[PATCH v2 0/7] Add support for QEMU's ramfb display
This is a rebase of Alexander Graf's QEMU ramfb support series with some changes of mine, in part to address reviews and to accommodate other changes enabling Bochs video driver. The original cover letter is as follows:
QEMU implements multiple ways to expose graphics output to the virt machine, but most of them are incompatible with hardware virtualization.
The one that does work reliably is ramfb. It's a very simple mechanism in which the guest reserves a memory region for the frame buffer and then notifies the host about its location and properties. The host then just displays the contents of the frame buffer on screen.
This patch set adds support to drive the ramfb device in our QEMU arm targets. Theoretically, it should work as is with any of the other architectures as well though.
With this driver, we have a very simple, KVM compatible way to expose GOP via UEFI to payloads and thus enable development and testing of graphical OS functionality with QEMU's -M virt.
Inspired by the "video: bochs: Remove the x86 limitation" series [1] that was recently merged, I have also sent a series adding Bochs video device support for ARM [2], and assuming that would get merged before this I've rebased this on that to avoid conflicts.
[1] https://lore.kernel.org/u-boot/20230723044041.1089804-1-bmeng@tinylab.org/ [2] https://lore.kernel.org/u-boot/20230814173944.288356-1-alpernebiyasak@gmail....
Changes in v2: - Remove extra "depends on DM_VIDEO" already in "if VIDEO" - Drop drivers/video/MAINTAINERS file - Decouple framebuffer allocation from EFI_LOADER - Add .bind() method for ramfb driver - Make resolution configurable with kconfig - Move struct to qfw.h and add comments for members - Use RAMFB_* definitions instead of DEFAULT_* - Use if (IS_ENABLED(CONFIG_VIDEO_RAMFB)) instead of #ifdef - Add patch "qfw: Add flag to allow probing before relocation" - Rebase on "qemu: arm: Enable Bochs, console buffering, USB keyboard" - Drop env changes from ARM (necessary but in prerequisite series) - Drop imply VIDEO, SYS_CONSOLE_IN_ENV changes from ARM (in prereq.) - Probe QFW in ARM QEMU board_early_init_f to bind ramfb pre-reloc - Add IS_ENABLED(CONFIG_QFW) check and error handling to ARM QEMU - Drop imply VIDEO, env changes from RISC-V patch (in u-boot/next) - Drop imply SYS_CONSOLE_IS_IN_ENV from RISC-V patch (def. y if VIDEO) - Probe QFW in RISC-V QEMU board_early_init_f to bind ramfb pre-reloc - Add IS_ENABLED(CONFIG_QFW) check and error handling to RISC-V QEMU - Add patch "x86: qemu: Enable ramfb by default"
v1: https://lore.kernel.org/u-boot/20220227144043.37359-1-agraf@csgraf.de/
Alexander Graf (5): qfw: Add WRITE definition ramfb: Add driver for ramfb display qfw: Spawn ramfb device if its file is present arm: qemu: Enable ramfb by default riscv: qemu: Enable ramfb by default
Alper Nebi Yasak (2): qfw: Add flag to allow probing before relocation x86: qemu: Enable ramfb by default
arch/arm/Kconfig | 3 + arch/x86/cpu/qemu/Kconfig | 4 + board/emulation/qemu-arm/qemu-arm.c | 41 +++++++++++ board/emulation/qemu-riscv/Kconfig | 5 ++ board/emulation/qemu-riscv/qemu-riscv.c | 41 +++++++++++ board/emulation/qemu-x86/qemu-x86.c | 47 ++++++++++++ configs/qemu-x86_64_defconfig | 4 +- configs/qemu-x86_defconfig | 1 - drivers/misc/qfw.c | 25 +++++++ drivers/misc/qfw_mmio.c | 1 + drivers/misc/qfw_pio.c | 1 + drivers/misc/qfw_sandbox.c | 1 + drivers/video/Kconfig | 30 ++++++++ drivers/video/Makefile | 1 + drivers/video/ramfb.c | 97 +++++++++++++++++++++++++ include/qfw.h | 11 +++ 16 files changed, 309 insertions(+), 4 deletions(-) create mode 100644 drivers/video/ramfb.c
base-commit: 832148f675e427060be074c276956962fa9b5cb6 prerequisite-patch-id: 2c8662d18f6f1e2d4e014bcd5d468e0396064f4f prerequisite-patch-id: 5f3e5e1d814187841ce299df0da16df16d0121c3 prerequisite-patch-id: adbd0fb953e726ea5ea0b248e00092dfc318fd46 prerequisite-patch-id: 7470d3af5e9ded16eb5a4de7c7264062dcb3ef7f
The QEMU fw_cfg device supports writing entries as well. Add the constant define for it so that we can leverage write functionality later.
