[PATCH v1] rockchip: use OF_UPSTREAM for rk3288
The device tree for rk3288 combined is now available in the /dts/upstream directory. Use imply OF_UPSTREAM to migrate all rk3288 boards. Clean up MAINTAINERS.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- ...boot.dtsi => rk3288-evb-rk808-u-boot.dtsi} | 0 arch/arm/dts/rk3288-evb.dts | 20 - arch/arm/dts/rk3288-evb.dtsi | 476 ---- arch/arm/dts/rk3288-firefly.dts | 43 - arch/arm/dts/rk3288-firefly.dtsi | 491 ---- arch/arm/dts/rk3288-miqi.dts | 16 - arch/arm/dts/rk3288-miqi.dtsi | 417 ---- arch/arm/dts/rk3288-popmetal.dts | 20 - arch/arm/dts/rk3288-popmetal.dtsi | 547 ----- arch/arm/dts/rk3288-rock-pi-n8.dts | 17 - arch/arm/dts/rk3288-rock2-som.dtsi | 278 --- arch/arm/dts/rk3288-rock2-square.dts | 181 -- arch/arm/dts/rk3288-tinker-s.dts | 29 - arch/arm/dts/rk3288-tinker.dts | 33 - arch/arm/dts/rk3288-tinker.dtsi | 533 ----- arch/arm/dts/rk3288-veyron-chromebook.dtsi | 205 -- arch/arm/dts/rk3288-veyron-jerry.dts | 208 -- arch/arm/dts/rk3288-veyron-mickey.dts | 266 --- arch/arm/dts/rk3288-veyron-minnie.dts | 302 --- arch/arm/dts/rk3288-veyron-speedy.dts | 143 -- arch/arm/dts/rk3288-veyron-u-boot.dtsi | 8 + arch/arm/dts/rk3288-veyron.dtsi | 795 ------- arch/arm/dts/rk3288-vmarc-som.dtsi | 361 --- arch/arm/dts/rk3288-vyasa.dts | 473 ---- arch/arm/dts/rk3288.dtsi | 2035 ----------------- arch/arm/mach-rockchip/Kconfig | 1 + board/chipspark/popmetal_rk3288/MAINTAINERS | 4 +- board/google/veyron/MAINTAINERS | 10 +- board/mqmaker/miqi_rk3288/MAINTAINERS | 4 +- board/rockchip/evb_rk3288/MAINTAINERS | 7 +- board/rockchip/tinker_rk3288/MAINTAINERS | 8 +- configs/chromebit_mickey_defconfig | 4 +- configs/chromebook_jerry_defconfig | 4 +- configs/chromebook_minnie_defconfig | 4 +- configs/chromebook_speedy_defconfig | 4 +- ...8_defconfig => evb-rk808-rk3288_defconfig} | 4 +- configs/firefly-rk3288_defconfig | 4 +- configs/miqi-rk3288_defconfig | 4 +- configs/phycore-rk3288_defconfig | 1 - configs/popmetal-rk3288_defconfig | 4 +- configs/rock-pi-n8-rk3288_defconfig | 2 +- configs/rock2_defconfig | 4 +- configs/tinker-rk3288_defconfig | 4 +- configs/tinker-s-rk3288_defconfig | 4 +- configs/vyasa-rk3288_defconfig | 4 +- doc/board/rockchip/rockchip.rst | 5 +- 46 files changed, 44 insertions(+), 7943 deletions(-) rename arch/arm/dts/{rk3288-evb-u-boot.dtsi => rk3288-evb-rk808-u-boot.dtsi} (100%) delete mode 100644 arch/arm/dts/rk3288-evb.dts delete mode 100644 arch/arm/dts/rk3288-evb.dtsi delete mode 100644 arch/arm/dts/rk3288-firefly.dts delete mode 100644 arch/arm/dts/rk3288-firefly.dtsi delete mode 100644 arch/arm/dts/rk3288-miqi.dts delete mode 100644 arch/arm/dts/rk3288-miqi.dtsi delete mode 100644 arch/arm/dts/rk3288-popmetal.dts delete mode 100644 arch/arm/dts/rk3288-popmetal.dtsi delete mode 100644 arch/arm/dts/rk3288-rock-pi-n8.dts delete mode 100644 arch/arm/dts/rk3288-rock2-som.dtsi delete mode 100644 arch/arm/dts/rk3288-rock2-square.dts delete mode 100644 arch/arm/dts/rk3288-tinker-s.dts delete mode 100644 arch/arm/dts/rk3288-tinker.dts delete mode 100644 arch/arm/dts/rk3288-tinker.dtsi delete mode 100644 arch/arm/dts/rk3288-veyron-chromebook.dtsi delete mode 100644 arch/arm/dts/rk3288-veyron-jerry.dts delete mode 100644 arch/arm/dts/rk3288-veyron-mickey.dts delete mode 100644 arch/arm/dts/rk3288-veyron-minnie.dts delete mode 100644 arch/arm/dts/rk3288-veyron-speedy.dts delete mode 100644 arch/arm/dts/rk3288-veyron.dtsi delete mode 100644 arch/arm/dts/rk3288-vmarc-som.dtsi delete mode 100644 arch/arm/dts/rk3288-vyasa.dts delete mode 100644 arch/arm/dts/rk3288.dtsi rename configs/{evb-rk3288_defconfig => evb-rk808-rk3288_defconfig} (95%)
diff --git a/arch/arm/dts/rk3288-evb-u-boot.dtsi b/arch/arm/dts/rk3288-evb-rk808-u-boot.dtsi similarity index 100% rename from arch/arm/dts/rk3288-evb-u-boot.dtsi rename to arch/arm/dts/rk3288-evb-rk808-u-boot.dtsi diff --git a/arch/arm/dts/rk3288-evb.dts b/arch/arm/dts/rk3288-evb.dts deleted file mode 100644 index bb24a96cddf7..000000000000 --- a/arch/arm/dts/rk3288-evb.dts +++ /dev/null @@ -1,20 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd - */ - -/dts-v1/; -#include "rk3288-evb.dtsi" - -/ { - model = "Evb-RK3288"; - compatible = "evb-rk3288,evb-rk3288", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; -}; - -&pwm1 { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-evb.dtsi b/arch/arm/dts/rk3288-evb.dtsi deleted file mode 100644 index 0e347beb154d..000000000000 --- a/arch/arm/dts/rk3288-evb.dtsi +++ /dev/null @@ -1,476 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd - */ - -#include "rk3288.dtsi" - -/ { - memory { - reg = <0x0 0x0 0x0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - }; - - keys: gpio-keys { - compatible = "gpio-keys"; - - button@0 { - gpio-key,wakeup = <1>; - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - label = "GPIO Power"; - linux,code = <116>; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_key>; - }; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_5v: usb-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - }; - - vcc_host_5v: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc_host_5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc_5v>; - }; - - vcc_otg_5v: usb-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&otg_vbus_drv>; - regulator-name = "vcc_otg_5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc_5v>; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - power-supply = <&vcc_sys>; - enable-gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; - brightness-levels = < - 0 1 2 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - default-brightness-level = <50>; - pwms = <&pwm0 0 25000 0>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pin>; - pwm-delay-us = <10000>; - status = "disabled"; - }; - - panel: panel { - compatible = "simple-panel"; - power-supply = <&vcc_io>; - backlight = <&backlight>; - enable-gpios = <&gpio7 3 GPIO_ACTIVE_HIGH>; - status = "disabled"; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - broken-cd; - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; - status = "okay"; -}; - -&gmac { - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio4 7 0>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - vdd_cpu: syr827@40 { - compatible = "silergy,syr827"; - fcs,suspend-voltage-selector = <1>; - reg = <0x40>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - }; - - vdd_gpu: syr828@41 { - compatible = "silergy,syr828"; - fcs,suspend-voltage-selector = <1>; - reg = <0x41>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - hym8563: hym8563@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - interrupt-parent = <&gpio7>; - interrupts = <4 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&rtc_int>; - }; - - act8846: act8846@5a { - compatible = "active-semi,act8846"; - reg = <0x5a>; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_hold>; - system-power-controller; - - regulators { - vcc_ddr: REG1 { - regulator-name = "vcc_ddr"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-always-on; - }; - - vcc_io: REG2 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_log: REG3 { - regulator-name = "vdd_log"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-always-on; - }; - - vcc_20: REG4 { - regulator-name = "vcc_20"; - regulator-min-microvolt = <2000000>; - regulator-max-microvolt = <2000000>; - regulator-always-on; - }; - - vccio_sd: REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd10_lcd: REG6 { - regulator-name = "vdd10_lcd"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcca_codec: REG7 { - regulator-name = "vcca_codec"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_tp: REG8 { - regulator-name = "vcca_33"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vccio_pmu: REG9 { - regulator-name = "vccio_pmu"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vdd_10: REG10 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcc_18: REG11 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc18_lcd: REG12 { - regulator-name = "vcc18_lcd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&pinctrl { - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - act8846 { - pwr_hold: pwr-hold { - rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - hym8563 { - rtc_int: rtc-int { - rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - keys { - pwr_key: pwr-key { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_otg { - otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc_18>; - status = "okay"; -}; - -&sdio0 { - broken-cd; - bus-width = <4>; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>; - vmmc-supply = <&vcc_18>; - status = "disabled"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; - vmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&spi0 { - pinctrl-names = "default"; - pinctrl-0 = <&spi0_clk>, <&spi0_cs0>, <&spi0_tx>, <&spi0_rx>, <&spi0_cs1>; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>, <&uart0_cts>, <&uart0_rts>; - status = "okay"; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&usb_host1 { - status = "okay"; -}; - -&usb_otg { - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&mipi_dsi { - status = "disabled"; - rockchip,panel = <&panel>; - display-timings { - timing0 { - bits-per-pixel = <24>; - clock-frequency = <160000000>; - hfront-porch = <120>; - hsync-len = <20>; - hback-porch = <21>; - hactive = <1200>; - vfront-porch = <21>; - vsync-len = <3>; - vback-porch = <18>; - vactive = <1920>; - hsync-active = <0>; - vsync-active = <0>; - de-active = <1>; - pixelclk-active = <0>; - }; - }; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-firefly.dts b/arch/arm/dts/rk3288-firefly.dts deleted file mode 100644 index 72982efdf6df..000000000000 --- a/arch/arm/dts/rk3288-firefly.dts +++ /dev/null @@ -1,43 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * Copyright (c) 2014, 2015 FUKAUMI Naoki naobsd@gmail.com - */ - -/dts-v1/; -#include "rk3288-firefly.dtsi" - -/ { - model = "Firefly-RK3288"; - compatible = "firefly,firefly-rk3288", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; -}; - -&ir { - gpios = <&gpio7 0 GPIO_ACTIVE_LOW>; -}; - -&pinctrl { - act8846 { - pmic_vsel: pmic-vsel { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_output_low>; - }; - }; - - ir { - ir_int: ir-int { - rockchip,pins = <7 0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm1 { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-firefly.dtsi b/arch/arm/dts/rk3288-firefly.dtsi deleted file mode 100644 index 0824b19ee642..000000000000 --- a/arch/arm/dts/rk3288-firefly.dtsi +++ /dev/null @@ -1,491 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * Copyright (c) 2014, 2015 FUKAUMI Naoki naobsd@gmail.com - */ - -#include "rk3288.dtsi" - -/ { - memory { - reg = <0x0 0x0 0x0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - }; - - ir: ir-receiver { - compatible = "gpio-ir-receiver"; - pinctrl-names = "default"; - pinctrl-0 = <&ir_int>; - }; - - keys: gpio-keys { - compatible = "gpio-keys"; - - button@0 { - gpio-key,wakeup = <1>; - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - label = "GPIO Power"; - linux,code = <116>; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_key>; - }; - }; - - leds { - compatible = "gpio-leds"; - - work { - gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; - label = "firefly:blue:user"; - linux,default-trigger = "rc-feedback"; - pinctrl-names = "default"; - pinctrl-0 = <&work_led>; - }; - - power { - gpios = <&gpio8 2 GPIO_ACTIVE_LOW>; - label = "firefly:green:power"; - linux,default-trigger = "default-on"; - pinctrl-names = "default"; - pinctrl-0 = <&power_led>; - }; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_5v: usb-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - }; - - vcc_host_5v: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc_host_5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc_5v>; - }; - - vcc_otg_5v: usb-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&otg_vbus_drv>; - regulator-name = "vcc_otg_5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc_5v>; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - broken-cd; - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc_flash>; - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - clock_in_out = "input"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - vdd_cpu: syr827@40 { - compatible = "silergy,syr827"; - fcs,suspend-voltage-selector = <1>; - reg = <0x40>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - }; - - vdd_gpu: syr828@41 { - compatible = "silergy,syr828"; - fcs,suspend-voltage-selector = <1>; - reg = <0x41>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - hym8563: hym8563@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - interrupt-parent = <&gpio7>; - interrupts = <4 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&rtc_int>; - }; - - act8846: act8846@5a { - compatible = "active-semi,act8846"; - reg = <0x5a>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_vsel>, <&pwr_hold>; - system-power-controller; - - regulators { - vcc_ddr: REG1 { - regulator-name = "vcc_ddr"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-always-on; - }; - - vcc_io: REG2 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_log: REG3 { - regulator-name = "vdd_log"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-always-on; - }; - - vcc_20: REG4 { - regulator-name = "vcc_20"; - regulator-min-microvolt = <2000000>; - regulator-max-microvolt = <2000000>; - regulator-always-on; - }; - - vccio_sd: REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd10_lcd: REG6 { - regulator-name = "vdd10_lcd"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcca_18: REG7 { - regulator-name = "vcca_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vcca_33: REG8 { - regulator-name = "vcca_33"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_lan: REG9 { - regulator-name = "vcc_lan"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vdd_10: REG10 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcc_18: REG11 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc18_lcd: REG12 { - regulator-name = "vcc18_lcd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&pinctrl { - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { - bias-pull-up; - drive-strength = <12>; - }; - - act8846 { - pwr_hold: pwr-hold { - rockchip,pins = <0 1 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - gmac { - phy_int: phy-int { - rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_pmeb: phy-pmeb { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - hym8563 { - rtc_int: rtc-int { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - keys { - pwr_key: pwr-key { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - power_led: power-led { - rockchip,pins = <8 2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - work_led: work-led { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - /* - * Default drive strength isn't enough to achieve even - * high-speed mode on firefly board so bump up to 12ma. