[U-Boot] [PATCH v3 1/5] 85xx: add boot from NAND/eSDHC/eSPI support
The MPC8536E is capable of booting form NAND/eSDHC/eSPI, this patch implements these three bootup methods in a unified way - all of these use the general cpu/mpc85xx/start.S, and load the main image to L2SRAM which lets us use the SPD to initialize the SDRAM.
For all three bootup methods, the bootup process can be divided into two stages: the first stage will initialize the corresponding controller, configure the L2SRAM, then copy the second stage image to L2SRAM and jump to it. The second stage image is just like the general U-Boot image to configure all the hardware and boot up to U-Boot command line.
When boot from NAND, the eLBC controller will first load the first stage image to internal 4K RAM buffer because it's also stored on the NAND flash. The first stage image, also call 4K NADN loader, will initialize the L2SRAM, load the second stage image to L2SRAM and jump to it. The 4K NAND loader's code comes from the corresponding nand_spl directory, along with the code twisted by CONFIG_NAND_SPL.
When boot from eSDHC/eSPI, there's no such a first stage image because the CPU ROM code does the same work. It will initialize the L2SRAM according to the config addr/word pairs on the fixed address and initialize the eSDHC/eSPI controller, then load the second stage image to L2SRAM and jump to it.
The macro CONFIG_SYS_RAMBOOT is used to control the code to produce the second stage image for all different bootup methods. It's set in the board config file when one of the bootup methods above is selected.
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com ---
- Move u-boot-nand.lds from board directory to cpu/mpc85xx, which make it avalible for 85xx platform - Some modification on u-boot-nand.lds accoring to u-boot.lds
cpu/mpc85xx/cpu_init.c | 19 ++++++ cpu/mpc85xx/start.S | 23 +++++++- cpu/mpc85xx/tlb.c | 6 ++ cpu/mpc85xx/u-boot-nand.lds | 140 +++++++++++++++++++++++++++++++++++++++++++ drivers/misc/fsl_law.c | 2 + 5 files changed, 189 insertions(+), 1 deletions(-) create mode 100644 cpu/mpc85xx/u-boot-nand.lds
diff --git a/cpu/mpc85xx/cpu_init.c b/cpu/mpc85xx/cpu_init.c index a54cf5d..5f66511 100644 --- a/cpu/mpc85xx/cpu_init.c +++ b/cpu/mpc85xx/cpu_init.c @@ -291,6 +291,25 @@ int cpu_init_r(void)
asm("msync;isync"); cache_ctl = l2cache->l2ctl; + +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L2_ADDR) + if (cache_ctl & MPC85xx_L2CTL_L2E) { + /* Clear L2 SRAM memory-mapped base address */ + out_be32(&l2cache->l2srbar0, 0x0); + out_be32(&l2cache->l2srbar1, 0x0); + + /* set MBECCDIS=0, SBECCDIS=0 */ + clrbits_be32(&l2cache->l2errdis, + (MPC85xx_L2ERRDIS_MBECC | + MPC85xx_L2ERRDIS_SBECC)); + + /* set L2E=0, L2SRAM=0 */ + clrbits_be32(&l2cache->l2ctl, + (MPC85xx_L2CTL_L2E | + MPC85xx_L2CTL_L2SRAM_ENTIRE)); + } +#endif + l2siz_field = (cache_ctl >> 28) & 0x3;
switch (l2siz_field) { diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index e21a4eb..c5b6bd9 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -57,10 +57,12 @@ GOT_ENTRY(_GOT2_TABLE_) GOT_ENTRY(_FIXUP_TABLE_)
+#ifndef CONFIG_NAND_SPL GOT_ENTRY(_start) GOT_ENTRY(_start_of_vectors) GOT_ENTRY(_end_of_vectors) GOT_ENTRY(transfer_to_handler) +#endif
GOT_ENTRY(__init_end) GOT_ENTRY(_end) @@ -235,10 +237,11 @@ _start_e500:
#endif /* CONFIG_MPC8569 */
- /* create a temp mapping in AS=1 to the 4M boot window */ lis r6,FSL_BOOKE_MAS0(1, 15, 0)@h ori r6,r6,FSL_BOOKE_MAS0(1, 15, 0)@l
+#ifndef CONFIG_SYS_RAMBOOT + /* create a temp mapping in AS=1 to the 4M boot window */ lis r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_4M)@h ori r7,r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_4M)@l