Signed-off-by: Alexander Graf agraf@csgraf.de Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
(no changes since v1)
include/qfw.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/qfw.h b/include/qfw.h index 42798fea7db4..d3aaa4d54efc 100644 --- a/include/qfw.h +++ b/include/qfw.h @@ -70,6 +70,7 @@ enum { #define FW_CFG_DMA_READ (1 << 1) #define FW_CFG_DMA_SKIP (1 << 2) #define FW_CFG_DMA_SELECT (1 << 3) +#define FW_CFG_DMA_WRITE (1 << 4)
/* Bit set in FW_CFG_ID response to indicate DMA interface availability. */ #define FW_CFG_DMA_ENABLED (1 << 1)
This patch implements a trivial version of a ramfb driver - hard coded to a single resolution set in Kconfig.
Signed-off-by: Alexander Graf agraf@csgraf.de [Alper: Deduplicate depends on DM_VIDEO, drop MAINTAINERS, decouple from EFI_LOADER, add .bind(), kconfigurable resolution, struct in .h] Co-developed-by: Alper Nebi Yasak alpernebiyasak@gmail.com Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
drivers/video/Kconfig | 30 +++++++++++++ drivers/video/Makefile | 1 + drivers/video/ramfb.c | 97 ++++++++++++++++++++++++++++++++++++++++++ include/qfw.h | 10 +++++ 4 files changed, 138 insertions(+) create mode 100644 drivers/video/ramfb.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 69f4809cf4a6..6ab46107483e 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -849,6 +849,36 @@ config VIDEO_MCDE_SIMPLE before u-boot starts, and u-boot will simply render to the pre- allocated frame buffer surface.
+config VIDEO_RAMFB + bool "QEMU ramfb display driver for in-RAM display" + depends on QFW + help + Enables a RAM based simple frame buffer driver which uses qfw to + notify the hypervisor about the location of a Frame Buffer allocated + in guest RAM as well as its properties. + +if VIDEO_RAMFB + +config VIDEO_RAMFB_SIZE_X + int "Width of ramfb display (X resolution)" + default 1280 + help + Sets the width of the ramfb display. + + These two options control the size of the display set up by QEMU. + Typical sizes are 1024 x 768 or 1280 x 1024. + +config VIDEO_RAMFB_SIZE_Y + int "Height of ramfb display (Y resolution)" + default 1024 + help + Sets the height of the ramfb display. + + These two options control the size of the display set up by QEMU. + Typical sizes are 1024 x 768 or 1280 x 1024. + +endif + config OSD bool "Enable OSD support" depends on DM diff --git a/drivers/video/Makefile b/drivers/video/Makefile index d13af9f3b19b..775b4e46e600 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -75,6 +75,7 @@ obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o obj-$(CONFIG_VIDEO_SIMPLE) += simplefb.o obj-$(CONFIG_VIDEO_VESA) += vesa.o obj-$(CONFIG_VIDEO_SEPS525) += seps525.o +obj-$(CONFIG_VIDEO_RAMFB) += ramfb.o obj-$(CONFIG_VIDEO_ZYNQMP_DPSUB) += zynqmp/