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_12ma>, - <6 RK_PC1 1 &pcfg_pull_up_drv_12ma>, - <6 RK_PC2 1 &pcfg_pull_up_drv_12ma>, - <6 RK_PC3 1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_12ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - usbhub_rst: usbhub-rst { - rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - usb_otg { - otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - vref-supply = <&vcc_18>; - status = "okay"; -}; - -&sdio0 { - broken-cd; - bus-width = <4>; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>; - vmmc-supply = <&vcc_18>; - status = "disabled"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - status = "okay"; -}; - -&spi0 { - pinctrl-names = "default"; - pinctrl-0 = <&spi0_clk>, <&spi0_cs0>, <&spi0_tx>, <&spi0_rx>, <&spi0_cs1>; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>, <&uart0_cts>, <&uart0_rts>; - status = "okay"; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&usb_host1 { - pinctrl-names = "default"; - pinctrl-0 = <&usbhub_rst>; - status = "okay"; -}; - -&usb_otg { - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-miqi.dts b/arch/arm/dts/rk3288-miqi.dts deleted file mode 100644 index 4a2f249e1b1f..000000000000 --- a/arch/arm/dts/rk3288-miqi.dts +++ /dev/null @@ -1,16 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd - */ - -/dts-v1/; -#include "rk3288-miqi.dtsi" - -/ { - model = "mqmaker MiQi"; - compatible = "mqmaker,miqi", "rockchip,rk3288"; - - chosen { - stdout-path = "serial2:115200n8"; - }; -}; diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi deleted file mode 100644 index c56e1109e3ac..000000000000 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ /dev/null @@ -1,417 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de - */ - -#include "rk3288.dtsi" - -/ { - memory { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - }; - - leds { - compatible = "gpio-leds"; - - work { - gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; - label = "miqi:green:user"; - linux,default-trigger = "default-on"; - pinctrl-names = "default"; - pinctrl-0 = <&led_ctl>; - }; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc_flash>; - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - clock_in_out = "input"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - vdd_cpu: syr827@40 { - compatible = "silergy,syr827"; - fcs,suspend-voltage-selector = <1>; - reg = <0x40>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - regulator-enable-ramp-delay = <300>; - regulator-ramp-delay = <8000>; - vin-supply = <&vcc_sys>; - }; - - vdd_gpu: syr828@41 { - compatible = "silergy,syr828"; - fcs,suspend-voltage-selector = <1>; - reg = <0x41>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - hym8563: hym8563@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - }; - - act8846: act8846@5a { - compatible = "active-semi,act8846"; - reg = <0x5a>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_vsel>; - system-power-controller; - - vp1-supply = <&vcc_sys>; - vp2-supply = <&vcc_sys>; - vp3-supply = <&vcc_sys>; - vp4-supply = <&vcc_sys>; - inl1-supply = <&vcc_sys>; - inl2-supply = <&vcc_sys>; - inl3-supply = <&vcc_20>; - - regulators { - vcc_ddr: REG1 { - regulator-name = "vcc_ddr"; - regulator-always-on; - }; - - vcc_io: REG2 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_log: REG3 { - regulator-name = "vdd_log"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-always-on; - }; - - vcc_20: REG4 { - regulator-name = "vcc_20"; - regulator-min-microvolt = <2000000>; - regulator-max-microvolt = <2000000>; - regulator-always-on; - }; - - vccio_sd: REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd10_lcd: REG6 { - regulator-name = "vdd10_lcd"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcca_18: REG7 { - regulator-name = "vcca_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vcca_33: REG8 { - regulator-name = "vcca_33"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_lan: REG9 { - regulator-name = "vcc_lan"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vdd_10: REG10 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcc_18: REG11 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc18_lcd: REG12 { - regulator-name = "vcc18_lcd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&io_domains { - audio-supply = <&vcca_33>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc_18>; - status = "okay"; -}; - -&pinctrl { - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { - bias-pull-up; - drive-strength = <12>; - }; - - act8846 { - pmic_int: pmic-int { - rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - pmic_sleep: pmic-sleep { - rockchip,pins = <0 0 RK_FUNC_GPIO &pcfg_output_low>; - }; - - pmic_vsel: pmic-vsel { - rockchip,pins = <7 1 RK_FUNC_GPIO &pcfg_output_low>; - }; - }; - - gmac { - phy_int: phy-int { - rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_pmeb: phy-pmeb { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - leds { - led_ctl: led-ctl { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - /* - * Default drive strength isn't enough to achieve even - * high-speed mode on firefly board so bump up to 12ma. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_12ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - vref-supply = <&vcc_18>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc_host>; - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-popmetal.dts b/arch/arm/dts/rk3288-popmetal.dts deleted file mode 100644 index 736dc51e2615..000000000000 --- a/arch/arm/dts/rk3288-popmetal.dts +++ /dev/null @@ -1,20 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd - */ - -/dts-v1/; -#include "rk3288-popmetal.dtsi" - -/ { - model = "PopMetal-RK3288"; - compatible = "chipspark,popmetal-rk3288", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; -}; - -&pwm1 { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi deleted file mode 100644 index ecff641b1099..000000000000 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ /dev/null @@ -1,547 +0,0 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#include <dt-bindings/input/input.h> -#include "rk3288.dtsi" - -/ { - memory{ - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - #clock-cells = <0>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - power { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - linux,input-type = <1>; - wakeup-source; - debounce-interval = <100>; - }; - }; - - ir: ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_int>; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - /* - * A PT5128 creates both dovdd_1v8 and vcc28_dvp, controlled - * by the dvp_pwr pin. - */ - vcc18_dvp: vcc18-dvp-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc18-dvp"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc28_dvp>; - }; - - vcc28_dvp: vcc28-dvp-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 17 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&dvp_pwr>; - regulator-name = "vcc28_dvp"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-always-on; - vin-supply = <&vcc_io>; - }; - - vcc5v0_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc5v0_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc_flash>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&gmac { - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio4 7 0>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - clock-frequency = <400000>; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_18>; - vcc9-supply = <&vcc_io>; - vcc10-supply = <&vcc_io>; - vcc11-supply = <&vcc_sys>; - vcc12-supply = <&vcc_io>; - vddio-supply = <&vcc_io>; - - regulators { - vdd_cpu: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_arm"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_io"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_lan: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_lan"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vccio_sd: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_10: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc18_lcd: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - ldo5: LDO_REG5 { - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "ldo5"; - }; - - vdd10_lcd: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd10_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_18: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca_33: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcca_33"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vccio_wl: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vccio_wl"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_lcd: SWITCH_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; - clock-frequency = <400000>; - - ak8963: ak8963@0d { - compatible = "asahi-kasei,ak8975"; - reg = <0x0d>; - interrupt-parent = <&gpio8>; - interrupts = <1 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&comp_int>; - }; - - l3g4200d: l3g4200d@68 { - compatible = "st,l3g4200d-gyro"; - st,drdy-int-pin = <2>; - reg = <0x6b>; - }; - - mma8452: mma8452@1d { - compatible = "fsl,mma8452"; - reg = <0x1d>; - interrupt-parent = <&gpio8>; - interrupts = <0 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&gsensor_int>; - }; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c3 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&io_domains { - audio-supply = <&vcca_33>; - bb-supply = <&vcc_io>; - dvp-supply = <&vcc18_dvp>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vccio_wl>; - status = "okay"; -}; - -&pinctrl { - ak8963 { - comp_int: comp-int { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - dvp { - dvp_pwr: dvp-pwr { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - ir { - ir_int: ir-int { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - mma8452 { - gsensor_int: gsensor-int { - rockchip,pins = <8 0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&uart0 { - status = "okay"; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&uart4 { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-rock-pi-n8.dts b/arch/arm/dts/rk3288-rock-pi-n8.dts deleted file mode 100644 index c9894a60e703..000000000000 --- a/arch/arm/dts/rk3288-rock-pi-n8.dts +++ /dev/null @@ -1,17 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * Copyright (c) 2019 Vamrs Limited - * Copyright (c) 2019 Amarula Solutions(India) - */ - -/dts-v1/; -#include "rk3288.dtsi" -#include <rockchip-radxa-dalang-carrier.dtsi> -#include "rk3288-vmarc-som.dtsi" - -/ { - model = "Radxa ROCK Pi N8"; - compatible = "radxa,rockpi-n8", "vamrs,rk3288-vmarc-som", - "rockchip,rk3288"; -}; diff --git a/arch/arm/dts/rk3288-rock2-som.dtsi b/arch/arm/dts/rk3288-rock2-som.dtsi deleted file mode 100644 index 58e32fbb80f6..000000000000 --- a/arch/arm/dts/rk3288-rock2-som.dtsi +++ /dev/null @@ -1,278 +0,0 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#include <dt-bindings/pwm/pwm.h> -#include "rk3288.dtsi" - -/ { - memory { - reg = <0x0 0x0 0x0 0x80000000>; - device_type = "memory"; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - pinctrl-0 = <&emmc_reset>; - pinctrl-names = "default"; - reset-gpios = <&gpio3 9 GPIO_ACTIVE_LOW>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - mmc-pwrseq = <&emmc_pwrseq>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; - vmmc-supply = <&vcc_io>; - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - clock_in_out = "input"; - phy-mode = "rgmii"; - phy-supply = <&vccio_pmu>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins &phy_rst>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 30000>; - rx_delay = <0x10>; - tx_delay = <0x30>; -}; - -&i2c0 { - status = "okay"; - - act8846: act8846@5a { - compatible = "active-semi,act8846"; - reg = <0x5a>; - system-power-controller; - inl1-supply = <&vcc_io>; - inl2-supply = <&vcc_sys>; - inl3-supply = <&vcc_20>; - vp1-supply = <&vcc_sys>; - vp2-supply = <&vcc_sys>; - vp3-supply = <&vcc_sys>; - vp4-supply = <&vcc_sys>; - - regulators { - vcc_ddr: REG1 { - regulator-name = "VCC_DDR"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-always-on; - }; - - vcc_io: REG2 { - regulator-name = "VCC_IO"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_log: REG3 { - regulator-name = "VDD_LOG"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcc_20: REG4 { - regulator-name = "VCC_20"; - regulator-min-microvolt = <2000000>; - regulator-max-microvolt = <2000000>; - regulator-always-on; - }; - - vccio_sd: REG5 { - regulator-name = "VCCIO_SD"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd10_lcd: REG6 { - regulator-name = "VDD10_LCD"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcca_codec: REG7 { - regulator-name = "VCCA_CODEC"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vcca_tp: REG8 { - regulator-name = "VCCA_TP"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vccio_pmu: REG9 { - regulator-name = "VCCIO_PMU"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_10: REG10 { - regulator-name = "VDD_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcc_18: REG11 { - regulator-name = "VCC_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc18_lcd: REG12 { - regulator-name = "VCC18_LCD"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - }; - }; - - vdd_cpu: syr827@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - regulator-always-on; - regulator-boot-on; - regulator-enable-ramp-delay = <300>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <8000>; - vin-supply = <&vcc_sys>; - }; - - vdd_gpu: syr828@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - regulator-always-on; - regulator-enable-ramp-delay = <300>; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_gpu"; - regulator-ramp-delay = <8000>; - vin-supply = <&vcc_sys>; - }; -}; - -&pinctrl { - pcfg_output_high: pcfg-output-high { - output-high; - }; - - emmc { - emmc_reset: emmc-reset { - rockchip,pins = <3 9 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - gmac { - phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-polarity = <0>; /* tshut polarity 0:LOW 1:HIGH */ - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-rock2-square.dts b/arch/arm/dts/rk3288-rock2-square.dts deleted file mode 100644 index 41676696ba33..000000000000 --- a/arch/arm/dts/rk3288-rock2-square.dts +++ /dev/null @@ -1,181 +0,0 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/dts-v1/; -#include "rk3288-rock2-som.dtsi" - -/ { - model = "Radxa Rock 2 Square"; - compatible = "radxa,rock2-square", "rockchip,rk3288"; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - ir: ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_int>; - }; - - sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "SPDIF"; - simple-audio-card,dai-link@1 { /* S/PDIF - S/PDIF */ - cpu { sound-dai = <&spdif>; }; - codec { sound-dai = <&spdif_out>; }; - }; - }; - - spdif_out: spdif-out { - compatible = "linux,spdif-dit"; - #sound-dai-cells = <0>; - }; - - vcc_usb_host: vcc-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - /* Always on as the rockchip usb phy doesn't have a vbus-supply - * property - */ - regulator-always-on; - regulator-name = "vcc_host"; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_io>; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; /* wp not hooked up */ - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&gmac { - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - hym8563@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>; - - }; -}; - -&i2c5 { - status = "okay"; -}; - -&pinctrl { - ir { - ir_int: ir-int { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&spdif { - status = "okay"; -}; - -&uart2 { - status = "okay"; - reg-shift = <2>; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-tinker-s.dts b/arch/arm/dts/rk3288-tinker-s.dts deleted file mode 100644 index cc7ac5f8811c..000000000000 --- a/arch/arm/dts/rk3288-tinker-s.dts +++ /dev/null @@ -1,29 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - */ - -/dts-v1/; - -#include "rk3288-tinker.dtsi" - -/ { - model = "Rockchip RK3288 Asus Tinker Board S"; - compatible = "asus,rk3288-tinker-s", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; - max-frequency = <150000000>; - mmc-hs200-1_8v; - mmc-ddr-1_8v; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-tinker.dts b/arch/arm/dts/rk3288-tinker.dts deleted file mode 100644 index 8b1848c310ee..000000000000 --- a/arch/arm/dts/rk3288-tinker.dts +++ /dev/null @@ -1,33 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd - */ - -/dts-v1/; -#include "rk3288-tinker.dtsi" - -/ { - model = "Tinker-RK3288"; - compatible = "rockchip,rk3288-tinker", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; -}; - -&pinctrl { - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm1 { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc5v0_host>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-tinker.dtsi b/arch/arm/dts/rk3288-tinker.dtsi deleted file mode 100644 index 62b4beb25100..000000000000 --- a/arch/arm/dts/rk3288-tinker.dtsi +++ /dev/null @@ -1,533 +0,0 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#include <dt-bindings/input/input.h> -#include "rk3288.dtsi" - -/ { - memory { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - #clock-cells = <0>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - button@0 { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - linux,input-type = <1>; - gpio-key,wakeup = <1>; - debounce-interval = <100>; - }; - }; - - gpio-leds { - compatible = "gpio-leds"; - - pwr-led { - gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "default-on"; - }; - - act-led { - gpios=<&gpio2 3 GPIO_ACTIVE_LOW>; - linux,default-trigger="mmc0"; - }; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - /* - * NOTE: vcc_sd isn't hooked up on v1.0 boards where power comes from - * vcc_io directly. Those boards won't be able to power cycle SD cards - * but it shouldn't hurt to toggle this pin there anyway. - */ - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc5v0_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc5v0_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; /* wp not hooked up */ - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - status = "okay"; - supports-sd; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&gmac { - phy-supply = <&vcc33_lan>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio4 7 0>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - clock-frequency = <400000>; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_18>; - vcc9-supply = <&vcc_io>; - vcc10-supply = <&vcc_io>; - vcc11-supply = <&vcc_sys>; - vcc12-supply = <&vcc_io>; - vddio-supply = <&vcc18_ldo1>; - - regulators { - vdd_cpu: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_arm"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_io"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc18_ldo1: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_ldo1"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc33_mipi: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_mipi"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_10: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc18_codec: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_codec"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vdd10_lcd: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd10_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_18: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_lcd: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc33_sd: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc33_sd"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc33_lan: SWITCH_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc33_lan"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - }; - }; -}; - -&i2c2 { - status = "okay"; - headset: nau8825@1a { - compatible = "nuvoton,nau8825"; - #sound-dai-cells = <0>; - reg = <0x1a>; - interrupt-parent = <&gpio6>; - interrupts = <5 IRQ_TYPE_LEVEL_LOW>; - nuvoton,jkdet-enable = <1>; - nuvoton,jkdet-pull-enable = <1>; - nuvoton,jkdet-pull-up = <0>; - nuvoton,jkdet-polarity = <1>; - nuvoton,vref-impedance = <2>; - nuvoton,micbias-voltage = <6>; - nuvoton,sar-threshold-num = <4>; - nuvoton,sar-threshold = <0xa 0x14 0x26 0x73>; - nuvoton,sar-hysteresis = <0>; - nuvoton,sar-voltage = <6>; - nuvoton,sar-compare-time = <0>; - nuvoton,sar-sampling-time = <0>; - nuvoton,short-key-debounce = <3>; - nuvoton,jack-insert-debounce = <7>; - nuvoton,jack-eject-debounce = <7>; - clock-names = "mclk"; - clocks = <&cru SCLK_I2S0_OUT>; - }; -}; - -&i2c5 { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; - -&pwm0 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc18_ldo1>; - status ="okay"; -}; - -&uart0 { - status = "okay"; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&uart4 { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host1 { - status = "okay"; -}; - -&usb_otg { - status= "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&pinctrl { - pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { - drive-strength = <8>; - }; - - pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - backlight { - bl_en: bl-en { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - eth_phy { - eth_phy_pwr: eth-phy-pwr { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - /* - * Default drive strength isn't enough to achieve even - * high-speed mode on EVB board so bump up to 8ma. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_8ma>; - }; - - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pwr_3g: pwr-3g { - rockchip,pins = <7 8 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; diff --git a/arch/arm/dts/rk3288-veyron-chromebook.dtsi b/arch/arm/dts/rk3288-veyron-chromebook.dtsi deleted file mode 100644 index 143eaae26db5..000000000000 --- a/arch/arm/dts/rk3288-veyron-chromebook.dtsi +++ /dev/null @@ -1,205 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Google Veyron (and derivatives) board device tree source - * - * Copyright 2014 Google, Inc - */ - -#include <dt-bindings/clock/rockchip,rk808.h> -#include <dt-bindings/input/input.h> -#include "rk3288-veyron.dtsi" - -/ { - aliases { - i2c20 = &i2c_tunnel; - video0 = &vopl; - video1 = &vopb; - }; - - gpio_keys: gpio-keys { - pinctrl-0 = <&pwr_key_h &ap_lid_int_l>; - lid { - label = "Lid"; - gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; - linux,code = <0>; /* SW_LID */ - linux,input-type = <5>; /* EV_SW */ - debounce-interval = <1>; - gpio-key,wakeup; - }; - }; - - gpio-charger { - compatible = "gpio-charger"; - gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&ac_present_ap>; - charger-type = "mains"; - }; - - /* A non-regulated voltage from power supply or battery */ - vccsys: vccsys { - compatible = "regulator-fixed"; - regulator-name = "vccsys"; - regulator-boot-on; - regulator-always-on; - }; - - vcc33_sys: vcc33-sys { - vin-supply = <&vccsys>; - }; - - vcc_5v: vcc-5v { - vin-supply = <&vccsys>; - }; - - /* This turns on vbus for host1 (dwc2) */ - vcc5_host1: vcc5-host1-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 11 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host1_pwr_en>; - regulator-name = "vcc5_host1"; - regulator-always-on; - regulator-boot-on; - }; - - /* This turns on vbus for otg for host mode (dwc2) */ - vcc5v_otg: vcc5v-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usbotg_pwren_h>; - regulator-name = "vcc5_host2"; - regulator-always-on; - regulator-boot-on; - }; -}; - -&rk808 { - regulators { - vcc33_ccd: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_ccd"; - regulator-suspend-mem-disabled; - }; - }; -}; - -&spi0 { - status = "okay"; - spi-activate-delay = <100>; - spi-max-frequency = <3000000>; - spi-deactivate-delay = <200>; - - cros_ec: ec@0 { - compatible = "google,cros-ec-spi"; - spi-max-frequency = <3000000>; - interrupt-parent = <&gpio7>; - interrupts = <7 IRQ_TYPE_LEVEL_LOW>; - ec-interrupt = <&gpio7 7 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ec_int>; - reg = <0>; - google,cros-ec-spi-pre-delay = <30>; - - i2c_tunnel: i2c-tunnel { - compatible = "google,cros-ec-i2c-tunnel"; - google,remote-bus = <0>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; -}; - -&i2c4 { - trackpad@15 { - compatible = "elan,i2c_touchpad"; - interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&trackpad_int>; - reg = <0x15>; - vcc-supply = <&vcc33_io>; - wakeup-source; - }; -}; - -&pinctrl { - pinctrl-0 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Wake only */ - &suspend_l_wake - &bt_dev_wake_awake - >; - pinctrl-1 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Sleep only */ - &suspend_l_sleep - &bt_dev_wake_sleep - >; - - buttons { - ap_lid_int_l: ap-lid-int-l { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - charger { - ac_present_ap: ac-present-ap { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - cros-ec { - ec_int: ec-int { - rockchip,pins = <7 7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_wp_gpio: sdmmc-wp-gpio { - rockchip,pins = <7 10 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - suspend { - suspend_l_wake: suspend-l-wake { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_low>; - }; - - suspend_l_sleep: suspend-l-sleep { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - trackpad { - trackpad_int: trackpad-int { - rockchip,pins = <7 3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb-host { - host1_pwr_en: host1-pwr-en { - rockchip,pins = <0 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - usbotg_pwren_h: usbotg-pwren-h { - rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -#include "cros-ec-keyboard.dtsi" diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts deleted file mode 100644 index 40fee55c7507..000000000000 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ /dev/null @@ -1,208 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Google Veyron Jerry Rev 3+ board device tree source - * - * Copyright 2014 Google, Inc - */ - -/dts-v1/; -#include "rk3288-veyron-chromebook.dtsi" -#include "cros-ec-sbs.dtsi" - -/ { - model = "Google Jerry"; - compatible = "google,veyron-jerry-rev7", "google,veyron-jerry-rev6", - "google,veyron-jerry-rev5", "google,veyron-jerry-rev4", - "google,veyron-jerry-rev3", "google,veyron-jerry", - "google,veyron", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; - - sound { - compatible = "rockchip,audio-max98090-jerry"; - - cpu { - sound-dai = <&i2s 0>; - }; - - codec { - sound-dai = <&max98090 0>; - }; - }; -}; - -&gpio_keys { - power { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - }; -}; - -&backlight { - power-supply = <&backlight_regulator>; -}; - -&panel { - power-supply= <&panel_regulator>; -}; - -&rk808 { - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l &dvs_1 &dvs_2>; - dvs-gpios = <&gpio7 12 GPIO_ACTIVE_HIGH>, - <&gpio7 15 GPIO_ACTIVE_HIGH>; - - regulators { - mic_vcc: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "mic_vcc"; - regulator-suspend-mem-disabled; - }; - }; -}; - -&sdmmc { - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio - &sdmmc_bus4>; - disable-wp; -}; - -&vcc_5v { - enable-active-high; - gpio = <&gpio7 21 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&drv_5v>; -}; - -&vcc50_hdmi { - enable-active-high; - gpio = <&gpio5 19 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc50_hdmi_en>; -}; - -&edp { - pinctrl-names = "default"; - pinctrl-0 = <&edp_hpd>; -}; - -&pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buck-5v { - drv_5v: drv-5v { - rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - emmc { - /* Make sure eMMC is not in reset */ - emmc_deassert_reset: emmc-deassert-reset { - rockchip,pins = <2 9 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - hdmi { - vcc50_hdmi_en: vcc50-hdmi-en { - rockchip,pins = <5 19 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd { - lcd_enable_h: lcd-en { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - avdd_1v8_disp_en: avdd-1v8-disp-en { - rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - dvs_1: dvs-1 { - rockchip,pins = <7 12 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; -}; - -&i2c4 { - status = "okay"; - - /* - * Trackpad pin control is shared between Elan and Synaptics devices - * so we have to pull it up to the bus level. - */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c4_xfer &trackpad_int>; - - trackpad@15 { - compatible = "elan,i2c_touchpad"; - interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; - /* - * Remove the inherited pinctrl settings to avoid clashing - * with bus-wide ones. - */ - /delete-property/pinctrl-names; - /delete-property/pinctrl-0; - reg = <0x15>; - vcc-supply = <&vcc33_io>; - wakeup-source; - }; - - trackpad@2c { - compatible = "hid-over-i2c"; - interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; - reg = <0x2c>; - hid-descr-addr = <0x0020>; - vcc-supply = <&vcc33_io>; - wakeup-source; - }; -}; diff --git a/arch/arm/dts/rk3288-veyron-mickey.dts b/arch/arm/dts/rk3288-veyron-mickey.dts deleted file mode 100644 index 0521d9e0e9a2..000000000000 --- a/arch/arm/dts/rk3288-veyron-mickey.dts +++ /dev/null @@ -1,266 +0,0 @@ -/* - * Google Veyron Mickey Rev 0 board device tree source - * - * Copyright 2015 Google, Inc - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/dts-v1/; -#include "rk3288-veyron-chromebook.dtsi" - -/ { - model = "Google Mickey"; - compatible = "google,veyron-mickey-rev8", "google,veyron-mickey-rev7", - "google,veyron-mickey-rev6", "google,veyron-mickey-rev5", - "google,veyron-mickey-rev4", "google,veyron-mickey-rev3", - "google,veyron-mickey-rev2", "google,veyron-mickey-rev1", - "google,veyron-mickey-rev0", "google,veyron-mickey", - "google,veyron", "rockchip,rk3288"; - - vcc_5v: vcc-5v { - vin-supply = <&vcc33_sys>; - }; - - vcc33_io: vcc33_io { - compatible = "regulator-fixed"; - regulator-name = "vcc33_io"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc33_sys>; - }; -}; - -&cpu_thermal { - /delete-node/ trips; - /delete-node/ cooling-maps; - - trips { - cpu_alert_almost_warm: cpu_alert_almost_warm { - temperature = <63000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert_warm: cpu_alert_warm { - temperature = <65000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert_almost_hot: cpu_alert_almost_hot { - temperature = <80000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert_hot: cpu_alert_hot { - temperature = <82000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert_hotter: cpu_alert_hotter { - temperature = <84000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert_very_hot: cpu_alert_very_hot { - temperature = <85000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_crit: cpu_crit { - temperature = <90000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - /* - * After 1st level, throttle the CPU down to as low as 1.4 GHz - * and don't let the GPU go faster than 400 MHz. Note that we - * won't throttle the GPU lower than 400 MHz due to CPU - * heat--we'll let the GPU do the rest itself. - */ - cpu_warm_limit_cpu { - trip = <&cpu_alert_warm>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT 4>; - }; - - /* - * Add some discrete steps to help throttling system deal - * with the fact that there are two passive cooling devices: - * the CPU and the GPU. - * - * - 1.2 GHz - 1.0 GHz (almost hot) - * - 800 MHz (hot) - * - 800 MHz - 696 MHz (hotter) - * - 696 MHz - min (very hot) - * - * Note: - * - 800 MHz appears to be a "sweet spot" for me. I can run - * some pretty serious workload here and be happy. - * - After 696 MHz we stop lowering voltage, so throttling - * past there is less effective. - */ - cpu_almost_hot_limit_cpu { - trip = <&cpu_alert_almost_hot>; - cooling-device = - <&cpu0 5 6>; - }; - cpu_hot_limit_cpu { - trip = <&cpu_alert_hot>; - cooling-device = - <&cpu0 7 7>; - }; - cpu_hotter_limit_cpu { - trip = <&cpu_alert_hotter>; - cooling-device = - <&cpu0 7 8>; - }; - cpu_very_hot_limit_cpu { - trip = <&cpu_alert_very_hot>; - cooling-device = - <&cpu0 8 THERMAL_NO_LIMIT>; - }; - }; -}; - -&emmc { - /delete-property/mmc-hs200-1_8v; -}; - -&i2c2 { - status = "disabled"; -}; - -&i2c4 { - status = "disabled"; -}; - -&i2s { - status = "okay"; - clock-names = "i2s_hclk", "i2s_clk", "i2s_clk_out"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; -}; - -&rk808 { - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l &dvs_1 &dvs_2>; - dvs-gpios = <&gpio7 12 GPIO_ACTIVE_HIGH>, - <&gpio7 15 GPIO_ACTIVE_HIGH>; - - /delete-property/ vcc6-supply; - /delete-property/ vcc12-supply; - - vcc11-supply = <&vcc33_sys>; - - regulators { - /* vcc33_io is sourced directly from vcc33_sys */ - /delete-node/ LDO_REG1; - /delete-node/ LDO_REG7; - - /* This is not a pwren anymore, but the real power supply */ - vdd10_lcd: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd10_lcd"; - regulator-suspend-mem-disabled; - }; - - vcc18_lcd: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_lcd"; - regulator-suspend-mem-disabled; - }; - }; -}; - -&pinctrl { - hdmi { - power_hdmi_on: power-hdmi-on { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - dvs_1: dvs-1 { - rockchip,pins = <7 12 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; -}; - -&sdmmc { - status = "disabled"; -}; - -&sdio0 { - status = "disabled"; -}; - -&sdmmc { - status = "disabled"; -}; - -&spi0 { - status = "disabled"; -}; - -&usb_host0_ehci { - status = "disabled"; -}; - -&usb_host1 { - status = "disabled"; -}; - -&vcc50_hdmi { - enable-active-high; - gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&power_hdmi_on>; -}; diff --git a/arch/arm/dts/rk3288-veyron-minnie.dts b/arch/arm/dts/rk3288-veyron-minnie.dts deleted file mode 100644 index b56a3f4f51af..000000000000 --- a/arch/arm/dts/rk3288-veyron-minnie.dts +++ /dev/null @@ -1,302 +0,0 @@ -/* - * Google Veyron Minnie Rev 0+ board device tree source - * - * Copyright 2015 Google, Inc - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/dts-v1/; -#include "rk3288-veyron-chromebook.dtsi" - -/ { - model = "Google Minnie"; - compatible = "google,veyron-minnie-rev4", "google,veyron-minnie-rev3", - "google,veyron-minnie-rev2", "google,veyron-minnie-rev1", - "google,veyron-minnie-rev0", "google,veyron-minnie", - "google,veyron", "rockchip,rk3288"; - - backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - startup-delay-us = <100000>; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - sound { - compatible = "rockchip,audio-max98090-jerry"; - - cpu { - sound-dai = <&i2s 0>; - }; - - codec { - sound-dai = <&max98090 0>; - }; - }; -}; - -&backlight { - /* Minnie panel PWM must be >= 1%, so start non-zero brightness at 3 */ - brightness-levels = < - 0 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - power-supply = <&backlight_regulator>; -}; - -&emmc { - /delete-property/mmc-hs200-1_8v; -}; - -&gpio_keys { - pinctrl-0 = <&pwr_key_h &ap_lid_int_l &volum_down_l &volum_up_l>; - - volum_down { - label = "Volum_down"; - gpios = <&gpio5 11 GPIO_ACTIVE_LOW>; - linux,code = <KEY_VOLUMEDOWN>; - debounce-interval = <100>; - }; - - volum_up { - label = "Volum_up"; - gpios = <&gpio5 10 GPIO_ACTIVE_LOW>; - linux,code = <KEY_VOLUMEUP>; - debounce-interval = <100>; - }; -}; - -&i2c_tunnel { - battery: bq27500@55 { - compatible = "ti,bq27500"; - reg = <0x55>; - }; -}; - -&i2c3 { - status = "okay"; - - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; - - touchscreen@10 { - compatible = "elan,ekth3500"; - reg = <0x10>; - interrupt-parent = <&gpio2>; - interrupts = <14 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&touch_int &touch_rst>; - reset-gpios = <&gpio2 15 GPIO_ACTIVE_LOW>; - vcc33-supply = <&vcc33_touch>; - vccio-supply = <&vcc33_touch>; - }; -}; - -&panel { - compatible = "auo,b101ean01", "simple-panel"; - power-supply= <&panel_regulator>; -}; - -&rk808 { - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l &dvs_1 &dvs_2>; - - regulators { - vcc33_touch: LDO_REG2 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_touch"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc5v_touch: SWITCH_REG2 { - regulator-name = "vcc5v_touch"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; -}; - -&sdmmc { - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio - &sdmmc_bus4>; -}; - -&vcc_5v { - enable-active-high; - gpio = <&gpio7 21 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&drv_5v>; -}; - -&vcc50_hdmi { - enable-active-high; - gpio = <&gpio5 19 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc50_hdmi_en>; -}; - -&pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buck-5v { - drv_5v: drv-5v { - rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - volum_down_l: volum-down-l { - rockchip,pins = <5 11 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - volum_up_l: volum-up-l { - rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - hdmi { - vcc50_hdmi_en: vcc50-hdmi-en { - rockchip,pins = <5 19 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd { - lcd_enable_h: lcd-en { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - avdd_1v8_disp_en: avdd-1v8-disp-en { - rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - dvs_1: dvs-1 { - rockchip,pins = <7 12 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - prochot { - gpio_prochot: gpio-prochot { - rockchip,pins = <2 8 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - touchscreen { - touch_int: touch-int { - rockchip,pins = <2 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - touch_rst: touch-rst { - rockchip,pins = <2 15 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; diff --git a/arch/arm/dts/rk3288-veyron-speedy.dts b/arch/arm/dts/rk3288-veyron-speedy.dts deleted file mode 100644 index 58c1fe96eea2..000000000000 --- a/arch/arm/dts/rk3288-veyron-speedy.dts +++ /dev/null @@ -1,143 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Google Veyron Speedy Rev 1+ board device tree source - * - * Copyright 2015 Google, Inc - */ - -/dts-v1/; -#include "rk3288-veyron-chromebook.dtsi" -#include "cros-ec-sbs.dtsi" -#include "rk3288-veyron-speedy-u-boot.dtsi" - -/ { - model = "Google Speedy"; - compatible = "google,veyron-speedy-rev9", "google,veyron-speedy-rev8", - "google,veyron-speedy-rev7", "google,veyron-speedy-rev6", - "google,veyron-speedy-rev5", "google,veyron-speedy-rev4", - "google,veyron-speedy-rev3", "google,veyron-speedy-rev2", - "google,veyron-speedy", "google,veyron", "rockchip,rk3288"; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 RK_PB6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - startup-delay-us = <100000>; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PB5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PB4 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; -}; - -&backlight { - power-supply = <&backlight_regulator>; -}; - -&cpu_alert0 { - temperature = <65000>; -}; - -&cpu_alert1 { - temperature = <70000>; -}; - -&edp { - /delete-property/pinctrl-names; - /delete-property/pinctrl-0; - - force-hpd; -}; - -&panel { - power-supply = <&panel_regulator>; -}; - -&rk808 { - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; -}; - -&sdmmc { - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio - &sdmmc_bus4>; -}; - -&vcc_5v { - enable-active-high; - gpio = <&gpio7 RK_PC5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&drv_5v>; -}; - -&vcc50_hdmi { - enable-active-high; - gpio = <&gpio5 RK_PC3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc50_hdmi_en>; -}; - -&pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buck-5v { - drv_5v: drv-5v { - rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - hdmi { - vcc50_hdmi_en: vcc50-hdmi-en { - rockchip,pins = <5 19 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd { - lcd_enable_h: lcd-en { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - avdd_1v8_disp_en: avdd-1v8-disp-en { - rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - dvs_1: dvs-1 { - rockchip,pins = <7 12 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; -}; diff --git a/arch/arm/dts/rk3288-veyron-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-u-boot.dtsi index 4f9c59c67573..57338cbf92e8 100644 --- a/arch/arm/dts/rk3288-veyron-u-boot.dtsi +++ b/arch/arm/dts/rk3288-veyron-u-boot.dtsi @@ -65,6 +65,14 @@
&spi2 { bootph-all; + + /delete-node/ flash@0; + + spi_flash: flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <50000000>; + }; };
&spi_flash { diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi deleted file mode 100644 index 99406151bf59..000000000000 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ /dev/null @@ -1,795 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Google Veyron (and derivatives) board device tree source - * - * Copyright 2014 Google, Inc - */ - -#include <dt-bindings/clock/rockchip,rk808.h> -#include <dt-bindings/input/input.h> -#include "rk3288.dtsi" - -/ { - memory { - reg = <0x0 0x0 0x0 0x80000000>; - }; - - chosen { - stdout-path = &uart2; - }; - - firmware { - chromeos { - pinctrl-names = "default"; - pinctrl-0 = <&fw_wp_ap>; - write-protect-gpio = <&gpio7 6 GPIO_ACTIVE_LOW>; - }; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - brightness-levels = < - 0 1 2 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - default-brightness-level = <128>; - enable-gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; - backlight-boot-off; - pinctrl-names = "default"; - pinctrl-0 = <&bl_en>; - pwms = <&pwm0 0 1000000 0>; - }; - - panel: panel { - compatible ="cnm,n116bgeea2","simple-panel"; - status = "okay"; - power-supply = <&vcc33_lcd>; - backlight = <&backlight>; - }; - - gpio_keys: gpio-keys { - compatible = "gpio-keys"; - - pinctrl-names = "default"; - pinctrl-0 = <&pwr_key_h>; - power { - label = "Power"; - gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>; - linux,code = <KEY_POWER>; - debounce-interval = <100>; - gpio-key,wakeup; - }; - }; - - gpio-restart { - compatible = "gpio-restart"; - gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&ap_warm_reset_h>; - priority = /bits/ 8 <200>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - pinctrl-0 = <&emmc_reset>; - pinctrl-names = "default"; - reset-gpios = <&gpio2 9 GPIO_ACTIVE_HIGH>; - }; - - sound { - compatible = "rockchip,rockchip-audio-max98090"; - rockchip,model = "ROCKCHIP-I2S"; - rockchip,i2s-controller = <&i2s>; - rockchip,audio-codec = <&max98090>; - rockchip,hp-det-gpios = <&gpio6 5 GPIO_ACTIVE_HIGH>; - rockchip,mic-det-gpios = <&gpio6 11 GPIO_ACTIVE_LOW>; - rockchip,headset-codec = <&headsetcodec>; - pinctrl-names = "default"; - pinctrl-0 = <&mic_det>, <&hp_det>; - }; - - vdd_logic: pwm-regulator { - compatible = "pwm-regulator"; - pwms = <&pwm1 0 2000 0>; - - voltage-table = <1350000 0>, - <1300000 10>, - <1250000 20>, - <1200000 31>, - <1150000 41>, - <1100000 52>, - <1050000 62>, - <1000000 72>, - < 950000 83>; - - regulator-min-microvolt = <950000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_logic"; - regulator-ramp-delay = <4000>; - }; - - vcc33_sys: vcc33-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc33_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vccsys>; - }; - - vcc_5v: vcc-5v { - compatible = "regulator-fixed"; - regulator-name = "vcc_5v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc50_hdmi: vcc50-hdmi { - compatible = "regulator-fixed"; - regulator-name = "vcc50_hdmi"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_5v>; - }; - - bt_regulator: bt-regulator { - /* - * On the module itself this is one of these (depending - * on the actual card pouplated): - * - BT_I2S_WS_BT_RFDISABLE_L - * - No connect - */ - - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_enable_l>; - regulator-name = "bt_regulator"; - }; - - wifi_regulator: wifi-regulator { - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 28 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - regulator-name = "wifi_regulator"; - - /* Faux input supply. See bt_regulator description. */ - vin-supply = <&bt_regulator>; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&efuse { - status = "okay"; -}; - -&emmc { - broken-cd; - bus-width = <8>; - cap-mmc-highspeed; - mmc-hs200-1_8v; - mmc-pwrseq = <&emmc_pwrseq>; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8 &emmc_pwr>; - status = "okay"; -}; - -&sdio0 { - broken-cd; - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - cap-sdio-irq; - card-external-vcc-supply = <&wifi_regulator>; - clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, - <&cru SCLK_SDIO0_SAMPLE>, <&rk808 RK808_CLKOUT1>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample", "card_ext_clock"; - keep-power-in-suspend; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>; - status = "okay"; - vmmc-supply = <&vcc33_sys>; - vqmmc-supply = <&vcc18_wl>; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - card-detect-delay = <200>; - cd-gpios = <&gpio7 5 GPIO_ACTIVE_LOW>; - num-slots = <1>; - status = "okay"; - vmmc-supply = <&vcc33_sd>; - vqmmc-supply = <&vccio_sd>; -}; - -&spi2 { - status = "okay"; - - spi_flash: spiflash@0 { - compatible = "spidev", "jedec,spi-nor"; - spi-max-frequency = <20000000>; /* Reduce for Dediprog em100 pro */ - reg = <0>; - }; -}; - -&i2c0 { - status = "okay"; - - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; /* 2.5ns measured */ - i2c-scl-rising-time-ns = <100>; /* 45ns measured */ - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - clock-output-names = "xin32k", "wifibt_32kin"; - interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - reg = <0x1b>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - - vcc1-supply = <&vcc33_sys>; - vcc2-supply = <&vcc33_sys>; - vcc3-supply = <&vcc33_sys>; - vcc4-supply = <&vcc33_sys>; - vcc6-supply = <&vcc_5v>; - vcc7-supply = <&vcc33_sys>; - vcc8-supply = <&vcc33_sys>; - vcc9-supply = <&vcc_5v>; - vcc10-supply = <&vcc33_sys>; - vcc11-supply = <&vcc_5v>; - vcc12-supply = <&vcc_18>; - - vddio-supply = <&vcc33_io>; - - regulators { - vdd_cpu: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1450000>; - regulator-name = "vdd_arm"; - regulator-ramp-delay = <6001>; - regulator-suspend-mem-disabled; - }; - - vdd_gpu: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; - regulator-ramp-delay = <6001>; - regulator-suspend-mem-disabled; - }; - - vcc135_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc135_ddr"; - regulator-suspend-mem-enabled; - }; - - /* - * vcc_18 has several aliases. (vcc18_flashio and - * vcc18_wl). We'll add those aliases here just to - * make it easier to follow the schematic. The signals - * are actually hooked together and only separated for - * power measurement purposes). - */ - vcc18_wl: vcc18_flashio: vcc_18: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; - regulator-suspend-mem-microvolt = <1800000>; - }; - - /* - * Note that both vcc33_io and vcc33_pmuio are always - * powered together. To simplify the logic in the dts - * we just refer to vcc33_io every time something is - * powered from vcc33_pmuio. In fact, on later boards - * (such as danger) they're the same net. - */ - vcc33_io: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_io"; - regulator-suspend-mem-microvolt = <3300000>; - }; - - vdd_10: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; - regulator-suspend-mem-microvolt = <1000000>; - }; - - vccio_sd: LDO_REG4 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-suspend-mem-disabled; - }; - - vcc33_sd: LDO_REG5 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_sd"; - regulator-suspend-mem-disabled; - }; - - vcc18_codec: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_codec"; - regulator-suspend-mem-disabled; - }; - - vdd10_lcd_pwren_h: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2500000>; - regulator-max-microvolt = <2500000>; - regulator-name = "vdd10_lcd_pwren_h"; - regulator-suspend-mem-disabled; - }; - - vcc33_lcd: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc33_lcd"; - regulator-suspend-mem-disabled; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; - - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; /* 2.5ns measured */ - i2c-scl-rising-time-ns = <100>; /* 40ns measured */ - - tpm: tpm@20 { - compatible = "infineon,slb9645tt"; - reg = <0x20>; - powered-while-suspended; - }; -}; - -&i2c2 { - status = "okay"; - - /* 100kHz since 4.7k resistors don't rise fast enough */ - clock-frequency = <100000>; - i2c-scl-falling-time-ns = <50>; /* 10ns measured */ - i2c-scl-rising-time-ns = <800>; /* 600ns measured */ - - max98090: max98090@10 { - compatible = "maxim,max98090"; - reg = <0x10>; - #sound-dai-cells = <0>; - interrupt-parent = <&gpio6>; - interrupts = <7 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&int_codec>; - }; -}; - -&i2c3 { - status = "okay"; - - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; -}; - -&i2c4 { - status = "okay"; - - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; /* 11ns measured */ - i2c-scl-rising-time-ns = <300>; /* 225ns measured */ - - headsetcodec: ts3a227e@3b { - compatible = "ti,ts3a227e"; - reg = <0x3b>; - interrupt-parent = <&gpio0>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ts3a227e_int_l>; - ti,micbias = <7>; /* MICBIAS = 2.8V */ - }; -}; - -&i2c5 { - status = "okay"; - - clock-frequency = <100000>; - i2c-scl-falling-time-ns = <300>; - i2c-scl-rising-time-ns = <1000>; -}; - -&i2s { - status = "okay"; - clock-names = "i2s_hclk", "i2s_clk", "i2s_clk_out"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; -}; - -&io_domains { - audio-supply = <&vcc18_codec>; - bb-supply = <&vcc33_io>; - dvp-supply = <&vcc_18>; - flash0-supply = <&vcc18_flashio>; - gpio1830-supply = <&vcc33_io>; - gpio30-supply = <&vcc33_io>; - lcdc-supply = <&vcc33_lcd>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc18_wl>; - status = "okay"; -}; - -&wdt { - status = "okay"; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm1 { - status = "okay"; -}; - -&uart0 { - status = "okay"; - - /* Pins don't include flow control by default; add that in */ - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - /* We need to go faster than 24MHz, so adjust clock parents / rates */ - assigned-clocks = <&cru SCLK_UART0>; - assigned-clock-rates = <48000000>; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; - reg-shift = <2>; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&edp { - status = "okay"; - rockchip,panel = <&panel>; -}; - -&hdmi { - status = "okay"; -}; - -&gpu { - status = "okay"; -}; - -&tsadc { - tsadc-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - tsadc-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ - status = "okay"; -}; - -&pinctrl { - pinctrl-names = "default", "sleep"; - pinctrl-0 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Wake only */ - &bt_dev_wake_awake - >; - pinctrl-1 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Sleep only */ - &bt_dev_wake_sleep - >; - - /* Add this for sdmmc pins to SD card */ - pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { - drive-strength = <8>; - }; - - pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - backlight { - bl_en: bl-en { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - pwr_key_h: pwr-key-h { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - codec { - hp_det: hp-det { - rockchip,pins = <6 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - int_codec: int-codec { - rockchip,pins = <6 7 RK_FUNC_GPIO &pcfg_pull_up>; - }; - mic_det: mic-det { - rockchip,pins = <6 11 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - emmc { - emmc_reset: emmc-reset { - rockchip,pins = <2 9 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - /* - * We run eMMC at max speed; bump up drive strength. - * We also have external pulls, so disable the internal ones. - */ - emmc_clk: emmc-clk { - rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; - }; - - emmc_cmd: emmc-cmd { - rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; - }; - - emmc_bus8: emmc-bus8 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 1 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 2 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 3 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 4 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 5 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 6 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 7 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; - }; - }; - - headset { - ts3a227e_int_l: ts3a227e-int-l { - rockchip,pins = <0 3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - /* - * Causes jerry to hang when probing bus 0 - * rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - */ - }; - }; - - reboot { - ap_warm_reset_h: ap-warm-reset-h { - rockchip,pins = <RK_GPIO0 13 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdio0 { - wifi_enable_h: wifienable-h { - rockchip,pins = <4 28 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - /* NOTE: mislabelled on schematic; should be bt_enable_h */ - bt_enable_l: bt-enable-l { - rockchip,pins = <4 29 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - /* - * We run sdio0 at max speed; bump up drive strength. - * We also have external pulls, so disable the internal ones. - */ - sdio0_bus4: sdio0-bus4 { - rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 22 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 23 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdio0_cmd: sdio0-cmd { - rockchip,pins = <4 24 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdio0_clk: sdio0-clk { - rockchip,pins = <4 25 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - /* - * These pins are only present on very new veyron boards; on - * older boards bt_dev_wake is simply always high. Note that - * gpio4_26 is a NC on old veyron boards, so it doesn't hurt - * to map this pin everywhere - */ - bt_dev_wake_sleep: bt-dev-wake-sleep { - rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_low>; - }; - - bt_dev_wake_awake: bt-dev-wake-awake { - rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - sdmmc { - /* - * We run sdmmc at max speed; bump up drive strength. - * We also have external pulls, so disable the internal ones. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 17 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 18 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 19 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - /* - * Builtin CD line is hooked to ground to prevent JTAG at boot - * (and also to get the voltage rail correct). Make we - * configure gpio6_C6 as GPIO so dw_mmc builtin CD doesn't - * think there's a card inserted - */ - sdmmc_cd_disabled: sdmmc-cd-disabled { - rockchip,pins = <6 22 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - /* This is where we actually hook up CD */ - sdmmc_cd_gpio: sdmmc-cd-gpio { - rockchip,pins = <7 5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - tpm { - tpm_int_h: tpm-int-h { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - write-protect { - fw_wp_ap: fw-wp-ap { - rockchip,pins = <7 6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; - needs-reset-on-resume; -}; - -&usb_host1 { - status = "okay"; -}; - -&usb_otg { - dr_mode = "host"; - status = "okay"; - assigned-clocks = <&cru SCLK_USBPHY480M_SRC>; - assigned-clock-parents = <&cru SCLK_OTGPHY0>; -}; diff --git a/arch/arm/dts/rk3288-vmarc-som.dtsi b/arch/arm/dts/rk3288-vmarc-som.dtsi deleted file mode 100644 index 793951655b73..000000000000 --- a/arch/arm/dts/rk3288-vmarc-som.dtsi +++ /dev/null @@ -1,361 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * Copyright (c) 2019 Vamrs Limited - * Copyright (c) 2019 Amarula Solutions(India) - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> - -/ { - compatible = "vamrs,rk3288-vmarc-som", "rockchip,rk3288"; - - vccio_flash: vccio-flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vccio_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vccio_flash>; - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_MAC>; - phy-supply = <&vcc_io>; - snps,reset-gpio = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec_c0>; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc_io>; - vcc9-supply = <&vcc_io>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc5v0_sys>; - vcc12-supply = <&vcc_io>; - vddio-supply = <&vcc_io>; - - regulators { - vdd_cpu: DCDC_REG1 { - regulator-name = "vdd_arm"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1400000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1250000>; - regulator-ramp-delay = <6000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_tp: LDO_REG1 { - regulator-name = "vcc_tp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca_codec: LDO_REG2 { - regulator-name = "vcca_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_wl: LDO_REG4 { - regulator-name = "vcc_wl"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vdd10_lcd: LDO_REG6 { - regulator-name = "vdd10_lcd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_18: LDO_REG7 { - regulator-name = "vcc_18"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_lcd: LDO_REG8 { - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_sd: SWITCH_REG1 { - regulator-name = "vcc_sd"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_lcd: SWITCH_REG2 { - regulator-name = "vcc_lcd"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&i2c1 { - clock-frequency = <400000>; - status = "okay"; - - hym8563: rtc@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - interrupt-parent = <&gpio5>; - interrupts = <RK_PC3 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <0>; - clock-output-names = "hym8563"; - pinctrl-names = "default"; - pinctrl-0 = <&hym8563_int>; - }; -}; - -&i2c5 { - status = "okay"; -}; - -&io_domains { - bb-supply = <&vcc_io>; - flash0-supply = <&vccio_flash>; - gpio1830-supply = <&vcc_18>; - gpio30-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc_wl>; - status = "okay"; -}; - -&pinctrl { - hym8563 { - hym8563_int: hym8563-int { - rockchip,pins = <5 RK_PC3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { - drive-strength = <8>; - }; - - pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = - <6 RK_PC0 1 &pcfg_pull_up_drv_8ma>, - <6 RK_PC1 1 &pcfg_pull_up_drv_8ma>, - <6 RK_PC2 1 &pcfg_pull_up_drv_8ma>, - <6 RK_PC3 1 &pcfg_pull_up_drv_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_8ma>; - }; - }; - - vbus_host { - usb1_en_oc: usb1-en-oc { - rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - vbus_typec { - usb0_en_oc: usb0-en-oc { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&sdio_pwrseq { - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; /* WIFI_REG_ON */ -}; - -&usbphy { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1 { - status = "okay"; -}; - -&usb_otg { - status = "okay"; -}; - -&vbus_host { - enable-active-high; - gpio = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>; /* USB1_EN_OC# */ -}; - -&vbus_typec { - enable-active-high; - gpio = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; /* USB0_EN_OC# */ -}; diff --git a/arch/arm/dts/rk3288-vyasa.dts b/arch/arm/dts/rk3288-vyasa.dts deleted file mode 100644 index 4193f7208cd0..000000000000 --- a/arch/arm/dts/rk3288-vyasa.dts +++ /dev/null @@ -1,473 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2017 Jagan Teki jagan@amarulasolutions.com - */ - -/dts-v1/; -#include "rk3288.dtsi" - -/ { - model = "Amarula Vyasa-RK3288"; - compatible = "amarula,vyasa-rk3288", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; - - memory { - reg = <0x0 0x0 0x0 0x80000000>; - device_type = "memory"; - }; - - dc12_vbat: dc12-vbat { - compatible = "regulator-fixed"; - regulator-name = "dc12_vbat"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - regulator-boot-on; - }; - - vboot_3v3: vboot-3v3 { - compatible = "regulator-fixed"; - regulator-name = "vboot_3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&dc12_vbat>; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <3700000>; - regulator-max-microvolt = <3700000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&dc12_vbat>; - }; - - vboot_5v: vboot-5v { - compatible = "regulator-fixed"; - regulator-name = "vboot_sv"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&dc12_vbat>; - }; - - v3g_3v3: v3g-3v3 { - compatible = "regulator-fixed"; - regulator-name = "v3g_3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&dc12_vbat>; - }; - - vsus_5v: vsus-5v { - compatible = "regulator-fixed"; - regulator-name = "vsus_5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_io>; - }; - - vcc50_hdmi: vcc50-hdmi { - compatible = "regulator-fixed"; - regulator-name = "vcc50_hdmi"; - enable-active-high; - gpio = <&gpio7 RK_PB4 GPIO_ACTIVE_HIGH>; /* HDMI_EN */ - pinctrl-names = "default"; - pinctrl-0 = <&vcc50_hdmi_en>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vsus_5v>; - }; - vusb1_5v: vusb1-5v { - compatible = "regulator-fixed"; - regulator-name = "vusb1_5v"; - enable-active-high; - gpio = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; /* OTG_VBUS_DRV */ - pinctrl-names = "default"; - pinctrl-0 = <&otg_vbus_drv>; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vsus_5v>; - }; - - vusb2_5v: vusb2-5v { - compatible = "regulator-fixed"; - regulator-name = "vusb2_5v"; - enable-active-high; - gpio = <&gpio8 RK_PB1 GPIO_ACTIVE_HIGH>; /* USB2_PWR_EN */ - pinctrl-names = "default"; - pinctrl-0 = <&usb2_pwr_en>; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vsus_5v>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; - vmmc-supply = <&vcc_io>; - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - clock_in_out = "input"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_io>; - vcc9-supply = <&vcc_sys>; - vcc10-supply = <&vcc_sys>; - vcc11-supply = <&vcc_sys>; - vcc12-supply = <&vcc_io>; - - regulators { - vdd_cpu: DCDC_REG1 { - regulator-name = "vdd_arm"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1250000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_tp: LDO_REG1 { - regulator-name = "vcc_tp"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_codec: LDO_REG2 { - regulator-name = "vcc_codec"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_gps: LDO_REG4 { - regulator-name = "vcc_gps"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vdd10_lcd: LDO_REG6 { - regulator-name = "vdd10_lcd"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_18: LDO_REG7 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_lcd: LDO_REG8 { - regulator-name = "vcc18_lcd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sd: SWITCH_REG1 { - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_lan: SWITCH_REG2 { - regulator-name = "vcc_lan"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - }; - }; -}; - -&i2c5 { - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host1 { - pinctrl-names = "default"; - pinctrl-0 = <&phy_pwr_en>; - status = "okay"; -}; - -&usb_otg { - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; - -&pinctrl { - pcfg_output_high: pcfg-output-high { - output-high; - }; - - gmac { - phy_int: phy-int { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_pmeb: phy-pmeb { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_rst: phy-rst { - rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - hdmi { - vcc50_hdmi_en: vcc50-hdmi-en { - rockchip,pins = <7 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb_host { - phy_pwr_en: phy-pwr-en { - rockchip,pins = <2 RK_PB1 RK_FUNC_GPIO &pcfg_output_high>; - }; - - usb2_pwr_en: usb2-pwr-en { - rockchip,pins = <8 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_otg { - otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; - - }; - }; -}; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi deleted file mode 100644 index ead343dc3df1..000000000000 --- a/arch/arm/dts/rk3288.dtsi +++ /dev/null @@ -1,2035 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/clock/rk3288-cru.h> -#include <dt-bindings/power/rk3288-power.h> -#include <dt-bindings/thermal/thermal.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> - -/ { - #address-cells = <2>; - #size-cells = <2>; - - compatible = "rockchip,rk3288"; - - interrupt-parent = <&gic>; - - aliases { - ethernet0 = &gmac; - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; - gpio4 = &gpio4; - gpio5 = &gpio5; - gpio6 = &gpio6; - gpio7 = &gpio7; - gpio8 = &gpio8; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - mshc0 = &emmc; - mshc1 = &sdmmc; - mshc2 = &sdio0; - mshc3 = &sdio1; - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; - serial4 = &uart4; - spi0 = &spi0; - spi1 = &spi1; - spi2 = &spi2; - }; - - arm-pmu { - compatible = "arm,cortex-a12-pmu"; - interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - enable-method = "rockchip,rk3066-smp"; - rockchip,pmu = <&pmu>; - - cpu0: cpu@500 { - device_type = "cpu"; - compatible = "arm,cortex-a12"; - reg = <0x500>; - resets = <&cru SRST_CORE0>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; /* min followed by max */ - clock-latency = <40000>; - clocks = <&cru ARMCLK>; - dynamic-power-coefficient = <370>; - }; - cpu1: cpu@501 { - device_type = "cpu"; - compatible = "arm,cortex-a12"; - reg = <0x501>; - resets = <&cru SRST_CORE1>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; /* min followed by max */ - clock-latency = <40000>; - clocks = <&cru ARMCLK>; - dynamic-power-coefficient = <370>; - }; - cpu2: cpu@502 { - device_type = "cpu"; - compatible = "arm,cortex-a12"; - reg = <0x502>; - resets = <&cru SRST_CORE2>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; /* min followed by max */ - clock-latency = <40000>; - clocks = <&cru ARMCLK>; - dynamic-power-coefficient = <370>; - }; - cpu3: cpu@503 { - device_type = "cpu"; - compatible = "arm,cortex-a12"; - reg = <0x503>; - resets = <&cru SRST_CORE3>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; /* min followed by max */ - clock-latency = <40000>; - clocks = <&cru ARMCLK>; - dynamic-power-coefficient = <370>; - }; - }; - - cpu_opp_table: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-126000000 { - opp-hz = /bits/ 64 <126000000>; - opp-microvolt = <900000>; - }; - opp-216000000 { - opp-hz = /bits/ 64 <216000000>; - opp-microvolt = <900000>; - }; - opp-312000000 { - opp-hz = /bits/ 64 <312000000>; - opp-microvolt = <900000>; - }; - opp-408000000 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <900000>; - }; - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <900000>; - }; - opp-696000000 { - opp-hz = /bits/ 64 <696000000>; - opp-microvolt = <950000>; - }; - opp-816000000 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <1000000>; - }; - opp-1008000000 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <1050000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <1100000>; - }; - opp-1416000000 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1200000>; - }; - opp-1512000000 { - opp-hz = /bits/ 64 <1512000000>; - opp-microvolt = <1300000>; - }; - opp-1608000000 { - opp-hz = /bits/ 64 <1608000000>; - opp-microvolt = <1350000>; - }; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - /* - * The rk3288 cannot use the memory area above 0xfe000000 - * for dma operations for some reason. While there is - * probably a better solution available somewhere, we - * haven't found it yet and while devices with 2GB of ram - * are not affected, this issue prevents 4GB from booting. - * So to make these devices at least bootable, block - * this area for the time being until the real solution - * is found. - */ - dma-unusable@fe000000 { - reg = <0x0 0xfe000000 0x0 0x1000000>; - }; - }; - - xin24m: oscillator { - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "xin24m"; - #clock-cells = <0>; - }; - - timer { - compatible = "arm,armv7-timer"; - arm,cpu-registers-not-fw-configured; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - clock-frequency = <24000000>; - arm,no-tick-in-suspend; - }; - - timer: timer@ff810000 { - compatible = "rockchip,rk3288-timer"; - reg = <0x0 0xff810000 0x0 0x20>; - interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_TIMER>, <&xin24m>; - clock-names = "pclk", "timer"; - }; - - display-subsystem { - compatible = "rockchip,display-subsystem"; - ports = <&vopl_out>, <&vopb_out>; - }; - - sdmmc: mmc@ff0c0000 { - compatible = "rockchip,rk3288-dw-mshc"; - max-frequency = <150000000>; - clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, - <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xff0c0000 0x0 0x4000>; - resets = <&cru SRST_MMC0>; - reset-names = "reset"; - status = "disabled"; - }; - - sdio0: mmc@ff0d0000 { - compatible = "rockchip,rk3288-dw-mshc"; - max-frequency = <150000000>; - clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, - <&cru SCLK_SDIO0_DRV>, <&cru SCLK_SDIO0_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xff0d0000 0x0 0x4000>; - resets = <&cru SRST_SDIO0>; - reset-names = "reset"; - status = "disabled"; - }; - - sdio1: mmc@ff0e0000 { - compatible = "rockchip,rk3288-dw-mshc"; - max-frequency = <150000000>; - clocks = <&cru HCLK_SDIO1>, <&cru SCLK_SDIO1>, - <&cru SCLK_SDIO1_DRV>, <&cru SCLK_SDIO1_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xff0e0000 0x0 0x4000>; - resets = <&cru SRST_SDIO1>; - reset-names = "reset"; - status = "disabled"; - }; - - emmc: mmc@ff0f0000 { - compatible = "rockchip,rk3288-dw-mshc"; - max-frequency = <150000000>; - clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, - <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xff0f0000 0x0 0x4000>; - resets = <&cru SRST_EMMC>; - reset-names = "reset"; - status = "disabled"; - }; - - saradc: saradc@ff100000 { - compatible = "rockchip,saradc"; - reg = <0x0 0xff100000 0x0 0x100>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - #io-channel-cells = <1>; - clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; - clock-names = "saradc", "apb_pclk"; - resets = <&cru SRST_SARADC>; - reset-names = "saradc-apb"; - status = "disabled"; - }; - - spi0: spi@ff110000 { - compatible = "rockchip,rk3288-spi", "rockchip,rk3066-spi"; - clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac_peri 11>, <&dmac_peri 12>; - dma-names = "tx", "rx"; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; - reg = <0x0 0xff110000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi1: spi@ff120000 { - compatible = "rockchip,rk3288-spi", "rockchip,rk3066-spi"; - clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac_peri 13>, <&dmac_peri 14>; - dma-names = "tx", "rx"; - interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; - reg = <0x0 0xff120000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi2: spi@ff130000 { - compatible = "rockchip,rk3288-spi", "rockchip,rk3066-spi"; - clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac_peri 15>, <&dmac_peri 16>; - dma-names = "tx", "rx"; - interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; - reg = <0x0 0xff130000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@ff140000 { - compatible = "rockchip,rk3288-i2c"; - reg = <0x0 0xff140000 0x0 0x1000>; - interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "i2c"; - clocks = <&cru PCLK_I2C1>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_xfer>; - status = "disabled"; - }; - - i2c3: i2c@ff150000 { - compatible = "rockchip,rk3288-i2c"; - reg = <0x0 0xff150000 0x0 0x1000>; - interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "i2c"; - clocks = <&cru PCLK_I2C3>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_xfer>; - status = "disabled"; - }; - - i2c4: i2c@ff160000 { - compatible = "rockchip,rk3288-i2c"; - reg = <0x0 0xff160000 0x0 0x1000>; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "i2c"; - clocks = <&cru PCLK_I2C4>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c4_xfer>; - status = "disabled"; - }; - - i2c5: i2c@ff170000 { - compatible = "rockchip,rk3288-i2c"; - reg = <0x0 0xff170000 0x0 0x1000>; - interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "i2c"; - clocks = <&cru PCLK_I2C5>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_xfer>; - status = "disabled"; - }; - - uart0: serial@ff180000 { - compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff180000 0x0 0x100>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac_peri 1>, <&dmac_peri 2>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>; - status = "disabled"; - }; - - uart1: serial@ff190000 { - compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff190000 0x0 0x100>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac_peri 3>, <&dmac_peri 4>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart1_xfer>; - status = "disabled"; - }; - - uart2: serial@ff690000 { - compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff690000 0x0 0x100>; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; - clock-names = "baudclk", "apb_pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&uart2_xfer>; - status = "disabled"; - }; - - uart3: serial@ff1b0000 { - compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff1b0000 0x0 0x100>; - interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac_peri 7>, <&dmac_peri 8>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart3_xfer>; - status = "disabled"; - }; - - uart4: serial@ff1c0000 { - compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff1c0000 0x0 0x100>; - interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac_peri 9>, <&dmac_peri 10>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart4_xfer>; - status = "disabled"; - }; - - dmac_peri: dma-controller@ff250000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff250000 0x0 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC2>; - clock-names = "apb_pclk"; - }; - - thermal-zones { - reserve_thermal: reserve-thermal { - polling-delay-passive = <1000>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - thermal-sensors = <&tsadc 0>; - }; - - cpu_thermal: cpu-thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - thermal-sensors = <&tsadc 1>; - - trips { - cpu_alert0: cpu_alert0 { - temperature = <70000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert1: cpu_alert1 { - temperature = <75000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_crit: cpu_crit { - temperature = <90000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu_alert0>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT 6>, - <&cpu1 THERMAL_NO_LIMIT 6>, - <&cpu2 THERMAL_NO_LIMIT 6>, - <&cpu3 THERMAL_NO_LIMIT 6>; - }; - map1 { - trip = <&cpu_alert1>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - gpu_thermal: gpu-thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - thermal-sensors = <&tsadc 2>; - - trips { - gpu_alert0: gpu_alert0 { - temperature = <70000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - gpu_crit: gpu_crit { - temperature = <90000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&gpu_alert0>; - cooling-device = - <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - }; - - tsadc: tsadc@ff280000 { - compatible = "rockchip,rk3288-tsadc"; - reg = <0x0 0xff280000 0x0 0x100>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; - clock-names = "tsadc", "apb_pclk"; - resets = <&cru SRST_TSADC>; - reset-names = "tsadc-apb"; - pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&otp_pin>; - pinctrl-1 = <&otp_out>; - pinctrl-2 = <&otp_pin>; - #thermal-sensor-cells = <1>; - rockchip,grf = <&grf>; - rockchip,hw-tshut-temp = <95000>; - status = "disabled"; - }; - - gmac: ethernet@ff290000 { - compatible = "rockchip,rk3288-gmac"; - reg = <0x0 0xff290000 0x0 0x10000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq", "eth_wake_irq"; - rockchip,grf = <&grf>; - clocks = <&cru SCLK_MAC>, - <&cru SCLK_MAC_RX>, <&cru SCLK_MAC_TX>, - <&cru SCLK_MACREF>, <&cru SCLK_MACREF_OUT>, - <&cru ACLK_GMAC>, <&cru PCLK_GMAC>; - clock-names = "stmmaceth", - "mac_clk_rx", "mac_clk_tx", - "clk_mac_ref", "clk_mac_refout", - "aclk_mac", "pclk_mac"; - resets = <&cru SRST_MAC>; - reset-names = "stmmaceth"; - status = "disabled"; - }; - - usb_host0_ehci: usb@ff500000 { - compatible = "generic-ehci"; - reg = <0x0 0xff500000 0x0 0x100>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_USBHOST0>; - phys = <&usbphy1>; - phy-names = "usb"; - status = "disabled"; - }; - - /* NOTE: doesn't work on RK3288, but was fixed on RK3288W */ - usb_host0_ohci: usb@ff520000 { - compatible = "generic-ohci"; - reg = <0x0 0xff520000 0x0 0x100>; - interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_USBHOST0>; - phys = <&usbphy1>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host1: usb@ff540000 { - compatible = "rockchip,rk3288-usb", "rockchip,rk3066-usb", - "snps,dwc2"; - reg = <0x0 0xff540000 0x0 0x40000>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_USBHOST1>; - clock-names = "otg"; - dr_mode = "host"; - phys = <&usbphy2>; - phy-names = "usb2-phy"; - snps,reset-phy-on-wake; - status = "disabled"; - }; - - usb_otg: usb@ff580000 { - compatible = "rockchip,rk3288-usb", "rockchip,rk3066-usb", - "snps,dwc2"; - reg = <0x0 0xff580000 0x0 0x40000>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_OTG0>; - clock-names = "otg"; - dr_mode = "otg"; - g-np-tx-fifo-size = <16>; - g-rx-fifo-size = <275>; - g-tx-fifo-size = <256 128 128 64 64 32>; - phys = <&usbphy0>; - phy-names = "usb2-phy"; - status = "disabled"; - }; - - usb_hsic: usb@ff5c0000 { - compatible = "generic-ehci"; - reg = <0x0 0xff5c0000 0x0 0x100>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HSIC>; - status = "disabled"; - }; - - dmac_bus_ns: dma-controller@ff600000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff600000 0x0 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; - status = "disabled"; - }; - - i2c0: i2c@ff650000 { - compatible = "rockchip,rk3288-i2c"; - reg = <0x0 0xff650000 0x0 0x1000>; - interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "i2c"; - clocks = <&cru PCLK_I2C0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_xfer>; - status = "disabled"; - }; - - i2c2: i2c@ff660000 { - compatible = "rockchip,rk3288-i2c"; - reg = <0x0 0xff660000 0x0 0x1000>; - interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clock-names = "i2c"; - clocks = <&cru PCLK_I2C2>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_xfer>; - status = "disabled"; - }; - - pwm0: pwm@ff680000 { - compatible = "rockchip,rk3288-pwm"; - reg = <0x0 0xff680000 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pin>; - clocks = <&cru PCLK_RKPWM>; - status = "disabled"; - }; - - pwm1: pwm@ff680010 { - compatible = "rockchip,rk3288-pwm"; - reg = <0x0 0xff680010 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm1_pin>; - clocks = <&cru PCLK_RKPWM>; - status = "disabled"; - }; - - pwm2: pwm@ff680020 { - compatible = "rockchip,rk3288-pwm"; - reg = <0x0 0xff680020 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm2_pin>; - clocks = <&cru PCLK_RKPWM>; - status = "disabled"; - }; - - pwm3: pwm@ff680030 { - compatible = "rockchip,rk3288-pwm"; - reg = <0x0 0xff680030 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm3_pin>; - clocks = <&cru PCLK_RKPWM>; - status = "disabled"; - }; - - bus_intmem: sram@ff700000 { - compatible = "mmio-sram"; - reg = <0x0 0xff700000 0x0 0x18000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x0 0xff700000 0x18000>; - smp-sram@0 { - compatible = "rockchip,rk3066-smp-sram"; - reg = <0x00 0x10>; - }; - }; - - pmu_sram: sram@ff720000 { - compatible = "rockchip,rk3288-pmu-sram", "mmio-sram"; - reg = <0x0 0xff720000 0x0 0x1000>; - }; - - pmu: power-management@ff730000 { - compatible = "rockchip,rk3288-pmu", "syscon", "simple-mfd"; - reg = <0x0 0xff730000 0x0 0x100>; - - power: power-controller { - compatible = "rockchip,rk3288-power-controller"; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - assigned-clocks = <&cru SCLK_EDP_24M>; - assigned-clock-parents = <&xin24m>; - - /* - * Note: Although SCLK_* are the working clocks - * of device without including on the NOC, needed for - * synchronous reset. - * - * The clocks on the which NOC: - * ACLK_IEP/ACLK_VIP/ACLK_VOP0 are on ACLK_VIO0_NIU. - * ACLK_ISP/ACLK_VOP1 are on ACLK_VIO1_NIU. - * ACLK_RGA is on ACLK_RGA_NIU. - * The others (HCLK_*,PLCK_*) are on HCLK_VIO_NIU. - * - * Which clock are device clocks: - * clocks devices - * *_IEP IEP:Image Enhancement Processor - * *_ISP ISP:Image Signal Processing - * *_VIP VIP:Video Input Processor - * *_VOP* VOP:Visual Output Processor - * *_RGA RGA - * *_EDP* EDP - * *_LVDS_* LVDS - * *_HDMI HDMI - * *_MIPI_* MIPI - */ - power-domain@RK3288_PD_VIO { - reg = <RK3288_PD_VIO>; - clocks = <&cru ACLK_IEP>, - <&cru ACLK_ISP>, - <&cru ACLK_RGA>, - <&cru ACLK_VIP>, - <&cru ACLK_VOP0>, - <&cru ACLK_VOP1>, - <&cru DCLK_VOP0>, - <&cru DCLK_VOP1>, - <&cru HCLK_IEP>, - <&cru HCLK_ISP>, - <&cru HCLK_RGA>, - <&cru HCLK_VIP>, - <&cru HCLK_VOP0>, - <&cru HCLK_VOP1>, - <&cru PCLK_EDP_CTRL>, - <&cru PCLK_HDMI_CTRL>, - <&cru PCLK_LVDS_PHY>, - <&cru PCLK_MIPI_CSI>, - <&cru PCLK_MIPI_DSI0>, - <&cru PCLK_MIPI_DSI1>, - <&cru SCLK_EDP_24M>, - <&cru SCLK_EDP>, - <&cru SCLK_ISP_JPE>, - <&cru SCLK_ISP>, - <&cru SCLK_RGA>; - pm_qos = <&qos_vio0_iep>, - <&qos_vio1_vop>, - <&qos_vio1_isp_w0>, - <&qos_vio1_isp_w1>, - <&qos_vio0_vop>, - <&qos_vio0_vip>, - <&qos_vio2_rga_r>, - <&qos_vio2_rga_w>, - <&qos_vio1_isp_r>; - #power-domain-cells = <0>; - }; - - /* - * Note: The following 3 are HEVC(H.265) clocks, - * and on the ACLK_HEVC_NIU (NOC). - */ - power-domain@RK3288_PD_HEVC { - reg = <RK3288_PD_HEVC>; - clocks = <&cru ACLK_HEVC>, - <&cru SCLK_HEVC_CABAC>, - <&cru SCLK_HEVC_CORE>; - pm_qos = <&qos_hevc_r>, - <&qos_hevc_w>; - #power-domain-cells = <0>; - }; - - /* - * Note: ACLK_VCODEC/HCLK_VCODEC are VCODEC - * (video endecoder & decoder) clocks that on the - * ACLK_VCODEC_NIU and HCLK_VCODEC_NIU (NOC). - */ - power-domain@RK3288_PD_VIDEO { - reg = <RK3288_PD_VIDEO>; - clocks = <&cru ACLK_VCODEC>, - <&cru HCLK_VCODEC>; - pm_qos = <&qos_video>; - #power-domain-cells = <0>; - }; - - /* - * Note: ACLK_GPU is the GPU clock, - * and on the ACLK_GPU_NIU (NOC). - */ - power-domain@RK3288_PD_GPU { - reg = <RK3288_PD_GPU>; - clocks = <&cru ACLK_GPU>; - pm_qos = <&qos_gpu_r>, - <&qos_gpu_w>; - #power-domain-cells = <0>; - }; - }; - - reboot-mode { - compatible = "syscon-reboot-mode"; - offset = <0x94>; - mode-normal = <BOOT_NORMAL>; - mode-recovery = <BOOT_RECOVERY>; - mode-bootloader = <BOOT_FASTBOOT>; - mode-loader = <BOOT_BL_DOWNLOAD>; - }; - }; - - sgrf: syscon@ff740000 { - compatible = "rockchip,rk3288-sgrf", "syscon"; - reg = <0x0 0xff740000 0x0 0x1000>; - }; - - cru: clock-controller@ff760000 { - compatible = "rockchip,rk3288-cru"; - reg = <0x0 0xff760000 0x0 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - assigned-clocks = <&cru PLL_GPLL>, <&cru PLL_CPLL>, - <&cru PLL_NPLL>, <&cru ACLK_CPU>, - <&cru HCLK_CPU>, <&cru PCLK_CPU>, - <&cru ACLK_PERI>, <&cru HCLK_PERI>, - <&cru PCLK_PERI>; - assigned-clock-rates = <594000000>, <400000000>, - <500000000>, <300000000>, - <150000000>, <75000000>, - <300000000>, <150000000>, - <75000000>; - }; - - grf: syscon@ff770000 { - compatible = "rockchip,rk3288-grf", "syscon", "simple-mfd"; - reg = <0x0 0xff770000 0x0 0x1000>; - - edp_phy: edp-phy { - compatible = "rockchip,rk3288-dp-phy"; - clocks = <&cru SCLK_EDP_24M>; - clock-names = "24m"; - #phy-cells = <0>; - status = "disabled"; - }; - - io_domains: io-domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - status = "disabled"; - }; - - usbphy: usbphy { - compatible = "rockchip,rk3288-usb-phy"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - - usbphy0: usb-phy@320 { - #phy-cells = <0>; - reg = <0x320>; - clocks = <&cru SCLK_OTGPHY0>; - clock-names = "phyclk"; - #clock-cells = <0>; - resets = <&cru SRST_USBOTG_PHY>; - reset-names = "phy-reset"; - }; - - usbphy1: usb-phy@334 { - #phy-cells = <0>; - reg = <0x334>; - clocks = <&cru SCLK_OTGPHY1>; - clock-names = "phyclk"; - #clock-cells = <0>; - resets = <&cru SRST_USBHOST0_PHY>; - reset-names = "phy-reset"; - }; - - usbphy2: usb-phy@348 { - #phy-cells = <0>; - reg = <0x348>; - clocks = <&cru SCLK_OTGPHY2>; - clock-names = "phyclk"; - #clock-cells = <0>; - resets = <&cru SRST_USBHOST1_PHY>; - reset-names = "phy-reset"; - }; - }; - }; - - wdt: watchdog@ff800000 { - compatible = "rockchip,rk3288-wdt", "snps,dw-wdt"; - reg = <0x0 0xff800000 0x0 0x100>; - clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - - spdif: sound@ff8b0000 { - compatible = "rockchip,rk3288-spdif", "rockchip,rk3066-spdif"; - reg = <0x0 0xff8b0000 0x0 0x10000>; - #sound-dai-cells = <0>; - clocks = <&cru SCLK_SPDIF8CH>, <&cru HCLK_SPDIF8CH>; - clock-names = "mclk", "hclk"; - dmas = <&dmac_bus_s 3>; - dma-names = "tx"; - interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&spdif_tx>; - rockchip,grf = <&grf>; - status = "disabled"; - }; - - i2s: i2s@ff890000 { - compatible = "rockchip,rk3288-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff890000 0x0 0x10000>; - #sound-dai-cells = <0>; - interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&i2s0_bus>; - rockchip,playback-channels = <8>; - rockchip,capture-channels = <2>; - status = "disabled"; - }; - - crypto: crypto@ff8a0000 { - compatible = "rockchip,rk3288-crypto"; - reg = <0x0 0xff8a0000 0x0 0x4000>; - interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_CRYPTO>, <&cru HCLK_CRYPTO>, - <&cru SCLK_CRYPTO>, <&cru