@@ -248,6 +251,20 @@ _start_e500: /* The 85xx has the default boot window 0xff800000 - 0xffffffff */ lis r9,FSL_BOOKE_MAS3(0xffc00000, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@h ori r9,r9,FSL_BOOKE_MAS3(0xffc00000, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@l +#else + /* + * create a temp mapping in AS=1 to the 1M TEXT_BASE space, the main + * image has been relocated to TEXT_BASE on the second stage. + */ + lis r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_1M)@h + ori r7,r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_1M)@l + + lis r8,FSL_BOOKE_MAS2(TEXT_BASE, (MAS2_I|MAS2_G))@h + ori r8,r8,FSL_BOOKE_MAS2(TEXT_BASE, (MAS2_I|MAS2_G))@l + + lis r9,FSL_BOOKE_MAS3(TEXT_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@h + ori r9,r9,FSL_BOOKE_MAS3(TEXT_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@l +#endif
mtspr MAS0,r6 mtspr MAS1,r7 @@ -359,6 +376,7 @@ _start_cont: bl board_init_f isync
+#ifndef CONFIG_NAND_SPL . = EXC_OFF_SYS_RESET .globl _start_of_vectors _start_of_vectors: @@ -813,6 +831,7 @@ in32: in32r: lwbrx r3,r0,r3 blr +#endif /* !CONFIG_NAND_SPL */
@@ -975,6 +994,7 @@ clear_bss: mr r4,r10 /* Destination Address */ bl board_init_r
+#ifndef CONFIG_NAND_SPL /* * Copy exception vector code to low memory * @@ -1128,3 +1148,4 @@ setup_ivors:
#include "fixed_ivor.S" blr +#endif /* !CONFIG_NAND_SPL */ diff --git a/cpu/mpc85xx/tlb.c b/cpu/mpc85xx/tlb.c index 0497a29..3fc7bd5 100644 --- a/cpu/mpc85xx/tlb.c +++ b/cpu/mpc85xx/tlb.c @@ -59,6 +59,7 @@ void set_tlb(u8 tlb, u32 epn, u64 rpn, #endif }
+#ifndef CONFIG_NAND_SPL void disable_tlb(u8 esel) { u32 _mas0, _mas1, _mas2, _mas3, _mas7; @@ -83,6 +84,7 @@ void disable_tlb(u8 esel) addrmap_set_entry(0, 0, 0, esel); #endif } +#endif
void invalidate_tlb(u8 tlb) { @@ -106,6 +108,7 @@ void init_tlbs(void) return ; }
+#ifdef CONFIG_NADN_SPL static void tlbsx (const volatile unsigned *addr) { __asm__ __volatile__ ("tlbsx 0,%0" : : "r" (addr), "m" (*addr)); @@ -132,6 +135,7 @@ int find_tlb_idx(void *addr, u8 tlbsel)
return -1; } +#endif
#ifdef CONFIG_ADDR_MAP void init_addr_map(void) @@ -168,6 +172,7 @@ void init_addr_map(void) } #endif
+#ifndef CONFIG_NAND_SPL #ifndef CONFIG_SYS_DDR_TLB_START #define CONFIG_SYS_DDR_TLB_START 8 #endif @@ -215,3 +220,4 @@ unsigned int setup_ddr_tlbs(unsigned int memsize_in_meg) */ return memsize_in_meg; } +#endif /* !CONFIG_NAND_SPL */ diff --git a/cpu/mpc85xx/u-boot-nand.lds b/cpu/mpc85xx/u-boot-nand.lds new file mode 100644 index 0000000..c14e946 --- /dev/null +++ b/cpu/mpc85xx/u-boot-nand.lds @@ -0,0 +1,140 @@ +/* + * Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + *(.text) + *(.fixup) + *(.got1) + } :text + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + *(.eh_frame) + } :text + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >> 2; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + .bootpg ADDR(.text) - 0x1000 : + { + cpu/mpc85xx/start.o (.bootpg) + } :text = 0xffff + + . = ADDR(.text) + 0x80000; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } :bss + + . = ALIGN(4); + _end = . ; + PROVIDE (end = .); +} diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index 7bdd355..aa877c6 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -74,6 +74,7 @@ int set_next_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) return idx; }
+#ifndef CONFIG_NAND_SPL int set_last_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) { u32 idx; @@ -166,6 +167,7 @@ int set_ddr_laws(u64 start, u64 sz, enum law_trgt_if id)
return 0; } +#endif
void init_laws(void) {
MPC8536E can support booting from NAND flash which uses the image u-boot-nand.bin. This image contains two parts: a 4K NAND loader and a main U-Boot image. The former is appended to the latter to produce u-boot-nand.bin. The 4K NAND loader includes the corresponding nand_spl directory, along with the code twisted by CONFIG_NAND_SPL. The main U-Boot image just like a general U-Boot image except the parts that included by CONFIG_SYS_RAMBOOT.