obj-y += bridge/ diff --git a/drivers/video/ramfb.c b/drivers/video/ramfb.c new file mode 100644 index 000000000000..ba17cac312b6 --- /dev/null +++ b/drivers/video/ramfb.c @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2022 Alexander Graf + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <video.h> +#include <asm/global_data.h> +#include <qfw.h> + +#define fourcc_code(a, b, c, d) ((u32)(a) | ((u32)(b) << 8) | \ + ((u32)(c) << 16) | ((u32)(d) << 24)) +#define DRM_FORMAT_XRGB8888 fourcc_code('X', 'R', '2', '4') + +#define RAMFB_WIDTH CONFIG_VIDEO_RAMFB_SIZE_X +#define RAMFB_HEIGHT CONFIG_VIDEO_RAMFB_SIZE_Y +#define RAMFB_BPIX VIDEO_BPP32 +#define RAMFB_FORMAT VIDEO_X8R8G8B8 + +static int ramfb_probe(struct udevice *dev) +{ + struct video_uc_plat *plat = dev_get_uclass_plat(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + u32 selector; + int ret; + struct fw_file *file; + struct udevice *qfw; + struct dm_qfw_ops *ops; + struct qfw_dma dma = {}; + struct ramfb_cfg cfg = { + .addr = cpu_to_be64(plat->base), + .fourcc = cpu_to_be32(DRM_FORMAT_XRGB8888), + .flags = 0, + .width = cpu_to_be32(RAMFB_WIDTH), + .height = cpu_to_be32(RAMFB_HEIGHT), + .stride = 0, + }; + + if (plat->base == 0) + return -EPROBE_DEFER; + + debug("%s: Frame buffer base %lx\n", __func__, plat->base); + + ret = qfw_get_dev(&qfw); + if (ret) + return -EPROBE_DEFER; + + ops = dm_qfw_get_ops(qfw); + if (!ops) + return -EPROBE_DEFER; + + file = qfw_find_file(qfw, "etc/ramfb"); + if (!file) { + /* No ramfb available. At least we tried. */ + return -ENOENT; + } + + uc_priv->xsize = RAMFB_WIDTH; + uc_priv->ysize = RAMFB_HEIGHT; + uc_priv->bpix = RAMFB_BPIX; + uc_priv->format = RAMFB_FORMAT; + uc_priv->fb = (void *)plat->base; + uc_priv->fb_size = plat->size; + + selector = be16_to_cpu(file->cfg.select); + dma.length = cpu_to_be32(sizeof(cfg)); + dma.address = cpu_to_be64((uintptr_t)&cfg); + dma.control = cpu_to_be32(FW_CFG_DMA_WRITE | FW_CFG_DMA_SELECT | + (selector << 16)); + + barrier(); + + /* Send a DMA write request which enables the screen */ + ops->read_entry_dma(qfw, &dma); + + return 0; +} + +static int ramfb_bind(struct udevice *dev) +{ + struct video_uc_plat *uc_plat = dev_get_uclass_plat(dev); + + /* Set the maximum supported resolution */ + uc_plat->size = RAMFB_WIDTH * RAMFB_HEIGHT * VNBYTES(RAMFB_BPIX); + debug("%s: Frame buffer size %x\n", __func__, uc_plat->size); + + return 0; +} + +U_BOOT_DRIVER(ramfb) = { + .name = "ramfb", + .id = UCLASS_VIDEO, + .probe = ramfb_probe, + .bind = ramfb_bind, +}; diff --git a/include/qfw.h b/include/qfw.h index d3aaa4d54efc..811abac6fd27 100644 --- a/include/qfw.h +++ b/include/qfw.h @@ -142,6 +142,16 @@ struct bios_linker_entry { }; } __packed;
+/* ramfb configuration details to read into etc/ramfb fw_cfg file */ +struct ramfb_cfg { + __be64 addr; /* Address of an allocated framebuffer */ + __be32 fourcc; /* Pixel format in Linux DRM fourcc code */ + __be32 flags; /* Unknown, appears unused */ + __be32 width; /* Width of the requested ramfb display */ + __be32 height; /* Height of the requested ramfb display */ + __be32 stride; /* Number of bytes per line? */ +} __packed; + /* DMA transfer control data between UCLASS_QFW and QEMU. */ struct qfw_dma { __be32 control;
On Tue, 22 Aug 2023 at 06:10, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Changes in v2:
Now that we have a ramfb device driver, let's add the necessary glueing magic to also spawn it when we find its qfw file node.
