[U-Boot] Query on the ci_udc driver for USB client implementation
Hello,
I am currently implementing USB Host and client support for Freescale Vybrid platform in u-boot. I managed to get the host implementation working.
For the host side, usb start calls usb_init(), which in turns call, usb_lowlevel_init(), from there into the ehic_hcd_init() of my implementation. So, setting up the necessary clocks and plls for USB in my implementation and then setting up the usb_ehci, ehci_hccr and echi_hcor structures was all. The flow and setup required i was able to trace.
The USB client part is not clear to me. I was thinking i can use the ci_udc driver somehow to implement the client part. How can i use the ci_udc driver to implement client functionality?. From what i could see, the usb_gadget_driver_register() is suppose to be the first call. But, i couldn't trace from where this gets called or the flow and setup is suppose to be. OR Is a separate client driver required and nothing generic can be used akin to how it could be done for host?
Sorry if i am asking this question in the wrong place. I couldn't find anyone in the u-boot IRC channel nor find something similar to the kernel-newbies mailing list.
Hope i am asking the right questions.
Thanks & Regards, Sanchayan Maity.
Hello,
Any pointers?
On Thursday 30 October 2014 11:14 AM, Sanchayan Maity wrote:
Hello,
On Mon, Nov 3, 2014 at 3:33 AM, Sanchayan Maity maitysanchayan@gmail.com wrote:
Hello,
Any pointers?
Adding Marek and Stefan on Cc in case they can provide some help.
Regards,
Fabio Estevam
Hello,
Hello,
Any pointers?
Regards,
Fabio Estevam
Hello,
See include/configs/sansa_fuze_plus.h , you need the gadget driver for the function you want to implement , in this case it's ethernet for example (selected via CONFIG_USB_ETH_CDC ).
An example of DFU/UMS can be found in include/configs/exynos4-common.h and to activate those, you need to use the 'dfu' or 'ums' commands.
There isn't any, so ask away ;-)
Best regards, Marek Vasut
Hello,
Any pointers?
Regards,
Fabio Estevam
Hello,
Thank you Marek. I had enabled usb ether options already and was trying to test USB client functionality with RNDIS. For some reason it was not working and i was not able to trace the issue and subsequently was not sure about the client part. Your inputs cleared my doubts. I tried UMS and DFU. UMS is working just fine and i can download the respective images through DFU. Though this DFU is not working full proof, but, i can figure that out now i feel.
Thanks again for your inputs. Cheers!
Best Regards, Sanchayan.
Hi Sanchayan,
Hello,
Any pointers?
Regards,
Fabio Estevam
Hello,
I'm very happy that UMS is working seamlessly. What kind of trouble do you have with DFU?
On Tuesday 04 November 2014 09:58 PM, Lukasz Majewski wrote:
Hi Sanchayan,
Hello,
Any pointers?
Regards,
Fabio Estevam
Hello,
Hello,
I have a memory alignment problem with DFU as of now.
mtdparts is as below device nand0 <fsl_nfc>, # parts = 4 #: name size offset mask_flags 0: vf-bcb 0x00020000 0x00000000 1 1: u-boot 0x00160000 0x00020000 1 2: u-boot-env 0x00080000 0x00180000 0 3: ubi 0x3fe00000 0x00200000 0
active partition: nand0,0 - (vf-bcb) 0x00020000 @ 0x00000000
defaults: mtdids : nand0=fsl_nfc mtdparts: mtdparts=fsl_nfc:128k(vf-bcb)ro,1408k(u-boot)ro,512k(u-boot-env),-(ubi)
As per the above, setenv dfu_alt_info "vf-bcb part 0,1;u-boot part 0,2;ubi part 0,4" and CONFIG_SYS_CACHELINE_SIZE is 32.
I have a ubifs image and i was trying to write it by running "dfu 0 nand 4" in u-boot and "sudo dfu-util -D ubifs.img -a ubi" on the host. I got the error as below.
"dfu_get_buf: Could not memalign 0x800000 bytes
Setting CONFIG_SYS_DFU_DATA_BUF_SIZE to (1024*1024) resolved this. After this, trying an update as above, did not give me an updated ubi (which i check by booting to user space) and doing a nand erase.part on ubi partition and then repeating the procedure results in ""Bad Linux ARM zImage magic!". After looking a bit online, at the below two links
http://lists.denx.de/pipermail/u-boot/2013-May/155089.html http://www.linux-mtd.infradead.org/faq/ubifs.html#L_mkfubifs
I started trying ubinize. Getting the memory alignment issues again now :). I have tried 1, 2, 4 and 8Mb for the dfu data buffer size. So i am trying to figure this out at the moment. I am probably missing something. :)
--Best Regards, Sanchayan.
Hi Sanchayan,
Hi Sanchayan,
Hello,
Any pointers?
Regards,
Fabio Estevam
On Thursday 30 October 2014 11:14 AM, Sanchayan Maity wrote: > Hello, > > I am currently implementing USB Host and client support for > Freescale Vybrid platform in u-boot. I managed to get the host > implementation working. > > For the host side, usb start calls usb_init(), which in turns > call, usb_lowlevel_init(), from there into the ehic_hcd_init() > of my implementation. So, setting up the necessary clocks and > plls for USB in my implementation and then setting up the > usb_ehci, ehci_hccr and echi_hcor structures was all. The flow > and setup required i was able to trace. > > The USB client part is not clear to me. I was thinking i can > use the ci_udc driver somehow to implement the client part. > How can i use the ci_udc driver to implement client > functionality?. From what i could see, the > usb_gadget_driver_register() is suppose to be the first call. > But, i couldn't trace from where this gets called or the flow > and setup is suppose to be. OR Is a separate client driver > required and nothing generic can be used akin to how it could > be done for host?
Hello,
On our boards we have eMMC memory, so I'm not so familiar with NAND DFU problems.
However, I would advise you to pose this question to any of AM335x boards maintainer (e.g. Tom Rini) since they use NAND on their boards.
> Sorry if i am asking this question in the wrong place. I > couldn't find anyone in the u-boot IRC channel nor find > something similar to the kernel-newbies mailing list.
Fabio Estevam
Lukasz Majewski
Sanchayan Maity