When power on, eLBC will automatically load from bank 0 the 4K NAND loader into the FCM buffer RAM where CPU can execute the boot code directly. In the first stage, the NAND loader copies itself to RAM or L2SRAM to free up the FCM buffer RAM, then loads the main image from NAND flash to RAM or L2SRAM and boot from it.
This patch implements the NAND loader to load the main image into L2SRAM, so the main image can configure the RAM by using SPD EEPROM. In the first stage, the NAND loader copies itself to the second to last 4K address space, and uses the last 4K address space as the initial RAM for stack.
Obviously, the size of L2SRAM shouldn't be less than the size of the image used. If so, the workaround is to generate another image that includes the code to configure the RAM by SPD and load it to L2SRAM first, then relocate the main image to RAM to boot up.
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com --- Makefile | 1 + board/freescale/mpc8536ds/config.mk | 7 ++ board/freescale/mpc8536ds/tlb.c | 11 ++ cpu/mpc85xx/nand_init.c | 109 ++++++++++++++++++++++ cpu/mpc85xx/u-boot-nand.lds | 4 +- include/configs/MPC8536DS.h | 96 +++++++++++++++---- nand_spl/board/freescale/mpc8536ds/Makefile | 119 ++++++++++++++++++++++++ nand_spl/board/freescale/mpc8536ds/nand_boot.c | 99 ++++++++++++++++++++ nand_spl/board/freescale/mpc8536ds/u-boot.lds | 67 +++++++++++++ 9 files changed, 490 insertions(+), 23 deletions(-) create mode 100644 cpu/mpc85xx/nand_init.c create mode 100644 nand_spl/board/freescale/mpc8536ds/Makefile create mode 100644 nand_spl/board/freescale/mpc8536ds/nand_boot.c create mode 100644 nand_spl/board/freescale/mpc8536ds/u-boot.lds
diff --git a/Makefile b/Makefile index 8fd9979..681242e 100644 --- a/Makefile +++ b/Makefile @@ -2442,6 +2442,7 @@ vme8349_config: unconfig ATUM8548_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc85xx atum8548
+MPC8536DS_NAND_config \ MPC8536DS_36BIT_config \ MPC8536DS_config: unconfig @$(MKCONFIG) -n $(@:_config=) MPC8536DS ppc mpc85xx mpc8536ds freescale diff --git a/board/freescale/mpc8536ds/config.mk b/board/freescale/mpc8536ds/config.mk index f030876..bf8dd76 100644 --- a/board/freescale/mpc8536ds/config.mk +++ b/board/freescale/mpc8536ds/config.mk @@ -23,6 +23,13 @@ # # mpc8536ds board # +ifndef NAND_SPL +ifeq ($(CONFIG_MK_MPC8536DS_NAND), y) +TEXT_BASE = $(CONFIG_RAMBOOT_TEXT_BASE) +LDSCRIPT := $(TOPDIR)/cpu/$(CPU)/u-boot-nand.lds +endif +endif + ifndef TEXT_BASE TEXT_BASE = 0xeff80000 endif diff --git a/board/freescale/mpc8536ds/tlb.c b/board/freescale/mpc8536ds/tlb.c index 35a13d4..dc52d7f 100644 --- a/board/freescale/mpc8536ds/tlb.c +++ b/board/freescale/mpc8536ds/tlb.c @@ -71,6 +71,17 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 4, BOOKE_PAGESZ_1M, 1), + +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L2_ADDR) + /* *I*G - L2SRAM */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR, CONFIG_SYS_INIT_L2_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256K, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR + 0x40000, + CONFIG_SYS_INIT_L2_ADDR_PHYS + 0x40000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_256K, 1), +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/cpu/mpc85xx/nand_init.c b/cpu/mpc85xx/nand_init.c new file mode 100644 index 0000000..c29b22d --- /dev/null +++ b/cpu/mpc85xx/nand_init.c @@ -0,0 +1,109 @@ +/* + * Copyright (C) 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/mmu.h> +#include <asm/fsl_law.h> + +DECLARE_GLOBAL_DATA_PTR; + +void cpu_init_early_f(void) +{ + int i; + + /* Pointer is writable since we allocated a register for it */ + gd = (gd_t *) (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); + + /* Clear initial global data */ + for (i = 0; i < sizeof(gd_t); i++) + ((char *)gd)[i] = 0; + + set_tlb(0, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 1, 0, BOOKE_PAGESZ_4K, 0); + + /* set up CCSR if we want it moved */ +#if (CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS) + { + volatile u32 *ccsr_virt = + (volatile u32 *)(CONFIG_SYS_CCSRBAR + 0x1000); + + set_tlb(0, (u32)ccsr_virt, CONFIG_SYS_CCSRBAR_DEFAULT, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 1, 1, BOOKE_PAGESZ_4K, 0); + + in_be32(ccsr_virt); + out_be32(ccsr_virt, CONFIG_SYS_CCSRBAR_PHYS >> 12); + in_be32((volatile u32 *)CONFIG_SYS_CCSRBAR); + } +#endif + + init_laws(); + invalidate_tlb(0); + init_tlbs(); +} + +void cpu_init_f(void) +{ + ccsr_lbc_t *lbc = (void *)(CONFIG_SYS_MPC85xx_LBC_ADDR); + + /* + * LCRR - Clock Ratio Register - set up local bus timing + * when needed + */ + out_be32(&lbc->lcrr, LCRR_DBYP | LCRR_CLKDIV_8); + +#if defined(CONFIG_NAND_BR_PRELIM) \ + && defined(CONFIG_NAND_OR_PRELIM) + out_be32(&lbc->br0, CONFIG_NAND_BR_PRELIM); + out_be32(&lbc->or0, CONFIG_NAND_OR_PRELIM); + /* for FPGA */ + out_be32(&lbc->br3, CONFIG_SYS_BR3_PRELIM); + out_be32(&lbc->or3, CONFIG_SYS_OR3_PRELIM); +#else +#error CONFIG_NAND_BR_PRELIM, CONFIG_NAND_OR_PRELIM must be defined +#endif + +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L2_ADDR) + ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; + uint l2srbar; + int i; + + l2srbar = CONFIG_SYS_INIT_L2_ADDR; + out_be32(&l2cache->l2srbar0, l2srbar); + + /* set MBECCDIS=1, SBECCDIS=1 */ + out_be32(&l2cache->l2errdis, + (MPC85xx_L2ERRDIS_MBECC | + MPC85xx_L2ERRDIS_SBECC)); + + /* set L2E=1 & L2SRAM=001 */ + out_be32(&l2cache->l2ctl, + (MPC85xx_L2CTL_L2E | + MPC85xx_L2CTL_L2SRAM_ENTIRE)); + + /* Initialize L2 SRAM to zero */ + for (i = 0; i < CONFIG_SYS_L2_SIZE; i++) + ((char *)l2srbar)[i] = 0; +#endif +} diff --git a/cpu/mpc85xx/u-boot-nand.lds b/cpu/mpc85xx/u-boot-nand.lds index c14e946..a0fc8f1 100644 --- a/cpu/mpc85xx/u-boot-nand.lds +++ b/cpu/mpc85xx/u-boot-nand.lds @@ -65,10 +65,8 @@ SECTIONS PROVIDE (etext = .); .rodata : { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) *(.eh_frame) + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } :text .fini : { *(.fini) } =0 .ctors : { *(.ctors) } diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 6018858..9b43e97 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -31,6 +31,12 @@ #define CONFIG_PHYS_64BIT 1 #endif
+#ifdef CONFIG_MK_MPC8536DS_NAND +#define CONFIG_NAND_U_BOOT 1 +#define CONFIG_RAMBOOT_NAND 1 +#define CONFIG_RAMBOOT_TEXT_BASE 0xf8f82000 +#endif + /* High Level Configuration Options */ #define CONFIG_BOOKE 1 /* BOOKE */ #define CONFIG_E500 1 /* BOOKE e500 family */ @@ -91,10 +97,21 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* + * Config the L2 Cache as L2 SRAM + */ +#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_L2_ADDR_PHYS 0xff8f80000ull +#else +#define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR +#endif +#define CONFIG_SYS_L2_SIZE (512 << 10) +#define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) + +/* * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) */ -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ #define CONFIG_SYS_CCSRBAR 0xffe00000 /* relocated CCSRBAR */ #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_CCSRBAR_PHYS 0xfffe00000ull /* physical addr of CCSRBAR */ @@ -103,6 +120,12 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #endif #define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR /* PQII uses CONFIG_SYS_IMMR */