Signed-off-by: Alexander Graf agraf@csgraf.de [Alper: Use if IS_ENABLED() instead of #ifdef] Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
Changes in v2: - Use if (IS_ENABLED(CONFIG_VIDEO_RAMFB)) instead of #ifdef
drivers/misc/qfw.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/drivers/misc/qfw.c b/drivers/misc/qfw.c index 7c01bf23d53b..4e4260982cce 100644 --- a/drivers/misc/qfw.c +++ b/drivers/misc/qfw.c @@ -16,6 +16,7 @@ #include <malloc.h> #include <qfw.h> #include <dm.h> +#include <dm/lists.h> #include <misc.h> #include <tables_csum.h> #include <asm/acpi_table.h> @@ -307,6 +308,27 @@ void qfw_read_entry(struct udevice *dev, u16 entry, u32 size, void *address) qfw_read_entry_io(qdev, entry, size, address); }
+static void qfw_bind_ramfb(struct udevice *dev) +{ + struct fw_file *file; + int ret; + + if (!IS_ENABLED(CONFIG_VIDEO_RAMFB)) + return; + + ret = qfw_read_firmware_list(dev); + if (ret) + return; + + file = qfw_find_file(dev, "etc/ramfb"); + if (!file) { + /* No ramfb available. */ + return; + } + + device_bind_driver(dev, "ramfb", "qfw-ramfb", NULL); +} + int qfw_register(struct udevice *dev) { struct qfw_dev *qdev = dev_get_uclass_priv(dev); @@ -323,6 +345,8 @@ int qfw_register(struct udevice *dev) if (dma_enabled & FW_CFG_DMA_ENABLED) qdev->dma_present = true;
+ qfw_bind_ramfb(dev); + return 0; }
Hi Alper,
So then how do we select which video driver is used? I think we should have this in the DT so there is some control.
Changes in v2:
int ret;
return;
Needs an error-code return
if (ret)
return;
if (!file) {
return;
check error
-- 2.40.1
On 2023-08-22 21:56 +03:00, Simon Glass wrote:
Hi Alper,
I think you mean choosing between multiple potential video devices for a video console, but just in case: AFAIK only the ramfb driver can be used with -device ramfb, unlike how either vesa or bochs can be used for -device VGA.
This series is less about being able to use multiple video devices, but more about supporting by default different configurations in which QEMU can be launched: with "-device VGA" or "-vga none -device ramfb".
That being said, I had some success with multiple video console attempts. For "-device VGA -device ramfb", we need to make `*addrp -= CONFIG_VAL(VIDEO_PCI_DEFAULT_FB_SIZE);` unconditional in video_reserve() to correctly allocate for both vesa and ramfb. Then we can run `env set serial,vidconsole,vidconsole1` which sets up both video/vidconsole devices with same text content.
Regardless of this series, with VIDEO_PCI_DEFAULT_FB_SIZE=0x3000000 and "-device VGA -device VGA -device VGA" we get two broken and one empty display, and `env set serial,vidconsole,vidconsole1,vidconsole2` puts a console to the third display. I think it's a bug the first two are broken, and it's initially using the first broken display as vidconsole.
Anyway, my opinion is: if stdout/stderr has "vidconsole", we should enable a vidconsole on all consoles, but if it has "vidconsole#" we should only enable the one on that video# device. Then device-tree could have /aliases { video0 = "..."; video1 = &...; } or something to have a stable order?
Or, you might mean adding a ramfb node to the device-tree, in which case that's going to reopen a can of OF_BOARD worms... (Same as what applies to putting bootph,* into qfw device-tree node, so I'll reply there.)
int ret;
return;
if (ret)
return;
if (!file) {
return;
check error
Will try to fix both, thanks.
QEMU firmware config drivers need to be probed to bind the ramfb device. The ramfb driver needs to be bound before relocation to properly reserve video memory for it, otherwise it cannot be probed after relocation. Add the flag to probe QEMU firmware config drivers before relocation so that ramfb can work as an initial vidconsole.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- Alternatively, I guess I could default VIDEO_PCI_DEFAULT_FB_SIZE to a higher size with "if VIDEO_RAMFB". But it exists because "PCI drivers cannot be bound before relocation unless they are mentioned in the devicetree" and qfw is in the QEMU-generated devicetree unlike those, so I assumed this would be the preferred way.
