[PATCH v3 0/3] verdin-imx8mm: verdin-imx8mp: various additions and improvements
Various additions and improvements for the Verdin iMX8M Mini and Verdin iMX8M Plus:
- updated env memory layout - verdin-imx8mm: prepare for optional job ring driver model (already applied) - verdin-imx8mm: improve and extend boot devices (already applied) - various config additions and improvements
Changes in v3: - Moved loadaddr back by 0.5MB as I meanwhile found out that it is actually a property of the kernel binary whether or not any additional moving/relocation will (need) to be done. However, a pre-maturely applied v2 did not take that into account as of yet [1]. [1] https://patchwork.ozlabs.org/project/uboot/cover/20220822130604.843081-1-mar... - Drop SNVS_LP general purpose register LPGPR0 based bootcount integration in favour of using the environment based one as that is what our update system uses. - Update patch 1 again after wrong version got pre-maturely epplied. - Drop patches 2 and 3 which already got applied. - Drop SNVS_LP general purpose register LPGPR0 based bootcount integration in favour of using the environment based one as that is what our update system uses.
Changes in v2: - Moved loadaddr by an additional 0.5MB to avoid "Moving Image from 0x48200000 to 0x48280000" during booti plus increasing kernel_comp_size by same 0.5MB.
Marcel Ziswiler (3): verdin-imx8mm: verdin-imx8mp: update env memory layout (again) verdin-imx8mm: various config additions and improvements verdin-imx8mp: various config additions and improvements
configs/verdin-imx8mm_defconfig | 7 ++----- configs/verdin-imx8mp_defconfig | 30 ++++++++++++++++++++++++++---- include/configs/verdin-imx8mm.h | 2 +- include/configs/verdin-imx8mp.h | 2 +- 4 files changed, 30 insertions(+), 11 deletions(-)
Update the distro config env memory layout for the Verdin iMX8M Mini and Verdin iMX8M Plus again:
- loadaddr=0x48200000 allows for 128MB area for uncompressing (ie FIT images, kernel_comp_addr_r, kernel_comp_size) - fdt_addr_r = loadaddr + 128MB - allows for 128MB kernel - scriptaddr = fdt_addr_r + 512KB - allows for 512KB fdt - ramdisk_addr_r = scriptaddr + 512KB - allows for 512KB script
Memory layout taken from commit fd5c7173ade4 ("imx8m{m,n}_venice: update env memory layout").
Note that for our regular BSP Layers and Reference Images for Yocto Project an updated distro boot script is required (see meta-toradex-bsp-common/recipes-bsp/u-boot/u-boot-distro-boot).
Note that this corrects a pre-maturely applied version 2 of the same patch set.
Fixes: bbe0089d29e ("verdin-imx8mm: verdin-imx8mp: update env memory layout") Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
configs/verdin-imx8mm_defconfig | 2 +- configs/verdin-imx8mp_defconfig | 2 +- include/configs/verdin-imx8mm.h | 2 +- include/configs/verdin-imx8mp.h | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index f65b4a7f307..9b9b684ccbc 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -19,7 +19,7 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_SYS_LOAD_ADDR=0x48280000 +CONFIG_SYS_LOAD_ADDR=0x48200000 CONFIG_SYS_MEMTEST_START=0x40000000 CONFIG_SYS_MEMTEST_END=0x80000000 CONFIG_LTO=y diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 5d0c57c52e4..071a2223d41 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -22,7 +22,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_IMX_BOOTAUX=y CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 -CONFIG_SYS_LOAD_ADDR=0x48280000 +CONFIG_SYS_LOAD_ADDR=0x48200000 CONFIG_SYS_MEMTEST_START=0x40000000 CONFIG_SYS_MEMTEST_END=0x80000000 CONFIG_DISTRO_DEFAULTS=y diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 4d20b86591f..ec893763215 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -23,7 +23,7 @@ "fdt_addr_r=0x50200000\0" \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "kernel_comp_addr_r=0x40200000\0" \ - "kernel_comp_size=0x08080000\0" \ + "kernel_comp_size=0x08000000\0" \ "ramdisk_addr_r=0x50300000\0" \ "scriptaddr=0x50280000\0"
diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 9b8db223bb2..959c15f598e 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -37,7 +37,7 @@ "fdt_addr_r=0x50200000\0" \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "kernel_comp_addr_r=0x40200000\0" \ - "kernel_comp_size=0x08080000\0" \ + "kernel_comp_size=0x08000000\0" \ "ramdisk_addr_r=0x50300000\0" \ "scriptaddr=0x50280000\0"
