[PATCH] tpm2: tis_spi: add linux compatible fallback string
This solves a compatibility issue with Linux device trees that contain TPMv2.x hardware. So it's easier to import DTSs from upstream kernel when migrating board init from C code to device tree.
The issue is that fallback binding is different between Linux and u-Boot.
Linux: "tcg,tpm_tis-spi" U-Boot: "tis,tpm2-spi"
Signed-off-by: Bruno Thomsen bruno.thomsen@gmail.com --- doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt | 2 +- drivers/tpm/tpm2_tis_spi.c | 4 ++++ 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt b/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt index b48a15112d..b0bc9d6a65 100644 --- a/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt +++ b/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt @@ -2,7 +2,7 @@ ST33TPHF20 SPI TPMv2.0 bindings -------------------------------
Required properties: -- compatible : Should be "tis,tpm2-spi" +- compatible : Should be "tis,tpm2-spi" or "tcg,tpm_tis-spi" - reg : SPI Chip select
Optional properties: diff --git a/drivers/tpm/tpm2_tis_spi.c b/drivers/tpm/tpm2_tis_spi.c index 36016de4a6..73e5b6aab4 100644 --- a/drivers/tpm/tpm2_tis_spi.c +++ b/drivers/tpm/tpm2_tis_spi.c @@ -679,6 +679,10 @@ static const struct udevice_id tpm_tis_spi_ids[] = { .compatible = "tis,tpm2-spi", .data = (ulong)&tpm_tis_std_chip_data, }, + { + .compatible = "tcg,tpm_tis-spi", + .data = (ulong)&tpm_tis_std_chip_data, + }, { } };
Do we have any known users of the other compatible? I don't see any in-tree so we should lean towards just using the one in Linux. Thanks!
Bruno Thomsen