Changes in v2: - Add patch "qfw: Add flag to allow probing before relocation"
drivers/misc/qfw.c | 1 + drivers/misc/qfw_mmio.c | 1 + drivers/misc/qfw_pio.c | 1 + drivers/misc/qfw_sandbox.c | 1 + 4 files changed, 4 insertions(+)
diff --git a/drivers/misc/qfw.c b/drivers/misc/qfw.c index 4e4260982cce..265f45290011 100644 --- a/drivers/misc/qfw.c +++ b/drivers/misc/qfw.c @@ -414,6 +414,7 @@ UCLASS_DRIVER(qfw) = { .name = "qfw", .post_bind = qfw_post_bind, .per_device_auto = sizeof(struct qfw_dev), + .flags = DM_FLAG_PRE_RELOC, };
struct bootdev_ops qfw_bootdev_ops = { diff --git a/drivers/misc/qfw_mmio.c b/drivers/misc/qfw_mmio.c index f397384054a6..a5274982711c 100644 --- a/drivers/misc/qfw_mmio.c +++ b/drivers/misc/qfw_mmio.c @@ -116,4 +116,5 @@ U_BOOT_DRIVER(qfw_mmio) = { .of_to_plat = qfw_mmio_of_to_plat, .probe = qfw_mmio_probe, .ops = &qfw_mmio_ops, + .flags = DM_FLAG_PRE_RELOC, }; diff --git a/drivers/misc/qfw_pio.c b/drivers/misc/qfw_pio.c index e2f628d33830..dae809bd3fea 100644 --- a/drivers/misc/qfw_pio.c +++ b/drivers/misc/qfw_pio.c @@ -66,4 +66,5 @@ U_BOOT_DRIVER(qfw_pio) = { .id = UCLASS_QFW, .probe = qfw_pio_probe, .ops = &qfw_pio_ops, + .flags = DM_FLAG_PRE_RELOC, }; diff --git a/drivers/misc/qfw_sandbox.c b/drivers/misc/qfw_sandbox.c index 1002df75339e..0bd36acd1a09 100644 --- a/drivers/misc/qfw_sandbox.c +++ b/drivers/misc/qfw_sandbox.c @@ -120,6 +120,7 @@ U_BOOT_DRIVER(qfw_sandbox) = { .plat_auto = sizeof(struct qfw_sandbox_plat), .probe = qfw_sandbox_probe, .ops = &qfw_sandbox_ops, + .flags = DM_FLAG_PRE_RELOC, };
U_BOOT_DRVINFO(qfw_sandbox) = {
Hi Alper,
Changes in v2:
Should we add this to the DT instead?
In the case where it isn't present it can return -EPERM.
Hi Alper,
Changes in v2:
I've experimented a bit, and got something that works nice on x86 because we have the device-trees in-tree. So I can add something to arch/x86/dts/qemu-*.dts like:
/ { fw-cfg { compatible = "qemu,fw-cfg-pio"; bootph-some-ram;
qfw-ramfb { compatible = "qemu,qfw-ramfb"; bootph-some-ram; }; }; };
Then add the compatibles as .of_match to qfw_pio and ramfb drivers, call dm_scan_fdt_dev(dev) in qfw_post_bind(), merge qfw_bind_ramfb() into the ramfb driver probe, and it will work without the board_early_init_[fr] hooks or these flags. That all seems to be fine.
The problem is other arches where QEMU generates a device-tree at runtime and passes it to U-Boot with OF_BOARD. It has, on arm64 (and with @10100000 instead on riscv64):
fw-cfg@9020000 { dma-coherent; reg = <0x00 0x9020000 0x00 0x18>; compatible = "qemu,fw-cfg-mmio"; };
As a proof of concept, I used `qemu-system-* -M dumpdtb=file.dtb` and `dtc -I dtb -O dts` to replace the empty qemu dts files, then set OF_BOARD=n and OF_OMIT_DTB=n, and added similar modifications to qemu-*-u-boot.dtsi. And everything seems fine like that as well.
I think it can be automated in Makefile, but I don't think disabling OF_BOARD is right here. I see there's OF_BOARD_FIXUP, so I guess I'll try finding the fw-cfg node there and adding the bootph props and ramfb nodes... Is this going the right way?
(And the pio/ramfb compatibles don't exist, do we have to use u-boot,*?)
Hi Alper,
Changes in v2:
/ { fw-cfg { compatible = "qemu,fw-cfg-pio"; bootph-some-ram; qfw-ramfb { compatible = "qemu,qfw-ramfb"; bootph-some-ram; }; }; };
This seems like a whole lot of work to avoid using the flags mechanism that we have, intentionally.
Now that we have everything in place to support ramfb, let's wire it up by default in the ARM QEMU targets. That way, you can easily use a graphical console by just passing -device ramfb to the QEMU command line.