+#if defined(CONFIG_RAMBOOT_NAND) && !defined(CONFIG_NAND_SPL) +#define CONFIG_SYS_CCSRBAR_DEFAULT CONFIG_SYS_CCSRBAR +#else +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ +#endif + #define CONFIG_SYS_PCI1_ADDR (CONFIG_SYS_CCSRBAR+0x8000) #define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_CCSRBAR+0xa000) #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_CCSRBAR+0x9000) @@ -190,8 +213,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE #endif
-#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM 0xf8000ff7 +#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) | BR_PS_16 | BR_V) +#define CONFIG_FLASH_OR_PRELIM 0xf8000ff7
#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V) #define CONFIG_SYS_OR1_PRELIM 0xf8000ff7 @@ -208,6 +231,12 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy);
#define CONFIG_SYS_MONITOR_BASE TEXT_BASE /* start of monitor */
+#if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) +#define CONFIG_SYS_RAMBOOT +#else +#undef CONFIG_SYS_RAMBOOT +#endif + #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_EMPTY_INFO @@ -276,12 +305,21 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
+#ifndef CONFIG_NAND_SPL #define CONFIG_SYS_NAND_BASE 0xffa00000 #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_NAND_BASE_PHYS 0xfffa00000ull #else #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE #endif +#else +#define CONFIG_SYS_NAND_BASE 0xfff00000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_NAND_BASE_PHYS 0xffff00000ull +#else +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE +#endif +#endif #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE,\ CONFIG_SYS_NAND_BASE + 0x40000, \ CONFIG_SYS_NAND_BASE + 0x80000, \ @@ -292,6 +330,15 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_NAND_FSL_ELBC 1 #define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
+/* NAND boot: 4K NAND loader config */ +#define CONFIG_SYS_NAND_SPL_SIZE 0x1000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE ((512 << 10) - 0x2000) +#define CONFIG_SYS_NAND_U_BOOT_DST (CONFIG_SYS_INIT_L2_ADDR) +#define CONFIG_SYS_NAND_U_BOOT_START (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_NAND_SPL_SIZE) +#define CONFIG_SYS_NAND_U_BOOT_OFFS (0) +#define CONFIG_SYS_NAND_U_BOOT_RELOC (CONFIG_SYS_INIT_L2_END - 0x2000) +#define CONFIG_SYS_NAND_U_BOOT_RELOC_SP ((CONFIG_SYS_INIT_L2_END - 1) & ~0xF) + /* NAND flash config */ #define CONFIG_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ @@ -307,8 +354,17 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); | OR_FCM_TRLX \ | OR_FCM_EHTR)
-#define CONFIG_SYS_BR2_PRELIM CONFIG_NAND_BR_PRELIM /* NAND Base Address */ -#define CONFIG_SYS_OR2_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ +#ifdef CONFIG_RAMBOOT_NAND +#define CONFIG_SYS_BR0_PRELIM CONFIG_NAND_BR_PRELIM /* NAND Base Address */ +#define CONFIG_SYS_OR0_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ +#define CONFIG_SYS_BR2_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ +#define CONFIG_SYS_OR2_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ +#else +#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ +#define CONFIG_SYS_OR0_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ +#define CONFIG_SYS_BR2_PRELIM CONFIG_NAND_BR_PRELIM /* NAND Base Address */ +#define CONFIG_SYS_OR2_PRELIM CONFIG_NAND_OR_PRELIM /* NAND Options */ +#endif
