ifdef CONFIG_SYS_SPI2 + case SPI2_BUS: + ds->regs = (struct davinci_spi_regs *)SPI2_BASE; + break; +#endif + default: /* Invalid bus number */ + return NULL; + } + + ds->freq = max_hz; + + return &ds->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct davinci_spi_slave *ds = to_davinci_spi(slave); + + free(ds); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct davinci_spi_slave *ds = to_davinci_spi(slave); + unsigned int scalar; + + /* Enable the SPI hardware */ + writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); + udelay(1000); + writel(SPIGCR0_SPIENA_MASK, &ds->regs->gcr0); + + /* Set master mode, powered up and not activated */ + writel(SPIGCR1_MASTER_MASK | SPIGCR1_CLKMOD_MASK, &ds->regs->gcr1); + + /* CS, CLK, SIMO and SOMI are functional pins */ + writel(((1 << slave->cs) | SPIPC0_CLKFUN_MASK | + SPIPC0_DOFUN_MASK | SPIPC0_DIFUN_MASK), &ds->regs->pc0); + + /* setup format */ + scalar = ((CONFIG_SYS_SPI_CLK / ds->freq) - 1) & 0xFF; + + /* + * Use following format: + * character length = 8, + * clock signal delayed by half clk cycle, + * clock low in idle state - Mode 0, + * MSB shifted out first + */ + writel(8 | (scalar << SPIFMT_PRESCALE_SHIFT) | + (1 << SPIFMT_PHASE_SHIFT), &ds->regs->fmt0); + + /* + * Including a minor delay. No science here. Should be good even with + * no delay + */ + writel((50 << SPI_C2TDELAY_SHIFT) | + (50 << SPI_T2CDELAY_SHIFT), &ds->regs->delay); + + /* default chip select register */ + writel(SPIDEF_CSDEF0_MASK, &ds->regs->def); + + /* no interrupts */ + writel(0, &ds->regs->int0); + writel(0, &ds->regs->lvl); + + /* enable SPI */ + writel((readl(&ds->regs->gcr1) | SPIGCR1_SPIENA_MASK), &ds->regs->gcr1); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct davinci_spi_slave *ds = to_davinci_spi(slave); + + /* Disable the SPI hardware */ + writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); +} + int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { @@ -386,41 +427,3 @@ out: } return 0; } - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - int ret = 0; - - switch (bus) { - case SPI0_BUS: - if (cs < SPI0_NUM_CS) - ret = 1; - break; -#ifdef CONFIG_SYS_SPI1 - case SPI1_BUS: - if (cs < SPI1_NUM_CS) - ret = 1; - break; -#endif -#ifdef CONFIG_SYS_SPI2 - case SPI2_BUS: - if (cs < SPI2_NUM_CS) - ret = 1; - break; -#endif - default: - /* Invalid bus number. Do nothing */ - break; - } - return ret; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - /* do nothing */ -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - /* do nothing */ -}
Axel Lin
Jagan Teki
Michal Simek