Signed-off-by: Alexander Graf agraf@csgraf.de [Alper: Rebase on bochs changes, add pre-reloc init, error handling] Co-developed-by: Alper Nebi Yasak alpernebiyasak@gmail.com Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
Changes in v2: - Rebase on "qemu: arm: Enable Bochs, console buffering, USB keyboard" - Drop env changes from ARM (necessary but in prerequisite series) - Drop imply VIDEO, SYS_CONSOLE_IN_ENV changes from ARM (in prereq.) - Probe QFW in ARM QEMU board_early_init_f to bind ramfb pre-reloc - Add IS_ENABLED(CONFIG_QFW) check and error handling to ARM QEMU
arch/arm/Kconfig | 3 +++ board/emulation/qemu-arm/qemu-arm.c | 41 +++++++++++++++++++++++++++++ 2 files changed, 44 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 1fd3ccd1607f..7afe26ac804f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1046,6 +1046,9 @@ config ARCH_QEMU imply USB_XHCI_PCI imply USB_KEYBOARD imply CMD_USB + imply VIDEO_RAMFB + imply BOARD_EARLY_INIT_F + imply BOARD_EARLY_INIT_R
config ARCH_RMOBILE bool "Renesas ARM SoCs" diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index 942f1fff5717..23ef31cb7feb 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -11,6 +11,7 @@ #include <fdtdec.h> #include <init.h> #include <log.h> +#include <qfw.h> #include <usb.h> #include <virtio_types.h> #include <virtio.h> @@ -102,6 +103,46 @@ static struct mm_region qemu_arm64_mem_map[] = { struct mm_region *mem_map = qemu_arm64_mem_map; #endif
+int board_early_init_f(void) +{ + struct udevice *dev; + int ret; + + /* + * Make sure we enumerate the QEMU Firmware device to bind ramfb + * so video_reserve() can reserve memory for it. + */ + if (IS_ENABLED(CONFIG_QFW)) { + ret = qfw_get_dev(&dev); + if (ret) { + log_err("Failed to get QEMU FW device: %d\n", ret); + return ret; + } + } + + return 0; +} + +int board_early_init_r(void) +{ + struct udevice *dev; + int ret; + + /* + * Make sure we enumerate the QEMU Firmware device to find ramfb + * before console_init. + */ + if (IS_ENABLED(CONFIG_QFW)) { + ret = qfw_get_dev(&dev); + if (ret) { + log_err("Failed to get QEMU FW device: %d\n", ret); + return ret; + } + } + + return 0; +} + int board_init(void) { return 0;
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
int ret;
if (ret) {
We should only present an error if the device is present but failed...so if the user doesn't provide the flag, all should be well.
return ret;
int ret;
if (ret) {
return ret;
int board_init(void) { return 0; -- 2.40.1
The glue here feels like a bit of a hack...we should rely on normal DT mechanisms here.
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
int ret;
if (ret) {
I don't understand what you mean by "user doesn't provide the flag". But I assume this should ignore the error (unless what?) so that we can continue to boot. Would that apply for board_early_init_r below as well?
return ret;
int ret;
if (ret) {
return ret;
Hi Alper, On Mon, 28 Aug 2023 at 09:46, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
int ret;
if (ret) {
I thought you said there was a qemu flag to enable ramfb? So add it to the DT and then the device can (in its bind routine) decide not to be bound by returning -ENODEV
return ret;
int ret;
if (ret) {
return ret;
Regards.
Simon
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
int ret;
if (ret) {
Ah. I'm not used to calling them flags, especially those that have values as in "-device ramfb". My mind jumped to DM_FLAG_PRE_RELOC / bootph-some-ram.
But note that what this code tries to probe here is not the ramfb device, it's the bus/parent of that. If this fails, we can't know if the user specified "-device ramfb" or not.
Is the parent node's device probed by the time .bind() is called? Or, can I have it probed by calling qfw_get_dev() (which is just uclass_first_device_err(UCLASS_QFW, ...))?
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
int ret;
if (ret) {
You bring up a great point here. I don't think we should model the actual ramfb device as device tree (platform) device. It's 100% enumerable from QFW which means we should treat it as a dynamic entity that gets created by QFW instead of from device tree, just like USB or PCI devices.
And when you do that, everything should fall into place nicely: You don't need to dynamically modify device trees on boot, the DT you get from QEMU is sufficient to enumerate everything, etc etc.
Alex
Hi Alper,
On Mon, 28 Aug 2023 at 12:29, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
int ret;
if (ret) {
I suppose your problem might be that there are up to three possible video devices (vesa, bochs, ramfb) and one of them needs to return 0 from bind() and the others need to return -ENODEV?
Perhaps another way would be to update the logic in stdio_init_tables() to find them all (which I believe it already does?) and then select one?
