[U-Boot] [GIT PULL] u-boot-sunxi/master
Hi Tom,
Here are a few changes that would be great to merge.
It's basically a few fixes for CPU frequencies that were underclocked, fastboot that was broken on a NAND-based device (the CHIP Pro, and it also moves the fastboot NAND option to Kconfig in the process), some missing options, one board, and the size check and size reduction patches that we discussed at length.
Thanks! Maxime
The following changes since commit 4c7a211046a3956058b512edd8533f7df031cc4a:
Kconfig: add CONFIG_BROKEN (2017-10-23 17:28:18 -0400)
git://git.denx.de/u-boot-sunxi master
for you to fetch changes up to 819f1e081c527d2d02cdaeec0027384688cf5de0:
sunxi: binman: Add U-Boot binary size check (2017-10-25 10:05:06 +0200)
---------------------------------------------------------------- Andre Przywara (1): SPL: SPI: select SPL_SPI_FLASH_SUPPORT on SPL_SPI_SUNXI
Benjamin Young (1): cmd: fastboot: Enable FASTBOOT_FLASH_NAND for SUNXI_NAND devices
Maxime Ripard (3): sunxi: Add support for the Banana Pi M2-Magic sunxi: Enable THUMB build for the U-Boot binary sunxi: binman: Add U-Boot binary size check
Quentin Schulz (1): sunxi: clk: fix N formula for CPUX clocks
arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/sun8i-r16-bananapi-m2m.dts | 321 +++++++++++++++++++++ arch/arm/dts/sunxi-u-boot.dtsi | 12 + arch/arm/include/asm/arch-sunxi/clock_sun8i_a83t.h | 2 +- cmd/fastboot/Kconfig | 10 + configs/Bananapi_m2m_defconfig | 21 ++ configs/orangepi_pc2_defconfig | 1 - configs/orangepi_zero_defconfig | 1 - drivers/mtd/spi/Kconfig | 1 + 10 files changed, 368 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/sun8i-r16-bananapi-m2m.dts create mode 100644 configs/Bananapi_m2m_defconfig
On Thu, Oct 26, 2017 at 05:19:21PM +0200, Maxime Ripard wrote:
Hi Tom,
Thanks! Maxime
Maxime Ripard