#define CONFIG_SYS_BR4_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x40000))\ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ @@ -526,15 +582,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_CMD_EXT2 #endif
-/* - * USB - */ -#define CONFIG_CMD_USB -#define CONFIG_USB_STORAGE -#define CONFIG_USB_EHCI -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET - #if defined(CONFIG_TSEC_ENET)
#ifndef CONFIG_NET_MULTI @@ -569,14 +616,23 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#if CONFIG_SYS_MONITOR_BASE > 0xfff80000 -#define CONFIG_ENV_ADDR 0xfff80000 + +#if defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_RAMBOOT_NAND) + #define CONFIG_ENV_IS_IN_NAND 1 + #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE + #define CONFIG_ENV_OFFSET ((512 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) +#endif #else -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) + #define CONFIG_ENV_IS_IN_FLASH 1 + #if CONFIG_SYS_MONITOR_BASE > 0xfff80000 + #define CONFIG_ENV_ADDR 0xfff80000 + #else + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) + #endif + #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ diff --git a/nand_spl/board/freescale/mpc8536ds/Makefile b/nand_spl/board/freescale/mpc8536ds/Makefile new file mode 100644 index 0000000..c9104d3 --- /dev/null +++ b/nand_spl/board/freescale/mpc8536ds/Makefile @@ -0,0 +1,119 @@ +# +# (C) Copyright 2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# Copyright 2009 Freescale Semiconductor, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +NAND_SPL := y +TEXT_BASE := 0xfff00000 +PAD_TO := 0xfff01000 + +include $(TOPDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_NAND_SPL + +SOBJS = start.o resetvec.o +COBJS = nand_boot_fsl_elbc.o ns16550.o nand_init.o nand_boot.o cache.o \ + tlb.o tlb_table.o law.o law_table.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin + +all: $(obj).depend $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) $(PLATFORM_LIBS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +# create symbolic links for common files + +$(obj)start.S: + @rm -f $(obj)start.S + ln -sf $(SRCTREE)/cpu/mpc85xx/start.S $(obj)start.S + +$(obj)resetvec.S: + @rm -f $(obj)resetvec.S + ln -s $(SRCTREE)/cpu/$(CPU)/resetvec.S $(obj)resetvec.S + +$(obj)nand_boot_fsl_elbc.c: + @rm -f $(obj)nand_boot_fsl_elbc.c + ln -sf $(SRCTREE)/nand_spl/nand_boot_fsl_elbc.c \ + $(obj)nand_boot_fsl_elbc.c + +$(obj)ns16550.c: + @rm -f $(obj)ns16550.c + ln -sf $(SRCTREE)/drivers/serial/ns16550.c $(obj)ns16550.c + +$(obj)nand_init.c: + @rm -f $(obj)nand_init.c + ln -sf $(SRCTREE)/cpu/mpc85xx/nand_init.c $(obj)nand_init.c + +$(obj)cache.c: + @rm -f $(obj)cache.c + ln -sf $(SRCTREE)/lib_ppc/cache.c $(obj)cache.c + +$(obj)tlb.c: + @rm -f $(obj)tlb.c + ln -sf $(SRCTREE)/cpu/mpc85xx/tlb.c $(obj)tlb.c + +$(obj)tlb_table.c: + @rm -f $(obj)tlb_table.c + ln -sf $(SRCTREE)/board/$(BOARDDIR)/tlb.c $(obj)tlb_table.c + +$(obj)law.c: + @rm -f $(obj)law.c + ln -sf $(SRCTREE)/drivers/misc/fsl_law.c $(obj)law.c + +$(obj)law_table.c: + @rm -f $(obj)law_table.c + ln -sf $(SRCTREE)/board/$(BOARDDIR)/law.c $(obj)law_table.c + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/freescale/mpc8536ds/nand_boot.c b/nand_spl/board/freescale/mpc8536ds/nand_boot.c new file mode 100644 index 0000000..77973d1 --- /dev/null +++ b/nand_spl/board/freescale/mpc8536ds/nand_boot.c @@ -0,0 +1,99 @@ +/* + * Copyright (C) 2009 Freescale Semiconductor, Inc. All rights reserved. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <ns16550.h> +#include <nand.h> + +void board_init_f(ulong bootflag) +{ + u8 sysclk_ratio; + uint plat_ratio, bus_clk, sys_clk; + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* initialize selected port with appropriate baud rate */ + sysclk_ratio = *((volatile unsigned char *)(PIXIS_BASE + PIXIS_SPD)); + sysclk_ratio &= 0x7; + switch (sysclk_ratio) { + case 0: + sys_clk = 33333000; + break; + case 1: + sys_clk = 39999600; + break; + case 2: + sys_clk = 49999500; + break; + case 3: + sys_clk = 66666000; + break; + case 4: + sys_clk = 83332500; + break; + case 5: + sys_clk = 99999000; + break; + case 6: + sys_clk = 133332000; + break; + case 7: + sys_clk = 166665000; + break; + default: + sys_clk = 0; + break; + } + + plat_ratio = (gur->porpllsr) & 0x0000003e; + plat_ratio >>= 1; + bus_clk = plat_ratio * sys_clk; + NS16550_init((NS16550_t)(CONFIG_SYS_CCSRBAR + 0x4500), + bus_clk / 16 / CONFIG_BAUDRATE); + + puts("\nNAND boot... "); + + /* copy code to RAM and jump to it - this should not return */ + /* NOTE - code has to be copied out of NAND buffer before + * other blocks can be read. + */ + relocate_code(CONFIG_SYS_NAND_U_BOOT_RELOC_SP, 0, + CONFIG_SYS_NAND_U_BOOT_RELOC); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + nand_boot(); +} + +void putc(char c) +{ + if (c == '\n') + NS16550_putc((NS16550_t)(CONFIG_SYS_CCSRBAR + 0x4500), '\r'); + + NS16550_putc((NS16550_t)(CONFIG_SYS_CCSRBAR + 0x4500), c); +} + +void puts(const char *str) +{ + while (*str) + putc(*str++); +} + diff --git a/nand_spl/board/freescale/mpc8536ds/u-boot.lds b/nand_spl/board/freescale/mpc8536ds/u-boot.lds new file mode 100644 index 0000000..fef3e42 --- /dev/null +++ b/nand_spl/board/freescale/mpc8536ds/u-boot.lds @@ -0,0 +1,67 @@ +/* + * (C) Copyright 2006 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de + * + * Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +SECTIONS +{ + . = 0xfff00000; + .text : { + *(.text) + } + _etext = .; + + .reloc : { + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >> 2; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + . = ALIGN(8); + .data : { + *(.rodata*) + *(.data*) + *(.sdata*) + } + _edata = .; + + . = ALIGN(8); + __init_begin = .; + __init_end = .; + + .resetvec ADDR(.text) + 0xffc : { + *(.resetvec) + } = 0xffff + + __bss_start = .; + .bss : { + *(.sbss) + *(.bss) + } + _end = .; +} +ASSERT(__init_end <= 0xfff00ffc, "NAND bootstrap too big");
Dear Mingkai Hu,
In message 1252649951-28543-2-git-send-email-Mingkai.hu@freescale.com you wrote:
- int i;
- /* Pointer is writable since we allocated a register for it */
- gd = (gd_t *) (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET);
- /* Clear initial global data */
- for (i = 0; i < sizeof(gd_t); i++)
- set_tlb(0, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS,
- /* set up CCSR if we want it moved */
Please do not declare vaiables righjt in the middle of the code. Consider moving this code into a separate function instead.