On 28.08.23 22:38, Simon Glass wrote:
Hi Alper,
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
int ret;
if (ret) {
How do multiple Legacy VGA devices work in parallel in the first place? Do we access the legacy VGA PIO ports or memory ranges? If so, which of the VGA devices owns it at which point in time?
IIRC the only way you can actually multiplex real VGA is by putting a VGA arbiter[1] in between that literally maps the BARs in and out or enables/disables device mapping dynamically, no?
It probably makes most sense to make multiple video outputs work smoothly with at most 1 VGA device at a time for now to resolve any U-Boot internal infrastructure problems, then maybe later try multiple VGAs.
Alex
Now that we have everything in place to support ramfb, let's wire it up by default in the RISC-V QEMU targets. That way, you can easily use a graphical console by just passing -device ramfb to the QEMU command line.
Signed-off-by: Alexander Graf agraf@csgraf.de [Alper: Rebase on bochs changes, add pre-reloc init and error handling] Co-developed-by: Alper Nebi Yasak alpernebiyasak@gmail.com Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
Changes in v2: - Drop imply VIDEO, env changes from RISC-V patch (in u-boot/next) - Drop imply SYS_CONSOLE_IS_IN_ENV from RISC-V patch (def. y if VIDEO) - Probe QFW in RISC-V QEMU board_early_init_f to bind ramfb pre-reloc - Add IS_ENABLED(CONFIG_QFW) check and error handling to RISC-V QEMU
board/emulation/qemu-riscv/Kconfig | 5 +++ board/emulation/qemu-riscv/qemu-riscv.c | 41 +++++++++++++++++++++++++ 2 files changed, 46 insertions(+)
diff --git a/board/emulation/qemu-riscv/Kconfig b/board/emulation/qemu-riscv/Kconfig index d56b4b5bc1ed..b5c72982e565 100644 --- a/board/emulation/qemu-riscv/Kconfig +++ b/board/emulation/qemu-riscv/Kconfig @@ -82,5 +82,10 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply USB_XHCI_PCI imply USB_KEYBOARD imply CMD_USB + imply BOARD_EARLY_INIT_F + imply BOARD_EARLY_INIT_R + imply VIDEO_RAMFB + imply CMD_QFW + imply QFW_MMIO
endif diff --git a/board/emulation/qemu-riscv/qemu-riscv.c b/board/emulation/qemu-riscv/qemu-riscv.c index 181abbbf97d8..1041e936e9d1 100644 --- a/board/emulation/qemu-riscv/qemu-riscv.c +++ b/board/emulation/qemu-riscv/qemu-riscv.c @@ -10,6 +10,7 @@ #include <fdtdec.h> #include <image.h> #include <log.h> +#include <qfw.h> #include <spl.h> #include <init.h> #include <usb.h> @@ -29,6 +30,46 @@ int is_flash_available(void) } #endif
+int board_early_init_f(void) +{ + struct udevice *dev; + int ret; + + /* + * Make sure we enumerate the QEMU Firmware device to bind ramfb + * so video_reserve() can reserve memory for it. + */ + if (IS_ENABLED(CONFIG_QFW)) { + ret = qfw_get_dev(&dev); + if (ret) { + log_err("Failed to get QEMU FW device: %d\n", ret); + return ret; + } + } + + return 0; +} + +int board_early_init_r(void) +{ + struct udevice *dev; + int ret; + + /* + * Make sure we enumerate the QEMU Firmware device to find ramfb + * before console_init. + */ + if (IS_ENABLED(CONFIG_QFW)) { + ret = qfw_get_dev(&dev); + if (ret) { + log_err("Failed to get QEMU FW device: %d\n", ret); + return ret; + } + } + + return 0; +} + int board_init(void) { /*
Hi Alper,
Changes in v2:
Again, please investigate DT mechanism which will work for all archs.
Now that we have everything in place to support ramfb, let's wire it up by default in the x86 QEMU targets. That way, we can use ramfb graphical console instead of the default by passing -vga none -device ramfb to the QEMU command line.
Also increase SYS_MALLOC_F_LEN for QEMU x86_64 to be the same as its SPL counterpart, because we're running out of alloc space in pre-reloc stage with ramfb enabled.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- This also suffers from the same issue with distros as the Bochs display driver [1], where it results in a hang after GRUB menu selection before the kernel can display anything. Couldn't reproduce on arm*/riscv*.
But just having it enabled doesn't seem to cause problems unless you run QEMU with -device ramfb, so this (unlike the Bochs video driver) can actually be co-enabled with VIDEO_VESA.
