[U-Boot] [PATCH v4] arm: dts: Stratix10: Add QSPI node
Add QSPI device tree to Stratix 10. Sync from Linux Stratix 10 dts.
Tested on Stratix 10 SoC devkit. SOCFPGA_STRATIX10 # sf probe 0:0 SF: Detected mt25qu02g with page size 256 Bytes, erase size 64 KiB, total 256 MiB
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
--- v3->v4: - Add qspi node to dtsi based on alphabetical order - Add spi-tx-bus-width and spi-rx-bus-width
v2->v3: - Change flash compatible to "jedec,spi-nor" - Change spi-max-frequency to 100MHz --- arch/arm/dts/socfpga_stratix10.dtsi | 15 +++++++++++++++ arch/arm/dts/socfpga_stratix10_socdk.dts | 23 +++++++++++++++++++++++ 2 files changed, 38 insertions(+)
diff --git a/arch/arm/dts/socfpga_stratix10.dtsi b/arch/arm/dts/socfpga_stratix10.dtsi index ee93725d648..fde76774047 100644 --- a/arch/arm/dts/socfpga_stratix10.dtsi +++ b/arch/arm/dts/socfpga_stratix10.dtsi @@ -237,6 +237,21 @@ reg = <0xffe00000 0x100000>; };
+ qspi: spi@ff8d2000 { + compatible = "cdns,qspi-nor"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xff8d2000 0x100>, + <0xff900000 0x100000>; + interrupts = <0 3 4>; + cdns,fifo-depth = <128>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x00000000>; + bus-num = <0>; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + rst: rstmgr@ffd11000 { #reset-cells = <1>; compatible = "altr,rst-mgr"; diff --git a/arch/arm/dts/socfpga_stratix10_socdk.dts b/arch/arm/dts/socfpga_stratix10_socdk.dts index c59b77d8298..438b43fef6b 100644 --- a/arch/arm/dts/socfpga_stratix10_socdk.dts +++ b/arch/arm/dts/socfpga_stratix10_socdk.dts @@ -10,6 +10,7 @@
aliases { serial0 = &uart0; + spi0 = &qspi; };
chosen { @@ -87,6 +88,28 @@ smplsel = <0>; };
+&qspi { + status = "okay"; + + flash@0 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; /* chip select */ + spi-max-frequency = <100000000>; + + page-size = <256>; + block-size = <16>; /* 2^16, 64KB */ + cdns,tshsl-ns = <50>; + cdns,tsd2d-ns = <50>; + cdns,tchsh-ns = <4>; + cdns,tslch-ns = <4>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + }; +}; + &uart0 { status = "okay"; };
Which tree? Which commit?
v3->v4:
v2->v3:
#size-cells = <0>;
bus-num = <0>;
This file should be in sync with the Linux one, no? Does the Linux on havethis U-Boot specific property here? I could check myself if you would have given a tree or commit id of the sync source in the commit message...
If the Linux dts does not have this property, it would have to be moved to a U-Boot specific "-u-boot.dtsi" addon file.
spi0 = &qspi; }; chosen {
+&qspi {
status = "okay";
flash@0 {
Same as above.
#size-cells = <1>;
page-size = <256>;
&uart0 { status = "okay"; }; -- 2.19.0
On Wed, Mar 27, 2019 at 7:31 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
It is based on kernel v5.0 in mainline.
v3->v4:
v2->v3:
#size-cells = <0>;
bus-num = <0>;
Okay, will add this in new revision.
Thanks.
Regards Ley Foon
In my understanding, 'sync from Linux' means this is a 1:1 copy of the file as it is in Linux. You should add the commit id or something like that to help reviewers identify the source and compare it.
However, I don't see all these U-Boot specific properties in the Linux version, so the term 'sync from Linux' does not seem correct. It seems like this difference has been there before this patch, so could you clean it up first? You'd do that by copying the files (e.g. from Linux 5.0) and after that restore the U-Boot contents by adding "-u-boot.dtsi" files. See my commit for gen5: commit c402e8170245 ("dts: arm: socfpga: merge gen5 devicetrees from linux") with the downside of a bad example: I forgot to add a Linux commit id :-(
v3->v4:
v2->v3:
#size-cells = <0>;
bus-num = <0>;
Thanks.
Regards Ley Foon
On Fri, Mar 29, 2019 at 2:57 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Okay, I will take a look this. Thanks.
Regards Ley Foon
v3->v4:
v2->v3:
#size-cells = <0>;
bus-num = <0>;
Thanks.
Regards Ley Foon
Ley Foon Tan
Ley Foon Tan
Simon Goldschmidt
