[U-Boot] [PATCH] spl: spl_mmc: Minor cosmetics
This switches some printf calls to puts and avoids a test repetition.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- common/spl/spl_mmc.c | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index de495c0..f5ac844 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -43,13 +43,12 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) (void *) spl_image.load_addr);
end: + if (count == 0) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - if (count == 0) - printf("spl: mmc block read error\n"); + puts("spl: mmc block read error\n"); #endif - - if (count == 0) return -1; + }
return 0; } @@ -63,7 +62,7 @@ static int mmc_load_image_raw_partition(struct mmc *mmc, int partition) err = get_partition_info(&mmc->block_dev, partition, &info); if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: partition error\n"); + puts("spl: partition error\n"); #endif return -1; } @@ -83,7 +82,7 @@ static int mmc_load_image_raw_os(struct mmc *mmc) (void *) CONFIG_SYS_SPL_ARGS_ADDR); if (count == 0) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: mmc block read error\n"); + puts("spl: mmc block read error\n"); #endif return -1; }
Paul Kocialkowski