- *(.rodata)
- *(.rodata1)
- *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
Please rebase your patch against current code.
- Config the L2 Cache as L2 SRAM
Line too long, please fix globally.
+$(obj)start.S:
- @rm -f $(obj)start.S
- ln -sf $(SRCTREE)/cpu/mpc85xx/start.S $(obj)start.S
+$(obj)resetvec.S:
- @rm -f $(obj)resetvec.S
- ln -s $(SRCTREE)/cpu/$(CPU)/resetvec.S $(obj)resetvec.S
- @rm -f $(obj)nand_boot_fsl_elbc.c
- ln -sf $(SRCTREE)/nand_spl/nand_boot_fsl_elbc.c \
+$(obj)ns16550.c:
- @rm -f $(obj)ns16550.c
- ln -sf $(SRCTREE)/drivers/serial/ns16550.c $(obj)ns16550.c
+$(obj)nand_init.c:
- @rm -f $(obj)nand_init.c
- ln -sf $(SRCTREE)/cpu/mpc85xx/nand_init.c $(obj)nand_init.c
+$(obj)cache.c:
- @rm -f $(obj)cache.c
- ln -sf $(SRCTREE)/lib_ppc/cache.c $(obj)cache.c
+$(obj)tlb.c:
- @rm -f $(obj)tlb.c
- ln -sf $(SRCTREE)/cpu/mpc85xx/tlb.c $(obj)tlb.c
+$(obj)tlb_table.c:
- @rm -f $(obj)tlb_table.c
- ln -sf $(SRCTREE)/board/$(BOARDDIR)/tlb.c $(obj)tlb_table.c
Consider using the same file name here; it will simplify the Makefile rules.
+$(obj)law.c:
- @rm -f $(obj)law.c
- ln -sf $(SRCTREE)/drivers/misc/fsl_law.c $(obj)law.c
Ditto.
+$(obj)law_table.c:
- @rm -f $(obj)law_table.c
- ln -sf $(SRCTREE)/board/$(BOARDDIR)/law.c $(obj)law_table.c
Ditto.
Please sort list.
And why do you need a separate rule everywhere? They look all the same to me (except for the inconsistent file names) ?
- $(CC) $(AFLAGS) -c -o $@ $<
- $(CC) $(CFLAGS) -c -o $@ $<
- u8 sysclk_ratio;
- uint plat_ratio, bus_clk, sys_clk;
- volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- /* initialize selected port with appropriate baud rate */
- sysclk_ratio = *((volatile unsigned char *)(PIXIS_BASE + PIXIS_SPD));
Please use I/O accessors.
- NS16550_init((NS16550_t)(CONFIG_SYS_CCSRBAR + 0x4500),
Smells like I/O accessors should be used here (and further down below), too?
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Wednesday, September 23, 2009 3:16 AM To: Hu Mingkai-B21284 Cc: u-boot@lists.denx.de; Wood Scott-B07421; Gala Kumar-B11780 Subject: Re: [U-Boot] [PATCH v3 3/5] NAND boot: MPC8536DS support
- /* set up CCSR if we want it moved */ #if
+(CONFIG_SYS_CCSRBAR_DEFAULT != CONFIG_SYS_CCSRBAR_PHYS)
OK.
- *(.rodata)
- *(.rodata1)
OK.
OK.
+$(obj)tlb.c:
+$(obj)tlb_table.c:
+$(obj)law.c:
Ditto.
+$(obj)law_table.c:
Ditto.
Please sort list.
Ok, I'll change it. But for some files, the name is same for different files in the different directory, for example, cpu/mpc85xx/tlb.c and board/freescale/mpc8536/tlb.c, so I changed the linked name.
+PIXIS_SPD));
Thanks, I've modified this, and prepared a new version patch.
Ditto.
Thanks, Mingkai
Hu Mingkai-B21284
Mingkai Hu