[1] https://lore.kernel.org/u-boot/20230724145210.304917-4-sjg@chromium.org/
Changes in v2: - Add patch "x86: qemu: Enable ramfb by default"
arch/x86/cpu/qemu/Kconfig | 4 +++ board/emulation/qemu-x86/qemu-x86.c | 47 +++++++++++++++++++++++++++++ configs/qemu-x86_64_defconfig | 4 +-- configs/qemu-x86_defconfig | 1 - 4 files changed, 52 insertions(+), 4 deletions(-)
diff --git a/arch/x86/cpu/qemu/Kconfig b/arch/x86/cpu/qemu/Kconfig index f8f2f6473088..e0a57ac2d687 100644 --- a/arch/x86/cpu/qemu/Kconfig +++ b/arch/x86/cpu/qemu/Kconfig @@ -13,6 +13,10 @@ config QEMU imply USB imply USB_EHCI_HCD imply VIDEO_VESA + imply VIDEO_RAMFB + imply BOARD_EARLY_INIT_F + imply BOARD_EARLY_INIT_R + imply CMD_QFW
if QEMU
diff --git a/board/emulation/qemu-x86/qemu-x86.c b/board/emulation/qemu-x86/qemu-x86.c index e69de29bb2d1..3a8a580cc591 100644 --- a/board/emulation/qemu-x86/qemu-x86.c +++ b/board/emulation/qemu-x86/qemu-x86.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <dm.h> +#include <init.h> +#include <log.h> +#include <qfw.h> + +int board_early_init_f(void) +{ + struct udevice *dev; + int ret; + + /* + * Make sure we enumerate the QEMU Firmware device to bind ramfb + * so video_reserve() can reserve memory for it. + */ + if (IS_ENABLED(CONFIG_QFW)) { + ret = qfw_get_dev(&dev); + if (ret) { + log_err("Failed to get QEMU FW device: %d\n", ret); + return ret; + } + } + + return 0; +} + +int board_early_init_r(void) +{ + struct udevice *dev; + int ret; + + /* + * Make sure we enumerate the QEMU Firmware device to find ramfb + * before console_init. + */ + if (IS_ENABLED(CONFIG_QFW)) { + ret = qfw_get_dev(&dev); + if (ret) { + log_err("Failed to get QEMU FW device: %d\n", ret); + return ret; + } + } + + return 0; +} diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index c6f30674a8fc..c9ad6eebd35c 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -1,13 +1,12 @@ CONFIG_X86=y CONFIG_TEXT_BASE=0x1110000 -CONFIG_SYS_MALLOC_F_LEN=0x1000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SIZE=0x40000 CONFIG_MAX_CPUS=2 CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SPL_TEXT_BASE=0xfffd8000 -CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_X86_RUN_64BIT=y @@ -59,7 +58,6 @@ CONFIG_CMD_USB=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_TIME=y -CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 24682a5387df..8a2311720f02 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_USB=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_TIME=y -CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MAC_PARTITION=y
Hi Alper,
Yes I see that problem too. I wonder how we can debug it?
Indeed...which makes me wonder if we can do something similar with Bochs, so that (from the cmdline) it is possible to chose ramfb, bochs or vesa?
Changes in v2:
imply VIDEO_RAMFB
imply CMD_QFW
if QEMU
int ret;
if (ret) {
return ret;
Same point about DT here.
int ret;
if (ret) {
return ret;
What is happening here? Why disable it?
CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 24682a5387df..8a2311720f02 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_USB=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_TIME=y -CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MAC_PARTITION=y -- 2.40.1
Hi Alper,
No idea, and I couldn't find a good commit to bisect from, tried as far back as v2021.10.
(Tried to answer video choice and DT concerns in another mail)
Changes in v2:
imply VIDEO_RAMFB
imply CMD_QFW
if QEMU
I used `imply CMD_QFW` above to be consistent with previous patches, so it's no longer necessary in defconfigs. Should I drop the imply and keep these in defconfig?
Hi Alper,
Changes in v2:
imply VIDEO_RAMFB
imply CMD_QFW
if QEMU
I think our Kconfig logic around the QFW options is a bit backwards, given that it's universal to the "qemu" boards and not used on qemu-emulates-known-hardware platforms. The qemu boards should be select'ing QFW, and CMD_QFW should be depends on QFW and default y, rather than selects.
Alexander Graf
Alper Nebi Yasak