From: Marcel Ziswiler marcel.ziswiler@toradex.com Update the distro config env memory layout for the Verdin iMX8M Mini and Verdin iMX8M Plus again:
Memory layout taken from commit fd5c7173ade4 ("imx8m{m,n}_venice: update env memory layout"). Note that for our regular BSP Layers and Reference Images for Yocto Project an updated distro boot script is required (see meta-toradex-bsp-common/recipes-bsp/u-boot/u-boot-distro-boot). Note that this corrects a pre-maturely applied version 2 of the same patch set. Fixes: bbe0089d29e ("verdin-imx8mm: verdin-imx8mp: update env memory layout") Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Best regards, Stefano Babic
- enable bootcount command - integrate bootcount using SNVS_LP general purpose register LPGPR0 - enable link-time optimisation - explicitly set a boot delay of one second - enable CRC32 and MD5 - enable command for low-level access to data in a partition - enable time commands - enable PMIC commands - improve ETHPRIME configuration - enable eMMC HS400 functionality - enable fixed PHY and MDIO driver model - remove stale PFUZE100 PMIC driver - enable thermal management unit driver - enable more USB host functionality - enable hexdump
Changes in v3: - Drop SNVS_LP general purpose register LPGPR0 based bootcount integration in favour of using the environment based one as that is what our update system uses.
configs/verdin-imx8mm_defconfig | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index 9b9b684ccbc..25cd59b185e 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -15,10 +15,7 @@ CONFIG_SYS_PROMPT="Verdin iMX8MM # " CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y -CONFIG_BOOTCOUNT_BOOTLIMIT=3 -CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 CONFIG_SPL=y -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_LOAD_ADDR=0x48200000 CONFIG_SYS_MEMTEST_START=0x40000000 CONFIG_SYS_MEMTEST_END=0x80000000 @@ -92,7 +89,7 @@ CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_SPL_DM=y CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 +CONFIG_BOOTCOUNT_ENV=y CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MM=y
- enable hexdump
- enable bootcount command - enable CRC32 and MD5 - enable time commands - enable GPIO LED support - enable further eMMC HS400 functionality - enable fixed PHY and MDIO driver model - enable USB host functionality - enable thermal management unit driver - enable hexdump
Changes in v3: - Update patch 1 again after wrong version got pre-maturely epplied. - Drop patches 2 and 3 which already got applied. - Drop SNVS_LP general purpose register LPGPR0 based bootcount integration in favour of using the environment based one as that is what our update system uses.
configs/verdin-imx8mp_defconfig | 28 +++++++++++++++++++++++++--- 1 file changed, 25 insertions(+), 3 deletions(-)
diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 071a2223d41..c476b734573 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -65,7 +65,9 @@ CONFIG_SYS_PBSIZE=2081 # CONFIG_BOOTM_NETBSD is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_EXPORTENV is not set -# CONFIG_CMD_CRC32 is not set +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y CONFIG_CMD_FUSE=y @@ -74,12 +76,14 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_READ=y CONFIG_CMD_USB=y +CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y CONFIG_CMD_UUID=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set -# CONFIG_EFI_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y @@ -106,29 +110,38 @@ CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y # CONFIG_SPL_DM_I2C is not set CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_LED=y +CONFIG_LED_GPIO=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y +CONFIG_SPL_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_ES_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y CONFIG_FSL_USDHC=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_PHY_FIXED=y +CONFIG_DM_MDIO=y CONFIG_DM_ETH_PHY=y CONFIG_DWC_ETH_QOS=y CONFIG_DWC_ETH_QOS_IMX=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y +CONFIG_PHY_IMX8MQ_USB=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y CONFIG_SPL_POWER_LEGACY=y CONFIG_POWER_DOMAIN=y CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y @@ -140,8 +153,17 @@ CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_EHCI_HCD=y +CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y CONFIG_IMX_WATCHDOG=y +CONFIG_HEXDUMP=y CONFIG_OF_LIBFDT_OVERLAY=y
- enable hexdump
Marcel Ziswiler
sbabic@denx.de