ACLK_DMAC1>; - clock-names = "aclk", "hclk", "sclk", "apb_pclk"; - resets = <&cru SRST_CRYPTO>; - reset-names = "crypto-rst"; - }; - - iep_mmu: iommu@ff900800 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff900800 0x0 0x40>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - status = "disabled"; - }; - - isp_mmu: iommu@ff914000 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_ISP>, <&cru HCLK_ISP>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - rockchip,disable-mmu-reset; - status = "disabled"; - }; - - rga: rga@ff920000 { - compatible = "rockchip,rk3288-rga"; - reg = <0x0 0xff920000 0x0 0x180>; - interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>; - clock-names = "aclk", "hclk", "sclk"; - power-domains = <&power RK3288_PD_VIO>; - resets = <&cru SRST_RGA_CORE>, <&cru SRST_RGA_AXI>, <&cru SRST_RGA_AHB>; - reset-names = "core", "axi", "ahb"; - }; - - vopb: vop@ff930000 { - compatible = "rockchip,rk3288-vop"; - reg = <0x0 0xff930000 0x0 0x19c>, <0x0 0xff931000 0x0 0x1000>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - power-domains = <&power RK3288_PD_VIO>; - resets = <&cru SRST_LCDC0_AXI>, <&cru SRST_LCDC0_AHB>, <&cru SRST_LCDC0_DCLK>; - reset-names = "axi", "ahb", "dclk"; - iommus = <&vopb_mmu>; - status = "disabled"; - - vopb_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vopb_out_hdmi: endpoint@0 { - reg = <0>; - remote-endpoint = <&hdmi_in_vopb>; - }; - - vopb_out_edp: endpoint@1 { - reg = <1>; - remote-endpoint = <&edp_in_vopb>; - }; - - vopb_out_mipi: endpoint@2 { - reg = <2>; - remote-endpoint = <&mipi_in_vopb>; - }; - - vopb_out_lvds: endpoint@3 { - reg = <3>; - remote-endpoint = <&lvds_in_vopb>; - }; - }; - }; - - vopb_mmu: iommu@ff930300 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff930300 0x0 0x100>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; - clock-names = "aclk", "iface"; - power-domains = <&power RK3288_PD_VIO>; - #iommu-cells = <0>; - status = "disabled"; - }; - - vopl: vop@ff940000 { - compatible = "rockchip,rk3288-vop"; - reg = <0x0 0xff940000 0x0 0x19c>, <0x0 0xff941000 0x0 0x1000>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - power-domains = <&power RK3288_PD_VIO>; - resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; - reset-names = "axi", "ahb", "dclk"; - iommus = <&vopl_mmu>; - status = "disabled"; - - vopl_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vopl_out_hdmi: endpoint@0 { - reg = <0>; - remote-endpoint = <&hdmi_in_vopl>; - }; - - vopl_out_edp: endpoint@1 { - reg = <1>; - remote-endpoint = <&edp_in_vopl>; - }; - - vopl_out_mipi: endpoint@2 { - reg = <2>; - remote-endpoint = <&mipi_in_vopl>; - }; - - vopl_out_lvds: endpoint@3 { - reg = <3>; - remote-endpoint = <&lvds_in_vopl>; - }; - }; - }; - - vopl_mmu: iommu@ff940300 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff940300 0x0 0x100>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; - clock-names = "aclk", "iface"; - power-domains = <&power RK3288_PD_VIO>; - #iommu-cells = <0>; - status = "disabled"; - }; - - mipi_dsi: dsi@ff960000 { - compatible = "rockchip,rk3288-mipi-dsi", "snps,dw-mipi-dsi"; - reg = <0x0 0xff960000 0x0 0x4000>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_MIPIDSI_24M>, <&cru PCLK_MIPI_DSI0>; - clock-names = "ref", "pclk"; - power-domains = <&power RK3288_PD_VIO>; - rockchip,grf = <&grf>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - mipi_in: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - - mipi_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_mipi>; - }; - - mipi_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_mipi>; - }; - }; - - mipi_out: port@1 { - reg = <1>; - }; - }; - }; - - lvds: lvds@ff96c000 { - compatible = "rockchip,rk3288-lvds"; - reg = <0x0 0xff96c000 0x0 0x4000>; - clocks = <&cru PCLK_LVDS_PHY>; - clock-names = "pclk_lvds"; - pinctrl-names = "lcdc"; - pinctrl-0 = <&lcdc_ctl>; - power-domains = <&power RK3288_PD_VIO>; - rockchip,grf = <&grf>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - lvds_in: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - - lvds_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_lvds>; - }; - - lvds_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_lvds>; - }; - }; - - lvds_out: port@1 { - reg = <1>; - }; - }; - }; - - edp: dp@ff970000 { - compatible = "rockchip,rk3288-dp"; - reg = <0x0 0xff970000 0x0 0x4000>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_EDP>, <&cru PCLK_EDP_CTRL>; - clock-names = "dp", "pclk"; - phys = <&edp_phy>; - phy-names = "dp"; - power-domains = <&power RK3288_PD_VIO>; - resets = <&cru SRST_EDP>; - reset-names = "dp"; - rockchip,grf = <&grf>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - edp_in: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - - edp_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_edp>; - }; - - edp_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_edp>; - }; - }; - - edp_out: port@1 { - reg = <1>; - }; - }; - }; - - hdmi: hdmi@ff980000 { - compatible = "rockchip,rk3288-dw-hdmi"; - reg = <0x0 0xff980000 0x0 0x20000>; - reg-io-width = <4>; - #sound-dai-cells = <0>; - rockchip,grf = <&grf>; - interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>, <&cru SCLK_HDMI_CEC>; - clock-names = "iahb", "isfr", "cec"; - power-domains = <&power RK3288_PD_VIO>; - status = "disabled"; - - ports { - hdmi_in: port { - #address-cells = <1>; - #size-cells = <0>; - hdmi_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_hdmi>; - }; - hdmi_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_hdmi>; - }; - }; - }; - }; - - vpu: video-codec@ff9a0000 { - compatible = "rockchip,rk3288-vpu"; - reg = <0x0 0xff9a0000 0x0 0x800>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vepu", "vdpu"; - clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; - clock-names = "aclk", "hclk"; - iommus = <&vpu_mmu>; - power-domains = <&power RK3288_PD_VIDEO>; - }; - - vpu_mmu: iommu@ff9a0800 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff9a0800 0x0 0x100>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - power-domains = <&power RK3288_PD_VIDEO>; - }; - - hevc_mmu: iommu@ff9c0440 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff9c0440 0x0 0x40>, <0x0 0xff9c0480 0x0 0x40>; - interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_HEVC>, <&cru HCLK_HEVC>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - status = "disabled"; - }; - - gpu: gpu@ffa30000 { - compatible = "rockchip,rk3288-mali", "arm,mali-t760"; - reg = <0x0 0xffa30000 0x0 0x10000>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "job", "mmu", "gpu"; - clocks = <&cru ACLK_GPU>; - operating-points-v2 = <&gpu_opp_table>; - #cooling-cells = <2>; /* min followed by max */ - power-domains = <&power RK3288_PD_GPU>; - status = "disabled"; - }; - - gpu_opp_table: opp-table-1 { - compatible = "operating-points-v2"; - - opp-100000000 { - opp-hz = /bits/ 64 <100000000>; - opp-microvolt = <950000>; - }; - opp-200000000 { - opp-hz = /bits/ 64 <200000000>; - opp-microvolt = <950000>; - }; - opp-300000000 { - opp-hz = /bits/ 64 <300000000>; - opp-microvolt = <1000000>; - }; - opp-400000000 { - opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <1100000>; - }; - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <1250000>; - }; - }; - - qos_gpu_r: qos@ffaa0000 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffaa0000 0x0 0x20>; - }; - - qos_gpu_w: qos@ffaa0080 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffaa0080 0x0 0x20>; - }; - - qos_vio1_vop: qos@ffad0000 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0000 0x0 0x20>; - }; - - qos_vio1_isp_w0: qos@ffad0100 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0100 0x0 0x20>; - }; - - qos_vio1_isp_w1: qos@ffad0180 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0180 0x0 0x20>; - }; - - qos_vio0_vop: qos@ffad0400 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0400 0x0 0x20>; - }; - - qos_vio0_vip: qos@ffad0480 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0480 0x0 0x20>; - }; - - qos_vio0_iep: qos@ffad0500 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0500 0x0 0x20>; - }; - - qos_vio2_rga_r: qos@ffad0800 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0800 0x0 0x20>; - }; - - qos_vio2_rga_w: qos@ffad0880 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0880 0x0 0x20>; - }; - - qos_vio1_isp_r: qos@ffad0900 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffad0900 0x0 0x20>; - }; - - qos_video: qos@ffae0000 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffae0000 0x0 0x20>; - }; - - qos_hevc_r: qos@ffaf0000 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffaf0000 0x0 0x20>; - }; - - qos_hevc_w: qos@ffaf0080 { - compatible = "rockchip,rk3288-qos", "syscon"; - reg = <0x0 0xffaf0080 0x0 0x20>; - }; - - dmac_bus_s: dma-controller@ffb20000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xffb20000 0x0 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; - }; - - efuse: efuse@ffb40000 { - compatible = "rockchip,rk3288-efuse"; - reg = <0x0 0xffb40000 0x0 0x20>; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&cru PCLK_EFUSE256>; - clock-names = "pclk_efuse"; - - cpu_id: cpu-id@7 { - reg = <0x07 0x10>; - }; - cpu_leakage: cpu_leakage@17 { - reg = <0x17 0x1>; - }; - }; - - gic: interrupt-controller@ffc01000 { - compatible = "arm,gic-400"; - interrupt-controller; - #interrupt-cells = <3>; - #address-cells = <0>; - - reg = <0x0 0xffc01000 0x0 0x1000>, - <0x0 0xffc02000 0x0 0x2000>, - <0x0 0xffc04000 0x0 0x2000>, - <0x0 0xffc06000 0x0 0x2000>; - interrupts = <GIC_PPI 9 0xf04>; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rk3288-pinctrl"; - rockchip,grf = <&grf>; - rockchip,pmu = <&pmu>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio0: gpio@ff750000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff750000 0x0 0x100>; - interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO0>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@ff780000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff780000 0x0 0x100>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO1>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@ff790000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff790000 0x0 0x100>; - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO2>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@ff7a0000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff7a0000 0x0 0x100>; - interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO3>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@ff7b0000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff7b0000 0x0 0x100>; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO4>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio5: gpio@ff7c0000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff7c0000 0x0 0x100>; - interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO5>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio6: gpio@ff7d0000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff7d0000 0x0 0x100>; - interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO6>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio7: gpio@ff7e0000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff7e0000 0x0 0x100>; - interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO7>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio8: gpio@ff7f0000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff7f0000 0x0 0x100>; - interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO8>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - hdmi { - hdmi_cec_c0: hdmi-cec-c0 { - rockchip,pins = <7 RK_PC0 2 &pcfg_pull_none>; - }; - - hdmi_cec_c7: hdmi-cec-c7 { - rockchip,pins = <7 RK_PC7 4 &pcfg_pull_none>; - }; - - hdmi_ddc: hdmi-ddc { - rockchip,pins = <7 RK_PC3 2 &pcfg_pull_none>, - <7 RK_PC4 2 &pcfg_pull_none>; - }; - - hdmi_ddc_unwedge: hdmi-ddc-unwedge { - rockchip,pins = <7 RK_PC3 RK_FUNC_GPIO &pcfg_output_low>, - <7 RK_PC4 2 &pcfg_pull_none>; - }; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_pull_up: pcfg-pull-up { - bias-pull-up; - }; - - pcfg_pull_down: pcfg-pull-down { - bias-pull-down; - }; - - pcfg_pull_none: pcfg-pull-none { - bias-disable; - }; - - pcfg_pull_none_12ma: pcfg-pull-none-12ma { - bias-disable; - drive-strength = <12>; - }; - - suspend { - global_pwroff: global-pwroff { - rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>; - }; - - ddrio_pwroff: ddrio-pwroff { - rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; - }; - - ddr0_retention: ddr0-retention { - rockchip,pins = <0 RK_PA2 1 &pcfg_pull_up>; - }; - - ddr1_retention: ddr1-retention { - rockchip,pins = <0 RK_PA3 1 &pcfg_pull_up>; - }; - }; - - edp { - edp_hpd: edp-hpd { - rockchip,pins = <7 RK_PB3 2 &pcfg_pull_down>; - }; - }; - - i2c0 { - i2c0_xfer: i2c0-xfer { - rockchip,pins = <0 RK_PB7 1 &pcfg_pull_none>, - <0 RK_PC0 1 &pcfg_pull_none>; - }; - }; - - i2c1 { - i2c1_xfer: i2c1-xfer { - rockchip,pins = <8 RK_PA4 1 &pcfg_pull_none>, - <8 RK_PA5 1 &pcfg_pull_none>; - }; - }; - - i2c2 { - i2c2_xfer: i2c2-xfer { - rockchip,pins = <6 RK_PB1 1 &pcfg_pull_none>, - <6 RK_PB2 1 &pcfg_pull_none>; - }; - }; - - i2c3 { - i2c3_xfer: i2c3-xfer { - rockchip,pins = <2 RK_PC0 1 &pcfg_pull_none>, - <2 RK_PC1 1 &pcfg_pull_none>; - }; - }; - - i2c4 { - i2c4_xfer: i2c4-xfer { - rockchip,pins = <7 RK_PC1 1 &pcfg_pull_none>, - <7 RK_PC2 1 &pcfg_pull_none>; - }; - }; - - i2c5 { - i2c5_xfer: i2c5-xfer { - rockchip,pins = <7 RK_PC3 1 &pcfg_pull_none>, - <7 RK_PC4 1 &pcfg_pull_none>; - }; - }; - - i2s0 { - i2s0_bus: i2s0-bus { - rockchip,pins = <6 RK_PA0 1 &pcfg_pull_none>, - <6 RK_PA1 1 &pcfg_pull_none>, - <6 RK_PA2 1 &pcfg_pull_none>, - <6 RK_PA3 1 &pcfg_pull_none>, - <6 RK_PA4 1 &pcfg_pull_none>, - <6 RK_PB0 1 &pcfg_pull_none>; - }; - }; - - lcdc { - lcdc_ctl: lcdc-ctl { - rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>, - <1 RK_PD1 1 &pcfg_pull_none>, - <1 RK_PD2 1 &pcfg_pull_none>, - <1 RK_PD3 1 &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up>; - }; - - sdmmc_cd: sdmmc-cd { - rockchip,pins = <6 RK_PC6 1 &pcfg_pull_up>; - }; - - sdmmc_bus1: sdmmc-bus1 { - rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>; - }; - - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>, - <6 RK_PC1 1 &pcfg_pull_up>, - <6 RK_PC2 1 &pcfg_pull_up>, - <6 RK_PC3 1 &pcfg_pull_up>; - }; - }; - - sdio0 { - sdio0_bus1: sdio0-bus1 { - rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>; - }; - - sdio0_bus4: sdio0-bus4 { - rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>, - <4 RK_PC5 1 &pcfg_pull_up>, - <4 RK_PC6 1 &pcfg_pull_up>, - <4 RK_PC7 1 &pcfg_pull_up>; - }; - - sdio0_cmd: sdio0-cmd { - rockchip,pins = <4 RK_PD0 1 &pcfg_pull_up>; - }; - - sdio0_clk: sdio0-clk { - rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none>; - }; - - sdio0_cd: sdio0-cd { - rockchip,pins = <4 RK_PD2 1 &pcfg_pull_up>; - }; - - sdio0_wp: sdio0-wp { - rockchip,pins = <4 RK_PD3 1 &pcfg_pull_up>; - }; - - sdio0_pwr: sdio0-pwr { - rockchip,pins = <4 RK_PD4 1 &pcfg_pull_up>; - }; - - sdio0_bkpwr: sdio0-bkpwr { - rockchip,pins = <4 RK_PD5 1 &pcfg_pull_up>; - }; - - sdio0_int: sdio0-int { - rockchip,pins = <4 RK_PD6 1 &pcfg_pull_up>; - }; - }; - - sdio1 { - sdio1_bus1: sdio1-bus1 { - rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>; - }; - - sdio1_bus4: sdio1-bus4 { - rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>, - <3 RK_PD1 4 &pcfg_pull_up>, - <3 RK_PD2 4 &pcfg_pull_up>, - <3 RK_PD3 4 &pcfg_pull_up>; - }; - - sdio1_cd: sdio1-cd { - rockchip,pins = <3 RK_PD4 4 &pcfg_pull_up>; - }; - - sdio1_wp: sdio1-wp { - rockchip,pins = <3 RK_PD5 4 &pcfg_pull_up>; - }; - - sdio1_bkpwr: sdio1-bkpwr { - rockchip,pins = <3 RK_PD6 4 &pcfg_pull_up>; - }; - - sdio1_int: sdio1-int { - rockchip,pins = <3 RK_PD7 4 &pcfg_pull_up>; - }; - - sdio1_cmd: sdio1-cmd { - rockchip,pins = <4 RK_PA6 4 &pcfg_pull_up>; - }; - - sdio1_clk: sdio1-clk { - rockchip,pins = <4 RK_PA7 4 &pcfg_pull_none>; - }; - - sdio1_pwr: sdio1-pwr { - rockchip,pins = <4 RK_PB1 4 &pcfg_pull_up>; - }; - }; - - emmc { - emmc_clk: emmc-clk { - rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none>; - }; - - emmc_cmd: emmc-cmd { - rockchip,pins = <3 RK_PC0 2 &pcfg_pull_up>; - }; - - emmc_pwr: emmc-pwr { - rockchip,pins = <3 RK_PB1 2 &pcfg_pull_up>; - }; - - emmc_bus1: emmc-bus1 { - rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>; - }; - - emmc_bus4: emmc-bus4 { - rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, - <3 RK_PA1 2 &pcfg_pull_up>, - <3 RK_PA2 2 &pcfg_pull_up>, - <3 RK_PA3 2 &pcfg_pull_up>; - }; - - emmc_bus8: emmc-bus8 { - rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, - <3 RK_PA1 2 &pcfg_pull_up>, - <3 RK_PA2 2 &pcfg_pull_up>, - <3 RK_PA3 2 &pcfg_pull_up>, - <3 RK_PA4 2 &pcfg_pull_up>, - <3 RK_PA5 2 &pcfg_pull_up>, - <3 RK_PA6 2 &pcfg_pull_up>, - <3 RK_PA7 2 &pcfg_pull_up>; - }; - }; - - spi0 { - spi0_clk: spi0-clk { - rockchip,pins = <5 RK_PB4 1 &pcfg_pull_up>; - }; - spi0_cs0: spi0-cs0 { - rockchip,pins = <5 RK_PB5 1 &pcfg_pull_up>; - }; - spi0_tx: spi0-tx { - rockchip,pins = <5 RK_PB6 1 &pcfg_pull_up>; - }; - spi0_rx: spi0-rx { - rockchip,pins = <5 RK_PB7 1 &pcfg_pull_up>; - }; - spi0_cs1: spi0-cs1 { - rockchip,pins = <5 RK_PC0 1 &pcfg_pull_up>; - }; - }; - spi1 { - spi1_clk: spi1-clk { - rockchip,pins = <7 RK_PB4 2 &pcfg_pull_up>; - }; - spi1_cs0: spi1-cs0 { - rockchip,pins = <7 RK_PB5 2 &pcfg_pull_up>; - }; - spi1_rx: spi1-rx { - rockchip,pins = <7 RK_PB6 2 &pcfg_pull_up>; - }; - spi1_tx: spi1-tx { - rockchip,pins = <7 RK_PB7 2 &pcfg_pull_up>; - }; - }; - - spi2 { - spi2_cs1: spi2-cs1 { - rockchip,pins = <8 RK_PA3 1 &pcfg_pull_up>; - }; - spi2_clk: spi2-clk { - rockchip,pins = <8 RK_PA6 1 &pcfg_pull_up>; - }; - spi2_cs0: spi2-cs0 { - rockchip,pins = <8 RK_PA7 1 &pcfg_pull_up>; - }; - spi2_rx: spi2-rx { - rockchip,pins = <8 RK_PB0 1 &pcfg_pull_up>; - }; - spi2_tx: spi2-tx { - rockchip,pins = <8 RK_PB1 1 &pcfg_pull_up>; - }; - }; - - uart0 { - uart0_xfer: uart0-xfer { - rockchip,pins = <4 RK_PC0 1 &pcfg_pull_up>, - <4 RK_PC1 1 &pcfg_pull_none>; - }; - - uart0_cts: uart0-cts { - rockchip,pins = <4 RK_PC2 1 &pcfg_pull_up>; - }; - - uart0_rts: uart0-rts { - rockchip,pins = <4 RK_PC3 1 &pcfg_pull_none>; - }; - }; - - uart1 { - uart1_xfer: uart1-xfer { - rockchip,pins = <5 RK_PB0 1 &pcfg_pull_up>, - <5 RK_PB1 1 &pcfg_pull_none>; - }; - - uart1_cts: uart1-cts { - rockchip,pins = <5 RK_PB2 1 &pcfg_pull_up>; - }; - - uart1_rts: uart1-rts { - rockchip,pins = <5 RK_PB3 1 &pcfg_pull_none>; - }; - }; - - uart2 { - uart2_xfer: uart2-xfer { - rockchip,pins = <7 RK_PC6 1 &pcfg_pull_up>, - <7 RK_PC7 1 &pcfg_pull_none>; - }; - /* no rts / cts for uart2 */ - }; - - uart3 { - uart3_xfer: uart3-xfer { - rockchip,pins = <7 RK_PA7 1 &pcfg_pull_up>, - <7 RK_PB0 1 &pcfg_pull_none>; - }; - - uart3_cts: uart3-cts { - rockchip,pins = <7 RK_PB1 1 &pcfg_pull_up>; - }; - - uart3_rts: uart3-rts { - rockchip,pins = <7 RK_PB2 1 &pcfg_pull_none>; - }; - }; - - uart4 { - uart4_xfer: uart4-xfer { - rockchip,pins = <5 RK_PB7 3 &pcfg_pull_up>, - <5 RK_PB6 3 &pcfg_pull_none>; - }; - - uart4_cts: uart4-cts { - rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>; - }; - - uart4_rts: uart4-rts { - rockchip,pins = <5 RK_PB5 3 &pcfg_pull_none>; - }; - }; - - tsadc { - otp_pin: otp-pin { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - otp_out: otp-out { - rockchip,pins = <0 RK_PB2 1 &pcfg_pull_none>; - }; - }; - - pwm0 { - pwm0_pin: pwm0-pin { - rockchip,pins = <7 RK_PA0 1 &pcfg_pull_none>; - }; - }; - - pwm1 { - pwm1_pin: pwm1-pin { - rockchip,pins = <7 RK_PA1 1 &pcfg_pull_none>; - }; - }; - - pwm2 { - pwm2_pin: pwm2-pin { - rockchip,pins = <7 RK_PC6 3 &pcfg_pull_none>; - }; - }; - - pwm3 { - pwm3_pin: pwm3-pin { - rockchip,pins = <7 RK_PC7 3 &pcfg_pull_none>; - }; - }; - - gmac { - rgmii_pins: rgmii-pins { - rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, - <3 RK_PD7 3 &pcfg_pull_none>, - <3 RK_PD2 3 &pcfg_pull_none>, - <3 RK_PD3 3 &pcfg_pull_none>, - <3 RK_PD4 3 &pcfg_pull_none_12ma>, - <3 RK_PD5 3 &pcfg_pull_none_12ma>, - <3 RK_PD0 3 &pcfg_pull_none_12ma>, - <3 RK_PD1 3 &pcfg_pull_none_12ma>, - <4 RK_PA0 3 &pcfg_pull_none>, - <4 RK_PA5 3 &pcfg_pull_none>, - <4 RK_PA6 3 &pcfg_pull_none>, - <4 RK_PB1 3 &pcfg_pull_none_12ma>, - <4 RK_PA4 3 &pcfg_pull_none_12ma>, - <4 RK_PA1 3 &pcfg_pull_none>, - <4 RK_PA3 3 &pcfg_pull_none>; - }; - - rmii_pins: rmii-pins { - rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, - <3 RK_PD7 3 &pcfg_pull_none>, - <3 RK_PD4 3 &pcfg_pull_none>, - <3 RK_PD5 3 &pcfg_pull_none>, - <4 RK_PA0 3 &pcfg_pull_none>, - <4 RK_PA5 3 &pcfg_pull_none>, - <4 RK_PA4 3 &pcfg_pull_none>, - <4 RK_PA1 3 &pcfg_pull_none>, - <4 RK_PA2 3 &pcfg_pull_none>, - <4 RK_PA3 3 &pcfg_pull_none>; - }; - }; - - spdif { - spdif_tx: spdif-tx { - rockchip,pins = <6 RK_PB3 1 &pcfg_pull_none>; - }; - }; - }; -}; diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 4d3157b2edd3..a9420406649c 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -131,6 +131,7 @@ config ROCKCHIP_RK3288 select SPL select SUPPORT_TPL select FDT_64BIT + imply OF_UPSTREAM imply PRE_CONSOLE_BUFFER imply ROCKCHIP_COMMON_BOARD imply SPL_ROCKCHIP_COMMON_BOARD diff --git a/board/chipspark/popmetal_rk3288/MAINTAINERS b/board/chipspark/popmetal_rk3288/MAINTAINERS index e12f128dcd70..9b1001260c78 100644 --- a/board/chipspark/popmetal_rk3288/MAINTAINERS +++ b/board/chipspark/popmetal_rk3288/MAINTAINERS @@ -1,7 +1,5 @@ POPMETAL-RK3288 -M: Lin Huang hl@rock-chips.com -S: Maintained -F: arch/arm/dts/rk3288-popmetal.dts +S: Orphan F: arch/arm/dts/rk3288-popmetal-u-boot.dtsi F: board/chipspark/popmetal_rk3288 F: include/configs/popmetal_rk3288.h diff --git a/board/google/veyron/MAINTAINERS b/board/google/veyron/MAINTAINERS index 67341b5d5564..382ad212569a 100644 --- a/board/google/veyron/MAINTAINERS +++ b/board/google/veyron/MAINTAINERS @@ -1,7 +1,6 @@ CHROMEBOOK JERRY BOARD M: Simon Glass sjg@chromium.org S: Maintained -F: arch/arm/dts/rk3288-veyron-jerry.dts F: arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi F: board/google/veyron/ F: include/configs/veyron.h @@ -10,7 +9,6 @@ F: configs/chromebook_jerry_defconfig CHROMEBIT MICKEY BOARD M: Simon Glass sjg@chromium.org S: Maintained -F: arch/arm/dts/rk3288-veyron-mickey.dts F: arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi F: board/google/veyron/ F: include/configs/veyron.h @@ -19,7 +17,6 @@ F: configs/chromebit_mickey_defconfig CHROMEBOOK MINNIE BOARD M: Simon Glass sjg@chromium.org S: Maintained -F: arch/arm/dts/rk3288-veyron-minnie.dts F: arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi F: board/google/veyron/ F: include/configs/veyron.h @@ -28,7 +25,6 @@ F: configs/chromebook_minnie_defconfig CHROMEBOOK SPEEDY BOARD M: Simon Glass sjg@chromium.org S: Maintained -F: arch/arm/dts/rk3288-veyron-speedy.dts F: arch/arm/dts/rk3288-veyron-speedy-u-boot.dtsi F: board/google/veyron/ F: include/configs/veyron.h @@ -37,8 +33,4 @@ F: configs/chromebook_speedy_defconfig CHROMEBOOK VEYRON COMMON FILES M: Simon Glass sjg@chromium.org S: Maintained -F: arch/arm/dts/rk3288-veyron.dtsi -F: arch/arm/dts/rk3288-veyron-analog-audio.dtsi -F: arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi -F: arch/arm/dts/rk3288-veyron-chromebook.dtsi -F: arch/arm/dts/rk3288-veyron-edp.dtsi +F: arch/arm/dts/rk3288-veyron-u-boot.dtsi diff --git a/board/mqmaker/miqi_rk3288/MAINTAINERS b/board/mqmaker/miqi_rk3288/MAINTAINERS index 1cb5f790fe78..8f25ec76a8b8 100644 --- a/board/mqmaker/miqi_rk3288/MAINTAINERS +++ b/board/mqmaker/miqi_rk3288/MAINTAINERS @@ -1,7 +1,5 @@ MIQI -M: Jernej Skrabec jernej.skrabec@siol.net -S: Maintained -F: arch/arm/dts/rk3288-miqi.dts +S: Orphan F: arch/arm/dts/rk3288-miqi-u-boot.dtsi F: board/mqmaker/miqi_rk3288 F: include/configs/miqi_rk3288.h diff --git a/board/rockchip/evb_rk3288/MAINTAINERS b/board/rockchip/evb_rk3288/MAINTAINERS index 9857ae335754..74a15438d231 100644 --- a/board/rockchip/evb_rk3288/MAINTAINERS +++ b/board/rockchip/evb_rk3288/MAINTAINERS @@ -1,12 +1,9 @@ EVB-RK3288 -M: Lin Huang hl@rock-chips.com -S: Maintained -F: arch/arm/dts/rk3288-evb.dts -F: arch/arm/dts/rk3288-evb.dtsi +S: Orphan F: arch/arm/dts/rk3288-evb-u-boot.dtsi F: board/rockchip/evb_rk3288 F: include/configs/evb_rk3288.h -F: configs/evb-rk3288_defconfig +F: configs/evb-rk808-rk3288_defconfig
ROCK-PI-N8 M: Jagan Teki jagan@amarulasolutions.com diff --git a/board/rockchip/tinker_rk3288/MAINTAINERS b/board/rockchip/tinker_rk3288/MAINTAINERS index 3869d5dc8534..38eb76c81ea8 100644 --- a/board/rockchip/tinker_rk3288/MAINTAINERS +++ b/board/rockchip/tinker_rk3288/MAINTAINERS @@ -1,10 +1,5 @@ TINKER-RK3288 -M: Lin Huang hl@rock-chips.com -S: Maintained -F: arch/arm/dts/rk3288-tinker.dts -F: arch/arm/dts/rk3288-tinker.dtsi -F: arch/arm/dts/rk3288-tinker-s.dts -F: arch/arm/dts/rk3288-tinker-s-u-boot.dtsi +S: Orphan F: arch/arm/dts/rk3288-tinker-u-boot.dtsi F: board/rockchip/tinker_rk3288 F: include/configs/tinker_rk3288.h @@ -13,6 +8,7 @@ F: configs/tinker-rk3288_defconfig TINKER-S-RK3288 M: Michael Trimarchi michael@amarulasolutions.com S: Maintained +F: arch/arm/dts/rk3288-tinker-s-u-boot.dtsi F: board/rockchip/tinker_rk3288 F: include/configs/tinker_rk3288.h F: configs/tinker-s-rk3288_defconfig diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 874f266dad1b..dd069a2d493c 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -8,7 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-veyron-mickey" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-veyron-mickey" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -29,7 +29,7 @@ CONFIG_SPL_SPI=y CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-mickey.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-veyron-mickey.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_LOG=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index f40b8e84e39e..e46e675e0144 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -8,7 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-veyron-jerry" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-veyron-jerry" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -28,7 +28,7 @@ CONFIG_SPL_SPI=y CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-jerry.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-veyron-jerry.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_LOG=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 2f125ba12adb..acdb45f29c8b 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -8,7 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-veyron-minnie" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-veyron-minnie" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -29,7 +29,7 @@ CONFIG_SPL_SPI=y CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-minnie.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-veyron-minnie.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_LOG=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index c19b0905d5cf..e258cdfb4819 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -8,7 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-veyron-speedy" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-veyron-speedy" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -29,7 +29,7 @@ CONFIG_SPL_SPI=y CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-speedy.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-veyron-speedy.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_LOG=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk808-rk3288_defconfig similarity index 95% rename from configs/evb-rk3288_defconfig rename to configs/evb-rk808-rk3288_defconfig index ae79efebf57a..c7e48848ebf9 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk808-rk3288_defconfig @@ -9,7 +9,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-evb-rk808" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -29,7 +29,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-evb-rk808.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-evb-rk808.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 00f23174210f..e1cc78f620f1 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -9,7 +9,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-firefly" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -26,7 +26,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-firefly.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-firefly.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index 420a8bd1e798..ca7845a0941a 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -8,7 +8,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-miqi" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-miqi" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -26,7 +26,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-miqi.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-miqi.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 0f8e999ee3f9..89cfd38980dc 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -48,7 +48,6 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_UPSTREAM=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 1b2fb4a38cd4..c454349d4bc9 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -8,7 +8,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-popmetal" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-popmetal" CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y @@ -25,7 +25,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-popmetal.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-popmetal.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index dde0b81eee4c..e73c8b4aa041 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -10,7 +10,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock-pi-n8" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-rock-pi-n8" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index bff65d1fc414..bbf0c9a39c44 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -8,7 +8,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-rock2-square" CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y @@ -25,7 +25,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-rock2-square.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-rock2-square.dtb" CONFIG_SILENT_CONSOLE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 42dbef9c2c30..93085c5217d8 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -10,7 +10,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-tinker" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -27,7 +27,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-tinker.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-tinker.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig index e62a03e066cc..097365345517 100644 --- a/configs/tinker-s-rk3288_defconfig +++ b/configs/tinker-s-rk3288_defconfig @@ -10,7 +10,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker-s" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-tinker-s" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -27,7 +27,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-tinker-s.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-tinker-s.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index e75466c1cad9..75d36bd1f78d 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -11,7 +11,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-vyasa" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3288-vyasa" CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=614400 CONFIG_ROCKCHIP_RK3288=y @@ -26,7 +26,7 @@ CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3288-vyasa.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3288-vyasa.dtb" CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_PAD_TO=0x7f8000 diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9bab86d23479..4633b58e6470 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -40,15 +40,16 @@ List of mainline supported Rockchip boards: * rk3229 - Rockchip Evb-RK3229 (evb-rk3229) * rk3288 - - Rockchip Evb-RK3288 (evb-rk3288) + - Rockchip Evb RK808-RK3288 (evb-rk808-rk3288) - Firefly-RK3288 (firefly-rk3288) - MQmaker MiQi (miqi-rk3288) - Phytec RK3288 PCM-947 (phycore-rk3288) - PopMetal-RK3288 (popmetal-rk3288) - Radxa Rock 2 Square (rock2) + - Radxa Rock Pi N8 (rock-pi-n8-rk3288) - Tinker-RK3288 (tinker-rk3288) - Google Jerry (chromebook_jerry) - - Google Mickey (chromebook_mickey) + - Google Mickey (chromebit_mickey) - Google Minnie (chromebook_minnie) - Google Speedy (chromebook_speedy) - Amarula Vyasa-RK3288 (vyasa-rk3288) -- 2.39.5
Hi Johan,
On 2024-12-09 13:30, Johan Jonker wrote:
The device tree for rk3288 combined is now available in the /dts/upstream directory. Use imply OF_UPSTREAM to migrate all rk3288 boards. Clean up MAINTAINERS.
Signed-off-by: Johan Jonker jbx6244@gmail.com
[snip]
Please rebase this on top of the following series:
rockchip: rk3288: Include files from dts/upstream https://patchwork.ozlabs.org/project/uboot/cover/20241109210427.884888-1-jon...
rockchip: rk3288-tinker: Migrate to OF_UPSTREAM https://patchwork.ozlabs.org/project/uboot/cover/20241105160054.1373319-1-jo...
rockchip: rk3288-miqi: Migrate to OF_UPSTREAM https://patchwork.ozlabs.org/project/uboot/cover/20241105215202.1491441-1-jo...
Similar cleanup/fixes should/could be made to other rk3328 targets. Already have one for rk3288-firefly incoming.
Regards, Jonas
Johan Jonker
Jonas Karlman
