Re: ext4load failed in the uboot
14 Oct
2022
14 Oct
'22
7:38 a.m.
Hi guys:
Do you have some patchs to protect this global vars?
kali
From: Kali Date: 2022-10-14 11:35 To: u-boot; wd Subject: ext4load failed in the uboot Hi guys: I'm kali.
We used this uboot(PDX-License-Identifier:GPL-2.0+) on the rtl11619b soc.
We find sometimes ext4load failed. cmd is "ext4load mmc 0:4 0x1400000 emmc.uImage".
I guss global vars cause this problem. Maybe,global vars are modified by other app.
for example:
static block_dev_desc_t *fs_dev_desc; static disk_partition_t fs_partition;( they are included fs.c)
struct ext2_data *ext4fs_root;struct ext2fs_node *ext4fs_file; uint32_t *ext4fs_indir1_block;( they are included ext4fs_common.c)
Please check it. Thank you!
kali
936
Kali
